开发板启动时显示 :
[ OK ] Started Remount Root and Kernel File Systems.
[ 3.557117] systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
[ 3.558616] systemd[1]: Failed to start Load Kernel Modules.
[FAILED] Failed to start Load Kernel Modules.
See ‘systemctl status systemd-modules-load.service’ for details.
[ 3.559717] systemd[1]: systemd-modules-load.service: Unit entered failed state.
[ 3.560816] systemd[1]: systemd-modules-load.service: Failed with result ‘exit-code’.
我想请教各位大哥的是:【Failed to start Load Kernel Modules】意思是说Kernel加载失败吗,那么我在kernel下加入的一些代码是不是都不能启用?比如LED灯的控制代码。
下面是执行systemctl restart systemd-modules-load.service的截图:
root@firefly:~# systemctl restart systemd-modules-load.service
Job for systemd-modules-load.service failed because the control process exited with error code. See “systemctl status systemd-modules-load.service” and “journalctl -xe” for details.
root@firefly:~# systemctl status systemd-modules-load.service
鈼[0m systemd-modules-load.service - Load Kernel Modules
Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static; ven
dor preset: enabled)
Active: failed (Result: exit-code) since Thu 2016-02-11 20:56:29 U
TC; 6s ago
Docs: man:systemd-modules-load.service(8)
man:modules-load.d(5)
Process: 3219 ExecStart=/lib/systemd/systemd-modules-load (code=exited
, status=1/FAILURE)
Main PID: 3219 (code=exited, status=1/FAILURE)
Feb 11 20:56:29 firefly systemd[1]: Starting Load Kernel Modules…
Feb 11 20:56:29 firefly systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Feb 11 20:56:29 firefly systemd[1]: Failed to start Load Kernel Modules.
Feb 11 20:56:29 firefly systemd[1]: systemd-modules-load.service: Unit entered failed state.
Feb 11 20:56:29 firefly systemd[1]: systemd-modules-load.service: Failed with result ‘exit-code’.
