由于目前的TensorFlow版本比较老旧导致很多算法和语法不通用编译报错,且没有几个贴详细说明如何在arm64上安装TensorFlow,借此为理由,写下人生第一个博客和firefly帖子。
—from中山
注意,安装的过程中会自动下载必须的包,需要连接好网络。脱机安装很可能失败。
1.安装必要的python环境
[b]
<font color="Black">sudo apt-get install libpython3.5-dev wget python3-pip python3-dev python3.5</font>
[/b]2.下载和安装别人编译好的arm(aarch64)版本tensorflow(因为自己编译需要配大量环境和占用很多资源,对于嵌入式板上编译就变得非常不可能,且现有的方法更为简便)
网上有别人编译好的TensorFlow,找到相应的文件。Releases · lhelontra/tensorflow-on-arm · GitHub
#使用wget下载tensorflow-1.9.0-cp35-none-linux_aarch64.whl到当前目录
#命名规则:cp35对赢python3.5,aarch64表示架构信息
wget https://github.com/lhelontra/tensorflow-on-arm/releases/download/v1.9.0/tensorflow-1.9.0-cp35-none-linux_aarch64.whl
#必须制定使用python3.5安装tensorflow-1.9.0-cp35-none-linux_aarch64.whl
sudo python3.5 -m pip install tensorflow-1.9.0-cp35-none-linux_aarch64.whl
到此为止,TensorFlow已经安装完成了
3.修改python默认为python3.5
为了因为C++调用python时,默认是调用python2.7,这导致很多python3.5的语法报错。所以需要更改python默认软连接
firefly@firefly:~/opencv-3-2$ python
Python 3.5.2 (default, Nov 23 2017, 16:37:01)
[GCC 5.4.0 20160609] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import tensorflow as tf
>>> hello = tf.constant('Hello world!')
>>> sess = tf.Session()
>>> print(sess.run(hello))
b'Hello world!'
测试调用一下:
>>> sess = tf.Session()
b'Hello world!'
4.出现的错误
有时候可能会出现缺少库额问题 bstdc++.so.6: version `GLIBCXX_3.4.22’ not found (required by /usr/local/lib/python3.5/dist-packages/tensorflow/python/_pywrap_tensorflow_internal.so
参考: libstdc++.so.6: version `GLIBCXX3.4.22’ not found
File "/usr/lib/python3.5/imp.py", line 242, in load_module
return load_dynamic(name, filename, file)
File "/usr/lib/python3.5/imp.py", line 342, in load_dynamic
return _load(spec)
ImportError: /usr/lib/aarch64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.22' not found (required by /usr/local/lib/python3.5/dist-packages/tensorflow/python/_pywrap_tensorflow_internal.so)
Failed to load the native TensorFlow runtime.
See https://www.tensorflow.org/install/install_sources#common_installation_problems
for some common reasons and solutions. Include the entire stack trace
above this error message when asking for help.
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
参考文献:
