Hello,
I use firefly-rk3288 android 5.1 sdk.
I want to update the system with microSD, but I can’t.
I made update.img and wrote to microSD. I reboot the microSD after insert it into the board, but update is fail.
Please help me.
hi,you can use the tool as follow to make microsd
[url=]SD_Firmware_Tool._v1.46.zip[/url]
SD_Firmware_Tool._v1.46.zip (454 KB)
Thank you for your answer.
I made a microSD for upgrade using the tool you attached.
However, when I put the microSD into the board and reboot, the upgrade does not work.
I can’t see anything on the screen.
I really need an upgrade using MicroSD.
What did I do wrong?
++ boot log
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Nov 20 2017 - 17:19:35)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 0
SDCard Update.
storage init OK!
GetParam
Load FDT from boot image.
power key: bank-0 pin-5
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =1 vol=1100000,pwm_value=63
#Boot ver: 0000-00-00#0.00
empty serial no.
unknown reboot type 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
Secure Boot state: 0
kernel @ 0x02000000 (0x0064e470)
ramdisk @ 0x05bf0000 (0x002ad198)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561afb1 … OK
[ 0.000000] Linux version 3.10.0 (loki@ubuntu-jlee) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #386 SMP PREEMPT Mon Dec 10 22:47:12 KST 2018
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7f000000
[ 0.000000] ion_reserve: cma reserved base 7f000000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203)
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1e2b000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),-@0x003BC000(userdata) storagemedia=sd sdfwupdate loader.timestamp=2017-11-20_17:19:35
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 2025964k/2025964k available, 71188k reserved, 1556480K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b0ba80 (11279 kB)
[ 0.000000] .init : 0xc0b0c000 - 0xc0b64440 ( 354 kB)
[ 0.000000] .data : 0xc0b66000 - 0xc0cb5bc0 (1343 kB)
[ 0.000000] .bss : 0xc0cb5bc0 - 0xc0dd387c (1144 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rk_get_uboot_display_flag: 7
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] midi clk = de835e00, pclk = de83bd00, rate = 16e3600
[ 0.000000] timer_midi_init (clk=miditimer, mux=0, scl=24, rate=1000000, div=1)
[ 0.000000] timer.1000000: midi , 100(HZ:0)
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:11
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:8
[ 0.501466] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.501482] pid_max: default: 32768 minimum: 301
[ 0.501599] Security Framework initialized
[ 0.501643] Mount-cache hash table entries: 512
[ 0.502263] Initializing cgroup subsys debug
[ 0.502276] Initializing cgroup subsys memory
[ 0.502303] Initializing cgroup subsys freezer
[ 0.502332] CPU: Testing write buffer coherency: ok
[ 0.502629]pus/cpu@1 missing clock-frequency property
[ 0.502652] /cpus/cpu@2 missing clock-frequency property
[ 0.502661] /cpus/cpu@3 missing clock-frequency property
[ 0.502706] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.502754] Setting up static identity map for 0xc07f9688 - 0xc07f96e0
[ 0.505999] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x17ea (version 3.1)
[ 0.579462] CPU1: Booted secondary processor
[ 0.579494] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.599143] CPU2: Booted secondary processor
[ 0.599166] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.618853] CPU3: Booted secondary processor
[ 0.618876] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.618979] Brought up 4 CPUs
[ 0.619008] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.619017] CPU: All CPU(s) started in SVC mode.
[ 0.619709] devtmpfs: initialized
[ 0.623965] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.625034] pinctrl core: initialized pinctrl subsystem
[ 0.625276] regulator-dummy: no parameters
[ 0.638522] NET: Registered protocol family 16
[ 0.640279] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.640580] ion_snapshot: 0x1ea80000 map to 0xe0907000 and copy to 0xc0daed8c (version 0.1)
[ 0.640797] Registered FIQ tty driver
[ 0.641191] fiq-debugger is disabled in device tree
[ 0.641842] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.641864] rockchip_get_bank_d1/sbin/sh: No controlling tty: open /dev/tty: No such device or address
/sbin/sh: warning: won’t have full job control
# ] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.641897] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.641986] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.642051] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.642112] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.642174] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.642243] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.642307] rockx/sbin/sh: No controlling tty: open /dev/tty: No such device or address
ff7d0000,end=0xff7d00ff
[ 0.642369] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.642430] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.642497] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.642560] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.642573] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.642585] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.642595] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.643196] rockchip_interrupts_register:bank_num=7
[ 0.6455/sbin/sh: No controlling tty: open /dev/tty: No such device or address
165] rockchip_pinctrl_probe:init ok
[ 0.652488] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.652575] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652588] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.652761] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.652832] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652844] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.653007] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.653076] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.653088] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.653259] rk_iommu ff940300.vopl_mmu: (vopl) Enx/sbin/sh: No controlling tty: open /dev/tty: No such device or address
[ 0.653342] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.653514] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.653588] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.653600] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.653776] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.653846] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.653858] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.654030] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.654101] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.654113] rk_iommu ff9n/sbin/sh: No controlling tty: open /dev/tty: No such device or address
t: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.655879] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.656463] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.656484] DDR DEBUG: version 1.00 20150126
[ 0.656511] DDR DEBUG: Channel a:
[ 0.656520] DDR DEBUG: DDR3 Device
[ 0.656533] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.656541] DDR DEBUG: Channel b:
[ 0.656548] DDR DEBUG: DDR3 Device
[ 0.656560] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.656569] DDR DEBUG: addr=0xcbf000
[ 0.656579] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.6565886/sbin/sh: No controlling tty: open /dev/tty: No such device or address
597] DDR DEBUG: chAddr[0]=0xcbf000, chAddr[1]=0xcbf000
[ 0.656608] DDR DEBUG: dtar[0]=0x70197000, dtar[1]=0x70197000
[ 0.656663] DDR DEBUG: init success!!! freq=200MHz
[ 0.656670] DDR DEBUG: Channel a:
[ 0.656683] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656695] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656707] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656720] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656731] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x /sbin/sh: No controlling tty: open /dev/tty: No such device or address
DRV Pull-Dwn=0x19
[ 0.656749] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.656756] DDR DEBUG: Channel b:
[ 0.656767] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656780] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656792] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656804] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656814] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.656823] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.656831] DDR DEBUGs/sbin/sh: No controlling tty: open /dev/tty: No such device or address
lab at 0
[ 0.680696] Rockchip hdmi driver version 2.0
[ 0.680696] .
[ 0.681950] SCSI subsystem initialized
[ 0.682100] usbcore: registered new interface driver usbfs
[ 0.682143] usbcore: registered new interface driver hub
[ 0.682228] usbcore: registered new device driver usb
[ 0.686183] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.686641] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.687090] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.687328] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.687614] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.687733] media: Linux media interface: v0.6/sbin/sh: No controlling tty: open /dev/tty: No such device or address
87822] pps_core: LinuxPPS API ver. 1 registered
[ 0.687832] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.687851] PTP clock support registered
[ 0.687899] i2c-core: driver [bq24296] using legacy suspend method
[ 0.687908] i2c-core: driver [bq24296] using legacy resume method
[ 0.688235] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[ 0.688878] ion_drm_heap_create: 0@0
[ 0.689000] Rockchip ion module is successfully loaded (v1.1)
[ 0.689161] Advanced Linux Sound Architecture Driver Initialized.
[ 0.689537] Bluetooth: Core ver 2.16
[ 0.689590] NET: Registered protocol family 31
[ 0.689600] Bluetooth: HCIo/sbin/sh: No controlling tty: open /dev/tty: No such device or address
oth: HCI socket layer initialized
[ 0.689629] Bluetooth: L2CAP socket layer initialized
[ 0.689653] Bluetooth: SCO socket layer initialized
[ 0.689884] cfg80211: Calling CRDA to update world regulatory domain
[ 0.690968] rk808_i2c_probe,line=1361
[ 0.691498] rk808_pre_init,line=1230
[ 0.707672] vdd_arm: 712 ↔ 1500 mV at 1100 mV
[ 0.714433] vdd_gpu: 712 ↔ 1500 mV at 1100 mV
[ 0.720860] rk_dcdc3: 1200 mV
[ 0.729641] vccio: 3300 mV
[ 0.736072] rk_ldo1: 1800 mV
[ 0.742498] rk_ldo2: 3300 mV
[ 0.748919] rk_ldo3: 1000 mV
[ 0.755351] rk_ldo4: 1800 mV
[ 0.761772] rk_ldo5: 3300 mV
[ 0.768225] rk_ldo6: 1000 mV
[ 0.774647] rk_ldk/sbin/sh: No controlling tty: open /dev/tty: No such device or address
_ldo9: at 3300 mV
[ 0.787629] rk_ldo10: at 3300 mV
[ 0.790360] rk808_irq_init: rk808_pmic_irq=1
[ 0.790673] i2c-core: driver [rk818] using legacy suspend method
[ 0.790684] i2c-core: driver [rk818] using legacy resume method
[ 0.791031] rk808_rtc_probe,line=540
[ 0.807925] rk808-rtc rk808-rtc: rtc core: registered rk808 as rtc0
[ 0.811411] rk808_rtc_probe:ok
[ 0.812904] Switching to clocksource arch_sys_counter
[ 0.833766] rga: Module initialized.
[ 0.834445] rga2 ff920000.rga: rga ion client create success!
[ 0.834594] rga: Driver loaded succesfully
[ 0.834794] fb disp policy is box
[ 0.834833] rk-fb rockchip-fb: rk fb ion client cb/sbin/sh: No controlling tty: open /dev/tty: No such device or address
uffer driver probe
[ 0.835185] rk-screen rk_screen.8: rockchip screen probe success
[ 0.835422] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.835801] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.836008] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.836293] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.836455] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.836623] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.837403] vop ver:3007236,unsupport output color:1
[ 0.837546] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 0.837571] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.867832] alloc_buffer:ion_phy_adn/sbin/sh: No controlling tty: open /dev/tty: No such device or address
:0x1800000
[ 0.880627] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1ea9c000
[ 0.880642] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.880851] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.880864] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.881109] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.881427] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.881582] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.881740] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.882560] unknow screen type: 0
[ 0.882576] vop ver:3007236,unsupport output color:1
[ 0.882637] rk3288-8/sbin/sh: No controlling tty: open /dev/tty: No such device or address
-lcdc lcdc1: wakeup from standby!
[ 0.886362] fb4:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.886376] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 0.886777] rockchip_set_mux:warning ignore bank num 15
[ 0.886911] rockchip_set_mux:warning ignore bank num 15
[ 0.887027] rockchip_set_mux:warning ignore bank num 15
[ 0.887149] rockchip_set_mux:warning ignore bank num 15
[ 0.887257] rockchip_set_mux:warning ignore bank num 15
[ 0.887374] rockchip_set_mux:warning ignore bank num 15
[ 0.888326] rockchip_set_mux:warning ignore bank num 15
[ 0.888481] rockchip_set_mux:warning ignore bank num 15
[ 0.889421] rockchip_set_mux:warning ignore bank 1/sbin/sh: No controlling tty: open /dev/tty: No such device or address
5
[ 0.890486] rockchip_set_mux:warning ignore bank num 15
[ 0.890634] rockchip_set_mux:warning ignore bank num 15
[ 0.891543] rockchip_set_mux:warning ignore bank num 15
[ 0.891720] rockchip_set_mux:warning ignore bank num 15
[ 0.893103] NET: Registered protocol family 2
[ 0.893759] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.893834] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.893906] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.893957] TCP: reno registered
[ 0.893972] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.893997] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.89g/sbin/sh: No controlling tty: open /dev/tty: No such device or address
initramfs…
[ 1.025352] Freeing initrd memory: 2740K (c5bf0000 - c5e9d000)
[ 1.026100] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.026701] vcodec_service: probe device ff9a0000.vpu_service
[ 1.026906] vcodec_service: No reset resource define
[ 1.027078] vcodec_service: ff9a0000.vpu_service: power on
[ 1.027167] vcodec_service: probe device ff9a0000.vpu_service
[ 1.027183] vcodec_service: checking hw id 4831
[ 1.028162] vcodec_service: ff9a0000.vpu_service: power off…
[ 1.028207] vcodec_service: done
[ 1.028215] vcodec_service: init success
[ 1.028280] vcodec_service: probe device ff9c0000.hevc_service
[ 1.02/sbin/sh: No controlling tty: open /dev/tty: No such device or address
8699] vcodec_service: probe device ff9c0000.hevc_service
[ 1.028714] vcodec_service: checking hw id 6867
[ 1.029267] vcodec_service: ff9c0000.hevc_service: power off…
[ 1.029307] vcodec_service: done
[ 1.029315] vcodec_service: init success
[ 1.029490] rknandbase v1.0 2014-03-31
[ 1.029734] rknand_probe clk rate = 148500000
[ 1.029859] rknand_driver:ret = 0
[ 1.030267] audit: initializing netlink socket (disabled)
[ 1.030308] type=2000 audit(0.530:1): initialized
[ 1.031173] bounce pool size: 64 pages
[ 1.035740] fuse init (API version 7.22)
[ 1.036097] msgmni has been set to 954
[ 1.037531] Block layer SCSI generic (bsg) driver version 0.4 loa /sbin/sh: No controlling tty: open /dev/tty: No such device or address
1.037557] io scheduler deadline registered
[ 1.037641] io scheduler cfq registered (default)
[ 1.038531] rockchip_hdmiv2_probe
[ 1.038696] hdmi_register() - video source 1 display 0
[ 1.039030] hdmi_submit_work event 0100 delay 0 sync 0
[ 1.039062]
[ 1.039062] hdmi_work_queue() - evt= 1 0
[ 1.039078] hdmi_dev_enable
[ 1.039086] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 1.039101] hdmi_submit_work event 0404 delay 10 sync 0
[ 1.039115]
[ 1.039115] hdmi_work_queue() - exit evt= 1 0
[ 1.039315]
[ 1.039315] hdmi_work_queue() - evt= 4 4
[ 1.039332] [hdmi_dev_detect_hotplug] reg3004 value 00
[ 1.039341] hdmi_work_queue() - hpd is 0 hotplug is 0
[ 1.039842] IEP Power ON
[ 1.039882] iep ion client create success!
[ 1.040326] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1ea97000
[ 1.040337] IEP Power OFF
[ 1.040353] IEP Driver loaded succesfully
[ 1.040454] Module initialized.
[ 1.041253] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.041270] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.042604] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.042620] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.042983] vdd_logic: 925 ↔ 1400 mV at 1100 mV
[ 1.043301]y/sbin/sh: No controlling tty: open /dev/tty: No such device or address
S0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.043729] serial ff180000.serial: membase e097e000
[ 1.043897] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 1.044062] serial ff190000.serial: membase e2192000
[ 1.044201] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 1.045855] console [ttyS2] enabled
[ 1.046025] serial ff690000.serial: membase fed60000
[ 1.046195] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 1.046375] serial ff1b0000.serial: membase e21be000
[ 1.046538] ff1c0000.serial: ttyS4 at MMIO 0xff1c0000 (irq = 91) is a rk29_serial.4
[ 1.046713] serial ff1c0000.serial: membase e21er/sbin/sh: No controlling tty: open /dev/tty: No such device or address
eated 1 device(s) …
[ 1.049828] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 1.049840] i2c-core: driver [mpu6050B1] using legacy resume method
[ 1.049856] mpu_init: Probe name mpu6050B1
[ 1.050001] ak8963_mod_init: Probe name ak8963_mod
[ 1.050800] SCSI Media Changer driver v0.25
[ 1.051089] dws->regs: e21e4000
[ 1.052463] rockchip_spi_probe:num_cs=2,bus_num=2,irq=78,freq=45692308 ok
[ 1.052739] tun: Universal TUN/TAP device driver, 1.6
[ 1.052751] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.052869] vmac_init.
[ 1.053461] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 1.053476] stmmac_probe_config_dt: clock input/outpu3/sbin/sh: No controlling tty: open /dev/tty: No such device or address
[ 1.053500] stmmac_probe_config_dt: RX delay(0x19).
[ 1.053548] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 1.053559] stmmc_pltfr_init:
[ 1.053568] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 1.053591] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 1.053602] stmmc_pltfr_init: init for RGMII
[ 1.053613] tx delay=0x23
[ 1.053613] rx delay=0x19
[ 1.053629] tx delay=0x23
[ 1.053629] rx delay=0x19
[ 1.054083] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.054094] Normal descriptors
[ 1.054103] Ring mode enabled
[ 1.054113] DMA HW capability register supported
[ 1.054125] RX Checksum Offload Engine supported (type 2)
[ 1.0 /sbin/sh: No controlling tty: open /dev/tty: No such device or address
On Lan supported
[ 1.054182] Enable RX Mitigation via HW Watchdog Timer
[ 1.054639] PPP generic driver version 2.4.2
[ 1.054799] PPP BSD Compression module registered
[ 1.054812] PPP Deflate Compression module registered
[ 1.054836] PPP MPPE Compression module registered
[ 1.054849] NET: Registered protocol family 24
[ 1.054886] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.054899] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.054913] Rockchip WiFi SYS interface (V1.00) …
[ 1.054949] esp_mem_init enter date May 17 2018 13:21:14
[ 1.054959] esp_mem_init VERSION [V2.5]
[ 1.055004] esp_ma/sbin/sh: No controlling tty: open /dev/tty: No such device or address
ce driver catc
[ 1.055122] usbcore: registered new interface driver kaweth
[ 1.055135] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.055174] usbcore: registered new interface driver pegasus
[ 1.055212] usbcore: registered new interface driver rtl8150
[ 1.055256] usbcore: registered new interface driver r8152
[ 1.055268] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.055338] usbcore: registered new interface driver hso
[ 1.055386] usbcore: registered new interface driver asix
[ 1.055427] usbcore: registered new interface driver ax88179_178a
[ 1.055466] usbcore: registered new interface driver cdc_ether
[ 1.055503] usbcore: registered new interr/sbin/sh: No controlling tty: open /dev/tty: No such device or address
face driver dm9601
[ 1.055585] usbcore: registered new interface driver dm9620
[ 1.055634] usbcore: registered new interface driver smsc75xx
[ 1.055682] usbcore: registered new interface driver smsc95xx
[ 1.055721] usbcore: registered new interface driver gl620a
[ 1.055761] usbcore: registered new interface driver net1080
[ 1.055805] usbcore: registered new interface driver plusb
[ 1.055847] usbcore: registered new interface driver rndis_host
[ 1.055891] usbcore: registered new interface driver cdc_subset
[ 1.055938] usbcore: registered new interface driver zaurus
[ 1.055978] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.056039] usbcore: registered new ii/sbin/sh: No controlling tty: open /dev/tty: No such device or address
nterface driver kalmia
[ 1.056113] usbcore: registered new interface driver ipheth
[ 1.056161] usbcore: registered new interface driver sierra_net
[ 1.056199] usbcore: registered new interface driver cx82310_eth
[ 1.056245] usbcore: registered new interface driver cdc_ncm
[ 1.056282] usbcore: registered new interface driver qmi_wwan
[ 1.056320] usbcore: registered new interface driver cdc_mbim
[ 1.056332] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.058791] EHCI: ehci_rk_probe e2240000 e2240010
[ 1.058809] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 1.058838] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 1.059236] r1/sbin/sh: No controlling tty: open /dev/tty: No such device or address
.078652] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 1.078736] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.078754] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.078768] usb usb1: Product: EHCI Host Controller
[ 1.078781] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.078794] usb usb1: SerialNumber: ff500000.usb
[ 1.079215] hub 1-0:1.0: USB hub found
[ 1.079240] hub 1-0:1.0: 1 port detected
[ 1.079402] EHCI: ehci_rk_probe ok
[ 1.079518] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.079827] usbcore: registered new interface driver cdc_acm
[ 1.079841] cdc_acm: USB Abstract Control Model driver for USB mi/sbin/sh: No controlling tty: open /dev/tty: No such device or address
nterface driver usblp
[ 1.079938] usbcore: registered new interface driver cdc_wdm
[ 1.079995] usbcore: registered new interface driver usb-storage
[ 1.080032] usbcore: registered new interface driver ums-alauda
[ 1.080067] usbcore: registered new interface driver ums-cypress
[ 1.080104] usbcore: registered new interface driver ums-datafab
[ 1.080140] usbcore: registered new interface driver ums_eneub6250
[ 1.080181] usbcore: registered new interface driver ums-freecom
[ 1.080219] usbcore: registered new interface driver ums-isd200
[ 1.080254] usbcore: registered new interface driver ums-jumpshot
[ 1.080291] usbcore: registered new interface driver ums-karma
[ 1.080327] usbcore: rer/sbin/sh: No controlling tty: open /dev/tty: No such device or address
e: registered new interface driver ums-sddr09
[ 1.080400] usbcore: registered new interface driver ums-sddr55
[ 1.080438] usbcore: registered new interface driver ums-usbat
[ 1.080527] usbcore: registered new interface driver usbserial
[ 1.080568] usbcore: registered new interface driver usbserial_generic
[ 1.080599] usbserial: USB Serial support registered for generic
[ 1.080638] usbcore: registered new interface driver ch341
[ 1.080668] usbserial: USB Serial support registered for ch341-uart
[ 1.080706] usbcore: registered new interface driver cp210x
[ 1.080735] usbserial: USB Serial support registered for cp210x
[ 1.080781] usbcore: registered new intet/sbin/sh: No controlling tty: open /dev/tty: No such device or address
registered for GSM modem (1-port)
[ 1.080877] usbcore: registered new interface driver pl2303
[ 1.080912] usbserial: USB Serial support registered for pl2303
[ 1.080958] usbcore: registered new interface driver trancevibrator
[ 1.080970] usb20_otg: version 3.10a 21-DEC-2012
[ 1.081415] e2280040
[ 1.081429] Core Release: 3.10a
[ 1.081441] Setting default values for core params
[ 1.081582] Using Buffer DMA mode
[ 1.081595] Periodic Transfer Interrupt Enhancement - disabled
[ 1.081606] Multiprocessor Interrupt Enhancement - disabled
[ 1.081617] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.081627] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.081642] Dedicated Tx FIF6/sbin/sh: No controlling tty: open /dev/tty: No such device or address
4] usb20_otg ff580000.usb: DWC OTG Controller
[ 1.081995] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 1.082032] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 1.082093] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.082109] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.082124] usb usb2: Product: DWC OTG Controller
[ 1.082137] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.082150] usb usb2: SerialNumber: ff580000.usb
[ 1.082580] hub 2-0:1.0: USB hub found
[ 1.082609] hub 2-0:1.0: 1 port detected
[ 1.082923] usb20_host: version 3.10a 21-DEC-2012
[ 1.085452] e2300040
[ l/sbin/sh: No controlling tty: open /dev/tty: No such device or address
ues for core params
[ 1.085582] Using Buffer DMA mode
[ 1.085594] Periodic Transfer Interrupt Enhancement - disabled
[ 1.085605] Multiprocessor Interrupt Enhancement - disabled
[ 1.085616] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.085626] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.085664] usb20_host ff540000.usb: DWC OTG Controller
[ 1.085691] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 1.085721] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 1.085813] Init: Power Port (0)
[ 1.085869] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.085886] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.085900] usbu/sbin/sh: No controlling tty: open /dev/tty: No such device or address
[ 1.085925] usb usb3: SerialNumber: ff540000.usb
[ 1.086338] hub 3-0:1.0: USB hub found
[ 1.086362] hub 3-0:1.0: 1 port detected
[ 1.087082] usbcore: registered new interface driver xpad
[ 1.087137] usbcore: registered new interface driver usb_acecad
[ 1.087188] usbcore: registered new interface driver aiptek
[ 1.087233] usbcore: registered new interface driver gtco
[ 1.087277] usbcore: registered new interface driver hanwang
[ 1.087319] usbcore: registered new interface driver kbtab
[ 1.087370] usbcore: registered new interface driver wacom
[ 1.087643] sensor_register_slave:mma8452,id=17
[ 1.087657] sensor_registe6/sbin/sh: No controlling tty: open /dev/tty: No such device or address
77] sensor_register_slave:mpu6880_acc,id=24
[ 1.087688] sensor_register_slave:mpu6500_acc,id=25
[ 1.087699] sensor_register_slave:cm3217,id=48
[ 1.087709] sensor_register_slave:cm3218,id=49
[ 1.087985] i2c /dev entries driver
[ 1.088682] IR NEC protocol handler initialized
[ 1.088696] IR RC5(x) protocol handler initialized
[ 1.088706] IR RC6 protocol handler initialized
[ 1.088715] IR JVC protocol handler initialized
[ 1.088725] IR Sony protocol handler initialized
[ 1.088734] IR RC5 (streamzap) protocol handler initialized
[ 1.088744] IR SANYO protocol handler initialized
[ 1.088754] IR MCE Keyboard/mouse protocol handler initialized
[ 1.0888940/sbin/sh: No controlling tty: open /dev/tty: No such device or address
6] USB Video Class driver (1.1.1)
[ 1.088915] gspca_main: v2.14.0 registered
[ 1.089058] test power disabled
[ 1.089098] i2c-core: driver [bq27320] using legacy suspend method
[ 1.089110] i2c-core: driver [bq27320] using legacy resume method
[ 1.089466] rockchip_temp_probe,line=364
[ 1.147540] tsadc ff280000.tsadc: initialized
[ 1.147949] device-mapper: uevent: version 1.0.3
[ 1.148203] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.148486] Bluetooth: HCI UART driver ver 2.2
[ 1.148502] Bluetooth: HCI H4 protocol initialized
[ 1.148513] Bluetooth: HCILL protocol initialized
[ 1.148524] rtk_btusb: Realtek Bluetooth USB driver module init, ven/sbin/sh: No controlling tty: open /dev/tty: No such device or address
terface for BT driver
[ 1.148702] usbcore: registered new interface driver rtk_btusb
[ 1.148810] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(594000), use default, just enable dvfs
[ 1.169461] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.169644] cpuidle: using governor ladder
[ 1.169657] cpuidle: using governor menu
[ 1.169693] Synopsys Designware Multimedia Card Interface Driver
[ 1.169705] MHSC version = Ver 2.00 2015-06-10
[ 1.170010] dw cru_regsbase addr 0x1d8.
[ 1.170022] dw cru_reset_offset val 3.
[ 1.170037] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.170093] dwmmc_rockchip ff0f0000.rksdmmc:./sbin/sh: No controlling tty: open /dev/tty: No such device or address
rksdmmc: Using internal DMA controller.
[ 1.170566] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.170688] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.186902] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.206609] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.206650] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.206669] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.206972] dw cru_regsbase addr 0x1d8.
[ 1.206984] dw cru_reset_offset val 0.
[ 1.206998] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.207053] dwmmc_rockchip ff0c0000.rksdmmc: failedc/sbin/sh: No controlling tty: open /dev/tty: No such device or address
[ 1.207933] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.218145] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.218208] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.236079] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.238692] mmc0: BKOPS_EN bit is not set
[ 1.240561] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.242839] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.242863] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.242884] [mmc0] tuning regsbase addr 0x218.
[ 1.243626] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 1.243636] [mmc0] host was already tuning, Don’t need to retry tune agan/sbin/sh: No controlling tty: open /dev/tty: No such device or address
ing error: cmd.error:0, data.error:-84
[ 1.243692] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 1.243701] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.243729] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 1.243773] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-248 (23 len)
[ 1.243785] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 282-282 (1 len)
[ 1.243796] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-248 (23 len)
[ 1.243806] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 124
[ 1.243849] mmc0: new HS200 MMC card at address 0001
[ 1.244118] mmcblk0: mmc0:0001 AJt/sbin/sh: No controlling tty: open /dev/tty: No such device or address
ition 3 4.00 MiB
[ 1.244523] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 1.244534] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.244543] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.244552] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.244561] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.244569] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.244577] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.244586] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.244594] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.244602] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.244627] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 1.244636] userdata: 0x077800000 – 0x3a3a00000 (12994 MB)
[ 1.244665] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc1]
[ 1.255826] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.255838] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.256147] dw cru_regsbase addr 0x1d8.
[ 1.256157] dw cru_reset_offset val 1.
[ 1.256167] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.256203] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ o/sbin/sh: No controlling tty: open /dev/tty: No such device or address
ntroller.
[ 1.256552] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.256805] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.275455] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.295153] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.295166] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.295448] leds-gpio leds.29: pins are not configured from the driver
[ 1.295497] leds-gpio leds.29: Skipping unavailable LED gpio -2 (firefly:blue:power)
[ 1.295514] leds-gpio leds.29: Skipping unavailable LED gpio -2 (firefly:yellow:user)
[ 1.295735] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.297112] us/sbin/sh: No controlling tty: open /dev/tty: No such device or address
bhid: USB HID core driver
[ 1.297230] ashmem: initialized
[ 1.297343] logger: created 256K log ‘log_main’
[ 1.297438] logger: created 256K log ‘log_events’
[ 1.297532] logger: created 256K log ‘log_radio’
[ 1.297619] logger: created 256K log ‘log_system’
[ 1.298669] input: rk29-keypad as /devices/ff100000.adc/key.31/input/input0
[ 1.300154] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.304526] rockchip-hdmi-i2s rockchip-hdmi-i2s.25: rk-hdmi-i2s-hifi ↔ ff890000.rockchip-i2s mapping ok
[ 1.315446] mmc1: Skipping voltage switch
[ 1.319451] wm8580 2-001a: ASoC: no source widget found for DAC1
[ 1.319463] wm8580 2-001a: ASoC: Failed to add route DAC1 → direct → VOUT1L
A/sbin/sh: No controlling tty: open /dev/tty: No such device or address
C1
[ 1.319486] wm8580 2-001a: ASoC: Failed to add route DAC1 → direct → VOUT1R
[ 1.319496] wm8580 2-001a: ASoC: no source widget found for DAC2
[ 1.319514] wm8580 2-001a: ASoC: Failed to add route DAC2 → direct → VOUT2L
[ 1.319525] wm8580 2-001a: ASoC: no source widget found for DAC2
[ 1.319534] wm8580 2-001a: ASoC: Failed to add route DAC2 → direct → VOUT2R
[ 1.319544] wm8580 2-001a: ASoC: no source widget found for DAC3
[ 1.319553] wm8580 2-001a: ASoC: Failed to add route DAC3 → direct → VOUT3L
[ 1.319563] wm8580 2-001a: ASoC: no source widget found for DAC3
[ 1.319571] wm8580 2-001a: ASoC: Failed to add route DAC3 → direct → VOUT3R
[ 1.319581]0/sbin/sh: No controlling tty: open /dev/tty: No such device or address
] wm8580 2-001a: ASoC: Failed to add route AINL → direct → ADC
[ 1.319599] wm8580 2-001a: ASoC: no sink widget found for ADC
[ 1.319607] wm8580 2-001a: ASoC: Failed to add route AINR → direct → ADC
[ 1.319708] Enter::rk29_wm8580_init----160
[ 1.321563] rockchip-wm8580 rockchip-wm8580.27: wm8580-hifi-playback ↔ ff890000.rockchip-i2s mapping ok
[ 1.321678] Enter::rk29_wm8580_init----160
[ 1.323689] rockchip-wm8580 rockchip-wm8580.27: wm8580-hifi-capture ↔ ff890000.rockchip-i2s mapping ok
[ 1.323733] wm8580 2-001a: ASoC: Failed to create LineIn debugfs file
[ 1.323757] wm8580 2-001a: ASoC: Failed to create MicIn debugfs file
[ 1.323770] wm8580 2-001a: 2/sbin/sh: No controlling tty: open /dev/tty: No such device or address
-001a: ASoC: Failed to create CenterSub debugfs file
[ 1.323801] wm8580 2-001a: ASoC: Failed to create Front debugfs file
[ 1.324208] rockchip_wm8580_audio_probe() register card
[ 1.324312] u32 classifier
[ 1.324320] Actions configured
[ 1.324333] Netfilter messages via NETLINK v0.30.
[ 1.324393] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.324768] ctnetlink v0.93: registering with nfnetlink.
[ 1.324839] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.324849] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.325115] xt_time: kernel timezone is -0000
[ 1.325386] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.325u/sbin/sh: No controlling tty: open /dev/tty: No such device or address
bic registered
[ 1.325635] Initializing XFRM netlink socket
[ 1.325864] NET: Registered protocol family 10
[ 1.326447] mip6: Mobile IPv6
[ 1.326477] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.326600] sit: IPv6 over IPv4 tunneling driver
[ 1.326961] NET: Registered protocol family 17
[ 1.326987] NET: Registered protocol family 15
[ 1.327047] Bridge firewalling registered
[ 1.327059] Ebtables v2.0 registered
[ 1.327241] Bluetooth: RFCOMM TTY layer initialized
[ 1.327267] Bluetooth: RFCOMM socket layer initialized
[ 1.327275] Bluetooth: RFCOMM ver 1.11
[ 1.327284] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.327291] Bluetooth: BNo/sbin/sh: No controlling tty: open /dev/tty: No such device or address
[ 1.327311] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.327323] Bluetooth: HIDP socket layer initialized
[ 1.327353] l2tp_core: L2TP core driver, V2.0
[ 1.327369] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.327376] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.327624] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.327640] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 1.327650] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 1.327660] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.327670] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 1.327680] [WL.
However, wh …
Hi, you can use the new firmware to make mircoSD,the firmware link as follow
https://drive.google.com/open?id=1Z6udta-x8cyf2rRh6qo7hnud2n-qU0_m
