我在官网上下载了
内核:4.4.154 https://github.com/rockchip-linux/kernel
编译后生成 kernel.img resource.img
uboot:1.15.115 https://github.com/rockchip-linux/u-boot
编译后生成 rk3399_loader_v1.15.115.bin trust.img uboot.img
再下载 官网提供的 ubuntu1604arm64-rootfs.img 文件系统,
paramter 文件:
FIRMWARE_VER: 6.0.1
MACHINE_MODEL: RK3399
MACHINE_ID: 007
MANUFACTURER: RK3399
MAGIC: 0x5041524B
ATAG: 0x00200800
MACHINE: 3399
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
#KERNEL_IMG: 0x00280000
#FDT_NAME: rk-kernel.dtb
#RECOVER_KEY: 1,1,0,20,0
#in section; per section 512(0x200) bytes
CMDLINE: console=ttyFIQ0 root=/dev/mmcblk1p6 rw rootwait mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00008000@0x00006000(resource),0x0000A000@0x0000E000(kernel),0x00002000@0x00018000(backup),-@0x0001A000(rootfs)
再通过mkupdate.bat 制作update.img 镜像 。
通过 RKdevTool v2.54 工具烧入板子上。烧写成功后自动重启,但是一直启动不了启动log如下
DDR Version 1.15 20181010
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
pmugrf_os_reg[2] = 0x3AA17AA1, stride = 0xD
CPUId = 0x0
ChipType = 0x10, 213
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=119276MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67278
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
GPT 0x3190d20 signature is wrong
LoadTrust Addr:0x4000
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xab0f0
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):4f4079b
NOTICE: BL31: Built : 17:40:23, Oct 11 2018
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1151): pd status 3e
INFO: BL31: Initializing BL32
ERR [0x0] TEE-CORE:atags_get_tag:146: atags_get_tag: find unknown magic(f5fff9ff)
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-187-g3f0aafa6 #11 Wed Oct 31 06:55:31 UTC 2018 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09-01990-gb34cbcd (Nov 22 2018 - 10:51:38 +0800)
Model: Firefly-RK3399 Board
DRAM: 3.8 GiB
Relocation Offset is: f7d14000
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
pwm-regulator(vdd-log): init 950000 uV
vdd_log 950000 uV
regulator(vdd-log) init 950000 uV
MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
*** Warning - bad CRC, using default environment
In: serial@ff1a0000
Out: serial@ff1a0000
Err: serial@ff1a0000
mmc_init: -95, time 9
switch to partitions #0, OK
get part misc fail -1
Net: eth0: ethernet@fe300000
Hit any key to stop autoboot: 2 1 0
android_bootloader_boot_flow Could not find misc partition
android_bootloader_boot_flow Could not found bootable partition boot
=Booting Rockchip format image=
rootfs: invalid image tag(0x0)
boot_rockchip_image ramdisk part rootfs read error
init_resource_list: failed to get boot part, ret=-1
DTB: rk-kernel.dtb
kernel @ 0x02080000 (0x01292008)
ramdisk @ 0x0a200000 (0x00000000)
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Loading Ramdisk to 08200000, end 08200000 … OK
Loading Device Tree to 00000000081e5000, end 00000000081ffbda … OK
Adding bank: start=0x00200000, size=0x08200000
Adding bank: start=0x0a200000, size=0xede00000
[ 0.000000] Linux version 4.4.154 (emel@workpc) (gcc version 4.9.4 20151028 (prerelease) (Linaro GCC 4.9-2016.02) ) #2 SMP Wed Nov 21 14:22:17 CST 2018
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ed6000 s45824 r8192 d32000 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 991752
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.mode=emmc rw rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0
root=PARTUUID=614e0000-0000 rootfstype=ext4
[ 0.000000] software IO TLB [mem 0xf7e8d000-0xf7ecd000] (0MB) mapped at [ffffffc0f7e8d000-ffffffc0f7eccfff]
[ 0.000000] Memory: 3937356K/4030464K available (11710K kernel code, 1672K rwdata, 4420K rodata, 1152K init, 761K bss, 93108K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8009050000 - 0xffffff8009170000 ( 1152 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008bf0000 ( 11712 KB)
[ 0.000000] .rodata : 0xffffff8008bf0000 - 0xffffff8009050000 ( 4480 KB)
[ 0.000000] .data : 0xffffff8009170000 - 0xffffff8009312008 ( 1673 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.000000] ITS: allocated 65536 Devices @a300000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000000a290000
[ 0.000000] CPU0: using LPI pending table @0x000000000a2a0000
[ 0.002149] Console: colour dummy device 80x25
[ 0.002592] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003583] pid_max: default: 32768 minimum: 301
[ 0.004163] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004817] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006262] Initializing cgroup subsys devices
[ 0.006698] Initializing cgroup subsys freezer
[ 0.007156] ftrace: allocating 42093 entries in 165 pages
[ 0.112326] sched-energy: Sched-energy-costs installed from DT
[ 0.112894] CPU0: update cpu_capacity 401
[ 0.113341] ASID allocator initialised with 32768 entries
[ 0.116862] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.118213] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.120429] Detected VIPT I-cache on CPU1
[ 0.120461] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.120491] CPU1: using LPI pending table @0x0000000000330000
[ 0.120531] CPU1: update cpu_capacity 401
[ 0.120535] CPU1: Booted secondary processor [410fd034]
[ 0.121081] Detected VIPT I-cache on CPU2
[ 0.121102] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.121129] CPU2: using LPI pending table @0x0000000000350000
[ 0.121156] CPU2: update cpu_capacity 401
[ 0.121159] CPU2: Booted secondary processor [410fd034]
[ 0.121677] Detected VIPT I-cache on CPU3
[ 0.121697] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.121723] CPU3: using LPI pending table @0x00000000003a0000
[ 0.121749] CPU3: update cpu_capacity 401
[ 0.121752] CPU3: Booted secondary processor [410fd034]
[ 0.122301] Detected PIPT I-cache on CPU4
[ 0.122328] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.122367] CPU4: using LPI pending table @0x00000000003e0000
[ 0.122405] CPU4: update cpu_capacity 1024
[ 0.122408] CPU4: Booted secondary processor [410fd082]
[ 0.122962] Detected PIPT I-cache on CPU5
[ 0.122980] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.123016] CPU5: using LPI pending table @0x00000000f2c10000
[ 0.123041] CPU5: update cpu_capacity 1024
[ 0.123044] CPU5: Booted secondary processor [410fd082]
[ 0.123129] Brought up 6 CPUs
[ 0.135513] SMP: Total of 6 processors activated.
[ 0.135965] CPU features: detected feature: GIC system register CPU interface
[ 0.136657] CPU: All CPU(s) started at EL2
[ 0.137088] alternatives: patching kernel code
[ 0.138883] devtmpfs: initialized
[ 0.155281] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.156228] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.157286] pinctrl core: initialized pinctrl subsystem
[ 0.158512] NET: Registered protocol family 16
[ 0.163282] cpuidle: using governor ladder
[ 0.167292] cpuidle: using governor menu
[ 0.167702] Registered FIQ tty driver
[ 0.168315] vdso: 2 pages (1 code @ ffffff8008bf6000, 1 data @ ffffff8009174000)
[ 0.169033] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.169841] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.193714] console [ttyFIQ0] enabled
[ 0.194398] bootconsole [uart0] disabled
[ 0.195329] Registered fiq debugger ttyFIQ0
[ 0.225113] iommu: Adding device ff650000.vpu_service to group 0
[ 0.225714] iommu: Adding device ff660000.rkvdec to group 1
[ 0.226303] iommu: Adding device ff8f0000.vop to group 2
[ 0.226840] iommu: Adding device ff900000.vop to group 3
[ 0.227418] iommu: Adding device ff910000.cif_isp to group 4
[ 0.229399] SCSI subsystem initialized
[ 0.229906] usbcore: registered new interface driver usbfs
[ 0.230447] usbcore: registered new interface driver hub
[ 0.230987] usbcore: registered new device driver usb
[ 0.231502] media: Linux media interface: v0.10
[ 0.231929] Linux video capture interface: v2.00
[ 0.232382] pps_core: LinuxPPS API ver. 1 registered
[ 0.232834] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.233656] PTP clock support registered
[ 0.235046] Advanced Linux Sound Architecture Driver Initialized.
[ 0.236062] Bluetooth: Core ver 2.21
[ 0.236399] NET: Registered protocol family 31
[ 0.236796] Bluetooth: HCI device and connection manager initialized
[ 0.237370] Bluetooth: HCI socket layer initialized
[ 0.237806] Bluetooth: L2CAP socket layer initialized
[ 0.238280] Bluetooth: SCO socket layer initialized
[ 0.239743] clocksource: Switched to clocksource arch_sys_counter
[ 0.288085] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.288996] NET: Registered protocol family 2
[ 0.289812] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.290707] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.292145] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.292828] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.293517] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.294446] NET: Registered protocol family 1
[ 0.295152] RPC: Registered named UNIX socket transport module.
[ 0.295685] RPC: Registered udp transport module.
[ 0.296124] RPC: Registered tcp transport module.
[ 0.296545] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.298174] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.298993] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.302712] Initialise system trusted keyring
[ 0.310898] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.312172] NFS: Registering the id_resolver key type
[ 0.312633] Key type id_resolver registered
[ 0.313023] Key type id_legacy registered
[ 0.313437] fuse init (API version 7.23)
[ 0.314178] SGI XFS with security attributes, no debug enabled
[ 0.319505] NET: Registered protocol family 38
[ 0.319939] Key type asymmetric registered
[ 0.320309] Asymmetric key parser ‘x509’ registered
[ 0.320908] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.321569] io scheduler noop registered
[ 0.321938] io scheduler deadline registered
[ 0.322432] io scheduler cfq registered (default)
[ 0.324428] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator
[ 0.329845] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.330426] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.331016] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.872792] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.873516] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.875292] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.876200] rk-vcodec ff650000.vpu_service: probe device
[ 0.876985] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 0.878344] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.878980] rk-vcodec ff650000.vpu_service: init success
[ 0.879887] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.880942] rk-vcodec ff660000.rkvdec: probe device
[ 0.881579] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 0.882552] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.883140] rk-vcodec ff660000.rkvdec: init success
[ 0.884981] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.885649] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.887879] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.888547] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.890433] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.892598] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 0.893691] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
[ 0.894642] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[ 0.895259] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer on device rockchip-pinctrl
[ 0.896258] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
[ 0.897242] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.899053] [drm] Initialized drm 1.1.0 20060810
[ 0.902419] [drm] Rockchip DRM driver version: v1.0.1
[ 0.903181] rockchip-drm display-subsystem: dmc is disabled
[ 0.903961] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 0.904786] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008c8eaa0)
[ 0.905517] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 0.906302] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008c8eaa0)
[ 0.907276] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 0.907882] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.908658] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.910212] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008c85048)
[ 0.910944] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.911526] [drm] No driver support for vblank timestamp query.
[ 0.912219] rockchip-drm display-subsystem: failed to parse loader memory
[ 1.041143] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[ 1.162355] Console: switching to colour frame buffer device 240x67
[ 1.243533] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.253378] mali ff9a0000.gpu: Failed to get regulator
[ 1.253857] mali ff9a0000.gpu: Power control initialization failed
[ 1.254989] Unable to detect cache hierarchy for CPU 0
[ 1.256283] brd: module loaded
[ 1.261700] loop: module loaded
[ 1.262530] zram: Added device: zram0
[ 1.263145] lkdtm: No crash points registered, enable through debugfs
[ 1.265481] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.266118] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.266622] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[ 1.267150] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.267880] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.268497] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.274049] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.274662] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.275116] Ring mode enabled
[ 1.275387] DMA HW capability register supported
[ 1.275792] Normal descriptors
[ 1.276097] RX Checksum Offload Engine supported (type 2)
[ 1.276585] TX Checksum insertion supported
[ 1.276966] Wake-Up On Lan supported
[ 1.277327] Enable RX Mitigation via HW Watchdog Timer
[ 1.342901] libphy: stmmac: probed
[ 1.343211] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.343792] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.345500] usbcore: registered new interface driver rndis_wlan
[ 1.346374] Rockchip WiFi SYS interface (V1.00) …
[ 1.346947] usbcore: registered new interface driver rtl8150
[ 1.347493] usbcore: registered new interface driver r8152
[ 1.348064] usbcore: registered new interface driver asix
[ 1.348588] usbcore: registered new interface driver ax88179_178a
[ 1.349183] usbcore: registered new interface driver cdc_ether
[ 1.349758] usbcore: registered new interface driver rndis_host
[ 1.350364] usbcore: registered new interface driver cdc_ncm
[ 1.350926] usbcore: registered new interface driver cdc_mbim
[ 1.353392] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 1.358664] rockchip-dwc3 usb1: fail to get drvdata hcd
[ 1.360893] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.361491] ehci-pci: EHCI PCI platform driver
[ 1.362028] ehci-platform: EHCI generic platform driver
[ 1.366609] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.367385] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.368242] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.374775] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.375540] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.376166] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.376820] usb usb1: Product: EHCI Host Controller
[ 1.377255] usb usb1: Manufacturer: Linux 4.4.154 ehci_hcd
[ 1.377758] usb usb1: SerialNumber: fe3c0000.usb
[ 1.378822] hub 1-0:1.0: USB hub found
[ 1.379196] hub 1-0:1.0: 1 port detected
[ 1.380345] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.380925] ohci-platform: OHCI generic platform driver
[ 1.382088] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.382959] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.383793] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.438957] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.439565] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.440218] usb usb2: Product: Generic Platform OHCI controller
[ 1.440759] usb usb2: Manufacturer: Linux 4.4.154 ohci_hcd
[ 1.441250] usb usb2: SerialNumber: fe3e0000.usb
[ 1.442301] hub 2-0:1.0: USB hub found
[ 1.442674] hub 2-0:1.0: 1 port detected
[ 1.444355] usbcore: registered new interface driver cdc_acm
[ 1.444871] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.445629] usbcore: registered new interface driver cdc_wdm
[ 1.446200] usbcore: registered new interface driver uas
[ 1.446795] usbcore: registered new interface driver usb-storage
[ 1.447436] usbcore: registered new interface driver usbserial
[ 1.448008] usbcore: registered new interface driver usbserial_generic
[ 1.448621] usbserial: USB Serial support registered for generic
[ 1.449217] usbcore: registered new interface driver cp210x
[ 1.449757] usbserial: USB Serial support registered for cp210x
[ 1.450348] usbcore: registered new interface driver ftdi_sio
[ 1.450911] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.451708] usbcore: registered new interface driver keyspan
[ 1.452256] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.452999] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.453678] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.454375] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.455088] usbcore: registered new interface driver option
[ 1.455613] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.456424] usbcore: registered new interface driver oti6858
[ 1.456972] usbserial: USB Serial support registered for oti6858
[ 1.457553] usbcore: registered new interface driver pl2303
[ 1.458088] usbserial: USB Serial support registered for pl2303
[ 1.458664] usbcore: registered new interface driver qcserial
[ 1.459220] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.459912] usbcore: registered new interface driver sierra
[ 1.460437] usbserial: USB Serial support registered for Sierra USB modem
[ 1.462561] usbcore: registered new interface driver usbtouchscreen
[ 1.464056] i2c /dev entries driver
[ 1.466280] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.467047] fan53555-reg: supplied by vcc5v0_sys
[ 1.470010] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.470710] fan53555-reg: supplied by vcc5v0_sys
[ 1.474280] rk808 0-001b: Pmic Chip id: 0x0
[ 1.478432] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.479064] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.479823] DCDC_REG1: supplied by vcc3v3_sys
[ 1.481181] DCDC_REG2: supplied by vcc3v3_sys
[ 1.482315] DCDC_REG3: supplied by vcc3v3_sys
[ 1.483127] DCDC_REG4: supplied by vcc3v3_sys
[ 1.484132] LDO_REG1: supplied by vcc3v3_sys
[ 1.485850] LDO_REG2: supplied by vcc3v3_sys
[ 1.487402] LDO_REG3: supplied by vcc3v3_sys
[ 1.488989] LDO_REG4: supplied by vcc3v3_sys
[ 1.490550] LDO_REG5: supplied by vcc3v3_sys
[ 1.492116] LDO_REG6: supplied by vcc3v3_sys
[ 1.493692] LDO_REG7: supplied by vcc3v3_sys
[ 1.495273] LDO_REG8: supplied by vcc3v3_sys
[ 1.496852] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.497716] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.502006] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.503069] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009576000
[ 1.504814] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009578000
[ 1.505595] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 1.506539] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 1.507139] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 1.508132] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 1.509313] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff800957a000
[ 1.511640] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 1.520934] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.521766] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800957c000
[ 1.523978] IR NEC protocol handler initialized
[ 1.525624] usbcore: registered new interface driver uvcvideo
[ 1.526151] USB Video Class driver (1.1.1)
[ 1.530241] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.531244] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 1.532958] Bluetooth: Virtual HCI driver ver 1.5
[ 1.533484] Bluetooth: HCI UART driver ver 2.3
[ 1.533905] Bluetooth: HCI UART protocol H4 registered
[ 1.534361] Bluetooth: HCI UART protocol LL registered
[ 1.534825] Bluetooth: HCI UART protocol ATH3K registered
[ 1.535366] usbcore: registered new interface driver bfusb
[ 1.535918] usbcore: registered new interface driver btusb
[ 1.536867] cpu cpu0: leakage=25
[ 1.538398] cpu cpu4: leakage=46
[ 1.540527] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.542367] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.545074] sdhci: Secure Digital Host Controller Interface driver
[ 1.545623] sdhci: Copyright(c) Pierre Ossman
[ 1.546036] Synopsys Designware Multimedia Card Interface Driver
[ 1.547368] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.548052] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.548655] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.549217] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.550153] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.550701] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.552084] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.552759] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.553360] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.553918] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.554887] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.555664] vcc_sd: unsupportable voltage range: 3300000-3000000uV
[ 1.556238] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 1.556906] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 1.567796] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.579012] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.579912] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.582171] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.582697] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.609840] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.611572] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.612644] usbcore: registered new interface driver usbhid
[ 1.613185] usbhid: USB HID core driver
[ 1.616062] usbcore: registered new interface driver snd-usb-audio
[ 1.634509] Initializing XFRM netlink socket
[ 1.635549] NET: Registered protocol family 10
[ 1.637410] NET: Registered protocol family 17
[ 1.637871] NET: Registered protocol family 15
[ 1.638612] Bluetooth: RFCOMM socket layer initialized
[ 1.639278] Bluetooth: RFCOMM ver 1.11
[ 1.639651] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.640213] Bluetooth: HIDP socket layer initialized
[ 1.640712] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.641433] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.641909] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354
[ 1.642516] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.643159] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.643884] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.644679] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.645329] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.645807] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.646281] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.647023] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.647779] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.648499] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.649228] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.649961] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 1.650607] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.651126] [BT_RFKILL]: ** disable irq
[ 1.651593] [BT_RFKILL]: bt_default device registered.
[ 1.652121] Key type dns_resolver registered
[ 1.653470] Registered cp15_barrier emulation handler
[ 1.654084] Registered setend emulation handler
[ 1.655068] Loading compiled-in X.509 certificates
[ 1.655373] mmc1: MAN_BKOPS_EN bit is not set
[ 1.657509] phy phy-ff770000.syscon:usb2-phy@e450.7: Failed to get VBUS supply regulator
[ 1.660816] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.661664] mali ff9a0000.gpu: Protected mode not available
[ 1.662916] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.663776] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 1.665941] mali ff9a0000.gpu: Probed as mali0
[ 1.668748] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.670313] mmcblk1: mmc1:0001 DJNB4R 116 GiB
[ 1.670962] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[ 1.671385] mmcblk1boot0: mmc1:0001 DJNB4R partition 1 4.00 MiB
[ 1.671992] mmcblk1boot1: mmc1:0001 DJNB4R partition 2 4.00 MiB
[ 1.672284] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 3
[ 1.672475] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 1.672536] xhci-hcd xhci-hcd.7.auto: irq 227, io mem 0xfe800000
[ 1.672758] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.672765] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.672771] usb usb3: Product: xHCI Host Controller
[ 1.672777] usb usb3: Manufacturer: Linux 4.4.154 xhci-hcd
[ 1.672783] usb usb3: SerialNumber: xhci-hcd.7.auto
[ 1.673446] hub 3-0:1.0: USB hub found
[ 1.673482] hub 3-0:1.0: 1 port detected
[ 1.673910] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[ 1.674118] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 4
[ 1.674205] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.674330] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.674337] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.674343] usb usb4: Product: xHCI Host Controller
[ 1.674348] usb usb4: Manufacturer: Linux 4.4.154 xhci-hcd
[ 1.674354] usb usb4: SerialNumber: xhci-hcd.7.auto
[ 1.674969] hub 4-0:1.0: USB hub found
[ 1.675000] hub 4-0:1.0: 1 port detected
[ 1.676843] xhci-hcd xhci-hcd.7.auto: remove, state 1
[ 1.676868] usb usb4: USB disconnect, device number 1
[ 1.681760] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.685039] mmcblk1rpmb: mmc1:0001 DJNB4R partition 3 4.00 MiB
[ 1.700899] xhci-hcd xhci-hcd.7.auto: Host not halted after 16000 microseconds.
[ 1.701548] xhci-hcd xhci-hcd.7.auto: Host controller not halted, aborting reset.
[ 1.702256] xhci-hcd xhci-hcd.7.auto: USB bus 4 deregistered
[ 1.703181] xhci-hcd xhci-hcd.7.auto: remove, state 1
[ 1.703652] usb usb3: USB disconnect, device number 1
[ 1.704778] xhci-hcd xhci-hcd.7.auto: USB bus 3 deregistered
[ 1.710060] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[ 1.710781] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 3
[ 1.711617] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 1.712466] xhci-hcd xhci-hcd.8.auto: irq 228, io mem 0xfe900000
[ 1.713182] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.713806] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.714444] usb usb3: Product: xHCI Host Controller
[ 1.714897] usb usb3: Manufacturer: Linux 4.4.154 xhci-hcd
[ 1.715382] usb usb3: SerialNumber: xhci-hcd.8.auto
[ 1.716425] hub 3-0:1.0: USB hub found
[ 1.716822] hub 3-0:1.0: 1 port detected
[ 1.717527] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[ 1.718211] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 4
[ 1.718977] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.719831] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.720436] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.721131] usb usb4: Product: xHCI Host Controller
[ 1.721570] usb usb4: Manufacturer: Linux 4.4.154 xhci-hcd
[ 1.722072] usb usb4: SerialNumber: xhci-hcd.8.auto
[ 1.723076] hub 4-0:1.0: USB hub found
[ 1.723440] hub 4-0:1.0: 1 port detected
[ 1.728532] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.729611] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 1.730526] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.789826] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.790665] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.791292] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.791947] usb usb5: Product: EHCI Host Controller
[ 1.792391] usb usb5: Manufacturer: Linux 4.4.154 ehci_hcd
[ 1.792903] usb usb5: SerialNumber: fe380000.usb
[ 1.794268] hub 5-0:1.0: USB hub found
[ 1.794642] hub 5-0:1.0: 1 port detected
[ 1.796204] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.796973] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.797580] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.798257] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.799327] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 1.800211] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.800358] hub 1-1:1.0: USB hub found
[ 1.800812] hub 1-1:1.0: 7 ports detected
[ 1.856230] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.856863] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.857504] usb usb6: Product: Generic Platform OHCI controller
[ 1.858044] usb usb6: Manufacturer: Linux 4.4.154 ohci_hcd
[ 1.858535] usb usb6: SerialNumber: fe3a0000.usb
[ 1.860313] hub 6-0:1.0: USB hub found
[ 1.860698] hub 6-0:1.0: 1 port detected
[ 1.862886] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.863564] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.864196] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.864768] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.865752] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.866303] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.867341] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.880086] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.892248] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.908793] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 1.916395] asoc-simple-card hdmi-codec: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 1.922850] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0
[ 1.923492] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22
[ 1.924159] asoc-simple-card spdif-sound: ASoC: can’t create pcm ff870000.spdif-dit-hifi :-22
[ 1.924949] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22
[ 1.926020] asoc-simple-card: probe of spdif-sound failed with error -22
[ 1.927835]
[ 1.927933] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.9 (r)
[ 1.927942] ======== dhd_wlan_init_plat_data ========
[ 1.927948] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.927960] dhd_wlan_init_gpio: WL_REG_ON=-1, WL_HOST_WAKE=-1
[ 1.927967] dhd_wlan_init_gpio: oob_irq=68, oob_irq_flags=0x414
[ 1.927971] dhd_wifi_platform_load: Enter
[ 1.928000] Power-up adapter ‘DHD generic adapter’
[ 1.928078] wifi_platform_set_power = 1
[ 1.928083] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.928089] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.928095] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.933126] =======================================================
[ 1.933684] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 1.934260] =======================================================
[ 1.934840] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver v5.2.2.3_24783.20171030) init.
[ 1.935634] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.936088] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.936517] RTW: module init start
[ 1.936851] RTW: rtl8188eu v5.2.2.3_24783.20171030
[ 1.937282] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.938083] usbcore: registered new interface driver rtl8188eu
[ 1.938608] RTW: module init ret=0
[ 1.938788] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.940507] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.941125] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 1.942783] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.944439] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:06 UTC (1358499006)
[ 1.946364] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.976314] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko
is ‘’, rk_ko_ver is ‘5’, built at ‘14:14:58’, on ‘Nov 21 2018’.
[ 1.978641] Mali: Mali device driver loaded
[ 1.979750] ALSA device list:
[ 1.980021] #0: rockchip,rt5640-codec
[ 1.980359] #1: HDMI-CODEC
[ 1.980922] Waiting for root device PARTUUID=614e0000-0000…
[ 2.004181] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.017622] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 313
[ 2.021928] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.022461] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 2.097900] usb 1-1.1: new low-speed USB device number 3 using ehci-platform
[ 2.181541] vendor storage:20160801 ret = 0
[ 2.189112] usb 1-1.1: New USB device found, idVendor=0e8f, idProduct=00fb
[ 2.189778] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.190436] usb 1-1.1: Product: USB Mouse
[ 2.190839] usb 1-1.1: Manufacturer: YSTEK
[ 2.197173] input: YSTEK USB Mouse as /devices/platform/fe3c0000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:0E8F:00FB.0001/input/input1
[ 2.229010] wifi_platform_bus_enumerate device present 1
[ 2.229491] ======== Card detection to detect SDIO card! ========
[ 2.230105] mmc2:mmc host rescan start!
[ 2.246706] bcmsdh_register: register client driver
[ 2.247766] bcmsdh_sdmmc_probe: Enter num=1
[ 2.248691] bcmsdh_sdmmc_probe: Enter num=2
[ 2.249116] bus num (host idx)=2, slot num (rca)=1
[ 2.249549] found adapter info ‘DHD generic adapter’
[ 2.250734] hid-generic 0003:0E8F:00FB.0001: input,hidraw0: USB HID v1.10 Mouse [YSTEK USB Mouse] on usb-fe3c0000.usb-1.1/input0
[ 2.250828] sdioh_attach: set sd_f2_blocksize 256
[ 2.252492] sdioh_attach: sd clock rate = 0
[ 2.255839] dhdsdio_probe : no mutex held. set lock
[ 2.257234] F1 signature read @0x18000000=0x17224356
[ 2.275544] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[ 2.278262] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 2.279175] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
[ 2.280028] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 2.282099] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 2.283013] wl_escan_attach: Enter
[ 2.283363] wl_escan_init: Enter
[ 2.284156] wl_create_event_handler(): thread:wl_escan_handler:a0 started
[ 2.284834] dhd_init_logstrs_array: Failed to open the file /installmedia/logstrs.bin
[ 2.285796] tsk Enter, tsk = 0xffffffc0f13701b0
[ 2.286305] dhd_attach(): thread:dhd_watchdog_thread:a1 started
[ 2.287288] dhd_attach(): thread:dhd_dpc:a2 started
[ 2.288307] dhd_attach(): thread:dhd_rxf:a3 started
[ 2.288795] dhd_deferred_work_init: work queue initialized
[ 2.289325] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 2.290873] sdioh_cis_read: func_cis_ptr[0]=0x10ac
[ 2.306976] Dongle Host Driver, version 1.579.77.41.9 (r)
[ 2.308767] wl_ext_iapsta_attach_netdev: bssidx=0
[ 2.309229] Register interface [wlan0] MAC: cc:4b:73:1d:df:86
[ 2.309229]
[ 2.310162] dhd_wl_ioctl: returning as busstate=0
[ 2.310598] dhd_dbg_detach_pkt_monitor, 2204
[ 2.311019] dhd_bus_devreset: == Power OFF ==
[ 2.311760] bcmsdh_oob_intr_unregister: Enter
[ 2.312158] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.312677] dhd_txglom_enable: enable 0
[ 2.313051] dhd_conf_set_txglom_params: txglom_mode=copy
[ 2.313528] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0
[ 2.314145] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=128, dhd_txminmax=-1
[ 2.314864] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300
[ 2.315481] dhd_bus_devreset: WLAN OFF DONE
[ 2.315958] wifi_platform_set_power = 0
[ 2.316323] ======== PULL WL_REG_ON(-1) LOW! ========
[ 2.316837] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.318593] [WLAN_RFKILL]: wifi shut off power.
[ 2.319048] dhdsdio_probe : the lock is released.
[ 2.319765] dhd_module_init: Exit err=0
[ 20.868040] random: nonblocking pool is initialized
=====================分界线=======================
希望各位大神给点建议,是哪里出了问题啊,非常感谢!
