rk3399 ubuntu 如何添加 GPU 相关的库
这里用了隔壁帖子给的链接下面的库 https://github.com/FireflyTeam/rk-rootfs-build/tree/master/packages/arm64 但是添加的时候出错了
里面有两个包 一个是libmali-rk-midgard-t86x-r14p0_1.6-1_arm64.deb 另一个是libmali-rk-dev_1.6-1_arm64.deb 后面那个依赖于rockchip-mali-midgard14 (= 1.6-1) 说这个没安装
dpkg: dependency problems prevent configuration of rockchip-mali-midgard-dev:
rockchip-mali-midgard-dev depends on rockchip-mali-midgard14 (= 1.6-1); however:
Package rockchip-mali-midgard14 is not installed.
apt-get install 也不行
Package rockchip-mali-midgard14 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
前面那个包加的时候报错了
dpkg: error processing archive libmali-rk-midgard-t86x-r14p0_1.6-1_arm64.deb (–install):
trying to overwrite ‘/usr/lib/aarch64-linux-gnu/libEGL.so’, which is also in package libmali-rk-dev:arm64 1.5-4
有大佬知道咋搞吗
放在同一个文件夹中,然后执行dpkg -i ./*.deb,需要一起安装才可以的
大哥 按照你的方法 好像还是失败了 和前面的报错一样{:4_101:}
不行啊老哥
apt remove libmali-rk-dev:arm64
