内核信息没有打印
U-Boot 2017.02-RK3288-06-gf0c33010c6 (Sep 10 2018 - 15:18:25)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 816000000HZ
periph pll = 297000000HZ
ddr pll = 396000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
Adding bank:0000000000000000(0000000100000000)
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
ERROR: v7_dcache_inval_range - start address is not aligned - 0x059bc50c
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x059bc70c
ERROR: v7_dcache_inval_range - start address is not aligned - 0x059cc30c
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x059cc50c
storage init OK!
GetParam
Load FDT from resource image.
no key node
No pmic detect.
can’t find dts node for pwm0
#Boot ver: 2018-09-10#2.30
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x007b9178)
ramdisk @ 0x05bf0000 (0x00299c84)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 05610268 … OK
Add bank:0000000000000000, 00000000fe000000
然后就启动文件系统了,求解答
