RK3288 刷android5.1固件后,重复重启进入
!(file:///C:/Users/answer/Desktop/1548060821.jpg)如图,自己的板子,自己编译这边android5.1的源码后,打包成固件刷进去,上电后每次都进入这个recovery界面,每次会自动重启,再加入此界面。硬件上把DDR改成了LPDDR3,用的是RK808,下面贴上部分串口log,附件里是详细的,希望有大神能帮忙看看。
[ 0.000000] Linux version 3.10.0 (jerome@lemaker) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #4 SMP PREEMPT Fri Jan 18 17:21:12 CST 2019
[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000
[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7cc00000
[ 0.000000] ion_reserve: cma reserved base 7cc00000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203)
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f26000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS3 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS3 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),-@0x003BC000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2019-01-18_17:20:50
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1992188k/1992188k available, 104964k reserved, 1523712K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bbbd80 (11984 kB)
[ 0.000000] .init : 0xc0bbc000 - 0xc0c15440 ( 358 kB)
[ 0.000000] .data : 0xc0c16000 - 0xc0da86c0 (1610 kB)
[ 0.000000] .bss : 0xc0da86c0 - 0xc0ecbdbc (1166 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:26
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:22
[ 0.493648] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.493664] pid_max: default: 32768 minimum: 301
[ 0.493781] Security Framework initialized
[ 0.493798] SELinux: Initializing.
[ 0.493873] Mount-cache hash table entries: 512
[ 0.494515] Initializing cgroup subsys debug
[ 0.494529] Initializing cgroup subsys memory
[ 0.494555] Initializing cgroup subsys freezer
[ 0.494584] CPU: Testing write buffer coherency: ok
[ 0.494899] /cpus/cpu@0 missing clock-frequency property
[ 0.494912] /cpus/cpu@1 missing clock-frequency property
[ 0.494922] /cpus/cpu@2 missing clock-frequency property
[ 0.494931] /cpus/cpu@3 missing clock-frequency property
[ 0.494985] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.495035] Setting up static identity map for 0xc0869720 - 0xc0869778
[ 0.498150] last_log: 0x1e900000 842 (version 3.1)
[ 0.571819] CPU1: Booted secondary processor
[ 0.571852] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.591485] CPU2: Booted secondary processor
[ 0.591509] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.611197] CPU3: Booted secondary processor
[ 0.611220] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.611320] Brought up 4 CPUs
[ 0.611349] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.611358] CPU: All CPU(s) started in SVC mode.
[ 0.612104] devtmpfs: initialized
[ 0.616467] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.617575] pinctrl core: initialized pinctrl subsystem
[ 0.617826] regulator-dummy: no parameters
[ 0.631961] NET: Registered protocol family 16
[ 0.633796] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.634172] ion_snapshot: 0x1ea98000 map to 0xe0907000 and copy to 0xc0ea704c (version 0.1)
[ 0.634411] Registered FIQ tty driver
[ 0.634813] fiq-debugger is disabled in device tree
[ 0.635550] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.635573] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.635590] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.635608] rockchip_get_ban5700] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.635767] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.635829] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.635891] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.635952] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.636014] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.636076] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.636138] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.636205] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.636269] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.636282] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.636294] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.636305] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.636917] rockchip_interrupts_register:bank_num=7
[ 0.638860] of_get_gpio_init_config:gpio[0] = 136, value = 0
[ 0.638880] of_get_gpio_init_config:gpio[1] = 13, value = 1
[ 0.638935] rockchip_pinctrl_probe:init ok
[ 0.645742] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.645837] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.645851] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.646019] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.646099] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646111] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.646269] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.646346] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646358] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.646517] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.646593] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646605] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.646771] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.646851] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646863] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.647026] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.647101] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647113] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.647283] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.647374] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647386] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.648975] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.648988] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.649574] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.649596] DDR DEBUG: version 1.00 20150126
[ 0.649626] DDR DEBUG: Channel a:
[ 0.649634] DDR DEBUG: LPDDR3 Device
[ 0.649648] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.649656] DDR DEBUG: Channel b:
[ 0.649664] DDR DEBUG: LPDDR3 Device
[ 0.649676] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.649685] DDR DEBUG: addr=0xdb2000
[ 0.649695] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.649703] DDR DEBUG: socAddr[0]=0xdb2000, socAddr[1]=0xdb2100
[ 0.649712] DDR DEBUG: chAddr[0]=0xdb2000, chAddr[1]=0xdb2000
[ 0.649724] DDR DEBUG: dtar[0]=0x201b6000, dtar[1]=0x201b6000
[ 0.649775] DDR DEBUG: init success!!! freq=200MHz
[ 0.649783] DDR DEBUG: Channel a:
[ 0.649796] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649808] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649821] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649833] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649845] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.649854] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.649863] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.649870] DDR DEBUG: Channel b:
[ 0.649881] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649894] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649906] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649918] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.649929] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.649938] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.649946] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.674760] bio: create slab at 0
[ 0.675274] Rockchip hdmi driver version 2.0
[ 0.675274] .
[ 0.676406] SCSI subsystem initialized
[ 0.676560] usbcore: registered new interface driver usbfs
[ 0.676604] usbcore: registered new interface driver hub
[ 0.676690] usbcore: registered new device driver usb
[ 0.678950] host_en_gpio= -2
[ 0.681337] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.681978] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.682419] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.682663] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.683096] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.683210] media: Linux media interface: v0.10
[ 0.683251] Linux video capture interface: v2.00
[ 0.683305] pps_core: LinuxPPS API ver. 1 registered
[ 0.683314] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.683334] PTP clock support registered
[ 0.683398] i2c-core: driver [bq24296] using legacy suspend method
[ 0.683407] i2c-core: driver [bq24296] using legacy resume method
[ 0.683710] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[ 0.684183] ion_drm_heap_create: 0@0
[ 0.684310] Rockchip ion module is successfully loaded (v1.1)
[ 0.684464] Advanced Linux Sound Architecture Driver Initialized.
[ 0.684876] Bluetooth: Core ver 2.16
[ 0.684914] NET: Registered protocol family 31
[ 0.684923] Bluetooth: HCI device and connection manager initialized
[ 0.684939] Bluetooth: HCI socket layer initialized
[ 0.684952] Bluetooth: L2CAP socket layer initialized
[ 0.684978] Bluetooth: SCO socket layer initialized
[ 0.685210] cfg80211: Calling CRDA to update world regulatory domain
[ 0.685896] act8846_i2c_probe,line=898
[ 0.687376] act8846 set 0xf4 error!
[ 0.687463] act8846: probe of 0-005a failed with error -11
[ 0.688230] The device is not syr82x fffffff5
[ 0.688248] syr82x: probe of 0-0040 failed with error -11
[ 0.688948] The device is not syr82x fffffff5
[ 0.688963] syr82x: probe of 0-0041 failed with error -11
[ 0.689407] rk808_i2c_probe,line=1355
[ 0.689909] rk808_pre_init,line=1224
[ 0.700044] rk808_i2c_probe: rk808_pmic_sleep=0
[ 0.706349] vdd_arm: 712 ↔ 1500 mV at 1100 mV
[ 0.713267] vdd_gpu: 712 ↔ 1500 mV at 1100 mV
[ 0.719709] rk_dcdc3: 1200 mV
[ 0.726463] vccio: 1800 ↔ 3300 mV at 3300 mV
[ 0.732915] rk_ldo1: 3300 mV
[ 0.739336] rk_ldo2: 3300 mV
[ 0.745758] rk_ldo3: 1000 mV
[ 0.752209] rk_ldo4: 1800 mV
[ 0.758633] rk_ldo5: 3300 mV
[ 0.765055] rk_ldo6: 1800 mV
[ 0.771090] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.771493] rk_ldo7: 1800 mV
[ 0.777920] rk_ldo8: 3300 mV
[ 0.781202] rk_ldo9: at 3300 mV
[ 0.784495] rk_ldo10: at 3300 mV
[ 0.787225] rk808_irq_init: rk808_pmic_irq=1
[ 0.787586] i2c-core: driver [rk818] using legacy suspend method
[ 0.787598] i2c-core: driver [rk818] using legacy resume method
[ 0.787945] rk808_rtc_probe,line=540
[ 0.804813] rk808-rtc rk808-rtc: rtc core: registered rk808 as rtc0
[ 0.808296] rk808_rtc_probe:ok
[ 0.809796] Switching to clocksource arch_sys_counter
[ 0.833164] rga: Module initialized.
[ 0.833861] rga2 ff920000.rga: rga ion client create success!
[ 0.834041] rga: Driver loaded succesfully
[ 0.834230] fb disp policy is box
[ 0.834296] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.834309] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.834630] rk-screen rk_screen.8: rockchip screen probe success
[ 0.834876] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.835229] rk32-edp ff970000.edp: screen is not edp!
[ 0.835249] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.835712] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.835932] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.836237] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.836414] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.836582] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.837276] rk3288-lcdc lcdc0: lcdc0: dclk:297000000>>fps:120
[ 0.837291] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.868117] alloc_buffer:ion_phy_addr=0x10000000
[ 0.880818] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.887733] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eab4000
[ 0.887768] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.888733] rockchip_set_mux:warning ignore bank num 15
[ 0.888884] rockchip_set_mux:warning ignore bank num 15
[ 0.889002] rockchip_set_mux:warning ignore bank num 15
[ 0.889120] rockchip_set_mux:warning ignore bank num 15
[ 0.889241] rockchip_set_mux:warning ignore bank num 15
[ 0.889357] rockchip_set_mux:warning ignore bank num 15
[ 0.890326] rockchip_set_mux:warning ignore bank num 15
[ 0.890495] rockchip_set_mux:warning ignore bank num 15
[ 0.891418] rockchip_set_mux:warning ignore bank num 15
[ 0.891566] rockchip_set_mux:warning ignore bank num 15
[ 0.892481] rockchip_set_mux:warning ignore bank num 15
[ 0.892632] rockchip_set_mux:warning ignore bank num 15
[ 0.893559] rockchip_set_mux:warning ignore bank num 15
[ 0.893704] rockchip_set_mux:warning ignore bank num 15
[ 0.894818] tc358749_hdmiin_probe!
[ 0.954083] tc358749_hdmiin_probe OK!
[ 0.954611] NET: Registered protocol family 2
[ 0.955267] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.955341] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.955413] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.955467] TCP: reno registered
[ 0.955483] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.955505] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.955703] NET: Registered protocol family 1
[ 0.956296] Unpacking initramfs…
[ 1.088775] Freeing initrd memory: 2740K (c5bf0000 - c5e9d000)
[ 1.089585] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.090118] vcodec_service: probe device ff9a0000.vpu_service
[ 1.090319] vcodec_service: No reset resource define
[ 1.090494] vcodec_service: ff9a0000.vpu_service: power on
[ 1.090579] vcodec_service: probe device ff9a0000.vpu_service
[ 1.090594] vcodec_service: checking hw id 4831
[ 1.091599] vcodec_service: ff9a0000.vpu_service: power off…
[ 1.091644] vcodec_service: done
[ 1.091652] vcodec_service: init success
[ 1.091715] vcodec_service: probe device ff9c0000.hevc_service
[ 1.092042] vcodec_service: ff9c0000.hevc_service: power on
[ 1.092103] vcodec_service: probe device ff9c0000.hevc_service
[ 1.092117] vcodec_service: checking hw id 6867
[ 1.092675] vcodec_service: ff9c0000.hevc_service: power off…
[ 1.092727] vcodec_service: done
[ 1.092748] vcodec_service: init success
[ 1.092882] rknandbase v1.0 2014-03-31
[ 1.093013] rknand: probe of ff400000.nandc failed with error -1
[ 1.093121] rknand_driver:ret = 0
[ 1.094263] audit: initializing netlink socket (disabled)
[ 1.094305] type=2000 audit(0.600:1): initialized
[ 1.095154] bounce pool size: 64 pages
[ 1.099774] fuse init (API version 7.22)
[ 1.100142] msgmni has been set to 952
[ 1.101965] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.101981] io scheduler noop registered
[ 1.101991] io scheduler deadline registered
[ 1.102085] io scheduler cfq registered (default)
[ 1.103240] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 1.103916] IEP Power ON
[ 1.103956] iep ion client create success!
[ 1.104391] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaae000
[ 1.104402] IEP Power OFF
[ 1.104419] IEP Driver loaded succesfully
[ 1.104515] Module initialized.
[ 1.105084] --11
[ 1.105369] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.105386] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.106742] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.106758] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.107033] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
[ 1.107048] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
[ 1.107057] pwm_regulator_probe:error
[ 1.107077] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
[ 1.107271] rk_serial.c v1.8 2014-03-04
[ 1.107498] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.107685] serial ff180000.serial: membase e097e000
[ 1.107855] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 1.108019] serial ff190000.serial: membase e41ae000
[ 1.108158] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 1.108318] serial ff690000.serial: membase fed60000
[ 1.108460] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 1.110136] console [ttyS3] enabled
[ 1.110301] serial ff1b0000.serial: membase e41b6000
[ 1.113031] loop: module loaded
[ 1.113402] zram: Created 1 device(s) …
[ 1.113481] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 1.113493] i2c-core: driver [mpu6050B1] using legacy resume method
[ 1.113510] mpu_init: Probe name mpu6050B1
[ 1.113681] ak8963_mod_init: Probe name ak8963_mod
[ 1.114363] SCSI Media Changer driver v0.25
[ 1.114656] dws->regs: e41b8000
[ 1.115969] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
[ 1.116250] tun: Universal TUN/TAP device driver, 1.6
[ 1.116263] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.116381] vmac_init.
[ 1.116956] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 1.116972] stmmac_probe_config_dt: clock input/output? (input).
[ 1.116985] stmmac_probe_config_dt: TX delay(0x23).
[ 1.116997] stmmac_probe_config_dt: RX delay(0x19).
[ 1.117046] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 1.117057] stmmc_pltfr_init:
[ 1.117066] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 1.117088] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 1.117100] stmmc_pltfr_init: init for RGMII
[ 1.117111] tx delay=0x23
[ 1.117111] rx delay=0x19
[ 1.117127] tx delay=0x23
[ 1.117127] rx delay=0x19
[ 1.117613] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.117625] Normal descriptors
[ 1.117634] Ring mode enabled
[ 1.117644] DMA HW capability register supported
[ 1.117656] RX Checksum Offload Engine supported (type 2)
[ 1.117667] TX Checksum insertion supported
[ 1.117676] Wake-Up On Lan supported
[ 1.117716] Enable RX Mitigation via HW Watchdog Timer
[ 1.118165] PPP generic driver version 2.4.2
[ 1.118331] PPP BSD Compression module registered
[ 1.118344] PPP Deflate Compression module registered
[ 1.118368] PPP MPPE Compression module registered
[ 1.118381] NET: Registered protocol family 24
[ 1.118416] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.118429] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.118442] Rockchip WiFi SYS interface (V1.00) …
[ 1.118476] esp_mem_init enter date Jan 17 2019 17:32:41
[ 1.118488] esp_mem_init VERSION [V2.5]
[ 1.118530] esp_mem_init complete
[ 1.118615] usbcore: registered new interface driver catc
[ 1.118655] usbcore: registered new interface driver kaweth
[ 1.118669] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.118707] usbcore: registered new interface driver pegasus
[ 1.118753] usbcore: registered new interface driver rtl8150
[ 1.118793] usbcore: registered new interface driver r8152
[ 1.118804] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.118867] usbcore: registered new interface driver hso
[ 1.118910] usbcore: registered new interface driver asix
[ 1.118949] usbcore: registered new interface driver ax88179_178a
[ 1.118987] usbcore: registered new interface driver cdc_ether
[ 1.119030] usbcore: registered new interface driver cdc_eem
[ 1.119067] usbcore: registered new interface driver dm9601
[ 1.119104] usbcore: registered new interface driver dm9620
[ 1.119151] usbcore: registered new interface driver smsc75xx
[ 1.119197] usbcore: registered new interface driver smsc95xx
[ 1.119235] usbcore: registered new interface driver gl620a
[ 1.119281] usbcore: registered new interface driver net1080
[ 1.119320] usbcore: registered new interface driver plusb
[ 1.119360] usbcore: registered new interface driver rndis_host
[ 1.119399] usbcore: registered new interface driver cdc_subset
[ 1.119436] usbcore: registered new interface driver zaurus
[ 1.119476] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.119540] usbcore: registered new interface driver int51x1
[ 1.119580] usbcore: registered new interface driver kalmia
[ 1.119624] usbcore: registered new interface driver ipheth
[ 1.119667] usbcore: registered new interface driver sierra_net
[ 1.119707] usbcore: registered new interface driver cx82310_eth
[ 1.119754] usbcore: registered new interface driver cdc_ncm
[ 1.119794] usbcore: registered new interface driver qmi_wwan
[ 1.119834] usbcore: registered new interface driver cdc_mbim
[ 1.119847] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.122302] EHCI: ehci_rk_probe e4240000 e4240010
[ 1.122320] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 1.122354] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 1.122692] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 1.134594] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 1.134678] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.134695] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.134709] usb usb1: Product: EHCI Host Controller
[ 1.134723] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.134735] usb usb1: SerialNumber: ff500000.usb
[ 1.135165] hub 1-0:1.0: USB hub found
[ 1.135197] hub 1-0:1.0: 1 port detected
[ 1.135356] EHCI: ehci_rk_probe ok
[ 1.135456] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.135746] usbcore: registered new interface driver cdc_acm
[ 1.135759] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.135814] usbcore: registered new interface driver usblp
[ 1.135857] usbcore: registered new interface driver cdc_wdm
[ 1.135919] usbcore: registered new interface driver usb-storage
[ 1.135958] usbcore: registered new interface driver ums-alauda
[ 1.135997] usbcore: registered new interface driver ums-cypress
[ 1.136042] usbcore: registered new interface driver ums-datafab
[ 1.136080] usbcore: registered new interface driver ums_eneub6250
[ 1.136119] usbcore: registered new interface driver ums-freecom
[ 1.136158] usbcore: registered new interface driver ums-isd200
[ 1.136196] usbcore: registered new interface driver ums-jumpshot
[ 1.136238] usbcore: registered new interface driver ums-karma
[ 1.136277] usbcore: registered new interface driver ums-onetouch
[ 1.136317] usbcore: registered new interface driver ums-sddr09
[ 1.136355] usbcore: registered new interface driver ums-sddr55
[ 1.136394] usbcore: registered new interface driver ums-usbat
[ 1.136486] usbcore: registered new interface driver usbserial
[ 1.136528] usbcore: registered new interface driver usbserial_generic
[ 1.136561] usbserial: USB Serial support registered for generic
[ 1.136602] usbcore: registered new interface driver ch341
[ 1.136633] usbserial: USB Serial support registered for ch341-uart
[ 1.136675] usbcore: registered new interface driver cp210x
[ 1.136705] usbserial: USB Serial support registered for cp210x
[ 1.136751] usbcore: registered new interface driver option
[ 1.136786] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.136855] usbcore: registered new interface driver pl2303
[ 1.136886] usbserial: USB Serial support registered for pl2303
[ 1.136933] usbcore: registered new interface driver trancevibrator
[ 1.136946] usb20_otg: version 3.10a 21-DEC-2012
[ 1.137358] e4280040
[ 1.137373] Core Release: 3.10a
[ 1.137385] Setting default values for core params
[ 1.137515] Using Buffer DMA mode
[ 1.137527] Periodic Transfer Interrupt Enhancement - disabled
[ 1.137538] Multiprocessor Interrupt Enhancement - disabled
[ 1.137550] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.137561] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.137574] Dedicated Tx FIFOs mode
[ 1.137606] pcd_init otg_dev = ddf3e840
[ 1.137755] usb20_otg ff580000.usb: DWC OTG Controller
[ 1.137785] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 1.137815] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 1.137875] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.137892] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.137906] usb usb2: Product: DWC OTG Controller
[ 1.137919] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.137932] usb usb2: SerialNumber: ff580000.usb
[ 1.138370] hub 2-0:1.0: USB hub found
[ 1.138395] hub 2-0:1.0: 1 port detected
[ 1.144574] usb20_host: version 3.10a 21-DEC-2012
[ 1.147091] e4300040
[ 1.147103] Core Release: 3.10a
[ 1.147114] Setting default values for core params
[ 1.147223] Using Buffer DMA mode
[ 1.147234] Periodic Transfer Interrupt Enhancement - disabled
[ 1.147245] Multiprocessor Interrupt Enhancement - disabled
[ 1.147256] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.147266] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.147294] usb20_host ff540000.usb: DWC OTG Controller
[ 1.147321] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 1.147351] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 1.147444] Init: Power Port (0)
[ 1.147510] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.147527] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.147541] usb usb3: Product: DWC OTG Controller
[ 1.147554] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.147567] usb usb3: SerialNumber: ff540000.usb
[ 1.147961] hub 3-0:1.0: USB hub found
[ 1.147983] hub 3-0:1.0: 1 port detected
[ 1.148665] usbcore: registered new interface driver xpad
[ 1.148724] usbcore: registered new interface driver usb_acecad
[ 1.148772] usbcore: registered new interface driver aiptek
[ 1.148819] usbcore: registered new interface driver gtco
[ 1.148882] usbcore: registered new interface driver hanwang
[ 1.148929] usbcore: registered new interface driver kbtab
[ 1.148983] usbcore: registered new interface driver wacom
[ 1.148994] ==gsl_ts_init==
[ 1.149059] ret=0
[ 1.149347] sensor_register_slave:mma8452,id=17
[ 1.149361] sensor_register_slave:gs_mc3230,id=23
[ 1.149371] gsensor_init
[ 1.149381] sensor_register_slave:mpu6880_acc,id=24
[ 1.149393] sensor_register_slave:mpu6500_acc,id=25
[ 1.149404] sensor_register_slave:cm3217,id=48
[ 1.149414] sensor_register_slave:cm3218,id=49
[ 1.149632] .. rk pwm remotectl v1.1 init
[ 1.149875] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 1.153176] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
[ 1.153260] hdmi->edidread:1[ 1.163836] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc1
[ 1.165495] i2c /dev entries driver
[ 1.166182] IR NEC protocol handler initialized
[ 1.166196] IR RC5(x) protocol handler initialized
[ 1.166207] IR RC6 protocol handler initialized
[ 1.166217] IR JVC protocol handler initialized
[ 1.166226] IR Sony protocol handler initialized
[ 1.166237] IR RC5 (streamzap) protocol handler initialized
[ 1.166247] IR SANYO protocol handler initialized
[ 1.166257] IR MCE Keyboard/mouse protocol handler initialized
[ 1.166422] usbcore: registered new interface driver uvcvideo
[ 1.166435] USB Video Class driver (1.1.1)
[ 1.166449] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 1.167899] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 1.167922] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 1.167944] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 1.167965] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 1.168005] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 1.168005]
[ 1.168080] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.168234] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe41e8000 size: 0x4000)
[ 1.168887] D1:camsys_platform_probe(1446): ff910000.isp memory:
[ 1.168906] D1:camsys_platform_probe(1456): Register memory (phy: 0xff910000 vir: 0xe4220000 size: 0x10000)
[ 1.168923] D1:camsys_platform_probe(1451): I2c memory (phy: 0x1df2c000 vir: 0xddf2c000 size: 0x1000)
[ 1.168938] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.168950] D1:camsys_platform_probe(1471): Probe ff910000.isp device success
[ 1.169340] not find test_power_init dev node
[ 1.169403] i2c-core: driver [bq27320] using legacy suspend method
[ 1.169415] i2c-core: driver [bq27320] using legacy resume method
[ 1.169755] rockchip_temp_probe,line=364
[ 1.200457] rockchip-hdmiv2 ff980000.hdmi: warning: no CEA video mode parsed from EDID !!!
[ 1.200492] hdmi output corlor mode is 1
[ 1.200508] hdmi connect to lcdc0
[ 1.200519] switch:en=1,lcdc_id=0,screen type=6,cur type=1
[ 1.200598] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60
[ 1.200652] pixel clk is 74250000 tmds clk is 74250000
[ 1.200685] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output DVI.
[ 1.223146] tsadc ff280000.tsadc: initialized
[ 1.223517] device-mapper: uevent: version 1.0.3
[ 1.223762] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.224055] Bluetooth: HCI UART driver ver 2.2
[ 1.224071] Bluetooth: HCI H4 protocol initialized
[ 1.224083] Bluetooth: HCILL protocol initialized
[ 1.224095] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.224107] rtk_btusb: Register usb char device interface for BT driver
[ 1.224280] usbcore: registered new interface driver rtk_btusb
[ 1.224345] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
[ 1.228199] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
[ 1.232005] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.232194] cpuidle: using governor ladder
[ 1.232208] cpuidle: using governor menu
[ 1.232244] Synopsys Designware Multimedia Card Interface Driver
[ 1.232255] MHSC version = Ver 2.00 2015-06-10
[ 1.232551] dw cru_regsbase addr 0x1d8.
[ 1.232564] dw cru_reset_offset val 3.
[ 1.232579] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.232619] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.237012] Using Buffer DMA mode
[ 1.237028] Periodic Transfer Interrupt Enhancement - disabled
[ 1.237039] Multiprocessor Interrupt Enhancement - disabled
[ 1.237051] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.237061] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.237185] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.237352] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.237498] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.252663] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.272385] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.272408] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.272427] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.272731] dw cru_regsbase addr 0x1d8.
[ 1.272744] dw cru_reset_offset val 0.
[ 1.272758] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.272794] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.273675] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.273819] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.273896] mmc1: no vmmc regulator found
[ 1.273993] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.274063] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.282235] Init: Power Port (0)
[ 1.282246] rk_battery_charger_detect_cb , battery_charger_detect 5
[ 1.292036] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.311745] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.311758] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.312026] dw cru_regsbase addr 0x1d8.
[ 1.312035] dw cru_reset_offset val 1.
[ 1.312045] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.312071] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.312248] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.312365] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.312622] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.330718] mmc0: BKOPS_EN bit is not set
[ 1.331373] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.333053] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.342236] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.342259] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.342278] [mmc0] tuning regsbase addr 0x218.
[ 1.343003] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 1.343012] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.343041] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 1.343077] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-5, data.error:-115
[ 1.343579] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-124 (12 len)
[ 1.343590] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 158-282 (12 len)
[ 1.343602] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-124 (12 len)
[ 1.343611] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 68
[ 1.343989] mmc0: new HS200 MMC card at address 0001
[ 1.344261] mmcblk0: mmc0:0001 H8G1e 7.28 GiB
[ 1.344374] mmcblk0rpmb: mmc0:0001 H8G1e partition 3 4.00 MiB
[ 1.344691] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 1.344704] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.344713] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.344722] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.344731] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.344739] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.344748] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.344756] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.344764] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.344772] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.344781] system: 0x012400000 – 0x072400000 (1536 MB)
[ 1.344789] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 1.344798] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 1.344806] userdata: 0x077800000 – 0x1d1c00000 (5540 MB)
[ 1.344835] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141358..dw_mci_set_ios: no card. [mmc1]
[ 1.351087] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.351108] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.351120] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.351413] leds-gpio leds.27: pins are not configured from the driver
[ 1.351691] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.353121] usbcore: registered new interface driver usbhid
[ 1.353131] usbhid: USB HID core driver
[ 1.353240] ashmem: initialized
[ 1.353343] logger: created 256K log ‘log_main’
[ 1.353434] logger: created 256K log ‘log_events’
[ 1.353522] logger: created 256K log ‘log_radio’
[ 1.353621] logger: created 256K log ‘log_system’
[ 1.354755] input: rk29-keypad as /devices/ff100000.adc/key.29/input/input1
[ 1.355611] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.355628] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.355639] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.355651] ES8323 2-0010: Error applying setting, reverse things back
[ 1.355699] es8323_adc = 0
[ 1.355714] jp es8323_line_det_gpio:79
[ 1.356386] es8323 probe error
[ 1.356405] ES8323: probe of 2-0010 failed with error -11
[ 1.357126] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.357614] rockchip-es8323 rockchip-es8323.26: ASoC: CODEC (null) not registered
[ 1.357645] rockchip_es8323_audio_probe() register card failed:-517
[ 1.357661] platform rockchip-es8323.26: Driver rockchip-es8323 requests probe deferral
[ 1.357830] u32 classifier
[ 1.357836] Actions configured
[ 1.357848] Netfilter messages via NETLINK v0.30.
[ 1.357908] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.358242] ctnetlink v0.93: registering with nfnetlink.
[ 1.358318] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.358327] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.358607] xt_time: kernel timezone is -0000
[ 1.358815] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.358948] arp_tables: (C) 2002 David S. Miller
[ 1.358986] TCP: cubic registered
[ 1.358992] Initializing XFRM netlink socket
[ 1.359226] NET: Registered protocol family 10
[ 1.359787] mip6: Mobile IPv6
[ 1.359819] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.359941] sit: IPv6 over IPv4 tunneling driver
[ 1.360283] NET: Registered protocol family 17
[ 1.360309] NET: Registered protocol family 15
[ 1.360363] Bridge firewalling registered
[ 1.360376] Ebtables v2.0 registered
[ 1.360535] Bluetooth: RFCOMM TTY layer initialized
[ 1.360560] Bluetooth: RFCOMM socket layer initialized
[ 1.360569] Bluetooth: RFCOMM ver 1.11
[ 1.360577] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.360584] Bluetooth: BNEP filters: protocol multicast
[ 1.360596] Bluetooth: BNEP socket layer initialized
[ 1.360605] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.360617] Bluetooth: HIDP socket layer initialized
[ 1.360647] l2tp_core: L2TP core driver, V2.0
[ 1.360663] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.360670] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.360865] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.360913] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 1.360925] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 1.360935] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.360944] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 1.360954] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.360976] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 1.360999] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 1.361009] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.361033] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 1.361042] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.361084] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.361238] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 1.361262] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 1.361278] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 1.361293] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 1.361340] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.361436] [BT_RFKILL]: ** disable irq
[ 1.361518] [BT_RFKILL]: ap6335 device registered.
[ 1.362393] rk3288_init_suspend
[ 1.362406] rk3288_suspend_init enter
[ 1.362608] rk3288_suspend_init: pm_ctrbits =200007
[ 1.362641] gpio_get_dts_info suspend:4
[ 1.362649] gpio_get_dts_info resume:4
[ 1.362655] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.362687] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.362849] clks_gating_suspend_init:clkgt info ok
[ 1.362961] Registering SWP/SWPB emulation handler
[ 1.362975] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
[ 1.384083] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
[ 1.384565] ddrfreq: verion 1.2 20140526
[ 1.384578] ddrfreq: normal 528MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 528MHz
[ 1.384587] ddrfreq: auto-freq=0
[ 1.384594] ddrfreq: auto-freq-table[0] 240MHz
[ 1.384601] ddrfreq: auto-freq-table[1] 324MHz
[ 1.384608] ddrfreq: auto-freq-table[2] 456MHz
[ 1.384614] ddrfreq: auto-freq-table[3] 528MHz
[ 1.385342] regulator-dummy: disabling
[ 1.385949] rockchip-es8323 rockchip-es8323.26: ASoC: CODEC (null) not registered
[ 1.385985] rockchip_es8323_audio_probe() register card failed:-517
[ 1.386005] platform rockchip-es8323.26: Driver rockchip-es8323 requests probe deferral
[ 1.386099] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 1.553661] wk2xxx_probe() GENA = 0xFF
[ 1.553671] spi driver error!!!
[ 1.553694] wk2xxxspi: probe of spi0.0 failed with error 1
[ 1.553717] register spi return v = :0
[ 1.553729] =======================================================
[ 1.553736] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 1.553743] =======================================================
[ 1.553751] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 1.553835] dhd_module_init: in
[ 1.553847] ======== dhd_wlan_init_plat_data ========
[ 1.553855] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 1.553863] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 1.553871] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.553894] dhd_wlan_init_gpio: host_oob_irq: 199
[ 1.553902] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 1.553909] dhd_wifi_platform_load: Enter
[ 1.553917] pcd_pullup, is_on 0
[ 1.553933] WARN::dwc_otg_handle_mode_mismatch_intr:69: Mode Mismatch Interrupt: currently in Host mode
[ 1.553933]
[ 1.553964] Power-up adapter ‘DHD generic adapter’
[ 1.553991] wifi_platform_set_power = 1
[ 1.553999] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.554003] file system registered
[ 1.554014] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.554023] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 1.554031] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 1.554747] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.554757] android_usb gadget: Number of LUNs=2
[ 1.554767] lun0: LUN: removable file: (no medium)
[ 1.554775] lun1: LUN: removable file: (no medium)
[ 1.554967] android_usb gadget: android_usb ready
[ 1.555112] i2c i2c-4: sensor_probe: gs_mma8452,debd1600
[ 1.555157] sensor_chip_init:gs_mma8452:devid=0x0,ops=0xc0d2dcac
[ 1.556469] sensor_active:fail to active sensor
[ 1.556480] sensor_init:line=188,error
[ 1.556487] sensor_initial:fail to init sensor
[ 1.556493] sensor_chip_init:fail to init sensor
[ 1.556504] i2c i2c-4: sensor_probe failed -11
[ 1.556504]
[ 1.556523] sensors: probe of 4-001d failed with error -11
[ 1.556550] sensor_init: Probe name sensors
[ 1.556578] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 1.560701] rk808-rtc rk808-rtc: setting system clock to 2013-01-21 08:53:22 UTC (1358758402)
[ 1.570252] rockchip-spdif-card rockchip-spdif-card.25: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
[ 1.571155] rockchip-es8323 rockchip-es8323.26: ASoC: CODEC (null) not registered
[ 1.571192] rockchip_es8323_audio_probe() register card failed:-517
[ 1.571210] platform rockchip-es8323.26: Driver rockchip-es8323 requests probe deferral
[ 1.575948] ret 1024
[ 1.576497] usbcore: registered new interface driver snd-usb-audio
[ 1.576508] ALSA device list:
[ 1.576515] #0: RK-SPDIF-CARD
[ 1.576990] Freeing unused kernel memory: 356K (c0bbc000 - c0c15000)
[ 1.628768] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 1.656106] [WLAN_RFKILL]: wifi turn on power. 156
[ 1.824107] type=1403 audit(1358758402.760:2): policy loaded auid=4294967295 ses=4294967295
[ 1.849884] init: could not import file ‘/init.recovery.rk30board.rc’ from ‘/init.rc’
[ 1.851778] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 1.851852] bat_cap: oldcap_path no exist
[ 1.851971] init: invalid gid ‘trace’
[ 1.852046] healthd: No charger supplies found
[ 1.852064] healthd: No battery devices found
[ 1.862772] wifi_platform_bus_enumerate device present 1
[ 1.862791] ======== Card detection to detect SDIO card! ========
[ 1.862800] mmc2:mmc host rescan start!
[ 1.959958] init: /dev/hw_random not found
[ 1.961336] init: /dev/hw_random not found
[ 1.962345] android_usb: already disabled
[ 1.962551] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 1.962572] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 2.079229] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 2.128429] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
[ 2.128456] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 600000Hz for init[mmc2]
[ 2.177616] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
[ 2.177646] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 400000Hz for init[mmc2]
[ 3.112413] EHCI: rk_ehci_hcd_enable, disable host controller
[ 3.830740] failed to power up DHD generic adapter, 0 retry left
[ 3.846569] wifi_platform_set_power = 0
[ 3.846583] ======== PULL WL_REG_ON(-1) LOW! ========
[ 3.846592] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.948816] [WLAN_RFKILL]: wifi shut off power.
[ 3.948829] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 3.948840] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 3.948850] wifi_platform_bus_enumerate device present 0
[ 3.948860] ======== Card detection to remove SDIO card! ========
[ 3.948869] mmc2:mmc host rescan start!
[ 3.948885] failed to power up DHD generic adapter, max retry reached**
[ 3.948918] unregister wifi platform drivers
[ 3.948928] wifi_platform_bus_enumerate device present 0
[ 3.948937] ======== Card detection to remove SDIO card! ========
[ 3.948944] mmc2:mmc host rescan start!
[ 3.948954] ======== dhd_wlan_deinit_plat_data ========
[ 3.948963] dhd_module_init: Failed to load the driver, try cnt 0
[ 3.948990] dhd_module_init: Failed to load driver max retry reached**
[ 3.949000] dhd_module_init: Exit err=-19
[ 6.403347] drmboot: module license ‘unspecified’ taints kernel.
[ 6.403381] Disabling lock debugging due to kernel taint
[ 6.403696] drm init, 20140910
[ 6.409156] drm init ok
[ 6.409307] init: Unable to open persistent property directory /data/property errno: 2
[ 6.410204] android_usb: already disabled
[ 6.410364] init: using deprecated syntax for specifying property ‘ro.product.manufacturer’, use ${name} instead
[ 6.410428] init: using deprecated syntax for specifying property ‘ro.product.model’, use ${name} instead
[ 6.410473] init: using deprecated syntax for specifying property ‘ro.serialno’, use ${name} instead
[ 6.410490] init: property ‘ro.serialno’ doesn’t exist while expanding ‘$ro.serialno’
[ 6.410502] init: cannot expand ‘$ro.serialno’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 6.411561] init: Warning! Service console needs a SELinux domain defined; please fix!
[ 6.413025] EXT4-fs (mmcblk0p9): VFS: Can’t find ext4 filesystem
[ 6.413922] read descriptors
[ 6.413936] read strings
[ 6.413971] pcd_pullup, is_on 1
[ 7.399861] EXT4-fs (mmcblk0p9): VFS: Can’t find ext4 filesystem
[ 8.393265] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 8.393276] [mmc0] Data transmission error, need to try retuning 1.
[ 8.393285] [mmc0] Data transmission error !!! MINTSTS: [0x00008008]
[ 8.393292] [mmc0] Data transmission error, need to try retuning 1.
[ 8.393698] [mmc0] tuning regsbase addr 0x218.
[ 8.394424] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 8.394431] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 8.394461] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 8.394494] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-5, data.error:-115
[ 8.394993] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-124 (12 len)
[ 8.395002] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 158-282 (12 len)
[ 8.395012] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-124 (12 len)
[ 8.395019] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 68
[ 8.395050] need_retune:1,brq->retune_retry_done:0.
[ 8.395056] mmcblk0: retrying because a re-tune was needed
[ 8.395354] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 8.395360] [mmc0] Data transmission error, need to try retuning 1.
[ 8.395368] [mmc0] Data transmission error !!! MINTSTS: [0x00008008]
[ 8.395375] [mmc0] Data transmission error, need to try retuning 1.
[ 8.395775] [mmc0] tuning regsbase addr 0x218.
[ 8.396531] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 8.396539] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 8.396565] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 8.396598] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-5, data.error:-115
[ 8.397092] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-124 (12 len)
[ 8.397101] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 158-282 (12 len)
[ 8.397110] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-124 (12 len)
[ 8.397117] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 68
[ 8.397145] need_retune:1,brq->retune_retry_done:1.
[ 8.397154] mmcblk0: error -110 transferring data, sector 24576, nr 96, cmd response 0x900, card status 0xd00
[ 8.397168] end_request: I/O error, dev mmcblk0, sector 24576
[ 8.397177] Buffer I/O error on device mmcblk0p3, logical block 0
[ 8.397183] lost page write due to I/O error on mmcblk0p3
[ 8.397200] end_request: I/O error, dev mmcblk0, sector 24584
[ 8.397207] Buffer I/O error on device mmcblk0p3, logical block 1
[ 8.397213] lost page write due to I/O error on mmcblk0p3
[ 8.397223] end_request: I/O error, dev mmcblk0, sector 24592
[ 8.397230] Buffer I/O error on device mmcblk0p3, logical block 2
[ 8.397236] lost page write due to I/O error on mmcblk0p3
[ 8.397246] end_request: I/O error, dev mmcblk0, sector 24600
[ 8.397253] Buffer I/O error on device mmcblk0p3, logical block 3
[ 8.397259] lost page write due to I/O error on mmcblk0p3
[ 8.397269] end_request: I/O error, dev mmcblk0, sector 24608
[ 8.397276] Buffer I/O error on device mmcblk0p3, logical block 4
[ 8.397282] lost page write due to I/O error on mmcblk0p3
[ 8.397293] end_request: I/O error, dev mmcblk0, sector 24616
[ 8.397299] Buffer I/O error on device mmcblk0p3, logical block 5
[ 8.397305] lost page write due to I/O error on mmcblk0p3
[ 8.397316] end_request: I/O error, dev mmcblk0, sector 24624
[ 8.397323] Buffer I/O error on device mmcblk0p3, logical block 6
[ 8.397329] lost page write due to I/O error on mmcblk0p3
[ 8.397339] end_request: I/O error, dev mmcblk0, sector 24632
[ 8.397345] Buffer I/O error on device mmcblk0p3, logical block 7
[ 8.397351] lost page write due to I/O error on mmcblk0p3
[ 8.397361] end_request: I/O error, dev mmcblk0, sector 24640
[ 8.397368] Buffer I/O error on device mmcblk0p3, logical block 8
[ 8.397374] lost page write due to I/O error on mmcblk0p3
[ 8.397384] end_request: I/O error, dev mmcblk0, sector 24648
[ 8.397391] Buffer I/O error on device mmcblk0p3, logical block 9
[ 8.397397] lost page write due to I/O error on mmcblk0p3
[ 8.398293] EXT4-fs (mmcblk0p9): VFS: Can’t find ext4 filesystem
[ 8.429679] rk3288-lcdc lcdc0: blank mode:0
[ 9.036109] [otg id chg] last id -1 current id 1
/sbin/sh: No controlling tty: open /dev/tty: No such device or address
/sbin/sh: warning: won’t have full job control
xterm-256colorxterm-256color# xterm-256colorxterm-256color[ 12.430208] EXT4-fs (mmcblk0p9): VFS: Can’t find ext4 filesystem
[ 12.555664] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 12.555704] [mmc0] Data transmission error, need to try retuning 1.
[ 12.555717] [mmc0] Data transmission error !!! MINTSTS: [0x00008008]
[ 12.555724] [mmc0] Data transmission error, need to try retuning 1.
[ 12.556167] [mmc0] tuning regsbase addr 0x218.
[ 12.557011] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 12.557024] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 12.557062] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 12.557102] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-5, data.error:-115
[ 12.557686] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-124 (12 len)
[ 12.557697] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 158-282 (12 len)
[ 12.557712] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-124 (12 len)
[ 12.557721] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 68
[ 12.557774] need_retune:1,brq->retune_retry_done:0.
[ 12.557782] mmcblk0: retrying because a re-tune was needed
[ 12.558131] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 12.558139] [mmc0] Data transmission error, need to try retuning 1.
[ 12.558149] [mmc0] Data transmission error !!! MINTSTS: [0x00008008]
[ 12.558156] [mmc0] Data transmission error, need to try retuning 1.
[ 12.558563] [mmc0] tuning regsbase addr 0x218.
[ 12.559373] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 12.559383] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 12.559413] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 12.559450] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-5, data.error:-115
[ 12.559978] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-124 (12 len)
[ 12.559989] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 158-282 (12 len)
[ 12.559998] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-124 (12 len)
[ 12.560008] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 68
[ 12.560040] need_retune:1,brq->retune_retry_done:1.
[ 12.560049] mmcblk0: error -110 transferring data, sector 335872, nr 256, cmd response 0x900, card status 0xd00
[ 12.560578] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 12.560587] [mmc0] Data transmission error, need to try retuning 1.
[ 12.560598] [mmc0] Data transmission error !!! MINTSTS: [0x00008008]
[ 12.560604] [mmc0] Data transmission error, need to try retuning 1.
[ 12.561014] [mmc0] tuning regsbase addr 0x218.
[ 12.561970] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 12.561979] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 12.562006] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 12.562071] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-5, data.error:-115
[ 12.562567] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-124 (12 len)
[ 12.562576] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 158-282 (12 len)
[ 12.562585] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-124 (12 len)
[ 12.562593] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 68
[ 12.562627] need_retune:1,brq->retune_retry_done:0.
[ 12.562633] mmcblk0: retrying because a re-tune was needed
[ 12.562968] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 12.562977] [mmc0] Data transmission error, need to try retuning 1.
[ 12.562986] [mmc0] Data transmission error !!! MINTSTS: [0x00008008]
[ 12.562992] [mmc0] Data transmission error, need to try retuning 1.
[ 12.563397] [mmc0] tuning regsbase addr 0x218.
[ 12.564154] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 12.564161] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 12.564186] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 12.564221] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-5, data.error:-115
[ 12.564743] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-124 (12 len)
[ 12.564752] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 158-282 (12 len)
[ 12.564761] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-124 (12 len)
[ 12.564770] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 68
[ 12.564798] need_retune:1,brq->retune_retry_done:1.
[ 12.564806] mmcblk0: error -110 transferring data, sector 336128, nr 256, cmd response 0x900, card status 0xd00
[ 12.565277] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 12.565284] [mmc0] Data transmission error, need to try retuning 1.
[ 12.565294] [mmc0] Data transmission error !!! MINTSTS: [0x00008008]
[ 12.565301] [mmc0] Data transmission error, need to try retuning 1.
[ 12.565708] [mmc0] tuning regsbase addr 0x218.
[ 12.566429] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 12.566437] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 12.566462] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 12.566494] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-5, data.error:-115
[ 12.567006] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-124 (12 len)
[ 12.567015] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 158-282 (12 len)
[ 12.567026] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-124 (12 len)
[ 12.567034] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 68
[ 12.567065] need_retune:1,brq->retune_retry_done:0.
[ 12.567071] mmcblk0: retrying because a re-tune was needed
[ 12.567402] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 12.567412] [mmc0] Data transmission error, need to try retuning 1.
[ 12.567420] [mmc0] Data transmission error !!! MINTSTS: [0x00008008]
[ 12.567426] [mmc0] Data transmission error, need to try retuning 1.
[ 12.567827] [mmc0] tuning regsbase addr 0x218.
[ 12.568574] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 12.568582] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 12.568609] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 12.568667] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-5, data.error:-115
[ 12.569206] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-124 (12 len)
[ 12.569215] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 158-282 (12 len)
[ 12.569225] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-124 (12 len)
[ 12.569233] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 68
[ 12.569262] need_retune:1,brq->retune_retry_done:1.
[ 12.569272] mmcblk0: error -110 transferring data, sector 336384, nr 256, cmd response 0x900, card status 0xd00
[ 12.569712] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 12.569720] [mmc0] Data transmission error, need to try retuning 1.
[ 12.569728] [mmc0] Data transmission error !!! MINTSTS: [0x00008008]
[ 12.569735] [mmc0] Data transmission error, need to try retuning 1.
[ 12.570142] [mmc0] tuning regsbase addr 0x218.
[ 12.570888] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 12.570895] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
Log-20190121_164930.rar (46.9 KB)
遇到了同样的问题,我也是换成了RK808电源IC,也是升级以后反复进入recovery模式,反复重启,楼主后来解决了吗,希望能分享一下解决办法!!!
