烧录了AIO-3288C_HSX101H40C_Android5.1.1_LVDS_180808这个固件后,屏的触摸功能没有
黄色座子为TP插座,红色座子为背光控制插座,这些肯定都是接对的
这个固件难道没有加入触摸功能?我新的屏触摸应该不可能会坏的吧
这个应该怎么解决啊?有没有这个固件的源码能提供看看
可以抓一下内核log,看打印什么先
jpchen 发表于 2018-8-18 12:02
可以抓一下内核log,看打印什么先
log抓了,应该看哪里呢?不懂啊
1|shell@firefly:/ $ dmesg
<6>[ 0.000000] Booting Linux on physical CPU 0x500
<6>[ 0.000000] Initializing cgroup subsys cpu
<6>[ 0.000000] Initializing cgroup subsys cpuacct
<5>[ 0.000000] Linux version 3.10.0 (sujl@tchipserver2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #140 SMP PREEMPT Wed Aug 8 10:45:07 CST 2018
<4>[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
<4>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<6>[ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
<4>[ 0.000000] rockchip_ion_reserve
<6>[ 0.000000] ion heap(drm): base(0) size(0) align(0)
<6>[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
<6>[ 0.000000] ion heap(vmalloc): base(0) size(0) align(0)
<6>[ 0.000000] cma: CMA: reserved 16 MiB at 7f000000
<6>[ 0.000000] ion_reserve: cma reserved base 7f000000 size 16777216
<6>[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
<4>[ 0.000000] Boot mode: REBOOT (6) flag: NORMAL (0xc3524200)
<7>[ 0.000000] On node 0 totalpages: 524288
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0da1080, node_mem_map c0ecc000
<7>[ 0.000000] Normal zone: 1024 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 3072 pages used for memmap
<7>[ 0.000000] HighMem zone: 393216 pages, LIFO batch:31
<6>[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f26000 s13376 r8192 d15296 u36864
<7>[ 0.000000] pcpu-alloc: s13376 r8192 d15296 u36864 alloc=9*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
<5>[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),-@0x003BC000(userdata) storagemedia=emmc loader.timestamp=2018-07-16_10:59:23
<6>[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 0.000000] allocated 4194304 bytes of page_cgroup
<6>[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
<6>[ 0.000000] Memory: 2048MB = 2048MB total
<5>[ 0.000000] Memory: 2026392k/2026392k available, 70760k reserved, 1556480K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc0bbbd80 (11984 kB)
<5>[ 0.000000] .init : 0xc0bbc000 - 0xc0c15440 ( 358 kB)
<5>[ 0.000000] .data : 0xc0c16000 - 0xc0da86c0 (1610 kB)
<5>[ 0.000000] .bss : 0xc0da86c0 - 0xc0ecbdbc (1166 kB)
<6>[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
<6>[ 0.000000] NR_IRQS:16 nr_irqs:16 16
<4>[ 0.000000] rk_clk_tree_init start!
<3>[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
<3>[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
<4>[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0
<4>[ 0.000000] rkclk_init_clks: cnt_parent = 7
<4>[ 0.000000] rkclk_init_clks: cnt_rate = 29
<4>[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
<6>[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
<6>[ 0.000000] Switching to timer-based delay loop
<6>[ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
<6>[ 0.000000] process version: 0
<6>[ 0.000000] channel:0, lkg:13
<6>[ 0.000000] target-temp:80
<6>[ 0.000000] channel:2, lkg:0
<6>[ 0.000000] channel:1, lkg:7
<6>[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
<6>[ 0.500548] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
<6>[ 0.500564] pid_max: default: 32768 minimum: 301
<6>[ 0.500683] Security Framework initialized
<6>[ 0.500699] SELinux: Initializing.
<7>[ 0.500733] SELinux: Starting in permissive mode
<6>[ 0.500771] Mount-cache hash table entries: 512
<6>[ 0.501407] Initializing cgroup subsys debug
<6>[ 0.501421] Initializing cgroup subsys memory
<6>[ 0.501448] Initializing cgroup subsys freezer
<6>[ 0.501477] CPU: Testing write buffer coherency: ok
<3>[ 0.501797] /cpus/cpu@0 missing clock-frequency property
<3>[ 0.501810] /cpus/cpu@1 missing clock-frequency property
<3>[ 0.501819] /cpus/cpu@2 missing clock-frequency property
<3>[ 0.501829] /cpus/cpu@3 missing clock-frequency property
<6>[ 0.501879] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
<6>[ 0.501929] Setting up static identity map for 0xc0869720 - 0xc0869778
<6>[ 0.505049] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x1749 (version 3.1)
<4>[ 0.578709] CPU1: Booted secondary processor
<6>[ 0.578742] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
<4>[ 0.598381] CPU2: Booted secondary processor
<6>[ 0.598405] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
<4>[ 0.618088] CPU3: Booted secondary processor
<6>[ 0.618112] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
<6>[ 0.618211] Brought up 4 CPUs
<6>[ 0.618239] SMP: Total of 4 processors activated (192.00 BogoMIPS).
<6>[ 0.618248] CPU: All CPU(s) started in SVC mode.
<6>[ 0.618979] devtmpfs: initialized
<6>[ 0.623303] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
<6>[ 0.624385] pinctrl core: initialized pinctrl subsystem
<6>[ 0.624635] regulator-dummy: no parameters
<6>[ 0.638558] NET: Registered protocol family 16
<6>[ 0.640352] DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>[ 0.640726] ion_snapshot: 0x1ea98000 map to 0xe0907000 and copy to 0xc0ea704c (version 0.1)
<6>[ 0.640950] Registered FIQ tty driver
<3>[ 0.641352] fiq-debugger is disabled in device tree
<4>[ 0.642036] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
<4>[ 0.642058] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
<4>[ 0.642075] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
<4>[ 0.642092] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
<4>[ 0.642185] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
<4>[ 0.642251] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
<4>[ 0.642312] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
<4>[ 0.642373] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
<4>[ 0.642435] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
<4>[ 0.642496] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
<4>[ 0.642558] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
<4>[ 0.642618] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
<4>[ 0.642687] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
<4>[ 0.642752] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
<4>[ 0.642764] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
<4>[ 0.642776] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
<4>[ 0.642787] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
<7>[ 0.642868] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
<7>[ 0.642925] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
<7>[ 0.642978] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
<7>[ 0.643038] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
<7>[ 0.643092] gpiochip_add: registered GPIOs 128 to 159 on device: gpio4
<7>[ 0.643146] gpiochip_add: registered GPIOs 160 to 191 on device: gpio5
<7>[ 0.643206] gpiochip_add: registered GPIOs 192 to 223 on device: gpio6
<7>[ 0.643261] gpiochip_add: registered GPIOs 224 to 255 on device: gpio7
<7>[ 0.643314] gpiochip_add: registered GPIOs 256 to 287 on device: gpio8
<7>[ 0.643367] gpiochip_add: registered GPIOs 288 to 319 on device: gpio15
<4>[ 0.643397] rockchip_interrupts_register:bank_num=7
<7>[ 0.645327] of_get_named_gpio_flags exited with status 136
<4>[ 0.645339] of_get_gpio_init_config:gpio[0] = 136, value = 0
<7>[ 0.645350] of_get_named_gpio_flags exited with status 13
<4>[ 0.645359] of_get_gpio_init_config:gpio[1] = 13, value = 1
<4>[ 0.645412] rockchip_pinctrl_probe:init ok
<6>[ 0.652479] rk_iommu ff900800.iep_mmu: (iep) Enter
<6>[ 0.652566] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.652579] rk_iommu ff900800.iep_mmu: (iep) Initialized
<6>[ 0.652748] rk_iommu ff950800.vip_mmu: (vip) Enter
<6>[ 0.652827] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.652839] rk_iommu ff950800.vip_mmu: (vip) Initialized
<6>[ 0.653001] rk_iommu ff930300.vopb_mmu: (vopb) Enter
<6>[ 0.653071] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.653083] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
<6>[ 0.653242] rk_iommu ff940300.vopl_mmu: (vopl) Enter
<6>[ 0.653322] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.653334] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
<6>[ 0.653503] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
<6>[ 0.653575] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.653588] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
<6>[ 0.653749] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
<6>[ 0.653826] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.653839] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
<6>[ 0.654010] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
<6>[ 0.654093] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.654105] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
<6>[ 0.655776] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[ 0.655788] hw-breakpoint: maximum watchpoint size is 4 bytes.
<3>[ 0.656362] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
<4>[ 0.656384] DDR DEBUG: version 1.00 20150126
<4>[ 0.656410] DDR DEBUG: Channel a:
<4>[ 0.656419] DDR DEBUG: DDR3 Device
<4>[ 0.656432] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.656441] DDR DEBUG: Channel b:
<4>[ 0.656448] DDR DEBUG: DDR3 Device
<4>[ 0.656460] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.656469] DDR DEBUG: addr=0xdb2000
<4>[ 0.656478] DDR DEBUG: stride=9, size=256, halfcap=40000000
<4>[ 0.656488] DDR DEBUG: socAddr[0]=0xdb2000, socAddr[1]=0xdb2100
<4>[ 0.656497] DDR DEBUG: chAddr[0]=0xdb2000, chAddr[1]=0xdb2000
<4>[ 0.656509] DDR DEBUG: dtar[0]=0x201b6000, dtar[1]=0x201b6000
<4>[ 0.656563] DDR DEBUG: init success!!! freq=200MHz
<4>[ 0.656571] DDR DEBUG: Channel a:
<4>[ 0.656584] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.656596] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.656609] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.656621] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.656633] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.656641] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.656651] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<4>[ 0.656658] DDR DEBUG: Channel b:
<4>[ 0.656669] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.656682] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.656694] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.656706] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.656717] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.656726] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.656735] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<6>[ 0.681453] bio: create slab at 0
<6>[ 0.681980] Rockchip hdmi driver version 2.0
<6>[ 0.681980] .
<5>[ 0.683152] SCSI subsystem initialized
<6>[ 0.683310] usbcore: registered new interface driver usbfs
<6>[ 0.683354] usbcore: registered new interface driver hub
<6>[ 0.683441] usbcore: registered new device driver usb
<7>[ 0.683696] of_get_named_gpio_flags exited with status 14
<7>[ 0.685705] of_get_named_gpio_flags exited with status 227
<4>[ 0.685714] host_en_gpio= 227
<4>[ 0.685721] midori
<7>[ 0.687720] of_get_named_gpio_flags exited with status 12
<7>[ 0.688829] of_get_named_gpio_flags exited with status 15
<7>[ 0.688851] of_get_named_gpio_flags exited with status 16
<6>[ 0.690121] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
<7>[ 0.690237] of_get_named_gpio_flags exited with status 260
<7>[ 0.690258] of_get_named_gpio_flags exited with status 261
<6>[ 0.690597] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
<7>[ 0.690704] of_get_named_gpio_flags exited with status 201
<7>[ 0.690722] of_get_named_gpio_flags exited with status 202
<6>[ 0.691050] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
<7>[ 0.691147] of_get_named_gpio_flags exited with status 81
<7>[ 0.691165] of_get_named_gpio_flags exited with status 80
<6>[ 0.691292] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
<7>[ 0.691395] of_get_named_gpio_flags exited with status 241
<7>[ 0.691413] of_get_named_gpio_flags exited with status 242
<6>[ 0.691913] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
<6>[ 0.692031] media: Linux media interface: v0.10
<6>[ 0.692071] Linux video capture interface: v2.00
<6>[ 0.692127] pps_core: LinuxPPS API ver. 1 registered
<6>[ 0.692137] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
<6>[ 0.692157] PTP clock support registered
<4>[ 0.692218] i2c-core: driver [bq24296] using legacy suspend method
<4>[ 0.692227] i2c-core: driver [bq24296] using legacy resume method
<6>[ 0.692543] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
<4>[ 0.693022] ion_drm_heap_create: 0@0
<6>[ 0.693153] Rockchip ion module is successfully loaded (v1.1)
<6>[ 0.693314] Advanced Linux Sound Architecture Driver Initialized.
<6>[ 0.693730] Bluetooth: Core ver 2.16
<6>[ 0.693768] NET: Registered protocol family 31
<6>[ 0.693778] Bluetooth: HCI device and connection manager initialized
<6>[ 0.693793] Bluetooth: HCI socket layer initialized
<6>[ 0.693807] Bluetooth: L2CAP socket layer initialized
<6>[ 0.693833] Bluetooth: SCO socket layer initialized
<6>[ 0.694068] cfg80211: Calling CRDA to update world regulatory domain
<4>[ 0.694756] act8846_i2c_probe,line=898
<4>[ 0.695756] act8846_parse_dt,line=746
<7>[ 0.696163] of_get_named_gpio_flags exited with status 238
<7>[ 0.696176] of_get_named_gpio_flags exited with status 1
<7>[ 0.696188] of_get_named_gpio_flags exited with status 263
<7>[ 0.696199] of_get_named_gpio_flags exited with status 259
<4>[ 0.696235] act8846_i2c_probe: act8846_pmic_hold=1
<4>[ 0.696257] act8846_i2c_probe: act8846_pmic_sleep=1
<4>[ 0.696272] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
<4>[ 0.696287] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
<6>[ 0.698378] act_dcdc1: 1200 mV
<6>[ 0.701336] vccio: 3300 mV
<6>[ 0.703205] vdd_logic: 700 ↔ 1500 mV at 1150 mV
<6>[ 0.706188] act_dcdc4: 2000 mV
<6>[ 0.707437] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
<6>[ 0.709729] act_ldo2: 1050 mV
<6>[ 0.712028] act_ldo3: 3300 mV
<6>[ 0.714325] act_ldo4: 3300 mV
<6>[ 0.716713] act_ldo5: 3300 mV
<6>[ 0.719048] act_ldo6: 1100 mV
<6>[ 0.721347] vcc_18: 1800 mV
<6>[ 0.723656] act_ldo8: 1850 mV
<6>[ 0.728409] vdd_arm: 712 ↔ 1500 mV at 1100 mV
<6>[ 0.733101] vdd_gpu: 712 ↔ 1500 mV at 900 mV
<4>[ 0.733862] rk808_i2c_probe,line=1355
<4>[ 0.735191] The device is not rk808 -11
<4>[ 0.735275] rk808: probe of 0-001b failed with error -11
<4>[ 0.735347] i2c-core: driver [rk818] using legacy suspend method
<4>[ 0.735356] i2c-core: driver [rk818] using legacy resume method
<6>[ 0.737138] Switching to clocksource arch_sys_counter
<6>[ 0.761208] rga: Module initialized.
<6>[ 0.761934] rga2 ff920000.rga: rga ion client create success!
<6>[ 0.762092] rga: Driver loaded succesfully
<6>[ 0.762298] fb disp policy is box
<7>[ 0.762308] uboot-logo-on:0
<6>[ 0.762341] rk-fb rockchip-fb: rk fb ion client create success!
<6>[ 0.762353] rk-fb rockchip-fb: rockchip framebuffer driver probe
<6>[ 0.762646] rk-screen rk_screen.8: rockchip screen probe success
<6>[ 0.762887] rk32-lvds rk32-lvds: rk32 lvds driver probe success
<3>[ 0.763248] rk32-edp ff970000.edp: screen is not edp!
<4>[ 0.763270] rk32-edp: probe of ff970000.edp failed with error -22
<7>[ 0.763750] of_get_named_gpio_flags exited with status 197
<7>[ 0.763783] of_get_named_gpio_flags exited with status 265
<6>[ 0.763802] pwr_ctr_name:lcd_en
<6>[ 0.763802] pwr_type:gpio
<6>[ 0.763802] gpio:197
<6>[ 0.763802] atv_val:1
<6>[ 0.763802] delay:10
<6>[ 0.763802]
<6>[ 0.763834] pwr_ctr_name:disp_en
<6>[ 0.763834] pwr_type:gpio
<6>[ 0.763834] gpio:265
<6>[ 0.763834] atv_val:1
<6>[ 0.763834] delay:10
<6>[ 0.763834]
<6>[ 0.764066] graphics fb0: rockchip framebuffer registerd:fb0
<6>[ 0.764372] graphics fb1: rockchip framebuffer registerd:fb1
<6>[ 0.764549] graphics fb2: rockchip framebuffer registerd:fb2
<6>[ 0.764714] graphics fb3: rockchip framebuffer registerd:fb3
<6>[ 0.785498] rk3288-lcdc lcdc0: lcdc0: dclk:65000000>>fps:58
<6>[ 0.785820] rk3288-lcdc lcdc0: wakeup from standby!
<4>[ 0.788898] rk_battery_charger_detect_cb , battery_charger_detect 1
<6>[ 0.801241] alloc_buffer:ion_phy_addr=0x10000000
<6>[ 0.807556] fb0:phy:10000000>>vir:e0991000>>len:0xc00000
<6>[ 0.807583] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eab4000
<6>[ 0.807597] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
<3>[ 0.807805] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
<4>[ 0.807818] rk_fb_trsm_ops_get:un supported transmitter:0!
<6>[ 0.808088] graphics fb4: rockchip framebuffer registerd:fb4
<6>[ 0.808422] graphics fb5: rockchip framebuffer registerd:fb5
<6>[ 0.808592] graphics fb6: rockchip framebuffer registerd:fb6
<6>[ 0.808753] graphics fb7: rockchip framebuffer registerd:fb7
<6>[ 0.809509] unknow screen type: 0
<6>[ 0.809596] rk3288-lcdc lcdc1: lcdc1: dclk:65000000>>fps:58
<6>[ 0.809610] rk3288-lcdc lcdc1: wakeup from standby!
<6>[ 0.811477] fb4:phy:10000000>>vir:e0991000>>len:0xc00000
<6>[ 0.811491] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
<4>[ 0.812333] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.812466] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.812602] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.812723] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.812841] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.812955] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.813539] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.813698] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.814241] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.814388] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.814922] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.815068] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.815609] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.815760] rockchip_set_mux:warning ignore bank num 15
<6>[ 0.817335] NET: Registered protocol family 2
<6>[ 0.817994] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.818069] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.818142] TCP: Hash tables configured (established 4096 bind 4096)
<6>[ 0.818198] TCP: reno registered
<6>[ 0.818215] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.818237] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.818431] NET: Registered protocol family 1
<6>[ 0.819036] Unpacking initramfs…
<6>[ 0.889027] Freeing initrd memory: 1304K (c5bf0000 - c5d36000)
<6>[ 0.889797] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
<6>[ 0.890363] vcodec_service: probe device ff9a0000.vpu_service
<4>[ 0.890567] vcodec_service: No reset resource define
<6>[ 0.890774] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 0.890861] vcodec_service: probe device ff9a0000.vpu_service
<6>[ 0.890877] vcodec_service: checking hw id 4831
<6>[ 0.891880] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 0.891926] vcodec_service: done
<6>[ 0.891934] vcodec_service: init success
<6>[ 0.892002] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.892332] vcodec_service: ff9c0000.hevc_service: power on
<6>[ 0.892394] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.892407] vcodec_service: checking hw id 6867
<6>[ 0.892977] vcodec_service: ff9c0000.hevc_service: power off…
<6>[ 0.893017] vcodec_service: done
<6>[ 0.893026] vcodec_service: init success
<4>[ 0.893157] rknandbase v1.0 2014-03-31
<4>[ 0.893295] rknand: probe of ff400000.nandc failed with error -1
<4>[ 0.893407] rknand_driver:ret = 0
<6>[ 0.895403] audit: initializing netlink socket (disabled)
<5>[ 0.895446] type=2000 audit(0.400:1): initialized
<4>[ 0.896272] bounce pool size: 64 pages
<6>[ 0.900812] fuse init (API version 7.22)
<6>[ 0.901195] msgmni has been set to 952
<7>[ 0.901244] SELinux: Registering netfilter hooks
<6>[ 0.903037] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
<6>[ 0.903054] io scheduler noop registered
<6>[ 0.903064] io scheduler deadline registered
<6>[ 0.903159] io scheduler cfq registered (default)
<7>[ 0.903832] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 0.904754] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
<4>[ 0.905470] IEP Power ON
<4>[ 0.905520] iep ion client create success!
<6>[ 0.905976] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaae000
<4>[ 0.905987] IEP Power OFF
<4>[ 0.906004] IEP Driver loaded succesfully
<4>[ 0.906104] Module initialized.
<6>[ 0.906932] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.906950] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
<6>[ 0.908308] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.908324] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
<3>[ 0.908609] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API
<3>[ 0.908624] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM
<4>[ 0.908633] pwm_regulator_probe:error
<6>[ 0.908655] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral
<4>[ 0.908856] rk_serial.c v1.8 2014-03-04
<6>[ 0.909077] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
<6>[ 0.909259] serial ff180000.serial: membase e097e000
<6>[ 0.909420] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
<6>[ 0.909587] serial ff190000.serial: membase e1592000
<6>[ 0.909723] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
<6>[ 0.911398] console [ttyS2] enabled
<6>[ 0.911568] serial ff690000.serial: membase fed60000
<6>[ 0.911764] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
<6>[ 0.911927] serial ff1b0000.serial: membase e159c000
<6>[ 0.914717] loop: module loaded
<6>[ 0.915086] zram: Created 1 device(s) …
<4>[ 0.915170] i2c-core: driver [mpu6050B1] using legacy suspend method
<4>[ 0.915183] i2c-core: driver [mpu6050B1] using legacy resume method
<6>[ 0.915199] mpu_init: Probe name mpu6050B1
<6>[ 0.915347] ak8963_mod_init: Probe name ak8963_mod
<6>[ 0.916065] SCSI Media Changer driver v0.25
<6>[ 0.916341] dws->regs: e159e000
<4>[ 0.917536] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
<6>[ 0.917830] tun: Universal TUN/TAP device driver, 1.6
<6>[ 0.917844] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<4>[ 0.917986] vmac_init.
<3>[ 0.918560] stmmac_probe_config_dt: Can not read property: pmu_regulator.
<6>[ 0.918577] stmmac_probe_config_dt: clock input/output? (input).
<6>[ 0.918590] stmmac_probe_config_dt: TX delay(0x1d).
<6>[ 0.918603] stmmac_probe_config_dt: RX delay(0x16).
<7>[ 0.918617] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 0.918635] of_get_named_gpio_flags exited with status 136
<7>[ 0.918644] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 0.918655] stmmac_probe_config_dt: is rockchip,rk3288-gmac
<6>[ 0.918666] stmmc_pltfr_init:
<3>[ 0.918676] stmmc_pltfr_init: ERROR: Get power-gpio failed.
<7>[ 0.918690] _gpio_request: gpio-136 (gmac_phy_reset) status -16
<3>[ 0.918699] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
<6>[ 0.918710] stmmc_pltfr_init: init for RGMII
<6>[ 0.918721] tx delay=0x1d
<6>[ 0.918721] rx delay=0x16
<6>[ 0.918738] tx delay=0x1d
<6>[ 0.918738] rx delay=0x16
<6>[ 0.919194] stmmac - user ID: 0x10, Synopsys ID: 0x35
<6>[ 0.919205] Normal descriptors
<6>[ 0.919215] Ring mode enabled
<6>[ 0.919226] DMA HW capability register supported
<6>[ 0.919238] RX Checksum Offload Engine supported (type 2)
<6>[ 0.919248] TX Checksum insertion supported
<6>[ 0.919258] Wake-Up On Lan supported
<6>[ 0.919295] Enable RX Mitigation via HW Watchdog Timer
<6>[ 0.919723] PPP generic driver version 2.4.2
<6>[ 0.919882] PPP BSD Compression module registered
<6>[ 0.919895] PPP Deflate Compression module registered
<6>[ 0.919919] PPP MPPE Compression module registered
<6>[ 0.919932] NET: Registered protocol family 24
<6>[ 0.919967] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
<6>[ 0.919980] CSLIP: code copyright 1989 Regents of the University of California.
<4>[ 0.919993] Rockchip WiFi SYS interface (V1.00) …
<4>[ 0.920027] esp_mem_init enter date May 30 2018 16:39:38
<4>[ 0.920038] esp_mem_init VERSION [V2.5]
<4>[ 0.920080] esp_mem_init complete
<6>[ 0.920166] usbcore: registered new interface driver catc
<6>[ 0.920208] usbcore: registered new interface driver kaweth
<6>[ 0.920222] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
<6>[ 0.920261] usbcore: registered new interface driver pegasus
<6>[ 0.920301] usbcore: registered new interface driver rtl8150
<6>[ 0.920345] usbcore: registered new interface driver r8152
<6>[ 0.920357] hso: drivers/net/usb/hso.c: Option Wireless
<6>[ 0.920424] usbcore: registered new interface driver hso
<6>[ 0.920469] usbcore: registered new interface driver asix
<6>[ 0.920507] usbcore: registered new interface driver ax88179_178a
<6>[ 0.920546] usbcore: registered new interface driver cdc_ether
<6>[ 0.920584] usbcore: registered new interface driver cdc_eem
<6>[ 0.920626] usbcore: registered new interface driver dm9601
<6>[ 0.920667] usbcore: registered new interface driver dm9620
<6>[ 0.920713] usbcore: registered new interface driver smsc75xx
<6>[ 0.920760] usbcore: registered new interface driver smsc95xx
<6>[ 0.920799] usbcore: registered new interface driver gl620a
<6>[ 0.920837] usbcore: registered new interface driver net1080
<6>[ 0.920881] usbcore: registered new interface driver plusb
<6>[ 0.920921] usbcore: registered new interface driver rndis_host
<6>[ 0.920960] usbcore: registered new interface driver cdc_subset
<6>[ 0.920999] usbcore: registered new interface driver zaurus
<6>[ 0.921039] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
<6>[ 0.921103] usbcore: registered new interface driver int51x1
<6>[ 0.921143] usbcore: registered new interface driver kalmia
<6>[ 0.921185] usbcore: registered new interface driver ipheth
<6>[ 0.921234] usbcore: registered new interface driver sierra_net
<6>[ 0.921278] usbcore: registered new interface driver cx82310_eth
<6>[ 0.921325] usbcore: registered new interface driver cdc_ncm
<6>[ 0.921365] usbcore: registered new interface driver qmi_wwan
<6>[ 0.921406] usbcore: registered new interface driver cdc_mbim
<6>[ 0.921419] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
<6>[ 0.923867] EHCI: ehci_rk_probe e1640000 e1640010
<6>[ 0.923886] rockchip_ehci_host ff500000.usb: EHCI Host Controller
<6>[ 0.923917] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
<6>[ 0.924258] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
<6>[ 0.943859] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
<6>[ 0.943942] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 0.943959] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 0.943974] usb usb1: Product: EHCI Host Controller
<6>[ 0.943987] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
<6>[ 0.944000] usb usb1: SerialNumber: ff500000.usb
<6>[ 0.944447] hub 1-0:1.0: USB hub found
<6>[ 0.944472] hub 1-0:1.0: 1 port detected
<6>[ 0.944642] EHCI: ehci_rk_probe ok
<6>[ 0.944752] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
<6>[ 0.945023] ohci-rockchip ff520000.usb: RK OHCI Host Controller
<6>[ 0.945052] ohci-rockchip ff520000.usb: new USB bus registered, assigned bus number 2
<6>[ 0.945100] ohci-rockchip ff520000.usb: irq 73, io mem 0xff520000
<6>[ 1.006873] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
<6>[ 1.006892] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.006906] usb usb2: Product: RK OHCI Host Controller
<6>[ 1.006919] usb usb2: Manufacturer: Linux 3.10.0 ohci_hcd
<6>[ 1.006932] usb usb2: SerialNumber: ff520000.usb
<6>[ 1.007366] hub 2-0:1.0: USB hub found
<6>[ 1.007390] hub 2-0:1.0: 1 port detected
<6>[ 1.007716] usbcore: registered new interface driver cdc_acm
<6>[ 1.007730] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<6>[ 1.007787] usbcore: registered new interface driver usblp
<6>[ 1.007832] usbcore: registered new interface driver cdc_wdm
<6>[ 1.007919] usbcore: registered new interface driver usb-storage
<6>[ 1.007964] usbcore: registered new interface driver ums-alauda
<6>[ 1.008004] usbcore: registered new interface driver ums-cypress
<6>[ 1.008045] usbcore: registered new interface driver ums-datafab
<6>[ 1.008085] usbcore: registered new interface driver ums_eneub6250
<6>[ 1.008125] usbcore: registered new interface driver ums-freecom
<6>[ 1.008165] usbcore: registered new interface driver ums-isd200
<6>[ 1.008205] usbcore: registered new interface driver ums-jumpshot
<6>[ 1.008244] usbcore: registered new interface driver ums-karma
<6>[ 1.008284] usbcore: registered new interface driver ums-onetouch
<6>[ 1.008325] usbcore: registered new interface driver ums-sddr09
<6>[ 1.008369] usbcore: registered new interface driver ums-sddr55
<6>[ 1.008412] usbcore: registered new interface driver ums-usbat
<6>[ 1.008503] usbcore: registered new interface driver usbserial
<6>[ 1.008547] usbcore: registered new interface driver usbserial_generic
<6>[ 1.008585] usbserial: USB Serial support registered for generic
<6>[ 1.008629] usbcore: registered new interface driver ch341
<6>[ 1.008661] usbserial: USB Serial support registered for ch341-uart
<6>[ 1.008704] usbcore: registered new interface driver cp210x
<6>[ 1.008739] usbserial: USB Serial support registered for cp210x
<6>[ 1.008790] usbcore: registered new interface driver option
<6>[ 1.008822] usbserial: USB Serial support registered for GSM modem (1-port)
<6>[ 1.008921] usbcore: registered new interface driver pl2303
<6>[ 1.008954] usbserial: USB Serial support registered for pl2303
<6>[ 1.009006] usbcore: registered new interface driver trancevibrator
<6>[ 1.009019] usb20_otg: version 3.10a 21-DEC-2012
<4>[ 1.009484] e1700040
<4>[ 1.009499] Core Release: 3.10a
<4>[ 1.009511] Setting default values for core params
<4>[ 1.009644] Using Buffer DMA mode
<4>[ 1.009656] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 1.009667] Multiprocessor Interrupt Enhancement - disabled
<4>[ 1.009678] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 1.009689] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 1.009703] Dedicated Tx FIFOs mode
<4>[ 1.009738] pcd_init otg_dev = dde65bc0
<6>[ 1.009889] usb20_otg ff580000.usb: DWC OTG Controller
<6>[ 1.009922] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 3
<6>[ 1.009955] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
<6>[ 1.010015] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.010032] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.010047] usb usb3: Product: DWC OTG Controller
<6>[ 1.010060] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 1.010073] usb usb3: SerialNumber: ff580000.usb
<6>[ 1.010507] hub 3-0:1.0: USB hub found
<6>[ 1.010536] hub 3-0:1.0: 1 port detected
<6>[ 1.012887] usb20_host: version 3.10a 21-DEC-2012
<4>[ 1.015425] e1780040
<4>[ 1.015439] Core Release: 3.10a
<4>[ 1.015449] Setting default values for core params
<4>[ 1.015567] Using Buffer DMA mode
<4>[ 1.015579] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 1.015590] Multiprocessor Interrupt Enhancement - disabled
<4>[ 1.015601] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 1.015611] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 1.015635] usb20_host ff540000.usb: DWC OTG Controller
<6>[ 1.015661] usb20_host ff540000.usb: new USB bus registered, assigned bus number 4
<6>[ 1.015690] usb20_host ff540000.usb: irq 57, io mem 0x00000000
<4>[ 1.015782] Init: Power Port (0)
<6>[ 1.015841] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.015858] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.015873] usb usb4: Product: DWC OTG Controller
<6>[ 1.015885] usb usb4: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 1.015898] usb usb4: SerialNumber: ff540000.usb
<6>[ 1.016322] hub 4-0:1.0: USB hub found
<6>[ 1.016345] hub 4-0:1.0: 1 port detected
<6>[ 1.017048] usbcore: registered new interface driver xpad
<6>[ 1.017108] usbcore: registered new interface driver usb_acecad
<6>[ 1.017156] usbcore: registered new interface driver aiptek
<6>[ 1.017201] usbcore: registered new interface driver gtco
<6>[ 1.017248] usbcore: registered new interface driver hanwang
<6>[ 1.017292] usbcore: registered new interface driver kbtab
<6>[ 1.017347] usbcore: registered new interface driver wacom
<4>[ 1.017358] ==gsl_ts_init==
<4>[ 1.017454] GSLX680 Enter gsl_ts_probe
<4>[ 1.109170] Using Buffer DMA mode
<4>[ 1.109184] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 1.109195] Multiprocessor Interrupt Enhancement - disabled
<4>[ 1.109206] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 1.109217] ^^^^^^^^^^^^^^^^^^Host Mode
<4>[ 1.150544] Init: Power Port (0)
<4>[ 1.150559] rk_battery_charger_detect_cb , battery_charger_detect 5
<4>[ 1.553920] gsl_ts_probe–1318, i2c_master_recv fail
<4>[ 1.553945] gslX680: probe of 4-0041 failed with error -11
<4>[ 1.553987] ret=0
<4>[ 1.554303] sensor_register_slave:mma8452,id=17
<4>[ 1.554318] sensor_register_slave:gs_mc3230,id=23
<4>[ 1.554328] gsensor_init
<4>[ 1.554339] sensor_register_slave:mpu6880_acc,id=24
<4>[ 1.554351] sensor_register_slave:mpu6500_acc,id=25
<4>[ 1.554361] sensor_register_slave:cm3217,id=48
<4>[ 1.554372] sensor_register_slave:cm3218,id=49
<3>[ 1.554598] .. rk pwm remotectl v1.1 init
<6>[ 1.554854] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
<7>[ 1.557874] of_get_named_gpio_flags exited with status 228
<6>[ 1.559866] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
<6>[ 1.560472] i2c /dev entries driver
<6>[ 1.561142] IR NEC protocol handler initialized
<6>[ 1.561156] IR RC5(x) protocol handler initialized
<6>[ 1.561167] IR RC6 protocol handler initialized
<6>[ 1.561177] IR JVC protocol handler initialized
<6>[ 1.561186] IR Sony protocol handler initialized
<6>[ 1.561197] IR RC5 (streamzap) protocol handler initialized
<6>[ 1.561207] IR SANYO protocol handler initialized
<6>[ 1.561216] IR MCE Keyboard/mouse protocol handler initialized
<6>[ 1.561376] usbcore: registered new interface driver uvcvideo
<6>[ 1.561388] USB Video Class driver (1.1.1)
<4>[ 1.561402] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
<7>[ 1.562827] of_get_named_gpio_flags exited with status 236
<4>[ 1.562840] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
<7>[ 1.562855] of_get_named_gpio_flags exited with status 236
<4>[ 1.562864] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
<4>[ 1.562886] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
<4>[ 1.562907] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
<4>[ 1.562947] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
<4>[ 1.562947]
<4>[ 1.563022] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
<4>[ 1.563175] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe15f8000 size: 0x4000)
<4>[ 1.563837] D1:camsys_platform_probe(1446): ff910000.isp memory:
<4>[ 1.563856] D1:camsys_platform_probe(1456): Register memory (phy: 0xff910000 vir: 0xe1620000 size: 0x10000)
<4>[ 1.563873] D1:camsys_platform_probe(1451): I2c memory (phy: 0x1dec6000 vir: 0xddec6000 size: 0x1000)
<4>[ 1.563889] D1:camsys_init_ext_fsh_module(20): init external flash module
<4>[ 1.563901] D1:camsys_platform_probe(1471): Probe ff910000.isp device success
<6>[ 1.564292] not find test_power_init dev node
<4>[ 1.564344] i2c-core: driver [bq27320] using legacy suspend method
<4>[ 1.564357] i2c-core: driver [bq27320] using legacy resume method
<4>[ 1.564703] rockchip_temp_probe,line=364
<6>[ 1.622812] tsadc ff280000.tsadc: initialized
<6>[ 1.623189] device-mapper: uevent: version 1.0.3
<6>[ 1.623435] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
<6>[ 1.623733] Bluetooth: HCI UART driver ver 2.2
<6>[ 1.623750] Bluetooth: HCI H4 protocol initialized
<6>[ 1.623762] Bluetooth: HCILL protocol initialized
<6>[ 1.623773] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
<6>[ 1.623785] rtk_btusb: Register usb char device interface for BT driver
<6>[ 1.623975] usbcore: registered new interface driver rtk_btusb
<4>[ 1.624614] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(585000), use default, just enable dvfs
<4>[ 1.628688] cpufreq version 1.0, suspend freq 1200 MHz
<6>[ 1.628886] cpuidle: using governor ladder
<6>[ 1.628898] cpuidle: using governor menu
<6>[ 1.628942] Synopsys Designware Multimedia Card Interface Driver
<6>[ 1.628954] MHSC version = Ver 2.00 2015-06-10
<4>[ 1.629250] dw cru_regsbase addr 0x1d8.
<4>[ 1.629263] dw cru_reset_offset val 3.
<6>[ 1.629277] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
<3>[ 1.629322] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.629619] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
<4>[ 1.629783] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
<7>[ 1.629813] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.629914] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 1.642497] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 1.662199] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
<6>[ 1.663319] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
<6>[ 1.663338] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
<4>[ 1.663717] dw cru_regsbase addr 0x1d8.
<4>[ 1.663731] dw cru_reset_offset val 0.
<6>[ 1.663741] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
<3>[ 1.663770] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.665679] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
<4>[ 1.665803] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
<7>[ 1.665824] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.666259] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
<4>[ 1.666333] 1358..dw_mci_set_ios: no card. [mmc1]
<4>[ 1.681849] 1358..dw_mci_set_ios: no card. [mmc1]
<6>[ 1.694298] mmc0: BKOPS_EN bit is not set
<4>[ 1.696171] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
<6>[ 1.698449] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
<4>[ 1.698471] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
<6>[ 1.698491] [mmc0] tuning regsbase addr 0x218.
<3>[ 1.699183] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
<3>[ 1.699193] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 1.699222] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
<3>[ 1.699248] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
<3>[ 1.699257] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 1.699286] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
<3>[ 1.699329] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-248 (23 len)
<3>[ 1.699341] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 282-282 (1 len)
<3>[ 1.699352] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-248 (23 len)
<3>[ 1.699362] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 124
<6>[ 1.699404] mmc0: new HS200 MMC card at address 0001
<6>[ 1.699697] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
<6>[ 1.699807] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB
<6>[ 1.700109] uboot: 0x000400000 – 0x000800000 (4 MB)
<6>[ 1.700122] misc: 0x000800000 – 0x000c00000 (4 MB)
<6>[ 1.700131] resource: 0x000c00000 – 0x001c00000 (16 MB)
<6>[ 1.700140] kernel: 0x001c00000 – 0x002c00000 (16 MB)
<6>[ 1.700149] boot: 0x002c00000 – 0x004c00000 (32 MB)
<6>[ 1.700157] recovery: 0x004c00000 – 0x006c00000 (32 MB)
<6>[ 1.700166] backup: 0x006c00000 – 0x00a000000 (52 MB)
<6>[ 1.700175] cache: 0x00a000000 – 0x012000000 (128 MB)
<6>[ 1.700183] kpanic: 0x012000000 – 0x012400000 (4 MB)
<6>[ 1.700192] system: 0x012400000 – 0x072400000 (1536 MB)
<6>[ 1.700200] metadata: 0x072400000 – 0x073400000 (16 MB)
<6>[ 1.700208] baseparamer: 0x073400000 – 0x073800000 (4 MB)
<6>[ 1.700217] userdata: 0x077800000 – 0x1d1c00000 (5540 MB)
<6>[ 1.701561] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
<6>[ 1.701576] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
<6>[ 1.700245] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc1]
<4>[ 1.701893] dw cru_regsbase addr 0x1d8.
<4>[ 1.701902] dw cru_reset_offset val 1.
<6>[ 1.701913] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
<3>[ 1.701954] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.702185] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
<4>[ 1.702312] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
<7>[ 1.702333] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.702584] 1358..dw_mci_set_ios: no card. [mmc2]
<4>[ 1.721206] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 1.740937] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
<6>[ 1.740950] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
<4>[ 1.741239] leds-gpio leds.28: pins are not configured from the driver
<7>[ 1.741258] of_get_named_gpio_flags exited with status 262
<7>[ 1.741266] of_get_named_gpio_flags exited with status 257
<7>[ 1.741275] of_get_named_gpio_flags exited with status 262
<7>[ 1.741349] of_get_named_gpio_flags exited with status 257
<6>[ 1.741449] hidraw: raw HID events driver (C) Jiri Kosina
<6>[ 1.742897] usbcore: registered new interface driver usbhid
<6>[ 1.742909] usbhid: USB HID core driver
<6>[ 1.743021] ashmem: initialized
<6>[ 1.743136] logger: created 256K log ‘log_main’
<6>[ 1.743248] logger: created 256K log ‘log_events’
<6>[ 1.743343] logger: created 256K log ‘log_radio’
<6>[ 1.743434] logger: created 256K log ‘log_system’
<7>[ 1.744315] of_get_named_gpio_flags exited with status 5
<7>[ 1.744328] of_get_named_gpio_flags exited with status 5
<6>[ 1.744566] input: rk29-keypad as /devices/ff100000.adc/key.30/input/input1
<3>[ 1.745439] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
<3>[ 1.745455] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
<3>[ 1.745466] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
<3>[ 1.745477] ES8323 2-0010: Error applying setting, reverse things back
<7>[ 1.745504] of_get_named_gpio_flags exited with status 10
<7>[ 1.745514] of_get_named_gpio_flags exited with status 226
<7>[ 1.745521] of_get_named_gpio_flags exited with status 239
<4>[ 1.745527] es8323_adc = 1
<7>[ 1.745535] of_get_named_gpio_flags exited with status 229
<7>[ 1.745548] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.745553] jp es8323_line_det_gpio:-1
<4>[ 1.745810] es8323 probe i2c recv ok
<6>[ 1.746770] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
<4>[ 1.747347] es8323_probe
<4>[ 1.761197] mmc1: Skipping voltage switch
<6>[ 1.813428] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
<4>[ 1.813452] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc1]
<4>[ 1.813497] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc1]
<6>[ 1.813509] mmc1: new high speed SDHC card at address aaaa
<6>[ 1.813775] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
<6>[ 1.815720] mmcblk1: p1
<4>[ 1.815997] 1358..dw_mci_set_ios: no card. [mmc2]
<4>[ 2.380840] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
<3>[ 2.380853] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
<4>[ 2.380864] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
<3>[ 2.380872] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
<4>[ 2.380882] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
<3>[ 2.380890] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
<4>[ 2.380900] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
<3>[ 2.380908] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
<4>[ 2.380917] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
<3>[ 2.380925] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
<4>[ 2.380934] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
<3>[ 2.380942] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
<4>[ 2.380951] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
<3>[ 2.380958] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
<4>[ 2.380967] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
<3>[ 2.380974] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
<4>[ 2.380983] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
<3>[ 2.380990] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
<4>[ 2.380999] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
<3>[ 2.381007] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
<4>[ 2.381016] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
<3>[ 2.381024] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
<4>[ 2.381033] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
<3>[ 2.381041] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
<4>[ 2.381051] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
<3>[ 2.381059] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
<4>[ 2.381068] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
<3>[ 2.381077] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
<4>[ 2.381086] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
<3>[ 2.381094] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
<4>[ 2.381103] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
<3>[ 2.381112] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
<4>[ 2.381133] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
<3>[ 2.381140] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
<4>[ 2.381149] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
<3>[ 2.381157] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
<4>[ 2.381167] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
<3>[ 2.381175] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
<4>[ 2.381185] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
<3>[ 2.381192] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
<4>[ 2.381202] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
<3>[ 2.381210] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
<4>[ 2.381219] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
<3>[ 2.381227] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
<3>[ 2.381357] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
<3>[ 2.381370] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
<3>[ 2.381381] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
<3>[ 2.381391] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
<3>[ 2.381416] ES8323 2-0010: ASoC: mux Differential Mux has no paths
<6>[ 2.387711] rockchip-es8323 rockchip-es8323.27: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
<6>[ 2.388099] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.27/sound/card0/input2
<6>[ 2.388515] u32 classifier
<6>[ 2.388522] Actions configured
<6>[ 2.388532] Netfilter messages via NETLINK v0.30.
<6>[ 2.388587] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
<6>[ 2.388867] ctnetlink v0.93: registering with nfnetlink.
<6>[ 2.388929] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 2.388936] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 2.389157] xt_time: kernel timezone is -0000
<6>[ 2.389320] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 2.389437] arp_tables: (C) 2002 David S. Miller
<6>[ 2.389471] TCP: cubic registered
<6>[ 2.389477] Initializing XFRM netlink socket
<6>[ 2.389654] NET: Registered protocol family 10
<6>[ 2.390110] mip6: Mobile IPv6
<6>[ 2.390135] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 2.390256] sit: IPv6 over IPv4 tunneling driver
<6>[ 2.390580] NET: Registered protocol family 17
<6>[ 2.390602] NET: Registered protocol family 15
<5>[ 2.390651] Bridge firewalling registered
<6>[ 2.390663] Ebtables v2.0 registered
<6>[ 2.390800] Bluetooth: RFCOMM TTY layer initialized
<6>[ 2.390821] Bluetooth: RFCOMM socket layer initialized
<6>[ 2.390827] Bluetooth: RFCOMM ver 1.11
<6>[ 2.390833] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 2.390839] Bluetooth: BNEP filters: protocol multicast
<6>[ 2.390849] Bluetooth: BNEP socket layer initialized
<6>[ 2.390855] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 2.390865] Bluetooth: HIDP socket layer initialized
<6>[ 2.390890] l2tp_core: L2TP core driver, V2.0
<6>[ 2.390901] l2tp_ppp: PPPoL2TP kernel driver, V2.0
<6>[ 2.390908] [WLAN_RFKILL]: Enter rfkill_wlan_init
<6>[ 2.391120] [WLAN_RFKILL]: Enter rfkill_wlan_probe
<6>[ 2.391131] [WLAN_RFKILL]: can’t find rockchip,grf property
<6>[ 2.391139] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212
<6>[ 2.391147] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
<6>[ 2.391154] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
<6>[ 2.391162] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
<7>[ 2.391175] of_get_named_gpio_flags exited with status 156
<6>[ 2.391181] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
<7>[ 2.391188] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 2.391193] of_get_named_gpio_flags exited with status 158
<6>[ 2.391199] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
<6>[ 2.391207] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
<6>[ 2.391234] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
<6>[ 2.391243] [WLAN_RFKILL]: Exit rfkill_wlan_probe
<6>[ 2.391276] [BT_RFKILL]: Enter rfkill_rk_init
<7>[ 2.391399] of_get_named_gpio_flags exited with status 147
<6>[ 2.391406] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
<7>[ 2.391414] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 2.391420] of_get_named_gpio_flags exited with status 157
<6>[ 2.391424] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
<7>[ 2.391432] of_get_named_gpio_flags exited with status 154
<6>[ 2.391438] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
<7>[ 2.391445] of_get_named_gpio_flags exited with status 159
<6>[ 2.391451] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
<6>[ 2.391493] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ 2.391587] [BT_RFKILL]: ** disable irq
<6>[ 2.391657] [BT_RFKILL]: ap6335 device registered.
<4>[ 2.392308] rk3288_init_suspend
<4>[ 2.392320] rk3288_suspend_init enter
<4>[ 2.392516] rk3288_suspend_init: pm_ctrbits =200007
<4>[ 2.392545] gpio_get_dts_info suspend:4
<4>[ 2.392552] gpio_get_dts_info resume:4
<4>[ 2.392557] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 2.392582] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 2.392709] clks_gating_suspend_init:clkgt info ok
<5>[ 2.392789] Registering SWP/SWPB emulation handler
<6>[ 2.393185] ddrfreq: verion 1.2 20140526
<6>[ 2.393196] ddrfreq: normal 528MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 528MHz
<6>[ 2.393203] ddrfreq: auto-freq=0
<6>[ 2.393209] ddrfreq: auto-freq-table[0] 240MHz
<6>[ 2.393214] ddrfreq: auto-freq-table[1] 324MHz
<6>[ 2.393219] ddrfreq: auto-freq-table[2] 456MHz
<6>[ 2.393224] ddrfreq: auto-freq-table[3] 528MHz
<6>[ 2.399660] regulator-dummy: disabling
<4>[ 2.399919] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
<7>[ 2.399931] of_get_named_gpio_flags exited with status 110
<7>[ 2.399945] of_get_named_gpio_flags exited with status 18
<7>[ 2.567260] of_get_named_gpio_flags exited with status 7
<7>[ 2.567287] of_get_named_gpio_flags exited with status 173
<1>[ 2.567386] wk2xxx_probe() GENA = 0xFF
<3>[ 2.567391] spi driver error!!!
<4>[ 2.567406] wk2xxxspi: probe of spi0.0 failed with error 1
<1>[ 2.567431] register spi return v = :0
<4>[ 2.567438] =======================================================
<4>[ 2.567443] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[ 2.567448] =======================================================
<4>[ 2.567454] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
<4>[ 2.567515] dhd_module_init: in
<4>[ 2.567522] ======== dhd_wlan_init_plat_data ========
<4>[ 2.567529] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
<4>[ 2.567534] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
<6>[ 2.567539] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
<4>[ 2.567556] dhd_wlan_init_gpio: host_oob_irq: 197
<4>[ 2.567563] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
<4>[ 2.567566] pcd_pullup, is_on 0
<4>[ 2.567573] dhd_wifi_platform_load: Enter
<4>[ 2.567579] WARN::dwc_otg_handle_mode_mismatch_intr:69: Mode Mismatch Interrupt: currently in Host mode
<4>[ 2.567579]
<6>[ 2.567597] file system registered
<4>[ 2.567600] Power-up adapter ‘DHD generic adapter’
<4>[ 2.567617] wifi_platform_set_power = 1
<4>[ 2.567623] ======== PULL WL_REG_ON(-1) HIGH! ========
<6>[ 2.567629] [WLAN_RFKILL]: rockchip_wifi_power: 1
<6>[ 2.567635] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
<6>[ 2.567640] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<6>[ 2.568135] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 2.568143] android_usb gadget: Number of LUNs=2
<6>[ 2.568150] lun0: LUN: removable file: (no medium)
<6>[ 2.568156] lun1: LUN: removable file: (no medium)
<6>[ 2.568297] android_usb gadget: android_usb ready
<6>[ 2.568393] i2c i2c-4: sensor_probe: gs_mc3230,debd1600
<7>[ 2.568402] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 2.568406] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 2.568411] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 2.568419] sensor_chip_init:gs_mc3230:devid=0x0,ops=0xc0d2dd08
<6>[ 2.628209] [Gsensor] init_3230_ctl_data 671 : error: -11
<4>[ 2.628703] sensor_active:line=1500,error
<4>[ 2.628709] sensor_init:line=1548,error
<4>[ 2.628714] sensor_initial:fail to init sensor
<4>[ 2.628719] sensor_chip_init:fail to init sensor
<3>[ 2.628726] i2c i2c-4: sensor_probe failed -11
<3>[ 2.628726]
<4>[ 2.628739] sensors: probe of 4-004c failed with error -11
<6>[ 2.628757] sensor_init: Probe name sensors
<4>[ 2.628772] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
<6>[ 2.629295] rtc_hym8563 0-0051: setting system clock to 2018-08-16 09:22:49 UTC (1534411369)
<6>[ 2.635354] rockchip-spdif-card rockchip-spdif-card.26: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
<4>[ 2.638935] ret 1024
<6>[ 2.639298] usbcore: registered new interface driver snd-usb-audio
<6>[ 2.639305] ALSA device list:
<6>[ 2.639310] #0: RK_ES8323
<6>[ 2.639315] #1: RK-SPDIF-CARD
<6>[ 2.639658] Freeing unused kernel memory: 356K (c0bbc000 - c0c15000)
<6>[ 2.675683] [WLAN_RFKILL]: wifi turn on power. 156
<7>[ 2.754567] SELinux: 2048 avtab hash slots, 5368 rules.
<7>[ 2.756271] SELinux: 2048 avtab hash slots, 5368 rules.
<7>[ 2.756289] SELinux: 1 users, 2 roles, 442 types, 0 bools, 1 sens, 1024 cats
<7>[ 2.756296] SELinux: 86 classes, 5368 rules
<7>[ 2.757155] SELinux: Completing initialization.
<7>[ 2.757161] SELinux: Setting up existing superblocks.
<7>[ 2.757176] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<7>[ 2.757191] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>[ 2.757240] SELinux: initialized (dev bdev, type bdev), not configured for labeling
<7>[ 2.757252] SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>[ 2.757265] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.757279] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
<7>[ 2.757447] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>[ 2.767650] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>[ 2.767665] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>[ 2.767674] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
<7>[ 2.767683] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>[ 2.767700] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>[ 2.767742] SELinux: initialized (dev configfs, type configfs), not configured for labeling
<7>[ 2.767750] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.767770] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<5>[ 2.806570] type=1403 audit(1534411369.670:2): policy loaded auid=4294967295 ses=4294967295
<11>[ 2.830592] init: invalid gid ‘trace’
<4>[ 2.882332] wifi_platform_bus_enumerate device present 1
<4>[ 2.882348] ======== Card detection to detect SDIO card! ========
<6>[ 2.882360] mmc2:mmc host rescan start!
<11>[ 2.919326] init: /dev/hw_random not found
<6>[ 2.919381] keychord: using input dev ff680000.pwm for fevent
<6>[ 2.919396] keychord: using input dev rk29-keypad for fevent
<7>[ 2.919808] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 2.920046] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.920291] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 2.921379] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.921519] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<6>[ 2.921689] EHCI: rk_ehci_hcd_enable, disable host controller
<7>[ 2.922655] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<11>[ 2.923728] init: /dev/hw_random not found
<14>[ 2.924589] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 2.925302] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
<4>[ 2.927573] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
<6>[ 2.931279] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 2.931303] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 2.931359] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
<14>[ 2.932417] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 2.937211] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 2.937257] e2fsck: system: clean, 1916/86400 files, 117730/393216 blocks
<6>[ 2.940773] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<7>[ 2.940797] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 2.940839] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
<6>[ 2.944646] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 2.944667] SELinux: initialized (dev mmcblk0p8, type ext4), uses xattr
<14>[ 2.944704] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
<4>[ 2.944992] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
<6>[ 2.948487] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 2.948508] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 2.948541] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
<14>[ 2.949212] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
<14>[ 2.953335] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 2.953370] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
<6>[ 2.957228] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 2.957252] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 2.957293] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
<14>[ 2.957334] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<14>[ 2.958173] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
<14>[ 2.958210] fsck.f2fs: fsck.f2fs terminated by exit(255)
<14>[ 2.958462] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
<4>[ 2.958813] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
<6>[ 2.962512] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 2.962536] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
<14>[ 2.962575] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
<14>[ 2.963280] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<14>[ 2.971352] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 2.971389] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 11/354816 files, 47251/1418240 blocks
<6>[ 2.975373] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
<7>[ 2.975401] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
<14>[ 2.975438] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
<11>[ 2.975459] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
<7>[ 2.976113] SELinux: initialized (dev functionfs, type functionfs), uses genfs_contexts
<4>[ 2.990578] dwc_otg_hcd_enable, enable host controller
<6>[ 2.994754] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
<6>[ 2.994832] mali ffa30000.gpu: Continuing without Mali clock control
<4>[ 2.994876] mali pd enabled
<4>[ 2.994888] clk enabled
<4>[ 2.994901] MALI_DVFS_STEP = 4, div_dvfs = 10
<6>[ 2.994912] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
<6>[ 2.994921] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
<6>[ 2.994932] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
<6>[ 2.994942] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
<3>[ 2.995026] turn on mali power
<6>[ 2.995038] kbase_platform_rk_init,register_reboot_notifier
<4>[ 2.995087] hrtimer: interrupt took 16334 ns
<6>[ 2.995183] mali ffa30000.gpu: GPU identified as 0x0750 r1p0 status 0
<6>[ 2.995927] mali ffa30000.gpu: Probed as mali0
<3>[ 2.996878] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 2.997438] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 2.997977] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<6>[ 2.998751] zram0: detected capacity change from 0 to 533413888
<6>[ 3.044302] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
<4>[ 3.096585] Using Buffer DMA mode
<4>[ 3.096602] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 3.096613] Multiprocessor Interrupt Enhancement - disabled
<4>[ 3.096623] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 3.096631] ^^^^^^^^^^^^^^^^^^Host Mode
<4>[ 3.098799] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
<3>[ 3.121852] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
<4>[ 3.126724] drmboot: module license ‘unspecified’ taints kernel.
<4>[ 3.126745] Disabling lock debugging due to kernel taint
<4>[ 3.126954] drm init, 20140910
<4>[ 3.127398] drm init ok
<14>[ 3.128874] bat_cap: oldcap path is /sys/devices/ff100000.adc
<11>[ 3.128917] bat_cap: oldcap_path no exist
<6>[ 3.129055] binder: 153:153 transaction failed 29189, size 0-0
<11>[ 3.129689] init: Warning! Service displayd needs a SELinux domain defined; please fix!
<4>[ 3.134220] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
<11>[ 3.134732] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
<5>[ 3.134754] type=1400 audit(1534411370.000:3): avc: denied { transition } for pid=159 comm=“init” path=“/system/xbin/vm” dev=“mmcblk0p10” ino=1915 scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
<11>[ 3.134759] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
<11>[ 3.134950] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
<6>[ 3.135441] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 3.135455] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 3.135469] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 3.135478] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 3.135500] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 3.135510] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 3.135523] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 3.135532] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<4>[ 3.135771] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 3.137308] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 3.138251] Init: Power Port (0)
<4>[ 3.140063] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
<4>[ 3.143523] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
<11>[ 3.143678] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
<11>[ 3.145117] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
<11>[ 3.145535] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
<11>[ 3.145699] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
<6>[ 3.227915] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
<4>[ 3.227938] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
<4>[ 3.227995] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
<6>[ 3.229497] mmc2: new high speed SDIO card at address 0001
<4>[ 3.245636] bcmsdh_register: register client driver
<4>[ 3.245728] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 3.245786] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 3.245793] bus num (host idx)=2, slot num (rca)=1
<4>[ 3.245799] found adapter info ‘DHD generic adapter’
<4>[ 3.245829] sdioh_attach: set sd_f2_blocksize 128
<4>[ 3.246069] F1 signature read @0x18000000=0x1541a9a6
<4>[ 3.247891] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
<4>[ 3.248528] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
<4>[ 3.248612] wifi_platform_get_mac_addr
<4>[ 3.248618] ======== dhd_wlan_get_mac_addr ========
<6>[ 3.248624] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
<6>[ 3.248633] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
<6>[ 3.248639] [WLAN_RFKILL]: This mac address is not valid, ignored…
<4>[ 3.248649] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=1
<4>[ 3.248685] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
<4>[ 3.248981] wl_create_event_handler(): thread:wl_event_handler:ab started
<4>[ 3.249053] wl_escan_attach: Enter
<4>[ 3.249077] wl_escan_init: Enter
<4>[ 3.249100] tsk Enter, tsk = 0xdd16149c
<4>[ 3.249120] wl_create_event_handler(): thread:wl_escan_handler:ac started
<4>[ 3.249135] tsk Enter, tsk = 0xdd190164
<4>[ 3.249158] dhd_attach(): thread:dhd_watchdog_thread:ad started
<4>[ 3.249204] dhd_attach(): thread:dhd_dpc:ae started
<4>[ 3.249250] dhd_attach(): thread:dhd_rxf:af started
<4>[ 3.249261] dhd_deferred_work_init: work queue initialized
<4>[ 3.256265] Dongle Host Driver, version 1.201.59.11 (r506368)
<4>[ 3.256265] Compiled in drivers/net/wireless/bcmdhd on Aug 2 2018 at 12:02:24
<4>[ 3.256568] Register interface [wlan0] MAC: 10:d0:7a:37:14:1a
<4>[ 3.256568]
<4>[ 3.256581] dhd_prot_ioctl : bus is down. we have nothing to do
<4>[ 3.256620] bcmsdh_oob_intr_unregister: Enter
<4>[ 3.256627] bcmsdh_oob_intr_unregister: irq is not registered
<4>[ 3.256638] dhd_txglom_enable: enable 0
<4>[ 3.256646] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
<4>[ 3.256652] dhd_conf_set_txglom_params: txglom_bucket_size=0
<4>[ 3.256660] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
<4>[ 3.256667] dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0, txctl_tmo_fix=1
<4>[ 3.256675] sdioh_set_mode: set txglom_mode to multi-desc
<4>[ 3.256682] dhd_bus_devreset: WLAN OFF DONE
<4>[ 3.256727] wifi_platform_set_power = 0
<4>[ 3.256734] ======== PULL WL_REG_ON(-1) LOW! ========
<6>[ 3.256740] [WLAN_RFKILL]: rockchip_wifi_power: 0
<6>[ 3.364478] [WLAN_RFKILL]: wifi shut off power.
<6>[ 3.364490] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
<6>[ 3.364497] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<4>[ 3.364548] dhd_module_init: Exit err=0
<7>[ 3.402941] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<3>[ 3.403335] android_usb: already disabled
<4>[ 3.403893] Indeed it is in host mode hprt0 = 00021501
<6>[ 3.405235] read descriptors
<6>[ 3.405247] read strings
<6>[ 3.405262] mtp_bind_config
<4>[ 3.405284] pcd_pullup, is_on 1
<7>[ 3.418132] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
<4>[ 3.455615] RKNAND_GET_SN_SECTOR
<4>[ 3.455629] return ret = 0
<4>[ 3.461569] RKNAND_GET_DRM_KEY
<4>[ 3.461581] return ret = 0
<38>[ 3.467874] logd.auditd: start
<38>[ 3.494747] type=1400 audit(1534411370.370:4): avc: denied { setattr } for pid=198 comm=“chmod” name=“vmdrm0” dev=“tmpfs” ino=1280 scontext=u:r:rild:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
<38>[ 3.494935] type=1400 audit(1534411370.370:5): avc: denied { fsetid } for pid=198 comm=“chmod” capability=4 scontext=u:r:rild:s0 tcontext=u:r:rild:s0 tclass=capability permissive=1
<38>[ 3.495045] type=1400 audit(1534411370.370:6): avc: denied { read write } for pid=163 comm=“rild” name=“vmdrm0” dev=“tmpfs” ino=1280 scontext=u:r:rild:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
<38>[ 3.495173] type=1400 audit(1534411370.370:7): avc: denied { open } for pid=163 comm=“rild” path=“/dev/vmdrm0” dev=“tmpfs” ino=1280 scontext=u:r:rild:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
<38>[ 3.495246] type=1400 audit(1534411370.370:8): avc: denied { ioctl } for pid=163 comm=“rild” path=“/dev/vmdrm0” dev=“tmpfs” ino=1280 ioctlcmd=b503 scontext=u:r:rild:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
<38>[ 3.500600] type=1400 audit(1534411370.370:9): avc: denied { rlimitinh } for pid=159 comm=“vm” scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
<38>[ 3.500720] type=1400 audit(1534411370.370:10): avc: denied { siginh } for pid=159 comm=“vm” scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
<12>[ 3.505931] avc: denied { set } for property=telephony.lteOnCdmaDevice scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service
<6>[ 3.580982] usb 4-1: new high-speed USB device number 2 using usb20_host
<4>[ 3.581052] Indeed it is in host mode hprt0 = 00001101
<6>[ 3.780649] usb 4-1: New USB device found, idVendor=1a40, idProduct=0101
<6>[ 3.780661] usb 4-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>[ 3.780669] usb 4-1: Product: USB 2.0 Hub [MTT]
<6>[ 3.781110] hub 4-1:1.0: USB hub found
<6>[ 3.781168] hub 4-1:1.0: 4 ports detected
<6>[ 4.073057] usb 4-1.4: new low-speed USB device number 3 using usb20_host
<11>[ 4.113649] healthd: No charger supplies found
<12>[ 4.113667] healthd: No battery devices found
<6>[ 4.195211] usb 4-1.4: New USB device found, idVendor=046d, idProduct=c077
<6>[ 4.195224] usb 4-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
<6>[ 4.195233] usb 4-1.4: Product: USB Optical Mouse
<6>[ 4.195240] usb 4-1.4: Manufacturer: Logitech
<6>[ 4.201750] input: Logitech USB Optical Mouse as /devices/ff540000.usb/usb4/4-1/4-1.4/4-1.4:1.0/input/input3
<6>[ 4.202041] hid-generic 0003:046D:C077.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-ff540000.usb-1.4/input0
<6>[ 4.214397] rk3288-lcdc lcdc0: blank mode:0
<4>[ 8.848160] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 8.848179] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 8.848187] D1:camsys_open(739): camsys_marvin(de014f10) is opened!
<4>[ 8.848276] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 8.848290] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 8.848301] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 8.848312] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 8.848317] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 8.848338] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 8.853374] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 8.853385] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 8.853490] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 8.853517] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 8.854581] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 8.855642] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
<4>[ 8.856702] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<3>[ 8.859941] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 8.861147] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 8.861224] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 8.861237] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
<4>[ 8.861249] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 8.862333] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 8.862362] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 8.864412] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 8.864426] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 8.864436] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 8.864443] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 8.864449] D1:camsys_release(763): camsys_marvin(de014f10) is closed
<4>[ 8.865008] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 8.865018] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 8.865040] D1:camsys_open(739): camsys_marvin(de014f10) is opened!
<4>[ 8.865109] D1:camsys_extdev_register(243): Get RK30_PIN2_PB5(77) gpio(active: 0) for dev_id 0x1000000 success!
<4>[ 8.865122] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x1000000 success!
<4>[ 8.865133] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x1000000 success!
<7>[ 8.865143] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 8.865148] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 8.865162] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV13850) register success
<4>[ 8.870196] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 8.870207] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 8.870312] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 8.870337] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 8.871401] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 8.872467] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
<4>[ 8.873526] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(77) set 1
<3>[ 8.876758] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 8.877960] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 8.878033] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(77) set 0
<4>[ 8.878045] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
<4>[ 8.878056] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 8.879132] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 8.879160] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 8.881211] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 8.881225] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 8.881235] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 8.881241] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 8.881248] D1:camsys_release(763): camsys_marvin(de014f10) is closed
<4>[ 8.882927] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 8.882938] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 8.882945] D1:camsys_open(739): camsys_marvin(de014f10) is opened!
<4>[ 8.883021] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
<4>[ 8.883041] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
<6>[ 8.884721] [otg id chg] last id -1 current id 1
<4>[ 8.888071] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 8.888082] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 8.888187] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 8.888213] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
<3>[ 8.889272] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<3>[ 8.890333] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 8.891387] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 8.894890] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
<3>[ 8.896366] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
<3>[ 8.896433] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 8.896442] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 8.896449] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<4>[ 8.897530] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 8.897558] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 8.899607] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 8.899624] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 8.899635] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 8.899642] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 8.899649] D1:camsys_release(763): camsys_marvin(de014f10) is closed
<38>[ 8.911377] type=1400 audit(1534411375.870:11): avc: denied { execute } for pid=469 comm=“mediaserver” name=“sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 8.911611] type=1400 audit(1534411375.870:12): avc: denied { read open } for pid=469 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 8.911767] type=1400 audit(1534411375.870:13): avc: denied { execute_no_trans } for pid=469 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 8.914004] type=1400 audit(1534411375.870:14): avc: denied { getattr } for pid=469 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 8.914173] type=1400 audit(1534411375.870:15): avc: denied { execute } for pid=469 comm=“sh” name=“toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 8.914366] type=1400 audit(1534411375.880:16): avc: denied { read open } for pid=469 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 8.914514] type=1400 audit(1534411375.880:17): avc: denied { execute_no_trans } for pid=469 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<4>[ 9.632758] es8323_mic_state_ctrl read:
<4>[ 9.632807] mic_state_switch 0
<4>[ 9.632815] hp_det = 0,insert hp
<4>[ 9.632819] hp mic use intern
<7>[ 24.589578] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<6>[ 25.679443] warning: `main’ uses 32-bit capabilities (legacy support in use)
<12>[ 40.072439] healthd: battery none chg=
<6>[ 40.282831] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
<6>[ 40.282855] lowmemorykiller: oom_adj 0 => oom_score_adj 0
<6>[ 40.282862] lowmemorykiller: oom_adj 1 => oom_score_adj 58
<6>[ 40.282869] lowmemorykiller: oom_adj 2 => oom_score_adj 117
<6>[ 40.282875] lowmemorykiller: oom_adj 3 => oom_score_adj 176
<6>[ 40.282881] lowmemorykiller: oom_adj 9 => oom_score_adj 529
<6>[ 40.282887] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
<6>[ 40.641116] acc_open
<6>[ 40.643209] acc_release
<4>[ 40.829785] phy_power_on: enable = 1
<4>[ 40.869186] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
<4>[ 40.869218] eth0: device MAC address 56:b3:f1:3b:93:ba
<6>[ 40.873283] libphy: stmmac: probed
<6>[ 40.873295] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
<6>[ 40.873303] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
<4>[ 43.825982] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
<7>[ 43.826046] SELinux: initialized (dev mmcblk1p1, type vfat), uses genfs_contexts
<11>[ 43.876124] init: no such service ‘fuse_external_sd’
<6>[ 44.286393] pm policy 0 → 1
<4>[ 45.310099] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 45.310121] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 45.310128] D1:camsys_open(739): camsys_marvin(de014f10) is opened!
<4>[ 45.310202] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 45.310216] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 45.310227] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 45.310238] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 45.310244] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 45.310265] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 45.315312] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 45.315325] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 45.315430] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 45.315457] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 45.316531] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 45.317602] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
<4>[ 45.318671] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<3>[ 45.321924] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 45.323144] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 45.323223] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 45.323236] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
<4>[ 45.323246] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 45.324337] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 45.324371] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 45.326432] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 45.326447] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 45.326457] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 45.326464] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 45.326471] D1:camsys_release(763): camsys_marvin(de014f10) is closed
<4>[ 45.327073] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 45.327083] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 45.327091] D1:camsys_open(739): camsys_marvin(de014f10) is opened!
<4>[ 45.327166] D1:camsys_extdev_register(243): Get RK30_PIN2_PB5(77) gpio(active: 0) for dev_id 0x1000000 success!
<4>[ 45.327178] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x1000000 success!
<4>[ 45.327189] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x1000000 success!
<7>[ 45.327199] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 45.327204] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 45.327218] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV13850) register success
<4>[ 45.332253] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 45.332266] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 45.332371] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 45.332397] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 45.333469] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 45.334933] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
<4>[ 45.336011] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(77) set 1
<3>[ 45.339286] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 45.340516] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 45.340590] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(77) set 0
<4>[ 45.340602] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
<4>[ 45.340613] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 45.341707] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 45.341740] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 45.343808] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 45.343826] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 45.343837] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 45.343843] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 45.343850] D1:camsys_release(763): camsys_marvin(de014f10) is closed
<4>[ 45.344449] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 45.344459] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 45.344466] D1:camsys_open(739): camsys_marvin(de014f10) is opened!
<4>[ 45.344532] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
<4>[ 45.344554] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
<4>[ 45.349595] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 45.349607] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 45.349712] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 45.349739] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
<3>[ 45.350806] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<3>[ 45.351880] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 45.352948] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 45.356472] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
<3>[ 45.357962] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
<3>[ 45.358031] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 45.358039] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 45.358046] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<4>[ 45.359191] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 45.359223] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 45.361276] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 45.361291] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 45.361301] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 45.361308] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 45.361315] D1:camsys_release(763): camsys_marvin(de014f10) is closed
<4>[ 45.366364] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 45.366378] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 45.366387] D1:camsys_open(739): camsys_marvin(de014f10) is opened!
<4>[ 45.366459] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 45.366471] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 45.366482] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 45.366494] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 45.366499] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 45.366520] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 45.371564] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 45.371576] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 45.371706] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 45.371735] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 45.372802] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 45.373874] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
<4>[ 45.375044] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<3>[ 45.378314] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 45.379542] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 45.379621] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 45.379633] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
<4>[ 45.379644] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 45.380738] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 45.380771] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 45.382835] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 45.382849] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 45.382860] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 45.382867] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 45.382874] D1:camsys_release(763): camsys_marvin(de014f10) is closed
<4>[ 45.383477] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 45.383488] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 45.383495] D1:camsys_open(739): camsys_marvin(de014f10) is opened!
<4>[ 45.383574] D1:camsys_extdev_register(243): Get RK30_PIN2_PB5(77) gpio(active: 0) for dev_id 0x1000000 success!
<4>[ 45.383586] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x1000000 success!
<4>[ 45.383598] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x1000000 success!
<7>[ 45.383609] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 45.383614] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 45.383628] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV13850) register success
<4>[ 45.389377] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 45.389390] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 45.389496] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 45.389523] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 45.390602] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 45.391676] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
<4>[ 45.392746] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(77) set 1
<3>[ 45.396003] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 45.397228] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 45.397308] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(77) set 0
<4>[ 45.397321] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
<4>[ 45.397332] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 45.398421] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 45.398453] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 45.400510] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 45.400524] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 45.400534] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 45.400541] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 45.400548] D1:camsys_release(763): camsys_marvin(de014f10) is closed
<4>[ 45.401143] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 45.401153] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 45.401161] D1:camsys_open(739): camsys_marvin(de014f10) is opened!
<4>[ 45.401221] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
<4>[ 45.401244] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
<4>[ 45.406289] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 45.406302] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 45.406407] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 45.406433] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
<3>[ 45.407498] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<3>[ 45.408565] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 45.409631] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 45.413169] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
<3>[ 45.414679] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
<3>[ 45.414756] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 45.414765] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 45.414773] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<4>[ 45.415870] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 45.415904] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 45.417967] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 45.417985] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 45.417996] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 45.418003] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 45.418011] D1:camsys_release(763): camsys_marvin(de014f10) is closed
<6>[ 45.785070] stmmc_pltfr_fix_mac_speed: fix speed to 100
<6>[ 45.785081] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
<6>[ 45.785089] libphy: stmmac-0:01 - Link is Up - 100/Full
<38>[ 46.625415] type=1400 audit(1534411414.200:18): avc: denied { write } for pid=1378 comm=“chip.devicetest” name=“force_usb_mode” dev=“sysfs” ino=12827 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
<4>[ 46.637519] force_usb_mode_store 1->1
<38>[ 47.392916] type=1400 audit(1534411414.980:19): avc: denied { entrypoint } for pid=1484 comm=“init” path=“/system/bin/usb_mode_switch.sh” dev=“mmcblk0p10” ino=347 scontext=u:r:install_recovery:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1
<38>[ 47.714031] type=1400 audit(1534411415.310:20): avc: denied { write } for pid=1564 comm=“vm” name=“server” dev=“tmpfs” ino=3210 scontext=u:r:system_app:s0 tcontext=u:object_r:device:s0 tclass=sock_file permissive=1
<11>[ 47.726789] init: untracked pid 1566 exited with status 0
<38>[ 47.740848] type=1400 audit(1534411415.330:21): avc: denied { read write } for pid=1378 comm=“chip.devicetest” name=“vmdrm0” dev=“tmpfs” ino=1280 scontext=u:r:system_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
<38>[ 47.747250] type=1400 audit(1534411415.340:22): avc: denied { open } for pid=1378 comm=“chip.devicetest” path=“/dev/vmdrm0” dev=“tmpfs” ino=1280 scontext=u:r:system_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
<38>[ 47.756495] type=1400 audit(1534411415.350:23): avc: denied { ioctl } for pid=1378 comm=“chip.devicetest” path=“/dev/vmdrm0” dev=“tmpfs” ino=1280 ioctlcmd=b503 scontext=u:r:system_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
<11>[ 47.774583] init: untracked pid 1575 exited with status 0
<4>[ 47.877035] Current WiFi chip is AP6212.
<4>[ 48.285589] Current WiFi chip is AP6212.
<4>[ 48.289253] Current WiFi chip is AP6212.
<6>[ 48.447783] [BT_RFKILL]: bt shut off power
<6>[ 48.992640] [BT_RFKILL]: ENABLE UART_RTS
<6>[ 49.100824] [BT_RFKILL]: DISABLE UART_RTS
<6>[ 49.100870] [BT_RFKILL]: bt turn on power
<38>[ 50.102924] type=1400 audit(1534411417.730:24): avc: denied { write } for pid=1378 comm=“chip.devicetest” name=“force_usb_mode” dev=“sysfs” ino=12827 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
<4>[ 50.105139] force_usb_mode_store 1->1
<4>[ 50.536952] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 50.536977] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 50.536986] D1:camsys_open(739): camsys_marvin(de014f10) is opened!
<4>[ 50.537068] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 50.537081] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 50.537098] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 50.537111] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 50.537117] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 50.537138] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 50.542176] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 50.542188] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 50.542294] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 50.542350] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 50.543420] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 50.544486] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
<4>[ 50.545541] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<3>[ 50.548767] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 50.549964] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 50.550037] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 50.550050] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
<4>[ 50.550061] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 50.551148] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 50.551179] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 50.553235] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 50.553249] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 50.553260] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 50.553266] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 50.553274] D1:camsys_release(763): camsys_marvin(de014f10) is closed
<4>[ 50.554171] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 50.554182] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 50.554195] D1:camsys_open(739): camsys_marvin(de014f10) is opened!
<4>[ 50.554272] D1:camsys_extdev_register(243): Get RK30_PIN2_PB5(77) gpio(active: 0) for dev_id 0x1000000 success!
<4>[ 50.554285] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x1000000 success!
<4>[ 50.554297] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x1000000 success!
<7>[ 50.554308] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 50.554318] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 50.554333] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV13850) register success
<4>[ 50.559368] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 50.559382] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 50.559487] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 50.559514] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 50.560576] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 50.561636] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
<4>[ 50.562696] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(77) set 1
<3>[ 50.565924] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 50.567172] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 50.567256] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(77) set 0
<4>[ 50.567269] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
<4>[ 50.567280] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 50.568355] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 50.568379] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 50.570458] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 50.570472] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 50.570483] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 50.570491] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 50.570499] D1:camsys_release(763): camsys_marvin(de014f10) is closed
<4>[ 50.571127] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 50.571138] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 50.571145] D1:camsys_open(739): camsys_marvin(de014f10) is opened!
<4>[ 50.571217] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
<4>[ 50.571239] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
<4>[ 50.576269] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 50.576281] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 50.576386] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 50.576410] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
<3>[ 50.577480] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<3>[ 50.578545] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 50.579602] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 50.583127] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
<3>[ 50.584609] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
<3>[ 50.584677] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 50.584687] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 50.584695] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<4>[ 50.585780] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 50.585815] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 50.588144] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 50.588172] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 50.588183] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 50.588191] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 50.588198] D1:camsys_release(763): camsys_marvin(de014f10) is closed
<11>[ 50.956707] init: untracked pid 1569 exited with status 0
<11>[ 50.956776] init: untracked pid 1578 exited with status 0
<6>[ 51.482252] [BT_RFKILL]: bt shut off power
<6>[ 56.554932] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
<38>[ 99.109816] type=1400 audit(1534411467.593:25): avc: denied { transition } for pid=2008 comm=“init” path=“/system/xbin/su” dev=“mmcblk0p10” ino=1912 scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
<38>[ 99.112997] type=1400 audit(1534411467.593:26): avc: denied { rlimitinh } for pid=2008 comm=“su” scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
<38>[ 99.113173] type=1400 audit(1534411467.593:27): avc: denied { siginh } for pid=2008 comm=“su” scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
<3>[ 101.604346] win[2]->area[1],not support scale
<3>[ 101.604385] xact=20,yact=28,xsize=21,ysize=28
<3>[ 101.638076] win[2]->area[1],not support scale
<3>[ 101.638109] xact=18,yact=28,xsize=19,ysize=28
<3>[ 101.873911] win[2]->area[1],not support scale
<3>[ 101.873949] xact=18,yact=28,xsize=19,ysize=28
<3>[ 126.009432] win[2]->area[1],not support scale
<3>[ 126.009466] xact=16,yact=28,xsize=17,ysize=28
<3>[ 140.477482] win[2]->area[1],not support scale
<3>[ 140.477526] xact=16,yact=28,xsize=17,ysize=28
<3>[ 140.528036] win[2]->area[1],not support scale
<3>[ 140.528073] xact=20,yact=28,xsize=21,ysize=28
<6>[95424.098237] rk3288-lcdc lcdc0: win0:new_addr:0x10000000 cur_addr:0x1138c000–1
<6>[95542.182379] rk3288-lcdc lcdc0: win0:new_addr:0x107d0000 cur_addr:0x1138c000–1
<6>[104631.861316] rk3288-lcdc lcdc0: win0:new_addr:0x1138c000 cur_addr:0x107d0000–1
<6>[104631.861392] rk3288-lcdc lcdc0: win2:new_addr:0x12e16000 cur_addr:0x10000000–1
<6>[106936.901520] rk3288-lcdc lcdc0: win0:new_addr:0x10000000 cur_addr:0x1138c000–1
<6>[125945.307342] rk3288-lcdc lcdc0: win0:new_addr:0x1138c000 cur_addr:0x10000000–1
<6>[125945.307445] rk3288-lcdc lcdc0: win2:new_addr:0x12e16000 cur_addr:0x10000000–1
<6>[158655.948601] rk3288-lcdc lcdc0: win0:new_addr:0x10000000 cur_addr:0x1138c000–1
<6>[158714.982417] rk3288-lcdc lcdc0: win0:new_addr:0x103e8000 cur_addr:0x1138c000–1
<6>[181858.672884] rk3288-lcdc lcdc0: win0:new_addr:0x10000000 cur_addr:0x1138c000–1
<6>[216278.981675] rk3288-lcdc lcdc0: win0:new_addr:0x107d0000 cur_addr:0x1138c000–1
<6>[244972.422458] rk3288-lcdc lcdc0: win0:new_addr:0x107d0000 cur_addr:0x1138c000–1
<6>[250581.222813] rk3288-lcdc lcdc0: win0:new_addr:0x103e8000 cur_addr:0x1138c000–1
<38>[324160.603096] type=1400 audit(1534740798.373:28): avc: denied { read } for pid=8062 comm=“adb” name=“usb” dev=“tmpfs” ino=1212 scontext=u:r
s0 tcontext=u:object_r:usb_device:s0 tclass=dir permissive=1
<38>[324160.605762] type=1400 audit(1534740798.373:29): avc: denied { open } for pid=8062 comm=“adb” path=“/dev/bus/usb” dev=“tmpfs” ino=1212 scontext=u:r
<11>[324160.724956] init: untracked pid 8061 exited with status 1
<38>[324167.909664] type=1400 audit(1534740805.803:30): avc: denied { read } for pid=8072 comm=“adb” name=“usb” dev=“tmpfs” ino=1212 scontext=u:r
<38>[324167.910120] type=1400 audit(1534740805.803:31): avc: denied { open } for pid=8072 comm=“adb” path=“/dev/bus/usb” dev=“tmpfs” ino=1212 scontext=u:r
<11>[324167.966659] init: untracked pid 8071 exited with status 1
<11>[324217.322127] init: untracked pid 8077 exited with status 1
<11>[324217.469794] init: untracked pid 8078 exited with status 1
<11>[328693.023701] init: untracked pid 8193 exited with status 1
ywx 发表于 2018-8-20 14:16
log抓了,应该看哪里呢?不懂啊
1|shell@firefly:/ $ dmesg
[ 0.000000] Booting Linux on physical …
如下log说明GSL3680触摸IC初始化失败,请确认排线是否有接错
<4>[ 1.017358] ==gsl_ts_init==
<4>[ 1.017454] GSLX680 Enter gsl_ts_probe
<4>[ 1.109170] Using Buffer DMA mode
<4>[ 1.109184] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 1.109195] Multiprocessor Interrupt Enhancement - disabled
<4>[ 1.109206] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 1.109217] ^^^^^^^^^^^^^^^^^^Host Mode
<4>[ 1.150544] Init: Power Port (0)
<4>[ 1.150559] rk_battery_charger_detect_cb , battery_charger_detect 5
<4>[ 1.553920] gsl_ts_probe–1318, i2c_master_recv fail
<4>[ 1.553945] gslX680: probe of 4-0041 failed with error -11
<4>[ 1.553987] ret=0
[ 1.0 …
排线都是按照wiki里面的教程接的,TP接TP,不会错的,而且线都对调了,保证线也都是好的
是这两个disabled,没有启用触摸吗?
1.109184] Peri …
你可以机器有个12v的跳帽是否有接上,或接入到5v
这个已经按照说明接的12V,外部接线什么的应该不会错的
有没有 AIO-3288C_HSX101H40C_Android5.1.1_LVDS_180808 这个固件的源代码可以提供啊
ywx 发表于 2018-8-22 11:09
这个已经按照说明接的12V,外部接线什么的应该不会错的有没有 AIO-3288C_HSX101H40C_Android5.1.1_LV …
请同步sdk到最新提交就有支持,同时编译方式可以参考AIO-3288C wiki
更新了SDK,重新编译烧录,还是一样的问题啊,没啥变化
是要去修改 gsl_ts_probe–1318, i2c_master_recv fail 失败的这部分源码吗?
是要去修改 gsl_ts_probe–1318, i2c_master_rec …
应该是硬件哪个地方有问题,可以寄到原厂分析分析
