烧录boot.img后,RK3288板在不断重启,这是什么问题
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Nov 20 2017 - 17:19:35)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
Adding bank:0
000000000000000(0000000080000000)
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2017-11-20#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x006483e0)
ramdisk @ 0x05bf0000 (0x00274868)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561ba2c … OK
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (wh@ubuntu) (gcc version 4.9.3 20150529 (prerelease) (15:4.9.3+svn231177-1) ) #4 SMP PREEMPT Sat Sep 8 19:41:02 PDT 2018 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] rockchip_ion_reserve [ 0.000000] cma: CMA: reserved 16 MiB at 2e800000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f2e000 s13888 r8192 d14784 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768 [ 0.000000] Kernel command line: console=tty0 console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00008000@0x00002000(resource),0x00008000@0x0000 A000(boot),0x00002000@0x00012000(misc),0x0001a000@0x00014000(backup), -@0x0002e000(linuxroot) storagemedia=emmc loader.timestamp=2017-11-20_17:19:35 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 2045244k/2045244k available, 51908k reserved, 1318912K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0ad9784 (11078 kB) [ 0.000000] .init : 0xc0ada000 - 0xc0d2b640 (2374 kB) [ 0.000000] .data : 0xc0d2c000 - 0xc0dd53d0 ( 677 kB) [ 0.000000] .bss : 0xc0dd53d0 - 0xc0ef5bd8 (1155 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000 [ 0.000000] rkclk: rk_clk_tree_init: unknown [ 0.000000] rkclk: rkclk_cache_parents: hdmi_dclk0 clk_get error [ 0.000000] rkclk: rkclk_cache_parents: hdmi_dclk1 clk_get error [ 0.000000] rkclk: rkclk_cache_parents: hdmi_dclk clk_get error [ 0.000000] rkclk: rkclk_cache_parents: aclk_hdcp clk_get error [ 0.000000] rkclk: rkclk_cache_parents: clk_hdcp clk_get error [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 33 [ 0.000000] Architected local timer running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 0 [ 0.000000] channel:0, lkg:26 [ 0.000000] target-temp:95 [ 0.000000] channel:2, lkg:0 [ 0.000000] target-temp:95 [ 0.000000] channel:0, lkg:26 [ 0.000000] target-temp:95 [ 0.000000] channel:1, lkg:17 [ 0.000000] target-temp:95 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty0] enabled [ 0.547051] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.547160] pid_max: default: 32768 minimum: 301 [ 0.547539] Security Framework initialized [ 0.547605] SELinux: Initializing. [ 0.547870] Mount-cache hash table entries: 512 [ 0.549953] Initializing cgroup subsys debug [ 0.550027] Initializing cgroup subsys freezer [ 0.550143] CPU: Testing write buffer coherency: ok [ 0.550927] /cpus/cpu@0 missing clock-frequency property [ 0.551005] /cpus/cpu@1 missing clock-frequency property [ 0.551068] /cpus/cpu@2 missing clock-frequency property [ 0.551129] /cpus/cpu@3 missing clock-frequency property [ 0.551283] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.551426] Setting up static identity map for 0xc07df310 - 0xc07df368 [ 0.555023] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x15af (version 3.0) [ 0.632312] CPU1: Booted secondary processor [ 0.632402] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.652052] CPU2: Booted secondary processor [ 0.652133] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.671820] CPU3: Booted secondary processor [ 0.671900] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.672254] Brought up 4 CPUs [ 0.672543] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.672605] CPU: All CPU(s) started in SVC mode. [ 0.674876] devtmpfs: initialized [ 0.692777] pinctrl core: initialized pinctrl subsystem [ 0.693556] regulator-dummy: no parameters [ 0.695247] NET: Registered protocol family 16 [ 0.700744] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.701722] ion_snapshot: 0x2e1b0000 map to 0xf0107000 and copy to 0xc0ece424 (version 0.1) [ 0.702270] Registered FIQ tty driver [ 0.705937] console [ttyFIQ0] enabled [ 0.706506] Registered fiq debugger ttyFIQ0 [ 0.708704] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 0.708833] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f [ 0.708956] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f [ 0.709078] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b [ 0.709395] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff [ 0.709697] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff [ 0.709993] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff [ 0.710292] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff [ 0.710656] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff [ 0.710960] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff [ 0.711261] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff [ 0.711561] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff [ 0.711874] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff [ 0.712183] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 0.712274] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 0.712380] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 0.712474] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 0.714156] rockchip_interrupts_register:bank_num=7 [ 0.721095] of_get_gpio_init_config:gpio[0] = 256, value = 0 [ 0.721220] of_get_gpio_init_config:gpio[1] = 233, value = 0 [ 0.721334] of_get_gpio_init_config:gpio[2] = 136, value = 0 [ 0.721571] rockchip_pinctrl_probe:init ok [ 0.743366] rk_iommu ff900800.iep_mmu: (iep) Enter [ 0.743741] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.743829] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 0.744446] rk_iommu ff950800.vip_mmu: (vip) Enter [ 0.744796] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.744886] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 0.745472] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 0.745822] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.745910] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 0.746504] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 0.746867] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.746957] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 0.747605] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 0.748015] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.748102] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 0.748729] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 0.749086] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.749175] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 0.749809] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 0.750274] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.750364] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 0.756071] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.756180] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.756864] DDR DEBUG: version 1.00 20140603 [ 0.756978] DDR DEBUG: Channel a: [ 0.757039] DDR DEBUG: DDR3 Device [ 0.757110] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.757201] DDR DEBUG: Channel b: [ 0.757256] DDR DEBUG: DDR3 Device [ 0.757323] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.757415] DDR DEBUG: addr=0xddb000 [ 0.757475] DDR DEBUG: stride=9, size=256, halfcap=40000000 [ 0.757547] DDR DEBUG: socAddr[0]=0xddb000, socAddr[1]=0xddb100 [ 0.757621] DDR DEBUG: chAddr[0]=0xddb000, chAddr[1]=0xddb000 [ 0.757696] DDR DEBUG: dtar[0]=0x301bb000, dtar[1]=0x301bb000 [ 0.757886] DDR DEBUG: init success!!! freq=200MHz [ 0.757952] DDR DEBUG: Channel a: [ 0.758022] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.758136] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.758250] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.758363] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.758471] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.758550] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.758620] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.758684] DDR DEBUG: Channel b: [ 0.758753] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.758865] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.758976] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.759088] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.759195] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.759273] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.759342] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.836085] bio: create slab at 0 [ 0.837986] Enter firefly_noatx8_init [ 0.838512] firefly_noatx8_probe 51 [ 0.839262] SCSI subsystem initialized [ 0.839837] usbcore: registered new interface driver usbfs [ 0.840027] usbcore: registered new interface driver hub [ 0.840351] usbcore: registered new device driver usb [ 0.844994] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 0.849359] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 0.850878] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 0.852374] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter [ 0.853244] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter [ 0.856065] media: Linux media interface: v0.10 [ 0.856255] Linux video capture interface: v2.00 [ 0.856442] pps_core: LinuxPPS API ver. 1 registered [ 0.856515] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.856653] PTP clock support registered [ 0.857124] rockchip_temp_probe,line=362 [ 0.857917] tsadc ff280000.tsadc: initialized [ 0.859268] rockchip_ion_parse_dt: num_heaps = 1 [ 0.859364] 0: 0 3 vmalloc 0x (null) [ 0.860168] Rockchip ion module is successfully loaded (v1.0) [ 0.860621] ~~~~~~~~~~~~~~~~~~~~~~~~Hello world~~~~~~~~~~~~~~~~~~~~~~~~ 0 [ 0.940596] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 1.845503] ~~~~~~~~~~~~~~~~~~~~~~~~Hello world~~~~~~~~~~~~~~~~~~~~~~~~ 1 [ 2.830878] ~~~~~~~~~~~~~~~~~~~~~~~~Hello world~~~~~~~~~~~~~~~~~~~~~~~~ 2 [ 3.816251] ~~~~~~~~~~~~~~~~~~~~~~~~Hello world~~~~~~~~~~~~~~~~~~~~~~~~ 3 [ 4.801644] ~~~~~~~~~~~~~~~~~~~~~~~~Hello world~~~~~~~~~~~~~~~~~~~~~~~~ 4 [ 5 .787013] ~~~~~~~~~~~~~~~~~~~~~~~~Hello world~~~~~~~~~~~~~~~~~~~~~~~~ 5 [ 6.772389] ~~~~~~~~~~~~~~~~~~~~~~~~Hello world~~~~~~~~~~~~~~~~~~~~~~~~ 6 [ 7.757759] ~~~~~~~~~~~~~~~~~~~~~~~~Hello world~~~~~~~~~~~~~~~~~~~~~~~~ 7 [ 8.743145] ~~~~~~~~~~~~~~~~~~~~~~~~Hello world~~~~~~~~~~~~~~~~~~~~~~~~ 8 [ 9.728524] ~~~~~~~~~~~~~~~~~~~~~~~~Hello world~~~~~~~~~~~~~~~~~~~~~~~~ 9 [ 10.713894] ~~~~~~~~~~~~~~~~~~~~~~~~Hello world~~~~~~~~~~~~~~~~~~~~~~~~ 10 [ 11 .699399] Advanced Linux Sound Architecture Driver Initialized. [ 11.700699] Bluetooth: Core ver 2.16 [ 11.700856] NET: Registered protocol family 31 [ 11.700928] Bluetooth: HCI device and connection manager initialized [ 11.701025] Bluetooth: HCI socket layer initialized [ 11.701105] Bluetooth: L2CAP socket layer initialized [ 11.701237] Bluetooth: SCO socket layer initialized [ 11.701925] cfg80211: Calling CRDA to update world regulatory domain [ 11.704261] act8846_i2c_probe,line=898 [ 11.705677] act8846_parse_dt,line=746 [ 11.707216] act8846_i2c_probe: act8846_pmic_hold=1 [ 11.707322] act8846_i2c_probe: act8846_pmic_sleep=1 [ 11.707471] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1 [ 11.707568] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1 [ 11.710058] act_dcdc1: 1200 mV [ 11.713782] vccio: 3300 mV [ 11.716387] vdd_logic: 700 <--> 1500 mV at 1100 mV [ 11.720054] act_dcdc4: 2000 mV [ 11.721910] vccio_sd: 1800 <--> 3300 mV at 3300 mV [ 11.724811] act_ldo2: 1050 mV [ 11.727717] act_ldo3: 2800 mV [ 11.730588] act_ldo4: 3300 mV [ 11.733456] act_ldo5: 3300 mV [ 11.736321] act_ldo6: 1100 mV [ 11.739254] vcc_18: 1800 mV [ 11.742169] act_ldo8: 1850 mV [ 11.748640] vdd_arm: 712 <--> 1500 mV at 1000 mV [ 11.754949] vdd_gpu: 712 <--> 1500 mV at 1000 mV [ 11.755961] rk808_i2c_probe,line=1368 [ 11.757627] The device is not rk808 -11 [ 11.757923] rk808: probe of 0-001b failed with error -11 [ 11.760361] i2s: maxburst: 1 [ 11.762795] Switching to clocksource arch_sys_counter [ 11.828120] rk-fb rockchip-fb: rk fb ion client create success! [ 11.828237] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 11.829417] rk-screen rk_screen.9: rockchip screen probe success [ 11.830259] rk32-lvds rk32-lvds: rk32 lvds driver probe success [ 11.831017] rk32-edp ff970000.edp: screen is not edp! [ 11.831118] rk32-edp: probe of ff970000.edp failed with error -22 [ 11.832435] rk3288-lcdc lcdc0: can't find power_ctr node for lcdc0 [ 11.833171] graphics fb0: rockchip framebuffer registerd:fb0 [ 11.834194] graphics fb1: rockchip framebuffer registerd:fb1 [ 11.834761] graphics fb2: rockchip framebuffer registerd:fb2 [ 11.835331] graphics fb3: rockchip framebuffer registerd:fb3 [ 11.835898] graphics fb4: rockchip framebuffer registerd:fb4 [ 11.837732] rk_iommu ff930300.vopb_mmu: (vopb) Enabled [ 11.838161] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60 [ 11.838274] rk3288-lcdc lcdc0: wakeup from standby! [ 11.955436] alloc_buffer:ion_phy_addr=0x10000000 [ 11.998873] fb0:phy:10000000>>vir:f0191000>>len:0x1800000 [ 12.119450] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled [ 12.120694] rockchip_set_mux:warning ignore bank num 15 [ 12.121179] rockchip_set_mux:warning ignore bank num 15 [ 12.121620] rockchip_set_mux:warning ignore bank num 15 [ 12.122057] rockchip_set_mux:warning ignore bank num 15 [ 12.122527] rockchip_set_mux:warning ignore bank num 15 [ 12.122957] rockchip_set_mux:warning ignore bank num 15 [ 12.123877] rockchip_set_mux:warning ignore bank num 15 [ 12.124408] rockchip_set_mux:warning ignore bank num 15 [ 12.125280] rockchip_set_mux:warning ignore bank num 15 [ 12.125839] rockchip_set_mux:warning ignore bank num 15 [ 12.126709] rockchip_set_mux:warning ignore bank num 15 [ 12.127315] rockchip_set_mux:warning ignore bank num 15 [ 12.128151] rockchip_set_mux:warning ignore bank num 15 [ 12.128713] rockchip_set_mux:warning ignore bank num 15 [ 12.150791] NET: Registered protocol family 2 [ 12.152305] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 12.152986] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 12.153630] TCP: Hash tables configured (established 8192 bind 8192) [ 12.153821] TCP: reno registered [ 12.153898] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 12.154062] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 12.154756] NET: Registered protocol family 1 [ 12.155563] RPC: Registered named UNIX socket transport module. [ 12.155654] RPC: Registered udp transport module. [ 12.155720] RPC: Registered tcp transport module. [ 12.155786] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 12.156308] Unpacking initramfs... [ 12.703063] Freeing initrd memory: 2512K (c5bf0000 - c5e64000) [ 12.705331] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available [ 12.706920] probe device ff9a0000.vpu_service [ 12.707418] vpu_service: power on [ 12.708600] checking hw id 4831 [ 12.709624] vpu_service set to auto frequency mode [ 12.709841] vcodec vpu_service: vcodec ion client create success! [ 12.711067] vpu_service: power off... [ 12.711178] done [ 12.711240] init success [ 12.711421] probe device ff9c0000.hevc_service [ 12.712082] hevc_service: power on [ 12.713225] checking hw id 6867 [ 12.714059] vcodec hevc_service: vcodec ion client create success! [ 12.715051] hevc_service: power off... [ 12.715159] done [ 12.715219] init success [ 12.715595] rknandbase v1.0 2014-03-31 [ 12.716267] rknand_probe clk rate = 148500000 [ 12.716689] rknand_driver:ret = 0 [ 12.717951] audit: initializing netlink socket (disabled) [ 12.718106] type=2000 audit(12.350:1): initialized [ 12.720419] bounce pool size: 64 pages [ 12.736133] NFS: Registering the id_resolver key type [ 12.736353] Key type id_resolver registered [ 12.736423] Key type id_legacy registered [ 12.736516] Installing knfsd (copyright (C) 1996 [email]okir@monad.swb.de[/email]). [ 12.738446] fuse init (API version 7.22) [ 12.739758] msgmni has been set to 1455 [ 12.745459] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 12.745577] io scheduler noop registered [ 12.745644] io scheduler deadline registered [ 12.745965] io scheduler cfq registered (default) [ 12.747520] Console: switching to colour frame buffer device 240x67 [ 12.798170] rga ff920000.rga: rga ion client create success! [ 12.798808] rga: Driver loaded succesfully [ 12.800414] IEP Power ON [ 12.800663] iep ion client create success! [ 12.801932] rk_iommu ff900800.iep_mmu: (iep) Enabled [ 12.802232] IEP Power OFF [ 12.802393] rk_iommu ff900800.iep_mmu: (iep) Disabled [ 12.802652] rk_iommu ff900800.iep_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e26b000 [ 12.803099] IEP Driver loaded succesfully [ 12.803568] Module initialized. [ 12.806074] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208 [ 12.806433] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 12.811071] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208 [ 12.811431] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 12.812570] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API [ 12.812980] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM [ 12.813319] pwm_regulator_probe:error [ 12.813543] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral [ 12.814974] rk_serial.c v1.8 2014-03-04 [ 12.815788] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0 [ 12.816788] serial ff180000.serial: membase f0172000 [ 12.817528] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1 [ 12.818442] serial ff190000.serial: membase f0174000 [ 12.819178] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3 [ 12.820087] serial ff1b0000.serial: membase f0176000 [ 12.829982] loop: module loaded [ 12.831933] SCSI Media Changer driver v0.25 [ 12.833143] tun: Universal TUN/TAP device driver, 1.6 [ 12.833409] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 12.835377] stmmac_probe_config_dt: Can not read property: pmu_regulator. [ 12.835771] stmmac_probe_config_dt: Can not read property: pmu_enable_level. [ 12.836110] stmmac_probe_config_dt: clock input or output? (input). [ 12.836409] stmmac_probe_config_dt: TX delay(0x30). [ 12.836648] stmmac_probe_config_dt: RX delay(0x20). [ 12.836968] stmmac_probe_config_dt: is rockchip,rk3288-gmac [ 12.837235] stmmc_pltfr_init: [ 12.837415] stmmc_pltfr_init: ERROR: Get power-gpio failed. [ 12.848603] stmmc_pltfr_init: ERROR: Request gmac phy reset pin failed. [ 12.859725] stmmc_pltfr_init: init for RGMII [ 12.870715] tx delay=0x30 [ 12.870715] rx delay=0x20 [ 12.893995] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 12.905034] Normal descriptors [ 12.916013] Ring mode enabled [ 12.926977] DMA HW capability register supported [ 12.927213] RX Checksum Offload Engine supported (type 2) [ 12.948928] TX Checksum insertion supported [ 12.959873] Wake-Up On Lan supported [ 12.970943] Enable RX Mitigation via HW Watchdog Timer [ 12.983370] PPP generic driver version 2.4.2 [ 12.994924] PPP BSD Compression module registered [ 13.006116] PPP Deflate Compression module registered [ 13.017306] PPP MPPE Compression module registered [ 13.028442] NET: Registered protocol family 24 [ 13.039610] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 13.051082] CSLIP: code copyright 1989 Regents of the University of California. [ 13.062636] Rockchip WiFi SYS interface (V1.00) ... [ 13.074452] usbcore: registered new interface driver catc [ 13.086163] usbcore: registered new interface driver kaweth [ 13.097630] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 13.109385] usbcore: registered new interface driver pegasus [ 13.121099] usbcore: registered new interface driver rtl8150 [ 13.132598] usbcore: registered new interface driver r8152 [ 13.143921] hso: drivers/net/usb/hso.c: Option Wireless [ 13.144151] usbcore: registered new interface driver hso [ 13.144284] usbcore: registered new interface driver asix [ 13.144397] usbcore: registered new interface driver ax88179_178a [ 13.144504] usbcore: registered new interface driver cdc_ether [ 13.144609] usbcore: registered new interface driver cdc_eem [ 13.144711] usbcore: registered new interface driver dm9601 [ 13.144824] usbcore: registered new interface driver dm9620 [ 13.144965] usbcore: registered new interface driver smsc75xx [ 13.145101] usbcore: registered new interface driver smsc95xx [ 13.145208] usbcore: registered new interface driver gl620a [ 13.145315] usbcore: registered new interface driver net1080 [ 13.145420] usbcore: registered new interface driver plusb [ 13.145539] usbcore: registered new interface driver rndis_host [ 13.145649] usbcore: registered new interface driver cdc_subset [ 13.145751] usbcore: registered new interface driver zaurus [ 13.145862] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 13.146025] usbcore: registered new interface driver int51x1 [ 13.146135] usbcore: registered new interface driver kalmia [ 13.146240] usbcore: registered new interface driver ipheth [ 13.146361] usbcore: registered new interface driver sierra_net [ 13.146484] usbcore: registered new interface driver cx82310_eth [ 13.146624] usbcore: registered new interface driver cdc_ncm [ 13.146735] usbcore: registered new interface driver qmi_wwan [ 13.146844] usbcore: registered new interface driver cdc_mbim [ 13.146865] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 13.150211] EHCI: ehci_rk_probe f1a00000 f1a00010 [ 13.150247] rockchip_ehci_host ff500000.usb: EHCI Host Controller [ 13.150317] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1 [ 13.189813] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000 [ 13.209533] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00 [ 13.209732] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 13.209769] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 13.209798] usb usb1: Product: EHCI Host Controller [ 13.209824] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 13.209850] usb usb1: SerialNumber: ff500000.usb [ 13.211178] hub 1-0:1.0: USB hub found [ 13.211235] hub 1-0:1.0: 1 port detected [ 13.211764] EHCI: ehci_rk_probe ok [ 13.212191] usbcore: registered new interface driver cdc_acm [ 13.212213] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 13.212371] usbcore: registered new interface driver usblp [ 13.212508] usbcore: registered new interface driver cdc_wdm [ 13.212703] usbcore: registered new interface driver usb-storage [ 13.212815] usbcore: registered new interface driver ums-alauda [ 13.212922] usbcore: registered new interface driver ums-cypress [ 13.213026] usbcore: registered new interface driver ums-datafab [ 13.213129] usbcore: registered new interface driver ums_eneub6250 [ 13.213232] usbcore: registered new interface driver ums-freecom [ 13.213337] usbcore: registered new interface driver ums-isd200 [ 13.213453] usbcore: registered new interface driver ums-jumpshot [ 13.213561] usbcore: registered new interface driver ums-karma [ 13.213670] usbcore: registered new interface driver ums-onetouch [ 13.213779] usbcore: registered new interface driver ums-sddr09 [ 13.213887] usbcore: registered new interface driver ums-sddr55 [ 13.213992] usbcore: registered new interface driver ums-usbat [ 13.214247] usbcore: registered new interface driver usbserial [ 13.214361] usbcore: registered new interface driver usbserial_generic [ 13.214449] usbserial: USB Serial support registered for generic [ 13.214572] usbcore: registered new interface driver option [ 13.214657] usbserial: USB Serial support registered for GSM modem (1-port) [ 13.214879] usbcore: registered new interface driver trancevibrator [ 13.214899] usb20_otg: version 3.10a 21-DEC-2012 [ 13.216071] f1a80040 [ 13.216099] Core Release: 3.10a [ 13.216121] Setting default values for core params [ 13.216478] Using Buffer DMA mode [ 13.216499] Periodic Transfer Interrupt Enhancement - disabled [ 13.216517] Multiprocessor Interrupt Enhancement - disabled [ 13.216538] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 13.216556] ^^^^^^^^^^^^^^^^^Device Mode [ 13.216581] Dedicated Tx FIFOs mode [ 13.216622] pcd_init otg_dev = eda1e740 [ 13.217106] usb20_otg ff580000.usb: DWC OTG Controller [ 13.217177] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2 [ 13.217252] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 13.217412] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 13.217448] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 13.217475] usb usb2: Product: DWC OTG Controller [ 13.217501] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 13.217527] usb usb2: SerialNumber: ff580000.usb [ 13.218848] hub 2-0:1.0: USB hub found [ 13.218901] hub 2-0:1.0: 1 port detected [ 13.220003] usb20_host: version 3.10a 21-DEC-2012 [ 13.223643] f1b00040 [ 13.223670] Core Release: 3.10a [ 13.223706] Setting default values for core params [ 13.224058] Using Buffer DMA mode [ 13.224079] Periodic Transfer Interrupt Enhancement - disabled [ 13.224096] Multiprocessor Interrupt Enhancement - disabled [ 13.224116] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 13.224133] ^^^^^^^^^^^^^^^^^^Host Mode [ 13.224225] usb20_host ff540000.usb: DWC OTG Controller [ 13.224291] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3 [ 13.224365] usb20_host ff540000.usb: irq 57, io mem 0x00000000 [ 13.224503] Init: Power Port (0) [ 13.224666] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 13.224702] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 13.224730] usb usb3: Product: DWC OTG Controller [ 13.224757] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 13.224783] usb usb3: SerialNumber: ff540000.usb [ 13.225981] hub 3-0:1.0: USB hub found [ 13.226033] hub 3-0:1.0: 1 port detected [ 13.228032] .. rk pwm remotectl v1.0 init [ 13.228270] remotectl probe j=0x0 [ 13.228722] input: ff680000.pwm as /devices/ff680000.pwm/input/input0 [ 13.229374] pwm enable val=0x646205 [ 13.230236] usbcore: registered new interface driver xpad [ 13.230382] usbcore: registered new interface driver usb_acecad [ 13.230512] usbcore: registered new interface driver aiptek [ 13.230639] usbcore: registered new interface driver gtco [ 13.230780] usbcore: registered new interface driver hanwang [ 13.230911] usbcore: registered new interface driver kbtab [ 13.231058] usbcore: registered new interface driver wacom [ 13.232078] sensor_register_slave:mma8452,id=17 [ 13.232104] sensor_register_slave:cm3217,id=44 [ 13.232124] sensor_register_slave:cm3218,id=45 [ 13.232141] tchip_rm_init is here! [ 13.233608] input: tchip_remote_key as /devices/virtual/input/input1 [ 13.234012] tchiprm_register_device is here! [ 13.234414] input: tchip_remote_touch as /devices/virtual/input/input2 [ 13.234747] tchip_remote_abs_register_device is here! [ 13.235141] input: tchip_remote_gsensor as /devices/virtual/input/input3 [ 13.235464] tchip_remote_gsensor_register_device is here! [ 13.238720] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed [ 13.242711] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0 [ 13.242849] i2c /dev entries driver [ 13.244954] IR NEC protocol handler initialized [ 13.244976] IR RC5(x) protocol handler initialized [ 13.244993] IR RC6 protocol handler initialized [ 13.245008] IR JVC protocol handler initialized [ 13.245024] IR Sony protocol handler initialized [ 13.245039] IR RC5 (streamzap) protocol handler initialized [ 13.245056] IR SANYO protocol handler initialized [ 13.245072] IR MCE Keyboard/mouse protocol handler initialized [ 13.245309] usbcore: registered new interface driver uvcvideo [ 13.245327] USB Video Class driver (1.1.1) [ 13.245354] CamSys driver version: v0.19.0, CamSys head file version: v0.8.0 [ 13.245380] E:camsys_soc_init(87): camsys isn't support soc: 0x32880001! [ 13.248498] D1:camsys_platform_probe(1061): 1-gpios-cifpower: gpio=236 [ 13.248548] D1:camsys_platform_probe(1064): gpios-cifpower: gpio_request [ 13.248589] D1:camsys_platform_probe(1066): 1-gpios-cifpower: gpio_request=0 [ 13.248628] D1:camsys_platform_probe(1075): gpios-cifpower: 236 high [ 13.248858] RockChip-CamSys: probe of ff910000.isp failed with error -1 [ 13.251712] device-mapper: uevent: version 1.0.3 [ 13.252455] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email] [ 13.253385] Bluetooth: HCI UART driver ver 2.2 [ 13.253414] Bluetooth: HCI H4 protocol initialized [ 13.253435] Bluetooth: HCILL protocol initialized [ 13.259115] cpufreq version 1.0, suspend freq 1200 MHz [ 13.259691] cpuidle: using governor ladder [ 13.259714] cpuidle: using governor menu [ 13.259815] Synopsys Designware Multimedia Card Interface Driver [ 13.260558] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a [ 13.275436] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller. [ 13.275892] 3291..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0] [ 13.275914] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05 [ 13.276260] 1381..dw_mci_set_ios: no card. [mmc0] [ 13.288264] 1381..dw_mci_set_ios: no card. [mmc0] [ 13.308031] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 13.309270] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo [ 13.309304] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized [ 13.310194] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a [ 13.325318] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller. [ 13.325833] 3285..dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1] [ 13.325856] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05 [ 13.338492] 1381..dw_mci_set_ios: no card. [mmc1] [ 13.357075] 1381..dw_mci_set_ios: no card. [mmc1] [ 13.363476] mmc0: BKOPS_EN bit is not set [ 13.376956] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo [ 13.376970] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized [ 13.377457] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a [ 13.381377] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0] [ 13.381439] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller. [ 13.381633] 3291..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2] [ 13.381642] mmc2 : Rockchip specific MHSC: Ver 1.13 2014-09-05 [ 13.381779] 1381..dw_mci_set_ios: no card. [mmc2] [ 13.390369] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0) [ 13.390393] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0] [ 13.396439] 1381..dw_mci_set_ios: no card. [mmc2] [ 13.416369] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo [ 13.416379] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized [ 13.416686] leds-gpio leds.31: pins are not configured from the driver [ 13.416974] hidraw: raw HID events driver (C) Jiri Kosina [ 13.418847] usbcore: registered new interface driver usbhid [ 13.418854] usbhid: USB HID core driver [ 13.419215] ashmem: initialized [ 13.419364] logger: created 256K log 'log_main' [ 13.419484] logger: created 256K log 'log_events' [ 13.419596] logger: created 256K log 'log_radio' [ 13.419611] rk_sdmmc: BOOT [ 13.419611] execute tuning: candidates_degree = SDMMC_SHIFT_DEGREE_0 SDMMC_SHIFT_DEGREE_90 SDMMC_SHIFT_DEGREE_180 SDMMC_SHIFT_DEGREE_INVALID[mmc0] [ 13.419730] logger: created 256K log 'log_system' [ 13.421023] input: rk29-keypad as /devices/ff100000.adc/key.34/input/input4 [ 13.421778] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by rockchip-i2s.0; cannot claim for 2-0010 [ 13.421789] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22 [ 13.421799] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl [ 13.421809] ES8323 2-0010: Error applying setting, reverse things back [ 13.423999] mmc0: new HS200 MMC card at address 0001 [ 13.424391] mmcblk0: mmc0:0001 AJTD4R 14.5 GiB [ 13.424759] resource: 0x000400000 -- 0x001400000 (16 MB) [ 13.424768] boot: 0x001400000 -- 0x002400000 (16 MB) [ 13.424775] misc: 0x002400000 -- 0x002800000 (4 MB) [ 13.424782] backup: 0x002800000 -- 0x005c00000 (52 MB) [ 13.424788] linuxroot: 0x005c00000 -- 0x3a3a00000 (14814 MB) [ 13.425600] mmcblk0: p1 p2 p3 p4 p51381..dw_mci_set_ios: no card. [mmc1] [ 13.426597] 1381..dw_mci_set_ios: no card. [mmc2] [ 13.428472] es8323 probe i2c recv ok [ 13.428736] i2c-core: driver [ES8323] using legacy suspend method [ 13.428743] i2c-core: driver [ES8323] using legacy resume method [ 13.429265] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered [ 13.429299] rockchip_hdmi_spdif_audio_probe() register card failed:-517 [ 13.429317] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral [ 13.429651] es8323_probe [ 13.429777] es8323_probe:register ISR (irq=194) [ 14.282375] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> NULL --> Left Line Mux [ 14.284810] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> NULL -> Left Line Mux [ 14.287210] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> NULL --> Left Line Mux [ 14.289612] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> NULL -> Left Line Mux [ 14.292004] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> NULL --> Left Line Mux [ 14.294380] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> NULL -> Left Line Mux [ 14.296769] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> NULL --> Right Line Mux [ 14.299161] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> NULL -> Right Line Mux [ 14.301542] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> NULL --> Right Line Mux [ 14.303910] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> NULL -> Right Line Mux [ 14.306258] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> NULL --> Right Line Mux [ 14.308635] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> NULL -> Right Line Mux [ 14.310977] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left PGA Mux [ 14.313311] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left PGA Mux [ 14.315643] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left PGA Mux [ 14.317965] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left PGA Mux [ 14.320281] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> LAMP --> Left PGA Mux [ 14.322577] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> LAMP -> Left PGA Mux [ 14.324856] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right PGA Mux [ 14.327150] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right PGA Mux [ 14.329432] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right PGA Mux [ 14.331755] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right PGA Mux [ 14.334005] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> RAMP --> Right PGA Mux [ 14.336266] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> RAMP -> Right PGA Mux [ 14.338525] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Differential Mux [ 14.340802] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Differential Mux [ 14.343047] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Differential Mux [ 14.345272] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Differential Mux [ 14.347479] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Differential Mux [ 14.349641] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Differential Mux [ 14.351774] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Differential Mux [ 14.353873] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Differential Mux [ 14.355944] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left Line Mux [ 14.357959] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left Line Mux [ 14.359977] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left Line Mux [ 14.362009] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left Line Mux [ 14.363979] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> LAMP --> Left Line Mux [ 14.365951] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> LAMP -> Left Line Mux [ 14.367923] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right Line Mux [ 14.369900] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right Line Mux [ 14.371915] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right Line Mux [ 14.373927] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right Line Mux [ 14.375962] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> RAMP --> Right Line Mux [ 14.377948] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> RAMP -> Right Line Mux [ 14.380006] ES8323 2-0010: ASoC: mux Right Line Mux has no paths [ 14.381915] ES8323 2-0010: ASoC: mux Left Line Mux has no paths [ 14.383773] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths [ 14.385586] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths [ 14.387398] ES8323 2-0010: ASoC: mux Differential Mux has no paths [ 14.391994] Enter::rk29_es8323_init----135 [ 14.397019] rockchip-es8323 rockchip-es8323.29: ES8323 HiFi <-> rockchip-i2s.0 mapping ok [ 14.399296] u32 classifier [ 14.401118] Actions configured [ 14.402901] Netfilter messages via NETLINK v0.30. [ 14.404733] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 14.406830] ctnetlink v0.93: registering with nfnetlink. [ 14.408741] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 14.410646] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 14.412731] xt_time: kernel timezone is -0000 [ 14.414753] ip_tables: (C) 2000-2006 Netfilter Core Team [ 14.416728] arp_tables: (C) 2002 David S. Miller [ 14.418649] TCP: cubic registered [ 14.420504] Initializing XFRM netlink socket [ 14.422531] NET: Registered protocol family 10 [ 14.424752] mip6: Mobile IPv6 [ 14.426542] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 14.428426] sit: IPv6 over IPv4 tunneling driver [ 14.430513] NET: Registered protocol family 17 [ 14.432319] NET: Registered protocol family 15 [ 14.434136] Bridge firewalling registered [ 14.435905] Ebtables v2.0 registered [ 14.437805] Bluetooth: RFCOMM TTY layer initialized [ 14.439608] Bluetooth: RFCOMM socket layer initialized [ 14.441356] Bluetooth: RFCOMM ver 1.11 [ 14.443095] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 14.444859] Bluetooth: BNEP filters: protocol multicast [ 14.446638] Bluetooth: BNEP socket layer initialized [ 14.448429] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 14.450219] Bluetooth: HIDP socket layer initialized [ 14.452005] l2tp_core: L2TP core driver, V2.0 [ 14.453745] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 14.455476] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 14.457400] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 14.459144] wlan_platdata_parse_dt: wifi_chip_type = bcmwifi [ 14.460881] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 14.462604] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 14.464360] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 14.466146] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0. [ 14.467951] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0. [ 14.469730] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 14.471518] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V [ 14.473362] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 14.475203] [BT_RFKILL]: Enter rfkill_rk_init [ 14.477119] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147. [ 14.478996] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155. [ 14.480848] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157. [ 14.482702] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154. [ 14.484557] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159. [ 14.486439] [BT_RFKILL]: Request irq for bt wakeup host [ 14.488367] [BT_RFKILL]: ** disable irq [ 14.490257] [BT_RFKILL]: ap6335 device registered. [ 14.492097] Key type dns_resolver registered [ 14.803544] hdmi->edidread:1 [ 15.118701] rk3288-hdmi ff980000.hdmi: warning: no CEA video mode parsed from EDID !!!! [ 15.153990] ******** Show Sink Info ******** [ 15.159311] Max tmds clk is 0 [ 15.163038] Support video mode: [ 15.166738] 1920x1080p@60Hz [ 15.170446] 1280x720p@60Hz [ 15.174076] 720x480p@60Hz [ 15.177689] Support video color mode: [ 15.180681] RGB [ 15.183364] Support video color depth: [ 15.186070] 24bit [ 15.188802] EHCI: rk_ehci_hcd_enable, disable host controller [ 15.191317] Support audio type: [ 15.193608] ******** Show Sink Info ******** [ 15.195927] [ 15.195927] rk_fb_switch_screen lcdc_id 0 type 6 enable 1 [ 15.200447] fb0 win id 1 state 1 [ 15.202737] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60 [ 15.205037] fb1 win id 0 state 0 [ 15.206963] dwc_otg_hcd_enable, enable host controller [ 15.209577] fb2 win id 2 state 0 [ 15.211827] fb3 win id 3 state 0 [ 15.214021] fb4 win id 4 state 0 [ 15.216198] [ 15.216198] rk_fb_switch_screen lcdc_id 0 type 6 enable 1 done [ 15.216198] [ 15.223083] pixel clk is 148500000 tmds clk is 148500000 last tmds clk 0 tmdsclk_ratio_change 0 [ 15.225494] rk3288-hdmi ff980000.hdmi: [hdmi_dev_config_video] sucess output DVI. [ 15.237975] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess. [ 15.240949] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0 [ 15.243419] rk3288_init_suspend [ 15.245838] rk3288_suspend_init enter [ 15.248462] rk3288_suspend_init: pm_ctrbits =40017 [ 15.250904] gpio_get_dts_info suspend:8 [ 15.253374] gpio_get_dts_info resume:8 [ 15.255810] rockchip,pmic-suspend_gpios:1007c30 1007c40 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 15.258413] rockchip,pmic-resume_gpios:2007c32 2007c42 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 15.261200] clks_gating_suspend_init:clkgt info ok [ 15.263795] Registering SWP/SWPB emulation handler [ 15.266681] ddrfreq: verion 1.2 20140526 [ 15.269397] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz [ 15.271740] ddrfreq: auto-freq=0 [ 15.274062] ddrfreq: auto-freq-table[0] 240MHz [ 15.276419] ddrfreq: auto-freq-table[1] 324MHz [ 15.278712] ddrfreq: auto-freq-table[2] 456MHz [ 15.280974] ddrfreq: auto-freq-table[3] 528MHz [ 15.284303] act_ldo3: operation not allowed [ 15.286199] vga_edid_probe: turn on ldo3 done. [ 15.287813] act_ldo4: operation not allowed [ 15.289640] vga_edid_probe: turn on ldo done. [ 15.291271] act_ldo2: operation not allowed [ 15.293078] vga_edid_probe: turn on ldo2 done. [ 15.294685] act_ldo8: operation not allowed [ 15.296489] vga_edid_probe: turn on ldo done. [ 15.303140] unable to read EDID block. [ 15.311712] Using Buffer DMA mode [ 15.313247] Periodic Transfer Interrupt Enhancement - disabled [ 15.314777] Multiprocessor Interrupt Enhancement - disabled [ 15.316337] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 15.317899] ^^^^^^^^^^^^^^^^^^Host Mode [ 15.339272] unable to read EDID block. [ 15.364482] Init: Power Port (0) [ 15.375270] unable to read EDID block. [ 15.376674] vga-ddc: read and parse edid failed errno:-5. [ 15.378080] vga_edid_probe: success. 10 [ 15.379595] firefly_vga_get_enable 180, 0 [ 15.380994] firefly_vga_get_status 186 [ 15.382379] firefly_vga_set_enable 159 enable:0 [ 15.383756] regulator-dummy: disabling [ 15.385401] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered [ 15.386811] rockchip_hdmi_spdif_audio_probe() register card failed:-517 [ 15.388226] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral [ 15.389734] pcd_pullup, is_on 0 [ 15.391223] file system registered [ 15.393160] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 15.394668] android_usb gadget: Number of LUNs=2 [ 15.396166] lun0: LUN: removable file: (no medium) [ 15.397639] lun1: LUN: removable file: (no medium) [ 15.399225] android_usb gadget: android_usb ready [ 15.400756] sensor_init: Probe name sensors [ 15.402233] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01 [ 15.404265] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:00:03 UTC (1293883203) [ 15.410928] usbcore: registered new interface driver snd-usb-audio [ 15.412492] ALSA device list: [ 15.414026] #0: RK_ES8323 [ 15.415133] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: rk-hdmi-spdif-hifi <-> rockchip-spdif mapping ok [ 15.417387] #1: RK-HDMI-SPDIF [ 15.420288] Freeing unused kernel memory: 2372K (c0ada000 - c0d2b000) [ 15.422049] Failed to execute /init [ 15.423756] Failed to execute /sbin/init. Attempting defaults... [ 15.425561] Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance. [ 15.586437] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #4 [ 15.593915] [] (unwind_backtrace+0x0/0xdc) from [] (show_stack+0x10/0x14) [ 15.603952] [] (show_stack+0x10/0x14) from [] (panic+0x88/0x1dc) [ 15.613227] [] (panic+0x88/0x1dc) from [] (kernel_init+0xb8/0xe4) [ 15.622589] [] (kernel_init+0xb8/0xe4) from [] (ret_from_fork+0x14/0x3c) [ 15.632555] CPU2: stopping [ 15.636867] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 3.10.0 #4 [ 15.644365] [] (unwind_backtrace+0x0/0xdc) from [] (show_stack+0x10/0x14) [ 15.654462] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x130/0x278) [ 15.664330] [] (handle_IPI+0x130/0x278) from [] (gic_handle_irq+0x54/0x5c) [ 15.674567] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70) [ 15.684539] Exception stack(0xee0c3f50 to 0xee0c3f98) [ 15.691272] 3f40: ee0c3f98 00000003 90b2bc8c 00000003 [ 15.701079] 3f60: 00000000 c1f42298 8ff3e785 00000003 c0d3ef78 c0ecdf74 00000002 c0d3ef78 [ 15.710919] 3f80: 00000008 ee0c3f98 c006d39c c055399c 00000113 ffffffff [ 15.719230] [] (__irq_svc+0x40/0x70) from [] (cpuidle_enter_state+0x4c/0xd4) [ 15.729668] [] (cpuidle_enter_state+0x4c/0xd4) from [] (cpuidle_idle_call+0x158/0x238) [ 15.740958] [] (cpuidle_idle_call+0x158/0x238) from [] (arch_cpu_idle+0x8/0x38) [ 15.751664] [] (arch_cpu_idle+0x8/0x38) from [] (cpu_startup_entry+0x1b4/0x214) [ 15.762413] [] (cpu_startup_entry+0x1b4/0x214) from [<000081bc>] (0x81bc) [ 15.771812] CPU0: stopping [ 15.776337] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.10.0 #4 [ 15.784045] [] (unwind_backtrace+0x0/0xdc) from [] (show_stack+0x10/0x14) [ 15.794348] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x130/0x278) [ 15.804402] [] (handle_IPI+0x130/0x278) from [] (gic_handle_irq+0x54/0x5c) [ 15.814816] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70) [ 15.824980] Exception stack(0xc0d2dee0 to 0xc0d2df28) [ 15.831917] dee0: 005ef498 00000000 00000000 00000000 3b9aca00 3b9aca00 c0d2df44 00000003 [ 15.841953] df00: 005ef498 00000000 00000000 c0d3ef78 3b9ac9ff c0d2df28 c02bd9b0 c02b1768 [ 15.851990] df20: 80000113 ffffffff [ 15.857426] [] (__irq_svc+0x40/0x70) from [] (__do_div64+0x58/0xe8) [ 15.867327] [] (__do_div64+0x58/0xe8) from [] (div_s64_rem+0x4c/0x6c) [ 15.877417] [] (div_s64_rem+0x4c/0x6c) from [] (ns_to_timespec+0x2c/0x60) [ 15.887855] [] (ns_to_timespec+0x2c/0x60) from [] (ns_to_timeval+0x10/0x34) [ 15.898461] [] (ns_to_timeval+0x10/0x34) from [] (cpuidle_enter_state+0x5c/0xd4) [ 15.909527] [] (cpuidle_enter_state+0x5c/0xd4) from [] (cpuidle_idle_call+0x158/0x238) [ 15.921131] [] (cpuidle_idle_call+0x158/0x238) from [] (arch_cpu_idle+0x8/0x38) [ 15.932131] [] (arch_cpu_idle+0x8/0x38) from [] (cpu_startup_entry+0x1b4/0x214) [ 15.943173] [] (cpu_startup_entry+0x1b4/0x214) from [] (start_kernel+0x2bc/0x310) [ 15.954395] CPU1: stopping [ 15.959228] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.10.0 #4 [ 15.967244] [] (unwind_backtrace+0x0/0xdc) from [] (show_stack+0x10/0x14) [ 15.977843] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x130/0x278) [ 15.988200] [] (handle_IPI+0x130/0x278) from [] (gic_handle_irq+0x54/0x5c) [ 15.998924] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70) [ 16.009376] Exception stack(0xee0c1f50 to 0xee0c1f98) [ 16.016594] 1f40: ee0c1f98 00000003 90b2bc8c 00000003 [ 16.026887] 1f60: 00000000 c1f39298 8f5b3d53 00000003 c0d3ef78 c0ecdf74 00000001 c0d3ef78 [ 16.037178] 1f80: 00000008 ee0c1f98 c006d39c c055399c 00000113 ffffffff [ 16.045939] [] (__irq_svc+0x40/0x70) from [] (cpuidle_enter_state+0x4c/0xd4) [ 16.056860] [] (cpuidle_enter_state+0x4c/0xd4) from [] (cpuidle_idle_call+0x158/0x238) [ 16.068664] [] (cpuidle_idle_call+0x158/0x238) from [] (arch_cpu_idle+0x8/0x38) [ 16.079858] [] (arch_cpu_idle+0x8/0x38) from [] (cpu_startup_entry+0x1b4/0x214) [ 16.091094] [] (cpu_startup_entry+0x1b4/0x214) from [<000081bc>] (0x81bc) [ 16.100962] CRU: [ 16.105110] 00000000: 00000000 9fff0042 0fff0021 00000008 [ 16.112763] 00000010: 00000001 9fff0025 0fff0012 00000008 [ 16.120397] 00000020: 00000007 ffff00c5 00000000 00000008 [ 16.127993] 00000030: 00000103 9fff00c5 0fff0063 00000008 [ 16.135584] 00000040: 00000b00 9fff0270 0fff0138 00000008 [ 16.143163] 00000050: 00005111 00000000 00000000 00000000 [ 16.150722] 00000060: 00004031 0000b108 00000000 00000200 [ 16.158220] 00000070: 00008100 00008200 00008342 00010014 [ 16.165725] 00000080: 01885091 00010014 0000a101 00002745 [ 16.173211] 00000090: 00004345 00008a00 00000200 00000200 [ 16.180694] 000000a0: 00000200 0bb8ea60 00010014 00010014 [ 16.188127] 000000b0: 00010014 00000910 00000900 001f05dc [ 16.195518] 000000c0: 00001703 00000707 00000e40 00000300 [ 16.202892] 000000d0: 00000342 00000742 00004141 00000100 [ 16.210239] 000000e0: 00004141 00000505 00008042 00008f8f [ 16.217567] 000000f0: 00000000 00000631 00001ee3 00004007 [ 16.224875] 00000100: 00001100 01885091 00004141 00000000 [ 16.232161] 00000110: 00000000 00000000 00000000 00000000 [ 16.239406] 00000120: 00000000 00000000 00000000 00000000 [ 16.246642] 00000130: 00000000 00000000 00000000 00000000 [ 16.253850] 00000140: 00000000 00000000 00000000 00000000 [ 16.261039] 00000150: 00000000 00000000 00000000 00000000 [ 16.268190] 00000160: 00001000 0000ff00 00003e20 0000faf8 [ 16.275325] 00000170: 00004c70 0000a6cf 00001bf0 00008139 [ 16.282416] 00000180: 00000f27 00000000 00000401 0000040c [ 16.289482] 00000190: 00000000 0000fe94 00000000 0000c19e [ 16.296538] 000001a0: 0000017f 00000000 00000000 00000000 [ 16.303568] 000001b0: 00000000 00000000 00000000 00000000 [ 16.310551] 000001c0: 00000000 00000000 00000000 00000000 [ 16.317521] 000001d0: 00000000 00000000 00000000 00000000 [ 16.324464] 000001e0: 00000000 00000000 00000000 00640064 [ 16.331364] 000001f0: 00000004 00000000 00000000 00000000 [ 16.338224] 00000200: 00000002 00000000 00000002 00000000 [ 16.345079] 00000210: 00000002 00000000 00000004 00000401 [ 16.351907] Rebooting in 5 seconds..
先确认正版烧录软件是否会有问题,还是你boot里面的程序有问题
确认了下,烧录官方的boot没问题,能正常使用。烧录我这boot就不行,不知道错在哪一步。
你的boot哪里来的
