rk3399仿照firefly lcd 调试方法调试edp屏幕接口,系统挂掉
1.uboot 报错
LT link start failed!
eDP link training failed (-121)
AUX CH command reply failed!
analogix_dp_read_byte_from_dpcd: Aux Transaction fail!
Rx Max Link Rate is abnormal :ff !
2.kernel 报错
[drm:rockchip_dp_bind] ERROR failed to find panel
[ 3.277390] rockchip-drm display-subsystem: failed to bind ff970000.edp (ops rockchip_dp_component_ops): -517
[ 3.277535] rockchip-drm display-subsystem: master bind failed: -517
[ 3.282752] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.282874] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
顶一下
检查上电时序和硬件连接是否正确
zhansb 发表于 2019-1-26 09:34
检查上电时序和硬件连接是否正确
大哥,我量的我们的板子lcd_en与lcd_rst电平不对,另外我发现firefly的板子在dts里面设的GPIO_ACTIVE_HIGH,这时输出本来应为低电平,但是量的是高电平,板子接口正常,可以显示,搞不明白怎么配dts了!是不是不像参考资料说的那样简单,你们是不是在uboot与kernel改了很多呢?主要应该注意些什么?谢谢。
我也碰到这个问题,是几率性的。
U-Boot 2014.10-RK3399-06-g406d420-dirty (Jul 19 2019 - 18:33:18)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from boot image.
power key: bank-0 pin-5
can’t find dts node for fixed
pmic:rk808
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=33
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2019-04-03#1.09
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
delay prepare[200] unprepare[200] enable[200] disable[200]
no fuel gauge found
Using display timing dts
Detailed mode clock 148500 kHz, flags[a]
H: 1920 2008 2052 2200
V: 1080 1084 1089 1125
bus_format: 100a
rk lcdc - 0 dclk set: dclk = 148500000HZ, pll select = 1, div = 1
Link Training Clock Recovery success
Link Training success!
Timeout of video stream on ok
unable to config video
Secure Boot state: 0
kernel @ 0x00280000 (0x01229008)
ramdisk @ 0x05bf0000 (0x001e07f8)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 0000000005614881 … OK
Add bank:000000000a200000, 0000000075e00000
CPU: rk3399
大佬解解决没?怎么解决的?
同样问题,没人解答呢。这都过了几年了。
