自己根据Firefly的原理图做了一个板子,烧写Firefly-RK3399_Android7.1.2_MP_180706.img无法开机,系统显示开机大图标,同一个板子烧写RK3399_Evb_Debian_V2.2_20180704可以开机进系统,不能开机LOG如下,
DDR Version 1.09 20171117
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1: 2017-06-09, version: 1.09
CPUId = 0x0
ChipType = 0x10, 1834
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 66611
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x7a1f4
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):9f93abc
NOTICE: BL31: Built : 10:18:20, Jul 27 2017
INFO: plat_rockchip_pmu_init(1089): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-126-g2a74125 #1 Fri Dec 22 01:53:31 UTC 2017 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.1
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Jul 05 2018 - 15:12:31)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2018-07-05#1.09
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
failed to find phy node
failed to find panel driver
no fuel gauge found
can’t find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
rockchip_panel_deinit: failed to find panel deinit funcs
failed to display kernel logo
checkKey
vbus = 1
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel @ 0x00280000 (0x01227808)
ramdisk @ 0x04bf0000 (0x001ad960)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 00000000046164f4 … OK
Add bank:000000000a200000, 0000000075e00000
[ 0.000000] Linux version 4.4.103 (firefly@tchip-server) (gcc version 4.9 20150123 (prerelease) (GCC) ) #115 SMP PREEMPT Fri Jul 6 14:27:10 CST 2018
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eefa000 s45504 r8192 d32320 u86016
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00300000@0x000B4000(system),0x00008000@0x003B4000(metadata),0x00002000@0x003BC000(baseparamer),-@0x003BE000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2018-07-05_15:12:31 hdmi.vic=-1 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0x7eeb1000-0x7eef1000] (0MB) mapped at [ffffffc07eeb1000-ffffffc07eef0fff]
[ 0.000000] Memory: 1988800K/2064384K available (10878K kernel code, 1630K rwdata, 5208K rodata, 832K init, 1069K bss, 59200K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009040000 - 0xffffff8009110000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b20000 ( 10880 KB)
[ 0.000000] .rodata : 0xffffff8008b20000 - 0xffffff8009040000 ( 5248 KB)
[ 0.000000] .data : 0xffffff8009110000 - 0xffffff80092a7808 ( 1631 KB)
[ 0.001957] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002921] pid_max: default: 32768 minimum: 301
[ 0.003438] Security Framework initialized
[ 0.003829] SELinux: Initializing.
[ 0.004242] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004870] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006307] Initializing cgroup subsys freezer
[ 0.006735] Initializing cgroup subsys debug
[ 0.008048] sched-energy: Sched-energy-costs installed from DT
[ 0.008598] CPU0: update cpu_capacity 401
[ 0.009048] ASID allocator initialised with 65536 entries
[ 0.025876] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027136] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039276] Detected VIPT I-cache on CPU1
[ 0.039307] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039342] CPU1: using LPI pending table @0x000000000a3f0000
[ 0.039384] CPU1: update cpu_capacity 401
[ 0.039388] CPU1: Booted secondary processor [410fd034]
[ 0.049269] Detected VIPT I-cache on CPU2
[ 0.049289] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049321] CPU2: using LPI pending table @0x000000007c020000
[ 0.049349] CPU2: update cpu_capacity 401
[ 0.049352] CPU2: Booted secondary processor [410fd034]
[ 0.059307] Detected VIPT I-cache on CPU3
[ 0.059325] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059358] CPU3: using LPI pending table @0x000000007c060000
[ 0.059384] CPU3: update cpu_capacity 401
[ 0.059387] CPU3: Booted secondary processor [410fd034]
[ 0.069357] Detected PIPT I-cache on CPU4
[ 0.069386] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069425] CPU4: using LPI pending table @0x000000007c0a0000
[ 0.069465] CPU4: update cpu_capacity 1024
[ 0.069468] CPU4: Booted secondary processor [410fd082]
[ 0.079378] Detected PIPT I-cache on CPU5
[ 0.079396] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079433] CPU5: using LPI pending table @0x000000007c0e0000
[ 0.079460] CPU5: update cpu_capacity 1024
[ 0.079463] CPU5: Booted secondary processor [410fd082]
[ 0.079547] Brought up 6 CPUs
[ 0.091646] SMP: Total of 6 processors activated.
[ 0.092088] CPU features: detected feature: GIC system register CPU interface
[ 0.092759] CPU: All CPU(s) started at EL2
[ 0.093181] alternatives: patching kernel code
[ 0.095286] devtmpfs: initialized
[ 0.115595] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.116569] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.117885] pinctrl core: initialized pinctrl subsystem
[ 0.119980] Failed to find legacy iommu devices
[ 0.120788] NET: Registered protocol family 16
[ 0.121569] schedtune: init normalization constants…
[ 0.122072] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.122706] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.123350] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.123982] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.124615] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.125248] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.125880] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.126512] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.127173] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.127807] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.128546] schedtune: verify normalization constants…
[ 0.129061] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.129601] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.130140] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.130688] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.131227] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.131767] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.132305] schedtune: configured to support 5 boost groups
[ 0.140723] cpuidle: using governor ladder
[ 0.150728] cpuidle: using governor menu
[ 0.151122] Registered FIQ tty driver
[ 0.151791] vdso: 2 pages (1 code @ ffffff8008b26000, 1 data @ ffffff8009114000)
[ 0.152526] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.153897] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.174933] console [pstore0] enabled
[ 0.175529] pstore: Registered ramoops as persistent store backend
[ 0.176132] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.178859] sip_fiq_debugger_uart_irq_tf_init error: -2
[ 0.179372] fiq debugger bind fiq to trustzone failed: -2
[[ 0.180189] console [ttyFIQ0] enabled
[[ 0.180881] bootconsole [uart0] disabled
[ 0.181807] Registered fiq debugger ttyFIQ0
[ 0.212658] Rockchip hdmi driver version 2.0
[ 0.214902] iommu: Adding device ff650000.vpu_service to group 0
[ 0.214979] iommu: Adding device ff660000.rkvdec to group 1
[ 0.215071] iommu: Adding device ff670000.iep to group 2
[ 0.215165] iommu: Adding device ff8f0000.vop to group 3
[ 0.215244] iommu: Adding device ff900000.vop to group 4
[ 0.215349] iommu: Adding device ff910000.isp to group 5
[ 0.215424] iommu: Adding device ff920000.isp to group 6
[ 0.216112] rk_iommu ff670800.iommu: can’t get aclk
[ 0.216131] rk_iommu ff670800.iommu: can’t get hclk
[ 0.217007] SCSI subsystem initialized
[ 0.217338] usbcore: registered new interface driver usbfs
[ 0.217383] usbcore: registered new interface driver hub
[ 0.217454] usbcore: registered new device driver usb
[ 0.217826] media: Linux media interface: v0.10
[ 0.217867] Linux video capture interface: v2.00
[ 0.218000] pps_core: LinuxPPS API ver. 1 registered
[ 0.218012] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.218039] PTP clock support registered
[ 0.219556] Advanced Linux Sound Architecture Driver Initialized.
[ 0.220023] Bluetooth: Core ver 2.21
[ 0.220073] NET: Registered protocol family 31
[ 0.220083] Bluetooth: HCI device and connection manager initialized
[ 0.220100] Bluetooth: HCI socket layer initialized
[ 0.220115] Bluetooth: L2CAP socket layer initialized
[ 0.220144] Bluetooth: SCO socket layer initialized
[ 0.221226] rockchip-cpuinfo cpuinfo: Serial : 149ecdd9c170ff6c
[ 0.221692] clocksource: Switched to clocksource arch_sys_counter
[ 0.264357] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.264604] NET: Registered protocol family 2
[ 0.265037] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.265137] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.265260] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.265337] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.265368] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.265523] NET: Registered protocol family 1
[ 0.266018] Trying to unpack rootfs image as initramfs…
[ 0.354437] Freeing initrd memory: 1716K
[ 0.354941] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.355109] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.357701] audit: initializing netlink subsys (disabled)
[ 0.357765] audit: type=2000 audit(0.353:1): initialized
[ 0.366078] VFS: Disk quotas dquot_6.6.0
[ 0.366202] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.367561] fuse init (API version 7.23)
[ 0.368719]
[ 0.368719] TEE Core Framework initialization (ver 1:0.1)
[ 0.368752] TEE armv7 Driver initialization
[ 0.369121] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.369138] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.369318] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.373273] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.373301] io scheduler noop registered
[ 0.373472] io scheduler cfq registered (default)
[ 0.374733] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.379836] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.379861] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.379884] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.901754] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.901933] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.903329] iep: failed to find iep power down clock source.
[ 0.903981] IEP Power ON
[ 0.904197] IEP Power OFF
[ 0.904357] IEP Driver loaded succesfully
[ 0.904588] Module initialized.
[ 0.905251] rk-vcodec ff650000.vpu_service: probe device
[ 0.905298] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07c2fa410
[ 0.905479] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.905543] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.906124] rk-vcodec ff650000.vpu_service: init success
[ 0.906750] rk-vcodec ff660000.rkvdec: probe device
[ 0.906800] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07c2fac10
[ 0.906945] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.907003] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.907326] rk-vcodec ff660000.rkvdec: init success
[ 0.908784] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.908803] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.910119] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.910137] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 N]u+ͷȷts-16
[ 0.911746] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.913336] console [ttyS0] disabled
[ 0.913380] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 0.913939] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.914520] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 40, base_baud = 1500000) is a 16550A
[ 0.914901] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 0.919834] mali ff9a0000.gpu: Failed to get regulator
[ 0.919882] mali ff9a0000.gpu: Power control initialization failed
[ 0.920172] Unable to detect cache hierarchy from DT for CPU 0
[ 0.928163] brd: module loaded
[ 0.932873] loop: module loaded
[ 0.933383] zram: Added device: zram0
[ 0.933968] SCSI Media Changer driver v0.25
[ 0.934973] rockchip-pinctrl pinctrl: pin gpio1-8 already requested by ff370000.serial; cannot claim for ff1d0000.spi
[ 0.934995] rockchip-pinctrl pinctrl: pin-40 (ff1d0000.spi) status -22
[ 0.935040] rockchip-pinctrl pinctrl: could not request pin 40 (gpio1-8) from group spi1-tx on device rockchip-pinctrl
[ 0.935066] rockchip-spi ff1d0000.spi: Error applying setting, reverse things back
[ 0.935207] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 0.935222] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 0.935857] register spi return v = :0
[ 0.935912] tun: Universal TUN/TAP device driver, 1.6
[ 0.935922] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.936827] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 0.936918] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 0.936937] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 0.936952] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 0.936979] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 0.937152] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 0.942171] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 0.942294] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.942305] Ring mode enabled
[ 0.942314] DMA HW capability register supported
[ 0.942323] Normal descriptors
[ 0.942334] RX Checksum Offload Engine supported (type 2)
[ 0.942343] Wake-Up On Lan supported
[ 0.942385] Enable RX Mitigation via HW Watchdog Timer
[ 1.011298] libphy: stmmac: probed
[ 1.011320] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.011333] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.012207] PPP generic driver version 2.4.2
[ 1.012414] PPP BSD Compression module registered
[ 1.012430] PPP Deflate Compression module registered
[ 1.012462] PPP MPPE Compression module registered
[ 1.012482] NET: Registered protocol family 24
[ 1.012525] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.012537] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.012555] Rockchip WiFi SYS interface (V1.00) …
[ 1.012639] usbcore: registered new interface driver catc
[ 1.012685] usbcore: registered new interface driver kaweth
[ 1.012702] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.012740] usbcore: registered new interface driver pegasus
[ 1.012783] usbcore: registered new interface driver rtl8150
[ 1.012826] usbcore: registered new interface driver r8152
[ 1.012841] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.012902] usbcore: registered new interface driver hso
[ 1.012952] usbcore: registered new interface driver asix
[ 1.012995] usbcore: registered new interface driver ax88179_178a
[ 1.013038] usbcore: registered new interface driver cdc_ether
[ 1.013081] usbcore: registered new interface driver cdc_eem
[ 1.013131] usbcore: registered new interface driver dm9601
[ 1.013186] usbcore: registered new interface driver smsc75xx
[ 1.013238] usbcore: registered new interface driver smsc95xx
[ 1.013281] usbcore: registered new interface driver gl620a
[ 1.013323] usbcore: registered new interface driver net1080
[ 1.013369] usbcore: registered new interface driver plusb
[ 1.013412] usbcore: registered new interface driver rndis_host
[ 1.013456] usbcore: registered new interface driver cdc_subset
[ 1.013499] usbcore: registered new interface driver zaurus
[ 1.013543] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.013602] usbcore: registered new interface driver int51x1
[ 1.013648] usbcore: registered new interface driver kalmia
[ 1.013691] usbcore: registered new interface driver ipheth
[ 1.013738] usbcore: registered new interface driver sierra_net
[ 1.013781] usbcore: registered new interface driver cx82310_eth
[ 1.013834] usbcore: registered new interface driver cdc_ncm
[ 1.013881] usbcore: registered new interface driver qmi_wwan
[ 1.013924] usbcore: registered new interface driver cdc_mbim
[ 1.015131] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.020498] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.021125] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.021144] ehci-pci: EHCI PCI platform driver
[ 1.021203] ehci-platform: EHCI generic platform driver
[ 1.025060] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.025089] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.025237] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.035078] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.035212] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.035228] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.035241] usb usb1: Product: EHCI Host Controller
[ 1.035253] usb usb1: Manufacturer: Linux 4.4.103 ehci_hcd
[ 1.035264] usb usb1: SerialNumber: fe3c0000.usb
[ 1.035816] hub 1-0:1.0: USB hub found
[ 1.035849] hub 1-0:1.0: 1 port detected
[ 1.036353] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.036388] ohci-platform: OHCI generic platform driver
[ 1.036840] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.036866] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.036983] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.092522] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.092550] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.092565] usb usb2: Product: Generic Platform OHCI controller
[ 1.092577] usb usb2: Manufacturer: Linux 4.4.103 ohci_hcd
[ 1.092589] usb usb2: SerialNumber: fe3e0000.usb
[ 1.093208] hub 2-0:1.0: USB hub found
[ 1.093262] hub 2-0:1.0: 1 port detected
[ 1.094797] usbcore: registered new interface driver cdc_acm
[ 1.094814] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.094896] usbcore: registered new interface driver usblp
[ 1.094959] usbcore: registered new interface driver cdc_wdm
[ 1.095069] usbcore: registered new interface driver uas
[ 1.095179] usbcore: registered new interface driver usb-storage
[ 1.095236] usbcore: registered new interface driver ums-alauda
[ 1.095296] usbcore: registered new interface driver ums-cypress
[ 1.095353] usbcore: registered new interface driver ums-datafab
[ 1.095408] usbcore: registered new interface driver ums_eneub6250
[ 1.095464] usbcore: registered new interface driver ums-freecom
[ 1.095519] usbcore: registered new interface driver ums-isd200
[ 1.095574] usbcore: registered new interface driver ums-jumpshot
[ 1.095634] usbcore: registered new interface driver ums-karma
[ 1.095689] usbcore: registered new interface driver ums-onetouch
[ 1.095749] usbcore: registered new interface driver ums-sddr09
[ 1.095804] usbcore: registered new interface driver ums-sddr55
[ 1.095859] usbcore: registered new interface driver ums-usbat
[ 1.095971] usbcore: registered new interface driver usbserial
[ 1.096020] usbcore: registered new interface driver usbserial_generic
[ 1.096060] usbserial: USB Serial support registered for generic
[ 1.096118] usbcore: registered new interface driver ch341
[ 1.096159] usbserial: USB Serial support registered for ch341-uart
[ 1.096218] usbcore: registered new interface driver cp210x
[ 1.096255] usbserial: USB Serial support registered for cp210x
[ 1.096327] usbcore: registered new interface driver option
[ 1.096365] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.096529] usbcore: registered new interface driver pl2303
[ 1.096567] usbserial: USB Serial support registered for pl2303
[ 1.096641] usbcore: registered new interface driver trancevibrator
[ 1.096661] usb20_otg: version 3.10a 21-DEC-2012
[ 1.096950] usb20_host: version 3.10a 21-DEC-2012
[ 1.097539] usbcore: registered new interface driver xpad
[ 1.097609] usbcore: registered new interface driver usb_acecad
[ 1.097673] usbcore: registered new interface driver aiptek
[ 1.097736] usbcore: registered new interface driver gtco
[ 1.097799] usbcore: registered new interface driver hanwang
[ 1.097860] usbcore: registered new interface driver kbtab
[ 1.097878] ==gsl_ts_init==
[ 1.097918] ret=0
[ 1.098512] .. rk pwm remotectl v1.1 init
[ 1.098830] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.099216] remotectl-pwm ff420030.pwm: set irq err, set support_psci to 0 !!
[ 1.099429] sensor_register_slave:mma8452,id=17
[ 1.099449] sensor_register_slave:lis3dh,id=7
[ 1.099467] sensor_register_slave:mma7660,id=18
[ 1.099486] sensor_register_slave:lsm303d,id=22
[ 1.099504] sensor_register_slave:mpu6880_acc,id=24
[ 1.099523] sensor_register_slave:mpu6500_acc,id=25
[ 1.099542] sensor_register_slave:lsm330_acc,id=26
[ 1.099560] sensor_register_slave:akm8975,id=29
[ 1.099579] sensor_register_slave:akm8963,id=30
[ 1.099597] sensor_register_slave:l3g4200d,id=44
[ 1.099614] sensor_register_slave:l3g20d,id=45
[ 1.099632] sensor_register_slave:ewtsa,id=46
[ 1.099650] sensor_register_slave:lsm330_gyro,id=50
[ 1.099667] sensor_register_slave:cm3217,id=52
[ 1.099685] sensor_register_slave:cm3218,id=53
[ 1.100553] i2c /dev entries driver
[ 1.101995] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.102123] fan53555-reg: supplied by vcc5v0_sys
[ 1.104016] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.104086] fan53555-reg: supplied by vcc5v0_sys
[ 1.106164] rk808 0-001b: Pmic Chip id: 0x0
[ 1.109691] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.109768] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.109891] DCDC_REG1: supplied by vcc3v3_sys
[ 1.110669] DCDC_REG2: supplied by vcc3v3_sys
[ 1.111239] DCDC_REG3: supplied by vcc3v3_sys
[ 1.111537] DCDC_REG4: supplied by vcc3v3_sys
[ 1.111989] LDO_REG1: supplied by vcc3v3_sys
[ 1.113119] LDO_REG2: supplied by vcc3v3_sys
[ 1.114090] LDO_REG3: supplied by vcc3v3_sys
[ 1.115126] LDO_REG4: supplied by vcc3v3_sys
[ 1.116096] LDO_REG5: supplied by vcc3v3_sys
[ 1.117117] LDO_REG6: supplied by vcc3v3_sys
[ 1.118182] LDO_REG7: supplied by vcc3v3_sys
[ 1.119219] LDO_REG8: supplied by vcc3v3_sys
[ 1.120248] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.120564] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.124648] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.125322] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80096b4000
[ 1.126097] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80096b6000
[ 1.126220] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 1.126238] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 1.126254] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 1.126269] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 1.126683] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80096b8000
[ 1.353731] fusb302 4-0022: port 0 probe success
[ 1.353775] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80096ba000
[ 1.354483] IR NEC protocol handler initialized
[ 1.354500] IR RC5(x/sz) protocol handler initialized
[ 1.354515] IR RC6 protocol handler initialized
[ 1.354528] IR JVC protocol handler initialized
[ 1.354542] IR Sony protocol handler initialized
[ 1.354555] IR SANYO protocol handler initialized
[ 1.354569] IR Sharp protocol handler initialized
[ 1.354583] IR MCE Keyboard/mouse protocol handler initialized
[ 1.354597] IR XMP protocol handler initialized
[ 1.354778] usbcore: registered new interface driver uvcvideo
[ 1.354788] USB Video Class driver (1.1.1)
[ 1.354806] CamSys driver version: v0.34.8, CamSys head file version: v0.13.0
[ 1.359081] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.359210] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.359442] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.359554] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 1.361894] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.362649] device-mapper: uevent: version 1.0.3
[ 1.362948] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.363092] Bluetooth: HCI UART driver ver 2.3
[ 1.363105] Bluetooth: HCI UART protocol H4 registered
[ 1.363116] Bluetooth: HCI UART protocol LL registered
[ 1.363132] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.363143] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 1.363153] rtk_btusb: Register usb char device interface for BT driver
[ 1.363373] usbcore: registered new interface driver rtk_btusb
[ 1.363749] cpu cpu0: leakage=25
[ 1.383893] cpu cpu0: temp=46875, pvtm=146834 (146504 + 330)
[ 1.384438] cpu cpu0: pvtm-sel=1
[ 1.384938] cpu cpu4: leakage=48
[ 1.397218] cpu cpu4: temp=46875, pvtm=152769 (152594 + 175)
[ 1.397387] cpu cpu4: pvtm-sel=1
[ 1.402922] sdhci: Secure Digital Host Controller Interface driver
[ 1.402994] sdhci: Copyright(c) Pierre Ossman
[ 1.403014] Synopsys Designware Multimedia Card Interface Driver
[ 1.404268] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.404421] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.404441] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.404501] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.404539] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.404591] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.404603] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.405709] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.405828] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.405849] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.405912] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.405938] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.406050] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.406402] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.406715] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.418535] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.432867] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.433376] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.435407] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.435478] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.465146] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.469002] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.473685] usbcore: registered new interface driver usbhid
[ 1.473710] usbhid: USB HID core driver
[ 1.473883] inv_mpu_iio: inv_mpu_init:746
[ 1.475551] ashmem: initialized
[ 1.478128] ff100000.saradc supply vref not found, using dummy regulator
[ 1.480179] rknandbase v1.1 2016-11-08
[ 1.481074] usbcore: registered new interface driver snd-usb-audio
[ 1.482940] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 1.507228] mmc1: MAN_BKOPS_EN bit is not set
[ 1.520991] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.522226] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 1.522869] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 1.523831] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 1.524721] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 1.525535] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.525558] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 1.525570] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 1.525582] resource: 0x001000000 – 0x002000000 (16 MB)
[ 1.525594] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 1.525606] boot: 0x003800000 – 0x005800000 (32 MB)
[ 1.525618] recovery: 0x005800000 – 0x007800000 (32 MB)
[ 1.525629] backup: 0x007800000 – 0x00e800000 (112 MB)
[ 1.525641] cache: 0x00e800000 – 0x016800000 (128 MB)
[ 1.525654] system: 0x016800000 – 0x076800000 (1536 MB)
[ 1.525666] metadata: 0x076800000 – 0x077800000 (16 MB)
[ 1.525679] baseparamer: 0x077800000 – 0x077c00000 (4 MB)
[ 1.525691] userdata: 0x077c00000 – 0x3a3a00000 (12990 MB)
[ 1.525762] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
[ 1.568470] usb 2-1: new low-speed USB device number 2 using ohci-platform
[ 1.660636] u32 classifier
[ 1.660726] Actions configured
[ 1.660801] Netfilter messages via NETLINK v0.30.
[ 1.660906] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.661554] ctnetlink v0.93: registering with nfnetlink.
[ 1.663383] xt_time: kernel timezone is -0000
[ 1.664581] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.664830] arp_tables: (C) 2002 David S. Miller
[ 1.665747] Initializing XFRM netlink socket
[ 1.666334] NET: Registered protocol family 10
[ 1.669595] mip6: Mobile IPv6
[ 1.669646] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.671340] sit: IPv6 over IPv4 tunneling driver
[ 1.672002] NET: Registered protocol family 17
[ 1.672083] NET: Registered protocol family 15
[ 1.672133] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.673461] Bridge firewalling registered
[ 1.673481] Ebtables v2.0 registered
[ 1.676171] Bluetooth: RFCOMM TTY layer initialized
[ 1.676199] Bluetooth: RFCOMM socket layer initialized
[ 1.676239] Bluetooth: RFCOMM ver 1.11
[ 1.676267] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.676278] Bluetooth: BNEP filters: protocol multicast
[ 1.676294] Bluetooth: BNEP socket layer initialized
[ 1.676309] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.676324] Bluetooth: HIDP socket layer initialized
[ 1.676384] l2tp_core: L2TP core driver, V2.0
[ 1.676407] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.676431] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.676928] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.677016] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 1.677027] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.677038] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.677139] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 1003, flags = 0.
[ 1.677150] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.677164] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.677241] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.677791] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 1083.
[ 1.677846] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 1009.
[ 1.677886] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 1090.
[ 1.677927] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 1004.
[ 1.688562] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.688625] [BT_RFKILL]: ** disable irq
[ 1.688822] [BT_RFKILL]: bt_default device registered.
[ 1.689163] sensor_register_slave:mpu6880_gyro,id=49
[ 1.691069] Registered cp15_barrier emulation handler
[ 1.691158] Registered setend emulation handler
[ 1.692258] registered taskstats version 1
[ 1.692500] vendor storage:20160801 ret = 0
[ 1.693505] rockchip ion idev is NULL
[ 1.693525] rga2 ff680000.rga: rga ion client create success!
[ 1.694005] rga: Driver loaded successfully ver:3.02
[ 1.695651] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 1.698309] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 1.698641] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 1.699451] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.699513] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.699605] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.701136] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 1.702052] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 1.702110] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 1.702127] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.702138] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 1.758758] usb 2-1: New USB device found, idVendor=413c, idProduct=2111
[ 1.758784] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.758796] usb 2-1: Product: Dell USB Wired Entry Keyboard
[ 1.758806] usb 2-1: Manufacturer: DELL
[ 1.767039] input: DELL Dell USB Wired Entry Keyboard as /devices/platform/fe3e0000.usb/usb2/2-1/2-1:1.0/0003:413C:2111.0001/input/input1
[ 1.820150] hid-generic 0003:413C:2111.0001: input,hidraw0: USB HID v1.10 Keyboard [DELL Dell USB Wired Entry Keyboard] on usb-fe3e0000.usb-1/input0
[ 1.830199] input: DELL Dell USB Wired Entry Keyboard as /devices/platform/fe3e0000.usb/usb2/2-1/2-1:1.1/0003:413C:2111.0002/input/input2
[ 1.882633] hid-generic 0003:413C:2111.0002: input,hidraw1: USB HID v1.10 Device [DELL Dell USB Wired Entry Keyboard] on usb-fe3e0000.usb-1/input1
[ 2.203685] rockchip-drm display-subsystem: fb0: frame buffer device
[ 2.217614] mali ff9a0000.gpu: leakage=31
[ 2.230300] mali ff9a0000.gpu: temp=46250, pvtm=124361 (124301 + 60)
[ 2.231717] mali ff9a0000.gpu: pvtm-sel=1
[ 2.233357] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 2.234348] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.235248] mali ff9a0000.gpu: Probed as mali0
[ 2.243555] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.243656] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 3
[ 2.244013] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 2.244106] xhci-hcd xhci-hcd.10.auto: irq 233, io mem 0xfe800000
[ 2.244358] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.244390] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.244418] usb usb3: Product: xHCI Host Controller
[ 2.244441] usb usb3: Manufacturer: Linux 4.4.103 xhci-hcd
[ 2.244465] usb usb3: SerialNumber: xhci-hcd.10.auto
[ 2.245454] hub 3-0:1.0: USB hub found
[ 2.245522] hub 3-0:1.0: 1 port detected
[ 2.246022] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.246061] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4
[ 2.246188] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.246376] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.246406] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.246432] usb usb4: Product: xHCI Host Controller
[ 2.246455] usb usb4: Manufacturer: Linux 4.4.103 xhci-hcd
[ 2.246478] usb usb4: SerialNumber: xhci-hcd.10.auto
[ 2.247320] hub 4-0:1.0: USB hub found
[ 2.247383] hub 4-0:1.0: 1 port detected
[ 2.249815] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.249865] usb usb4: USB disconnect, device number 1
[ 2.278768] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[ 2.278851] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[ 2.279143] xhci-hcd xhci-hcd.10.auto: USB bus 4 deregistered
[ 2.279168] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.279197] usb usb3: USB disconnect, device number 1
[ 2.279792] xhci-hcd xhci-hcd.10.auto: USB bus 3 deregistered
[ 2.286081] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.286144] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[ 2.286415] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 2.286476] xhci-hcd xhci-hcd.11.auto: irq 234, io mem 0xfe900000
[ 2.286640] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.286653] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.286664] usb usb3: Product: xHCI Host Controller
[ 2.286675] usb usb3: Manufacturer: Linux 4.4.103 xhci-hcd
[ 2.286685] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 2.287319] hub 3-0:1.0: USB hub found
[ 2.287355] hub 3-0:1.0: 1 port detected
[ 2.287644] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.287663] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 2.287745] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.287854] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.287867] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.287878] usb usb4: Product: xHCI Host Controller
[ 2.287888] usb usb4: Manufacturer: Linux 4.4.103 xhci-hcd
[ 2.287899] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 2.288478] hub 4-0:1.0: USB hub found
[ 2.288515] hub 4-0:1.0: 1 port detected
[ 2.294196] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.294260] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 2.294639] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 2.302015] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.302461] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.302494] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.302520] usb usb5: Product: EHCI Host Controller
[ 2.302544] usb usb5: Manufacturer: Linux 4.4.103 ehci_hcd
[ 2.302568] usb usb5: SerialNumber: fe380000.usb
[ 2.303856] hub 5-0:1.0: USB hub found
[ 2.303990] hub 5-0:1.0: 1 port detected
[ 2.305795] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.305854] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 2.306171] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 2.363070] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.363172] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.363199] usb usb6: Product: Generic Platform OHCI controller
[ 2.363224] usb usb6: Manufacturer: Linux 4.4.103 ohci_hcd
[ 2.363248] usb usb6: SerialNumber: fe3a0000.usb
[ 2.364782] hub 6-0:1.0: USB hub found
[ 2.364869] hub 6-0:1.0: 1 port detected
[ 2.367707] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.367956] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.367993] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.368059] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.368108] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.368197] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.368221] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.368962] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.382052] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.395571] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.396562] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 2.440756] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.442504] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.444213] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.447429] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.505982] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
[ 2.548004] asoc-simple-card spdif-sound: dit-hifi ↔ ff870000.spdif mapping ok
[ 2.550999] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[ 2.551057] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to add ELD: -16
[ 2.551991] rk-hdmi-dp-sound hdmi-dp-sound: multicodec ↔ ff8a0000.i2s mapping ok
[ 2.552087] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to create Playback debugfs file
[ 2.553490] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 2.591982] usb 3-1: new low-speed USB device number 2 using xhci-hcd
[ 2.699829] otg_wakelock_init: No USB transceiver found
[ 2.701153] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 12:53:31 UTC (1358513611)
[ 2.703650] It doesn’t contain Rogue gpu
[ 2.716373] usb 3-1: New USB device found, idVendor=04ca, idProduct=0061
[ 2.716435] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.716471] usb 3-1: Product: USB Optical Mouse
[ 2.716503] usb 3-1: Manufacturer: PixArt
[ 2.717400] usb 3-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 2.724476] input: PixArt USB Optical Mouse as /devices/platform/usb@fe900000/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/3-1:1.0/0003:04CA:0061.0003/input/input3
u 2.737493]
[ 2.775639] hid-generic 0003:04CA:0061.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-xhci-hcd.11.auto-1/input0
[ 2.777557] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 2.808918] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 82
[ 2.811513] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.811572] mmc2: new ultra high speed SDR104 SDIO card at address 0001
请问Firefly的系统固件里是否有对硬件进行检测的地方?
