用firefly-rk3288的ubuntu版本烧录到rk3288 reload板子上,系统无法启动,但是hdmi无法输出图像,有如下打印:
[ OK ] Started Light Display Manager.
Starting Hostname Service…
[ OK ] Started Hostname Service.
[ OK ] Started Run Click system-level hooks.
[ 10.422652] [drm:dw_hdmi_rockchip_set_property] ERROR failed to set rockchip hdmi connector property
[ 10.432979] [drm:dw_hdmi_rockchip_set_property] ERROR failed to set rockchip hdmi connector property
[ 10.443289] [drm:dw_hdmi_rockchip_set_property] ERROR failed to set rockchip hdmi connector property
[ 10.453582] [drm:dw_hdmi_rockchip_set_property] ERROR failed to set rockchip hdmi connector property
[ 10.463885] [drm:dw_hdmi_rockchip_set_property] ERROR failed to set rockchip hdmi connector property
[ 10.474183] [drm:dw_hdmi_rockchip_set_property] ERROR failed to set rockchip hdmi connector property
你为啥要将firefly-rk3288的固件烧到reload上面。直接用reload 的ubuntu固件不行吗
http://www.t-firefly.com/doc/download/4.html
那个reload 的ubuntu固件百度网盘里是空的,在哪里可以下载到reload版本的ubuntu版本呢
http://www.t-firefly. …
现在可以去下载了。
leung先森 发表于 2018-10-16 14:39
现在可以去下载了。
恩,已经下载了,多谢
reload 与 firefly版有什么区别?我现在3328也遇到这个问题,failed to set rockchip hdmi connector property hue
