Firefly-RK3399 Android8.1 無法開機
安裝且編譯完之後燒入之後無法開機並自己進入燒入模式請大大支援
回報狀況如下
U-Boot 2014.10-RK3399-06 (Oct 28 2018 - 20:37:38)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
invalide header tag
ca head not found
#Boot ver: 2018-10-26#1.12
empty serial no.
reboot rockusb.
http://dev.t-firefly.com/thread-52783-1-1.html
工具没用对,看帖子里面说的
