rk3399默认串口波特率为1500000,我参考了本站上的修改帖子,修改了uboot里的rk3399_defconfig文件,以及dts上的文件,波特率也的确变为了115200,但是在一级引导那一处波特率还是1500000,就是开机打印的第一段字符串如果设置115200波特率,还是乱码,请问这块区域的波特率该如何修改?
打印信息如下:
▒▒▒u▒▒z▒▒▒y▒:▒▒▒▒▒▒<▒▒▒▒▒O▒Ɉ▒▒ҽd$▒▒▒{▒▒▒▒▒▒▒▒//o<=▒^/O/▒▒▒<ޞ▒/▒<Ok▒▒&a▒▒▒Kk▒<ŋ▒▒▒▒^▒<▒
U-Boot 2014.10-RK3399-06 (Jan 03 2019 - 23:47:42)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2019-01-03#1.09
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
failed to find phy node
failed to find panel driver
no fuel gauge found
can’t find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
[EDID-EXTEND] It is a CEA 861 Series Extension.
no baseparametr,find best edid mode,vic=16
hdmi_dev->video.vic is 4
rk lcdc - 0 dclk set: dclk = 74250000HZ, pll select = 0, div = 1
rockchip_panel_prepare: failed to find panel prepare funcs
hdmi_dev_config_video vic 4 color_output 3 color_output_depth 8
pixel clk is 74250000 tmds clk is 74250000
hsync_pol 1 vsync_pol 1
[HDMI] sucess output HDMI.
PHY PLL not locked: PCLK_ON=1,TMDSCLK_ON=0
rockchip_panel_enable: failed to find panel prepare funcs
failed to display kernel logo
checkKey
vbus = 1
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel @ 0x00280000 (0x01227808)
ramdisk @ 0x04bf0000 (0x001ad958)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 00000000046164e4 … OK
Add bank:000000000a200000, 0000000075e00000
就是开头那一段打印信息,还是乱码
一级引导rk3399_loader_v1.09.109.bin,该文件是哪里编译出来的
这个源码原厂没有开放
请问您修改这个波特率在哪里修改的?按照论坛上说的修改,内核引导一半之后又变回1500000了
估计你设备树里没有改:
fiq_debugger: fiq-debugger {
compatible = “rockchip,fiq-debugger”;
rockchip,serial-id = <2>;
rockchip,wake-irq = <0>;
rockchip,irq-mode-enable = <0>; /* If enable uart uses irq instead of fiq /
rockchip,baudrate = <1500000>; / Only 115200 and 1500000 */
pinctrl-names = “default”;
pinctrl-0 = <&uart2c_xfer>;
interrupts = <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH 0>;
风在摇曳风铃 发表于 2019-8-8 09:34
估计你设备树里没有改:
compatible = “rockchip,fiq-debugger” …
已经改了,是使用buid.sh工具制作update.img时没更新kernel的问题
哥们 请明示!
我也遇见了kenerl启动过程中变成1500000的情况
同问!!!!
就前面一段无所谓吧
12.1 DDR Loader修改方法
DDR Loader中关闭或切换打印,需要修改DDR Loader中的UART打印配置,修改文件
rkbin/tools/ddrbin_param.txt中的以下参数:
详细使用说明请参考文档:ddrbin_tool_user_guide.txt。修改完成后,使用以下命令重新生成ddr.bin固
件。具体ddr.bin固件名请替换为实际SDK中使用的ddr.bin固件名。
uart id= # UART控制器id,配置为0xf为关闭打印
uart iomux= # 复用的IOMUX引脚
uart baudrate= # 115200 or 1500000
./ddrbin_tool ddrbin_param.txt path/to/ddr.bin
