系统新烧进去的一天内运行正常,然后就会出现SSH登陆不上、各应用服务无法连接的问题。TTL进去看init成功然后是内核panic。不知道是为什么。
log看下
忘了留存,下次遇到再发出来,谢谢!
DDR version 1.06 20170424
DDR4
786MHz
Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
ddrconfig:19
Boot1 Release Time: 2017-05-18, version: 2.43
ChipType = 0x11, 178
emmc reinit
emmc reinit
SdmmcInit=2 400
SdmmcInit=0 0
BootCapSize=0
UserCapSize=7620MB
FwPartOffset=2000 , 0
StorageInit ok = 45111
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
LoadTrustBL
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xa3810
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):f947c7e
NOTICE: BL31: Built : 09:28:45, May 31 2017
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: SPSR = 0x3c9
U-Boot 2017.09-gc58a8168bd (Sep 14 2018 - 00:04:33 +0800)
Model: Firefly ROC-RK3328-CC
DRAM: 2 GiB
MMC: rksdmmc@ff520000: 0, rksdmmc@ff500000: 1
*** Warning - bad CRC, using default environment
In: serial@ff130000
Out: serial@ff130000
Err: serial@ff130000
misc_init_r
cpuid=55524b50303130313400000000013018
serial=728d2f5a6dc6f12
roc-rk3328-cc late init …
Net: No ethernet found.
mmc_init: -95, time 2009
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:4…
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
180 bytes read in 4 ms (43.9 KiB/s)
1: kernel-4.4
Retrieving file: /Image
reading /Image
16640008 bytes read in 777 ms (20.4 MiB/s)
append: earlycon=uart8250,mmio32,0xff130000 rw root=PARTUUID=b921b045-1d rootwait rootfstype=ext4 init=/sbin/init
Retrieving file: /rk3328-roc-cc.dtb
reading /rk3328-roc-cc.dtb
58477 bytes read in 8 ms (7 MiB/s)
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Loading Device Tree to 000000007def0000, end 000000007df0146c … OK
[ 0.000000] Linux version 4.4.114 (topillar@topillar-virtual-machine) (gcc version 7.3.0 (Ubuntu/Linaro 7.3.0-16ubuntu3) ) #1 SMP Fri Sep 14 00:16:42 CST 2018
[ 0.000000] earlycon: Early serial console at MMIO32 0xff130000 (options ‘’)
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07ff3e000 s45800 r8192 d32024 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 515592
[ 0.000000] Kernel command line: rockchip_jtag earlyprintk=uart8250-32bit,0xff130000 earlycon=uart8250,mmio32,0xff130000 rw root=PARTUUID=b921b045-1d rootwait rootfstype=ext4 init=/sbin/init
[ 0.000000] software IO TLB [mem 0x79800000-0x7d800000] (64MB) mapped at [ffffffc079800000-ffffffc07d7fffff]
[ 0.000000] Memory: 1975476K/2095104K available (9982K kernel code, 1402K rwdata, 3760K rodata, 1088K init, 693K bss, 119628K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8008df0000 - 0xffffff8008f00000 ( 1088 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008a40000 ( 9984 KB)
[ 0.000000] .rodata : 0xffffff8008a40000 - 0xffffff8008df0000 ( 3776 KB)
[ 0.000000] .data : 0xffffff8008f00000 - 0xffffff800905e808 ( 1403 KB)
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.001887] Console: colour dummy device 80x25
[ 0.002303] console [tty0] enabled
[ 0.002632] bootconsole [uart0] disabled
[ 0.003041] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003084] pid_max: default: 32768 minimum: 301
[ 0.003299] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.003327] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004418] Initializing cgroup subsys devices
[ 0.004458] Initializing cgroup subsys freezer
[ 0.004510] ftrace: allocating 37189 entries in 146 pages
[ 0.123673] sched-energy: CPU device node has no sched-energy-costs
[ 0.123722] Invalid sched_group_energy for CPU0
[ 0.123743] CPU0: update cpu_capacity 1024
[ 0.123827] ASID allocator initialised with 32768 entries
[ 0.130117] Detected VIPT I-cache on CPU1
[ 0.130196] Invalid sched_group_energy for CPU1
[ 0.130202] CPU1: update cpu_capacity 1024
[ 0.130208] CPU1: Booted secondary processor [410fd034]
[ 0.131013] Detected VIPT I-cache on CPU2
[ 0.131076] Invalid sched_group_energy for CPU2
[ 0.131082] CPU2: update cpu_capacity 1024
[ 0.131087] CPU2: Booted secondary processor [410fd034]
[ 0.131886] Detected VIPT I-cache on CPU3
[ 0.131943] Invalid sched_group_energy for CPU3
[ 0.131949] CPU3: update cpu_capacity 1024
[ 0.131953] CPU3: Booted secondary processor [410fd034]
[ 0.132080] Brought up 4 CPUs
[ 0.132330] SMP: Total of 4 processors activated.
[ 0.132388] CPU: All CPU(s) started at EL2
[ 0.132471] alternatives: patching kernel code
[ 0.132838] Invalid sched_group_energy for CPU3
[ 0.132889] Invalid sched_group_energy for Cluster3
[ 0.132932] Invalid sched_group_energy for CPU2
[ 0.132977] Invalid sched_group_energy for Cluster2
[ 0.133020] Invalid sched_group_energy for CPU1
[ 0.133060] Invalid sched_group_energy for Cluster1
[ 0.133111] Invalid sched_group_energy for CPU0
[ 0.133151] Invalid sched_group_energy for Cluster0
[ 0.134185] devtmpfs: initialized
[ 0.157916] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.158037] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.158758] xor: measuring software checksum speed
[ 0.168234] 8regs : 1080.000 MB/sec
[ 0.178317] 8regs_prefetch: 968.000 MB/sec
[ 0.188397] 32regs : 1456.000 MB/sec
[ 0.198487] 32regs_prefetch: 1224.000 MB/sec
[ 0.198531] xor: using function: 32regs (1456.000 MB/sec)
[ 0.198607] pinctrl core: initialized pinctrl subsystem
[ 0.200203] NET: Registered protocol family 16
[ 0.205631] cpuidle: using governor ladder
[ 0.209670] cpuidle: using governor menu
[ 0.209739] Registered FIQ tty driver
[ 0.210208] vdso: 2 pages (1 code @ ffffff8008a46000, 1 data @ ffffff8008f04000)
[ 0.210315] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.210553] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.240981] genirq: Setting trigger mode 8 for irq 176 failed (gic_set_type+0x0/0x64)
[ 0.295873] console [ttyFIQ0] enabled
[ 0.296637] Registered fiq debugger ttyFIQ0
[ 0.332668] raid6: int64x1 gen() 199 MB/s
[ 0.349756] raid6: int64x1 xor() 179 MB/s
[ 0.367069] raid6: int64x2 gen() 324 MB/s
[ 0.384126] raid6: int64x2 xor() 246 MB/s
[ 0.401313] raid6: int64x4 gen() 476 MB/s
[ 0.418453] raid6: int64x4 xor() 333 MB/s
[ 0.435677] raid6: int64x8 gen() 386 MB/s
[ 0.452812] raid6: int64x8 xor() 306 MB/s
[ 0.470080] raid6: neonx1 gen() 359 MB/s
[ 0.487175] raid6: neonx1 xor() 314 MB/s
[ 0.504396] raid6: neonx2 gen() 546 MB/s
[ 0.521512] raid6: neonx2 xor() 482 MB/s
[ 0.538682] raid6: neonx4 gen() 738 MB/s
[ 0.555874] raid6: neonx4 xor() 570 MB/s
[ 0.573097] raid6: neonx8 gen() 761 MB/s
[ 0.590242] raid6: neonx8 xor() 574 MB/s
[ 0.590660] raid6: using algorithm neonx8 gen() 761 MB/s
[ 0.591162] raid6: … xor() 574 MB/s, rmw enabled
[ 0.591646] raid6: using intx1 recovery algorithm
[ 0.592717] mpp venc_srv: mpp_probe enter
[ 0.593172] mpp venc_srv: init success
[ 0.595844] vcc_sd: regulator get failed, ret=-517
[ 0.598067] vcc_host_5v: regulator get failed, ret=-517
[ 0.599331] vcc_host_5v: supplied by vcc_sys
[ 0.600892] iommu: Adding device ff350000.vpu_service to group 0
[ 0.601569] iommu: Adding device ff351000.avsd to group 1
[ 0.602200] iommu: Adding device ff360000.rkvdec to group 2
[ 0.602828] iommu: Adding device ff330000.h265e to group 3
[ 0.603462] iommu: Adding device ff340000.vepu to group 4
[ 0.604083] iommu: Adding device ff370000.vop to group 5
[ 0.605902] rk_iommu ff360480.iommu: can’t get aclk
[ 0.606400] rk_iommu ff360480.iommu: can’t get hclk
[ 0.607130] rk_iommu ff330200.iommu: can’t get aclk
[ 0.607616] rk_iommu ff330200.iommu: can’t get hclk
[ 0.608549] rk_iommu ff373f00.iommu: can’t get aclk
[ 0.609032] rk_iommu ff373f00.iommu: can’t get hclk
[ 0.610311] SCSI subsystem initialized
[ 0.611085] usbcore: registered new interface driver usbfs
[ 0.611695] usbcore: registered new interface driver hub
[ 0.612368] usbcore: registered new device driver usb
[ 0.612956] media: Linux media interface: v0.10
[ 0.613485] Linux video capture interface: v2.00
[ 0.614028] pps_core: LinuxPPS API ver. 1 registered
[ 0.614527] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.615420] PTP clock support registered
[ 0.618028] Advanced Linux Sound Architecture Driver Initialized.
[ 0.619592] Bluetooth: Core ver 2.21
[ 0.620030] NET: Registered protocol family 31
[ 0.620458] Bluetooth: HCI device and connection manager initialized
[ 0.621089] Bluetooth: HCI socket layer initialized
[ 0.621570] Bluetooth: L2CAP socket layer initialized
[ 0.622112] Bluetooth: SCO socket layer initialized
[ 0.624016] rockchip-cpuinfo cpuinfo: Serial : 728d2f5a6dc6f125
[ 0.625583] clocksource: Switched to clocksource arch_sys_counter
[ 0.738868] NET: Registered protocol family 2
[ 0.740237] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.741250] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.742911] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.743712] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.744469] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.745695] NET: Registered protocol family 1
[ 0.746756] RPC: Registered named UNIX socket transport module.
[ 0.747338] RPC: Registered udp transport module.
[ 0.747823] RPC: Registered tcp transport module.
[ 0.748281] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.750210] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.755939] Initialise system trusted keyring
[ 0.772706] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.774889] NFS: Registering the id_resolver key type
[ 0.775434] Key type id_resolver registered
[ 0.775882] Key type id_legacy registered
[ 0.776390] fuse init (API version 7.23)
[ 0.777594] SGI XFS with security attributes, no debug enabled
[ 0.785786] NET: Registered protocol family 38
[ 0.786285] Key type asymmetric registered
[ 0.786712] Asymmetric key parser ‘x509’ registered
[ 0.787592] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.788347] io scheduler noop registered
[ 0.788766] io scheduler deadline registered
[ 0.789437] io scheduler cfq registered (default)
[ 0.793449] rockchip-usb2phy ff450000.syscon:usb2-phy@100: vbus_drv is not assigned
[ 0.795381] rockchip-u3phy ff470000.usb3-phy: vbus_drv is not assigned
[ 0.798943] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully
[ 0.803767] rk-vcodec vpu_combo: no regulator for vcodec
[ 0.804682] rk-vcodec vpu_combo: failed on clk_get clk_cabac
[ 0.805249] rk-vcodec vpu_combo: failed on clk_get clk_core
[ 0.805905] platform ff350000.vpu_service: probe device
[ 0.806470] platform ff350000.vpu_service: vpu mmu dec ffffffc0791e7010
[ 0.807485] platform ff350000.vpu_service: allocator is drm
[ 0.808138] platform ff350000.vpu_service: checking hw id 0
[ 0.809808] platform ff351000.avsd: probe device
[ 0.810410] platform ff351000.avsd: vpu mmu dec ffffffc0791e7010
[ 0.811392] platform ff351000.avsd: allocator is drm
[ 0.811958] platform ff351000.avsd: checking hw id 6731
[ 0.814786] rk-vcodec vpu_combo: could not find power_model node
[ 0.815379] rk-vcodec vpu_combo: init success
[ 0.816329] rk-vcodec ff360000.rkvdec: no regulator for vcodec
[ 0.816973] rk-vcodec ff360000.rkvdec: parent devfreq retry
[ 0.818651] probe device ff330000.h265e
[ 0.819483] mpp_dev ff330000.h265e: try to get iommu dev ffffffc079248c10
[ 0.820752] mpp_dev ff330000.h265e: resource ready, register device
[ 0.822051] probe device ff340000.vepu
[ 0.822886] mpp_dev ff340000.vepu: try to get iommu dev ffffffc079249410
[ 0.824037] mpp_dev ff340000.vepu: resource ready, register device
[ 0.828412] dma-pl330 ff1f0000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.829094] dma-pl330 ff1f0000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.831261] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.835207] ff120000.serial: ttyS1 at MMIO 0xff120000 (irq = 12, base_baud = 1500000) is a 16550A
[ 0.838124] [drm] Initialized drm 1.1.0 20060810
[ 0.842795] rockchip-drm display-subsystem: devfreq is not set
[ 0.843915] rockchip-vop ff370000.vop: failed to get vop register byname
[ 0.844635] rockchip-vop ff370000.vop: invalid resource
[ 0.845152] rockchip-vop ff370000.vop: failed to get vop lut registers
[ 0.845793] rockchip-vop ff370000.vop: invalid resource
[ 0.846309] rockchip-vop ff370000.vop: failed to get vop cabc lut registers
[ 0.847332] rockchip-drm display-subsystem: bound ff370000.vop (ops 0xffffff8008aee6d0)
[ 0.848657] i2c i2c-4: of_i2c: modalias failure on /hdmi@ff3c0000/ports
[ 0.849309] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.850317] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
[ 0.852667] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops 0xffffff8008ae6638)
[ 0.853476] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.854112] [drm] No driver support for vblank timestamp query.
[ 0.854817] rockchip-drm display-subsystem: failed to parse display resources
[ 0.855544] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 0.856422] [drm] Cannot find any crtc or sizes - going 1024x768
[ 0.882642] Console: switching to colour frame buffer device 128x48
[ 0.903174] rockchip-drm display-subsystem: fb0: frame buffer device
[ 0.914004] Unable to detect cache hierarchy for CPU 0
[ 0.916298] brd: module loaded
[ 0.927443] loop: module loaded
[ 0.929132] zram: Added device: zram0
[ 0.930148] lkdtm: No crash points registered, enable through debugfs
[ 0.934526] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 0.935701] rk_gmac-dwmac ff540000.ethernet: clock input or output? (input).
[ 0.936644] rk_gmac-dwmac ff540000.ethernet: TX delay(0x28).
[ 0.937387] rk_gmac-dwmac ff540000.ethernet: RX delay(0x16).
[ 0.938162] rk_gmac-dwmac ff540000.ethernet: integrated PHY? (no).
[ 0.939246] rk_gmac-dwmac ff540000.ethernet: cannot get clock clk_mac_speed
[ 0.940167] rk_gmac-dwmac ff540000.ethernet: clock input from PHY
[ 0.945997] rk_gmac-dwmac ff540000.ethernet: init for RGMII
[ 0.946924] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.947598] Ring mode enabled
[ 0.948006] DMA HW capability register supported
[ 0.948607] Normal descriptors
[ 0.949064] RX Checksum Offload Engine supported (type 2)
[ 0.949787] Wake-Up On Lan supported
[ 0.950352] Enable RX Mitigation via HW Watchdog Timer
[ 1.015935] libphy: stmmac: probed
[ 1.016430] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.025426] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.035782] Rockchip WiFi SYS interface (V1.00) …
[ 1.046920] phy phy-ff470000.usb3-phy.2: u3phy u2 power on
[ 1.055694] phy phy-ff470000.usb3-phy.3: u3phy u3 power on
[ 1.065730] ff580000.usb supply vusb_d not found, using dummy regulator
[ 1.074712] ff580000.usb supply vusb_a not found, using dummy regulator
[ 1.096083] dwc2 ff580000.usb: DWC OTG Controller
[ 1.104699] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
[ 1.113536] dwc2 ff580000.usb: irq 40, io mem 0xff580000
[ 1.122426] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.131106] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.139739] usb usb1: Product: DWC OTG Controller
[ 1.148029] usb usb1: Manufacturer: Linux 4.4.114 dwc2_hsotg
[ 1.156332] usb usb1: SerialNumber: ff580000.usb
[ 1.165484] hub 1-0:1.0: USB hub found
[ 1.173480] hub 1-0:1.0: 1 port detected
[ 1.182781] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.190887] ehci-pci: EHCI PCI platform driver
[ 1.198696] ehci-platform: EHCI generic platform driver
[ 1.209243] ehci-platform ff5c0000.usb: EHCI Host Controller
[ 1.217369] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2
[ 1.225609] ehci-platform ff5c0000.usb: irq 41, io mem 0xff5c0000
[ 1.238627] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.246643] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.254325] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.262038] usb usb2: Product: EHCI Host Controller
[ 1.269428] usb usb2: Manufacturer: Linux 4.4.114 ehci_hcd
[ 1.276870] usb usb2: SerialNumber: ff5c0000.usb
[ 1.285410] hub 2-0:1.0: USB hub found
[ 1.292909] hub 2-0:1.0: 1 port detected
[ 1.300999] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.308579] ohci-platform: OHCI generic platform driver
[ 1.316594] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
[ 1.324620] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3
[ 1.332643] ohci-platform ff5d0000.usb: irq 42, io mem 0xff5d0000
[ 1.394942] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.402818] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.410757] usb usb3: Product: Generic Platform OHCI controller
[ 1.418633] usb usb3: Manufacturer: Linux 4.4.114 ohci_hcd
[ 1.426433] usb usb3: SerialNumber: ff5d0000.usb
[ 1.435190] hub 3-0:1.0: USB hub found
[ 1.442927] hub 3-0:1.0: 1 port detected
[ 1.452112] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 1.460363] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 4
[ 1.468756] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00210010
[ 1.477038] xhci-hcd xhci-hcd.9.auto: irq 180, io mem 0xff600000
[ 1.485217] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.493229] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.501381] usb usb4: Product: xHCI Host Controller
[ 1.509267] usb usb4: Manufacturer: Linux 4.4.114 xhci-hcd
[ 1.517195] usb usb4: SerialNumber: xhci-hcd.9.auto
[ 1.526162] hub 4-0:1.0: USB hub found
[ 1.534065] hub 4-0:1.0: 1 port detected
[ 1.542525] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 1.550974] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[ 1.559424] usb usb5: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.568046] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.576290] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.584585] usb usb5: Product: xHCI Host Controller
[ 1.592583] usb usb5: Manufacturer: Linux 4.4.114 xhci-hcd
[ 1.600650] usb usb5: SerialNumber: xhci-hcd.9.auto
[ 1.609724] hub 5-0:1.0: USB hub found
[ 1.617712] hub 5-0:1.0: 1 port detected
[ 1.626629] usbcore: registered new interface driver usb-storage
[ 1.635400] mousedev: PS/2 mouse device common for all mice
[ 1.645264] usbcore: registered new interface driver usbtouchscreen
[ 1.654109] .. rk pwm remotectl v1.1 init
[ 1.662845] input: ff1b0030.pwm as /devices/platform/ff1b0030.pwm/input/input0
[ 1.673056] i2c /dev entries driver
[ 1.684663] rk808 1-0018: Pmic Chip id: 0x8050
[ 1.694150] rk808 1-0018: source: on=0x40, off=0x00
[ 1.719136] vcc_sd: supplied by vcc_io
[ 1.737340] rk808 1-0018: register rk8050 regulators
[ 1.746090] rk8xx-gpio rk8xx-gpio: register rk8050 gpio successful
[ 1.764956] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.774452] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff800919e000
[ 1.785170] IR NEC protocol handler initialized
[ 1.794333] usbcore: registered new interface driver uvcvideo
[ 1.802966] USB Video Class driver (1.1.1)
[ 1.816982] rockchip-thermal ff250000.tsadc: Missing tshut mode property, using default (cru)
[ 1.826160] rockchip-thermal ff250000.tsadc: Missing tshut-polarity property, using default (low)
[ 1.836704] Bluetooth: Virtual HCI driver ver 1.5
[ 1.845822] Bluetooth: HCI UART driver ver 2.3
[ 1.854423] Bluetooth: HCI UART protocol H4 registered
[ 1.862969] Bluetooth: HCI UART protocol LL registered
[ 1.871408] Bluetooth: HCI UART protocol ATH3K registered
[ 1.879970] usbcore: registered new interface driver bfusb
[ 1.888530] usbcore: registered new interface driver btusb
[ 1.897609] cpu cpu0: cpu_leakage=12
[ 1.905866] cpu cpu0: cpu_leakage=12
[ 1.913905] cpu cpu0: cpu_leakage-volt-sel=1
[ 1.925910] sdhci: Secure Digital Host Controller Interface driver
[ 1.930238] sdhci: Copyright(c) Pierre Ossman
[ 1.934245] Synopsys Designware Multimedia Card Interface Driver
[ 1.939301] dwmmc_rockchip ff500000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.943755] dwmmc_rockchip ff500000.dwmmc: Using internal DMA controller.
[ 1.947997] dwmmc_rockchip ff500000.dwmmc: Version ID is 270a
[ 1.952150] dwmmc_rockchip ff500000.dwmmc: DW MMC controller at irq 37,32 bit host data width,256 deep fifo
[ 1.956726] dwmmc_rockchip ff500000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.961342] dwmmc_rockchip ff500000.dwmmc: No vqmmc regulator found
[ 1.976629] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.991661] dwmmc_rockchip ff500000.dwmmc: 1 slots initialized
[ 1.996695] dwmmc_rockchip ff520000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.001298] dwmmc_rockchip ff520000.dwmmc: Using internal DMA controller.
[ 2.005679] dwmmc_rockchip ff520000.dwmmc: Version ID is 270a
[ 2.009956] dwmmc_rockchip ff520000.dwmmc: DW MMC controller at irq 38,32 bit host data width,256 deep fifo
[ 2.014649] dwmmc_rockchip ff520000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.019239] dwmmc_rockchip ff520000.dwmmc: No vmmc regulator found
[ 2.023572] dwmmc_rockchip ff520000.dwmmc: No vqmmc regulator found
[ 2.038607] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.053687] dwmmc_rockchip ff520000.dwmmc: 1 slots initialized
[ 2.058392] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.064754] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.069655] usbcore: registered new interface driver usbhid
[ 2.074125] usbhid: USB HID core driver
[ 2.079299] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 2.085477] usbcore: registered new interface driver snd-usb-audio
[ 2.090925] rk3328-codec ff410000.codec: spk_depop_time use default value.
[ 2.098421] Initializing XFRM netlink socket
[ 2.103522] NET: Registered protocol family 10
[ 2.108996] NET: Registered protocol family 17
[ 2.113401] NET: Registered protocol family 15
[ 2.117734] Bluetooth: RFCOMM socket layer initialized
[ 2.122012] Bluetooth: RFCOMM ver 1.11
[ 2.126007] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.130211] Bluetooth: HIDP socket layer initialized
[ 2.134334] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.138616] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.142824] Key type dns_resolver registered
[ 2.147317] Registered cp15_barrier emulation handler
[ 2.151354] Registered setend emulation handler
[ 2.155965] Loading compiled-in X.509 certificates
[ 2.162002] Btrfs loaded
[ 2.166618] rk-vcodec ff360000.rkvdec: no regulator for vcodec
[ 2.170881] rk-vcodec ff360000.rkvdec: parent devfreq retry
[ 2.175917] rockchip-dmc dmc: current ATF version 0x101!
[ 2.180144] rockchip-dmc dmc: read tf version 0x101!
[ 2.185695] rockchip-dmc dmc: ddr_leakage=11
[ 2.189778] rockchip-dmc dmc: ddr_leakage-volt-sel=0
[ 2.194366] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 2.220554] asoc-simple-card sound: rk3328-hifi ↔ ff010000.i2s mapping ok
[ 2.225869] asoc-simple-card hdmi-sound: i2s-hifi ↔ ff000000.i2s mapping ok
[ 2.230525] rk-vcodec ff360000.rkvdec: no regulator for vcodec
[ 2.234432] rk-vcodec ff360000.rkvdec: parent devfreq is ok
[ 2.238569] rk-vcodec ff360000.rkvdec: probe device
[ 2.242293] rk-vcodec ff360000.rkvdec: vpu mmu dec ffffffc079248410
[ 2.246339] rk-vcodec ff360000.rkvdec: allocator is drm
[ 2.250061] rk-vcodec ff360000.rkvdec: checking hw id 3410
[ 2.254060] rk-vcodec ff360000.rkvdec: init success
[ 2.259495] rk808-rtc rk808-rtc: setting system clock to 2016-01-21 08:50:09 UTC (1453366209)
[ 2.272914] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 415; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-release_v1.02-14-gf9ef75429d38’, rk_ko_ver is ‘5’, built at ‘00:13:36’, on ‘Sep 14 2018’.
[ 2.284996] mali-utgard ff300000.gpu: mali_platform_device->num_resources = 9
[ 2.289043] mali-utgard ff300000.gpu: resource[0].start = 0x0x00000000ff300000
[ 2.293088] mali-utgard ff300000.gpu: resource[1].start = 0x0x00000000ff300000
[ 2.297107] mali-utgard ff300000.gpu: resource[2].start = 0x0x0000000000000011
[ 2.301018] mali-utgard ff300000.gpu: resource[3].start = 0x0x0000000000000012
[ 2.304822] mali-utgard ff300000.gpu: resource[4].start = 0x0x0000000000000013
[ 2.308564] mali-utgard ff300000.gpu: resource[5].start = 0x0x0000000000000014
[ 2.312245] mali-utgard ff300000.gpu: resource[6].start = 0x0x0000000000000015
[ 2.315871] mali-utgard ff300000.gpu: resource[7].start = 0x0x0000000000000016
[ 2.319442] mali-utgard ff300000.gpu: resource[8].start = 0x0x0000000000000017
[ 2.322942] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 617; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali.
[ 2.330374] mali-utgard ff300000.gpu: gpu_leakage=11
[ 2.333776] mali-utgard ff300000.gpu: gpu_leakage-volt-sel=1
[ 2.337737] devfreq ff300000.gpu: Couldn’t update frequency transition information.
[ 2.342650] Mali: Mali device driver loaded
[ 2.347340] ALSA device list:
[ 2.350692] #0: rockchip,rk3328
[ 2.354050] #1: rockchip,hdmi
[ 2.357529] Waiting for root device PARTUUID=b921b045-1d…
[ 2.570565] dwmmc_rockchip ff520000.dwmmc: Busy; trying anyway
[ 2.574184] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x0)
[ 2.580146] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.584322] mmc0: new high speed SDHC card at address 0001
[ 2.588410] mmcblk0: mmc0:0001 MS 7.44 GiB
[ 2.602451] mmcblk0: p1 p2 p3 p4 p5
[ 2.990785] JBD2: Invalid checksum recovering block 1 in log
[ 2.995335] JBD2: Invalid checksum recovering block 1 in log
[ 5.152576] vendor storage:20160801 ret = -1
[ 5.454020] random: nonblocking pool is initialized
[ 13.797322] JBD2: recovery failed
[ 13.800884] EXT4-fs (mmcblk0p5): error loading journal
[ 13.807322] VFS: Cannot open root device “PARTUUID=b921b045-1d” or unknown-block(179,5): error -5
[ 13.811569] Please append a correct “root=” boot option; here are the available partitions:
[ 13.815796] 0100 4096 ram0 (driver?)
[ 13.819665] b300 7802880 mmcblk0 driver: mmcblk
[ 13.823581] b301 4000 mmcblk0p1 65388504-6af8-4ab1-8669-c75adb5bb4d8
[ 13.827723] b302 4096 mmcblk0p2 22975d0d-42f9-401b-93af-ddba2e9ce68e
[ 13.831884] b303 4096 mmcblk0p3 08b3ff9d-626d-4ca5-8f81-a0e99a7df65e
[ 13.836070] b304 114688 mmcblk0p4 0e1806a1-3e39-4295-a626-e17d53092b5b
[ 13.840273] b305 7169007 mmcblk0p5 b921b045-1df0-41c3-af44-4c6f280d3fae
[ 13.844497] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5)
[ 13.848870] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.4.114 #1
[ 13.853062] Hardware name: Firefly ROC-RK3328-CC (DT)
[ 13.857132] Call trace:
[ 13.860841] [] dump_backtrace+0x0/0x220
[ 13.864741] [] show_stack+0x24/0x30
[ 13.868490] [] dump_stack+0x98/0xc0
[ 13.872161] [] panic+0xe8/0x23c
[ 13.875776] [] mount_block_root+0x244/0x2b0
[ 13.879536] [] mount_root+0x70/0x80
[ 13.883253] [] prepare_namespace+0x1a0/0x1b0
[ 13.887085] [] kernel_init_freeable+0x1f4/0x22c
[ 13.890988] [] kernel_init+0x18/0x100
[ 13.894832] [] ret_from_fork+0x10/0x20
[ 13.898721] CPU2: stopping
[ 13.902401] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.4.114 #1
[ 13.906472] Hardware name: Firefly ROC-RK3328-CC (DT)
[ 13.910375] Call trace:
[ 13.913905] [] dump_backtrace+0x0/0x220
[ 13.917722] [] show_stack+0x24/0x30
[ 13.921532] [] dump_stack+0x98/0xc0
[ 13.925270] [] handle_IPI+0x1d0/0x248
[ 13.928961] [] gic_handle_irq+0xa8/0xc0
[ 13.932662] Exception stack(0xffffffc0003efe10 to 0xffffffc0003eff40)
[ 13.936526] fe00: 0000004077094000 ffffff8008ed4000
[ 13.940617] fe20: 0000000000000000 ffffff8008f1c500 0100000000000000 ffffff8009062cc0
[ 13.944713] fe40: 0000000000001c96 000000000000048c ffffffc0003da380 ffffffc0003efee0
[ 13.948793] fe60: 0000000000000920 0000000000000400 0000000000000278 0000000000000002
[ 13.952827] fe80: 0000000000000001 0000000000000000 0000000000000028 0000000000007fff
[ 13.956776] fea0: 0000000000000002 ffffff8008ed4000 ffffff800902a9c0 ffffff800902a000
[ 13.960669] fec0: ffffff8008f05000 ffffff8008f05618 ffffff8008a47000 000000000310c000
[ 13.964560] fee0: 000000000310f000 0000000002a2b234 0000000000000000 ffffffc0003eff40
[ 13.968483] ff00: ffffff8008085100 ffffffc0003eff40 ffffff8008085104 0000000060000045
[ 13.972421] ff20: ffffff8008ed4000 ffffff8008f05000 ffffffffffffffff ffffff8008a47000
[ 13.976415] [] el1_irq+0xb4/0x140
[ 13.980127] [] arch_cpu_idle+0x8c/0x100
[ 13.983879] [] default_idle_call+0x30/0x34
[ 13.987655] [] cpu_startup_entry+0x214/0x2ac
[ 13.991426] [] secondary_start_kernel+0x198/0x1c4
[ 13.995174] [<0000000002a2b178>] 0x2a2b178
[ 13.998653] CPU3: stopping
[ 14.001935] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4.114 #1
[ 14.005569] Hardware name: Firefly ROC-RK3328-CC (DT)
[ 14.009095] Call trace:
[ 14.012358] [] dump_backtrace+0x0/0x220
[ 14.015933] [] show_stack+0x24/0x30
[ 14.019461] [] dump_stack+0x98/0xc0
[ 14.022954] [] handle_IPI+0x1d0/0x248
[ 14.026391] [] gic_handle_irq+0xa8/0xc0
[ 14.029774] Exception stack(0xffffffc0003f3e10 to 0xffffffc0003f3f40)
[ 14.033277] 3e00: 00000040770a9000 ffffff8008ed4000
[ 14.036968] 3e20: 0000000000000000 ffffff8008f1c500 0100000000000000 000000001d44fa59
[ 14.040676] 3e40: 0000000000001c52 00000040770a9000 ffffffc0003db080 ffffffc0003f3ee0
[ 14.044417] 3e60: 0000000000000920 ffffff800901e000 0000000000000000 0000000000005dc0
[ 14.048198] 3e80: 00000f4240001f40 0000000000000000 0000000000000000 0000000000000000
[ 14.051975] 3ea0: 0000000000000000 ffffff8008ed4000 ffffff800902a9c0 ffffff800902a000
[ 14.055772] 3ec0: ffffff8008f05000 ffffff8008f05618 ffffff8008a47000 000000000310c000
[ 14.059585] 3ee0: 000000000310f000 0000000002a2b234 0000000000000000 ffffffc0003f3f40
[ 14.063428] 3f00: ffffff8008085100 ffffffc0003f3f40 ffffff8008085104 0000000060000045
[ 14.067304] 3f20: ffffff8008ed4000 ffffff8008f05000 ffffffffffffffff ffffff8008a47000
[ 14.071198] [] el1_irq+0xb4/0x140
[ 14.074842] [] arch_cpu_idle+0x8c/0x100
[ 14.078515] [] default_idle_call+0x30/0x34
[ 14.082204] [] cpu_startup_entry+0x214/0x2ac
[ 14.085878] [] secondary_start_kernel+0x198/0x1c4
[ 14.089588] [<0000000002a2b178>] 0x2a2b178
[ 14.093083] CPU0: stopping
[ 14.096446] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.114 #1
[ 14.100181] Hardware name: Firefly ROC-RK3328-CC (DT)
[ 14.103863] Call trace:
[ 14.107292] [] dump_backtrace+0x0/0x220
[ 14.111001] [] show_stack+0x24/0x30
[ 14.114624] [] dump_stack+0x98/0xc0
[ 14.118200] [] handle_IPI+0x1d0/0x248
[ 14.121768] [] gic_handle_irq+0xa8/0xc0
[ 14.125341] Exception stack(0xffffff8008f03de0 to 0xffffff8008f03f10)
[ 14.129088] 3de0: 000000407706a000 ffffff8008ed4000 0000000000000000 ffffff8008f1c500
[ 14.133009] 3e00: 0100000000000000 000000001c74f859 0000000000001be8 000000000000000f
[ 14.136939] 3e20: ffffff8008f0da90 ffffff8008f03eb0 0000000000000920 0000000000000400
[ 14.140846] 3e40: 0000000000000001 0000000000000000 000000000000000e 00000000895acb21
[ 14.144731] 3e60: 0000000000000008 00000000df7e4c9a 00000000b24999b3 ffffff8008ed4000
[ 14.148609] 3e80: ffffff800902a9c0 ffffff800902a000 ffffff8008f05000 ffffff8008f05618
[ 14.152469] 3ea0: ffffff8008a47000 000000000310c000 000000000310f000 0000000002a2b22c
[ 14.156352] 3ec0: 0000000002df001c ffffff8008f03f10 ffffff8008085100 ffffff8008f03f10
[ 14.160270] 3ee0: ffffff8008085104 0000000060000045 ffffff8008ed4000 ffffff8008f05000
[ 14.164201] 3f00: ffffffffffffffff ffffff8008a47000
[ 14.167857] [] el1_irq+0xb4/0x140
[ 14.171497] [] arch_cpu_idle+0x8c/0x100
[ 14.175186] [] default_idle_call+0x30/0x34
[ 14.178886] [] cpu_startup_entry+0x214/0x2ac
[ 14.182569] [] rest_init+0x74/0x7c
[ 14.186157] [] start_kernel+0x384/0x3a8
[ 14.189766] [] __primary_switched+0x30/0x6c
[ 14.193414] CRU:
[ 14.196719] 00000000: 000070d7 00000486 000a3d70 00000000 00000000 00000000 00000000 00000000
[ 14.200775] 00000020: 00001055 00001441 00000001 00000000 00000000 00000000 00000000 00000000
[ 14.204813] 00000040: 00001032 00001441 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.208782] 00000060: 000023d7 00000458 000a3d70 00000000 00000000 00000000 00000000 00000000
[ 14.212675] 00000080: 00001113 00002000 00005a5a 00000000 3a98c064 00000000 00000000 00000000
[ 14.216523] 000000a0: 0000103a 00001441 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.220334] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.224100] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.227835] 00000100: 000007c0 00001115 00000003 00000000 00002c80 00008004 0000000f 00010014
[ 14.231538] 00000120: 00000100 00933d09 0000000f 00010014 0000000f 00010014 00000207 00010014
[ 14.235227] 00000140: 00000207 00010014 00000207 00010014 00008087 0000170c 000001df 00000017
[ 14.238883] 00000160: 0000079f 00000207 0000000f 00000705 00004107 00000011 0000000b 00000017
[ 14.242497] 00000180: 0000021d 00008800 00000707 00000707 00000305 00000203 00007a97 00000002
[ 14.246096] 000001a0: 00003111 0bb8ea60 00003113 00000003 00000040 0000001f 00000000 00000000
[ 14.249644] 000001c0: 00000b0b 0000000b 000000df 00000505 00000b31 00000000 00000000 00000000
[ 14.253189] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.256712] 00000200: 00000400 0000ff8e 0000febf 00000123 00000611 0000006a 000000ff 00000000
[ 14.260228] 00000220: 000007e0 000000de 00000000 00000111 00000000 00000000 00000001 00000de2
[ 14.263731] 00000240: 00009eb7 0000b800 00000000 00008002 00000000 00008fcc 00000021 00000003
[ 14.267204] 00000260: 00000003 0000003c 00000003 00000000 00000001 00000000 00000000 00000000
[ 14.270669] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.274083] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.277428] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.280723] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.283960] 00000300: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.287162] 00000320: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.290344] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.293497] 00000360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.296611] 00000380: 00000004 00000000 00000004 00000000 00000004 00000000 00000004 00000000
[ 14.299658] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.302622] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.305527] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.308379] Kernel Offset: disabled
[ 14.310760] Memory Limit: none
[ 14.313092] rockchip-thermal ff250000.tsadc: channal 0: temperature(64 C)
[ 14.315799] THERMAL REGS:
[ 14.318103] 00000000: 00000200 00010013 00000101 00000000 00000000 00000000 00000000 00000000
[ 14.321040] 00000020: 000001fe 00000000 00000000 00000000 00000209 00000000 00000000 00000000
[ 14.323942] 00000040: 00000258 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.326773] 00000060: 00000004 00000004 000000fa 00000032 00000000 00000000 00000000 00000000
[ 14.329565] 00000080: 00000000 00000000
[ 14.331918] —[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5)
[ 36.155555] Watchdog detected hard LOCKUP on cpu 2
[ 36.156047] ------------[ cut here ]------------
[ 36.160757] WARNING: at kernel/watchdog.c:352
[ 36.163319] Modules linked in:
[ 36.165764]
[ 36.167995] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.4.114 #1
[ 36.170648] Hardware name: Firefly ROC-RK3328-CC (DT)
[ 36.173258] task: ffffffc000390000 task.stack: ffffffc000398000
[ 36.176020] PC is at watchdog_timer_fn+0x190/0x2e8
[ 36.178714] LR is at watchdog_timer_fn+0x190/0x2e8
[ 36.181377] pc : [] lr : [] pstate: 600001c5
[ 36.184360] sp : ffffffc07ff56e00
[ 36.186995] x29: ffffffc07ff56e00 x28: 0000000000000002
[ 36.189890] x27: ffffff8008f07708 x26: ffffff8008eda238
[ 36.192789] x25: ffffffc07ff59250 x24: ffffffc00039bb30
[ 36.195679] x23: 0000000000000000 x22: 0000000000000000
[ 36.198570] x21: ffffff8008f06000 x20: ffffff8008eda2b0
[ 36.201458] x19: ffffff8008eda000 x18: 0000000000000005
[ 36.204343] x17: 0000000024eda1c5 x16: 0000000000000000
[ 36.207208] x15: 0000000000000000 x14: ffffff80094e06c0
[ 36.210071] x13: ffffff80094e06c0 x12: ffffffc078a724c0
[ 36.212947] x11: 00000000ffffffff x10: 0000000000000008
[ 36.215837] x9 : 0000000000aaaaaa x8 : 0000000000001000
[ 36.218710] x7 : 0000000000000000 x6 : 0000000000000001
[ 36.221567] x5 : 0000000000000000 x4 : 0000000000000000
[ 36.224398] x3 : 000000407707f000 x2 : 000000407707f000
[ 36.227238] x1 : 0000000000000001 x0 : 0000000000000026
[ 36.230101]
[ 36.230101] PC: 0xffffff800812b834:
[ 36.235313] b834 91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[ 36.238751] b854 a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[ 36.242274] b874 f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90005be0
[ 36.245881] b894 91039c00 340000c2 9400d1bf f8226860 f87c7b60 3834681f 17ffffd3 9400d249
[ 36.249566] b8b4 d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7c5a f94386a1 36080941
[ 36.253329] b8d4 b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[ 36.257163] b8f4 6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[ 36.261081] b914 d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 b0007d01 52800000
[ 36.265084]
[ 36.265084] LR: 0xffffff800812b834:
[ 36.271614] b834 91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[ 36.275619] b854 a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[ 36.279631] b874 f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90005be0
[ 36.283623] b894 91039c00 340000c2 9400d1bf f8226860 f87c7b60 3834681f 17ffffd3 9400d249
[ 36.287676] b8b4 d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7c5a f94386a1 36080941
[ 36.291804] b8d4 b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[ 36.295999] b8f4 6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[ 36.300206] b914 d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 b0007d01 52800000
[ 36.304384]
[ 36.304384] SP: 0xffffffc07ff56d80:
[ 36.311226] 6d80 00000000 00000000 00000000 00000000 0039bb30 ffffffc0 7ff59250 ffffffc0
[ 36.315410] 6da0 08eda238 ffffff80 08f07708 ffffff80 00000002 00000000 7ff56e00 ffffffc0
[ 36.319615] 6dc0 0812b8b4 ffffff80 7ff56e00 ffffffc0 0812b8b4 ffffff80 600001c5 00000000
[ 36.323858] 6de0 08f06708 ffffff80 00000003 00000000 00000000 00000080 79400028 ffffffc0
[ 36.328109] 6e00 7ff56e70 ffffffc0 081024e8 ffffff80 7ff59250 ffffffc0 7ff58c00 ffffffc0
[ 36.332355] 6e20 651ae75e 00000008 7ff58c80 ffffffc0 08ed4000 ffffff80 00000001 00000000
[ 36.336607] 6e40 0902a498 ffffff80 651ae75e 00000008 0812b724 ffffff80 00390000 ffffffc0
[ 36.340864] 6e60 7ff59250 ffffffc0 08f06708 ffffff80 7ff56ee0 ffffffc0 08102acc ffffff80
[ 36.345187]
[ 36.345187] X12: 0xffffffc078a72440:
[ 36.352347] 2440 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.356686] 2460 c67c0000 c67cc6c6 7cc6c6c6 00000000 00000000 00000000 00000000 38383838
[ 36.361032] 2480 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ffff0000
[ 36.365391] 24a0 06303030 c6c0c0c6 06303030 c6c0c0c6 c6303030 6cc6c6c6 7c787830 387c7c7c
[ 36.369789] 24c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ffff0000
[ 36.374227] 24e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.378639] 2500 00000000 38380000 6c6c6c38 c6c6c6c6 d6d6c6c6 d6d6d6d6 c6c6c6c6 6c6cc6c6
[ 36.383106] 2520 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.387618]
[ 36.387618] X13: 0xffffff80094e0640:
[ 36.395311] 0640 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.399944] 0660 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.404561] 0680 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.409176] 06a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.413772] 06c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.418345] 06e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.422864] 0700 00000000 00000000 00000000 00000000 00aaaaaa 00000000 00000000 00000000
[ 36.427371] 0720 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.431790]
[ 36.431790] X14: 0xffffff80094e0640:
[ 36.439152] 0640 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.443538] 0660 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.447840] 0680 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.452062] 06a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.456201] 06c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.460257] 06e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.464221] 0700 00000000 00000000 00000000 00000000 00aaaaaa 00000000 00000000 00000000
[ 36.468170] 0720 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.472034]
[ 36.472034] X19: 0xffffff8008ed9f80:
[ 36.478287] 9f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.482119] 9fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.485869] 9fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.489537] 9fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.493119] a000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.496623] a020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.500030] a040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.503417] a060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.506707]
[ 36.506707] X20: 0xffffff8008eda230:
[ 36.511877] a230 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.515189] a250 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.518433] a270 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.521609] a290 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.524717] a2b0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.527762] a2d0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.530711] a2f0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.533636] a310 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.536465]
[ 36.536465] X21: 0xffffff8008f05f80:
[ 36.540781] 5f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.543668] 5fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.546478] 5fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.549280] 5fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.552006] 6000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.554661] 6020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.557219] 6040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.559755] 6060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.562194]
[ 36.562194] X24: 0xffffffc00039bab0:
[ 36.565852] bab0 00000059 00000000 00000000 00000000 0906606e ffffff80 00000006 00000000
[ 36.568504] bad0 0039baf0 ffffffc0 00012900 00000006 00000000 00000000 00000000 00000001
[ 36.571202] baf0 0039bb90 ffffffc0 080ed46c ffffff80 0039bc10 ffffffc0 08c9f508 ffffff80
[ 36.573963] bb10 08f12000 ffffff80 00000000 00000000 790a1000 ffffffc0 09062850 ffffff80
[ 36.576765] bb30 000052f6 00000000 3d40cac5 00000000 000003e8 00000000 7707f000 00000040
[ 36.579629] bb50 00000000 00000000 00000000 00000000 00000001 00000000 00000000 00000000
[ 36.582425] bb70 00001000 00000000 00aaaaaa 00000000 00000008 00000000 ffffffff 00000000
[ 36.585221] bb90 78a72150 ffffffc0 094e0020 ffffff80 094e0020 ffffff80 00000000 00000000
[ 36.587993]
[ 36.587993] X25: 0xffffffc07ff591d0:
[ 36.592316] 91d0 ffffffff 00000000 ffffffff ffffffff 00000001 00000000 7ff591e8 ffffffc0
[ 36.595296] 91f0 7ff591e8 ffffffc0 7ff591f8 ffffffc0 7ff591f8 ffffffc0 0812a318 ffffff80
[ 36.598342] 9210 0039bcf8 ffffffc0 0039bc50 ffffffc0 00020002 00000000 00000000 00000000
[ 36.601451] 9230 00000000 00000000 00000009 00000000 00000003 00000000 003db400 ffffffc0
[ 36.604612] 9250 7ff59250 ffffffc0 7ff590c0 ffffffc0 00000000 00000000 651ae600 00000008
[ 36.607827] 9270 651ae600 00000008 0812b724 ffffff80 7ff58c80 ffffffc0 00000000 0000000b
[ 36.611012] 9290 0812b6f8 ffffff80 63746177 676f6468 0000312f 00000000 00000000 00000000
[ 36.614241] 92b0 00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[ 36.617425]
[ 36.617425] X26: 0xffffff8008eda1b8:
[ 36.622572] a1b8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.625972] a1d8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.629366] a1f8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.632758] a218 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.636151] a238 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.639543] a258 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.642841] a278 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.646115] a298 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.649295]
[ 36.649295] X27: 0xffffff8008f07688:
[ 36.654431] 7688 00000001 00000000 00000001 00000000 000003e8 00000000 7ff92a00 ffffffc0
[ 36.657825] 76a8 00000015 00000000 7ff929c0 ffffffc0 00000001 00000004 00000060 00000000
[ 36.661271] 76c8 00015000 00001000 00000001 00000000 7ff92a40 ffffffc0 7ff92a80 ffffffc0
[ 36.664792] 76e8 00000000 00000003 00000010 00000000 7ff928c0 ffffffc0 7ff3e000 ffffffc0
[ 36.668333] 7708 7706a000 00000040 7707f000 00000040 77094000 00000040 770a9000 00000040
[ 36.671929] 7728 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 36.675465] 7748 00000002 00000000 00003061 00000000 00010000 00000000 0007ffff 00000000
[ 36.678994] 7768 0000f084 00000000 00002000 00000000 00000000 0000fffa 00000000 00000000
[ 36.682452]
[ 36.682452] X29: 0xffffffc07ff56d80:
[ 36.688153] 6d80 00000000 00000000 00000000 00000000 0039bb30 ffffffc0 7ff59250 ffffffc0
[ 36.691831] 6da0 08eda238 ffffff80 08f07708 ffffff80 00000002 00000000 7ff56e00 ffffffc0
[ 36.695567] 6dc0 0812b8b4 ffffff80 7ff56e00 ffffffc0 0812b8b4 ffffff80 600001c5 00000000
[ 36.699366] 6de0 08f06708 ffffff80 00000003 00000000 00000000 00000080 79400028 ffffffc0
[ 36.703233] 6e00 7ff56e70 ffffffc0 081024e8 ffffff80 7ff59250 ffffffc0 7ff58c00 ffffffc0
[ 36.707165] 6e20 651ae75e 00000008 7ff58c80 ffffffc0 08ed4000 ffffff80 00000001 00000000
[ 36.711069] 6e40 0902a498 ffffff80 651ae75e 00000008 0812b724 ffffff80 00390000 ffffffc0
[ 36.715021] 6e60 7ff59250 ffffffc0 08f06708 ffffff80 7ff56ee0 ffffffc0 08102acc ffffff80
[ 36.718935]
[ 36.722078] —[ end trace 7304e17e2ddacdd4 ]—
[ 36.725525] Call trace:
[ 36.728747] Exception stack(0xffffffc07ff56c30 to 0xffffffc07ff56d60)
[ 36.732383] 6c20: ffffff8008eda000 0000008000000000
[ 36.736218] 6c40: ffffffc07ff56e00 ffffff800812b8b4 0000000000000026 0000000000000000
[ 36.740094] 6c60: ffffffc07ff56d00 ffffff80080ed46c ffffffc07ff56d80 ffffff8008ca70e7
[ 36.743953] 6c80: ffffff8008f06000 0000000000000000 0000000000000000 ffffffc00039bb30
[ 36.747779] 6ca0: ffffffc07ff59250 ffffff8008eda238 ffffff8008f07708 0000000000000002
[ 36.751649] 6cc0: ffffffc07ff56cf0 ffffff8008ed4000 0000000000000026 0000000000000001
[ 36.755460] 6ce0: 000000407707f000 000000407707f000 0000000000000000 0000000000000000
[ 36.759249] 6d00: 0000000000000001 0000000000000000 0000000000001000 0000000000aaaaaa
[ 36.763004] 6d20: 0000000000000008 00000000ffffffff ffffffc078a724c0 ffffff80094e06c0
[ 36.766754] 6d40: ffffff80094e06c0 0000000000000000 0000000000000000 0000000024eda1c5
[ 36.770514] [] watchdog_timer_fn+0x190/0x2e8
[ 36.774093] [] __hrtimer_run_queues+0x1bc/0x284
[ 36.777677] [] hrtimer_interrupt+0xac/0x1bc
[ 36.781221] [] arch_timer_handler_phys+0x38/0x50
[ 36.784771] [] handle_percpu_devid_irq+0xe8/0x178
[ 36.788337] [] generic_handle_irq+0x2c/0x44
[ 36.791801] [] __handle_domain_irq+0xb4/0xb8
[ 36.795323] [] gic_handle_irq+0x7c/0xc0
[ 36.798837] Exception stack(0xffffffc00039bb30 to 0xffffffc00039bc60)
[ 36.802536] bb20: 00000000000052f6 000000003d40cac5
[ 36.806473] bb40: 00000000000003e8 000000407707f000 0000000000000000 0000000000000000
[ 36.810471] bb60: 0000000000000001 0000000000000000 0000000000001000 0000000000aaaaaa
[ 36.814492] bb80: 0000000000000008 00000000ffffffff ffffffc078a72150 ffffff80094e0020
[ 36.818565] bba0: ffffff80094e0020 0000000000000000 0000000000000000 0000000024eda1c5
[ 36.822616] bbc0: 0000000000000005 0000000000005dc0 0000000000000000 0000000000005528
[ 36.826679] bbe0: 00000000000055f0 0000000000000053 0000000000418958 ffffff8008c9ac95
[ 36.830684] bc00: fffffffffffffffb 0000000000008000 ffffff8008e4a4c8 ffffffc00039bc60
[ 36.834694] bc20: ffffff800843ba48 ffffffc00039bc60 ffffff800843ba00 0000000080000045
[ 36.838689] bc40: ffffff800843ba48 ffffffc00039bc80 ffffffffffffffff 0000000020000045
[ 36.842681] [] el1_irq+0xb4/0x140
[ 36.846401] [] __delay+0x24/0x48
[ 36.850106] [] __const_udelay+0x24/0x2c
[ 36.853881] [] panic+0x238/0x23c
[ 36.857615] [] mount_block_root+0x244/0x2b0
[ 36.861387] [] mount_root+0x70/0x80
[ 36.865103] [] prepare_namespace+0x1a0/0x1b0
[ 36.868840] [] kernel_init_freeable+0x1f4/0x22c
[ 36.872586] [] kernel_init+0x18/0x100
[ 36.876214] [] ret_from_fork+0x10/0x20
好像找到原因了:不能用GPARTED 扩分区,空闲空间添加新分区然后挂载来用。
还是不行
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Serial Getty on ttyFIQ0.
[ OK ] Reached target Login Prompts.
Ubuntu 18.04.1 LTS Seafire ttyFIQ0
Seafire login: [ 48.845485] mmcblk0: error -110 transferring data, sector 2475160, nr 64, cmd response 0x900, card status 0x0
[ 49.979547] mmc0: card never left busy state
[ 49.982805] mmcblk0: error -110 sending status command, retrying
[ 49.984598] mmcblk0: error -110 sending status command, retrying
[ 49.986338] mmcblk0: error -110 sending status command, aborting
[ 49.987275] blk_update_request: I/O error, dev mmcblk0, sector 2475160
[ 49.988277] blk_update_request: I/O error, dev mmcblk0, sector 2475168
[ 49.989299] blk_update_request: I/O error, dev mmcblk0, sector 2475176
[ 49.990292] blk_update_request: I/O error, dev mmcblk0, sector 2475184
[ 49.991292] blk_update_request: I/O error, dev mmcblk0, sector 2475192
[ 49.992282] blk_update_request: I/O error, dev mmcblk0, sector 2475200
[ 49.993272] blk_update_request: I/O error, dev mmcblk0, sector 2475208
[ 49.994260] blk_update_request: I/O error, dev mmcblk0, sector 2475216
[ 49.997900] mmcblk0: error -110 sending status command, retrying
搞定:TF卡的问题。烧写的时候没问题,运行起来就会出问题,换了32G TF卡不仅快了,还稳定了
我还以为是cpu温度太高了呢?加了3个散热片呢?太挑sd了,我用16g的sd也这样,后面改成32g也正常了,我之前16g刷树莓派都正常
你好, 我的uboot起不来是怎么回事呢?
log显示 DRAM的大小都读取不到?
DDR3
786MHz
ddrconfig:6
ChipType = 0x11, 125
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=14910MB
FwPartOffset=2000 , 2000
SdmmcInit=0 2
StorageInit ok = 20770
Raw SecureMode = 0
LoadTrustBL
No find bl30.bin
No find bl32.bin
Load OK, addr=0x200000, size=0xa7fec
RunBL31 0x10000
INFO: SPSR = 0x3c9
U-Boot 2017.09-gc58a816-dirty (Oct 19 2018 - 00:39:34 +0800)
DRAM:
topillar 发表于 2018-9-27 07:00
还是不行[ OK ] Started Serial Getty on ttyS0.
error -110这个错误号意思是SD卡有问题,物理的那种,所以这是板子挑卡呢,多半某个脚电压有点问题
c01h 发表于 2018-10-19 10:25
我还以为是cpu温度太高了呢?加了3个散热片呢?太挑sd了,我用16g的sd也这样,后面改成32g也正常了,我之前 …
除了这个问题,这款板子真不错,运行很好。
