你好我们使用RK3399 外接 M.2 B KEY WWAN设备,发现在PCIE 初始化阶段 出现如下错误。我们初步分析应该是开发板 PCIE接口就没有工作,请帮忙检查确认下。
[ 0.334584] rockchip-pcie f8000000.pcie: zhaofei test go to fun[rockchip_pcie_probe],line[1292]
[ 0.335966] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.336548] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.337139] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.589008] rockchip-pcie f8000000.pcie: zhaofei test go to fun[rockchip_pcie_init_port],line[573]
[ 1.089821] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.090559] rockchip-pcie: probe of f8000000.pcie failed with error -110
PCIE vpcie3v3,vpcie1v8,vpcie0v9 都没找到,使用的是官方的镜像 。 请官方尽快回复一下,PCIE接口是否能够正常工作
PCIe link training gen1 timeout! 是否是官方DTS配置出错了
leung
November 29, 2018, 3:25am
4
leung先森 发表于 2018-11-29 11:25
供电肯定是有的,log上面的参数没用到自然就这样显示。
pcie在初始化时尝试与设备通信,通信失败就会卸 …
您好,多谢分析。你认为是不是在没有外接PCIE设备时候,系统初始化PCIE 控制器的时候 就应该输出这样的错误lOG?
leung
November 29, 2018, 3:46am
6
18091852872 发表于 2018-11-29 11:34
您好,多谢分析。你认为是不是在没有外接PCIE设备时候,系统初始化PCIE 控制器的时候 就应该输出这样的错 …
rk3399_firefly_aio_box:/ $ dmesg | grep pcie
[ 0.214536] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc3v3-pcie-regulator[0]' - status (0)
[ 0.377600] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[ 0.377615] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[ 0.377642] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[ 0.377871] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.377897] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.377921] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.398693] PCI host bridge /pcie@f8000000 ranges:
[ 0.399054] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[ 0.405439] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 0.405654] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.405685] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
[ 0.405785] aer 0000:00:00.0:pcie02: service driver aer loaded
不是,上面的log是和SSD成功通信后的输出,你可以对比下,并不是所有提示的log都是有用的,很多log都是为了兼容性而添加的参数,有则加载,没有也不影响。
leung先森 发表于 2018-11-29 11:46
不是,上面的log是和SSD成功通信后的输出,你可以对比下,并不是所有提示的log都是有用的,很多log都是 …
有两个问题
RK3399 M.2接口 只能接SSD 是否可以外接其他设备比如 M.2 B KEY WWAN设备
2.从你这边的LOG看已经设别到固态硬盘了,你使用的是什么型号的?如何连接的?
我们使用时附件型号
leung
November 29, 2018, 6:14am
8
18091852872 发表于 2018-11-29 11:56
有两个问题
你这种肯定不行。
1.必须是nvme,sata的都不行
2.pcie M.2 NGFF Bkey,带有Mkey/Bkey兼容接口都不支持。能用的英特尔600P系列,三星evo系列
leung先森 发表于 2018-11-29 14:14
你这种肯定不行。
1.必须是nvme,sata的都不行
2.pcie M.2 NGFF Bkey,带有Mkey/Bkey兼容接口都不支持 …
多谢回复!
我们如果外接 pcie M.2 NGFF Bkey 的wwan设备 是否可以支持?
你这种肯定不行。
1.必须是nvme,sata的都不行
请问为何不支持B&Mkey的呢?他不是兼容接口么?
ooxx
October 10, 2019, 10:15am
12
leung先森 发表于 2019-8-12 09:33
不是
为啥这个不兼容啊?
b&m key 应该是兼容bkey 和 m key的吧?
那真正的b key的nvm 是啥样?有图吗?
谢谢!
leung
October 10, 2019, 12:47pm
13
ooxx 发表于 2019-10-10 18:15
为啥这个不兼容啊?
1.必须是nvme,sata的都不行
三星 MZ-V7E250BW 250G 970EVO plus pcie m2 nvme
intel/英特尔 600p 360G M.2 PCIe NVMe M2固态硬盘
