安卓启动不了
安卓启动时一直停留在开机动画页面,无法进入系统桌面,日志如下:
U-Boot 2014.10-RK3399-06 (Sep 28 2018 - 11:20:58)
CPU: rk3399
cpu version = 0
CPU's clock information:
    aplll = 816000000HZ
    apllb = 24000000HZ
    gpll = 800000000HZ
               aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
    cpll = 800000000HZ
    dpll = 800000000HZ
    vpll = 24000000HZ
    npll = 24000000HZ
    ppll = 676000000HZ
Board:	Rockchip platform Board
Uboot as second level loader
DRAM:  Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can't find dts node for fixed
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can't find dts node for pwm1
    aplll = 816000000HZ
    apllb = 24000000HZ
    gpll = 800000000HZ
    cpll = 800000000HZ
    dpll = 800000000HZ
    vpll = 24000000HZ
    npll = 24000000HZ
    ppll = 676000000HZ
#Boot ver: 2018-09-28#1.09
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
failed to find phy node
no fuel gauge found
Using display timing dts
Detailed mode clock 83000 kHz, flags[a]
    H: 1280 1352 1480 1680
    V: 0800 0803 0809 0831
bus_format: 100e
rk lcdc - 0 dclk set: dclk = 83000000HZ, pll select = 1, div = 1
force target_mbps=498
final DSI-Link bandwidth: 498 Mbps x 4
failed to wait for phy clk lane stop state
failed to display kernel logo
checkKey
vbus = 0
Hit any key to stop autoboot:  0
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel   @ 0x00280000 (0x01227008)
ramdisk  @ 0x04bf0000 (0x001adc34)
bootrk: do_bootm_linux...
   Loading Device Tree to 0000000004600000, end 00000000046171e8 ... OK
Add bank:000000000a200000, 0000000075e00000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Initializing cgroup subsys schedtune
[    0.000000] Linux version 4.4.103 (root@YCWDZ) (gcc version 4.9 20150123 (prerelease) (GCC) ) #13 SMP PREEMPT Sat Sep 22 09:57:38 CST 2018
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] hdmi init vic is -1
[    0.000000] Reserved memory: failed to reserve memory for node 'stb-devinfo@00000000': base 0x0000000000000000, size 0 MiB
[    0.000000] cma: Reserved 16 MiB at 0x000000007f000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eef5000 s45504 r8192 d32320 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 507912
[    0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00300000@0x000B4000(system),0x00008000@0x003B4000(metadata),0x00002000@0x003BC000(baseparamer),-@0x003BE000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2018-09-28_11:20:58 hdmi.vic=-1 SecureBootCheckOk=0
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] software IO TLB [mem 0x7eead000-0x7eeed000] (0MB) mapped at [ffffffc07eead000-ffffffc07eeecfff]
[    0.000000] Memory: 1986268K/2064384K available (10878K kernel code, 1628K rwdata, 5208K rodata, 832K init, 1071K bss, 61732K reserved, 16384K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000]       .init : 0xffffff8009040000 - 0xffffff8009110000   (   832 KB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008b20000   ( 10880 KB)
[    0.000000]     .rodata : 0xffffff8008b20000 - 0xffffff8009040000   (  5248 KB)
[    0.000000]       .data : 0xffffff8009110000 - 0xffffff80092a7008   (  1629 KB)
[    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
[    0.000000]               0xffffffbdc0008000 - 0xffffffbdc2000000   (    31 MB actual)
[    0.000000]     fixed   : 0xffffffbffe7fd000 - 0xffffffbffec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc080000000   (  2046 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[    0.000000] ITS: allocated 65536 Devices @a200000 (psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x000000000a280000
[    0.000000] ITS: Allocated 1792 chunks for LPIs
[    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] CPU0: using LPI pending table @0x000000000a290000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[    0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.010012] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.021296] pid_max: default: 32768 minimum: 301
[    0.026452] Security Framework initialized
[    0.030956] SELinux:  Initializing.
[    0.034871] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.042237] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.050834] Initializing cgroup subsys freezer
[    0.055733] Initializing cgroup subsys debug
[    0.061349] sched-energy: Sched-energy-costs installed from DT
[    0.067773] CPU0: update cpu_capacity 401
[    0.072224] ASID allocator initialised with 65536 entries
[    0.095028] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.105114] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.128780] Detected VIPT I-cache on CPU1
[    0.128812] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.128846] CPU1: using LPI pending table @0x000000000a3f0000
[    0.128890] CPU1: update cpu_capacity 401
[    0.128893] CPU1: Booted secondary processor [410fd034]
[    0.138776] Detected VIPT I-cache on CPU2
[    0.138795] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.138828] CPU2: using LPI pending table @0x000000007bc20000
[    0.138855] CPU2: update cpu_capacity 401
[    0.138858] CPU2: Booted secondary processor [410fd034]
[    0.148815] Detected VIPT I-cache on CPU3
[    0.148834] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.148867] CPU3: using LPI pending table @0x000000007bc60000
[    0.148894] CPU3: update cpu_capacity 401
[    0.148897] CPU3: Booted secondary processor [410fd034]
[    0.158862] Detected PIPT I-cache on CPU4
[    0.158890] CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.158930] CPU4: using LPI pending table @0x000000007bca0000
[    0.158971] CPU4: update cpu_capacity 1024
[    0.158974] CPU4: Booted secondary processor [410fd082]
[    0.168885] Detected PIPT I-cache on CPU5
[    0.168902] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.168939] CPU5: using LPI pending table @0x000000007bce0000
[    0.168966] CPU5: update cpu_capacity 1024
[    0.168969] CPU5: Booted secondary processor [410fd082]
[    0.169054] Brought up 6 CPUs
[    0.311509] SMP: Total of 6 processors activated.
[    0.316670] CPU features: detected feature: GIC system register CPU interface
[    0.324514] CPU: All CPU(s) started at EL2
[    0.329052] alternatives: patching kernel code
[    0.336473] devtmpfs: initialized
[    0.355082] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.365826] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.373407] pinctrl core: initialized pinctrl subsystem
[    0.380745] Failed to find legacy iommu devices
[    0.386104] NET: Registered protocol family 16
[    0.391353] schedtune: init normalization constants...
[    0.397011] schedtune: CLUSTER[0-3]      min_pwr:    56 max_pwr:   222
[    0.404194] schedtune: CPU[0]            min_pwr:     0 max_pwr:   222
[    0.411372] schedtune: CPU[1]            min_pwr:     0 max_pwr:   222
[    0.418552] schedtune: CPU[2]            min_pwr:     0 max_pwr:   222
[    0.425730] schedtune: CPU[3]            min_pwr:     0 max_pwr:   222
[    0.432911] schedtune: CLUSTER[4-5]      min_pwr:    65 max_pwr:  1108
[    0.440088] schedtune: CPU[4]            min_pwr:     0 max_pwr:  1108
[    0.447266] schedtune: CPU[5]            min_pwr:     0 max_pwr:  1108
[    0.454444] schedtune: SYSTEM            min_pwr:   121 max_pwr:  4434
[    0.461622] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[    0.470041] schedtune: verify normalization constants...
[    0.475880] schedtune: max_pwr/2^0: 4313 => norm_pwr:  1024
[    0.482016] schedtune: max_pwr/2^1: 2156 => norm_pwr:   511
[    0.488144] schedtune: max_pwr/2^2: 1078 => norm_pwr:   255
[    0.494271] schedtune: max_pwr/2^3:  539 => norm_pwr:   127
[    0.500399] schedtune: max_pwr/2^4:  269 => norm_pwr:    63
[    0.506527] schedtune: max_pwr/2^5:  134 => norm_pwr:    31
[    0.512653] schedtune: configured to support 5 boost groups
[    0.532149] cpuidle: using governor ladder
[    0.546688] cpuidle: using governor menu
[    0.551016] Registered FIQ tty driver
[    0.555374] vdso: 2 pages (1 code @ ffffff8008b26000, 1 data @ ffffff8009114000)
[    0.563532] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.571704] DMA: preallocated 256 KiB pool for atomic allocations
[    0.599144] console [pstore0] enabled
[    0.603345] pstore: Registered ramoops as persistent store backend
[    0.610152] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[    0.618386] sip_fiq_debugger_uart_irq_tf_init error: -2
[    0.624145] fiq debugger bind fiq to trustzone failed: -2
[[    0.630352] console [ttyFIQ0] enabled
[[    0.638040] bootconsole [uart0] disabled
[    0.646424] Registered fiq debugger ttyFIQ0
[    0.677262] Rockchip hdmi driver version 2.0
[    0.679539] iommu: Adding device ff650000.vpu_service to group 0
[    0.679610] iommu: Adding device ff660000.rkvdec to group 1
[    0.679697] iommu: Adding device ff670000.iep to group 2
[    0.679796] iommu: Adding device ff8f0000.vop to group 3
[    0.679877] iommu: Adding device ff900000.vop to group 4
[    0.679986] iommu: Adding device ff910000.isp to group 5
[    0.680062] iommu: Adding device ff920000.isp to group 6
[    0.680748] rk_iommu ff670800.iommu: can't get aclk
[    0.680764] rk_iommu ff670800.iommu: can't get hclk
[    0.681643] SCSI subsystem initialized
[    0.681984] usbcore: registered new interface driver usbfs
[    0.682030] usbcore: registered new interface driver hub
[    0.682100] usbcore: registered new device driver usb
[    0.682476] media: Linux media interface: v0.10
[    0.682524] Linux video capture interface: v2.00
[    0.682654] pps_core: LinuxPPS API ver. 1 registered
[    0.682666] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.682691] PTP clock support registered
[    0.684244] Advanced Linux Sound Architecture Driver Initialized.
[    0.684729] Bluetooth: Core ver 2.21
[    0.684776] NET: Registered protocol family 31
[    0.684787] Bluetooth: HCI device and connection manager initialized
[    0.684805] Bluetooth: HCI socket layer initialized
[    0.684819] Bluetooth: L2CAP socket layer initialized
[    0.684848] Bluetooth: SCO socket layer initialized
[    0.685885] rockchip-cpuinfo cpuinfo: Serial		: b05fbf124cc9dc39
[    0.686384] clocksource: Switched to clocksource arch_sys_counter
[    0.728532] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.728767] NET: Registered protocol family 2
[    0.729182] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.729282] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    0.729401] TCP: Hash tables configured (established 16384 bind 16384)
[    0.729478] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    0.729508] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    0.729657] NET: Registered protocol family 1
[    0.730185] Trying to unpack rootfs image as initramfs...
[    0.818799] Freeing initrd memory: 1716K
[    0.819311] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.819396] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.822183] audit: initializing netlink subsys (disabled)
[    0.822238] audit: type=2000 audit(0.696:1): initialized
[    0.827404] VFS: Disk quotas dquot_6.6.0
[    0.827527] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.828918] fuse init (API version 7.23)
[    0.830117]
[    0.830117] TEE Core Framework initialization (ver 1:0.1)
[    0.830146] TEE armv7 Driver initialization
[    0.830484] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[    0.830499] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[    0.830666] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[    0.834889] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.834911] io scheduler noop registered
[    0.835076] io scheduler cfq registered (default)
[    0.836302] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[    0.837403] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[    0.842373] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    0.842392] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    0.842409] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    1.363095] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    1.363279] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    1.364108] backlight supply power not found, using dummy regulator
[    1.365165] iep: failed to find iep power down clock source.
[    1.365759] IEP Power ON
[    1.365970] IEP Power OFF
[    1.366081] IEP Driver loaded succesfully
[    1.366304] Module initialized.
[    1.370265] rk-vcodec ff650000.vpu_service: probe device
[    1.370317] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07beea010
[    1.370486] rk-vcodec ff650000.vpu_service: allocator is drm
[    1.370543] rk-vcodec ff650000.vpu_service: checking hw id 0
[    1.371059] rk-vcodec ff650000.vpu_service: init success
[    1.383348] rk-vcodec ff660000.rkvdec: probe device
[    1.383393] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07beea810
[    1.383546] rk-vcodec ff660000.rkvdec: allocator is drm
[    1.383603] rk-vcodec ff660000.rkvdec: checking hw id 6876
[    1.383958] rk-vcodec ff660000.rkvdec: init success
[    1.385377] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.385395] dma-pl330 ff6d0000.dma-controller: 	DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    1.386751] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.386768] dma-pl330 ff6e0000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.388370] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    1.389830] console [ttyS0] disabled
[    1.389875] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[    1.390402] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[    1.390797] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[    1.394749] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[    1.394973] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[    1.394999] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[    1.395249] rockchip-drm display-subsystem: master bind failed: -517
[    1.396821] ff960000.dsi.0 supply power not found, using dummy regulator
[    1.397077] panel-simple-dsi ff960000.dsi.0: panel_simple_dsi_parse_dcs_cmds: dcs_cmd=29 len=243, cmd_cnt=27
[    1.397094] panel-simple-dsi ff960000.dsi.0: panel_simple_dsi_parse_dcs_cmds: dcs_cmd=5 len=8, cmd_cnt=2
[    1.397484] mali ff9a0000.gpu: Failed to get regulator
[    1.397497] mali ff9a0000.gpu: Power control initialization failed
[    1.397802] Unable to detect cache hierarchy from DT for CPU 0
[    1.405321] brd: module loaded
[    1.410069] loop: module loaded
[    1.410573] zram: Added device: zram0
[    1.411107] SCSI Media Changer driver v0.25
[    1.412254] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[    1.412271] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[    1.413096] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    1.583407] wk2xxx_serial_init()
[    1.583419] wk2xxx_request_port
[    1.583432] ttysWK0 at I/O 0x1 (irq = 105, base_baud = 460800) is a wk2xxx
[    1.583635] uart_add_one_port success for line i:= 0 with right 0
[    1.583647] wk2xxx_request_port
[    1.583659] ttysWK1 at I/O 0x2 (irq = 105, base_baud = 460800) is a wk2xxx
[    1.583818] uart_add_one_port success for line i:= 1 with right 0
[    1.583829] wk2xxx_request_port
[    1.583840] ttysWK2 at I/O 0x3 (irq = 105, base_baud = 460800) is a wk2xxx
[    1.584003] uart_add_one_port success for line i:= 2 with right 0
[    1.584014] wk2xxx_request_port
[    1.584024] ttysWK3 at I/O 0x4 (irq = 105, base_baud = 460800) is a wk2xxx
[    1.584186] uart_add_one_port success for line i:= 3 with right 0
[    1.584198] uart_add_one_port = 0x0
[    1.584226] register spi return v = :0
[    1.584284] tun: Universal TUN/TAP device driver, 1.6
[    1.584295] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.585255] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    1.585274] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    1.585287] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[    1.585313] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    1.585488] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    1.590507] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    1.590631] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    1.590641]  Ring mode enabled
[    1.590649]  DMA HW capability register supported
[    1.590658]  Normal descriptors
[    1.590669]  RX Checksum Offload Engine supported (type 2)
[    1.590678]  TX Checksum insertion supported
[    1.590686]  Wake-Up On Lan supported
[    1.590730]  Enable RX Mitigation via HW Watchdog Timer
[    1.665205] libphy: stmmac: probed
[    1.665222] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[    1.665235] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[    1.665246] eth%d: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02)
[    1.665258] eth%d: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03)
[    1.665269] eth%d: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04)
[    1.665279] eth%d: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05)
[    1.665290] eth%d: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06)
[    1.665300] eth%d: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07)
[    1.665310] eth%d: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08)
[    1.665320] eth%d: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09)
[    1.665331] eth%d: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a)
[    1.665341] eth%d: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b)
[    1.665352] eth%d: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c)
[    1.665362] eth%d: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d)
[    1.665373] eth%d: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e)
[    1.665383] eth%d: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f)
[    1.665393] eth%d: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10)
[    1.665404] eth%d: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11)
[    1.665414] eth%d: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12)
[    1.665425] eth%d: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13)
[    1.665435] eth%d: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14)
[    1.665446] eth%d: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15)
[    1.665456] eth%d: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16)
[    1.665466] eth%d: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17)
[    1.665476] eth%d: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18)
[    1.665487] eth%d: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19)
[    1.665497] eth%d: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a)
[    1.665508] eth%d: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b)
[    1.665518] eth%d: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c)
[    1.665528] eth%d: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d)
[    1.665539] eth%d: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e)
[    1.665549] eth%d: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f)
[    1.666440] PPP generic driver version 2.4.2
[    1.666613] PPP BSD Compression module registered
[    1.666629] PPP Deflate Compression module registered
[    1.666660] PPP MPPE Compression module registered
[    1.666680] NET: Registered protocol family 24
[    1.666722] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[    1.666735] CSLIP: code copyright 1989 Regents of the University of California.
[    1.666753] Rockchip WiFi SYS interface (V1.00) ...
[    1.666836] usbcore: registered new interface driver catc
[    1.666881] usbcore: registered new interface driver kaweth
[    1.666897] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    1.666939] usbcore: registered new interface driver pegasus
[    1.666989] usbcore: registered new interface driver rtl8150
[    1.667031] usbcore: registered new interface driver r8152
[    1.667047] hso: drivers/net/usb/hso.c: Option Wireless
[    1.667101] usbcore: registered new interface driver hso
[    1.667150] usbcore: registered new interface driver asix
[    1.667196] usbcore: registered new interface driver ax88179_178a
[    1.667240] usbcore: registered new interface driver cdc_ether
[    1.667283] usbcore: registered new interface driver cdc_eem
[    1.667326] usbcore: registered new interface driver dm9601
[    1.667378] usbcore: registered new interface driver smsc75xx
[    1.667436] usbcore: registered new interface driver smsc95xx
[    1.667479] usbcore: registered new interface driver gl620a
[    1.667522] usbcore: registered new interface driver net1080
[    1.667564] usbcore: registered new interface driver plusb
[    1.667607] usbcore: registered new interface driver rndis_host
[    1.667653] usbcore: registered new interface driver cdc_subset
[    1.667696] usbcore: registered new interface driver zaurus
[    1.667740] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.667800] usbcore: registered new interface driver int51x1
[    1.667843] usbcore: registered new interface driver kalmia
[    1.667885] usbcore: registered new interface driver ipheth
[    1.667936] usbcore: registered new interface driver sierra_net
[    1.667979] usbcore: registered new interface driver cx82310_eth
[    1.668031] usbcore: registered new interface driver cdc_ncm
[    1.668074] usbcore: registered new interface driver qmi_wwan
[    1.668119] usbcore: registered new interface driver cdc_mbim
[    1.675034] rockchip-dwc3 usb@fe800000: fail to get drvdata hcd
[    1.681766] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[    1.682405] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.682424] ehci-pci: EHCI PCI platform driver
[    1.682485] ehci-platform: EHCI generic platform driver
[    1.686127] ehci-platform fe380000.usb: EHCI Host Controller
[    1.686156] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[    1.686294] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[    1.693237] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    1.693372] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.693388] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.693401] usb usb1: Product: EHCI Host Controller
[    1.693412] usb usb1: Manufacturer: Linux 4.4.103 ehci_hcd
[    1.693423] usb usb1: SerialNumber: fe380000.usb
[    1.693880] hub 1-0:1.0: USB hub found
[    1.693914] hub 1-0:1.0: 1 port detected
[    1.697784] ehci-platform fe3c0000.usb: EHCI Host Controller
[    1.697810] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[    1.697934] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[    1.706376] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    1.706501] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.706516] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.706529] usb usb2: Product: EHCI Host Controller
[    1.706540] usb usb2: Manufacturer: Linux 4.4.103 ehci_hcd
[    1.706551] usb usb2: SerialNumber: fe3c0000.usb
[    1.706948] hub 2-0:1.0: USB hub found
[    1.706979] hub 2-0:1.0: 1 port detected
[    1.707500] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.707530] ohci-platform: OHCI generic platform driver
[    1.707822] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    1.707848] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[    1.707972] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[    1.763850] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    1.763865] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.763878] usb usb3: Product: Generic Platform OHCI controller
[    1.763890] usb usb3: Manufacturer: Linux 4.4.103 ohci_hcd
[    1.763901] usb usb3: SerialNumber: fe3a0000.usb
[    1.764306] hub 3-0:1.0: USB hub found
[    1.764338] hub 3-0:1.0: 1 port detected
[    1.764834] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    1.764860] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[    1.764963] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[    1.820499] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    1.820515] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.820529] usb usb4: Product: Generic Platform OHCI controller
[    1.820540] usb usb4: Manufacturer: Linux 4.4.103 ohci_hcd
[    1.820552] usb usb4: SerialNumber: fe3e0000.usb
[    1.820951] hub 4-0:1.0: USB hub found
[    1.820983] hub 4-0:1.0: 1 port detected
[    1.821840] usbcore: registered new interface driver cdc_acm
[    1.821852] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.821915] usbcore: registered new interface driver usblp
[    1.821965] usbcore: registered new interface driver cdc_wdm
[    1.822016] usbcore: registered new interface driver uas
[    1.822108] usbcore: registered new interface driver usb-storage
[    1.822154] usbcore: registered new interface driver ums-alauda
[    1.822199] usbcore: registered new interface driver ums-cypress
[    1.822245] usbcore: registered new interface driver ums-datafab
[    1.822289] usbcore: registered new interface driver ums_eneub6250
[    1.822333] usbcore: registered new interface driver ums-freecom
[    1.822378] usbcore: registered new interface driver ums-isd200
[    1.822423] usbcore: registered new interface driver ums-jumpshot
[    1.822467] usbcore: registered new interface driver ums-karma
[    1.822517] usbcore: registered new interface driver ums-onetouch
[    1.822562] usbcore: registered new interface driver ums-sddr09
[    1.822607] usbcore: registered new interface driver ums-sddr55
[    1.822651] usbcore: registered new interface driver ums-usbat
[    1.822737] usbcore: registered new interface driver usbserial
[    1.822776] usbcore: registered new interface driver usbserial_generic
[    1.822807] usbserial: USB Serial support registered for generic
[    1.822860] usbcore: registered new interface driver ch341
[    1.822889] usbserial: USB Serial support registered for ch341-uart
[    1.822938] usbcore: registered new interface driver cp210x
[    1.822967] usbserial: USB Serial support registered for cp210x
[    1.823074] usbcore: registered new interface driver option
[    1.823106] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.823254] usbcore: registered new interface driver pl2303
[    1.823286] usbserial: USB Serial support registered for pl2303
[    1.823343] usbcore: registered new interface driver trancevibrator
[    1.823361] usb20_otg: version 3.10a 21-DEC-2012
[    1.823541] usb20_host: version 3.10a 21-DEC-2012
[    1.824001] usbcore: registered new interface driver xpad
[    1.824057] usbcore: registered new interface driver usb_acecad
[    1.824108] usbcore: registered new interface driver aiptek
[    1.824159] usbcore: registered new interface driver gtco
[    1.824209] usbcore: registered new interface driver hanwang
[    1.824258] usbcore: registered new interface driver kbtab
[    1.824274] ==gsl_ts_init==
[    1.824304] ret=0
[    1.824696] .. rk pwm remotectl v1.1 init
[    1.824929] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[    1.825207] remotectl-pwm ff420030.pwm: set irq err, set support_psci to 0 !!
[    1.825342] sensor_register_slave:mma8452,id=17
[    1.825360] sensor_register_slave:lis3dh,id=7
[    1.825376] sensor_register_slave:mma7660,id=18
[    1.825391] sensor_register_slave:lsm303d,id=22
[    1.825407] sensor_register_slave:mpu6880_acc,id=24
[    1.825423] sensor_register_slave:mpu6500_acc,id=25
[    1.825438] sensor_register_slave:lsm330_acc,id=26
[    1.825454] sensor_register_slave:akm8975,id=29
[    1.825469] sensor_register_slave:akm8963,id=30
[    1.825485] sensor_register_slave:l3g4200d,id=44
[    1.825500] sensor_register_slave:l3g20d,id=45
[    1.825515] sensor_register_slave:ewtsa,id=46
[    1.825531] sensor_register_slave:lsm330_gyro,id=50
[    1.825547] sensor_register_slave:cm3217,id=52
[    1.825562] sensor_register_slave:cm3218,id=53
[    1.826236] i2c /dev entries driver
[    1.827326] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    1.827396] fan53555-reg: supplied by vcc5v0_sys
[    1.829059] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    1.829109] fan53555-reg: supplied by vcc5v0_sys
[    1.830930] rk808 0-001b: Pmic Chip id: 0x0
[    1.834038] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    1.834102] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    1.834186] DCDC_REG1: supplied by vcc3v3_sys
[    1.834845] DCDC_REG2: supplied by vcc3v3_sys
[    1.835343] DCDC_REG3: supplied by vcc3v3_sys
[    1.835560] DCDC_REG4: supplied by vcc3v3_sys
[    1.835938] LDO_REG1: supplied by vcc3v3_sys
[    1.836970] LDO_REG2: supplied by vcc3v3_sys
[    1.837861] LDO_REG3: supplied by vcc3v3_sys
[    1.838755] LDO_REG4: supplied by vcc3v3_sys
[    1.839648] LDO_REG5: supplied by vcc3v3_sys
[    1.840570] LDO_REG6: supplied by vcc3v3_sys
[    1.841465] LDO_REG7: supplied by vcc3v3_sys
[    1.842378] LDO_REG8: supplied by vcc3v3_sys
[    1.843256] SWITCH_REG1: supplied by vcc3v3_sys
[    1.843471] SWITCH_REG2: supplied by vcc3v3_sys
[    1.846803] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[    1.847327] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff800974a000
[    1.847958] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff800974c000
[    1.848043] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[    1.848060] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[    1.848075] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer  on device rockchip-pinctrl
[    1.848090] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[    1.848413] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff800974e000
[    1.848981] goodix_ts_probe() start
[    1.849009] 4-005d supply tp not found, using dummy regulator
[    1.977167] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
[    2.013046] usb 2-1: new high-speed USB device number 2 using ehci-platform
[    2.060503] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
[    2.136982] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201
[    2.136999] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.137013] usb 2-1: Product: USB 2.0 Hub [MTT]
[    2.137608] hub 2-1:1.0: USB hub found
[    2.137731] hub 2-1:1.0: 7 ports detected
[    2.143851] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
[    2.227165] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
[    2.310511] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
[    2.393842] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
[    2.476386] <<-GTP-ERROR->> I2C read 0x8000, 10 bytes, double check failed!
[    2.476398] <<-GTP-ERROR->> Failed to get chip-type, set chip type default: GOODIX_GT9
[    2.477243] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -6! Process reset.
[    2.559716] <<-GTP-ERROR->> GTP i2c test failed time 1.
[    2.573833] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -6! Process reset.
[    2.656381] <<-GTP-ERROR->> GTP i2c test failed time 2.
[    2.670499] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -6! Process reset.
[    2.753048] <<-GTP-ERROR->> GTP i2c test failed time 3.
[    2.767165] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -6! Process reset.
[    2.849714] <<-GTP-ERROR->> GTP i2c test failed time 4.
[    2.863832] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -6! Process reset.
[    2.946381] <<-GTP-ERROR->> GTP i2c test failed time 5.
[    2.959709] <goodix_ts_probe>_2749    I2C communication ERROR!
[    2.959720]    <goodix_ts_probe>_2817  prob error !!!!!!!!!!!!!!!
[    2.959809] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009750000
[    2.960572] IR NEC protocol handler initialized
[    2.960587] IR RC5(x/sz) protocol handler initialized
[    2.960601] IR RC6 protocol handler initialized
[    2.960614] IR JVC protocol handler initialized
[    2.960628] IR Sony protocol handler initialized
[    2.960642] IR SANYO protocol handler initialized
[    2.960656] IR Sharp protocol handler initialized
[    2.960670] IR MCE Keyboard/mouse protocol handler initialized
[    2.960684] IR XMP protocol handler initialized
[    2.960887] usbcore: registered new interface driver uvcvideo
[    2.960897] USB Video Class driver (1.1.1)
[    2.960915] CamSys driver version: v0.34.8, CamSys head file version: v0.13.0
[    2.965201] __power_supply_register: Expected proper parent device for 'test_ac'
[    2.965338] __power_supply_register: Expected proper parent device for 'test_battery'
[    2.965584] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[    2.965703] __power_supply_register: Expected proper parent device for 'test_usb'
[    2.968079] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[    2.969090] device-mapper: uevent: version 1.0.3
[    2.969352] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    2.972841] Bluetooth: HCI UART driver ver 2.3
[    2.972855] Bluetooth: HCI UART protocol H4 registered
[    2.972866] Bluetooth: HCI UART protocol LL registered
[    2.972881] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[    2.972892] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[    2.972902] rtk_btusb: Register usb char device interface for BT driver
[    2.973262] usbcore: registered new interface driver rtk_btusb
[    2.973677] cpu cpu0: leakage=22
[    2.990009] cpu cpu0: temp=31111, pvtm=145745 (146895 + -1150)
[    2.990235] cpu cpu0: pvtm-sel=1
[    2.990532] cpu cpu4: leakage=39
[    3.002702] cpu cpu4: temp=31111, pvtm=151076 (151786 + -710)
[    3.002846] cpu cpu4: pvtm-sel=1
[    3.007261] sdhci: Secure Digital Host Controller Interface driver
[    3.007278] sdhci: Copyright(c) Pierre Ossman
[    3.007294] Synopsys Designware Multimedia Card Interface Driver
[    3.008118] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    3.008202] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    3.008223] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    3.008277] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    3.008301] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    3.008346] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    3.008358] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    3.009117] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    3.009170] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    3.009188] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    3.009228] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    3.009250] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    3.009333] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[    3.009928] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.011581] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[    3.011595] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[    3.039812] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    3.040877] hidraw: raw HID events driver (C) Jiri Kosina
[    3.046505] usbcore: registered new interface driver usbhid
[    3.046518] usbhid: USB HID core driver
[    3.046648] inv_mpu_iio: inv_mpu_init:746
[    3.047230] ashmem: initialized
[    3.048705] ff100000.saradc supply vref not found, using dummy regulator
[    3.052041] rknandbase v1.1 2016-11-08
[    3.053526] usbcore: registered new interface driver snd-usb-audio
[    3.067449] lkd tc358749x_parse_dts: power(1)
[    3.067546] lkd tc358749x_parse_dts: int(0)
[    3.067634] lkd tc358749x_parse_dts: reset(1)
[    3.078774] tc358749x 1-000f: tc358749x_parse_dts success
[    3.078912] tc358749x 1-000f: tc358749x_i2c_probe success
[    3.080466] mmc0: MAN_BKOPS_EN bit is not set
[    3.084421] u32 classifier
[    3.084441]     Actions configured
[    3.084487] Netfilter messages via NETLINK v0.30.
[    3.084561] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    3.085022] ctnetlink v0.93: registering with nfnetlink.
[    3.085805] xt_time: kernel timezone is -0000
[    3.086610] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.086904] arp_tables: (C) 2002 David S. Miller
[    3.087309] Initializing XFRM netlink socket
[    3.087907] NET: Registered protocol family 10
[    3.089090] mip6: Mobile IPv6
[    3.089129] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.090367] sit: IPv6 over IPv4 tunneling driver
[    3.090976] NET: Registered protocol family 17
[    3.091011] NET: Registered protocol family 15
[    3.091062] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    3.091415] Bridge firewalling registered
[    3.091435] Ebtables v2.0 registered
[    3.091663] Bluetooth: RFCOMM TTY layer initialized
[    3.091682] Bluetooth: RFCOMM socket layer initialized
[    3.091715] Bluetooth: RFCOMM ver 1.11
[    3.091741] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.091751] Bluetooth: BNEP filters: protocol multicast
[    3.091767] Bluetooth: BNEP socket layer initialized
[    3.091782] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.091797] Bluetooth: HIDP socket layer initialized
[    3.091866] l2tp_core: L2TP core driver, V2.0
[    3.091890] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    3.091910] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    3.092325] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    3.092418] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[    3.092431] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    3.092442] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    3.092558] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 1003, flags = 0.
[    3.092569] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    3.092597] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    3.092682] [BT_RFKILL]: Enter rfkill_rk_init
[    3.092768] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    3.093342] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 1083.
[    3.093399] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 1009.
[    3.093439] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 1090.
[    3.093479] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 1004.
[    3.093994] [BT_RFKILL]: Request irq for bt wakeup host
[    3.094033] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[    3.094083] [BT_RFKILL]: ** disable irq
[    3.094251] [BT_RFKILL]: bt_default device registered.
[    3.094559] sensor_register_slave:mpu6880_gyro,id=49
[    3.096240] Registered cp15_barrier emulation handler
[    3.096331] Registered setend emulation handler
[    3.096577] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[    3.097586] registered taskstats version 1
[    3.098849] rockchip ion idev is NULL
[    3.098867] rga2 ff680000.rga: rga ion client create success!
[    3.099104] rga: Driver loaded successfully ver:3.02
[    3.100165] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[    3.100555] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[    3.101042] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[    3.101328] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[    3.101415] rockchip-drm display-subsystem: bound ff960000.dsi (ops dw_mipi_dsi_ops)
[    3.102041] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[    3.102049] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[    3.102097] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[    3.102185] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    3.102311]      uboot: 0x000400000 -- 0x000800000 (4 MB)
[    3.102321]      trust: 0x000800000 -- 0x000c00000 (4 MB)
[    3.102329]       misc: 0x000c00000 -- 0x001000000 (4 MB)
[    3.102336]   resource: 0x001000000 -- 0x002000000 (16 MB)
[    3.102343]     kernel: 0x002000000 -- 0x003800000 (24 MB)
[    3.102349]       boot: 0x003800000 -- 0x005800000 (32 MB)
[    3.102355]   recovery: 0x005800000 -- 0x007800000 (32 MB)
[    3.102362]     backup: 0x007800000 -- 0x00e800000 (112 MB)
[    3.102368]      cache: 0x00e800000 -- 0x016800000 (128 MB)
[    3.102375]     system: 0x016800000 -- 0x076800000 (1536 MB)
[    3.102381]   metadata: 0x076800000 -- 0x077800000 (16 MB)
[    3.102387] baseparamer: 0x077800000 -- 0x077c00000 (4 MB)
[    3.102394]   userdata: 0x077c00000 -- 0x3a3a00000 (12990 MB)
[    3.102422]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
[    3.104153] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[    3.104179] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.104192] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[    3.367642] rockchip-drm display-subsystem: fb0:  frame buffer device
[    3.378245] mali ff9a0000.gpu: leakage=30
[    3.402006] mali ff9a0000.gpu: temp=30000, pvtm=123786 (124292 + -506)
[    3.402840] mali ff9a0000.gpu: pvtm-sel=1
[    3.404448] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[    3.406243] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[    3.410752] mali ff9a0000.gpu: Probed as mali0
[    3.415847] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    3.415863] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[    3.416013] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[    3.416041] xhci-hcd xhci-hcd.9.auto: irq 236, io mem 0xfe800000
[    3.416133] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    3.416141] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.416147] usb usb5: Product: xHCI Host Controller
[    3.416153] usb usb5: Manufacturer: Linux 4.4.103 xhci-hcd
[    3.416159] usb usb5: SerialNumber: xhci-hcd.9.auto
[    3.416447] hub 5-0:1.0: USB hub found
[    3.416467] hub 5-0:1.0: 1 port detected
[    3.416606] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    3.416615] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 6
[    3.416653] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.416715] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[    3.416722] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.416729] usb usb6: Product: xHCI Host Controller
[    3.416734] usb usb6: Manufacturer: Linux 4.4.103 xhci-hcd
[    3.416740] usb usb6: SerialNumber: xhci-hcd.9.auto
[    3.416956] hub 6-0:1.0: USB hub found
[    3.416972] hub 6-0:1.0: 1 port detected
[    3.417635] xhci-hcd xhci-hcd.9.auto: remove, state 1
[    3.417651] usb usb6: USB disconnect, device number 1
[    3.441205] xhci-hcd xhci-hcd.9.auto: Host not halted after 16000 microseconds.
[    3.441213] xhci-hcd xhci-hcd.9.auto: Host controller not halted, aborting reset.
[    3.441257] xhci-hcd xhci-hcd.9.auto: USB bus 6 deregistered
[    3.441265] xhci-hcd xhci-hcd.9.auto: remove, state 1
[    3.441276] usb usb5: USB disconnect, device number 1
[    3.441646] xhci-hcd xhci-hcd.9.auto: USB bus 5 deregistered
[    3.446617] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[    3.446633] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 5
[    3.446771] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[    3.446799] xhci-hcd xhci-hcd.10.auto: irq 237, io mem 0xfe900000
[    3.446870] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    3.446877] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.446883] usb usb5: Product: xHCI Host Controller
[    3.446889] usb usb5: Manufacturer: Linux 4.4.103 xhci-hcd
[    3.446895] usb usb5: SerialNumber: xhci-hcd.10.auto
[    3.447362] hub 5-0:1.0: USB hub found
[    3.447382] hub 5-0:1.0: 1 port detected
[    3.447508] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[    3.447518] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 6
[    3.447548] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.447590] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[    3.447597] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.447603] usb usb6: Product: xHCI Host Controller
[    3.447609] usb usb6: Manufacturer: Linux 4.4.103 xhci-hcd
[    3.447614] usb usb6: SerialNumber: xhci-hcd.10.auto
[    3.448003] hub 6-0:1.0: USB hub found
[    3.448018] hub 6-0:1.0: 1 port detected
[    3.448641] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    3.448695] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    3.448708] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    3.448726] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    3.448740] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    3.448768] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    3.448774] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    3.448933] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[    3.460148] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.473130] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[    3.473611] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    3.473813] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    3.473826] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    3.473844] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    3.473857] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    3.473910] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[    3.474093] dwmmc_rockchip fe320000.dwmmc: allocated mmc-pwrseq
[    3.474176] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    3.474627] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    3.486453] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.500805] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[    3.501453] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok
[    3.515688] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok
[    3.516984] asoc-simple-card rt5640-sound: rt5640-aif2 <-> ff890000.i2s mapping ok
[    3.517535] asoc-simple-card rt5640-sound: tc358749x-audio <-> ff890000.i2s mapping ok
[    3.519111] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input1
[    3.519773] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    3.520290] asoc-simple-card spdif-sound: dit-hifi <-> ff870000.spdif mapping ok
[    3.520613] otg_wakelock_init: No USB transceiver found
[    3.521413] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:06 UTC (1358499006)
[    3.521905] It doesn't contain Rogue gpu
[    3.530415] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.531374] ret 1024
[    3.531651] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-e258084', rk_ko_ver is '5', built at '08:33:30', on 'Sep 21 2018'.
[    3.531813] Mali: Mali device driver loaded
[    3.532076] input: rk29-keypad as /devices/platform/rockchip-key/input/input2
[    3.532182] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.532572] ALSA device list:
[    3.532578]   #0: rockchip,hdmi
[    3.532582]   #1: rockchip,rt5640-codec
[    3.532587]   #2: ROCKCHIP,SPDIF
[    3.533016] Freeing unused kernel memory: 832K
[    3.535538] init: init first stage started!
[    3.535676] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    3.568805] audit: type=1403 audit(1358499006.543:2): policy loaded auid=4294967295 ses=4294967295
[    3.569216] init: (Inkit399_firefly_anuxlvds_box:/cin g took 0.03s.)
[    3.571326] init: init second stage started!
[    3.573864] init: Setting ro.rk.soc=rk3399
[    3.573916] init: OK,EMMC DRIVERS INIT OK
[    3.573932] init: property_set("ro.boot.mode", "emmc") failed
[    3.573968] init: property_set("ro.hardware", "rk30board") failed
[    3.575150] init: Running restorecon...
[    3.592227] mmc_host mmc1: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[    3.616952] vendor storage:20160801 ret = 0
[    3.621397] init: waitpid failed: No child processes
[    3.621624] init: (Loading properties from /default.prop took 0.00s.)
[    3.622678] init: /init.rc: 588: invalid keyword 'echo'
[    3.622909] init: (Parsing /init.environ.rc took 0.00s.)
[    3.623137] init: (Parsing /init.usb.rc took 0.00s.)
[    3.623642] init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[    3.624033] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[    3.624066] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[    3.624114] init: could not import file '/init.stt_trace.rc' from '/init.debug.rc': No such file or directory
[    3.624222] init: (Parsing /init.logs.rc took 0.00s.)
[    3.624270] init: (Parsing /init.crashlogd.rc took 0.00s.)
[    3.624317] init: (Parsing /init.coredump.rc took 0.00s.)
[    3.624352] init: (Parsing /init.log-watch.rc took 0.00s.)
[    3.624387] init: (Parsing /init.kernel.rc took 0.00s.)
[    3.624452] init: (Parsing /init.debug-charging.rc took 0.00s.)
[    3.624464] init: (Parsing /init.debug.rc took 0.00s.)
[    3.624474] init: (Parsing init.rockchip.rc took 0.00s.)
[    3.624694] init: (Parsing init.connectivity.rc took 0.00s.)
[    3.624743] init: (Parsing init.box.samba.rc took 0.00s.)
[    3.624805] init: (Parsing init.rk3399.rc took 0.00s.)
[    3.624870] init: init.box.rc: 25: invalid keyword 'ioprio'
[    3.624884] init: (Parsing init.box.rc took 0.00s.)
[    3.624905] init: could not import file 'init.car.rc' from '/init.rk30board.rc': No such file or directory
[    3.624926] init: could not import file 'init.optee.rc' from '/init.rk30board.rc': No such file or directory
[    3.624938] init: (Parsing /init.rk30board.rc took 0.00s.)
[    3.625292] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[    3.625360] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[    3.625371] init: (Parsing /init.rc took 0.00s.)
[    3.625692] init: Starting service 'ueventd'...
[    3.627963] audit: type=1400 audit(1358499006.603:3): avc:  denied  { getattr } for  pid=1 comm="init" path="/sys/kernel/debug/tracing/trace_marker" dev="tracefs" ino=2126 scontext=u:r:init:s0 tcontext=u:object_r:debugfs_trace_marker:s0 tclass=file permissive=1
[    3.631311] ueventd: ueventd started!
[    3.633467] ueventd: invalid gid 'trace'
[    3.785166] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 110
[    3.788146] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[    3.788175] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[    3.811371] init: write_file: Unable to open '/proc/self/coredump_filter': No such file or directory
[    3.811411] init: write_file: Unable to open '/proc/sys/kernel/panic_on_stackoverflow': No such file or directory
[    3.853208] init: Waiting for /dev/.coldboot_done...
[    3.883938] ueventd: Coldboot took 0.24s.
[    3.893773] init: Waiting for /dev/.coldboot_done took 0.04s.
[    3.893876] init: /dev/hw_random not found
[    3.894553] keychord: using input dev ff420030.pwm for fevent
[    3.894563] keychord: using input dev rk29-keypad for fevent
[    3.900540] init: write_file: Unable to open '/proc/cpu/alignment': No such file or directory
[    3.909346] Registered swp emulation handler
[    3.909555] init: write_file: Unable to open '/sys/module/rockchip_pm/parameters/policy': No such file or directory
[    3.910376] init: /dev/hw_random not found
[    3.911268] fs_mgr: Warning: unknown flag resize
[    3.914438] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[    3.914538] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/system,target=/system,type=ext4)=0
[    3.915317] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=-1: No such file or directory
[    3.915846] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache
[    3.923159] random: e2fsck: uninitialized urandom read (40 bytes read, 41 bits of entropy available)
[    3.959859] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    3.959859]
[    3.959892] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: recovering journal
[    3.959892]
[    3.959903] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: clean, 27/8192 files, 1649/32768 blocks (check in 2 mounts)
[    3.959903]
[    3.962487] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[    3.962545] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[    3.963495] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[    3.964724] EXT4-fs (mmcblk0p11): recovery complete
[    3.964735] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    3.964777] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[    3.974392] fs_mgr: check_fs(): unmount(/metadata) succeeded
[    3.974415] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata
[    3.975388] random: e2fsck: uninitialized urandom read (40 bytes read, 43 bits of entropy available)
[    3.983238] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    3.983238]
[    3.983282] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[    3.983282]
[    3.988798] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[    3.988915] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[    3.989021] fs_mgr: Running /system/bin/fsck.f2fs -a /dev/block/platform/fe330000.sdhci/by-name/userdata
[    3.990790] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[    3.990790]
[    3.990836] fsck.f2fs: fsck.f2fs terminated by exit(255)
[    3.990836]
[    4.053021] F2FS-fs (mmcblk0p13): recover_inode: ino = e78f, name = .temp.A5Mnts
[    4.055650] F2FS-fs (mmcblk0p13): recover_dentry: ino = e78f, name = .temp.A5Mnts, dir = 2d, err = 0
[    4.055686] F2FS-fs (mmcblk0p13): recover_data: ino = e78f (i_size: recover) recovered = 0, err = 0
[    4.055698] F2FS-fs (mmcblk0p13): recover_inode: ino = e790, name = .temp.lxl0Wo
[    4.055711] F2FS-fs (mmcblk0p13): recover_dentry: ino = e790, name = .temp.lxl0Wo, dir = 2d, err = 0
[    4.055732] F2FS-fs (mmcblk0p13): recover_data: ino = e790 (i_size: recover) recovered = 0, err = 0
[    4.055742] F2FS-fs (mmcblk0p13): recover_inode: ino = e791, name = .temp.6011F2
[    4.055755] F2FS-fs (mmcblk0p13): recover_dentry: ino = e791, name = .temp.6011F2, dir = 2d, err = 0
[    4.055775] F2FS-fs (mmcblk0p13): recover_data: ino = e791 (i_size: recover) recovered = 0, err = 0
[    4.055785] F2FS-fs (mmcblk0p13): recover_inode: ino = e792, name = .temp.gZfH9q
[    4.060548] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=f2fs)=0
[    4.063703] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[    4.063966] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[    4.064155] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[    4.064412] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[    4.064608] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[    4.064790] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[    4.064977] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[    4.065183] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[    4.065468] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[    4.065670] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[    4.065896] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[    4.066099] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[    4.066300] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[    4.066534] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[    4.066943] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[    4.067188] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[    4.067397] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[    4.067584] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[    4.067772] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[    4.067956] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[    4.068160] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[    4.068345] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[    4.068532] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[    4.068718] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[    4.068937] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[    4.069146] init: ignored duplicate definition of service 'ril-daemon'init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[    4.069396] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[    4.069601] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[    4.069823] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[    4.070058] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[    4.070280] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[    4.071223] init: property_set("ro.board.platform", "rk3399") failed
[    4.071612] init: property_set("ro.rk.screenoff_time", "2147483647") failed
[    4.071766] init: property_set("ro.rk.screenshot_enable", "true") failed
[    4.071865] init: (Loading properties from /system/build.prop took 0.00s.)
[    4.071909] init: (Loading properties from /vendor/build.prop took 0.00s.)
[    4.071937] init: (Loading properties from /factory/factory.prop took 0.00s.)
[    4.072030] fs_mgr: Warning: unknown flag resize
[    4.072114] init: /recovery not specified in fstab
[    4.072214] init: Starting service 'healthd'...
[    4.072590] init: cannot find '/system/bin/displayd' (No such file or directory), disabling 'displayd'
[    4.073135] init: Starting service 'earlylogs'...
[    4.074504] binder: 222:222 transaction failed 29189/-22, size 0-0 line 2951
[    4.074895] init: Starting service 'zygote'...
[    4.075628] init: Starting service 'zygote_secondary'...
[    4.076474] init: Starting service 'lmkd'...
[    4.077053] random: elogs.sh: uninitialized urandom read (40 bytes read, 50 bits of entropy available)
[    4.077476] init: Starting service 'servicemanager'...
[    4.078813] init: Starting service 'surfaceflinger'...
[    4.078981] random: app_process64: uninitialized urandom read (40 bytes read, 50 bits of entropy available)
[    4.081396] init: Starting service 'vold'...
[    4.083691] random: app_process32: uninitialized urandom read (40 bytes read, 50 bits of entropy available)
[    4.084619] init: Service 'earlylogs' (pid 223) exited with status 0
[    4.085195] random: surfaceflinger: uninitialized urandom read (40 bytes read, 50 bits of entropy available)
[    4.085830] random: lmkd: uninitialized urandom read (40 bytes read, 50 bits of entropy available)
[    4.087477] random: servicemanager: uninitialized urandom read (40 bytes read, 50 bits of entropy available)
[    4.094837] random: vold: uninitialized urandom read (40 bytes read, 51 bits of entropy available)
[    4.095514] init: insmod: open("/system/lib/modules/ump.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/mali.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/mali_kbase.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/rk30_mirroring.ko") failed: No such file or directoryinit: finit_module for "/system/lib/modules/rk29-ipp.ko" failed: Exec format errorinit: insmod: open("/system/lib/modules/pvrsrvkm.ko") failed: No such file or directoryinit: finit_module for "/drmboot.ko" failed: Exec format errorfs_mgr: Warning: unknown flag resize
[    4.097958] zram0: detected capacity change from 0 to 533413888
[    4.134925] random: mkswap: uninitialized urandom read (40 bytes read, 55 bits of entropy available)
[    4.143429] Adding 520908k swap on /dev/block/zram0.  Priority:-1 extents:1 across:520908k SS
[    4.146116] init: Starting service 'debuggerd'...
[    4.147035] init: Starting service 'debuggerd64'...
[    4.163919] init: Not bootcharting.
[    4.278640] fs_mgr: Warning: unknown flag resize
[    4.377857] init: Starting service 'exec 1 (/system/bin/tzdatacheck)'...
[    4.388585] init: Service 'exec 1 (/system/bin/tzdatacheck)' (pid 251) exited with status 0
[    4.406805] audit: type=1400 audit(1358499007.383:4): avc:  denied  { setattr } for  pid=1 comm="init" name="cifsmanager" dev="mmcblk0p13" ino=86 scontext=u:r:init:s0 tcontext=u:object_r:cifsmanager_exec:s0 tclass=dir permissive=1
[    4.416570] init: write_file: Unable to open '/proc/sys/kernel/core_pattern': No such file or directory
[    4.418493] init: (Loading properties from /data/local.prop took 0.00s.)
[    4.462488] init: Starting service 'logd'...
[    4.463208] init: Starting service 'logd-reinit'...
[    4.464123] init: write_file: Unable to open '/proc/sys/vm/min_free_order_shift': No such file or directory
[    4.465448] init: SELinux:  Could not stat /sys/devices/system/cpu/cpufreq/interactive: No such file or directory.
[    4.466236] init: write_file: Unable to open '/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold': No such file or directory
[    4.468000] audit: type=1400 audit(1358499007.443:5): avc:  denied  { relabelto } for  pid=1 comm="init" name="recovery" dev="tmpfs" ino=15701 scontext=u:r:init:s0 tcontext=u:object_r:recovery_block_device:s0 tclass=lnk_file permissive=1
[    4.468060] audit: type=1400 audit(1358499007.443:6): avc:  denied  { relabelto } for  pid=1 comm="init" name="boot" dev="tmpfs" ino=15697 scontext=u:r:init:s0 tcontext=u:object_r:boot_block_device:s0 tclass=lnk_file permissive=1
[    4.468957] audit: type=1400 audit(1358499007.443:7): avc:  denied  { getattr } for  pid=1 comm="init" path="/system/xbin/vm" dev="mmcblk0p10" ino=2742 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[    4.468995] init: Starting service 'vm_daemon'...
[    4.470582] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[    4.470601] init: write: cannot expand '${ro.serialno}'
[    4.471289] audit: type=1400 audit(1358499007.446:8): avc:  denied  { execute } for  pid=259 comm="init" name="vm" dev="mmcblk0p10" ino=2742 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[    4.471341] audit: type=1400 audit(1358499007.446:9): avc:  denied  { read open } for  pid=259 comm="init" path="/system/xbin/vm" dev="mmcblk0p10" ino=2742 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[    4.471491] audit: type=1400 audit(1358499007.446:10): avc:  denied  { transition } for  pid=259 comm="init" path="/system/xbin/vm" dev="mmcblk0p10" ino=2742 scontext=u:r:init:s0 tcontext=u:r:sudaemon:s0 tclass=process permissive=1
[    4.471555] file system registered
[    4.475298] using random self ethernet address
[    4.475310] using random host ethernet address
[    4.475360] init: write_file: Unable to open '/config/usb_gadget/g1/functions/rndis.gs4/wceis': Permission denied
[    4.481285] init: Starting service 'console'...
[    4.482031] init: Starting service 'adbd'...
[    4.483630] init: Starting service 'ap_log_srv'...
[    4.484363] init: cannot find '/system/bin/update_verifier' (No such file or directory), disabling 'exec 2 (/system/bin/update_verifier)'
[    4.484704] init: Starting service 'ril-daemon'...
[    4.485209] init: cannot find '/system/bin/install-recovery.sh' (No such file or directory), disabling 'flash_recovery'
[    4.485436] init: Starting service 'drmservice'...
[    4.485842] init: cannot find '/system/bin/bplus_helper' (No such file or directory), disabling 'bplus_helper'
[    4.485997] init: Service up_eth0 does not have a SELinux domain defined.
[    4.486014] init: cannot find '/system/bin/rk_store_keybox' (No such file or directory), disabling 'rk_store_keybox'
[    4.486095] init: Starting service 'akmd'...
[    4.487499] init: Starting service 'audioserver'...
[    4.488292] init: Starting service 'cameraserver'...
[    4.489107] init: Starting service 'drm'...
[    4.493293] init: Starting service 'installd'...
[    4.493558] init: couldn't write 268 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[    4.493964] logd.auditd: start
[    4.494024] logd.klogd: 4370983422
[    4.494828] init: Starting service 'keystore'...
[    4.495459] init: Starting service 'mediacodec'...
[    4.496044] init: Starting service 'mediadrm'...
[    4.499955] init: Starting service 'mediaextractor'...
[    4.501573] init: Starting service 'media'...
[    4.502234] init: Starting service 'netd'...
[    4.502870] init: Service 'logd-reinit' (pid 258) exited with status 145
[    4.503259] init: Starting service 'crashlogd'...
[    4.503932] init: Starting service 'log-watch'...
[    4.504820] init: Starting service 'gatekeeperd'...
[    4.505522] init: Starting service 'perfprofd'...
[    4.573833] init: Service 'akmd' (pid 266) exited with status 254
[    4.597025] ret = ffffffffffffffff
[    4.598100] init: property 'sys.serialno' doesn't exist while expanding '${sys.serialno}'
[    4.598117] init: setprop: cannot expand '${sys.serialno}'
[    4.600440] init: Service 'drmservice' (pid 265) exited with status 0
[    4.687120] init: avc:  denied  { set } for property=telephony.lteOnCdmaDevice pid=264 uid=0 gid=1001 scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[    4.689905] read descriptors
[    4.689919] read strings
[    4.720276] init: Starting service 'apk_logfs'...
[    4.724504] init: Service 'ap_log_srv' (pid 263) exited with status 0
[    4.924125] init: Untracked pid 331 exited with status 0
[    4.936034] type=1400 audit(1358499007.706:22): avc: denied { execute } for pid=307 comm="audioserver" name="sh" dev="mmcblk0p10" ino=414 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[    4.936327] type=1400 audit(1358499007.706:23): avc: denied { read open } for pid=307 comm="audioserver" path="/system/bin/sh" dev="mmcblk0p10" ino=414 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[    4.936803] type=1400 audit(1358499007.710:24): avc: denied { execute_no_trans } for pid=307 comm="audioserver" path="/system/bin/sh" dev="mmcblk0p10" ino=414 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[    4.936973] type=1400 audit(1358499007.710:25): avc: denied { getattr } for pid=307 comm="sh" path="/system/bin/sh" dev="mmcblk0p10" ino=414 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[    4.937135] type=1400 audit(1358499007.726:26): avc: denied { getattr } for pid=307 comm="sh" path="/system/bin/toybox" dev="mmcblk0p10" ino=448 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[    4.937280] type=1400 audit(1358499007.726:27): avc: denied { execute } for pid=307 comm="sh" name="toybox" dev="mmcblk0p10" ino=448 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[    4.937426] type=1400 audit(1358499007.726:28): avc: denied { read open } for pid=307 comm="sh" path="/system/bin/toybox" dev="mmcblk0p10" ino=448 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[    4.937571] type=1400 audit(1358499007.726:29): avc: denied { execute_no_trans } for pid=307 comm="sh" path="/system/bin/toybox" dev="mmcblk0p10" ino=448 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[    4.937725] type=1400 audit(1358499007.846:30): avc: denied { getattr } for pid=313 comm="sh" path="/system/xbin/vm" dev="mmcblk0p10" ino=2742 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[    4.937894] type=1400 audit(1358499007.846:31): avc: denied { execute } for pid=313 comm="sh" name="vm" dev="mmcblk0p10" ino=2742 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[    4.938037] type=1400 audit(1358499007.853:32): avc: denied { read open } for pid=325 comm="sh" path="/system/xbin/vm" dev="mmcblk0p10" ino=2742 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[    4.938208] type=1400 audit(1358499007.856:33): avc: denied { execute_no_trans } for pid=325 comm="sh" path="/system/xbin/vm" dev="mmcblk0p10" ino=2742 scontext=u:r:audioserver:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[    4.938353] type=1400 audit(1358499007.856:34): avc: denied { write } for pid=329 comm="vm" name="server" dev="tmpfs" ino=10311 scontext=u:r:audioserver:s0 tcontext=u:object_r:device:s0 tclass=sock_file permissive=1
[    4.938511] type=1400 audit(1358499007.856:35): avc: denied { connectto } for pid=329 comm="vm" path="/dev/com.koushikdutta.superuser.daemon/server" scontext=u:r:audioserver:s0 tcontext=u:r:sudaemon:s0 tclass=unix_stream_socket permissive=1
[    4.938661] type=1400 audit(1358499007.866:36): avc: denied { sys_ptrace } for pid=331 comm="vm" capability=19 scontext=u:r:sudaemon:s0 tcontext=u:r:sudaemon:s0 tclass=capability permissive=1
[    4.938818] type=1400 audit(1358499007.866:37): avc: denied { read } for pid=331 comm="vm" scontext=u:r:sudaemon:s0 tcontext=u:r:audioserver:s0 tclass=file permissive=1
[    4.938961] type=1400 audit(1358499007.866:38): avc: denied { search } for pid=331 comm="vm" name="329" dev="proc" ino=10481 scontext=u:r:sudaemon:s0 tcontext=u:r:audioserver:s0 tclass=dir permissive=1
[    4.939106] type=1400 audit(1358499007.866:39): avc: denied { read } for pid=331 comm="vm" name="exe" dev="proc" ino=10482 scontext=u:r:sudaemon:s0 tcontext=u:r:audioserver:s0 tclass=lnk_file permissive=1
[    4.939256] type=1400 audit(1358499007.873:40): avc: denied { open } for pid=333 comm="vm" path="/proc/313/cmdline" dev="proc" ino=10486 scontext=u:r:sudaemon:s0 tcontext=u:r:audioserver:s0 tclass=file permissive=1
[    4.939424] type=1400 audit(1358499007.873:41): avc: denied { setuid } for pid=333 comm="vm" capability=7 scontext=u:r:sudaemon:s0 tcontext=u:r:sudaemon:s0 tclass=capability permissive=1
[    4.939573] type=1400 audit(1358499007.873:42): avc: denied { setgid } for pid=333 comm="vm" capability=6 scontext=u:r:sudaemon:s0 tcontext=u:r:sudaemon:s0 tclass=capability permissive=1
[    4.943260] type=1400 audit(1358499007.876:43): avc: denied { execute } for pid=333 comm="vm" name="sh" dev="mmcblk0p10" ino=414 scontext=u:r:sudaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[    4.943470] type=1400 audit(1358499007.876:44): avc: denied { read open } for pid=333 comm="vm" path="/system/bin/sh" dev="mmcblk0p10" ino=414 scontext=u:r:sudaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[    4.943637] type=1400 audit(1358499007.876:45): avc: denied { execute_no_trans } for pid=333 comm="vm" path="/system/bin/sh" dev="mmcblk0p10" ino=414 scontext=u:r:sudaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[    4.943783] type=1400 audit(1358499007.876:46): avc: denied { getattr } for pid=333 comm="sh" path="/system/bin/sh" dev="mmcblk0p10" ino=414 scontext=u:r:sudaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[    4.943941] type=1400 audit(1358499007.876:47): avc: denied { getattr } for pid=333 comm="sh" path="/vendor" dev="rootfs" ino=7677 scontext=u:r:sudaemon:s0 tcontext=u:object_r:rootfs:s0 tclass=lnk_file permissive=1
[    4.944088] type=1400 audit(1358499007.883:48): avc: denied { execute } for pid=334 comm="vm" name="app_process64" dev="mmcblk0p10" ino=165 scontext=u:r:sudaemon:s0 tcontext=u:object_r:zygote_exec:s0 tclass=file permissive=1
[    4.944439] type=1400 audit(1358499007.883:49): avc: denied { read open } for pid=334 comm="vm" path="/system/bin/app_process64" dev="mmcblk0p10" ino=165 scontext=u:r:sudaemon:s0 tcontext=u:object_r:zygote_exec:s0 tclass=file permissive=1
[    4.944521] type=1400 audit(1358499007.883:50): avc: denied { execute_no_trans } for pid=334 comm="vm" path="/system/bin/app_process64" dev="mmcblk0p10" ino=165 scontext=u:r:sudaemon:s0 tcontext=u:object_r:zygote_exec:s0 tclass=file permissive=1
[    4.944593] type=1400 audit(1358499007.883:51): avc: denied { getattr } for pid=334 comm="app_process" path="/system/bin/app_process64" dev="mmcblk0p10" ino=165 scontext=u:r:sudaemon:s0 tcontext=u:object_r:zygote_exec:s0 tclass=file permissive=1
[    4.944665] type=1400 audit(1358499007.883:52): avc: denied { getattr } for pid=333 comm="sh" path="/system/bin/toybox" dev="mmcblk0p10" ino=448 scontext=u:r:sudaemon:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[    4.944811] type=1400 audit(1358499007.883:53): avc: denied { execute } for pid=333 comm="sh" name="toybox" dev="mmcblk0p10" ino=448 scontext=u:r:sudaemon:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[    4.944955] type=1400 audit(1358499007.883:54): avc: denied { read open } for pid=333 comm="sh" path="/system/bin/toybox" dev="mmcblk0p10" ino=448 scontext=u:r:sudaemon:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[    4.945105] type=1400 audit(1358499007.883:55): avc: denied { execute_no_trans } for pid=333 comm="sh" path="/system/bin/toybox" dev="mmcblk0p10" ino=448 scontext=u:r:sudaemon:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[    4.945247] type=1400 audit(1358499007.896:56): avc: denied { getattr } for pid=333 comm="chmod" path="/dev/vmdrm0" dev="tmpfs" ino=9278 scontext=u:r:sudaemon:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[    4.945390] type=1400 audit(1358499007.896:57): avc: denied { setattr } for pid=333 comm="chmod" name="vmdrm0" dev="tmpfs" ino=9278 scontext=u:r:sudaemon:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[    4.945535] type=1400 audit(1358499007.900:58): avc: denied { read write } for pid=267 comm="audioserver" name="vmdrm0" dev="tmpfs" ino=9278 scontext=u:r:audioserver:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[    4.945917] type=1400 audit(1358499007.900:59): avc: denied { open } for pid=267 comm="audioserver" path="/dev/vmdrm0" dev="tmpfs" ino=9278 scontext=u:r:audioserver:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[    4.946008] type=1400 audit(1358499007.900:60): avc: denied { ioctl } for pid=267 comm="audioserver" path="/dev/vmdrm0" dev="tmpfs" ino=9278 ioctlcmd=b503 scontext=u:r:audioserver:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[    5.027186] init: Untracked pid 345 exited with status 0
[    5.081861] healthd: BatteryCurrentNowPath not found
[    5.081894] healthd: BatteryCycleCountPath not found
[    5.373082] iep dpi mode inactivity
[    5.534910] init: Starting service 'bootanim'...
[    5.737433] Freeing drm_logo memory: 3000K
[    5.982453] type=1400 audit(1358499008.956:91): avc: denied { dac_override } for pid=334 comm="main" capability=1 scontext=u:r:sudaemon:s0 tcontext=u:r:sudaemon:s0 tclass=capability permissive=1
[    5.997321] type=1400 audit(1358499008.973:92): avc: denied { call } for pid=334 comm="main" scontext=u:r:sudaemon:s0 tcontext=u:r:servicemanager:s0 tclass=binder permissive=1
[    6.033498] init: Untracked pid 334 exited with status 1
[    6.036902] init: Untracked pid 350 exited with status 1
[    6.268915] random: nonblocking pool is initialized
[    6.583844] capability: warning: `main' uses 32-bit capabilities (legacy support in use)
[    7.498778] type=1400 audit(1358499010.473:93): avc: denied { read } for pid=267 comm="audioserver" scontext=u:r:audioserver:s0 tcontext=u:r:audioserver:s0 tclass=netlink_kobject_uevent_socket permissive=1
[   10.459915] acc_open
[   10.459942] acc_release
[   11.284278] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: mac address: 0e:65:50:53:77:29
[   11.284314] eth0: device MAC address 0e:65:50:53:77:29
[   11.331431] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.2 (r)
[   11.331487] ======== dhd_wlan_init_plat_data ========
[   11.331495] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[   11.331502] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[   11.331512] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[   11.331527] dhd_wlan_init_gpio: host_oob_irq: 74
[   11.331538] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[   11.331546] dhd_wifi_platform_load: Enter
[   11.331572] Power-up adapter 'DHD generic adapter'
[   11.332077] wifi_platform_set_power = 1
[   11.332095] ======== PULL WL_REG_ON(-1) HIGH! ========
[   11.332103] [WLAN_RFKILL]: rockchip_wifi_power: 1
[   11.332111] [WLAN_RFKILL]: wifi turn on power. -1
[   11.636437] wifi_platform_bus_enumerate device present 1
[   11.636468] ======== Card detection to detect SDIO card! ========
[   11.636478] mmc1:mmc host rescan start!
[   11.652703] bcmsdh_register: register client driver
[   11.652884] bcmsdh_sdmmc_probe: Enter num=1
[   11.652954] bcmsdh_sdmmc_probe: Enter num=2
[   11.652961] bus num (host idx)=1, slot num (rca)=1
[   11.652969] found adapter info 'DHD generic adapter'
[   11.652998] sdioh_attach: set sd_f2_blocksize 256
[   11.653075] sdioh_attach: sd clock rate = 0
[   11.653243] F1 signature read @0x18000000=0x17224356
[   11.655731] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[   11.656062] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[   11.656139] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
[   11.657021] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[   11.661468] wl_escan_attach: Enter
[   11.661524] wl_escan_init: Enter
[   11.664801] wl_create_event_handler(): thread:wl_escan_handler:32b started
[   11.665024] tsk Enter, tsk = 0xffffffc0449b01a0
[   11.667010] dhd_attach(): thread:dhd_watchdog_thread:32d started
[   11.667442] dhd_attach(): thread:dhd_dpc:338 started
[   11.667650] dhd_attach(): thread:dhd_rxf:339 started
[   11.667673] dhd_deferred_work_init: work queue initialized
[   11.667726] dhd_bus_set_default_min_res_mask: Unhandled chip id
[   11.667888] sdioh_cis_read: func_cis_ptr[0]=0x10ac
[   11.672847] Dongle Host Driver, version 1.579.77.41.2 (r)
[   11.678577] Register interface [wlan0]  MAC: ac:83:f3:9e:f0:ea
[   11.678577]
[   11.685323] dhd_wl_ioctl: returning as busstate=0
[   11.685348] dhd_dbg_detach_pkt_monitor, 2204
[   11.685358] dhd_bus_devreset: == Power OFF ==
[   11.686952] bcmsdh_oob_intr_unregister: Enter
[   11.686970] bcmsdh_oob_intr_unregister: irq is not registered
[   11.686985] dhd_txglom_enable: enable 0
[   11.686992] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[   11.687001] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=128, dhd_txminmax=-1
[   11.687008] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=5
[   11.687015] sdioh_set_mode: set txglom_mode to copy
[   11.687022] dhd_bus_devreset:  WLAN OFF DONE
[   11.687082] wifi_platform_set_power = 0
[   11.687089] ======== PULL WL_REG_ON(-1) LOW! ========
[   11.687097] [WLAN_RFKILL]: rockchip_wifi_power: 0
[   11.689482] [WLAN_RFKILL]: wifi shut off power.
[   11.689619] dhd_module_init: Exit err=0
[   11.849492] dhd_open: Enter ffffffc07bd57000
[   11.849522]
[   11.849522] Dongle Host Driver, version 1.579.77.41.2 (r)
[   11.849531] wl_android_wifi_on in 1
[   11.849538] wl_android_wifi_on in 2: g_wifi_on=0
[   11.849546] wifi_platform_set_power = 1
[   11.849552] ======== PULL WL_REG_ON(-1) HIGH! ========
[   11.849559] [WLAN_RFKILL]: rockchip_wifi_power: 1
[   11.849567] [WLAN_RFKILL]: wifi turn on power. -1
[   11.881518] type=1400 audit(1358499014.856:94): avc: denied { execute } for pid=881 comm="android.bg" name="sh" dev="mmcblk0p10" ino=414 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[   11.900557] type=1400 audit(1358499014.856:95): avc: denied { read open } for pid=881 comm="android.bg" path="/system/bin/sh" dev="mmcblk0p10" ino=414 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[   11.902088] type=1400 audit(1358499014.860:96): avc: denied { execute_no_trans } for pid=881 comm="android.bg" path="/system/bin/sh" dev="mmcblk0p10" ino=414 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[   11.902259] type=1400 audit(1358499014.863:97): avc: denied { getattr } for pid=881 comm="sh" path="/system/bin/sh" dev="mmcblk0p10" ino=414 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[   11.905828] type=1400 audit(1358499014.870:98): avc: denied { getattr } for pid=881 comm="sh" path="/system/xbin/vm" dev="mmcblk0p10" ino=2742 scontext=u:r:system_server:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[   11.906022] type=1400 audit(1358499014.870:99): avc: denied { execute } for pid=881 comm="sh" name="vm" dev="mmcblk0p10" ino=2742 scontext=u:r:system_server:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[   11.906162] type=1400 audit(1358499014.873:100): avc: denied { read open } for pid=886 comm="sh" path="/system/xbin/vm" dev="mmcblk0p10" ino=2742 scontext=u:r:system_server:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[   11.907559] type=1400 audit(1358499014.876:101): avc: denied { execute_no_trans } for pid=886 comm="sh" path="/system/xbin/vm" dev="mmcblk0p10" ino=2742 scontext=u:r:system_server:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[   11.914595] type=1400 audit(1358499014.890:102): avc: denied { write } for pid=893 comm="vm" name="server" dev="tmpfs" ino=10311 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=sock_file permissive=1
[   11.915705] type=1400 audit(1358499014.890:103): avc: denied { connectto } for pid=893 comm="vm" path="/dev/com.koushikdutta.superuser.daemon/server" scontext=u:r:system_server:s0 tcontext=u:r:sudaemon:s0 tclass=unix_stream_socket permissive=1
[   11.916464] type=1400 audit(1358499014.890:104): avc: denied { sys_ptrace } for pid=895 comm="vm" capability=19 scontext=u:r:sudaemon:s0 tcontext=u:r:sudaemon:s0 tclass=capability permissive=1
[   11.916948] type=1400 audit(1358499014.890:105): avc: denied { read } for pid=895 comm="vm" scontext=u:r:sudaemon:s0 tcontext=u:r:system_server:s0 tclass=file permissive=1
[   11.921600] type=1400 audit(1358499014.890:106): avc: denied { search } for pid=895 comm="vm" name="893" dev="proc" ino=19561 scontext=u:r:sudaemon:s0 tcontext=u:r:system_server:s0 tclass=dir permissive=1
[   11.922477] type=1400 audit(1358499014.890:107): avc: denied { read } for pid=895 comm="vm" name="exe" dev="proc" ino=17541 scontext=u:r:sudaemon:s0 tcontext=u:r:system_server:s0 tclass=lnk_file permissive=1
[   11.922651] type=1400 audit(1358499014.893:108): avc: denied { open } for pid=898 comm="vm" path="/proc/881/cmdline" dev="proc" ino=11850 scontext=u:r:sudaemon:s0 tcontext=u:r:system_server:s0 tclass=file permissive=1
[   11.924078] type=1400 audit(1358499014.893:109): avc: denied { setuid } for pid=898 comm="vm" capability=7 scontext=u:r:sudaemon:s0 tcontext=u:r:sudaemon:s0 tclass=capability permissive=1
[   11.924872] type=1400 audit(1358499014.893:110): avc: denied { setgid } for pid=898 comm="vm" capability=6 scontext=u:r:sudaemon:s0 tcontext=u:r:sudaemon:s0 tclass=capability permissive=1
[   11.925052] type=1400 audit(1358499014.893:111): avc: denied { execute } for pid=898 comm="vm" name="sh" dev="mmcblk0p10" ino=414 scontext=u:r:sudaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[   11.925601] type=1400 audit(1358499014.893:112): avc: denied { read open } for pid=898 comm="vm" path="/system/bin/sh" dev="mmcblk0p10" ino=414 scontext=u:r:sudaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[   11.925699] type=1400 audit(1358499014.893:113): avc: denied { execute_no_trans } for pid=898 comm="vm" path="/system/bin/sh" dev="mmcblk0p10" ino=414 scontext=u:r:sudaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[   11.925780] type=1400 audit(1358499014.896:114): avc: denied { execute } for pid=899 comm="vm" name="app_process64" dev="mmcblk0p10" ino=165 scontext=u:r:sudaemon:s0 tcontext=u:object_r:zygote_exec:s0 tclass=file permissive=1
[   11.930269] type=1400 audit(1358499014.896:115): avc: denied { read open } for pid=899 comm="vm" path="/system/bin/app_process64" dev="mmcblk0p10" ino=165 scontext=u:r:sudaemon:s0 tcontext=u:object_r:zygote_exec:s0 tclass=file permissive=1
[   11.930418] type=1400 audit(1358499014.896:116): avc: denied { execute_no_trans } for pid=899 comm="vm" path="/system/bin/app_process64" dev="mmcblk0p10" ino=165 scontext=u:r:sudaemon:s0 tcontext=u:object_r:zygote_exec:s0 tclass=file permissive=1
[   11.930505] type=1400 audit(1358499014.896:117): avc: denied { getattr } for pid=898 comm="sh" path="/system/bin/sh" dev="mmcblk0p10" ino=414 scontext=u:r:sudaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[   11.930581] type=1400 audit(1358499014.896:118): avc: denied { getattr } for pid=898 comm="sh" path="/vendor" dev="rootfs" ino=7677 scontext=u:r:sudaemon:s0 tcontext=u:object_r:rootfs:s0 tclass=lnk_file permissive=1
[   11.930653] type=1400 audit(1358499014.896:119): avc: denied { getattr } for pid=899 comm="app_process" path="/system/bin/app_process64" dev="mmcblk0p10" ino=165 scontext=u:r:sudaemon:s0 tcontext=u:object_r:zygote_exec:s0 tclass=file permissive=1
[   11.932590] type=1400 audit(1358499014.906:120): avc: denied { getattr } for pid=898 comm="sh" path="/system/bin/toybox" dev="mmcblk0p10" ino=448 scontext=u:r:sudaemon:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[   11.937583] type=1400 audit(1358499014.910:121): avc: denied { execute } for pid=898 comm="sh" name="toybox" dev="mmcblk0p10" ino=448 scontext=u:r:sudaemon:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[   11.937816] type=1400 audit(1358499014.913:122): avc: denied { read open } for pid=898 comm="sh" path="/system/bin/toybox" dev="mmcblk0p10" ino=448 scontext=u:r:sudaemon:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[   11.937906] type=1400 audit(1358499014.913:123): avc: denied { execute_no_trans } for pid=898 comm="sh" path="/system/bin/toybox" dev="mmcblk0p10" ino=448 scontext=u:r:sudaemon:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[   11.956568] type=1400 audit(1358499014.930:124): avc: denied { getattr } for pid=898 comm="chmod" path="/dev/vmdrm0" dev="tmpfs" ino=9278 scontext=u:r:sudaemon:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[   11.956801] type=1400 audit(1358499014.933:125): avc: denied { setattr } for pid=898 comm="chmod" name="vmdrm0" dev="tmpfs" ino=9278 scontext=u:r:sudaemon:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[   11.957920] init: Untracked pid 895 exited with status 0
[   11.960738] audit_log_lost: 35 callbacks suppressed
[   11.960753] audit: audit_lost=42 audit_rate_limit=20 audit_backlog_limit=64
[   11.960760] audit: rate limit exceeded
[   11.960917] type=1400 audit(1358499014.936:126): avc: denied { read write } for pid=589 comm="android.bg" name="vmdrm0" dev="tmpfs" ino=9278 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[   11.961080] type=1400 audit(1358499014.936:127): avc: denied { open } for pid=589 comm="android.bg" path="/dev/vmdrm0" dev="tmpfs" ino=9278 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[   11.961166] type=1400 audit(1358499014.936:128): avc: denied { ioctl } for pid=589 comm="android.bg" path="/dev/vmdrm0" dev="tmpfs" ino=9278 ioctlcmd=b503 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[   11.962724] type=1400 audit(1358499014.936:129): avc: denied { execute } for pid=906 comm="android.bg" name="sh" dev="mmcblk0p10" ino=414 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[   11.963296] type=1400 audit(1358499014.936:130): avc: denied { read open } for pid=906 comm="android.bg" path="/system/bin/sh" dev="mmcblk0p10" ino=414 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[   11.986030] init: Untracked pid 912 exited with status 0
[   12.156414] sdio_reset_comm():
[   12.169794] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[   12.186545] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[   12.234287] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[   12.237689] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[   12.241236] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[   12.247067] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[   12.358458] mmc_host mmc1: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[   12.441720] init: Untracked pid 915 exited with status 0
[   12.544093] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 110
[   12.544156] sdioh_start: set sd_f2_blocksize 256
[   12.544338]
[   12.544338]
[   12.544338] dhd_bus_devreset: == WLAN ON ==
[   12.544414] F1 signature read @0x18000000=0x17224356
[   12.547062] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[   12.547668] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[   12.547722] dhd_bus_set_default_min_res_mask: Unhandled chip id
[   12.548338] dhd_conf_read_config: Ignore config file /system/etc/firmware/config.txt
[   12.548363] Final fw_path=/system/etc/firmware/fw_bcm4356a2_ag.bin
[   12.548370] Final nv_path=/system/etc/firmware/nvram_ap6356.txt
[   12.548375] Final clm_path=/system/etc/firmware/clm_bcmdhd.blob
[   12.548381] Final conf_path=/system/etc/firmware/config.txt
[   12.548388] dhd_set_bus_params: set use_rxchain 0
[   12.548394] dhd_set_bus_params: set txinrx_thres 128
[   12.548400] dhd_set_bus_params: set txglomsize 36
[   12.548827] dhd_os_open_image: /system/etc/firmware/fw_bcm4356a2_ag.bin (558327 bytes) open success
[   12.584950] init: Untracked pid 899 exited with status 0
[   12.595254] dhd_os_open_image: /system/etc/firmware/nvram_ap6356.txt (2840 bytes) open success
[   12.595738] NVRAM version: AP6356S_NVRAM_V1.2_20170331
[   12.596220] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[   12.652607] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[   12.652833] bcmsdh_oob_intr_register HW_OOB irq=74 flags=0x4
[   12.653122] dhd_get_memdump_info: File [/data/misc/wifi/.memdump.info] doesn't exist
[   12.653130] dhd_get_memdump_info: MEMDUMP ENABLED = 2
[   12.653622] Disable tdls_auto_op failed. -1
[   12.653629] dhd_preinit_ioctls: Set tcpack_sup_mode 1
[   12.653943] dhd_apply_default_clm: Ignore clm file /system/etc/firmware/clm_bcmdhd.blob
[   12.654946] Firmware up: op_mode=0x0005, MAC=ac:83:f3:9e:f0:ea
[   12.654954] dhd_conf_set_country: set country CN, revision 38
[   12.691799] dhd_wlfc_enable: ret=0
[   12.691850] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[   12.691866] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[   12.692437] Country code: CN (CN/38)
[   12.692730] dhd_conf_set_intiovar: set roam_off 1
[   12.695011] dhd_conf_set_intiovar: set txbf 1
[   12.695490] dhd_preinit_ioctls Set scancache failed -23
[   12.695653] dhd_conf_set_intiovar: set WLC_SET_FAKEFRAG 219 1
[   12.701054]   Driver: 1.579.77.41.2 (r)
[   12.701054]   Firmware: wl0: Apr 18 2017 13:54:43 version 7.35.184.1.r5 (A2 Station/P2P) FWID 01-efd4ca0d
[   12.701054]   CLM: 7.10.16
[   12.701350] dhd_txglom_enable: enable 1
[   12.701358] dhd_conf_set_txglom_params: txglomsize=36, deferred_tx_len=36, bus_txglom=-1
[   12.701366] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=128, dhd_txminmax=-1
[   12.701372] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=5
[   12.701378] sdioh_set_mode: set txglom_mode to copy
[   12.701387] dhd_conf_get_disable_proptx: fw_proptx=1, disable_proptx=-1
[   12.703794] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
[   12.703984] dhd_conf_set_intiovar: set ampdu_hostreorder 1
[   12.704914] dhd_pno_init: Support Android Location Service
[   12.739374] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[   12.739875] rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1), status=-23
[   12.739887] dhd_rtt_init : FTM is not supported
[   12.739899] dhd_preinit_ioctls: SensorHub diabled 0
[   12.740298] dhd_preinit_ioctls failed to set ShubHub disable
[   12.740702] dhd_ndo_get_version: failed, retcode = -23
[   12.741116] dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed, ERR -23
[   12.741122] failed to get wnm_bsstrans_resp
[   12.741492] failed to set WNM capabilities
[   12.741500] wl_android_wifi_on: Success
[   12.757543] dhd_open: Exit ret=0
[   12.762464] init: Starting service 'p2p_supplicant'...
[   12.897922] P2P interface registered
[   12.897939] wl_cfgp2p_add_p2p_disc_if: wdev: ffffffc04533e800, wdev->net:           (null)
[   12.902461] WLC_E_IF: NO_IF set, event Ignored
[   12.903187] P2P interface started
[   12.935331] Random MAC OUI to be used - da:a1:19
[   12.946815] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.947158] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.947468] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.947764] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.948057] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.948356] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.948656] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.948947] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.949242] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.949557] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.949876] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.950191] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.950499] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.951246] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.951541] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.951830] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.952553] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.952841] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.953160] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.953632] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.953949] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.954270] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.954564] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.954856] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.955148] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.955440] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.955743] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.956055] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.956444] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.956763] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.957056] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.957343] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.958000] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.958291] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.958578] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.959290] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.959591] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.959894] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[   12.960003] dhd_dbg_attach_pkt_monitor, 1606
[   12.964970] net_os_enable_packet_filter: val = 0
[   12.965338] net_os_rxfilter_add_remove: add_remove = 0, num = 2
[   12.966064] net_os_enable_packet_filter: val = 1
[   12.966293] net_os_enable_packet_filter: val = 0
[   12.966626] net_os_rxfilter_add_remove: add_remove = 0, num = 3
[   12.967195] net_os_enable_packet_filter: val = 1
[   12.989555] dhd_set_suspend: Remove extra suspend setting
[   12.989572] dhd_enable_packet_filter: enter, value = 0
[   13.280416] type=1400 audit(1358499016.256:161): avc: denied { read } for pid=267 comm="audioserver" scontext=u:r:audioserver:s0 tcontext=u:r:audioserver:s0 tclass=netlink_kobject_uevent_socket permissive=1
