rk3399开启wifi热点的信道是随机的?不是应该选择一个用的最少的信道吗?
package com.android.server.wifi.util;
import android.net.wifi.WifiConfiguration;
import android.net.wifi.WifiScanner;
import android.util.Log;
import com.android.server.wifi.WifiNative;
import java.util.ArrayList;
import java.util.Random;
  • Provide utility functions for updating soft AP related configuration.
    public class ApConfigUtil {
    private static final String TAG = “ApConfigUtil”;
    public static final int DEFAULT_AP_BAND = WifiConfiguration.AP_BAND_2GHZ;
    public static final int DEFAULT_AP_CHANNEL = 6;
    /* Return code for updateConfiguration. */
    public static final int SUCCESS = 0;
    public static final int ERROR_NO_CHANNEL = 1;
    public static final int ERROR_GENERIC = 2;
    /* Random number generator used for AP channel selection. */
    private static final Random sRandom = new Random();
    • Convert frequency to channel.
    • @param frequency frequency to convert
    • @return channel number associated with given frequency, -1 if no match
      public static int convertFrequencyToChannel(int frequency) {
      if (frequency >= 2412 && frequency <= 2472) {
      return (frequency - 2412) / 5 + 1;
      } else if (frequency == 2484) {
      return 14;
      } else if (frequency >= 5170 && frequency <= 5825) {
      DFS is included. */
      return (frequency - 5170) / 5 + 34;
      return -1;
    • Return a channel number for AP setup based on the frequency band.
    • @param apBand 0 for 2GHz, 1 for 5GHz
    • @param allowed2GChannels list of allowed 2GHz channels
    • @param allowed5GFreqList list of allowed 5GHz frequencies
    • @return a valid channel number on success, -1 on failure.
      public static int chooseApChannel(int apBand,
      ArrayList allowed2GChannels,
      int allowed5GFreqList) {
      if (apBand != WifiConfiguration.AP_BAND_2GHZ
      && apBand != WifiConfiguration.AP_BAND_5GHZ) {
      Log.e(TAG, "Invalid band: " + apBand);
      return -1;
      if (apBand == WifiConfiguration.AP_BAND_2GHZ) {
      /* Select a channel from 2GHz band. /
      if (allowed2GChannels == null || allowed2GChannels.size() == 0) {
      Log.d(TAG, “2GHz allowed channel list not specified”);
      Use default channel. */
      return DEFAULT_AP_CHANNEL;
       /* Pick a random channel. */
       int index = sRandom.nextInt(allowed2GChannels.size());
       return allowed2GChannels.get(index).intValue();
      /* 5G without DFS. /
      if (allowed5GFreqList != null && allowed5GFreqList.length > 0) {
      Pick a random channel from the list of supported channels. */
      return convertFrequencyToChannel(
      allowed5GFreqList[sRandom.nextInt(allowed5GFreqList.length)]);
      Log.e(TAG, “No available channels on 5GHz band”);
      return -1;
    • Update AP band and channel based on the provided country code and band.
    • This will also set
    • @param wifiNative reference to WifiNative
    • @param countryCode country code
    • @param config configuration to update
    • @return an integer result code
      public static int updateApChannelConfig(WifiNative wifiNative,
      String countryCode,
      WifiConfiguration config) {
      Use default band and channel for device without HAL. */
      if (!wifiNative.isHalStarted()) {
      config.apBand = DEFAULT_AP_BAND;
      config.apChannel = DEFAULT_AP_CHANNEL;
      return SUCCESS;
      /* Country code is mandatory for 5GHz band. */
      if (config.apBand == WifiConfiguration.AP_BAND_5GHZ
      && countryCode == null) {
      Log.e(TAG, “5GHz band is not allowed without country code, use channel:153 for 5GHz AP”);
