ubuntu 14.04 4GB内存 ,16GB交换空间 ,按照http://dev.t-firefly.com/forum.php?mod=viewthread&tid=12165&highlight=android7.1 这个帖子进行编译 ,
报错:
Building with Jack: out/ta…agment-gingerbread_intermediates/classes.jack
FAILED: /bin/bash -c “(rm -f out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/classes.jack ) && (rm -rf out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/jack-rsc ) && (mkdir -p out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/ ) && (mkdir -p out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/jack-rsc ) && (rm -f out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/jack-rsc/java-source-list ) && (touch out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/jack-rsc/java-source-list ) && (echo -n 'frameworks/support/fragment/gingerbread/android/support/v4/app/BaseFragmentActivityGingerbread.java ’ >> out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/jack-rsc/java-source-list ) && (if [ -d "out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/src" ]; then find out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/src -name ‘*.java’ >> out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/jack-rsc/java-source-list; fi ) && (tr ’ ’ ‘\n’ < out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/jack-rsc/java-source-list | build/tools/normalize_path.py | sort -u > out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/jack-rsc/java-source-list-uniq ) && (if [ -s out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/jack-rsc/java-source-list-uniq ] ; then export tmpEcjArg="@out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/jack-rsc/java-source-list-uniq"; else export tmpEcjArg=""; fi; JACK_VERSION=3.36.CANDIDATE out/host/linux-x86/bin/jack @build/core/jack-default.args --verbose error -g -D jack.java.source.version=1.7 --classpath out/target/common/obj/JAVA_LIBRARIES/sdk_v9_intermediates/classes.jack:out/target/common/obj/JAVA_LIBRARIES/android-support-annotations_intermediates/classes.jack:out/target/common/obj/JAVA_LIBRARIES/android-support-compat_intermediates/classes.jack:out/target/common/obj/JAVA_LIBRARIES/android-support-core-ui_intermediates/classes.jack:out/target/common/obj/JAVA_LIBRARIES/android-support-core-utils_intermediates/classes.jack:out/target/common/obj/JAVA_LIBRARIES/android-support-media-compat_intermediates/classes.jack:out/target/common/obj/JAVA_LIBRARIES/sdk_v9_intermediates/classes.jack -D jack.import.resource.policy=keep-first -D jack.import.type.policy=keep-first -D jack.android.min-api-level=9 --output-jack out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/classes.jack $tmpEcjArg || ( rm -f out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/classes.jack ; exit 41 ) ) && (rm -f out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/jack-rsc/java-source-list ) && (mv out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/jack-rsc/java-source-list-uniq out/target/common/obj/JAVA_LIBRARIES/android-support-fragment-gingerbread_intermediates/jack-rsc.java-source-list )”
Communication error with Jack server (28). Try ‘jack-diagnose’
[ 39% 19475/48820] Building with Jack: out/ta…RARIES/xmp_toolkit_intermediates/classes.jack
该如何解决?
