自己写了个pwm蜂鸣器驱动,直接执行应用程序是正常的,但是在HAL层调用时候,发现能够正常open,ioctl控制的时候,就出现not a typewriter,这个现象大家有遇到过吗?这是我的代码
static int pwmbeep_set_val(struct pwmbeep_device_t* dev, int val)
ALOGI("PWMbeep Stub: set value %d to device.", val);
ALOGI("PWMbeep Stub: dev fd = %d.", fd);
int ret;
HANDLE fd;
fd = open("/dev/pwm_buzzer",O_RDWR);
if(fd <0)
ALOGE("Pwmbeep fd open failed. fd = %s",strerror(errno));
if(val)
ret = ioctl(fd,PWMBEEP_ON,0);
if(ret)
ALOGE("Pwmbeep ioctl open failed. ret = %s",strerror(errno));
return 0;
