新手求助, rk3288 porting touch driver NG.
版子: firefly rk3288
OS: android 5.1.1
需要使用 cypress touch IC
一直遇到障礙
請求協助.
下方是與 cypress 相關的code
PS1: synaptics 一併附在下方
PS2: synaptics function ok.
        tsc@24 {
//		status = "disabled";
                compatible = "cy,cyttsp6_i2c_adapter";
                reg = <0x24>;
                /* GPIO 38, high-to-low edge triggered */
                interrupt-parent = <&gpio8>; //<&gpio3>;
                interrupts = <GPIO_A7 IRQ_TYPE_EDGE_FALLING>; //<6 2>;
                cy,core {
                        cy,irq_gpio = <&gpio8 GPIO_A7 IRQ_TYPE_LEVEL_LOW>;
                        cy,rst_gpio = <&gpio8 GPIO_A6 0x00>; //<48>;
//                        cy,err_gpio = <49>;
                        /* Enable cy,max_xfer_len to limit max I2C/SPI transfer length */
                        cy,max_xfer_len = <0x100>;
                        cy,mt {
                                cy,inp_dev_name = "cyttsp6_mt";
                                /* CY_MT_FLAG_FLIP | CY_MT_FLAG_INV_X | CY_MT_FLAG_INV_Y */
                               /* cy,flags = <0x38>;*/
                                cy,abs =
                                        /* ABS_MT_POSITION_X, CY_ABS_MIN_X, CY_ABS_MAX_X, 0, 0 */
                                        <0x35 0 1280 0 0
                                        /* ABS_MT_POSITION_Y, CY_ABS_MIN_Y, CY_ABS_MAX_Y, 0, 0 */
                                        0x36 0 720 0 0
                                        /* ABS_MT_PRESSURE, CY_ABS_MIN_P, CY_ABS_MAX_P, 0, 0 */
                                        0x3a 0 255 0 0
                                        /* CY_IGNORE_VALUE, CY_ABS_MIN_W, CY_ABS_MAX_W, 0, 0 */
                                        0xffff 0 255 0 0
                                        /* ABS_MT_TRACKING_ID, CY_ABS_MIN_T, CY_ABS_MAX_T, 0, 0 */
                                        0x39 0 15 0 0
                                        /* ABS_MT_TOUCH_MAJOR, 0, 255, 0, 0 */
                                        0x30 0 255 0 0
                                        /* ABS_MT_TOUCH_MINOR, 0, 255, 0, 0 */
                                        0x31 0 255 0 0
                                        /* ABS_MT_ORIENTATION, -127, 127, 0, 0 */
                                        0x34 0xffffff81 127 0 0
                                        /* ABS_MT_TOOL_TYPE, 0, MT_TOOL_MAX, 0, 0 */
                                        0x37 0 1 0 0
                                        /* ABS_DISTANCE, 0, 255, 0, 0 */
                                        0x19 0 255 0 0>;
                                cy,vkeys_x = <1280>;
                                cy,vkeys_y = <720>;
        synaptics_ts@20 {
                compatible = "synaptics,synaptics_dsx";
                reg = <0x20>;
        	touch-gpio = <&gpio8 GPIO_A7 IRQ_TYPE_EDGE_FALLING>;
                reset-gpio = <&gpio5 GPIO_B1 GPIO_ACTIVE_LOW>;
                //power-gpio = <&gpio0 GPIO_C5 GPIO_ACTIVE_LOW>;
                max-x = <1280>;
                max-y = <720>;
                flip-x = <0>;
                flip-y = <0>;
dmesg中與 cyttsp相關訊息
<6>[ 0.853620] cyttsp6_i2c_adapter 1-0024: cyttsp6_init: INIT CYTTSP RST gpio=3 and IRQ gpio=3 ERR gpio=0
<6>[ 0.959458] cyttsp6_i2c_adapter 1-0024: cyttsp6_xres: RESET CYTTSP gpio=3 r=0
<3>[ 1.943454] cyttsp6_i2c_adapter 1-0024: cyttsp6_wait_bl_heartbeat: tmo waiting bl heartbeat cd->mode=0
<3>[ 1.943473] cyttsp6_i2c_adapter 1-0024: cyttsp6_startup_: Error on h/w reset r=-62
<6>[ 2.051692] cyttsp6_i2c_adapter 1-0024: cyttsp6_xres: RESET CYTTSP gpio=3 r=0
<3>[ 3.035691] cyttsp6_i2c_adapter 1-0024: cyttsp6_wait_bl_heartbeat: tmo waiting bl heartbeat cd->mode=0
<3>[ 3.035710] cyttsp6_i2c_adapter 1-0024: cyttsp6_startup_: Error on h/w reset r=-62
<6>[ 3.143930] cyttsp6_i2c_adapter 1-0024: cyttsp6_xres: RESET CYTTSP gpio=3 r=0
<3>[ 4.127939] cyttsp6_i2c_adapter 1-0024: cyttsp6_wait_bl_heartbeat: tmo waiting bl heartbeat cd->mode=0
<3>[ 4.127966] cyttsp6_i2c_adapter 1-0024: cyttsp6_startup_: Error on h/w reset r=-62
<6>[ 4.236172] cyttsp6_i2c_adapter 1-0024: cyttsp6_xres: RESET CYTTSP gpio=3 r=0
<3>[ 5.220173] cyttsp6_i2c_adapter 1-0024: cyttsp6_wait_bl_heartbeat: tmo waiting bl heartbeat cd->mode=0
<3>[ 5.220195] cyttsp6_i2c_adapter 1-0024: cyttsp6_startup_: Error on h/w reset r=-62
<6>[ 5.220213] cyttsp6_i2c_adapter 1-0024: cyttsp6_startup_: cyttsp6_exit startup rc=-19…
<3>[ 5.220882] cyttsp6_i2c_adapter 1-0024: _cyttsp6_core_sleep_device: Device in BOOTLADER mode.
<6>[ 5.220901] cyttsp6_i2c_adapter 1-0024: cyttsp6_core_sleep: sleep state rc -22
<3>[ 5.269384] cyttsp6_i2c_adapter 1-0024: cyttsp6_core_rt_suspend: Error on sleep
<3>[ 5.269403] cyttsp6_i2c_adapter 1-0024: cyttsp6_probe: Fail initial startup r=-19
<4>[ 5.269693] [] (gpiod_free+0xe0/0xfc) from [] (cyttsp6_init+0x138/0x15c)
<4>[ 5.269716] [] (cyttsp6_init+0x138/0x15c) from [] (cyttsp6_probe+0x53c/0x600)
<4>[ 5.269738] [] (cyttsp6_probe+0x53c/0x600) from [] (cyttsp6_i2c_probe+0x74/0xa0)
<4>[ 5.269762] [] (cyttsp6_i2c_probe+0x74/0xa0) from [] (i2c_device_probe+0xa8/0xd4)
<3>[ 5.270084] cyttsp6_i2c_adapter 1-0024: cyttsp6_probe failed.
<6>[ 5.270173] cyttsp6_loader_init: Cypress TTSP FW Loader Driver (Built TTDA.02.05.776588) rc=0
<6>[ 5.270191] cyttsp6_debug_init: Cypress TTSP Debug Driver (Built TTDA.02.05.776588) rc=0
<6>[ 5.270207] cyttsp6_device_access_init: Cypress TTSP Device Access Driver (Built TTDA.02.05.776588) rc=0
PS: 抱歉, 不知道如何附檔, 若需要更詳細資訊, 我在貼上來.
請問
為甚麼 INT 與 RST設定不同腳位? error message 卻顯示相同???
setting
cy,irq_gpio = <&gpio8 GPIO_A7>;
cy,rst_gpio = <&gpio8 GPIO_A6>;
error message:
