刷了官方的安卓7.1系统,进入系统设置中依然无法打开wifi功能。无论我怎么拨动wifi开关,但都打不开wifi功能。
下面是串口日志
DDR version 1.08 20170628
DDR4
333MHz
Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
ddrconfig:14
Boot1 Release Time: 2017-06-12, version: 2.44
ChipType = 0x11, 184
emmc reinit
emmc reinit
SdmmcInit=2 20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=7728MB
FwPartOffset=2000 , 0
run on sd0
StorageInit ok = 48613
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x582e4
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):f947c7e
NOTICE: BL31: Built : 09:28:45, May 31 2017
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:336: Initializing (1.1.0-87-g80b20ce #1 Mon May 22 06:34:06 UTC 2017 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:337: Release version: 1.3
INFO: SPSR = 0x3c9
U-Boot 2017.02-RK3328-06 (Jul 26 2018 - 14:14:04)
CPU: rk3328
cpu version = 1
CPU’s clock information:
arm pll = 600000000HZ
general pll = 800000000HZ
ddr pll = 664000000HZ
codec pll = 594000000HZ
new pll = 594000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Adding bank:0000000000200000(000000003fe00000)
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01000000
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 0
SDCard Boot.
storage init OK!
GetParam
remotectl v0.1
pwm freq=0x11b3dc
pwm_freq_nstime=0x35d
Load FDT from resource image.
power key: bank-16777215 pin-255
rk816_set_regulator_init vdd_arm init uV:1225000
rk805 pre init: 0x19 = 0x08
rk805 pre init: new otp ver, skip operation
pmic:rk805
can’t find dts node for pwm0
arm pll = 1200000000HZ
#Boot ver: 0000-00-00#0.00
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
can’t find dts node for deviceinfo
rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
left = 0, right = 0, top = 0, bottom = 0, overscan = 0
panel->left = 100 , panel->right = 100 ,panel->top = 100, panel->bottom = 100, panel->overscan = 100
tve baseparamer 0x0@0-0
[EDID-EXTEND] It is a CEA 861 Series Extension.
no baseparametr,find best edid mode,vic=16
hdmi_dev->video.vic is 16
hdmi_dev_config_video vic 16 color_output 3 color_output_depth 8
pixel clk is 148500000 tmds clk is 148500000
hsync_pol 1 vsync_pol 1
[HDMI] sucess output HDMI.
no fuel gauge found
checkKey
vbus = 1
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x00e5f008)
ramdisk @ 0x05bf0000 (0x0019d02c)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 000000000561d83d … OK
Add bank:0000000009400000, 0000000036c00000
[ 0.000000] [0: swapper: 0] Initializing cgroup subsys cpuset [ 0.000000] [0: swapper: 0] Initializing cgroup subsys cpu [ 0.000000] [0: swapper: 0] Initializing cgroup subsys cpuacct [ 0.000000] [0: swapper: 0] Linux version 3.10.104 (zouxf@tchipser14) (gcc version 4.9 20150123 (prerelease) (GCC) ) #12 SMP PREEMPT Sat Aug 4 17:07:17 HKT 2018 [ 0.000000] [0: swapper: 0] CPU: AArch64 Processor [410fd034] revision 4 [ 0.000000] [0: swapper: 0] Machine: rockchip,roc-rk3328-cc [ 0.000000] [0: swapper: 0] rockchip_uboot_logo_setup: mem: 0x0000000002000000@0x000000003dc00000, offset:0x0000000000000000 [ 0.000000] [0: swapper: 0] hdmi init vic is 16 [ 0.000000] [0: swapper: 0] cvbs init tve.format is -1 [ 0.000000] [0: swapper: 0] cvbs init tve.format is -1 [ 0.000000] [0: swapper: 0] cvbs init tve.format is -1 [ 0.000000] [0: swapper: 0] rockchip_uboot_mem_reserve: reserve 0x0000000002000000@0x000000003dc00000 for uboot logo [ 0.000000] [0: swapper: 0] rockchip_ion_reserve [ 0.000000] [0: swapper: 0] ion heap(cma): base(0) size(0) align(0) [ 0.000000] [0: swapper: 0] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] [0: swapper: 0] cma: CMA: reserved 16 MiB at 3cc00000 [ 0.000000] [0: swapper: 0] psci: probing for conduit method from DT. [ 0.000000] [0: swapper: 0] psci: PSCIv1.0 detected in firmware. [ 0.000000] [0: swapper: 0] psci: Using standard PSCI v0.2 function IDs [ 0.000000] [0: swapper: 0] PERCPU: Embedded 12 pages/cpu @ffffffc03fd39000 s18752 r8192 d22208 u49152 [ 0.000000] [0: swapper: 0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 253959 [ 0.000000] [0: swapper: 0] Kernel command line: earlyprintk=uart8250-32bit,0xff130000 console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00004000@0x00004000(trust),0x00002000@0x00008000(misc),0x00000800@0x0000A000(baseparamer),0x00007800@0x0000A800(resource),0x00010000@0x00012000(kernel),0x00010000@0x00022000(boot),0x00010000@0x00032000(recovery),0x00020000@0x00042000(backup),0x00040000@0x00062000(cache),0x00008000@0x000A2000(metadata),0x00002000@0x000AA000(kpanic),0x00300000@0x000AC000(system),-@0x003AC000(userdata) storagemedia=sd androidboot.mode=sd uboot_logo=0x02000000@0x3dc00000 loader.timestamp=2018-07-26_14:14:04 hdmi.vic=16 tve.format=-1 SecureBootCheckOk=0 [ 0.000000] [0: swapper: 0] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] [0: swapper: 0] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.000000] [0: swapper: 0] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes) [ 0.000000] [0: swapper: 0] Memory: 130MB 876MB = 1006MB total [ 0.000000] [0: swapper: 0] Memory: 946712k/946712k available, 83432k reserved [ 0.000000] [0: swapper: 0] Virtual kernel memory layout: [ 0.000000] [0: swapper: 0] vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000 (245759 MB) [ 0.000000] [0: swapper: 0] vmemmap : 0xffffffbc00007000 - 0xffffffbc00e00000 ( 13 MB) [ 0.000000] [0: swapper: 0] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB) [ 0.000000] [0: swapper: 0] memory : 0xffffffc000000000 - 0xffffffc03fe00000 ( 1022 MB) [ 0.000000] [0: swapper: 0] .init : 0xffffffc000c9d000 - 0xffffffc000cfe940 ( 391 kB) [ 0.000000] [0: swapper: 0] .text : 0xffffffc000080000 - 0xffffffc000c9ca24 ( 12403 kB) [ 0.000000] [0: swapper: 0] .data : 0xffffffc000cff000 - 0xffffffc000edf008 ( 1921 kB) [ 0.000000] [0: swapper: 0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] [0: swapper/0: 0] Preemptible hierarchical RCU implementation. [ 0.000000] [0: swapper/0: 0] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] [0: swapper/0: 0] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] [0: swapper/0: 0] Architected cp15 timer(s) running at 24.00MHz (phys). [ 2.369561] [0: swapper/0: 0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 2.369583] [0: swapper/0: 0] pid_max: default: 32768 minimum: 301 [ 2.369692] [0: swapper/0: 0] Security Framework initialized [ 2.369718] [0: swapper/0: 0] SELinux: Initializing. [ 2.369814] [0: swapper/0: 0] Mount-cache hash table entries: 256 [ 2.370418] [0: swapper/0: 0] Initializing cgroup subsys debug [ 2.370439] [0: swapper/0: 0] Initializing cgroup subsys freezer [ 2.370923] [0: swapper/0: 1] /cpus/cpu@0: Missing clock-frequency property [ 2.370963] [0: swapper/0: 1] /cpus/cpu@1: Missing clock-frequency property [ 2.370999] [0: swapper/0: 1] /cpus/cpu@2: Missing clock-frequency property [ 2.371034] [0: swapper/0: 1] /cpus/cpu@3: Missing clock-frequency property [ 2.371052] [0: swapper/0: 1] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available [ 2.372657] [0: swapper/0: 1] last_log: 0x000000003b400000 map to 0xffffff8000006000 and copy to 0xffffff8000088000, size 0x80000 early 0x1897 (version 3.1) [ 2.398507] [1: swapper/1: 0] CPU1: Booted secondary processor [ 2.401771] [2: swapper/2: 0] CPU2: Booted secondary processor [ 2.408342] [3: swapper/3: 0] CPU3: Booted secondary processor [ 2.408450] [0: swapper/0: 1] Brought up 4 CPUs [ 2.408482] [0: swapper/0: 1] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 2.409283] [0: swapper/0: 1] devtmpfs: initialized [ 2.413899] [0: swapper/0: 1] pinctrl core: initialized pinctrl subsystem [ 2.414229] [0: swapper/0: 1] regulator-dummy: no parameters [ 2.424265] [0: swapper/0: 1] NET: Registered protocol family 16 [ 2.425200] [0: swapper/0: 1] ion_snapshot: 0x3b6c8000 map to 0xffffff8000109000 and copy to 0xffffffc000fb3960 (version 0.1) [ 2.425658] [0: swapper/0: 1] Registered FIQ tty driver [ 2.426128] [0: swapper/0: 1] vdso: 2 pages (1 code, 1 data) at base ffffffc000d05000 [ 2.426159] [0: swapper/0: 1] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 2.428171] [0: swapper/0: 1] software IO TLB [mem 0x3b000000-0x3b400000] (4MB) mapped at [ffffffc03ae00000-ffffffc03b1fffff] [ 2.430030] [0: swapper/0: 1] DMA: preallocated 2048 KiB pool for atomic allocations [ 2.430057] [0: swapper/0: 1] rockchip sip version v2 [ 2.431394] [0: swapper/0: 1] rk3368_init_rockchip_pmu_ops: could not find pmu dt node [ 2.431491] [0: swapper/0: 1] rk_clk_tree_init start! [ 2.446320] [0: swapper/0: 1] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 2.446401] [0: swapper/0: 1] rkclk_init_clks: cnt_parent = 12 [ 2.446761] [0: swapper/0: 1] rkclk_init_clks: cnt_rate = 29 [ 2.447332] [0: swapper/0: 1] rkclk: gcd=0, frac div is not be supported [ 2.447359] [0: swapper/0: 1] rkclk: clk_frac_div name=uart2_frac can't get rate=0 [ 2.447388] [0: swapper/0: 1] rkclk: gcd=0, frac div is not be supported [ 2.447412] [0: swapper/0: 1] rkclk: clk_frac_div name=uart1_frac can't get rate=0 [ 2.447441] [0: swapper/0: 1] rkclk: gcd=0, frac div is not be supported [ 2.447464] [0: swapper/0: 1] rkclk: clk_frac_div name=uart0_frac can't get rate=0 [ 2.449077] [0: swapper/0: 1] rkclk: warning: clk_rate < 1*MHZ or > 2000*MHZ [ 2.449779] [0: swapper/0: 1] rkclk: warning: clk_rate < 1*MHZ or > 2000*MHZ [ 2.464998] [0: swapper/0: 1] syscon ff100000.syscon: regmap [mem 0xff100000-0xff100fff] registered [ 2.465237] [0: swapper/0: 1] syscon ff140000.syscon: regmap [mem 0xff140000-0xff140fff] registered [ 2.467575] [0: swapper/0: 1] rk_iommu ff330200.h265e_mmu: (h265e) Enter [ 2.467718] [0: swapper/0: 1] rk_iommu ff330200.h265e_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 2.467747] [0: swapper/0: 1] rk_iommu ff330200.h265e_mmu: (h265e) Initialized [ 2.468158] [0: swapper/0: 1] rk_iommu ff340800.vepu_mmu: (vepu) Enter [ 2.468259] [0: swapper/0: 1] rk_iommu ff340800.vepu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 2.468287] [0: swapper/0: 1] rk_iommu ff340800.vepu_mmu: (vepu) Initialized [ 2.468985] [0: swapper/0: 1] rk_iommu ff350800.vpu_mmu: (vpu) Enter [ 2.469093] [0: swapper/0: 1] rk_iommu ff350800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 2.469120] [0: swapper/0: 1] rk_iommu ff350800.vpu_mmu: (vpu) Initialized [ 2.469530] [0: swapper/0: 1] rk_iommu ff360480.vdec_mmu: (vdec) Enter [ 2.469628] [0: swapper/0: 1] rk_iommu ff360480.vdec_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 2.469656] [0: swapper/0: 1] rk_iommu ff360480.vdec_mmu: (vdec) Initialized [ 2.470151] [0: swapper/0: 1] rk_iommu ff373f00.vopb_mmu: (vopb) Enter [ 2.470241] [0: swapper/0: 1] rk_iommu ff373f00.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 2.470269] [0: swapper/0: 1] rk_iommu ff373f00.vopb_mmu: (vopb) Initialized [ 2.470812] [0: swapper/0: 1] rk_iommu ff3a0800.iep_mmu: (iep) Enter [ 2.470909] [0: swapper/0: 1] rk_iommu ff3a0800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 2.470937] [0: swapper/0: 1] rk_iommu ff3a0800.iep_mmu: (iep) Initialized [ 2.471696] [0: swapper/0: 1] syscon ff440000.syscon: regmap [mem 0xff440000-0xff440fff] registered [ 2.472026] [0: swapper/0: 1] syscon ff450000.syscon: regmap [mem 0xff450000-0xff450fff] registered [ 2.472398] [0: swapper/0: 1] syscon ff460000.syscon: regmap [mem 0xff460000-0xff460fff] registered [ 2.474304] [0: swapper/0: 1] syscon ff720000.syscon: regmap [mem 0xff720000-0xff722fff] registered [ 2.474521] [0: swapper/0: 1] syscon ff780000.syscon: regmap [mem 0xff780000-0xff782fff] registered [ 2.474743] [0: swapper/0: 1] syscon ff790000.syscon: regmap [mem 0xff790000-0xff7902ff] registered [ 2.488228] [0: swapper/0: 1] console [ttyFIQ0] enabled [ 2.488532] [0: swapper/0: 1] Registered fiq debugger ttyFIQ0 [ 2.488947] [0: swapper/0: 1] process version: 0 [ 2.489116] [0: swapper/0: 1] channel:0, lkg:10 [ 2.489147] [0: swapper/0: 1] target-temp:95 [ 2.489202] [0: swapper/0: 1] channel:2, lkg:8 [ 2.489251] [0: swapper/0: 1] channel:2, lkg:8 [ 2.489302] [0: swapper/0: 1] channel:2, lkg:8 [ 2.489330] [0: swapper/0: 1] target-temp:110 [ 2.516857] [0: swapper/0: 1] bio: create slab at 0 [ 2.517556] [0: swapper/0: 1] Rockchip hdmi driver version 2.0 [ 2.517773] [0: swapper/0: 1] mpp venc_srv.19: mpp_probe enter [ 2.517824] [0: swapper/0: 1] mpp venc_srv.19: init success [ 2.518861] [0: swapper/0: 1] vcc5v0_host: no parameters [ 2.519661] [0: swapper/0: 1] ppvar_sd_card_io: 1800 <--> 3300 mV at 3300 mV [ 2.521240] [0: swapper/0: 1] SCSI subsystem initialized [ 2.521477] [0: swapper/0: 1] usbcore: registered new interface driver usbfs [ 2.521549] [0: swapper/0: 1] usbcore: registered new interface driver hub [ 2.521831] [0: swapper/0: 1] usbcore: registered new device driver usb [ 2.524225] [0: swapper/0: 1] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff800042e000 [ 2.524929] [0: swapper/0: 1] media: Linux media interface: v0.10 [ 2.525000] [0: swapper/0: 1] Linux video capture interface: v2.00 [ 2.525163] [0: swapper/0: 1] pps_core: LinuxPPS API ver. 1 registered [ 2.525191] [0: swapper/0: 1] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[giometti@linux.it](mailto:giometti@linux.it)> [ 2.525236] [0: swapper/0: 1] PTP clock support registered [ 2.525322] [0: swapper/0: 1] i2c-core: driver [bq24296] using legacy suspend method [ 2.525350] [0: swapper/0: 1] i2c-core: driver [bq24296] using legacy resume method [ 2.526923] [0: swapper/0: 1] Rockchip ion module is successfully loaded (v1.1) [ 2.527740] [0: swapper/0: 1] Advanced Linux Sound Architecture Driver Initialized. [ 2.528322] [0: swapper/0: 1] Bluetooth: Core ver 2.16 [ 2.528390] [0: swapper/0: 1] NET: Registered protocol family 31 [ 2.528476] [0: swapper/0: 1] Bluetooth: HCI device and connection manager initialized [ 2.528517] [0: swapper/0: 1] Bluetooth: HCI socket layer initialized [ 2.528549] [0: swapper/0: 1] Bluetooth: L2CAP socket layer initialized [ 2.528600] [0: swapper/0: 1] Bluetooth: SCO socket layer initialized [ 2.528962] [0: kworker/0:1: 30] cfg80211: Calling CRDA to update world regulatory domain [ 2.531659] [0: swapper/0: 1] rk816_i2c_probe,line=789 [ 2.532106] [0: swapper/0: 1] pmic is rk805, chip version is 8050 [ 2.532289] [0: swapper/0: 1] pmic on/off source: on=0x40, off=0x0 [ 2.534205] [0: swapper/0: 1] rk816_i2c_probe: rk816_pmic_sleep=0 [ 2.535014] [0: swapper/0: 1] rk816_regulator_probe: compatible rk805 [ 2.537076] [0: swapper/0: 1] vdd_logic: 712 <--> 1350 mV at 1100 mV [ 2.538524] [0: swapper/0: 1] vdd_arm: 712 <--> 1350 mV at 1225 mV [ 2.539824] [0: swapper/0: 1] vcc_ddr: 1200 mV [ 2.541570] [0: swapper/0: 1] vcc_io: 3300 mV [ 2.543294] [0: swapper/0: 1] vdd_18: 1800 mV [ 2.544967] [0: swapper/0: 1] vcc_18emmc: 1800 mV [ 2.546656] [0: swapper/0: 1] vdd_11: 1100 mV [ 2.547130] [0: swapper/0: 1] rk816_i2c_probe success [ 2.547191] [0: swapper/0: 1] i2c-core: driver [rk816] using legacy suspend method [ 2.547218] [0: swapper/0: 1] i2c-core: driver [rk816] using legacy resume method [ 2.547299] [0: swapper/0: 1] i2c-core: driver [rk818] using legacy suspend method [ 2.547326] [0: swapper/0: 1] i2c-core: driver [rk818] using legacy resume method [ 2.548237] [0: swapper/0: 1] rk816_rtc_probe,line=463 [ 2.551505] [0: swapper/0: 1] rk8xx-rtc rk8xx-rtc: rtc core: registered rk816 as rtc0 [ 2.551810] [0: swapper/0: 1] rk805: rtc ok [ 2.552376] [0: swapper/0: 1] rockchip-i2s ff000000.i2s: i2s0 has no mclk [ 2.554801] [0: swapper/0: 1] Switching to clocksource arch_sys_counter [ 2.588763] [0: swapper/0: 1] rga: Module initialized. [ 2.589471] [0: swapper/0: 1] rga2 ff390000.rga: rga ion client create success! [ 2.589729] [0: swapper/0: 1] rga: Driver loaded succesfully [ 2.590049] [0: swapper/0: 1] fb disp policy is box [ 2.590077] [0: swapper/0: 1] uboot-logo-on:1 [ 2.590135] [0: swapper/0: 1] rk-fb rockchip-fb: rk fb ion client create success! [ 2.590167] [0: swapper/0: 1] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 2.590865] [0: swapper/0: 1] can't find screen_init node [ 2.590900] [0: swapper/0: 1] rk-screen rk_screen.18: rockchip screen probe success [ 2.592242] [0: swapper/0: 1] rk322xh-lcdc ff370000.vop: vop_dev->regs=0xffffff800043c000 [ 2.592341] [0: swapper/0: 1] rk322xh-lcdc vop0: can't find power_ctr node for lcdc0 [ 2.592737] [0: swapper/0: 1] graphics fb0: rockchip framebuffer registerd:fb0 [ 2.593217] [0: swapper/0: 1] graphics fb1: rockchip framebuffer registerd:fb1 [ 2.593464] [0: swapper/0: 1] graphics fb2: rockchip framebuffer registerd:fb2 [ 2.593699] [0: swapper/0: 1] graphics fb3: rockchip framebuffer registerd:fb3 [ 2.593926] [0: swapper/0: 1] graphics fb4: rockchip framebuffer registerd:fb4 [ 2.594134] [0: swapper/0: 1] rk322xh-lcdc vop0: failed to get vop hclk_noc source [ 2.595622] [0: swapper/0: 1] rk322xh-lcdc vop0: lcdc0: dclk:594000000>>fps:29 [ 2.604828] [0: swapper/0: 1] alloc_buffer:ion_phy_addr=0x10000000 [ 2.609975] [0: swapper/0: 1] fb0:phy:10000000>>vir:ffffff8000446000>>len:0xb00000 [ 2.660356] [2: swapper/0: 1] rk_iommu ff373f00.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x3b782000 [ 2.660448] [2: swapper/0: 1] rk322xh-lcdc vop0: lcdc0 probe ok, iommu enabled [ 2.662956] [2: swapper/0: 1] NET: Registered protocol family 2 [ 2.664093] [2: swapper/0: 1] TCP established hash table entries: 8192 (order: 5, 131072 bytes) [ 2.664366] [2: swapper/0: 1] TCP bind hash table entries: 8192 (order: 5, 131072 bytes) [ 2.664641] [2: swapper/0: 1] TCP: Hash tables configured (established 8192 bind 8192) [ 2.664783] [2: swapper/0: 1] TCP: reno registered [ 2.664820] [2: swapper/0: 1] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 2.664887] [2: swapper/0: 1] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 2.665257] [2: swapper/0: 1] NET: Registered protocol family 1 [ 2.665744] [2: swapper/0: 1] RPC: Registered named UNIX socket transport module. [ 2.665778] [2: swapper/0: 1] RPC: Registered udp transport module. [ 2.665804] [2: swapper/0: 1] RPC: Registered tcp transport module. [ 2.665829] [2: swapper/0: 1] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.666065] [2: swapper/0: 1] rk816_gpio_probe: compatible rk805 [ 2.666276] [2: swapper/0: 1] rk8xx-gpio rk8xx-gpio: driver success [ 2.667531] [2: swapper/0: 1] Unpacking initramfs... [ 2.800042] [2: swapper/0: 1] Freeing initrd memory: 1652K (ffffffc0059f0000 - ffffffc005b8d000) [ 2.801523] [2: swapper/0: 1] rknandbase v1.0 2014-03-31 [ 2.802152] [2: swapper/0: 1] rknand_driver:ret = 0 [ 2.802611] [2: swapper/0: 1] vcodec_service: No noc aclk reset resource define [ 2.802641] [2: swapper/0: 1] vcodec_service: No noc hclk reset resource define [ 2.802667] [2: swapper/0: 1] vcodec_service: No core reset resource define [ 2.802695] [2: swapper/0: 1] vcodec_service: No cabac reset resource define [ 2.802847] [2: swapper/0: 1] vcodec vpu_combo.20: failed on clk_get clk_cabac [ 2.802976] [2: swapper/0: 1] vcodec vpu_combo.20: do not have pd_video [ 2.803046] [2: swapper/0: 1] vcodec_service: probe device ff350000.vpu_service [ 2.803116] [2: swapper/0: 1] vcodec_service: checking hw id 0 [ 2.804257] [2: swapper/0: 1] vcodec_service: probe device ff351000.avsd [ 2.804339] [2: swapper/0: 1] vcodec_service: checking hw id 6731 [ 2.805723] [2: swapper/0: 1] vcodec_service: init success [ 3.015154] [0: kworker/0:1: 30] rk_battery_charger_detect_cb , battery_charger_detect 2 [ 3.016060] [2: swapper/0: 1] vcodec ff360000.rkvdec: do not have pd_video [ 3.016169] [2: swapper/0: 1] vcodec_service: probe device ff360000.rkvdec [ 3.016229] [2: swapper/0: 1] DVFS ERR: dvfs_target: aclk_rkvdec is disable, set rate error [ 3.016294] [2: swapper/0: 1] vcodec_service: checking hw id 3410 [ 3.017074] [2: swapper/0: 1] DVFS ERR: dvfs_target: aclk_rkvdec is disable, set rate error [ 3.018112] [2: swapper/0: 1] vcodec_service: init success [ 3.021150] [2: swapper/0: 1] Initialise system trusted keyring [ 3.021300] [2: swapper/0: 1] audit: initializing netlink socket (disabled) [ 3.021376] [2: swapper/0: 1] type=2000 audit(0.656:1): initialized [ 3.026872] [2: swapper/0: 1] VFS: Disk quotas dquot_6.5.2 [ 3.027156] [2: swapper/0: 1] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 3.029577] [2: swapper/0: 1] NFS: Registering the id_resolver key type [ 3.029675] [2: swapper/0: 1] Key type id_resolver registered [ 3.029702] [2: swapper/0: 1] Key type id_legacy registered [ 3.030195] [2: swapper/0: 1] fuse init (API version 7.22) [ 3.031334] [2: swapper/0: 1] [ 3.031334] [2: swapper/0: 1] TEE Core Framework initialization (ver 1:0.1) [ 3.031412] [2: swapper/0: 1] TEE armv7 Driver initialization [ 3.032018] [2: swapper/0: 1] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0" [ 3.032055] [2: swapper/0: 1] TEE core: Alloc the misc device "opteearmtz00" (id=0) [ 3.032354] [2: swapper/0: 1] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=58) [ 3.034621] [2: swapper/0: 1] Key type asymmetric registered [ 3.034662] [2: swapper/0: 1] Asymmetric key parser 'x509' registered [ 3.034931] [2: swapper/0: 1] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 3.034967] [2: swapper/0: 1] io scheduler noop registered [ 3.035113] [2: swapper/0: 1] io scheduler cfq registered (default) [ 3.039562] [2: swapper/0: 1] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully [ 3.042116] [2: swapper/0: 1] rockchip-hdmiv2 ff3c0000.hdmi: rockchip hdmiv2 probe success. [ 3.042923] [2: swapper/0: 1] iep: failed to find iep power down clock source. [ 3.043564] [2: swapper/0: 1] iep ion client create success! [ 3.043601] [2: swapper/0: 1] IEP Power ON [ 3.044291] [2: swapper/0: 1] rk_iommu ff3a0800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x3b785000 [ 3.044330] [2: swapper/0: 1] IEP Power OFF [ 3.044373] [2: swapper/0: 1] IEP Driver loaded succesfully [ 3.044592] [2: swapper/0: 1] Module initialized. [ 3.045198] [2: swapper/0: 1] rk3036-tve ff373e00.tve: rockchip,rk322xh-tve tv encoder probe ok [ 3.045613] [2: swapper/0: 1] probe device ff330000.h265e [ 3.046030] [2: swapper/0: 1] mpp_dev ff330000.h265e: try to get iommu dev rockchip,h265e_mmu [ 3.046743] [2: swapper/0: 1] mpp_dev ff330000.h265e: resource ready, register device [ 3.047154] [2: swapper/0: 1] probe device ff340000.vepu [ 3.047756] [2: swapper/0: 1] mpp_dev ff340000.vepu: try to get iommu dev rockchip,vepu_mmu [ 3.048463] [2: swapper/0: 1] mpp_dev ff340000.vepu: resource ready, register device [ 3.051180] [2: swapper/0: 1] dma-pl330 ff1f0000.pdma: Loaded driver for PL330 DMAC-2364208 [ 3.051229] [2: swapper/0: 1] dma-pl330 ff1f0000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 3.051954] [2: swapper/0: 1] rk_serial.c v1.8 2014-03-04 [ 3.052462] [2: swapper/0: 1] [drm] Initialized drm 1.1.0 20060810 [ 3.055942] [2: swapper/0: 1] loop: module loaded [ 3.056438] [2: swapper/0: 1] zram: Created 1 device(s) [ 3.056679] [2: swapper/0: 1] i2c-core: driver [mpu6050B1] using legacy suspend method [ 3.056709] [2: swapper/0: 1] i2c-core: driver [mpu6050B1] using legacy resume method [ 3.056739] [2: swapper/0: 1] mpu_init: Probe name mpu6050B1 [ 3.057029] [2: swapper/0: 1] ak8963_mod_init: Probe name ak8963_mod [ 3.058342] [2: swapper/0: 1] SCSI Media Changer driver v0.25 [ 3.058882] [2: swapper/0: 1] tun: Universal TUN/TAP device driver, 1.6 [ 3.058913] [2: swapper/0: 1] tun: (C) 1999-2004 Max Krasnyansky <[maxk@qualcomm.com](mailto:maxk@qualcomm.com)> [ 3.060151] [2: swapper/0: 1] stmmac_probe_config_dt: Can not read property: pmu_regulator. [ 3.060194] [2: swapper/0: 1] stmmac_probe_config_dt: clock input/output? (input). [ 3.060224] [2: swapper/0: 1] stmmac_probe_config_dt: TX delay(0x28). [ 3.060252] [2: swapper/0: 1] stmmac_probe_config_dt: RX delay(0x16). [ 3.060279] [2: swapper/0: 1] stmmac_probe_config_dt: Can not read property: phy-type. [ 3.060556] [2: swapper/0: 1] stmmc_pltfr_init: [ 3.060581] [2: swapper/0: 1] stmmc_pltfr_init: ERROR: Get power-gpio failed. [ 3.060619] [2: swapper/0: 1] stmmc_pltfr_init: ERROR: Get link-gpio failed. [ 3.060646] [2: swapper/0: 1] stmmc_pltfr_init: ERROR: Get led-gpio failed. [ 3.060672] [2: swapper/0: 1] stmmc_pltfr_init: init for RGMII [ 3.060698] [2: swapper/0: 1] tx delay=0x28 [ 3.060698] [2: swapper/0: 1] rx delay=0x16 [ 3.061060] [2: swapper/0: 1] gmac_clk_init: warning: cannot get mac_clkin clock [ 3.061132] [2: swapper/0: 1] gmac_clk_init: warning: cannot get clk_macphy clock [ 3.061216] [2: swapper/0: 1] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 3.061245] [2: swapper/0: 1] Normal descriptors [ 3.061268] [2: swapper/0: 1] Ring mode enabled [ 3.061295] [2: swapper/0: 1] DMA HW capability register supported [ 3.061320] [2: swapper/0: 1] RX Checksum Offload Engine supported (type 2) [ 3.061345] [2: swapper/0: 1] TX Checksum insertion supported [ 3.061369] [2: swapper/0: 1] Wake-Up On Lan supported [ 3.061447] [2: swapper/0: 1] Enable RX Mitigation via HW Watchdog Timer [ 3.062113] [2: swapper/0: 1] PPP generic driver version 2.4.2 [ 3.062404] [2: swapper/0: 1] PPP BSD Compression module registered [ 3.062435] [2: swapper/0: 1] PPP Deflate Compression module registered [ 3.062491] [2: swapper/0: 1] PPP MPPE Compression module registered [ 3.062520] [2: swapper/0: 1] NET: Registered protocol family 24 [ 3.062590] [2: swapper/0: 1] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 3.062619] [2: swapper/0: 1] CSLIP: code copyright 1989 Regents of the University of California. [ 3.062647] [2: swapper/0: 1] Rockchip WiFi SYS interface (V1.00) ... [ 3.062704] [2: swapper/0: 1] esp_mem_init enter date Jul 20 2018 16:17:20 [ 3.062730] [2: swapper/0: 1] esp_mem_init VERSION [V2.5] [ 3.062813] [2: swapper/0: 1] esp_mem_init complete [ 3.062918] [2: swapper/0: 1] usbcore: registered new interface driver catc [ 3.062987] [2: swapper/0: 1] usbcore: registered new interface driver kaweth [ 3.063016] [2: swapper/0: 1] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 3.063096] [2: swapper/0: 1] usbcore: registered new interface driver pegasus [ 3.063163] [2: swapper/0: 1] usbcore: registered new interface driver rtl8150 [ 3.063190] [2: swapper/0: 1] hso: drivers/net/usb/hso.c: Option Wireless [ 3.063300] [2: swapper/0: 1] usbcore: registered new interface driver hso [ 3.063420] [2: swapper/0: 1] usbcore: registered new interface driver asix [ 3.063489] [2: swapper/0: 1] usbcore: registered new interface driver ax88179_178a [ 3.063562] [2: swapper/0: 1] usbcore: registered new interface driver cdc_ether [ 3.063629] [2: swapper/0: 1] usbcore: registered new interface driver cdc_eem [ 3.063693] [2: swapper/0: 1] usbcore: registered new interface driver dm9601 [ 3.063759] [2: swapper/0: 1] usbcore: registered new interface driver dm9620 [ 3.063833] [2: swapper/0: 1] usbcore: registered new interface driver smsc75xx [ 3.063921] [2: swapper/0: 1] usbcore: registered new interface driver smsc95xx [ 3.063989] [2: swapper/0: 1] usbcore: registered new interface driver gl620a [ 3.064053] [2: swapper/0: 1] usbcore: registered new interface driver net1080 [ 3.064118] [2: swapper/0: 1] usbcore: registered new interface driver plusb [ 3.064185] [2: swapper/0: 1] usbcore: registered new interface driver rndis_host [ 3.064251] [2: swapper/0: 1] usbcore: registered new interface driver cdc_subset [ 3.064321] [2: swapper/0: 1] usbcore: registered new interface driver zaurus [ 3.064390] [2: swapper/0: 1] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 3.064488] [2: swapper/0: 1] usbcore: registered new interface driver int51x1 [ 3.064554] [2: swapper/0: 1] usbcore: registered new interface driver kalmia [ 3.064623] [2: swapper/0: 1] usbcore: registered new interface driver ipheth [ 3.064692] [2: swapper/0: 1] usbcore: registered new interface driver sierra_net [ 3.064763] [2: swapper/0: 1] usbcore: registered new interface driver cx82310_eth [ 3.064838] [2: swapper/0: 1] usbcore: registered new interface driver cdc_ncm [ 3.064904] [2: swapper/0: 1] usbcore: registered new interface driver qmi_wwan [ 3.064970] [2: swapper/0: 1] usbcore: registered new interface driver cdc_mbim [ 3.067341] [2: swapper/0: 1] phy phy-ff470000.usb3-phy.1: u3phy u2 power on [ 3.067419] [2: swapper/0: 1] phy phy-ff470000.usb3-phy.2: u3phy u3 power on [ 3.068295] [2: swapper/0: 1] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 3.068354] [2: swapper/0: 1] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 3.069733] [2: swapper/0: 1] xhci-hcd xhci-hcd.0.auto: irq 99, io mem 0xff600000 [ 3.069872] [2: swapper/0: 1] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.069938] [2: swapper/0: 1] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.069971] [2: swapper/0: 1] usb usb1: Product: xHCI Host Controller [ 3.070002] [2: swapper/0: 1] usb usb1: Manufacturer: Linux 3.10.104 xhci-hcd [ 3.070032] [2: swapper/0: 1] usb usb1: SerialNumber: xhci-hcd.0.auto [ 3.070811] [2: swapper/0: 1] hub 1-0:1.0: USB hub found [ 3.070866] [2: swapper/0: 1] hub 1-0:1.0: 1 port detected [ 3.071119] [2: swapper/0: 1] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 3.071165] [2: swapper/0: 1] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 3.071291] [2: swapper/0: 1] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003 [ 3.071326] [2: swapper/0: 1] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.071357] [2: swapper/0: 1] usb usb2: Product: xHCI Host Controller [ 3.071387] [2: swapper/0: 1] usb usb2: Manufacturer: Linux 3.10.104 xhci-hcd [ 3.071418] [2: swapper/0: 1] usb usb2: SerialNumber: xhci-hcd.0.auto [ 3.071990] [2: swapper/0: 1] hub 2-0:1.0: USB hub found [ 3.072032] [2: swapper/0: 1] hub 2-0:1.0: 1 port detected [ 3.072279] [2: swapper/0: 1] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.072309] [2: swapper/0: 1] ehci-platform: EHCI generic platform driver [ 3.072933] [2: swapper/0: 1] ehci-platform ff5c0000.usb: EHCI Host Controller [ 3.072987] [2: swapper/0: 1] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 3 [ 3.073693] [2: swapper/0: 1] ehci-platform ff5c0000.usb: irq 48, io mem 0xff5c0000 [ 3.083066] [2: swapper/0: 1] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00 [ 3.083206] [2: swapper/0: 1] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.083241] [2: swapper/0: 1] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.083273] [2: swapper/0: 1] usb usb3: Product: EHCI Host Controller [ 3.083305] [2: swapper/0: 1] usb usb3: Manufacturer: Linux 3.10.104 ehci_hcd [ 3.083335] [2: swapper/0: 1] usb usb3: SerialNumber: ff5c0000.usb [ 3.083974] [2: swapper/0: 1] hub 3-0:1.0: USB hub found [ 3.084022] [2: swapper/0: 1] hub 3-0:1.0: 1 port detected [ 3.084712] [2: swapper/0: 1] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 3.084742] [2: swapper/0: 1] ohci-platform: OHCI generic platform driver [ 3.085108] [2: swapper/0: 1] ohci-platform ff5d0000.usb: Generic Platform OHCI controller [ 3.085163] [2: swapper/0: 1] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 4 [ 3.085260] [2: swapper/0: 1] ohci-platform ff5d0000.usb: irq 49, io mem 0xff5d0000 [ 3.139338] [0: kworker/u8:0: 6] hdmi output corlor mode is 3 [ 3.139380] [0: kworker/u8:0: 6] hdmi connect to lcdc0 [ 3.139411] [0: kworker/u8:0: 6] switch:en=1,lcdc_id=0,screen type=6,cur type=1 [ 3.139434] [0: kworker/u8:0: 6] data space: 0, color mode: 3 [ 3.139511] [0: kworker/u8:0: 6] rk322xh-lcdc vop0: lcdc0: dclk:594000000>>fps:60 [ 3.139560] [2: swapper/0: 1] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 3.139576] [0: kworker/u8:0: 6] pixel clk is 148500000 tmds clk is 148500000 [ 3.139628] [2: swapper/0: 1] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.139653] [0: kworker/u8:0: 6] rockchip-hdmiv2 ff3c0000.hdmi: [hdmi_dev_config_video] success output HDMI. [ 3.139687] [2: swapper/0: 1] usb usb4: Product: Generic Platform OHCI controller [ 3.139718] [2: swapper/0: 1] usb usb4: Manufacturer: Linux 3.10.104 ohci_hcd [ 3.139749] [2: swapper/0: 1] usb usb4: SerialNumber: ff5d0000.usb [ 3.140402] [2: swapper/0: 1] hub 4-0:1.0: USB hub found [ 3.140451] [2: swapper/0: 1] hub 4-0:1.0: 1 port detected [ 3.140935] [2: swapper/0: 1] usbcore: registered new interface driver cdc_acm [ 3.140966] [2: swapper/0: 1] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 3.141063] [2: swapper/0: 1] usbcore: registered new interface driver usblp [ 3.141141] [2: swapper/0: 1] usbcore: registered new interface driver cdc_wdm [ 3.141302] [2: swapper/0: 1] usbcore: registered new interface driver usb-storage [ 3.141378] [2: swapper/0: 1] usbcore: registered new interface driver ums-alauda [ 3.141447] [2: swapper/0: 1] usbcore: registered new interface driver ums-cypress [ 3.141520] [2: swapper/0: 1] usbcore: registered new interface driver ums-datafab [ 3.141589] [2: swapper/0: 1] usbcore: registered new interface driver ums_eneub6250 [ 3.141664] [2: swapper/0: 1] usbcore: registered new interface driver ums-freecom [ 3.141735] [2: swapper/0: 1] usbcore: registered new interface driver ums-isd200 [ 3.141805] [2: swapper/0: 1] usbcore: registered new interface driver ums-jumpshot [ 3.141900] [2: swapper/0: 1] usbcore: registered new interface driver ums-karma [ 3.141973] [2: swapper/0: 1] usbcore: registered new interface driver ums-onetouch [ 3.142114] [2: swapper/0: 1] usbcore: registered new interface driver ums-sddr09 [ 3.142187] [2: swapper/0: 1] usbcore: registered new interface driver ums-sddr55 [ 3.142258] [2: swapper/0: 1] usbcore: registered new interface driver ums-usbat [ 3.142415] [2: swapper/0: 1] usbcore: registered new interface driver usbserial [ 3.142487] [2: swapper/0: 1] usbcore: registered new interface driver usbserial_generic [ 3.142541] [2: swapper/0: 1] usbserial: USB Serial support registered for generic [ 3.142614] [2: swapper/0: 1] usbcore: registered new interface driver option [ 3.142667] [2: swapper/0: 1] usbserial: USB Serial support registered for GSM modem (1-port) [ 3.142998] [2: swapper/0: 1] usbcore: registered new interface driver trancevibrator [ 3.143027] [2: swapper/0: 1] usb20_otg: version 3.10a 21-DEC-2012 [ 3.143842] [2: swapper/0: 1] ffffff8001480040 [ 3.143879] [2: swapper/0: 1] Core Release: 3.10a [ 3.143907] [2: swapper/0: 1] Setting default values for core params [ 3.144105] [2: swapper/0: 1] Using Buffer DMA mode [ 3.144134] [2: swapper/0: 1] Periodic Transfer Interrupt Enhancement - disabled [ 3.144160] [2: swapper/0: 1] Multiprocessor Interrupt Enhancement - disabled [ 3.144189] [2: swapper/0: 1] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 3.144217] [2: swapper/0: 1] ^^^^^^^^^^^^^^^^^Device Mode [ 3.144255] [2: swapper/0: 1] Dedicated Tx FIFOs mode [ 3.144300] [2: swapper/0: 1] pcd_init otg_dev = ffffffc005646700 [ 3.144545] [2: swapper/0: 1] usb20_otg ff580000.usb: DWC OTG Controller [ 3.144596] [2: swapper/0: 1] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 5 [ 3.144657] [2: swapper/0: 1] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 3.144774] [2: swapper/0: 1] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.144809] [2: swapper/0: 1] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.144841] [2: swapper/0: 1] usb usb5: Product: DWC OTG Controller [ 3.144871] [2: swapper/0: 1] usb usb5: Manufacturer: Linux 3.10.104 dwc_otg_hcd [ 3.144902] [2: swapper/0: 1] usb usb5: SerialNumber: ff580000.usb [ 3.145576] [2: swapper/0: 1] hub 5-0:1.0: USB hub found [ 3.145622] [2: swapper/0: 1] hub 5-0:1.0: 1 port detected [ 3.148784] [0: swapper/0: 1] usb20_host: version 3.10a 21-DEC-2012 [ 3.149831] [0: swapper/0: 1] usbcore: registered new interface driver xpad [ 3.149930] [0: swapper/0: 1] usbcore: registered new interface driver usb_acecad [ 3.150018] [0: swapper/0: 1] usbcore: registered new interface driver aiptek [ 3.150094] [0: swapper/0: 1] usbcore: registered new interface driver gtco [ 3.150170] [0: swapper/0: 1] usbcore: registered new interface driver hanwang [ 3.150242] [0: swapper/0: 1] usbcore: registered new interface driver kbtab [ 3.150348] [0: swapper/0: 1] usbcore: registered new interface driver wacom [ 3.152178] [0: swapper/0: 1] input: rk816_pwrkey as /devices/ff160000.i2c/i2c-1/1-0018/rk8xx-pwrkey/input/input0 [ 3.152463] [0: swapper/0: 1] rk805 register rk8xx_pwrkey driver [ 3.152538] [0: swapper/0: 1] sensor_register_slave:mma8452,id=17 [ 3.152567] [0: swapper/0: 1] sensor_register_slave:gs_mc3230,id=23 [ 3.152592] [0: swapper/0: 1] [Gsensor] gsensor_init [ 3.152619] [0: swapper/0: 1] sensor_register_slave:mpu6880_acc,id=24 [ 3.152646] [0: swapper/0: 1] sensor_register_slave:mpu6500_acc,id=25 [ 3.152673] [0: swapper/0: 1] sensor_register_slave:bma2xx_acc,id=26 [ 3.152700] [0: swapper/0: 1] sensor_register_slave:cm3217,id=49 [ 3.152726] [0: swapper/0: 1] sensor_register_slave:cm3218,id=50 [ 3.152753] [0: swapper/0: 1] sensor_register_slave:ls_stk3410,id=58 [ 3.153124] [0: swapper/0: 1] sensor_register_slave:ps_stk3410,id=63 [ 3.153612] [0: swapper/0: 1] .. rk pwm remotectl v1.1 init [ 3.154121] [0: swapper/0: 1] input: ff1b0030.pwm as /devices/ff1b0030.pwm/input/input1 [ 3.154886] [0: swapper/0: 1] i2c /dev entries driver [ 3.155445] [0: swapper/0: 1] IR NEC protocol handler initialized [ 3.155475] [0: swapper/0: 1] IR RC5(x) protocol handler initialized [ 3.155501] [0: swapper/0: 1] IR RC6 protocol handler initialized [ 3.155526] [0: swapper/0: 1] IR JVC protocol handler initialized [ 3.155551] [0: swapper/0: 1] IR Sony protocol handler initialized [ 3.155576] [0: swapper/0: 1] IR RC5 (streamzap) protocol handler initialized [ 3.155602] [0: swapper/0: 1] IR SANYO protocol handler initialized [ 3.155627] [0: swapper/0: 1] IR MCE Keyboard/mouse protocol handler initialized [ 3.155912] [0: swapper/0: 1] usbcore: registered new interface driver uvcvideo [ 3.155940] [0: swapper/0: 1] USB Video Class driver (1.1.1) [ 3.155969] [0: swapper/0: 1] CamSys driver version: v0.34.0, CamSys head file version: v0.13.0 [ 3.155998] [0: swapper/0: 1] E:camsys_soc_init(30): camsys_soc_init exit! [ 3.157648] [0: swapper/0: 1] not find test_power_init dev node [ 3.157733] [0: swapper/0: 1] i2c-core: driver [bq27320] using legacy suspend method [ 3.157762] [0: swapper/0: 1] i2c-core: driver [bq27320] using legacy resume method [ 3.161804] [0: swapper/0: 1] thermal thermal_zone0: failed to read out thermal zone 0 [ 3.162470] [0: swapper/0: 1] device-mapper: uevent: version 1.0.3 [ 3.162882] [0: swapper/0: 1] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [dm-devel@redhat.com](mailto:dm-devel@redhat.com) [ 3.163272] [0: swapper/0: 1] Bluetooth: HCI UART driver ver 2.2 [ 3.163304] [0: swapper/0: 1] Bluetooth: HCI H4 protocol initialized [ 3.163331] [0: swapper/0: 1] Bluetooth: HCILL protocol initialized [ 3.165395] [0: swapper/0: 1] cpufreq version 1.0, suspend freq 1008 MHz [ 3.166327] [0: swapper/0: 1] cpuidle: using governor ladder [ 3.166361] [0: swapper/0: 1] cpuidle: using governor menu [ 3.166787] [0: swapper/0: 1] Synopsys Designware Multimedia Card Interface Driver [ 3.166817] [0: swapper/0: 1] MHSC version = Ver 2.00 2015-06-10 [ 3.167927] [0: swapper/0: 1] dwmmc_rockchip ff520000.rksdmmc: Version ID is 270a [ 3.168020] [0: swapper/0: 1] dwmmc_rockchip ff520000.rksdmmc: failed to get hpclk_mmc [ 3.244324] [2: kworker/2:1: 33] Using Buffer DMA mode [ 3.244368] [2: kworker/2:1: 33] Periodic Transfer Interrupt Enhancement - disabled [ 3.244388] [2: kworker/2:1: 33] Multiprocessor Interrupt Enhancement - disabled [ 3.244411] [2: kworker/2:1: 33] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 3.244431] [2: kworker/2:1: 33] ^^^^^^^^^^^^^^^^^^Host Mode [ 3.245206] [0: swapper/0: 1] dwmmc_rockchip ff520000.rksdmmc: Using internal DMA controller. [ 3.247198] [1: swapper/0: 1] dwmmc_rockchip ff520000.rksdmmc: dw_mci_init_slot: fmin=400000, fmax=150000000 [mmc0] [ 3.260282] [1: swapper/0: 1] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 3.273425] [1: swapper/0: 1] dwmmc_rockchip ff520000.rksdmmc: DW MMC controller at irq 46, 32 bit host data width, 256 deep fifo [ 3.273447] [1: swapper/0: 1] dwmmc_rockchip ff520000.rksdmmc: 1 slots initialized [ 3.274089] [1: swapper/0: 1] dwmmc_rockchip ff500000.rksdmmc: Version ID is 270a [ 3.274151] [1: swapper/0: 1] dwmmc_rockchip ff500000.rksdmmc: failed to get hpclk_mmc [ 3.277815] [1: swapper/0: 1] dwmmc_rockchip ff500000.rksdmmc: Using internal DMA controller. [ 3.278172] [1: swapper/0: 1] dwmmc_rockchip ff500000.rksdmmc: dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc1] [ 3.278592] [1: swapper/0: 1] dwmmc_rockchip ff500000.rksdmmc: mmc1: No udbg pinctrl found! [ 3.278765] [1: swapper/0: 1] enter gpio_regulator_set_voltage 72 [ 3.278793] [1: swapper/0: 1] enter gpio_regulator_set_voltage line 93 ,gpio=25 state=0 [ 3.293133] [2: kworker/u8:0: 6] Init: Power Port (0) [ 3.293162] [2: kworker/u8:0: 6] rk_battery_charger_detect_cb , battery_charger_detect 5 [ 3.293248] [2: kworker/2:1: 33] ff580000.usb resume, HPRT0:0x41803 [ 3.296290] [1: swapper/0: 1] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc1] [ 3.309474] [1: swapper/0: 1] dwmmc_rockchip ff500000.rksdmmc: DW MMC controller at irq 44, 32 bit host data width, 256 deep fifo [ 3.309506] [1: swapper/0: 1] dwmmc_rockchip ff500000.rksdmmc: 1 slots initialized [ 3.309991] [1: swapper/0: 1] leds-gpio leds.32: pins are not configured from the driver [ 3.310569] [0: swapper/0: 1] leds-gpio leds.32: firefly:blue:power can_sleep:1 mode:23 [ 3.311204] [0: swapper/0: 1] leds-gpio leds.32: firefly:yellow:user can_sleep:1 mode:05 [ 3.311322] [0: swapper/0: 1] leds-gpio leds.32: Skipping unavailable LED gpio -2 (ir) [ 3.311813] [0: swapper/0: 1] hidraw: raw HID events driver (C) Jiri Kosina [ 3.314464] [0: swapper/0: 1] usbcore: registered new interface driver usbhid [ 3.314495] [0: swapper/0: 1] usbhid: USB HID core driver [ 3.314793] [0: swapper/0: 1] ashmem: initialized [ 3.315048] [0: swapper/0: 1] logger: created 256K log 'log_main' [ 3.315225] [0: swapper/0: 1] logger: created 256K log 'log_events' [ 3.315389] [0: swapper/0: 1] logger: created 256K log 'log_radio' [ 3.315669] [0: swapper/0: 1] logger: created 256K log 'log_system' [ 3.316766] [0: swapper/0: 1] Rockchip DDR Initialize, verision: V1.01 20170517 [ 3.316799] [0: swapper/0: 1] current ATF version 0x101! [ 3.316829] [0: swapper/0: 1] rockchip_ddr ddr.25: share memory addr=0x102000 [ 3.318995] [0: swapper/0: 1] rockchip_ddr_probe: success [ 3.320402] [0: swapper/0: 1] input: rk29-keypad as /devices/ff280000.adc/rockchip-key.33/input/input2 [ 3.322111] [0: swapper/0: 1] --es8316_init--start-- [ 3.326909] [2: kworker/2:1: 33] ff580000.usb suspend, HPRT0:0x41801 [ 3.433976] I[2: kworker/u8:0: 6] dwmmc_rockchip ff500000.rksdmmc: descriptor is still owned by IDMAC. [ 3.434023] I[2: kworker/u8:0: 6] dwmmc_rockchip ff500000.rksdmmc: dw_mci_submit_data_dma: fall back to PIO mode for current transfer [ 3.436762] [1: swapper/0: 1] rk322x-audio rockchip_audio.28: rk322x-hifi <-> ff010000.i2s mapping ok [ 3.439514] [0: kworker/u8:0: 6] mmc_host mmc1: Bus speed (slot 0) = 100000000Hz (slot req 50000000Hz, actual 50000000HZ div = 1) [ 3.439566] [0: kworker/u8:0: 6] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc1] [ 3.439659] [0: kworker/u8:0: 6] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc1] [ 3.439684] [0: kworker/u8:0: 6] mmc1: new high speed SDHC card at address 59b4 [ 3.440226] [0: kworker/u8:0: 6] mmcblk0: mmc1:59b4 SD 7.54 GiB [ 3.440616] [1: swapper/0: 1] rockchip-hdmi-i2s rockchip_hdmi_i2s.29: rk-hdmi-i2s-hifi <-> ff000000.i2s mapping ok [ 3.440932] [0: kworker/u8:0: 6] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 3.440954] [0: kworker/u8:0: 6] trust: 0x000800000 -- 0x001000000 (8 MB) [ 3.440969] [0: kworker/u8:0: 6] misc: 0x001000000 -- 0x001400000 (4 MB) [ 3.440983] [0: kworker/u8:0: 6] baseparamer: 0x001400000 -- 0x001500000 (1 MB) [ 3.440998] [0: kworker/u8:0: 6] resource: 0x001500000 -- 0x002400000 (15 MB) [ 3.441013] [0: kworker/u8:0: 6] kernel: 0x002400000 -- 0x004400000 (32 MB) [ 3.441027] [0: kworker/u8:0: 6] boot: 0x004400000 -- 0x006400000 (32 MB) [ 3.441043] [0: kworker/u8:0: 6] recovery: 0x006400000 -- 0x008400000 (32 MB) [ 3.441056] [0: kworker/u8:0: 6] backup: 0x008400000 -- 0x00c400000 (64 MB) [ 3.441071] [0: kworker/u8:0: 6] cache: 0x00c400000 -- 0x014400000 (128 MB) [ 3.441086] [0: kworker/u8:0: 6] metadata: 0x014400000 -- 0x015400000 (16 MB) [ 3.441101] [0: kworker/u8:0: 6] kpanic: 0x015400000 -- 0x015800000 (4 MB) [ 3.441115] [0: kworker/u8:0: 6] system: 0x015800000 -- 0x075800000 (1536 MB) [ 3.441130] [0: kworker/u8:0: 6] userdata: 0x075800000 -- 0x1e2c00000 (5844 MB) [ 3.441168] [0: kworker/u8:0: 6] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14[ 3.442215] [1: swapper/0: 1] u32 classifier [ 3.442241] [1: swapper/0: 1] Actions configured [ 3.442262] [1: swapper/0: 1] Netfilter messages via NETLINK v0.30. [ 3.442359] [1: swapper/0: 1] nf_conntrack version 0.5.0 (7537 buckets, 30148 max) [ 3.442726] [1: swapper/0: 1] ctnetlink v0.93: registering with nfnetlink. [ 3.442831] [1: swapper/0: 1] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 3.442846] [1: swapper/0: 1] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 3.443307] [1: swapper/0: 1] xt_time: kernel timezone is -0000 [ 3.443558] [1: swapper/0: 1] ip_tables: (C) 2000-2006 Netfilter Core Team [ 3.443726] [1: swapper/0: 1] arp_tables: (C) 2002 David S. Miller [ 3.443771] [1: swapper/0: 1] TCP: cubic registered [ 3.443785] [1: swapper/0: 1] Initializing XFRM netlink socket [ 3.444095] [1: swapper/0: 1] NET: Registered protocol family 10 [ 3.444769] [1: swapper/0: 1] mip6: Mobile IPv6 [ 3.444814] [1: swapper/0: 1] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 3.444982] [1: swapper/0: 1] sit: IPv6 over IPv4 tunneling driver [ 3.445415] [1: swapper/0: 1] NET: Registered protocol family 17 [ 3.445454] [1: swapper/0: 1] NET: Registered protocol family 15 [ 3.445537] [1: swapper/0: 1] Bridge firewalling registered [ 3.445560] [1: swapper/0: 1] Ebtables v2.0 registered [ 3.446030] [1: swapper/0: 1] Bluetooth: RFCOMM TTY layer initialized [ 3.446083] [1: swapper/0: 1] Bluetooth: RFCOMM socket layer initialized [ 3.446098] [1: swapper/0: 1] Bluetooth: RFCOMM ver 1.11 [ 3.446112] [1: swapper/0: 1] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 3.446125] [1: swapper/0: 1] Bluetooth: BNEP filters: protocol multicast [ 3.446145] [1: swapper/0: 1] Bluetooth: BNEP socket layer initialized [ 3.446159] [1: swapper/0: 1] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 3.446180] [1: swapper/0: 1] Bluetooth: HIDP socket layer initialized [ 3.446269] [1: swapper/0: 1] l2tp_core: L2TP core driver, V2.0 [ 3.446291] [1: swapper/0: 1] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 3.446305] [1: swapper/0: 1] 8021q: 802.1Q VLAN Support v1.8 [ 3.446344] [1: swapper/0: 1] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 3.446673] [1: swapper/0: 1] [BT_RFKILL]: Enter rfkill_rk_init [ 3.446918] [1: swapper/0: 1] Key type dns_resolver registered [ 3.448304] [1: swapper/0: 1] Registering SWP/SWPB emulation handler [ 3.448338] [1: swapper/0: 1] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x0000000002000000@0x000000003dc00000 [ 3.453502] [1: swapper/0: 1] ddrfreq: verion 1.2 20140526 [ 3.453539] [1: swapper/0: 1] ddrfreq: normal 1020MHz performance 1020MHz low_power 0MHz video_1080p 1020MHz video_4k 1020MHz dualview 1020MHz idle 0MHz suspend 1020MHz reboot 1020MHz video_4k_10b 0MHz [ 3.453556] [1: swapper/0: 1] ddrfreq: auto-freq=0 [ 3.453569] [1: swapper/0: 1] ddrfreq: auto-freq-table[0] 1020MHz [ 3.453582] [1: swapper/0: 1] ddrfreq: auto-freq-table[1] 1020MHz [ 3.464674] [1: swapper/0: 1] Loading compiled-in X.509 certificates [ 3.464710] [1: swapper/0: 1] registered taskstats version 1 [ 3.464794] [1: swapper/0: 1] regulator-dummy: disabling [ 3.464921] [1: swapper/0: 1] unable to find transceiver of type USB2 PHY [ 3.464937] [1: swapper/0: 1] otg_wakelock_init: No USB transceiver found [ 3.465015] [1: swapper/0: 1] pcd_pullup, is_on 0[ 3.465043] I[0: swapper/0: 0] WARN::dwc_otg_handle_mode_mismatch_intr:69: Mode Mismatch Interrupt: currently in Host mode
[ 3.465055] I[0: swapper/0: 0]
[ 3.465065] [1: swapper/0: 1] file system registered
[ 3.465795] [1: swapper/0: 1] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 3.465814] [1: swapper/0: 1] android_usb gadget: Number of LUNs=2
[ 3.465827] [1: swapper/0: 1] lun0: LUN: removable file: (no medium)
[ 3.465841] [1: swapper/0: 1] lun1: LUN: removable file: (no medium)
[ 3.466077] [1: swapper/0: 1] android_usb gadget: android_usb ready
[ 3.466141] [1: swapper/0: 1] sensor_init: Probe name sensors
[ 3.466168] [1: swapper/0: 1] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 3.466831] [0: swapper/0: 1] rk8xx-rtc rk8xx-rtc: setting system clock to 2016-01-21 08:50:03 UTC (1453366203)
[ 3.472270] [0: swapper/0: 1] rk3688_suspend_init: getting dev node error
[ 3.472296] [0: swapper/0: 1] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-ae30b1a’, rk_ko_ver is ‘5’, built at ‘17:07:14’, on ‘Aug 4 2018’.
[ 3.472405] [0: swapper/0: 1] mali-utgard ff300000.gpu: mali_platform_device->num_resources = 9
[ 3.472422] [0: swapper/0: 1] mali-utgard ff300000.gpu: resource[0].start = 0x0x00000000ff300000
[ 3.472437] [0: swapper/0: 1] mali-utgard ff300000.gpu: resource[1].start = 0x0x00000000ff300000
[ 3.472452] [0: swapper/0: 1] mali-utgard ff300000.gpu: resource[2].start = 0x0x000000000000007a
[ 3.472467] [0: swapper/0: 1] mali-utgard ff300000.gpu: resource[3].start = 0x0x0000000000000077
[ 3.472481] [0: swapper/0: 1] mali-utgard ff300000.gpu: resource[4].start = 0x0x000000000000007d
[ 3.472496] [0: swapper/0: 1] mali-utgard ff300000.gpu: resource[5].start = 0x0x0000000000000078
[ 3.472511] [0: swapper/0: 1] mali-utgard ff300000.gpu: resource[6].start = 0x0x0000000000000079
[ 3.472526] [0: swapper/0: 1] mali-utgard ff300000.gpu: resource[7].start = 0x0x000000000000007b
[ 3.472541] [0: swapper/0: 1] mali-utgard ff300000.gpu: resource[8].start = 0x0x000000000000007c
[ 3.472579] [0: swapper/0: 1] mali-utgard ff300000.gpu: freq: 200000000, min_threshold: 0, max_threshold: 70
[ 3.472595] [0: swapper/0: 1] mali-utgard ff300000.gpu: freq: 300000000, min_threshold: 70, max_threshold: 80
[ 3.472611] [0: swapper/0: 1] mali-utgard ff300000.gpu: freq: 400000000, min_threshold: 81, max_threshold: 90
[ 3.472626] [0: swapper/0: 1] mali-utgard ff300000.gpu: freq: 492000000, min_threshold: 92, max_threshold: 100
[ 3.472675] [0: swapper/0: 1] mali-utgard ff300000.gpu: initial freq = 200000000
[ 3.474436] [0: swapper/0: 1] Mali: Mali device driver loaded
[ 3.474805] [0: swapper/0: 1] usbcore: registered new interface driver snd-usb-audio
[ 3.474820] [0: swapper/0: 1] ALSA device list:
[ 3.474832] [0: swapper/0: 1] #0: RK_RK322x
[ 3.474843] [0: swapper/0: 1] #1: RK-HDMI-I2S
[ 3.475041] [0: swapper/0: 1] Freeing unused kernel memory: 388K (ffffffc000c9d000 - ffffffc000cfe000)
[ 3.476277] [1: init: 1] init: init first stage started!
[ 3.529368] [1: init: 1] type=1403 audit(1453366203.560:2): policy loaded auid=4294967295 ses=4294967295
[ 3.529948] [1: init: 1] init: (Initializing SELinux non-enforcing took 0.05s.)
[ 3.532836] [2: init: 1] init: init second stage started!
[ 3.537014] [2: init: 1] init: property_set(“ro.boot.mode”, “emmc”) failed
[ 3.537170] [2: init: 1] init: OK,SD DRIVERS INIT OK
[ 3.537210] [2: init: 1] init: property_set(“ro.boot.mode”, “sd”) failed
[ 3.537319] [2: init: 1] init: property_set(“ro.hardware”, “rk30board”) failed
[ 3.537573] [2: init: 1] init: -----set_soc_if_need,get soc=roc-rk3328-cc,len = 13
[ 3.540684] [2: init: 1] init: Running restorecon…
[ 3.602474] [2: init: 1] init: waitpid failed: No child processes
[ 3.602822] [2: init: 1] init: (Loading properties from /default.prop took 0.00s.)
[ 3.605286] [2: init: 1] init: (Parsing /init.environ.rc took 0.00s.)
[ 3.605867] [2: init: 1] init: (Parsing /init.usb.rc took 0.00s.)
[ 3.607082] [2: init: 1] init: (Parsing init.rk30board.bootmode.sd.rc took 0.00s.)
[ 3.608450] [2: init: 1] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[ 3.608547] [2: init: 1] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[ 3.608606] [2: init: 1] init: could not import file ‘/init.debug.rc’ from ‘init.rockchip.rc’: No such file or directory
[ 3.608634] [2: init: 1] init: (Parsing init.rockchip.rc took 0.00s.)
[ 3.608875] [2: init: 1] init: (Parsing init.connectivity.rc took 0.00s.)
[ 3.609005] [2: init: 1] init: (Parsing init.box.samba.rc took 0.00s.)
[ 3.609052] [2: init: 1] init: could not import file ‘init.rk3328.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 3.609232] [2: init: 1] init: (Parsing init.box.rc took 0.00s.)
[ 3.609273] [2: init: 1] init: could not import file ‘init.car.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 3.609311] [2: init: 1] init: could not import file ‘init.optee.rc’ from ‘/init.rk30board.rc’: No 609337] [2: init: 1] init: (Parsing /init.rk30board.rc took 0.00s.)
[ 3.610260] [2: init: 1] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[ 3.610412] [2: init: 1] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[ 3.610440] [2: init: 1] init: (Parsing /init.rc took 0.01s.)
[ 3.610972] [2: init: 1] init: Starting service ‘ueventd’…
[ 3.612771] [2: init: 1] type=1400 audit(1453366203.643:3): avc: denied { getattr } for pid=1 comm=“init” path=“/sys/kernel/debug/tracing/trace_marker” dev=“debugfs” ino=158 scontext=u:r:init:s0 tcontext=u:object_r:debugfs_trace_marker:s0 tclass=file permissive=1
[ 3.613426] [1: ueventd: 123] ueventd: ueventd started!
[ 3.614221] [1: ueventd: 123] ueventd: invalid gid ‘trace’
[ 3.806204] [1: ueventd: 123] ueventd: Coldboot took 0.19s.
[ 3.983908] [0:vendor_storage_: 115] vendor storage:20160801 ret = 0
[ 4.024528] [2: init: 1] init: Waiting for /dev/.coldboot_done…
[ 4.024620] [2: init: 1] init: Waiting for /dev/.coldboot_done took 0.00s.
[ 4.024688] [2: init: 1] init: /dev/hw_random not found
[ 4.025373] [2: init: 1] keychord: using input dev rk816_pwrkey for fevent
[ 4.025392] [2: init: 1] keychord: using input dev ff1b0030.pwm for fevent
[ 4.025407] [2: init: 1] keychord: using input dev rk29-keypad for fevent
[ 4.031269] [2: init: 1] init: write_file: Unable to open ‘/proc/cpu/alignment’: No such file or directory
[ 4.037041] [2: init: 1] init: write_file: Unable to open ‘/proc/sys/abi/swp’: No such file or directory
[ 4.037275] [2: init: 1] pm policy 0 → 1
[ 4.037939] [2: init: 1] init: /dev/hw_random not found
[ 4.037992] I[0: fb-vsync: 50] dwc_otg_hcd_disconnect_cb: Invalid disconnect interrupt hprt0 = 0x00041803
[ 4.038014] I[0: fb-vsync: 50] dwc_otg_hcd_handle_port_intr: hcd->state = 4, hcd->flags = 1
[ 4.038063] [0: kworker/0:1: 30] ff580000.usb resume, HPRT0:0x41801
[ 4.038699] [3: init: 126] fs_mgr: Warning: unknown flag resize
[ 4.049232] [3: init: 126] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 4.049385] [3: init: 126] fs_mgr: __mount(source=/dev/block/platform/ff500000.rksdmmc/by-name/system,target=/system,type=ext4)=0
[ 4.059163] [3: init: 126] EXT4-fs (mmcblk0p10): warning: maximal mount count reached, running e2fsck is recommended
[ 4.157330] [3: init: 126] EXT4-fs (mmcblk0p10): recovery complete
[ 4.157361] [3: init: 126] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 4.157487] [3: init: 126] fs_mgr: __mount(source=/dev/block/platform/ff500000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
[ 4.158336] [3: init: 126] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 4.168785] [2: khubd: 40] Indeed it is in host mode hprt0 = 00041901
[ 4.216089] [3: init: 126] EXT4-fs (mmcblk0p11): recovery complete
[ 4.216115] [3: init: 126] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 4.216237] [3: init: 126] fs_mgr: check_fs(): mount(/dev/block/platform/ff500000.rksdmmc/by-name/metadata,/metadata,ext4)=0: Success
[ 4.265831] [3: init: 126] fs_mgr: check_fs(): unmount(/metadata) succeeded
[ 4.267101] [3: init: 126] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/ff500000.rksdmmc/by-name/metadata
[ 4.332728] [2: khubd: 40] usb 5-1: new low-speed USB device number 2 using usb20_otg
[ 4.333672] [0: khubd: 40] Indeed it is in host mode hprt0 = 00041901
[ 4.458489] [3: e2fsck: 135] type=1400 audit(1453366204.503:4): avc: denied { getattr } for pid=135 comm=“e2fsck” path=“/dev/block/mmcblk0p11” dev=“tmpfs” ino=1314 scontext=u:r:fsck:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=1
[ 4.458685] [3: e2fsck: 135] type=1400 audit(1453366204.503:5): avc: denied { read } for pid=135 comm=“e2fsck” name=“mmcblk0p11” dev=“tmpfs” ino=1314 scontext=u:r:fsck:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=1
[ 4.458724] [3: e2fsck: 135] type=1400 audit(1453366204.503:6): avc: denied { open } for pid=135 comm=“e2fsck” path=“/dev/block/mmcblk0p11” dev=“tmpfs” ino=1314 scontext=u:r:fsck:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=1
[ 4.458824] [3: e2fsck: 135] type=1400 audit(1453366204.503:7): avc: denied { write } for pid=135 comm=“e2fsck” name=“mmcblk0p11” dev=“tmpfs” ino=1314 scontext=u:r:fsck:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=1
[ 4.458880] [3: e2fsck: 135] type=1400 audit(1453366204.503:8): avc: denied { ioctl } for pid=135 comm=“e2fsck” path=“/dev/block/mmcblk0p11” dev=“tmpfs” ino=1314 ioctlcmd=127c scontext=u:r:fsck:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=1
[ 4.514327] [0: khubd: 40] usb 5-1: New USB device found, idVendor=1c4f, idProduct=0065
[ 4.514358] [0: khubd: 40] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.514378] [0: khubd: 40] usb 5-1: Product: Usb Mouse
[ 4.514399] [0: khubd: 40] usb 5-1: Manufacturer: SIGMACHIP
[ 4.521961] [0: khubd: 40] input: SIGMACHIP Usb Mouse as /devices/ff580000.usb/usb5/5-1/5-1:1.0/input/input3
[ 4.523332] [2: khubd: 40] hid-generic 0003:1C4F:0065.0001: input,hidraw0: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-ff580000.usb-1/input0
[ 4.660892] [3: init: 126] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 4.660967] [3: init: 126] e2fsck: /dev/block/platform/ff500000.rksdmmc/by-name/metadata has been mounted 10 times without being checked, check forced.
[ 4.661000] [3: init: 126] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 4.661027] [3: init: 126] e2fsck: Pass 2: Checking directory structure
[ 4.661054] [3: init: 126] e2fsck: Pass 3: Checking directory connectivity
[ 4.661080] [3: init: 126] e2fsck: Pass 4: Checking reference counts
[ 4.661106] [3: init: 126] e2fsck: Pass 5: Checking group summary information
[ 4.661134] [3: init: 126] e2fsck: /dev/block/platform/ff500000.rksdmmc/by-name/metadata: 11/1024 files (0.0% non-contiguous), 1102/4096 blocks
[ 4.715196] [3: init: 126] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 4.715320] [3: init: 126] fs_mgr: __mount(source=/dev/block/platform/ff500000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
[ 4.716272] [3: init: 126] EXT4-fs (mmcblk0p14): Ignoring removed nomblk_io_submit option
[ 7.899214] [0: init: 126] EXT4-fs (mmcblk0p14): recovery complete
[ 7.987881] [0: init: 126] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 7.988022] [0: init: 126] fs_mgr: check_fs(): mount(/dev/block/platform/ff500000.rksdmmc/by-name/userdata,/data,ext4)=0: Success
[ 8.040168] [0: init: 126] fs_mgr: check_fs(): unmount(/data) succeeded
[ 8.040227] [0: init: 126] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/ff500000.rksdmmc/by-name/userdata
[ 8.162769] [0: init: 126] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 8.162838] [0: init: 126] e2fsck: /dev/block/platform/ff500000.rksdmmc/by-name/userdata: clean, 7155/374624 files, 143415/1496064 blocks (check in 4 mounts)
[ 8.213179] [3: init: 126] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 8.213308] [3: init: 126] fs_mgr: __mount(source=/dev/block/platform/ff500000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
[ 8.225386] [0: init: 1] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[ 8.226180] [0: init: 1] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[ 8.226867] [0: init: 1] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[ 8.227706] [0: init: 1] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[ 8.228434] [0: init: 1] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[ 8.229135] [0: init: 1] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[ 8.229797] [0: init: 1] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[ 8.230511] [0: init: 1] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[ 8.231344] [0: init: 1] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[ 8.232069] [0: init: 1] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[ 8.232799] [0: init: 1] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[ 8.233508] [0: init: 1] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[ 8.234209] [0: init: 1] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[ 8.234843] [0: init: 1] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[ 8.235740] [0: init: 1] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[ 8.236524] [0: init: 1] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[ 8.237210] [0: init: 1] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[ 8.237856] [0: init: 1] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[ 8.238504] [0: init: 1] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[ 8.239143] [0: init: 1] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[ 8.239867] [0: init: 1] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[ 8.240547] [0: init: 1] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[ 8.241205] [0: init: 1] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[ 8.241864] [0: init: 1] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[ 8.242568] [0: init: 1] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[ 8.243258] [0: init: 1] init: ignored duplicate definition of service ‘ril-daemon’init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[ 8.244037] [0: init: 1] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[ 8.244693] [0: init: 1] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[ 8.245391] [0: init: 1] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[ 8.246099] [0: init: 1] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[ 8.246818] [0: init: 1] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[ 8.249218] [0: init: 1] init: property_set(“ro.board.platform”, “rk3328”) failed
[ 8.249525] [0: init: 1] init: property_set(“ro.opengles.version”, “196609”) failed
[ 8.249655] [0: init: 1] init: property_set(“ro.rk.screenoff_time”, “2147483647”) failed
[ 8.249849] [0: init: 1] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[ 8.249977] [0: init: 1] init: (Loading properties from /system/build.prop took 0.00s.)
[ 8.250084] [0: init: 1] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 8.250121] [0: init: 1] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 8.250255] [0: init: 1] fs_mgr: Warning: unknown flag resize
[ 8.250377] [0: init: 1] init: /recovery not specified in fstab
[ 8.250500] [0: init: 1] init: Starting service ‘healthd’…
[ 8.252064] [0: init: 1] init: Starting service ‘displayd’…
[ 8.252950] [0: init: 1] init: Starting service ‘zygote’…
[ 8.253037] [3: healthd: 143] binder: 143:143 transaction failed 29189, size 0-0
[ 8.253658] [0: init: 1] init: Starting service ‘zygote_secondary’…
[ 8.254567] [0: init: 1] init: Starting service ‘lmkd’…
[ 8.256034] [0: init: 1] init: Starting service ‘servicemanager’…
[ 8.259506] [0: displayd: 144] type=1400 audit(1453366208.366:9): avc: denied { getattr } for pid=144 comm=“displayd” path=“/vendor” dev=“rootfs” ino=5191 scontext=u:r:displayd:s0 tcontext=u:object_r:rootfs:s0 tclass=lnk_file permissive=1
[ 8.260089] [2: init: 1] init: Starting service ‘surfaceflinger’…
[ 8.260878] [2: init: 1] init: Starting service ‘vold’…
[ 8.478349] [2: init: 1] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali_kbase.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/rk30_mirroring.ko”) failed: No such file or directoryinit: finit_module for “/system/lib/modules/rk29-ipp.ko” failed: Exec format errorinit: insmod: open(“/system/lib/modules/pvrsrvkm.ko”) failed: No such file or directoryinit: finit_module for “/drmboot.ko” failed: Exec format errorfs_mgr: Warning: unknown flag resize
[ 8.483329] [0: init: 1] zram0: detected capacity change from 0 to 533413888
[ 8.904838] [0: displayd: 144] type=1400 audit(1453366209.020:10): avc: denied { read } for pid=144 comm=“displayd” name=“psched” dev=“proc” ino=4026532760 scontext=u:r:displayd:s0 tcontext=u:object_r:proc_net:s0 tclass=file permissive=1
[ 8.904891] [0: displayd: 144] type=1400 audit(1453366209.020:11): avc: denied { open } for pid=144 comm=“displayd” path=“/proc/144/net/psched” dev=“proc” ino=4026532760 scontext=u:r:displayd:s0 tcontext=u:object_r:proc_net:s0 tclass=file permissive=1
[ 8.904958] [0: displayd: 144] type=1400 audit(1453366209.020:12): avc: denied { getattr } for pid=144 comm=“displayd” path=“/proc/144/net/psched” dev=“proc” ino=4026532760 scontext=u:r:displayd:s0 tcontext=u:object_r:proc_net:s0 tclass=file permissive=1
[ 8.905738] [0: displayd: 144] type=1400 audit(1453366209.023:13): avc: denied { read } for pid=144 comm=“displayd” name=“lcdcid” dev=“sysfs” ino=7848 scontext=u:r:displayd:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 8.905782] [0: displayd: 144] type=1400 audit(1453366209.023:14): avc: denied { open } for pid=144 comm=“displayd” path=“/sys/devices/fb.17/graphics/fb0/lcdcid” dev=“sysfs” ino=7848 scontext=u:r:displayd:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 8.905827] [0: displayd: 144] type=1400 audit(1453366209.023:15): avc: denied { getattr } for pid=144 comm=“displayd” path=“/sys/devices/fb.17/graphics/fb0/lcdcid” dev=“sysfs” ino=7848 scontext=u:r:displayd:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 9.127351] [0: init: 1] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 9.129247] [1: displayd: 144] type=1400 audit(1453366209.250:16): avc: denied { read } for pid=144 comm=“displayd” name=“display” dev=“sysfs” ino=6988 scontext=u:r:displayd:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 9.129305] [1: displayd: 144] type=1400 audit(1453366209.250:17): avc: denied { open } for pid=144 comm=“displayd” path=“/sys/class/display” dev=“sysfs” ino=6988 scontext=u:r:displayd:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 9.130521] [0: init: 1] init: Starting service ‘debuggerd’…
[ 9.131293] [0: init: 1] init: Starting service ‘debuggerd64’…
[ 9.313807] [0: init: 1] init: Not bootcharting.
[ 9.358552] [0: healthd: 143] healthd: No battery devices found
[ 9.555976] [0: vold: 150] fs_mgr: Warning: unknown flag resize
[ 9.871004] [0: surfaceflinger: 149] rk322xh-lcdc vop0: blank mode:0
[ 9.872079] [2: init: 1] init: Starting service ‘bootanim’…
[ 11.006575] [2: init: 1] init: Starting service ‘exec 1 (/system/bin/tzdatacheck)’…
[ 11.030513] [2: kworker/2:1: 33] [otg id chg] last id -1 current id 64
[ 11.115559] [2: init: 1] init: Service ‘exec 1 (/system/bin/tzdatacheck)’ (pid 180) exited with status 0
[ 11.144261] [2: init: 1] type=1400 audit(1453366211.296:18): avc: denied { setattr } for pid=1 comm=“init” name=“cifsmanager” dev=“mmcblk0p14” ino=203601 scontext=u:r:init:s0 tcontext=u:object_r:cifsmanager_exec:s0 tclass=dir permissive=1
[ 15.179132] [2: init: 1] EXT4-fs (mmcblk0p14): Unrecognized mount option “background_gc=on” or missing value
[ 15.223729] [2: init: 1] init: (Loading properties from /data/local.prop took 0.00s.)
[ 21.245947] [2: init: 1] init: Starting service ‘logd’…
[ 21.246628] [2: init: 1] init: Starting service ‘logd-reinit’…
[ 21.249623] [2: init: 1] init: SELinux: Could not stat /sys/devices/system/cpu/cpufreq/interactive: No such file or directory.
[ 21.250780] [2: init: 1] init: write_file: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold’: No such file or directory
[ 21.252552] [2: init: 1] init: SELinux: Could not get canonical path for /dev/block/platform/fe330000.sdhci/by-name/ restorecon: No such file or directory.
[ 21.253117] [2: init: 1] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 21.253147] [2: init: 1] init: write: cannot expand ‘${ro.serialno}’
[ 21.253408] [2: init: 1] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 21.301786] [2: init: 1] init: Starting service ‘console’…
[ 21.302293] [2: init: 1] android_usb: already disabled
[ 21.302513] [2: init: 1] init: Starting service ‘adbd’…
[ 21.304031] [2: init: 1] type=1400 audit(1453366221.623:19): avc: denied { getattr } for pid=1 comm=“init” path=“/system/xbin/su” dev=“mmcblk0p13” ino=2096 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 21.304095] [2: init: 1] init: Starting service ‘su_daemon’…
[ 21.304890] [3: init: 195] type=1400 audit(1453366221.623:20): avc: denied { execute } for pid=195 comm=“init” name=“su” dev=“mmcblk0p13” ino=2096 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 21.304944] [3: init: 195] type=1400 audit(1453366221.623:21): avc: denied { read open } for pid=195 comm=“init” path=“/system/xbin/su” dev=“mmcblk0p13” ino=2096 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 21.305049] [3: init: 195] type=1400 audit(1453366221.623:22): avc: denied { transition } for pid=195 comm=“init” path=“/system/xbin/su” dev=“mmcblk0p13” ino=2096 scontext=u:r:init:s0 tcontext=u:r:sudaemon:s0 tclass=process permissive=1
[ 21.305094] [3: init: 195] type=1400 audit(1453366221.623:23): avc: denied { entrypoint } for pid=195 comm=“init” path=“/system/xbin/su” dev=“mmcblk0p13” ino=2096 scontext=u:r:sudaemon:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 21.305102] [2: init: 1] init: cannot find ‘/system/bin/update_verifier’ (No such file or directory), disabling ‘exec 2 (/system/bin/update_verifier)’
[ 21.305160] [2: init: 1] init: cannot find ‘/system/bin/install-recovery.sh’ (No such file or directory), disabling ‘flash_recovery’
[ 21.305669] [2: init: 1] init: Starting service ‘drmservice’…
[ 21.306197] [2: init: 1] init: cannot find ‘/system/bin/bplus_helper’ (No such file or directory), disabling ‘bplus_helper’
[ 21.306759] [2: init: 1] init: Service up_eth0 does not have a SELinux domain defined.
[ 21.306808] [2: init: 1] init: cannot find ‘/system/bin/rk_store_keybox’ (No such file or directory), disabling ‘rk_store_keybox’
[ 21.306880] [2: init: 1] init: cannot find ‘/system/bin/akmd’ (No such file or directory), disabling ‘akmd’
[ 21.307377] [2: init: 1] init: Starting service ‘audioserver’…
[ 21.308230] [2: init: 1] init: Starting service ‘cameraserver’…
[ 21.308652] [3: init: 198] init: couldn’t write 198 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 21.309054] [2: init: 1] init: Starting service ‘drm’…
[ 21.309908] [2: init: 1] init: Starting service ‘installd’…
[ 21.310786] [2: init: 1] init: Starting service ‘keystore’…
[ 21.311722] [2: init: 1] init: Starting service ‘mediacodec’…
[ 21.312568] [2: init: 1] init: Starting service ‘mediadrm’…
[ 21.313519] [2: init: 1] init: Starting service ‘mediaextractor’…
[ 21.314410] [2: init: 1] init: Starting service ‘media’…
[ 21.315301] [2: init: 1] init: Starting service ‘netd’…
[ 21.316175] [2: init: 1] init: Starting service ‘gatekeeperd’…
[ 21.317233] [2: init: 1] init: Starting service ‘perfprofd’…
[ 21.320087] [3: su: 195] type=1400 audit(1453366221.640:24): avc: denied { rlimitinh } for pid=195 comm=“su” scontext=u:r:init:s0 tcontext=u:r:sudaemon:s0 tclass=process permissive=1
[ 21.320129] [3: su: 195] type=1400 audit(1453366221.640:25): avc: denied { siginh } for pid=195 comm=“su” scontext=u:r:init:s0 tcontext=u:r:sudaemon:s0 tclass=process permissive=1
[ 21.320198] [3: su: 195] type=1400 audit(1453366221.640:26): avc: denied { noatsecure } for pid=195 comm=“su” scontext=u:r:init:s0 tcontext=u:r:sudaemon:s0 tclass=process permissive=1
[ 21.321311] [3: su: 195] type=1400 audit(1453366221.640:27): avc: denied { read } for pid=195 comm=“su” path=“/system/xbin/su” dev=“mmcblk0p13” ino=2096 scontext=u:r:sudaemon:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 21.321568] [3: su: 195] type=1400 audit(1453366221.640:28): avc: denied { write } for pid=195 comm=“su” name=“/” dev=“tmpfs” ino=1166 scontext=u:r:sudaemon:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1
[ 22.356101] [0: logd: 187] logd.auditd: start
[ 22.356647] [0: logd: 187] logd.klogd: 20307030437
roc_rk3328_cc_box:/ $ [ 23.196496] [2: init: 1] init: Service ‘logd-reinit’ (pid 188) exited with status 145
[ 23.196709] [2: init: 1] init: Service ‘drmservice’ (pid 196) exited with status 0
[ 23.232266] [3: logd.auditd: 272] type=1400 audit(1453366223.556:34): avc: denied { execute } for pid=269 comm=“audioserver” name=“sh” dev=“mmcblk0p13” ino=387 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 23.234604] [3: logd.auditd: 272] type=1400 audit(1453366223.556:35): avc: denied { read open } for pid=269 comm=“audioserver” path=“/system/bin/sh” dev=“mmcblk0p13” ino=387 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 23.236803] [3: logd.auditd: 272] type=1400 audit(1453366223.560:36): avc: denied { execute_no_trans } for pid=269 comm=“audioserver” path=“/system/bin/sh” dev=“mmcblk0p13” ino=387 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 23.239056] [3: logd.auditd: 272] type=1400 audit(1453366223.560:37): avc: denied { getattr } for pid=269 comm=“sh” path=“/system/bin/sh” dev=“mmcblk0p13” ino=387 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 23.241166] [3: logd.auditd: 272] type=1400 audit(1453366223.566:38): avc: denied { getattr } for pid=269 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk0p13” ino=420 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 23.242208] [1: logd.auditd: 272] type=1400 audit(1453366223.566:39): avc: denied { execute } for pid=269 comm=“sh” name=“toybox” dev=“mmcblk0p13” ino=420 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 23.242657] [1: logd.auditd: 272] type=1400 audit(1453366223.566:40): avc: denied { read open } for pid=269 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk0p13” ino=420 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 23.242807] [1: logd.auditd: 272] type=1400 audit(1453366223.566:41): avc: denied { execute_no_trans } for pid=269 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk0p13” ino=420 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 23.276950] [1: usb ffs open: 276] read descriptors
[ 23.276980] [1: usb ffs open: 276] read descriptors
[ 23.276996] [1: usb ffs open: 276] read strings
[ 23.277036] [1: usb ffs open: 276] pcd_pullup, is_on 1
[ 25.754246] [1: logd.auditd: 272] type=1400 audit(1453366226.143:42): avc: denied { create } for pid=197 comm=“audioserver” scontext=u:r:audioserver:s0 tcontext=u:r:audioserver:s0 tclass=netlink_kobject_uevent_socket permissive=1
[ 25.754573] [1: logd.auditd: 272] type=1400 audit(1453366226.143:43): avc: denied { setopt } for pid=197 comm=“audioserver” scontext=u:r:audioserver:s0 tcontext=u:r:audioserver:s0 tclass=netlink_kobject_uevent_socket permissive=1
[ 25.754711] [1: logd.auditd: 272] type=1400 audit(1453366226.143:44): avc: denied { bind } for pid=197 comm=“audioserver” scontext=u:r:audioserver:s0 tcontext=u:r:audioserver:s0 tclass=netlink_kobject_uevent_socket permissive=1
[ 27.611960] [3: system_server: 473] warning: `system_server’ uses 32-bit capabilities (legacy support in use)
[ 36.815320] [3: system_server: 433] acc_open
[ 36.815770] [3: system_server: 433] acc_release
[ 37.155601] [2: Binder:206_2: 462] phy_power_on: enable = 1
[ 37.195073] [2: Binder:206_2: 462] rk_devinfo_get_eth_mac: 00.00.00.00.00.00
[ 37.195101] [2: Binder:206_2: 462] eth_mac_vendor_storage: rk_vendor_read eth mac address: 66:2e:95:fe:d1:9e
[ 37.195117] [2: Binder:206_2: 462] eth0: device MAC address 66:2e:95:fe:d1:9e
[ 37.195428] [1: logd.auditd: 272] type=1400 audit(1453366237.773:45): avc: denied { read } for pid=197 comm=“audioserver” scontext=u:r:audioserver:s0 tcontext=u:r:audioserver:s0 tclass=netlink_kobject_uevent_socket permissive=1
[ 37.200468] [2: Binder:206_2: 462] libphy: stmmac: probed
[ 37.200495] [2: Binder:206_2: 462] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
[ 37.200510] [2: Binder:206_2: 462] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
[ 39.405102] [1: logd.auditd: 272] type=1400 audit(1453366240.016:46): avc: denied { search } for pid=205 comm=“mediaserver” name=“433” dev=“proc” ino=9214 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=dir permissive=1
[ 39.405299] [1: logd.auditd: 272] type=1400 audit(1453366240.016:47): avc: denied { read } for pid=205 comm=“mediaserver” name=“cmdline” dev=“proc” ino=10733 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=file permissive=1
[ 39.405431] [1: logd.auditd: 272] type=1400 audit(1453366240.016:48): avc: denied { open } for pid=205 comm=“mediaserver” path=“/proc/433/cmdline” dev=“proc” ino=10733 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=file permissive=1
[ 41.543438] [3: logd.auditd: 272] type=1400 audit(1453366242.190:49): avc: denied { read } for pid=197 comm=“AudioOut_D” name=“audioinfo” dev=“sysfs” ino=10441 scontext=u:r:audioserver:s0 tcontext=u:object_r:sysfs_hdmi:s0 tclass=file permissive=1
[ 41.545815] [3: logd.auditd: 272] type=1400 audit(1453366242.190:50): avc: denied { open } for pid=197 comm=“AudioOut_D” path=“/sys/devices/virtual/display/HDMI/audioinfo” dev=“sysfs” ino=10441 scontext=u:r:audioserver:s0 tcontext=u:object_r:sysfs_hdmi:s0 tclass=file permissive=1
[ 41.552617] [3: logd.auditd: 272] type=1400 audit(1453366242.190:51): avc: denied { getattr } for pid=197 comm=“AudioOut_D” path=“/sys/devices/virtual/display/HDMI/audioinfo” dev=“sysfs” ino=10441 scontext=u:r:audioserver:s0 tcontext=u:object_r:sysfs_hdmi:s0 tclass=file permissive=1
[ 43.248431] [0: init: 1] init: write_file: Unable to open ‘/sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq’: No such file or directory
[ 44.860332] [2: init: 1] init: cannot find ‘/system/bin/glgps’ (No such file or directory), disabling ‘gpsd’
[ 44.862932] [2: init: 1] init: Starting service ‘exec 3 (/system/bin/bootstat)’…
[ 45.078261] [3: init: 1] init: Service ‘exec 3 (/system/bin/bootstat)’ (pid 852) exited with status 0
[ 45.078727] [3: init: 1] init: Starting service ‘exec 4 (/system/bin/bootstat)’…
[ 45.101093] [3: init: 1] init: Service ‘exec 4 (/system/bin/bootstat)’ (pid 853) exited with status 0
[ 45.101549] [3: init: 1] init: Starting service ‘exec 5 (/system/bin/bootstat)’…
[ 45.304241] [3: init: 1] init: Service ‘exec 5 (/system/bin/bootstat)’ (pid 854) exited with status 0
[ 45.304778] [3: init: 1] init: Starting service ‘exec 6 (/system/bin/bootstat)’…
[ 45.357949] [1: init: 1] init: Service ‘exec 6 (/system/bin/bootstat)’ (pid 855) exited with status 0
[ 47.980832] [1: init: 1] init: Service ‘bootanim’ is being killed…
[ 47.986283] [2: init: 1] init: Service ‘bootanim’ (pid 178) killed by signal 9
[ 51.563817] [1: logd.auditd: 272] type=1400 audit(1453366252.373:52): avc: denied { read } for pid=1015 comm=“ContactsProvide” name=“mm_stat” dev=“sysfs” ino=11488 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:sysfs_zram:s0 tclass=file permissive=1
[ 51.566875] [1: logd.auditd: 272] type=1400 audit(1453366252.373:53): avc: denied { open } for pid=1015 comm=“ContactsProvide” path=“/sys/devices/virtual/block/zram0/mm_stat” dev=“sysfs” ino=11488 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:sysfs_zram:s0 tclass=file permissive=1
[ 51.568410] [2: logd.auditd: 272] type=1400 audit(1453366252.373:54): avc: denied { getattr } for pid=1015 comm=“ContactsProvide” path=“/sys/devices/virtual/block/zram0/mm_stat” dev=“sysfs” ino=11488 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:sysfs_zram:s0 tclass=file permissive=1
