开机卡死在Firefly界面
烧录了两个版本的固件:android和LINUX的,都是开机究卡死在Firefly界面,之后就一直没动静了。串口打印了LINUX版本下的完整信息,到EMMC那块接没有后文了。
DDR Version 1.07 20161103
Channel 0: DDR3, 666MHz
Channel 1: DDR3, 666MHz
256B stride
Boot1: 2016-07-29, version: 1.05
CPUId = 0x0
ChipType = 10 1846
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 63565
LoadTrustBL
No find bl30.bin
No find bl32.bin
theLoader 200000 78851
LoaderFlag2: 0x0
NOTICE: BL31: v1.2(debug):e1a1ee4
NOTICE: BL31: Built : 14:38:26, Sep 29 2016
INFO: plat_rockchip_pmu_init(1202): pd status 3e
INFO: SPSR = 0x3c9
U-Boot 2017.02-RK3399-06-ga7c7ca8 (Mar 28 2017 - 11:12:22)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
aclk_periph_h = 148500000HZ, hclk_periph_h = 74250000HZ, pclk_periph_h = 37125000HZ
aclk_periph_l0 = 99000000HZ, hclk_periph_l0 = 99000000HZ, pclk_periph_l0 = 49500000HZ
hclk_periph_l1 = 99000000HZ, pclk_periph_l1 = 49500000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
no key node
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=33
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2017-03-28#1.05
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
misc partition not found!
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x01100808)
ramdisk @ 0x05bf0000 (0x00000000)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 0000000005614737 … OK
Add bank:0000000000200000, 000000007fe00000
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.77 (yjkjui@yjkjui-Name) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #58 SMP Fri Dec 14 10:40:51 CST 2018 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fefb000 s46336 r8192 d31488 u86016 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 515592 [ 0.000000] Kernel command line: console=ttyFIQ0 root=/dev/mmcblk1p6 rw rootwait mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00008000@0x00006000(resource),0x0000A000@0x0000E000(kernel),0x00002000@0x00018000(backup),-@0x0001A000(boot) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2017-03-28_11:12:22 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.000000] software IO TLB [mem 0x79a00000-0x7da00000] (64MB) mapped at [ffffffc079a00000-ffffffc07d9fffff] [ 0.000000] Memory: 1973964K/2095104K available (10942K kernel code, 1474K rwdata, 3808K rodata, 1152K init, 763K bss, 121140K reserved, 0K cma-reserved) [ 0.000000] Virtual kernel memory layout: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB) [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB) [ 0.000000] .init : 0xffffff8008ef0000 - 0xffffff8009010000 ( 1152 KB) [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b30000 ( 10944 KB) [ 0.000000] .rodata : 0xffffff8008b30000 - 0xffffff8008ef0000 ( 3840 KB) [ 0.000000] .data : 0xffffff8009010000 - 0xffffff8009180808 ( 1475 KB) [ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum) [ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc2000000 ( 31 MB actual) [ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB) [ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB) [ 0.000000] memory : 0xffffffc000200000 - 0xffffffc080000000 ( 2046 MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 64. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6 [ 0.000000] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000 [ 0.000000] ITS: allocated 65536 Devices @79480000 (psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GIC: using LPI property table @0x0000000079410000 [ 0.000000] ITS: Allocated 1792 chunks for LPIs [ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000 [ 0.000000] CPU0: using LPI pending table @0x0000000079420000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001223] Console: colour dummy device 80x25 [ 0.001250] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000) [ 0.001264] pid_max: default: 32768 minimum: 301 [ 0.001362] Security Framework initialized [ 0.001373] Yama: becoming mindful. [ 0.001456] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.001469] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.002237] Initializing cgroup subsys devices [ 0.002257] Initializing cgroup subsys freezer [ 0.002285] ftrace: allocating 40296 entries in 158 pages [ 0.111517] sched-energy: Sched-energy-costs installed from DT [ 0.111536] CPU0: update cpu_capacity 401 [ 0.111598] ASID allocator initialised with 65536 entries [ 0.111640] funs:create_kthread,create_kthread is run.....pid_num=1 [ 0.111806] funs:create_kthread,create_kthread is run.....pid_num=2 [ 0.111891] funs:create_kthread,create_kthread is run.....pid_num=3 [ 0.112029] funs:create_kthread,create_kthread is run.....pid_num=4 [ 0.112160] funs:create_kthread,create_kthread is run.....pid_num=5 [ 0.112230] funs:create_kthread,create_kthread is run.....pid_num=6 [ 0.112307] funs:create_kthread,create_kthread is run.....pid_num=7 [ 0.114764] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.115239] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.115669] funs:create_kthread,create_kthread is run.....pid_num=8 [ 0.115982] funs:create_kthread,create_kthread is run.....pid_num=9 [ 0.116108] funs:create_kthread,create_kthread is run.....pid_num=10 [ 0.116183] funs:create_kthread,create_kthread is run.....pid_num=11 [ 0.116282] funs:create_kthread,create_kthread is run.....pid_num=12 [ 0.116367] funs:create_kthread,create_kthread is run.....pid_num=13 [ 0.116580] Detected VIPT I-cache on CPU1 [ 0.116613] CPU1: found redistributor 1 region 0:0x00000000fef20000 [ 0.116648] CPU1: using LPI pending table @0x0000000079690000 [ 0.116695] CPU1: update cpu_capacity 401 [ 0.116699] CPU1: Booted secondary processor [410fd034] [ 0.116810] funs:create_kthread,create_kthread is run.....pid_num=14 [ 0.116904] funs:create_kthread,create_kthread is run.....pid_num=15 [ 0.116977] funs:create_kthread,create_kthread is run.....pid_num=16 [ 0.117068] funs:create_kthread,create_kthread is run.....pid_num=17 [ 0.117151] funs:create_kthread,create_kthread is run.....pid_num=18 [ 0.117300] Detected VIPT I-cache on CPU2 [ 0.117321] CPU2: found redistributor 2 region 0:0x00000000fef40000 [ 0.117355] CPU2: using LPI pending table @0x00000000796c0000 [ 0.117382] CPU2: update cpu_capacity 401 [ 0.117386] CPU2: Booted secondary processor [410fd034] [ 0.117483] funs:create_kthread,create_kthread is run.....pid_num=19 [ 0.117570] funs:create_kthread,create_kthread is run.....pid_num=20 [ 0.117643] funs:create_kthread,create_kthread is run.....pid_num=21 [ 0.117733] funs:create_kthread,create_kthread is run.....pid_num=22 [ 0.117810] funs:create_kthread,create_kthread is run.....pid_num=23 [ 0.117968] Detected VIPT I-cache on CPU3 [ 0.117988] CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.118021] CPU3: using LPI pending table @0x0000000079700000 [ 0.118048] CPU3: update cpu_capacity 401 [ 0.118052] CPU3: Booted secondary processor [410fd034] [ 0.118134] funs:create_kthread,create_kthread is run.....pid_num=24 [ 0.118232] funs:create_kthread,create_kthread is run.....pid_num=25 [ 0.118305] funs:create_kthread,create_kthread is run.....pid_num=26 [ 0.118395] funs:create_kthread,create_kthread is run.....pid_num=27 [ 0.118472] funs:create_kthread,create_kthread is run.....pid_num=28 [ 0.118640] Detected PIPT I-cache on CPU4 [ 0.118667] CPU4: found redistributor 100 region 0:0x00000000fef80000 [ 0.118704] CPU4: using LPI pending table @0x0000000079740000 [ 0.118746] CPU4: update cpu_capacity 1024 [ 0.118750] CPU4: Booted secondary processor [410fd082] [ 0.118873] funs:create_kthread,create_kthread is run.....pid_num=29 [ 0.118963] funs:create_kthread,create_kthread is run.....pid_num=30 [ 0.119038] funs:create_kthread,create_kthread is run.....pid_num=31 [ 0.119136] funs:create_kthread,create_kthread is run.....pid_num=32 [ 0.119212] funs:create_kthread,create_kthread is run.....pid_num=33 [ 0.119355] Detected PIPT I-cache on CPU5 [ 0.119374] CPU5: found redistributor 101 region 0:0x00000000fefa0000 [ 0.119407] CPU5: using LPI pending table @0x0000000079770000 [ 0.119434] CPU5: update cpu_capacity 1024 [ 0.119437] CPU5: Booted secondary processor [410fd082] [ 0.119537] Brought up 6 CPUs [ 0.119561] SMP: Total of 6 processors activated. [ 0.119570] CPU features: detected feature: GIC system register CPU interface [ 0.119583] CPU: All CPU(s) started at EL2 [ 0.119629] alternatives: patching kernel code [ 0.120784] funs:create_kthread,create_kthread is run.....pid_num=34 [ 0.121098] devtmpfs: initialized [ 0.134155] funs:create_kthread,create_kthread is run.....pid_num=35 [ 0.134672] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [ 0.134698] futex hash table entries: 2048 (order: 5, 131072 bytes) [ 0.134969] funs:create_kthread,create_kthread is run.....pid_num=36 [ 0.135187] pinctrl core: initialized pinctrl subsystem [ 0.135956] NET: Registered protocol family 16 [ 0.139902] cpuidle: using governor ladder [ 0.143913] cpuidle: using governor menu [ 0.143934] Registered FIQ tty driver [ 0.144134] vdso: 2 pages (1 code @ ffffff8008b36000, 1 data @ ffffff8009014000) [ 0.144163] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.144324] DMA: preallocated 256 KiB pool for atomic allocations [ 0.247560] console [ttyFIQ0] enabled [ 0.248092] Registered fiq debugger ttyFIQ0 [ 0.260683] funs:create_kthread,create_kthread is run.....pid_num=37 [ 0.261354] funs:create_kthread,create_kthread is run.....pid_num=38 [ 0.262204] funs:create_kthread,create_kthread is run.....pid_num=39 [ 0.262910] funs:create_kthread,create_kthread is run.....pid_num=40 [ 0.263640] funs:create_kthread,create_kthread is run.....pid_num=41 [ 0.264906] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 0.267928] iommu: Adding device ff650000.vpu_service to group 0 [ 0.268527] iommu: Adding device ff660000.rkvdec to group 1 [ 0.269126] iommu: Adding device ff8f0000.vop to group 2 [ 0.269671] iommu: Adding device ff900000.vop to group 3 [ 0.270589] funs:create_kthread,create_kthread is run.....pid_num=42 [ 0.271404] SCSI subsystem initialized [ 0.271830] funs:create_kthread,create_kthread is run.....pid_num=43 [ 0.272671] usbcore: registered new interface driver usbfs [ 0.273206] usbcore: registered new interface driver hub [ 0.273759] usbcore: registered new device driver usb [ 0.274314] media: Linux media interface: v0.10 [ 0.274751] Linux video capture interface: v2.00 [ 0.275195] pps_core: LinuxPPS API ver. 1 registered [ 0.275644] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.276453] PTP clock support registered [ 0.276943] funs:create_kthread,create_kthread is run.....pid_num=44 [ 0.278745] Bluetooth: Core ver 2.21 [ 0.279103] NET: Registered protocol family 31 [ 0.279497] Bluetooth: HCI device and connection manager initialized [ 0.280060] Bluetooth: HCI socket layer initialized [ 0.280500] Bluetooth: L2CAP socket layer initialized [ 0.280969] Bluetooth: SCO socket layer initialized [ 0.281662] funs:create_kthread,create_kthread is run.....pid_num=45 [ 0.282568] rockchip-cpuinfo cpuinfo: Serial : ae2abd8457fcdf1d [ 0.283565] clocksource: Switched to clocksource arch_sys_counter [ 0.331884] thermal thermal_zone1: power_allocator: sustainable_power will be estimated [ 0.332643] funs:create_kthread,create_kthread is run.....pid_num=46 [ 0.333362] NET: Registered protocol family 2 [ 0.334073] funs:create_kthread,create_kthread is run.....pid_num=47 [ 0.334191] TCP established hash table entries: 16384 (order: 5, 131072 bytes) [ 0.334285] TCP bind hash table entries: 16384 (order: 7, 524288 bytes) [ 0.334591] TCP: Hash tables configured (established 16384 bind 16384) [ 0.334665] UDP hash table entries: 1024 (order: 4, 98304 bytes) [ 0.334727] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes) [ 0.334971] NET: Registered protocol family 1 [ 0.338025] funs:create_kthread,create_kthread is run.....pid_num=48 [ 0.338777] RPC: Registered named UNIX socket transport module. [ 0.339303] RPC: Registered udp transport module. [ 0.339739] RPC: Registered tcp transport module. [ 0.340156] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.341302] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.342133] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.343200] funs:create_kthread,create_kthread is run.....pid_num=49 [ 0.343885] funs:create_kthread,create_kthread is run.....pid_num=50 [ 0.344542] funs:create_kthread,create_kthread is run.....pid_num=51 [ 0.345231] funs:create_kthread,create_kthread is run.....pid_num=52 [ 0.345918] funs:create_kthread,create_kthread is run.....pid_num=53 [ 0.346632] funs:create_kthread,create_kthread is run.....pid_num=54 [ 0.347349] funs:create_kthread,create_kthread is run.....pid_num=55 [ 0.348074] funs:create_kthread,create_kthread is run.....pid_num=56 [ 0.348778] funs:create_kthread,create_kthread is run.....pid_num=57 [ 0.349464] funs:create_kthread,create_kthread is run.....pid_num=58 [ 0.350166] funs:create_kthread,create_kthread is run.....pid_num=59 [ 0.350882] funs:create_kthread,create_kthread is run.....pid_num=60 [ 0.351584] funs:create_kthread,create_kthread is run.....pid_num=61 [ 0.352274] funs:create_kthread,create_kthread is run.....pid_num=62 [ 0.354264] Initialise system trusted keyring [ 0.354729] funs:create_kthread,create_kthread is run.....pid_num=63 [ 0.355437] funs:create_kthread,create_kthread is run.....pid_num=64 [ 0.361649] funs:create_kthread,create_kthread is run.....pid_num=65 [ 0.362739] EXT4-fs: init fun is run [ 0.364480] funs:create_kthread,create_kthread is run.....pid_num=66 [ 0.365139] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.366895] funs:create_kthread,create_kthread is run.....pid_num=67 [ 0.367631] funs:create_kthread,create_kthread is run.....pid_num=68 [ 0.368548] NFS: Registering the id_resolver key type [ 0.369037] Key type id_resolver registered [ 0.369407] Key type id_legacy registered [ 0.369788] Installing knfsd (copyright (C) 1996 [email]okir@monad.swb.de[/email]). [ 0.371071] fuse init (API version 7.23) [ 0.371918] SGI XFS with security attributes, no debug enabled [ 0.373285] funs:create_kthread,create_kthread is run.....pid_num=69 [ 0.374029] funs:create_kthread,create_kthread is run.....pid_num=70 [ 0.375072] funs:create_kthread,create_kthread is run.....pid_num=71 [ 0.375760] funs:create_kthread,create_kthread is run.....pid_num=72 [ 0.376433] funs:create_kthread,create_kthread is run.....pid_num=73 [ 0.377113] funs:create_kthread,create_kthread is run.....pid_num=74 [ 0.377806] funs:create_kthread,create_kthread is run.....pid_num=75 [ 0.378481] funs:create_kthread,create_kthread is run.....pid_num=76 [ 0.379170] funs:create_kthread,create_kthread is run.....pid_num=77 [ 0.379852] funs:create_kthread,create_kthread is run.....pid_num=78 [ 0.380529] funs:create_kthread,create_kthread is run.....pid_num=79 [ 0.381215] funs:create_kthread,create_kthread is run.....pid_num=80 [ 0.381941] funs:create_kthread,create_kthread is run.....pid_num=81 [ 0.382629] funs:create_kthread,create_kthread is run.....pid_num=82 [ 0.383307] funs:create_kthread,create_kthread is run.....pid_num=83 [ 0.383999] funs:create_kthread,create_kthread is run.....pid_num=84 [ 0.384690] funs:create_kthread,create_kthread is run.....pid_num=85 [ 0.385357] funs:create_kthread,create_kthread is run.....pid_num=86 [ 0.386049] funs:create_kthread,create_kthread is run.....pid_num=87 [ 0.386742] funs:create_kthread,create_kthread is run.....pid_num=88 [ 0.387419] funs:create_kthread,create_kthread is run.....pid_num=89 [ 0.388107] funs:create_kthread,create_kthread is run.....pid_num=90 [ 0.388807] funs:create_kthread,create_kthread is run.....pid_num=91 [ 0.389477] funs:create_kthread,create_kthread is run.....pid_num=92 [ 0.390155] funs:create_kthread,create_kthread is run.....pid_num=93 [ 0.390835] funs:create_kthread,create_kthread is run.....pid_num=94 [ 0.391493] funs:create_kthread,create_kthread is run.....pid_num=95 [ 0.392166] funs:create_kthread,create_kthread is run.....pid_num=96 [ 0.392843] funs:create_kthread,create_kthread is run.....pid_num=97 [ 0.393504] funs:create_kthread,create_kthread is run.....pid_num=98 [ 0.394177] funs:create_kthread,create_kthread is run.....pid_num=99 [ 0.395497] funs:create_kthread,create_kthread is run.....pid_num=100 [ 0.396196] funs:create_kthread,create_kthread is run.....pid_num=101 [ 0.396870] NET: Registered protocol family 38 [ 0.397288] Key type asymmetric registered [ 0.397680] Asymmetric key parser 'x509' registered [ 0.398258] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 0.398926] io scheduler noop registered [ 0.399277] io scheduler deadline registered [ 0.399782] io scheduler cfq registered (default) [ 0.400946] platform ff770000.syscon:usb2-phy@e450: Driver rockchip-usb2phy requests probe deferral [ 0.402301] funs:create_kthread,create_kthread is run.....pid_num=102 [ 0.403059] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned [ 0.404146] funs:create_kthread,create_kthread is run.....pid_num=103 [ 0.406243] platform ff7c0000.phy: Driver rockchip-typec-phy requests probe deferral [ 0.408601] Enter viewmore_gpio_probe [ 0.408926] Enter viewmore_gpio_probe get node = gpio_viewmore this board is master board [ 0.409748] Enter viewmore_gpio_probe return = 91
[ 0.410249] Enter viewmore_gpio_probe return = 13
[ 0.410759] Enter viewmore_gpio_probe return = 122
[ 0.411269] Enter viewmore_gpio_probe return = 7
[ 0.411762] Enter viewmore_gpio_probe return = 70
[ 0.412259] Enter viewmore_gpio_probe return = 2
[ 0.412750] Enter viewmore_gpio_probe return = 121
[ 0.413253] Enter viewmore_gpio_probe return = 120
[ 0.413769] Enter viewmore_gpio_probe return = 42
[ 0.414261] Enter viewmore_gpio_probe return = 54
[ 0.414764] Enter viewmore_gpio_probe return = 55
get pinctrl success
[ 0.415874] set pinctrl gpio_state[0] is success
[ 0.416286] set pinctrl gpio_state[1] is success
[ 0.416703] set pinctrl gpio_state[2] is success
[ 0.417113] set pinctrl gpio_state[3] is success
[ 0.417522] set pinctrl gpio_state[4] is success
[ 0.417938] set pinctrl gpio_state[5] is success
[ 0.418348] set pinctrl id_state[0] is success
[ 0.418751] set pinctrl id_state[1]is success
[ 0.419148] set pinctrl board_flag_state[0]is success
[ 0.419610] set pinctrl board_flag_state[1]is success
[ 0.420065] set pinctrl board_flag_state[0]is success
[ 0.422241] funs:create_kthread,create_kthread is run…pid_num=104
[ 0.423022] rk-vcodec ff650000.vpu_service: probe device
[ 0.423533] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc078d96c10
[ 0.424307] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.424866] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.425423] funs:create_kthread,create_kthread is run…pid_num=105
[ 0.426153] funs:create_kthread,create_kthread is run…pid_num=106
[ 0.427018] rk-vcodec ff650000.vpu_service: init success
[ 0.427778] funs:create_kthread,create_kthread is run…pid_num=107
[ 0.428731] rk-vcodec ff660000.rkvdec: probe device
[ 0.429195] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc078d97410
[ 0.429900] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.430409] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.430957] funs:create_kthread,create_kthread is run…pid_num=108
[ 0.431840] rk-vcodec ff660000.rkvdec: init success
[ 0.433578] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.434247] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.436464] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.437144] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.439059] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.441178] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[ 0.442622] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 36, base_baud = 1500000) is a 16550A
[ 0.444018] ff370000.serial: ttyS1 at MMIO 0xff370000 (irq = 38, base_baud = 1500000) is a 16550A
[ 0.445748] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 0.449307] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008bd2e20)
[ 0.450232] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008bd2e20)
[ 0.451187] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 0.451789] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.452525] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.453487] funs:create_kthread,create_kthread is run…pid_num=109
[ 0.454200] funs:create_kthread,create_kthread is run…pid_num=110
[ 0.455168] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008bcdda0)
[ 0.455903] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.456613] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 0.457338] rockchip-drm display-subsystem: failed to parse loader memory
[ 0.457980] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 0.458721] [drm:drm_fb_helper_single_fb_probe] Cannot find any crtc or sizes - going 1024x768
[ 0.470912] Console: switching to colour frame buffer device 128x48
[ 0.478493] rockchip-drm display-subsystem: fb0: frame buffer device
[ 0.485912] mali ff9a0000.gpu: Failed to get regulator
[ 0.486365] mali ff9a0000.gpu: Power control initialization failed
[ 0.487003] platform ff9a0000.gpu: Driver mali requests probe deferral
[ 0.487824] Unable to detect cache hierarchy from DT for CPU 0
[ 0.488466] funs:create_kthread,create_kthread is run…pid_num=111
[ 0.489694] brd: module loaded
[ 0.490198] funs:create_kthread,create_kthread is run…pid_num=112
[ 0.491460] funs:create_kthread,create_kthread is run…pid_num=113
[ 0.492703] funs:create_kthread,create_kthread is run…pid_num=114
[ 0.493903] funs:create_kthread,create_kthread is run…pid_num=115
[ 0.495101] funs:create_kthread,create_kthread is run…pid_num=116
[ 0.496299] funs:create_kthread,create_kthread is run…pid_num=117
[ 0.497513] funs:create_kthread,create_kthread is run…pid_num=118
[ 0.498750] funs:create_kthread,create_kthread is run…pid_num=119
[ 0.499838] loop: module loaded
[ 0.500230] funs:create_kthread,create_kthread is run…pid_num=120
[ 0.501266] zram: Added device: zram0
[ 0.501874] lkdtm: No crash points registered, enable through debugfs
[ 0.502696] funs:create_kthread,create_kthread is run…pid_num=121
[ 0.503838] register spi return v = :0
[ 0.504191] tun: Universal TUN/TAP device driver, 1.6
[ 0.504651] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.506502] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 0.507142] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 0.507652] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 0.508327] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 0.508871] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 0.514490] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.514950] Ring mode enabled
[ 0.515226] DMA HW capability register supported
[ 0.515639] Normal descriptors
[ 0.515949] RX Checksum Offload Engine supported (type 2)
[ 0.516435] TX Checksum insertion supported
[ 0.516821] Wake-Up On Lan supported
[ 0.517176] Enable RX Mitigation via HW Watchdog Timer
[ 0.587410] libphy: stmmac: probed
[ 0.587760] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 0.588331] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 0.588851] eth%d: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02)
[ 0.589362] eth%d: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03)
[ 0.589881] eth%d: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04)
[ 0.590392] eth%d: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05)
[ 0.590908] eth%d: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06)
[ 0.591419] eth%d: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07)
[ 0.591936] eth%d: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08)
[ 0.592446] eth%d: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09)
[ 0.592963] eth%d: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a)
[ 0.593486] eth%d: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b)
[ 0.594013] eth%d: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c)
[ 0.594535] eth%d: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d)
[ 0.595063] eth%d: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e)
[ 0.595592] eth%d: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f)
[ 0.596113] eth%d: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10)
[ 0.596642] eth%d: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11)
[ 0.597164] eth%d: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12)
[ 0.597691] eth%d: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13)
[ 0.598213] eth%d: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14)
[ 0.598742] eth%d: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15)
[ 0.599264] eth%d: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16)
[ 0.599791] eth%d: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17)
[ 0.600313] eth%d: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18)
[ 0.600840] eth%d: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19)
[ 0.601362] eth%d: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a)
[ 0.601891] eth%d: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b)
[ 0.602412] eth%d: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c)
[ 0.602940] eth%d: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d)
[ 0.603461] eth%d: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e)
[ 0.603989] eth%d: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f)
[ 0.605513] PPP generic driver version 2.4.2
[ 0.606144] usbcore: registered new interface driver rndis_wlan
[ 0.606795] funs:create_kthread,create_kthread is run…pid_num=122
[ 0.607498] Rockchip WiFi SYS interface (V1.00) …
[ 0.607982] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.608712] usbcore: registered new interface driver pegasus
[ 0.609243] usbcore: registered new interface driver rtl8150
[ 0.609784] usbcore: registered new interface driver r8152
[ 0.610314] usbcore: registered new interface driver asix
[ 0.610831] usbcore: registered new interface driver ax88179_178a
[ 0.611396] usbcore: registered new interface driver cdc_ether
[ 0.611952] usbcore: registered new interface driver dm9601
[ 0.612484] usbcore: registered new interface driver smsc75xx
[ 0.613045] usbcore: registered new interface driver smsc95xx
[ 0.613596] usbcore: registered new interface driver net1080
[ 0.614126] usbcore: registered new interface driver rndis_host
[ 0.614691] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.615404] usbcore: registered new interface driver cdc_ncm
[ 0.615944] usbcore: registered new interface driver qmi_wwan
[ 0.616485] usbcore: registered new interface driver cdc_mbim
[ 0.618640] platform fe800000.dwc3: Driver dwc3 requests probe deferral
[ 0.619279] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 0.619983] platform usb@fe800000: Driver rockchip-dwc3 requests probe deferral
[ 0.627273] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 0.628099] platform usb@fe900000: Driver rockchip-dwc3 requests probe deferral
[ 0.629527] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.630137] ehci-pci: EHCI PCI platform driver
[ 0.630594] ehci-platform: EHCI generic platform driver
[ 0.631312] platform fe380000.usb: Driver ehci-platform requests probe deferral
[ 0.635582] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 0.636237] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 0.637045] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 0.643580] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 0.644284] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.644894] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.645536] usb usb1: Product: EHCI Host Controller
[ 0.645975] usb usb1: Manufacturer: Linux 4.4.77 ehci_hcd
[ 0.646451] usb usb1: SerialNumber: fe3c0000.usb
[ 0.647315] hub 1-0:1.0: USB hub found
[ 0.647686] hub 1-0:1.0: 1 port detected
[ 0.648528] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.649101] ohci-platform: OHCI generic platform driver
[ 0.649822] platform fe3a0000.usb: Driver ohci-platform requests probe deferral
[ 0.650698] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 0.651455] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 0.652253] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 0.707713] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.708310] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.708964] usb usb2: Product: Generic Platform OHCI controller
[ 0.709488] usb usb2: Manufacturer: Linux 4.4.77 ohci_hcd
[ 0.709972] usb usb2: SerialNumber: fe3e0000.usb
[ 0.710828] hub 2-0:1.0: USB hub found
[ 0.711186] hub 2-0:1.0: 1 port detected
[ 0.712348] usbcore: registered new interface driver cdc_acm
[ 0.712864] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.713611] usbcore: registered new interface driver cdc_wdm
[ 0.714148] usbcore: registered new interface driver uas
[ 0.714707] usbcore: registered new interface driver usb-storage
[ 0.715315] usbcore: registered new interface driver usbserial
[ 0.715866] usbcore: registered new interface driver usbserial_generic
[ 0.716471] usbserial: USB Serial support registered for generic
[ 0.717051] usbcore: registered new interface driver cp210x
[ 0.717580] usbserial: USB Serial support registered for cp210x
[ 0.718146] usbcore: registered new interface driver ftdi_sio
[ 0.718690] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 0.719413] usbcore: registered new interface driver keyspan
[ 0.719944] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 0.720662] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 0.721322] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 0.721996] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 0.722683] usbcore: registered new interface driver option
[ 0.723190] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.723922] usbcore: registered new interface driver oti6858
[ 0.724440] usbserial: USB Serial support registered for oti6858
[ 0.725020] usbcore: registered new interface driver pl2303
[ 0.725537] usbserial: USB Serial support registered for pl2303
[ 0.726109] usbcore: registered new interface driver qcserial
[ 0.726649] usbserial: USB Serial support registered for Qualcomm USB modem
[ 0.727305] usbcore: registered new interface driver sierra
[ 0.727836] usbserial: USB Serial support registered for Sierra USB modem
[ 0.729193] usbcore: registered new interface driver iforce
[ 0.729780] usbcore: registered new interface driver xpad
[ 0.730329] ==gsl_ts_init==
[ 0.730616] ret=0
[ 0.730871] funs:create_kthread,create_kthread is run…pid_num=123
[ 0.731615] usbcore: registered new interface driver usbtouchscreen
[ 0.732420] .. rk pwm remotectl v1.1 init
[ 0.733021] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 0.734349] i2c /dev entries driver
[ 0.735840] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 0.736521] fan53555-reg: supplied by vcc5v0_sys
[ 0.738736] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 0.739389] fan53555-reg: supplied by vcc5v0_sys
[ 0.741728] rk808 0-001b: Pmic Chip id: 0x0
[ 0.744990] funs:create_kthread,create_kthread is run…pid_num=124
[ 0.745972] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.746577] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.747207] DCDC_REG1: supplied by vcc3v3_sys
[ 0.749353] DCDC_REG2: supplied by vcc3v3_sys
[ 0.750294] DCDC_REG3: supplied by vcc3v3_sys
[ 0.750933] DCDC_REG4: supplied by vcc3v3_sys
[ 0.751763] LDO_REG1: supplied by vcc3v3_sys
[ 0.753220] LDO_REG2: supplied by vcc3v3_sys
[ 0.754544] LDO_REG3: supplied by vcc3v3_sys
[ 0.755882] LDO_REG4: supplied by vcc3v3_sys
[ 0.757200] LDO_REG5: supplied by vcc3v3_sys
[ 0.758539] LDO_REG6: supplied by vcc3v3_sys
[ 0.759868] LDO_REG7: supplied by vcc3v3_sys
[ 0.761183] LDO_REG8: supplied by vcc3v3_sys
[ 0.762523] SWITCH_REG1: supplied by vcc3v3_sys
[ 0.763189] SWITCH_REG2: supplied by vcc3v3_sys
[ 0.767067] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 0.768195] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80093cc000
[ 0.768951] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 0.769891] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 0.770475] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 0.771457] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 0.772532] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80093ce000
[ 0.774225] funs:create_kthread,create_kthread is run…pid_num=125
[ 0.783803] funs:create_kthread,create_kthread is run…pid_num=126
[ 0.784468] fusb302 4-0022: port 0 probe success
[ 0.784914] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80093d0000
[ 0.786695] IR NEC protocol handler initialized
[ 0.787103] IR RC5(x/sz) protocol handler initialized
[ 0.787565] IR RC6 protocol handler initialized
[ 0.787972] IR JVC protocol handler initialized
[ 0.788379] IR Sony protocol handler initialized
[ 0.788795] IR SANYO protocol handler initialized
[ 0.789214] IR Sharp protocol handler initialized
[ 0.789642] IR MCE Keyboard/mouse protocol handler initialized
[ 0.790154] IR XMP protocol handler initialized
[ 0.791018] rockchip-rga ff680000.rga: HW Version: 0x03.02
[ 0.791805] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[ 0.792645] usbcore: registered new interface driver uvcvideo
[ 0.793155] USB Video Class driver (1.1.1)
[ 0.795800] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 0.796608] funs:create_kthread,create_kthread is run…pid_num=127
[ 0.798238] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 0.799029] funs:create_kthread,create_kthread is run…pid_num=128
[ 0.799721] Bluetooth: Virtual HCI driver ver 1.5
[ 0.800255] Bluetooth: HCI UART driver ver 2.3
[ 0.800662] Bluetooth: HCI UART protocol H4 registered
[ 0.801114] Bluetooth: HCI UART protocol LL registered
[ 0.801573] Bluetooth: HCI UART protocol ATH3K registered
[ 0.802109] usbcore: registered new interface driver bfusb
[ 0.802658] usbcore: registered new interface driver btusb
[ 0.803529] cpu cpu0: leakage=25
[ 0.804015] cpu cpu4: leakage=43
[ 0.808185] sdhci: Secure Digital Host Controller Interface driver
[ 0.808750] sdhci: Copyright(c) Pierre Ossman
[ 0.809148] Synopsys Designware Multimedia Card Interface Driver
[ 0.810497] dwmmc_rockchip fe310000.dwmmc: spin_lock_init…
[ 0.811029] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.811857] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 0.812461] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 0.813038] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 0.813983] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 0.814529] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 0.815386] platform fe310000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[ 0.816547] dwmmc_rockchip fe320000.dwmmc: spin_lock_init…
[ 0.817078] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.817742] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 0.818342] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 0.818892] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 0.819865] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 0.820666] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 0.821453] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 0.832623] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.843648] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 0.844162] dwmmc_rockchip fe320000.dwmmc: dw_mci_probe is done
[ 0.844741] funs:create_kthread,create_kthread is run…pid_num=129
[ 0.844954] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.846667] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 0.847201] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 0.848779] funs:create_kthread,create_kthread is run…pid_num=130
[ 0.874589] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 0.875267] funs:create_kthread,create_kthread is run…pid_num=131
[ 0.876214] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.877371] usbcore: registered new interface driver usbhid
[ 0.877882] usbhid: USB HID core driver
[ 0.879130] funs:create_kthread,create_kthread is run…pid_num=132
[ 0.880240] u32 classifier
[ 0.880488] Netfilter messages via NETLINK v0.30.
[ 0.880984] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 0.881842] ctnetlink v0.93: registering with nfnetlink.
[ 0.882438] ip_set: protocol 6
[ 0.882736] IPVS: Registered protocols ()
[ 0.883250] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 0.883993] IPVS: Creating netns size=1592 id=0
[ 0.884423] IPVS: ipvs loaded.
[ 0.885014] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 0.885622] Initializing XFRM netlink socket
[ 0.886643] NET: Registered protocol family 10
[ 0.887397] funs:create_kthread,create_kthread is run…pid_num=133
[ 0.888515] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 0.889172] sit: IPv6 over IPv4 tunneling driver
[ 0.890069] NET: Registered protocol family 17
[ 0.890481] NET: Registered protocol family 15
[ 0.890921] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 0.892058] Bridge firewalling registered
[ 0.892438] funs:create_kthread,create_kthread is run…pid_num=134
[ 0.893124] Bluetooth: RFCOMM socket layer initialized
[ 0.893711] Bluetooth: RFCOMM ver 1.11
[ 0.894072] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 0.894625] Bluetooth: HIDP socket layer initialized
[ 0.895152] 8021q: 802.1Q VLAN Support v1.8
[ 0.895574] lib80211: common routines for IEEE802.11 drivers
[ 0.896131] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 0.897057] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 0.897596] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354
[ 0.898204] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 0.898845] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 0.899596] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 0.900394] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 0.900873] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 0.901370] [BT_RFKILL]: Enter rfkill_rk_init
[ 0.902342] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 0.903116] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 0.903860] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 0.904603] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 0.905702] [BT_RFKILL]: Request irq for bt wakeup host
[ 0.906227] [BT_RFKILL]: ** disable irq
[ 0.906759] [BT_RFKILL]: bt_default device registered.
[ 0.907307] Key type dns_resolver registered
[ 0.907764] funs:create_kthread,create_kthread is run…pid_num=135
[ 0.908844] Registered cp15_barrier emulation handler
[ 0.909307] Registered setend emulation handler
[ 0.910524] Loading compiled-in X.509 certificates
[ 0.911185] funs:create_kthread,create_kthread is run…pid_num=136
[ 0.912419] funs:create_kthread,create_kthread is run…pid_num=137
[ 0.913241] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 0.914197] funs:create_kthread,create_kthread is run…pid_num=138
[ 0.915359] funs:create_kthread,create_kthread is run…pid_num=139
[ 0.917543] funs:create_kthread,create_kthread is run…pid_num=140
[ 0.918259] funs:create_kthread,create_kthread is run…pid_num=141
[ 0.919065] funs:create_kthread,create_kthread is run…pid_num=142
[ 0.919835] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 0.921082] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_kbase_devfreq.c; [Line] : 271; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 0.921421] mmc1: MAN_BKOPS_EN bit is not set
[ 0.922485] funs:create_kthread,create_kthread is run…pid_num=143
[ 0.923621] funs:create_kthread,create_kthread is run…pid_num=144
[ 0.924734] mali ff9a0000.gpu: Probed as mali0
[ 0.931923] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 0.932750] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 3
[ 0.933385] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 0.933901] funs:create_kthread,create_kthread is run…pid_num=145
[ 0.934106] funs:create_kthread,create_kthread is run…pid_num=146
[ 0.934230] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 0.934338] funs:create_kthread,create_kthread is run…pid_num=147
[ 0.934489] funs:create_kthread,create_kthread is run…pid_num=148
[ 0.934606] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 0.934710] funs:create_kthread,create_kthread is run…pid_num=149
[ 0.934896] funs:create_kthread,create_kthread is run…pid_num=150
[ 0.935017] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 0.935127] funs:create_kthread,create_kthread is run…pid_num=151
[ 0.935329] funs:create_kthread,create_kthread is run…pid_num=152
[ 0.935430] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 0.936101] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 0.936111] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 0.936119] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 0.936126] kernel: 0x001c00000 – 0x003000000 (20 MB)
[ 0.936133] backup: 0x003000000 – 0x003400000 (4 MB)
[ 0.936140] boot: 0x003400000 – 0x3a3a00000 (14854 MB)
[ 0.940753] mmcblk1: p1 p2 p3 p4 p5 p6
[ 0.940754] funs:create_kthread,create_kthread is run…pid_num=153
[ 0.944676] xhci-hcd xhci-hcd.5.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 0.945478] xhci-hcd xhci-hcd.5.auto: irq 226, io mem 0xfe800000
[ 0.946155] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.946762] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.947404] usb usb3: Product: xHCI Host Controller
[ 0.947846] usb usb3: Manufacturer: Linux 4.4.77 xhci-hcd
[ 0.948323] usb usb3: SerialNumber: xhci-hcd.5.auto
[ 0.949250] hub 3-0:1.0: USB hub found
[ 0.949623] hub 3-0:1.0: 1 port detected
[ 0.950244] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 0.950885] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 4
[ 0.951645] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 0.952443] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.953051] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.953698] usb usb4: Product: xHCI Host Controller
[ 0.954128] usb usb4: Manufacturer: Linux 4.4.77 xhci-hcd
[ 0.954616] usb usb4: SerialNumber: xhci-hcd.5.auto
[ 0.955471] hub 4-0:1.0: USB hub found
[ 0.955841] hub 4-0:1.0: 1 port detected
[ 0.957377] xhci-hcd xhci-hcd.5.auto: remove, state 1
[ 0.957876] usb usb4: USB disconnect, device number 1
[ 0.982124] xhci-hcd xhci-hcd.5.auto: Host not halted after 16000 microseconds.
[ 0.982768] xhci-hcd xhci-hcd.5.auto: Host controller not halted, aborting reset.
[ 0.983458] xhci-hcd xhci-hcd.5.auto: USB bus 4 deregistered
[ 0.984122] xhci-hcd xhci-hcd.5.auto: remove, state 1
[ 0.984593] usb usb3: USB disconnect, device number 1
[ 0.985402] xhci-hcd xhci-hcd.5.auto: USB bus 3 deregistered
[ 0.992378] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[ 0.993011] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 3
[ 0.993830] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 0.994636] xhci-hcd xhci-hcd.6.auto: irq 227, io mem 0xfe900000
[ 0.995278] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.995893] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.996531] usb usb3: Product: xHCI Host Controller
[ 0.996964] usb usb3: Manufacturer: Linux 4.4.77 xhci-hcd
[ 0.997438] usb usb3: SerialNumber: xhci-hcd.6.auto
[ 0.998222] hub 3-0:1.0: USB hub found
[ 0.998586] hub 3-0:1.0: 1 port detected
[ 0.999144] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[ 0.999744] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 4
[ 1.000462] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.001248] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.001859] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.002497] usb usb4: Product: xHCI Host Controller
[ 1.002946] usb usb4: Manufacturer: Linux 4.4.77 xhci-hcd
[ 1.003419] usb usb4: SerialNumber: xhci-hcd.6.auto
[ 1.004184] hub 4-0:1.0: USB hub found
[ 1.004534] hub 4-0:1.0: 1 port detected
[ 1.008877] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.009515] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 1.010309] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.016575] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.017247] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.017861] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.018498] usb usb5: Product: EHCI Host Controller
[ 1.018943] usb usb5: Manufacturer: Linux 4.4.77 ehci_hcd
[ 1.019417] usb usb5: SerialNumber: fe380000.usb
[ 1.020204] hub 5-0:1.0: USB hub found
[ 1.020566] hub 5-0:1.0: 1 port detected
[ 1.021450] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.022189] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 1.022967] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.077880] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.078487] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.079158] usb usb6: Product: Generic Platform OHCI controller
[ 1.079702] usb usb6: Manufacturer: Linux 4.4.77 ohci_hcd
[ 1.080191] usb usb6: SerialNumber: fe3a0000.usb
[ 1.081454] hub 6-0:1.0: USB hub found
[ 1.081867] hub 6-0:1.0: 1 port detected
[ 1.084012] dwmmc_rockchip fe310000.dwmmc: spin_lock_init…
[ 1.084546] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.085251] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.085890] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.086435] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.087455] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.088021] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.089078] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.100686] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.111785] funs:create_kthread,create_kthread is run…pid_num=154
[ 1.111843] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.111858] dwmmc_rockchip fe310000.dwmmc: dw_mci_probe is done
[ 1.113547] funs:create_kthread,create_kthread is run…pid_num=155
[ 1.114393] dhd_module_init: in
[ 1.114714] ======== dhd_wlan_init_plat_data ========
[ 1.115166] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 1.115640] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 1.116067] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 1.116406] funs:create_kthread,create_kthread is run…pid_num=156
[ 1.117283] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.117806] dhd_wlan_init_gpio: host_oob_irq: 67
[ 1.118220] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 1.118716] dhd_wifi_platform_load: Enter
[ 1.119154] Power-up adapter ‘DHD generic adapter’
[ 1.119717] wifi_platform_set_power = 1
[ 1.120082] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.120546] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.120783] funs:create_kthread,create_kthread is run…pid_num=157
[ 1.120863] rk808-rtc rk808-rtc: read time flag by yh
[ 1.121031] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:03 UTC (1358499003)
[ 1.122806] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.139701] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
u? 1.152987]
[ 1.177626] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 1.218627] mmc_host mmc2: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
楼主解决没 ?、?
