大家好!
我按照 wik i教程http://wiki.t-firefly.com/zh_CN/Firefly-RK3399/linux_compile_gpt.html
自己编译了一个内核 boot.img, 内核烧写到开发板后无法正常启动,提示
[ 2.393802] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.394508] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.395223] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.395815] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.396768] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.397668] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.398259] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.399653] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.410862] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.422996] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.424672] rockchip-dmc dmc: Failed to get leakage
[ 2.425275] rockchip-dmc dmc: Failed to get pvtm
[ 2.427019] rockchip-dmc dmc: could not find power_model node
有人知道是为什么吗?
