3288 Andriod4.4运行没问题,Andriod5.1无法启动,请问是什么原因导致的
[ 6.620322] Rebooting in 5 seconds..DDR Version 1.00 20160530
SRX
Channel a: DDR3 200MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=8 Size=1024MB
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-10 (Nov 20 2017 - 17:19:35)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 20
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from boot image.
power key: bank-0 pin-5
No pmic detect.
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =1 vol=1100000,pwm_value=63
#Boot ver: 2017-11-20#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
got recovery cmd from misc.
Secure Boot state: 0
kernel @ 0x02000000 (0x006a77b0)
ramdisk @ 0x05bf0000 (0x002ad18c)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561c4d8 … OK
[ 0.000000] Linux version 3.10.0 (firefly@tchip-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #160 SMP PREEMPT Thu Mar 8 15:09:53 CST 2018
[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000
[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7cc00000
[ 0.000000] ion_reserve: cma reserved base 7cc00000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203)
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f1f000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),-@0x003BC000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2017-11-20_17:19:35
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1992216k/1992216k available, 104936k reserved, 1523712K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bb4b2c (11955 kB)
[ 0.000000] .init : 0xc0bb5000 - 0xc0c0e440 ( 358 kB)
[ 0.000000] .data : 0xc0c10000 - 0xc0da2d40 (1612 kB)
[ 0.000000] .bss : 0xc0da2d40 - 0xc0ec3bbc (1156 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:12
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:10
[ 0.497690] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.497704] pid_max: default: 32768 minimum: 301
[ 0.497822] Security Framework initialized
[ 0.497838] SELinux: Initializing.
[ 0.497913] Mount-cache hash table entries: 512
[ 0.498554] Initializing cgroup subsys debug
[ 0.498569] Initializing cgroup subsys memory
[ 0.498595] Initializing cgroup subsys freezer
[ 0.498624] CPU: Testing write buffer coherency: ok
[ 0.498932] /cpus/cpu@0 missing clock-frequency property
[ 0.498946] /cpus/cpu@1 missing clock-frequency property
[ 0.498955] /cpus/cpu@2 missing clock-frequency property
[ 0.498964] /cpus/cpu@3 missing clock-frequency property
[ 0.499012] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.499062] Setting up static identity map for 0xc085d580 - 0xc085d5d8
[ 0.502353] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x1849 (version 3.1)
[ 0.575829] CPU1: Booted secondary processor
[ 0.575861] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.595499] CPU2: Booted secondary processor
[ 0.595522] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.615208] CPU3: Booted secondary processor
[ 0.615231] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.615329] Brought up 4 CPUs
[ 0.615357] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.615365] CPU: All CPU(s) started in SVC mode.
[ 0.616090] devtmpfs: initialized
[ 0.620502] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.621591] pinctrl core: initialized pinctrl subsystem
[ 0.621838] regulator-dummy: no parameters
[ 0.636236] NET: Registered protocol family 16
[ 0.638062] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.638376] ion_snapshot: 0x1ea90000 map to 0xe0907000 and copy to 0xc0e9ee4c (version 0.1)
[ 0.638594] Registered FIQ tty driver
[ 0.638986] fiq-debugger is disabled in device tree
[ 0.639704] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.639726] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.639743] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.639760] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.639855] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.639922] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.639984] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.640046] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.640108] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.640170] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.640231] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.640293] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.640361] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.640425] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.640438] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.640449] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.640460] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.641094] rockchip_interrupts_register:bank_num=7
[ 0.643022] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 0.643042] of_get_gpio_init_config:gpio[1] = 136, value = 0
[ 0.643108] rockchip_pinctrl_probe:init ok
[ 0.650230] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.650319] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.650331] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.650504] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.650583] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.650596] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.650763] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.650836] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.650849] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.651021] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.651093] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.651105] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.651273] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.651350] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.651362] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.651537] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.651610] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.651623] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.651795] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.651874] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.651887] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.653681] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.653693] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.654310] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.654334] DDR DEBUG: version 1.00 20150126
[ 0.654362] DDR DEBUG: Channel a:
[ 0.654370] DDR DEBUG: DDR3 Device
[ 0.654384] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.654393] DDR DEBUG: Channel b:
[ 0.654400] DDR DEBUG: DDR3 Device
[ 0.654412] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.654422] DDR DEBUG: addr=0xdac000
[ 0.654431] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.654440] DDR DEBUG: socAddr[0]=0xdac000, socAddr[1]=0xdac100
[ 0.654449] DDR DEBUG: chAddr[0]=0xdac000, chAddr[1]=0xdac000
[ 0.654460] DDR DEBUG: dtar[0]=0x401b5000, dtar[1]=0x401b5000
[ 0.654514] DDR DEBUG: init success!!! freq=200MHz
[ 0.654522] DDR DEBUG: Channel a:
[ 0.654534] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.654546] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.654559] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.654571] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.654583] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.654591] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.654600] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.654608] DDR DEBUG: Channel b:
[ 0.654619] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.654631] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.654643] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.654655] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.654666] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.654675] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.654684] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.679199] bio: create slab at 0
[ 0.679692] Rockchip hdmi driver version 2.0
[ 0.679692] .
[ 0.680881] SCSI subsystem initialized
[ 0.681036] usbcore: registered new interface driver usbfs
[ 0.681082] usbcore: registered new interface driver hub
[ 0.681175] usbcore: registered new device driver usb
[ 0.685904] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.686373] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.686814] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.687063] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.688023] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.688147] media: Linux media interface: v0.10
[ 0.688193] Linux video capture interface: v2.00
[ 0.688249] pps_core: LinuxPPS API ver. 1 registered
[ 0.688259] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.688278] PTP clock support registered
[ 0.688337] i2c-core: driver [bq24296] using legacy suspend method
[ 0.688346] i2c-core: driver [bq24296] using legacy resume method
[ 0.688688] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[ 0.689370] ion_drm_heap_create: 0@0
[ 0.689498] Rockchip ion module is successfully loaded (v1.1)
[ 0.689656] Advanced Linux Sound Architecture Driver Initialized.
[ 0.690087] Bluetooth: Core ver 2.16
[ 0.690144] NET: Registered protocol family 31
[ 0.690153] Bluetooth: HCI device and connection manager initialized
[ 0.690169] Bluetooth: HCI socket layer initialized
[ 0.690182] Bluetooth: L2CAP socket layer initialized
[ 0.690208] Bluetooth: SCO socket layer initialized
[ 0.690434] cfg80211: Calling CRDA to update world regulatory domain
[ 0.691129] act8846_i2c_probe,line=898
[ 0.692576] act8846 set 0xf4 error!
[ 0.692661] act8846: probe of 0-005a failed with error -11
[ 0.697208] vdd_arm: 712 ↔ 1500 mV at 950 mV
[ 0.701910] vdd_gpu: 712 ↔ 1500 mV at 900 mV
[ 0.702656] rk808_i2c_probe,line=1355
[ 0.704018] The device is not rk808 -11
[ 0.704089] rk808: probe of 0-001b failed with error -11
[ 0.704166] i2c-core: driver [rk818] using legacy suspend method
[ 0.704176] i2c-core: driver [rk818] using legacy resume method
[ 0.705939] Switching to clocksource arch_sys_counter
[ 0.729864] rga: Module initialized.
[ 0.730560] rga2 ff920000.rga: rga ion client create success!
[ 0.730743] rga: Driver loaded succesfully
[ 0.730946] fb disp policy is box
[ 0.731010] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.731022] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.731364] rk-screen rk_screen.8: rockchip screen probe success
[ 0.731621] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.731998] rk32-edp ff970000.edp: screen is not edp!
[ 0.732017] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.732506] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.732734] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.733043] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.733212] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.733370] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.734096] rk3288-lcdc lcdc0: lcdc0: dclk:297000000>>fps:120
[ 0.734112] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.765095] alloc_buffer:ion_phy_addr=0x10000000
[ 0.777379] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.780523] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.794385] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaa7000
[ 0.794415] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.794675] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.794688] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.794957] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.795287] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.795452] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.795619] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.796391] unknow screen type: 0
[ 0.796406] vop ver:3007236,unsupport output color:1
[ 0.796469] rk3288-lcdc lcdc1: lcdc1: dclk:148500000>>fps:868
[ 0.796482] rk3288-lcdc lcdc1: wakeup from standby!
[ 0.800266] fb4:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.800280] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 0.801167] rockchip_set_mux:warning ignore bank num 15
[ 0.801292] rockchip_set_mux:warning ignore bank num 15
[ 0.801405] rockchip_set_mux:warning ignore bank num 15
[ 0.801529] rockchip_set_mux:warning ignore bank num 15
[ 0.801644] rockchip_set_mux:warning ignore bank num 15
[ 0.801762] rockchip_set_mux:warning ignore bank num 15
[ 0.801876] rockchip_set_mux:warning ignore bank num 15
[ 0.801997] rockchip_set_mux:warning ignore bank num 15
[ 0.802150] rockchip_set_mux:warning ignore bank num 15
[ 0.802276] rockchip_set_mux:warning ignore bank num 15
[ 0.803792] NET: Registered protocol family 2
[ 0.804497] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.804572] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.804645] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.804698] TCP: reno registered
[ 0.804712] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.804736] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.804929] NET: Registered protocol family 1
[ 0.805573] Unpacking initramfs…
[ 0.939862] Freeing initrd memory: 2740K (c5bf0000 - c5e9d000)
[ 0.940701] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.941275] vcodec_service: probe device ff9a0000.vpu_service
[ 0.941506] vcodec_service: No reset resource define
[ 0.941682] vcodec_service: ff9a0000.vpu_service: power on
[ 0.941793] vcodec_service: probe device ff9a0000.vpu_service
[ 0.941809] vcodec_service: checking hw id 4831
[ 0.942851] vcodec_service: ff9a0000.vpu_service: power off…
[ 0.942894] vcodec_service: done
[ 0.942904] vcodec_service: init success
[ 0.942967] vcodec_service: probe device ff9c0000.hevc_service
[ 0.943303] vcodec_service: ff9c0000.hevc_service: power on
[ 0.943364] vcodec_service: probe device ff9c0000.hevc_service
[ 0.943379] vcodec_service: checking hw id 6867
[ 0.943959] vcodec_service: ff9c0000.hevc_service: power off…
[ 0.943999] vcodec_service: done
[ 0.944007] vcodec_service: init success
[ 0.944146] rknandbase v1.0 2014-03-31
[ 0.944275] rknand: probe of ff400000.nandc failed with error -1
[ 0.944383] rknand_driver:ret = 0
[ 0.946289] audit: initializing netlink socket (disabled)
[ 0.946341] type=2000 audit(0.450:1): initialized
[ 0.947209] bounce pool size: 64 pages
[ 0.951939] fuse init (API version 7.22)
[ 0.952341] msgmni has been set to 952
[ 0.954194] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.954212] io scheduler noop registered
[ 0.954221] io scheduler deadline registered
[ 0.954317] io scheduler cfq registered (default)
[ 0.955589] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 0.956323] IEP Driver loaded succesfully
[ 0.956415] Module initialized.
[ 0.957214] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.957231] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.958604] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.958621] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.958929] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
[ 0.958943] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
[ 0.958952] pwm_regulator_probe:error
[ 0.958972] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
[ 0.959168] rk_serial.c v1.8 2014-03-04
[ 0.959403] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 0.959625] serial ff180000.serial: membase e0972000
[ 0.959796] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 0.959961] serial ff190000.serial: membase e097e000
[ 0.960098] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 0.961648] console [ttyS2] enabled
[ 0.961865] serial ff690000.serial: membase fed60000
[ 0.962045] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 0.962220] serial ff1b0000.serial: membase e41be000
[ 0.965020] loop: module loaded
[ 0.965383] zram: Created 1 device(s) …
[ 0.965470] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 0.965482] i2c-core: driver [mpu6050B1] using legacy resume method
[ 0.965500] mpu_init: Probe name mpu6050B1
[ 0.965656] ak8963_mod_init: Probe name ak8963_mod
[ 0.966358] SCSI Media Changer driver v0.25
[ 0.966610] dws->regs: e41e2000
[ 0.967762] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
[ 0.968053] tun: Universal TUN/TAP device driver, 1.6
[ 0.968065] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.968188] vmac_init.
[ 0.968757] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 0.968773] stmmac_probe_config_dt: clock input/output? (input).
[ 0.968786] stmmac_probe_config_dt: TX delay(0x1d).
[ 0.968798] stmmac_probe_config_dt: RX delay(0x16).
[ 0.968848] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 0.968859] stmmc_pltfr_init:
[ 0.968868] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 0.968891] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 0.968902] stmmc_pltfr_init: init for RGMII
[ 0.968913] tx delay=0x1d
[ 0.968913] rx delay=0x16
[ 0.968930] tx delay=0x1d
[ 0.968930] rx delay=0x16
[ 0.969390] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.969402] Normal descriptors
[ 0.969410] Ring mode enabled
[ 0.969422] DMA HW capability register supported
[ 0.969434] RX Checksum Offload Engine supported (type 2)
[ 0.969445] TX Checksum insertion supported
[ 0.969454] Wake-Up On Lan supported
[ 0.969494] Enable RX Mitigation via HW Watchdog Timer
[ 0.969965] PPP generic driver version 2.4.2
[ 0.970128] PPP BSD Compression module registered
[ 0.970141] PPP Deflate Compression module registered
[ 0.970164] PPP MPPE Compression module registered
[ 0.970177] NET: Registered protocol family 24
[ 0.970214] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.970227] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.970241] Rockchip WiFi SYS interface (V1.00) …
[ 0.970279] esp_mem_init enter date Oct 9 2017 16:20:34
[ 0.970290] esp_mem_init VERSION [V2.5]
[ 0.970336] esp_mem_init complete
[ 0.970421] usbcore: registered new interface driver catc
[ 0.970463] usbcore: registered new interface driver kaweth
[ 0.970478] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.970520] usbcore: registered new interface driver pegasus
[ 0.970577] usbcore: registered new interface driver rtl8150
[ 0.970625] usbcore: registered new interface driver r8152
[ 0.970637] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.970706] usbcore: registered new interface driver hso
[ 0.970749] usbcore: registered new interface driver asix
[ 0.970788] usbcore: registered new interface driver ax88179_178a
[ 0.970826] usbcore: registered new interface driver cdc_ether
[ 0.970863] usbcore: registered new interface driver cdc_eem
[ 0.970906] usbcore: registered new interface driver dm9601
[ 0.970946] usbcore: registered new interface driver dm9620
[ 0.970992] usbcore: registered new interface driver smsc75xx
[ 0.971037] usbcore: registered new interface driver smsc95xx
[ 0.971076] usbcore: registered new interface driver gl620a
[ 0.971114] usbcore: registered new interface driver net1080
[ 0.971157] usbcore: registered new interface driver plusb
[ 0.971197] usbcore: registered new interface driver rndis_host
[ 0.971236] usbcore: registered new interface driver cdc_subset
[ 0.971274] usbcore: registered new interface driver zaurus
[ 0.971314] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.971379] usbcore: registered new interface driver int51x1
[ 0.971418] usbcore: registered new interface driver kalmia
[ 0.971457] usbcore: registered new interface driver ipheth
[ 0.971504] usbcore: registered new interface driver sierra_net
[ 0.971545] usbcore: registered new interface driver cx82310_eth
[ 0.971591] usbcore: registered new interface driver cdc_ncm
[ 0.971630] usbcore: registered new interface driver qmi_wwan
[ 0.971705] usbcore: registered new interface driver cdc_mbim
[ 0.971720] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.974189] EHCI: ehci_rk_probe e4240000 e4240010
[ 0.974209] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 0.974238] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 0.974560] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 0.991376] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 0.991459] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.991476] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.991491] usb usb1: Product: EHCI Host Controller
[ 0.991504] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 0.991518] usb usb1: SerialNumber: ff500000.usb
[ 0.992006] hub 1-0:1.0: USB hub found
[ 0.992032] hub 1-0:1.0: 1 port detected
[ 0.992199] EHCI: ehci_rk_probe ok
[ 0.992314] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.992625] usbcore: registered new interface driver cdc_acm
[ 0.992638] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.992690] usbcore: registered new interface driver usblp
[ 0.992739] usbcore: registered new interface driver cdc_wdm
[ 0.992802] usbcore: registered new interface driver usb-storage
[ 0.992842] usbcore: registered new interface driver ums-alauda
[ 0.992881] usbcore: registered new interface driver ums-cypress
[ 0.992919] usbcore: registered new interface driver ums-datafab
[ 0.992957] usbcore: registered new interface driver ums_eneub6250
[ 0.992995] usbcore: registered new interface driver ums-freecom
[ 0.993034] usbcore: registered new interface driver ums-isd200
[ 0.993071] usbcore: registered new interface driver ums-jumpshot
[ 0.993113] usbcore: registered new interface driver ums-karma
[ 0.993154] usbcore: registered new interface driver ums-onetouch
[ 0.993193] usbcore: registered new interface driver ums-sddr09
[ 0.993232] usbcore: registered new interface driver ums-sddr55
[ 0.993275] usbcore: registered new interface driver ums-usbat
[ 0.993367] usbcore: registered new interface driver usbserial
[ 0.993412] usbcore: registered new interface driver usbserial_generic
[ 0.993445] usbserial: USB Serial support registered for generic
[ 0.993491] usbcore: registered new interface driver ch341
[ 0.993523] usbserial: USB Serial support registered for ch341-uart
[ 0.993564] usbcore: registered new interface driver cp210x
[ 0.993594] usbserial: USB Serial support registered for cp210x
[ 0.993639] usbcore: registered new interface driver option
[ 0.993670] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.993740] usbcore: registered new interface driver pl2303
[ 0.993772] usbserial: USB Serial support registered for pl2303
[ 0.993817] usbcore: registered new interface driver trancevibrator
[ 0.993831] usb20_otg: version 3.10a 21-DEC-2012
[ 0.994279] e4280040
[ 0.994293] Core Release: 3.10a
[ 0.994306] Setting default values for core params
[ 0.994437] Using Buffer DMA mode
[ 0.994449] Periodic Transfer Interrupt Enhancement - disabled
[ 0.994460] Multiprocessor Interrupt Enhancement - disabled
[ 0.994472] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.994483] ^^^^^^^^^^^^^^^^^Device Mode
[ 0.994497] Dedicated Tx FIFOs mode
[ 0.994518] pcd_init otg_dev = ddf1a180
[ 0.994691] usb20_otg ff580000.usb: DWC OTG Controller
[ 0.994721] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 0.994753] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 0.994814] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.994831] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.994845] usb usb2: Product: DWC OTG Controller
[ 0.994858] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.994871] usb usb2: SerialNumber: ff580000.usb
[ 0.995293] hub 2-0:1.0: USB hub found
[ 0.995317] hub 2-0:1.0: 1 port detected
[ 0.995625] usb20_host: version 3.10a 21-DEC-2012
[ 0.998161] e4300040
[ 0.998174] Core Release: 3.10a
[ 0.998184] Setting default values for core params
[ 0.998312] Using Buffer DMA mode
[ 0.998324] Periodic Transfer Interrupt Enhancement - disabled
[ 0.998334] Multiprocessor Interrupt Enhancement - disabled
[ 0.998347] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.998357] ^^^^^^^^^^^^^^^^^^Host Mode
[ 0.998388] usb20_host ff540000.usb: DWC OTG Controller
[ 0.998415] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 0.998444] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 0.998537] Init: Power Port (0)
[ 0.998594] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.998611] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.998625] usb usb3: Product: DWC OTG Controller
[ 0.998638] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.998651] usb usb3: SerialNumber: ff540000.usb
[ 0.999062] hub 3-0:1.0: USB hub found
[ 0.999085] hub 3-0:1.0: 1 port detected
[ 0.999817] usbcore: registered new interface driver xpad
[ 0.999875] usbcore: registered new interface driver usb_acecad
[ 0.999922] usbcore: registered new interface driver aiptek
[ 0.999968] usbcore: registered new interface driver gtco
[ 1.000024] usbcore: registered new interface driver hanwang
[ 1.000071] usbcore: registered new interface driver kbtab
[ 1.000129] usbcore: registered new interface driver wacom
[ 1.000255] ==gsl_ts_init==
[ 1.000302] ret=0
[ 1.000596] sensor_register_slave:mma8452,id=17
[ 1.000611] sensor_register_slave:gs_mc3230,id=23
[ 1.000621] gsensor_init
[ 1.000630] sensor_register_slave:mpu6880_acc,id=24
[ 1.000641] sensor_register_slave:mpu6500_acc,id=25
[ 1.000652] sensor_register_slave:cm3217,id=48
[ 1.000663] sensor_register_slave:cm3218,id=49
[ 1.000891] .. rk pwm remotectl v1.1 init
[ 1.001146] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 1.004490] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
[ 1.015072] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.016712] i2c /dev entries driver
[ 1.017385] IR NEC protocol handler initialized
[ 1.017398] IR RC5(x) protocol handler initialized
[ 1.017409] IR RC6 protocol handler initialized
[ 1.017419] IR JVC protocol handler initialized
[ 1.017429] IR Sony protocol handler initialized
[ 1.017439] IR RC5 (streamzap) protocol handler initialized
[ 1.017449] IR SANYO protocol handler initialized
[ 1.017460] IR MCE Keyboard/mouse protocol handler initialized
[ 1.017632] usbcore: registered new interface driver uvcvideo
[ 1.017644] USB Video Class driver (1.1.1)
[ 1.017657] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 1.019103] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 1.019127] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 1.019148] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 1.019169] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 1.019209] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 1.019209]
[ 1.019285] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.019442] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe41f8000 size: 0x4000)
[ 1.020081] D1:camsys_platform_probe(1446): ff910000.isp memory:
[ 1.020100] D1:camsys_platform_probe(1456): Register memory (phy: 0xff910000 vir: 0xe4220000 size: 0x10000)
[ 1.020116] D1:camsys_platform_probe(1451): I2c memory (phy: 0x1df26000 vir: 0xddf26000 size: 0x1000)
[ 1.020132] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.020144] D1:camsys_platform_probe(1471): Probe ff910000.isp device success
[ 1.020560] not find test_power_init dev node
[ 1.020617] i2c-core: driver [bq27320] using legacy suspend method
[ 1.020629] i2c-core: driver [bq27320] using legacy resume method
[ 1.020997] rockchip_temp_probe,line=364
[ 1.079944] tsadc ff280000.tsadc: initialized
[ 1.080318] device-mapper: uevent: version 1.0.3
[ 1.080564] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.080941] Bluetooth: HCI UART driver ver 2.2
[ 1.080957] Bluetooth: HCI H4 protocol initialized
[ 1.080968] Bluetooth: HCILL protocol initialized
[ 1.080980] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.080992] rtk_btusb: Register usb char device interface for BT driver
[ 1.081170] usbcore: registered new interface driver rtk_btusb
[ 1.081229] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
[ 1.081831] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
[ 1.083751] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.083949] cpuidle: using governor ladder
[ 1.083963] cpuidle: using governor menu
[ 1.084002] Synopsys Designware Multimedia Card Interface Driver
[ 1.084013] MHSC version = Ver 2.00 2015-06-10
[ 1.084315] dw cru_regsbase addr 0x1d8.
[ 1.084329] dw cru_reset_offset val 3.
[ 1.084344] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.084387] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.084699] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.084875] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.085008] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.099622] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.119331] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.120431] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.120450] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.120771] dw cru_regsbase addr 0x1d8.
[ 1.120784] dw cru_reset_offset val 0.
[ 1.120799] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.120846] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.122803] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.122926] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.122995] mmc1: no vmmc regulator found
[ 1.123093] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.123171] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.138970] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.151429] mmc0: BKOPS_EN bit is not set
[ 1.153309] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.155596] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.155618] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.155640] [mmc0] tuning regsbase addr 0x218.
[ 1.156498] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-282 (26 len)
[ 1.156510] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-282 (26 len)
[ 1.156520] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 147
[ 1.156564] mmc0: new HS200 MMC card at address 0001
[ 1.156832] mmcblk0: mmc0:0001 AGND3R 14.5 GiB
[ 1.156957] mmcblk0rpmb: mmc0:0001 AGND3R partition 3 4.00 MiB
[ 1.157284] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 1.157297] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.157306] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.157314] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.157323] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.157332] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.157341] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.157349] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.157357] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.157366] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.157375] system: 0x012400000 – 0x072400000 (1536 MB)
[ 1.157383] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 1.157391] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 1.157400] userdata: 0x077800000 – 0x3a3a00000 (12994 MB)
[ 1.157432] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14[ 1.158695] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.158710] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.159027] dw cru_regsbase addr 0x1d8.
[ 1.159035] dw cru_reset_offset val 1.
[ 1.159046] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.159084] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.159318] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.159450] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.159698] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.178331] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.198035] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.198058] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.198071] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.198355] leds-gpio leds.29: pins are not configured from the driver
[ 1.198585] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.200059] usbcore: registered new interface driver usbhid
[ 1.200069] usbhid: USB HID core driver
[ 1.200183] ashmem: initialized
[ 1.200302] logger: created 256K log ‘log_main’
[ 1.200393] logger: created 256K log ‘log_events’
[ 1.200484] logger: created 256K log ‘log_radio’
[ 1.200580] logger: created 256K log ‘log_system’
[ 1.201683] input: rk29-keypad as /devices/ff100000.adc/key.32/input/input1
[ 1.202532] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.202549] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.202561] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.202572] ES8323 2-0010: Error applying setting, reverse things back
[ 1.202626] jp es8323_line_det_gpio:-1
[ 1.218029] es8323 probe error
[ 1.218046] ES8323: probe of 2-0010 failed with error -11
[ 1.218829] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.219411] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
[ 1.219443] rockchip_es8323_audio_probe() register card failed:-517
[ 1.219456] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
[ 1.219624] u32 classifier
[ 1.219631] Actions configured
[ 1.219642] Netfilter messages via NETLINK v0.30.
[ 1.219701] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.219995] ctnetlink v0.93: registering with nfnetlink.
[ 1.220060] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.220068] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.220334] xt_time: kernel timezone is -0000
[ 1.220517] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.220640] arp_tables: (C) 2002 David S. Miller
[ 1.220677] TCP: cubic registered
[ 1.220684] Initializing XFRM netlink socket
[ 1.220875] NET: Registered protocol family 10
[ 1.221341] mip6: Mobile IPv6
[ 1.221368] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.221472] sit: IPv6 over IPv4 tunneling driver
[ 1.221772] NET: Registered protocol family 17
[ 1.221797] NET: Registered protocol family 15
[ 1.221846] Bridge firewalling registered
[ 1.221858] Ebtables v2.0 registered
[ 1.222004] Bluetooth: RFCOMM TTY layer initialized
[ 1.222029] Bluetooth: RFCOMM socket layer initialized
[ 1.222035] Bluetooth: RFCOMM ver 1.11
[ 1.222043] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.222049] Bluetooth: BNEP filters: protocol multicast
[ 1.222060] Bluetooth: BNEP socket layer initialized
[ 1.222067] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.222077] Bluetooth: HIDP socket layer initialized
[ 1.222101] l2tp_core: L2TP core driver, V2.0
[ 1.222114] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.222121] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.222318] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.222332] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 1.222340] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 1.222347] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.222356] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 1.222364] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.222383] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 1.222403] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 1.222410] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.222435] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 1.222442] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.222481] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.222600] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 1.222615] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 1.222628] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 1.222641] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 1.222654] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 1.222699] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.222790] [BT_RFKILL]: ** disable irq
[ 1.222865] [BT_RFKILL]: ap6335 device registered.
[ 1.223585] rk3288_init_suspend
[ 1.223596] rk3288_suspend_init enter
[ 1.223788] rk3288_suspend_init: pm_ctrbits =200007
[ 1.223817] gpio_get_dts_info suspend:4
[ 1.223823] gpio_get_dts_info resume:4
[ 1.223830] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.223855] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.223986] clks_gating_suspend_init:clkgt info ok
[ 1.224077] Registering SWP/SWPB emulation handler
[ 1.224088] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
[ 1.226320] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
[ 1.226721] ddrfreq: verion 1.2 20140526
[ 1.226735] ddrfreq: normal 528MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 528MHz
[ 1.226743] ddrfreq: auto-freq=0
[ 1.226748] ddrfreq: auto-freq-table[0] 240MHz
[ 1.226754] ddrfreq: auto-freq-table[1] 324MHz
[ 1.226759] ddrfreq: auto-freq-table[2] 456MHz
[ 1.226765] ddrfreq: auto-freq-table[3] 528MHz
[ 1.227312] Unable to handle kernel paging request at virtual address fffffe2b
[ 2.969279] EHCI: rk_ehci_hcd_enable, disable host controller
[ 4.798111] pgd = c0004000
[ 4.800764] [fffffe2b] *pgd=1eff6821, *pte=00000000, *ppte=00000000
[ 4.806846] Internal error: Oops: 17 [#1] PREEMPT SMP ARM
[ 4.812127] Modules linked in:
[ 4.815117] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #160
[ 4.821084] task: de890000 ti: de872000 task.ti: de872000
[ 4.826382] PC is at regulator_set_voltage+0x8/0xe0
[ 4.831152] LR is at vga_edid_probe+0x4c/0x380
[ 4.835497] pc : [] lr : [] psr: a0000113
[ 4.835497] sp : de873e38 ip : 00000000 fp : 00000000
[ 4.846750] r10: c0bb55f0 r9 : c0c0a09c r8 : c02dfaac
[ 4.851867] r7 : c1f0fc88 r6 : de004e00 r5 : 00000000 r4 : fffffdfb
[ 4.858264] r3 : 00000000 r2 : 001b7740 r1 : 001b7740 r0 : fffffdfb
[ 4.864662] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 4.871824] Control: 10c5387d Table: 0000406a DAC: 00000015
[ 4.877451]
[ 4.877451] PC: 0xc02ea988:
[ 4.881627] a988 e3530000 1a000002 e5962018 e3520000 0a000013 e58d3000 e1a00004 e5963018
[ 4.889643] a9a8 e1a0100d e28d2004 e58d3004 ebfffa2a e2506000 ba00000b e1a00004 e1a0100d
[ 4.897659] a9c8 e28d2004 ebffffb9 e2506000 ba000005 e1a00004 e89d0006 ebfffc02 e1a06000
[ 4.905676] a9e8 ea000000 e3e06015 e1a00005 eb15c127 e1a00006 e8bd807c e92d45f7 e1a04000
[ 4.913692] aa08 e5905030 e58d2000 e2856038 e58d1004 e1a00006 eb15c1b4 e5942014 e59d3004
[ 4.921708] aa28 e1520003 1a000004 e5942018 e59d3000 e1520003 03a0a000 0a000022 e5953000
[ 4.929724] aa48 e5933014 e5932004 e3520000 1a000003 e593300c e3530000 03e0a015 0a000019
[ 4.937741] aa68 e1a00005 e28d1004 e1a0200d ebfff9fa e250a000 ba000013 e59d3004 e1a00005
[ 4.945759]
[ 4.945759] LR: 0xc02dfa78:
[ 4.949936] fa78 e1a01005 e1a03000 e3a00004 ebf5c203 ea000001 e59f0014 eb1587a5 e1a00004
[ 4.957952] fa98 e8bd81f0 c0e7dfac c02dfebc c004f938 c0a9040b e92d41ff e1a06000 e590715c
[ 4.965969] fab8 e5900018 e5903008 e5933008 e12fff33 e3100001 03e05012 0a0000b0 e3a00000
[ 4.973985] fad8 e59f12c4 eb002a08 e2504000 059f02bc 0a000007 e59f12b8 e1a02001 eb002bc1
[ 4.982001] faf8 e1a00004 eb002cbc e3500000 159f02a4 059f02a4 e59f12a4 eb158785 e3a00000
[ 4.990018] fb18 e59f129c eb0029f8 e2504000 059f0294 0a000007 e59f1290 e1a02001 eb002bb1
[ 4.998034] fb38 e1a00004 eb002cac e3500000 159f027c 059f027c e59f1264 eb158775 e3a00000
[ 5.006050] fb58 e59f1270 eb0029e8 e2504000 059f0268 0a000007 e59f1264 e1a02001 eb002ba1
[ 5.014068]
[ 5.014068] SP: 0xde873db8:
[ 5.018245] 3db8 c0285044 c0e85c4c 00000000 00000001 c0e85c64 00000000 000003e0 00000000
[ 5.026262] 3dd8 00000020 c02eaa08 a0000113 ffffffff de873e24 c000d598 fffffdfb 001b7740
[ 5.034278] 3df8 001b7740 00000000 fffffdfb 00000000 de004e00 c1f0fc88 c02dfaac c0c0a09c
[ 5.042294] 3e18 c0bb55f0 00000000 00000000 de873e38 c02dfaf8 c02eaa08 a0000113 ffffffff
[ 5.050311] 3e38 fffffdfb 001b7740 001b7740 fffffdfb 00000000 de004e00 c1f0fc88 c02dfaac
[ 5.058327] 3e58 c0bb55f0 c02dfaf8 de004e00 00000000 00000065 00000000 de004e20 00000000
[ 5.066343] 3e78 de004e04 de004e00 c02dfaac c05290b0 00000000 de004e20 00000000 c0c4ddc0
[ 5.074360] 3e98 c0da3000 c0309f54 de004e20 c0c4ddc0 c0c4ddc0 00000000 c0da3000 c030a1b0
[ 5.082377]
[ 5.082377] R0: 0xfffffd7b:
[ 5.086554] fd78 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.094571] fd98 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.102587] fdb8 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.110603] fdd8 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.118620] fdf8 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.126636] fe18 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.134653] fe38 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.142669] fe58 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.150685] fe78 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.158703]
[ 5.158703] R4: 0xfffffd7b:
[ 5.162880] fd78 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.170897] fd98 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.178913] fdb8 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.186929] fdd8 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.194946] fdf8 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.202962] fe18 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.210978] fe38 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.218994] fe58 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.227011] fe78 ******** ******** ******** ******** ******** ******** ******** ********
[ 5.235028]
[ 5.235028] R6: 0xde004d80:
[ 5.239206] 4d80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.247222] 4da0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.255238] 4dc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.263255] 4de0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.271271] 4e00 00500000 5f616776 00636464 00000000 00000000 00000000 de010858 c0c4dd9c
[ 5.279287] 4e20 de010880 deb5ef00 deb64ec0 de00500c de004c2c de010888 de981340 c0cd2880
[ 5.287304] 4e40 deb64e80 00000003 00000007 00000000 c0d29ee4 00000000 00000000 de004e5c
[ 5.295320] 4e60 de004e5c de890000 00000000 c0d29f2c c0c4ddc0 00000000 00000000 00000020
[ 5.303337]
[ 5.303337] R7: 0xc1f0fc08:
[ 5.307515] fc08 00000000 00000000 c5618865 00000004 c561408c c1f0fc44 00000000 00000000
[ 5.315531] fc28 c5618865 00000124 00000004 00000000 c05fed00 00000000 00000000 c0ae83d2
[ 5.323548] fc48 0000000d c1f0fc78 00000000 00000000 00000000 c0ae83d2 00000124 0000000d
[ 5.331564] fc68 00000000 c05fed00 00000000 00000000 30316b72 635f3030 6365646f 00000000
[ 5.339580] fc88 c1f0fe68 c0af47b1 00000000 c1f0fce0 c1f0fcfc 00000000 c1f0f40c 00000000
[ 5.347596] fca8 00000000 00000000 c1f0fe70 dea74b80 c1f0fea0 c1f0fa90 c1f0f438 dea1b840
[ 5.355613] fcc8 c0d79acc dea74c00 00000001 00000003 00000008 00000000 6332692f 31666640
[ 5.363629] fce8 30303036 67762f30 64645f61 30354063 00000000 c561874b 00000010 c56140b0
[ 5.371647]
[ 5.371647] R8: 0xc02dfa2c:
[ 5.375824] fa2c e3a02000 e5843004 e2840010 e5843008 e3a01002 e59f3058 e584300c e1a03002
[ 5.383841] fa4c ebf59271 e59f304c e5844024 e1a00008 e584504c e5843020 e5847050 e5846054
[ 5.391857] fa6c e5955030 ebf57535 e1a02004 e1a01005 e1a03000 e3a00004 ebf5c203 ea000001
[ 5.399873] fa8c e59f0014 eb1587a5 e1a00004 e8bd81f0 c0e7dfac c02dfebc c004f938 c0a9040b
[ 5.407889] faac e92d41ff e1a06000 e590715c e5900018 e5903008 e5933008 e12fff33 e3100001
[ 5.415906] facc 03e05012 0a0000b0 e3a00000 e59f12c4 eb002a08 e2504000 059f02bc 0a000007
[ 5.423922] faec e59f12b8 e1a02001 eb002bc1 e1a00004 eb002cbc e3500000 159f02a4 059f02a4
[ 5.431939] fb0c e59f12a4 eb158785 e3a00000 e59f129c eb0029f8 e2504000 059f0294 0a000007
[ 5.439956]
[ 5.439956] R9: 0xc0c0a01c:
[ 5.444134] a01c c0be1890 c0be18a0 c0be18b0 c0be18c0 c0be18d0 c0be18e0 c0be18f0 c0be1900
[ 5.452150] a03c c0be1910 c0be1920 c0be1930 c0be1940 c0be1950 c0be1960 c0bb7764 c0bb8ee0
[ 5.460166] a05c c0bbc2ac c0bbc498 c0029198 c0bbe7f0 c00367c4 c0bbeffc c0bc10f0 c0bc272c
[ 5.468183] a07c c0bc278c c0bc28b0 c0bc2914 c0bc49f4 c0bc6d78 c0bca8a0 c0bda6d4 c0bdb644
[ 5.476199] a09c c0bdb87c c0309cd8 c03aceb0 c042aeb4 c045dee4 c0be0594 c0be0a94 c0be0b40
[ 5.484215] a0bc c0be5610 c0be5810 c0be7570 c0be8dcc c0bec10c c0bec190 c0bee878 c0bdca14
[ 5.492232] a0dc c0610508 c0be8364 c0be8df0 c0be9070 c0bd6ba4 37303730 30303130 32303030
[ 5.500248] a0fc 30303144 31343030 30304445 30303030 30303030 30303030 30303030 30303030
[ 5.508265]
[ 5.508265] R10: 0xc0bb5570:
[ 5.512528] 5570 e5941000 ebd27bb5 e3500000 1a000009 e1a00005 e59f1058 ebdb2dcd e3500000
[ 5.520544] 5590 1a00000c e5940000 e59f1048 ebdb2dc8 e3500000 1a000007 e5943004 e1a00007
[ 5.528561] 55b0 e12fff33 e3500000 0a000002 e59f0028 e1a01005 ebf230d8 e284400c e1540006
[ 5.536577] 55d0 3affffe2 e3a00000 e8bd80f8 c0c08d80 c0c09290 c0a59050 c0a58ed3 c0a58edc
[ 5.544593] 55f0 e92d4038 e2515000 e1a04000 0a000014 ebdb2dec e2803001 e0843003 e1550003
[ 5.552610] 5610 03a0303d 05453001 0a00000d e2800002 e0844000 e1550004 1a000008 e3a0303d
[ 5.560626] 5630 e1a00005 e5453002 ebdb2dde e1a01005 e2802001 e2450001 ebdb0cc0 ea000000
[ 5.568642] 5650 e7f001f2 e3a00000 e8bd8038 e92d45f8 e1a04000 e1a06001 ebffffe0 e1a00004
[ 5.576663] Process swapper/0 (pid: 1, stack limit = 0xde872238)
[ 5.582547] Stack: (0xde873e38 to 0xde874000)
[ 5.586812] 3e20: fffffdfb 001b7740
[ 5.594832] 3e40: 001b7740 fffffdfb 00000000 de004e00 c1f0fc88 c02dfaac c0bb55f0 c02dfaf8
[ 5.602848] 3e60: de004e00 00000000 00000065 00000000 de004e20 00000000 de004e04 de004e00
[ 5.610864] 3e80: c02dfaac c05290b0 00000000 de004e20 00000000 c0c4ddc0 c0da3000 c0309f54
[ 5.618881] 3ea0: de004e20 c0c4ddc0 c0c4ddc0 00000000 c0da3000 c030a1b0 00000000 de004e20
[ 5.626897] 3ec0: de004e54 c030a228 c0c4ddc0 de873ed8 c030a1c8 c03089f0 de9d755c deb5ef34
[ 5.634913] 3ee0: c0c4ddc0 c0c4ddc0 c581c880 c0d29f2c 00000000 c03097a4 c0a90595 c0a90596
[ 5.642930] 3f00: c0c4ddc0 c0bdb644 de872000 00000000 c0da3000 c030a714 c0d29f2c c0c4dd9c
[ 5.650945] 3f20: c0bdb644 de872000 00000000 c0da3000 c0bb55f0 c052adec 00000000 00000007
[ 5.658962] 3f40: c0bdb644 c00086a4 c0bdb644 00000004 00000007 c0c02d7c c0c02d5c c0da3000
[ 5.666978] 3f60: 00000201 c0bb5b28 00000007 00000007 c0bb55f0 00000000 c0c092dc c0c092dc
[ 5.674994] 3f80: 00000000 00000000 00000000 00000000 00000000 c0bb5be8 de872000 00000000
[ 5.683010] 3fa0: c083b58c c083b594 00000000 c000da98 00000000 00000000 00000000 00000000
[ 5.691026] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.699043] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 ffffffff ff7fffff
[ 5.707081] [] (regulator_set_voltage+0x8/0xe0) from [] (vga_edid_probe+0x4c/0x380)
[ 5.716279] [] (vga_edid_probe+0x4c/0x380) from [] (i2c_device_probe+0xa8/0xd4)
[ 5.725150] [] (i2c_device_probe+0xa8/0xd4) from [] (really_probe+0xa8/0x20c)
[ 5.733844] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 5.742798] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 5.751922] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 5.760791] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 5.769660] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 5.778530] [] (driver_register+0x9c/0x138) from [] (i2c_register_driver+0x40/0xac)
[ 5.787741] [] (i2c_register_driver+0x40/0xac) from [] (do_one_initcall+0x34/0xc8)
[ 5.796871] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 5.805394] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 5.814436] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 5.823305] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 5.831485] Code: e1a00006 e8bd807c e92d45f7 e1a04000 (e5905030)
[ 5.837576] —[ end trace fa61b599e194fbe6 ]—
[ 5.842073] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 5.842073]
[ 5.850992] CPU0: stopping
[ 5.853634] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 3.10.0 #160
[ 5.860554] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 5.868904] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
[ 5.877004] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 5.885447] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 5.893627] Exception stack(0xc0c11f08 to 0xc0c11f50)
[ 5.898577] 1f00: c0c11f50 00000005 442b7d35 00000001 c1f212e0 00000000
[ 5.906594] 1f20: 441bef46 00000001 c0c22fd8 c0c10000 c0c22fe8 00000000 00000000 c0c11f50
[ 5.914608] 1f40: c00798fc c05b9d00 60000113 ffffffff
[ 5.919564] [] (__irq_svc+0x40/0x70) from [] (cpuidle_enter_state+0x54/0xec)
[ 5.928175] [] (cpuidle_enter_state+0x54/0xec) from [] (cpuidle_idle_call+0x16c/0x27c)
[ 5.937639] [] (cpuidle_idle_call+0x16c/0x27c) from [] (arch_cpu_idle+0x8/0x38)
[ 5.946512] [] (arch_cpu_idle+0x8/0x38) from [] (cpu_idle_loop+0x1b8/0x224)
[ 5.955037] [] (cpu_idle_loop+0x1b8/0x224) from [] (freezing_slow_path+0x0/0x80)
[ 5.963989] [] (freezing_slow_path+0x0/0x80) from [] (0xffffffff)
[ 5.971660] CPU2: stopping
[ 5.974305] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 3.10.0 #160
[ 5.981220] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 5.989574] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
[ 5.997674] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 6.006118] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 6.014299] Exception stack(0xde8bff30 to 0xde8bff78)
[ 6.019247] ff20: de8bff78 00000005 442b7e59 00000001
[ 6.027265] ff40: c1f332e0 00000000 427758b4 00000001 c0c22fd8 de8be000 c0c22fe8 00000000
[ 6.035280] ff60: 00000000 de8bff78 c00798fc c05b9d00 60000113 ffffffff
[ 6.041766] [] (__irq_svc+0x40/0x70) from [] (cpuidle_enter_state+0x54/0xec)
[ 6.050379] [] (cpuidle_enter_state+0x54/0xec) from [] (cpuidle_idle_call+0x16c/0x27c)
[ 6.059845] [] (cpuidle_idle_call+0x16c/0x27c) from [] (arch_cpu_idle+0x8/0x38)
[ 6.068714] [] (arch_cpu_idle+0x8/0x38) from [] (cpu_idle_loop+0x1b8/0x224)
[ 6.077241] [] (cpu_idle_loop+0x1b8/0x224) from [] (freezing_slow_path+0x0/0x80)
[ 6.086191] CPU3: stopping
[ 6.088836] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 3.10.0 #160
[ 6.095751] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 6.104105] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
[ 6.112206] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 6.120648] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 6.128830] Exception stack(0xde8c1f30 to 0xde8c1f78)
[ 6.133778] 1f20: de8c1f78 00000005 442b7d35 00000001
[ 6.141796] 1f40: c1f3c2e0 00000000 4373da77 00000001 c0c22fd8 de8c0000 c0c22fe8 00000000
[ 6.149811] 1f60: 00000000 de8c1f78 c00798fc c05b9d00 60000113 ffffffff
[ 6.156296] [] (__irq_svc+0x40/0x70) from [] (cpuidle_enter_state+0x54/0xec)
[ 6.164909] [] (cpuidle_enter_state+0x54/0xec) from [] (cpuidle_idle_call+0x16c/0x27c)
[ 6.174375] [] (cpuidle_idle_call+0x16c/0x27c) from [] (arch_cpu_idle+0x8/0x38)
[ 6.183245] [] (arch_cpu_idle+0x8/0x38) from [] (cpu_idle_loop+0x1b8/0x224)
[ 6.191772] [] (cpu_idle_loop+0x1b8/0x224) from [] (freezing_slow_path+0x0/0x80)
[ 6.200722] CRU:
[ 6.202521] 00000000: 00000001 9fff0043 0fff0022 00000008 00000005 9fff0031 0fff0018 00000008
[ 6.210875] 00000020: 00000103 9fff007f 0fff0040 00000008 00000007 9fff00c5 0fff0014 00000008
[ 6.219232] 00000040: 00000b00 1fff0270 0fff0138 0000000a 00001111 00000000 00000000 00000000
[ 6.227589] 00000060: 00004031 0000b108 00000003 00000200 00008100 00008100 00008585 00010014
[ 6.235946] 00000080: 01885091 01885091 0000a101 00002745 00004345 00008a00 00000200 00000200
[ 6.244304] 000000a0: 00000200 0bb8ea60 00010014 00010014 00010014 00000910 00000900 001f05dc
[ 6.252661] 000000c0: 00001703 0000078c 00000e40 00000101 00000542 00000342 00004141 00004040
[ 6.261018] 000000e0: 00004141 00000505 00008042 00008f8f 00000000 00000631 00001ee5 00008307
[ 6.269376] 00000100: 00001200 00010014 00004141 00000000 00000000 00000000 00000000 00000000
[ 6.277732] 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.286090] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.294448] 00000160: 00000000 00000000 00000100 00000800 00000000 00000000 0000eb00 00000092
[ 6.302805] 00000180: 00000000 00000000 0000000c 00000000 00000000 0000e010 00000000 00000000
[ 6.311162] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.319520] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.327877] 000001e0: 00000000 00000000 00000000 00640064 00000004 00000000 00000002 00000000
[ 6.336235] 00000200: 00000002 00000000 00000002 00000000 00000002 00000000 00000004 00000471
[ 6.344592] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.352949] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.361307] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.369664] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.378021] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.386379] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.394737] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.403094] 00000300: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.411452] 00000320: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.419809] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.428166] 00000360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.436524] 00000380: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.444881] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.453239] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.461596] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.469954] 00000400: 00000001 9fff0043 0fff0022 00000008 00000005 9fff0031 0fff0018 00000008
[ 6.478308] Rebooting in 5 seconds..
VGA硬件应该问题
问题还解决了啊?遇到同样的问题
