firefly-rk3399 ubuntu18.04 进入不了桌面
各位大神们,有在firefly-3399上移植ubuntu18.04的吗
我按照wiki上移植进入不了桌面,连接HDMI左上角光标闪烁,串口输入sudo startx后log如下
X.Org X Server 1.19.6
Release Date: 2017-12-20
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.4.0-119-generic aarch64 Ubuntu
Current Operating System: Linux localhost.localdomain 4.4.77 #329 SMP Mon Dec 18 15:44:03 CST 2017 aarch64
Kernel command line: console=ttyFIQ0 root=/dev/mmcblk1p6 rw rootwait mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00008000@0x00006000(resource),0x0000A000@0x0000E000(kernel),0x00002000@0x00018000(backup),-@0x0001A000(boot) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2017-03-28_11:12:22 androidboot.mode=emmc
Build Date: 13 April 2018 08:08:56PM
xorg-server 2:1.19.6-1ubuntu4 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (–) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: “/var/log/Xorg.0.log”, Time: Mon Jan 29 00:11:38 2018
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
gbm: failed to open any driver (search paths /usr/lib/aarch64-linux-gnu/dri:${ORIGIN}/dri:/usr/lib/dri)
gbm: Last dlopen error: /usr/lib/dri/rockchip_dri.so: cannot open shared object file: No such file or directory
failed to load driver: rockchip
EGL_MESA_drm_image required.
xinit: connection to X server lost
waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
sudo cat /var/log/Xorg.0.log 后
[ 1000.589] X Protocol Version 11, Revision 0
[ 1000.589] Build Operating System: Linux 4.4.0-119-generic aarch64 Ubuntu
[ 1000.590] Current Operating System: Linux localhost.localdomain 4.4.77 #329 SMP Mon Dec 18 15:44:03 CST 2017 aarch64
[ 1000.590] Kernel command line: console=ttyFIQ0 root=/dev/mmcblk1p6 rw rootwait mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00008000@0x00006000(resource),0x0000A000@0x0000E000(kernel),0x00002000@0x00018000(backup),-@0x0001A000(boot) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2017-03-28_11:12:22 androidboot.mode=emmc
[ 1000.593] Build Date: 13 April 2018 08:08:56PM
[ 1000.594] xorg-server 2:1.19.6-1ubuntu4 (For technical support please see http://www.ubuntu.com/support)
[ 1000.594] Current version of pixman: 0.34.0
[ 1000.595] Before reporting problems, check http://wiki.x.org
[ 1000.595] Markers: (–) probed, () from config file, (==) default setting,
[ 1000.597] (==) Log file: “/var/log/Xorg.0.log”, Time: Mon Jan 29 00:14:55 2018
[ 1000.597] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 1000.598] (==) No Layout section. Using the first Screen section.
[ 1000.598] (==) No screen section available. Using defaults.
[ 1000.598] (
) |–>Screen “Default Screen Section” (0)
[ 1000.598] (**) | |–>Monitor “”
[ 1000.599] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 1000.599] (==) Automatically adding devices
[ 1000.599] (==) Automatically enabling devices
[ 1000.599] (==) Automatically adding GPU devices
[ 1000.599] (==) Automatically binding GPU devices
[ 1000.599] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 1000.599] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 1000.599] Entry deleted from font path.
[ 1000.599] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 1000.599] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 1000.599] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 1000.600] Entry deleted from font path.
[ 1000.600] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 1000.600] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 1000.600] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 1000.600] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 1000.600] (II) Loader magic: 0x556fa56010
[ 1000.600] (II) Module ABI versions:
[ 1000.600] X.Org ANSI C Emulation: 0.4
[ 1000.600] X.Org Video Driver: 23.0
[ 1000.600] X.Org XInput driver : 24.1
[ 1000.600] X.Org Server Extension : 10.0
[ 1000.607] (–) using VT number 2
[ 1000.607] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 1000.611] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 1000.612] (II) no primary bus or device found
[ 1000.612] falling back to /sys/devices/platform/display-subsystem/drm/card0
[ 1000.612] (II) LoadModule: “glx”
[ 1000.614] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 1000.621] (II) Module glx: vendor=“X.Org Foundation”
[ 1000.621] compiled for 1.19.6, module version = 1.0.0
[ 1000.621] ABI class: X.Org Server Extension, version 10.0
[ 1000.621] (==) Matched modesetting as autoconfigured driver 0
[ 1000.621] (==) Matched fbdev as autoconfigured driver 1
[ 1000.621] (==) Assigned the driver to the xf86ConfigLayout
[ 1000.621] (II) LoadModule: “modesetting”
[ 1000.622] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 1000.623] (II) Module modesetting: vendor=“X.Org Foundation”
[ 1000.623] compiled for 1.19.6, module version = 1.19.6
[ 1000.623] Module class: X.Org Video Driver
[ 1000.623] ABI class: X.Org Video Driver, version 23.0
[ 1000.623] (II) LoadModule: “fbdev”
[ 1000.624] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 1000.625] (II) Module fbdev: vendor=“X.Org Foundation”
[ 1000.625] compiled for 1.19.3, module version = 0.4.4
[ 1000.625] Module class: X.Org Video Driver
[ 1000.625] ABI class: X.Org Video Driver, version 23.0
[ 1000.625] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 1000.625] (II) FBDEV: driver for framebuffer: fbdev
[ 1000.659] (II) modeset(0): using drv /dev/dri/card0
[ 1000.660] (WW) Falling back to old probe method for fbdev
[ 1000.660] (II) Loading sub module “fbdevhw”
[ 1000.660] (II) LoadModule: “fbdevhw”
[ 1000.660] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 1000.661] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 1000.661] compiled for 1.19.6, module version = 0.0.2
[ 1000.661] ABI class: X.Org Video Driver, version 23.0
[ 1000.661] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 1000.661] (II) modeset(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 1000.661] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 1000.661] (==) modeset(0): RGB weight 888
[ 1000.661] (==) modeset(0): Default visual is TrueColor
[ 1000.661] (II) Loading sub module “glamoregl”
[ 1000.661] (II) LoadModule: “glamoregl”
[ 1000.662] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 1000.677] (II) Module glamoregl: vendor=“X.Org Foundation”
[ 1000.677] compiled for 1.19.6, module version = 1.0.0
[ 1000.677] ABI class: X.Org ANSI C Emulation, version 0.4
[ 1000.677] (II) glamor: OpenGL accelerated X.org driver based.
[ 1000.781] (II) glamor: EGL version 1.4 (DRI2):
[ 1000.781] EGL_MESA_drm_image required.
[ 1000.782] (EE) modeset(0): glamor initialization failed
[ 1000.782] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[ 1000.935] (II) modeset(0): Output HDMI-1 has no monitor section
[ 1001.079] (II) modeset(0): EDID for output HDMI-1
[ 1001.079] (II) modeset(0): Manufacturer: SAM Model: c45 Serial#: 16777217
[ 1001.079] (II) modeset(0): Year: 2014 Week: 42
[ 1001.079] (II) modeset(0): EDID Version: 1.3
[ 1001.079] (II) modeset(0): Digital Display Input
[ 1001.079] (II) modeset(0): Max Image Size [cm]: horiz.: 142 vert.: 80
[ 1001.079] (II) modeset(0): Gamma: 2.20
[ 1001.079] (II) modeset(0): No DPMS capabilities specified
[ 1001.079] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 1001.080] (II) modeset(0): First detailed timing is preferred mode
[ 1001.080] (II) modeset(0): redX: 0.641 redY: 0.330 greenX: 0.301 greenY: 0.601
[ 1001.080] (II) modeset(0): blueX: 0.150 blueY: 0.061 whiteX: 0.280 whiteY: 0.290
[ 1001.080] (II) modeset(0): Supported established timings:
[ 1001.080] (II) modeset(0): 720x400@70Hz
[ 1001.080] (II) modeset(0): 640x480@60Hz
[ 1001.080] (II) modeset(0): 640x480@67Hz
[ 1001.080] (II) modeset(0): 640x480@72Hz
[ 1001.080] (II) modeset(0): 640x480@75Hz
[ 1001.080] (II) modeset(0): 800x600@60Hz
[ 1001.080] (II) modeset(0): 800x600@72Hz
[ 1001.080] (II) modeset(0): 800x600@75Hz
[ 1001.080] (II) modeset(0): 832x624@75Hz
[ 1001.080] (II) modeset(0): 1024x768@60Hz
[ 1001.080] (II) modeset(0): 1024x768@70Hz
[ 1001.080] (II) modeset(0): 1024x768@75Hz
[ 1001.080] (II) modeset(0): 1280x1024@75Hz
[ 1001.080] (II) modeset(0): 1152x864@75Hz
[ 1001.080] (II) modeset(0): Manufacturer’s mask: 0
[ 1001.080] (II) modeset(0): Supported standard timings:
[ 1001.080] (II) modeset(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 1001.080] (II) modeset(0): #1: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 1001.080] (II) modeset(0): #2: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 1001.080] (II) modeset(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 1001.080] (II) modeset(0): #4: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 1001.080] (II) modeset(0): #5: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 1001.080] (II) modeset(0): #6: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 1001.081] (II) modeset(0): Supported detailed timing:
[ 1001.081] (II) modeset(0): clock: 297.0 MHz Image Size: 1872 x 1053 mm
[ 1001.081] (II) modeset(0): h_active: 3840 h_sync: 4016 h_sync_end 4104 h_blank_end 4400 h_border: 0
[ 1001.081] (II) modeset(0): v_active: 2160 v_sync: 2168 v_sync_end 2178 v_blanking: 2250 v_border: 0
[ 1001.081] (II) modeset(0): clock: 148.5 MHz Image Size: 1872 x 1053 mm
[ 1001.081] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 1001.081] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 1001.081] (II) modeset(0): Ranges: V min: 24 V max: 75 Hz, H min: 15 H max: 81 kHz, PixClock max 305 MHz
[ 1001.081] (II) modeset(0): Monitor name: SAMSUNG
[ 1001.081] (II) modeset(0): clock: 74.2 MHz Image Size: 1872 x 1053 mm
[ 1001.081] (II) modeset(0): h_active: 1920 h_sync: 2448 h_sync_end 2492 h_blank_end 2640 h_border: 0
[ 1001.081] (II) modeset(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
[ 1001.081] (II) modeset(0): clock: 85.5 MHz Image Size: 1872 x 1053 mm
[ 1001.081] (II) modeset(0): h_active: 1366 h_sync: 1436 h_sync_end 1579 h_blank_end 1792 h_border: 0
[ 1001.081] (II) modeset(0): v_active: 768 v_sync: 771 v_sync_end 774 v_blanking: 798 v_border: 0
[ 1001.081] (II) modeset(0): Number of EDID sections to follow: 1
[ 1001.081] (II) modeset(0): EDID (in hex):
[ 1001.081] (II) modeset(0): 00ffffffffffff004c2d450c01000001
[ 1001.081] (II) modeset(0): 2a180103808e50780a23ada4544d9926
[ 1001.081] (II) modeset(0): 0f474abdef80714f81c0810081809500
[ 1001.082] (II) modeset(0): a9c0b300010104740030f2705a80b058
[ 1001.082] (II) modeset(0): 8a00501d7400001e023a801871382d40
[ 1001.082] (II) modeset(0): 582c4500501d7400001e000000fd0018
[ 1001.082] (II) modeset(0): 4b0f511e000a202020202020000000fc
[ 1001.082] (II) modeset(0): 0053414d53554e470a202020202001aa
[ 1001.082] (II) modeset(0): 02033cf1535f101f041305142021225d
[ 1001.082] (II) modeset(0): 5e626364071603122309070783010000
[ 1001.082] (II) modeset(0): e2000f6e030c001000b83c2110800102
[ 1001.082] (II) modeset(0): 0304e3060501e50e60616566011d80d0
[ 1001.082] (II) modeset(0): 721c1620102c2580501d7400009e6621
[ 1001.082] (II) modeset(0): 56aa51001e30468f3300501d7400001e
[ 1001.082] (II) modeset(0): 00000000000000000000000000000000
[ 1001.082] (II) modeset(0): 0000000000000000000000000000002c
[ 1001.082] (–) modeset(0): HDMI max TMDS frequency 300000KHz
[ 1001.082] (II) modeset(0): Printing probed modes for output HDMI-1
[ 1001.082] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 1001.082] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 1001.082] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1920x1080i"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1920x1080i"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1920x1080"x30.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1920x1080"x25.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1920x1080"x24.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1920x1080i"x59.9 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1920x1080"x30.0 74.18 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1920x1080"x24.0 74.18 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1366x768"x59.8 85.50 1366 1436 1579 1792 768 771 774 798 +hsync +vsync (47.7 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 1001.083] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 1001.084] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 1001.084] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 1001.084] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 1001.084] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 1001.084] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 1001.084] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 1001.084] (II) modeset(0): Modeline "720x576i"x50.0 13.50 720 732 795 864 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 1001.084] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 1001.084] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 1001.084] (II) modeset(0): Modeline "720x480i"x60.0 13.51 720 739 801 858 480 488 494 525 interlace -hsync -vsync (15.8 kHz e)
[ 1001.084] (II) modeset(0): Modeline "720x480i"x59.9 13.50 720 739 801 858 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 1001.084] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 1001.084] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 1001.084] (II) modeset(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 1001.084] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 1001.084] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 1001.084] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 1001.084] (II) modeset(0): Output HDMI-1 connected
[ 1001.084] (II) modeset(0): Using exact sizes for initial modes
[ 1001.084] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0
[ 1001.085] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 1001.085] (==) modeset(0): DPI set to (96, 96)
[ 1001.085] (II) Loading sub module “fb”
[ 1001.085] (II) LoadModule: “fb”
[ 1001.085] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 1001.086] (II) Module fb: vendor=“X.Org Foundation”
[ 1001.086] compiled for 1.19.6, module version = 1.0.0
[ 1001.086] ABI class: X.Org ANSI C Emulation, version 0.4
[ 1001.086] (II) UnloadModule: “fbdev”
[ 1001.086] (II) Unloading fbdev
[ 1001.086] (II) UnloadSubModule: “fbdevhw”
[ 1001.086] (II) Unloading fbdevhw
[ 1001.087] (==) Depth 24 pixmap format is 32 bpp
[ 1001.100] (==) modeset(0): Backing store enabled
[ 1001.100] (==) modeset(0): Silken mouse enabled
[ 1001.100] (II) modeset(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 1001.101] (==) modeset(0): DPMS enabled
[ 1001.101] (–) RandR disabled
[ 1001.114] (II) SELinux: Disabled on system
[ 1001.116] (II) AIGLX: Screen 0 is not DRI2 capable
[ 1001.116] (EE) AIGLX: reverting to software rendering
[ 1001.125] (II) IGLX: enabled GLX_MESA_copy_sub_buffer
[ 1001.129] (II) IGLX: Loaded and initialized swrast
[ 1001.129] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 1001.131] (II) modeset(0): Damage tracking initialized
[ 1001.131] (II) modeset(0): Setting screen physical size to 508 x 285
[ 1001.260] (II) config/udev: Adding input device HID 04f3:0103 (/dev/input/event3)
[ 1001.260] () HID 04f3:0103: Applying InputClass “libinput keyboard catchall”
[ 1001.260] (II) LoadModule: “libinput”
[ 1001.261] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 1001.265] (II) Module libinput: vendor=“X.Org Foundation”
[ 1001.265] compiled for 1.19.6, module version = 0.27.1
[ 1001.265] Module class: X.Org XInput Driver
[ 1001.265] ABI class: X.Org XInput driver, version 24.1
[ 1001.265] (II) Using input driver ‘libinput’ for ‘HID 04f3:0103’
[ 1001.265] (
) HID 04f3:0103: always reports core events
[ 1001.265] () Option “Device” “/dev/input/event3”
[ 1001.265] (
) Option “_source” “server/udev”
[ 1001.267] (II) event3 - HID 04f3:0103: is tagged by udev as: Keyboard
[ 1001.267] (II) event3 - HID 04f3:0103: device is a keyboard
[ 1001.267] (II) event3 - HID 04f3:0103: device removed
[ 1001.275] () Option “config_info” “udev:/sys/devices/platform/fe3c0000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:04F3:0103.0002/input/input3/event3”
[ 1001.275] (II) XINPUT: Adding extended input device “HID 04f3:0103” (type: KEYBOARD, id 6)
[ 1001.275] (
) Option “xkb_model” “pc105”
[ 1001.275] () Option “xkb_layout” “au”
[ 1001.321] (II) event3 - HID 04f3:0103: is tagged by udev as: Keyboard
[ 1001.321] (II) event3 - HID 04f3:0103: device is a keyboard
[ 1001.323] (II) config/udev: Adding input device HID 04f3:0103 (/dev/input/event4)
[ 1001.323] (
[ 1001.323] (II) Using input driver ‘libinput’ for ‘HID 04f3:0103’
[ 1001.323] () HID 04f3:0103: always reports core events
[ 1001.323] (
) Option “Device” “/dev/input/event4”
[ 1001.323] () Option “_source” “server/udev”
[ 1001.324] (II) event4 - HID 04f3:0103: is tagged by udev as: Keyboard
[ 1001.324] (II) event4 - HID 04f3:0103: device is a keyboard
[ 1001.324] (II) event4 - HID 04f3:0103: device removed
[ 1001.329] (II) libinput: HID 04f3:0103: needs a virtual subdevice
[ 1001.329] (
) Option “config_info” “udev:/sys/devices/platform/fe3c0000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:04F3:0103.0003/input/input4/event4”
[ 1001.329] (II) XINPUT: Adding extended input device “HID 04f3:0103” (type: MOUSE, id 7)
[ 1001.329] () Option “AccelerationScheme” “none”
[ 1001.329] (
) HID 04f3:0103: (accel) selected scheme none/0
[ 1001.329] () HID 04f3:0103: (accel) acceleration factor: 2.000
[ 1001.329] (
) HID 04f3:0103: (accel) acceleration threshold: 4
[ 1001.330] (II) event4 - HID 04f3:0103: is tagged by udev as: Keyboard
[ 1001.330] (II) event4 - HID 04f3:0103: device is a keyboard
[ 1001.331] (II) config/udev: Adding input device PixArt Lenovo USB Optical Mouse (/dev/input/event2)
[ 1001.331] () PixArt Lenovo USB Optical Mouse: Applying InputClass “libinput pointer catchall”
[ 1001.331] (II) Using input driver ‘libinput’ for ‘PixArt Lenovo USB Optical Mouse’
[ 1001.331] (
) PixArt Lenovo USB Optical Mouse: always reports core events
[ 1001.331] () Option “Device” “/dev/input/event2”
[ 1001.332] (
[ 1001.332] (II) event2 - PixArt Lenovo USB Optical Mouse: is tagged by udev as: Mouse
[ 1001.332] (II) event2 - PixArt Lenovo USB Optical Mouse: device is a pointer
[ 1001.332] (II) event2 - PixArt Lenovo USB Optical Mouse: device removed
[ 1001.347] () Option “config_info” “udev:/sys/devices/platform/fe3c0000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:17EF:6019.0001/input/input2/event2”
[ 1001.347] (II) XINPUT: Adding extended input device “PixArt Lenovo USB Optical Mouse” (type: MOUSE, id 8)
[ 1001.347] (
[ 1001.347] () PixArt Lenovo USB Optical Mouse: (accel) selected scheme none/0
[ 1001.347] (
) PixArt Lenovo USB Optical Mouse: (accel) acceleration factor: 2.000
[ 1001.347] () PixArt Lenovo USB Optical Mouse: (accel) acceleration threshold: 4
[ 1001.348] (II) event2 - PixArt Lenovo USB Optical Mouse: is tagged by udev as: Mouse
[ 1001.348] (II) event2 - PixArt Lenovo USB Optical Mouse: device is a pointer
[ 1001.349] (II) config/udev: Adding input device gpio-keys (/dev/input/event1)
[ 1001.349] (
) gpio-keys: Applying InputClass “libinput keyboard catchall”
[ 1001.349] (II) Using input driver ‘libinput’ for ‘gpio-keys’
[ 1001.349] () gpio-keys: always reports core events
[ 1001.349] (
) Option “Device” “/dev/input/event1”
[ 1001.349] () Option “_source” “server/udev”
[ 1001.350] (II) event1 - gpio-keys: is tagged by udev as: Keyboard
[ 1001.350] (II) event1 - gpio-keys: device is a keyboard
[ 1001.350] (II) event1 - gpio-keys: device removed
[ 1001.355] (
) Option “config_info” “udev:/sys/devices/platform/gpio-keys/input/input1/event1”
[ 1001.355] (II) XINPUT: Adding extended input device “gpio-keys” (type: KEYBOARD, id 9)
[ 1001.355] () Option “xkb_model” “pc105”
[ 1001.355] (
[ 1001.356] (II) event1 - gpio-keys: is tagged by udev as: Keyboard
[ 1001.356] (II) event1 - gpio-keys: device is a keyboard
[ 1001.356] (II) config/udev: Adding input device rockchip,rt5640-codec Headphone Jack (/dev/input/event0)
[ 1001.357] (II) No input driver specified, ignoring this device.
[ 1001.357] (II) This device may have been added with another device file.
[ 1001.364] () HID 04f3:0103: Applying InputClass “libinput keyboard catchall”
[ 1001.364] (II) Using input driver ‘libinput’ for ‘HID 04f3:0103’
[ 1001.364] (
[ 1001.364] () Option “Device” “/dev/input/event4”
[ 1001.364] (
) Option “_source” “_driver/libinput”
[ 1001.364] (II) libinput: HID 04f3:0103: is a virtual subdevice
[ 1001.365] () Option “config_info” “udev:/sys/devices/platform/fe3c0000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:04F3:0103.0003/input/input4/event4”
[ 1001.365] (II) XINPUT: Adding extended input device “HID 04f3:0103” (type: KEYBOARD, id 10)
[ 1001.365] (
[ 1001.365] (**) Option “xkb_layout” “au”
[ 1002.563] (II) event3 - HID 04f3:0103: device removed
[ 1002.575] (II) event2 - PixArt Lenovo USB Optical Mouse: device removed
[ 1002.587] (II) event1 - gpio-keys: device removed
[ 1002.593] (II) event4 - HID 04f3:0103: device removed
[ 1002.602] (II) UnloadModule: “libinput”
[ 1002.603] (II) UnloadModule: “libinput”
[ 1002.731] (II) Server terminated successfully (0). Closing log file.
resize2fs 后可以了
123
我也是现实有显示出来,但是光标移植在闪
