刷sd固件Android8.1*181016.img后HDMI没有输出?
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000rsion 4.4.126 (zouxf@tchip14) (gled
[    0.000000] Reserved memory: failed to reserve memory for node 'stb-devinfo@B
[    0.000000] cma: Reserved 16 M[    0.000000] psci: probing for conduit metho.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] ps[    0.000000] PERCPU: Embedded t 1 zonelists in Zone order, m)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 byte)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0xf6ea9000-0xf6ee9000] (0MB) mapped at [fff]
[    0.000000] Memory: 3918676K/4030464K available (10878K kernel code, 1716K r)
[    0.000000]      ffbdc3e00000   (    61 MB actual)
[    0.000000]     fixed   : 0000 - 0xffffffc0f8000000   (  36 MB)
[    0.000000] SLUB: HWaler=0-3, MinObjects=0, CPUs=6, No_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] ITS: /interrupt-controller@f[    0.000000] ITS: allocated 65536 s
[    0.000000] CPU0: found redistributor 0 region 0:0x0000000
                                                             [    0.000000] GICk
[    0.000000] rockchip_clk_r[    0.000000] rockchip_cpuclk_pre_rate_change: li1
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffff[    0.001893] Calibr)
[    0.004872] Moureezer
[    0.008164] sched-ene-energy-costs installed from DT
[    0.008728] CPU0: update cpu[    0.026031] PCI/MSI: /interrupt-controller@fed
[    0.027272] Platform MSI: /interrupt-controller@fee00000[    0.039428] Detec1
[    0.039460] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.039500] CPU1: using LPI pending tab000fef40000
[    0.049462] CPU2 processor [410fd034]
[    0.059441] Detected VIPT I-cache on C [410fd034]
[    0.069487] Detected PIPT I-cache on CPU4
     [    0.069600] CPU4: Booted sec processor [410fd082]
[    0.07using LPI pending table @0x00000terface
[    0.093241] CPU: All CPU(s) started at EL2
[    0.0  0.096008] devtmpfs: initialized
[    0.115683] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[    0.116661] f[    0.118008] pinctrl core: ini] Failed to find legacy iommu ds
[    0.120844] NET: Registered protocol family 16
[    0_pwr:     0 max_pwr:   222
[    0.123448] schedtune: CPU[1]            min_pwr:     0 max_pwr: .125990] sc4
[    0.127926] schedtune: uchedtune: max_pwr/2^2: 1078 => n_pwr:   255
[    0.130820] sches
[    0.140854] cpuidle: using governor ladder
[    0.150858] cpuidle: using governor menu
[    0.151253] Registered FIQ tty driver
[    0.151957] vdso: 2 pages (1 code @ ff152701] hw-breakpoint: found 6 bcations
[    0.175582] console [pstore-1] enabled
[    0.176184] pstore: Registered ramoops as persistent store backend
[    0.176789][    0.179381] fiq debugger fiq IQ0] enabled
   0.180037] console [ttyFIQ0] enabled
[    0.180[    0.180728] bootconsole [uartiq debugger ttyFIQ0
[    0.218924] iommu: Adding device ff650000.vpu_service to group 0
[    0.219001] iommu: Adding device ff660000.rkvdec to group 1
[    0.219078] iommu: Adding device ff670000.iep to group 2
[    0.219170] iommu: Adding device ff8f0000.vop to group 3
[    0.219240] iommu: Adding device ff900000.vommu: can't get aclk
[    0.220rface: v0.10
[    0.221644] Linnterface: v2.00
[    0.221814] river Initialized.
[    0.22406 socket layer initialized
[    .224943] rockchip-cpuinfo cpuinf[    0.267361] thermal thermal_zone1: powed
[    0.267600] NET: Registered protod (established 32768 bind 32768)
[    0.268544] UDP hash table 68590] UDP-Lite hash table entri[    0.336871] FrK
[    0.337425] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 count)
[    0.340444] audit: type=2000 au[    0.345665] VFS: Disk quotas dquot_6.6.0
[    0.345789] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.346816] Registering sdcardfs [    0.348479]
[    0.348479] vice "opteearmtz00" (id=0)
[    0.349102] TEE Core: Register th[    0.353004] Block layer SCSI generic (bs.
[    0.358173] IEP Power ON
[    0.358343] IEP Power OFF
[    0.358418] IEP Driver loaded sucec ff650000.vpu_service: allocatm
[    0.359244] rk-vcodec ff65ff660000.rkvdec: probe device
[7] rk-vcodec ff660000.rkvdec: vpodec ff660000.rkvdec: allocator oller:        2
[    0.363979  0.367554] ff180000.serial: ttyf180000 (irq = 38, base_baud = 1rl0
[    0.388888] brd: module loaded
[    0.397247] loop: module loaded
[    0.397811] zram: Added device: zram0
[    0.398670] SCSI Media Changer driver v0.25
[    0.399524] rockchip-spi ff1d0000.spi: Failed to request TX DMf1d0000.spi: ne
[    0.400088] m25p80 spi0.0Max Krasnyansky <maxk@qualcomm.com>
[    0.402187] rk_gmac-dwmat clock clk_mac_speed
[    0.40[    0.407433] rk_gmac-dwmac fe3ormal descriptors
[    0.407585hecksum Offload Engine supported[    0.474730] libphy: stmmac: prod
[    0.474768] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[    0.474777] eth%d: PHY ID 001cc915 at 1 IRQ d protocol family 24
[    0.475sity of California.
[    0.47603] Rockchip WiFi SYS interface (egasus
[    0.476261] usbcore: d new interface driver rtl8150
[    0.476301] usbcore: register6509] usbcore: registered new in driver cdc_ethr
[    0.476548] usbcore: registered new interf0] usbcore: registered new inter00t
[    0.477246] usbcore: regisace driver cx82310_eth
[    0.4e driver cdc_mbim
[    0.478558  0.481007] ohci_hcd: USB 1.1 'Oe driver usblp
[    0.482012] ue: registered new interface drivinterface driver uas
[    0.482 new interface driver ums_eneub60
[    0.482347] usbcore: registered new interface driver ums-j: registered new i2
[    0.483669] usbr hanwang
[    0.483933] usbcorered new interface driver kbtab
[    0.484410] .. rk pwm remotelave:mma7660,id=18
[    0.48512sensor_register_slave:lsm303d,id230,id=23
[    0.485145] [Gsens5231] sensor_register_slave:akm8963,id=31
[    0.485244] sensor18,id=54
 0 probe success with role ROLE_ry_role ROLE_MODE_NONE
[    0.43x-i2c ff3d0000.i2c: Initializedcc5v0_sys
[    0.500847] rk808 ip id: 0x0
[    0.504130] rk808-regulator rk808-regulator: thersys
[    0.506335] LDO_REG1: supplied by vcc3v3_sys
[    0.507 LDO_REG5: supplied by vcc3v3_sys
[    0.511363] LDO_REG6: supp 0-001b: Can not read property pmic,stby-gpio
[    0.518794] rked RK3xxx I2C bus at ffffff800989a000
[    0.520922] fusb302 7-ODE_DRP, try_role ROLE_MODE_NONE
                                                         [    0.525359] mp8859 0
[    0.525699] mp8859 7-006initialized
[    0.526693] IR Srotocol handler initialized
[  vcvideo
[    0.526934] USB Videriver (1.1.1)
[    0.526950] Cagister: Expected proper parent d table: code=1023, temperature7
[    0.534855] deviceoth: HCI UART protocol LL registd
[    0.535446] rtk_btusb: RTK35453] rtk_btusb: Realtek Blueto[    0.558954] cpu)
[    0.559558] cpu cpu4: cpu_leakage=36
[    0.559614] cpu cpu4: cpu_leakage=36
[    0.572151] cpu cpu4: temp=50000, pvtm=156751 (156436 + 315)
[    0.576944] sdhci: Secure Digital Host Controller Interface driver
[    0.577035] sdhci: Copyright(c) Pierre Ossman
[    0.577241] Synopsys Designware Multrockchip fe320000.dwmmc: Version 270a
[    0.579221] dwmmc_rockchip fe320000.dwmmc: DW MMC cont3000000 done
[    0.580587] roc[    0.592244] mmc_host mmc0: Bus speed (slot 0) = 400000Hz ()
[    0.606591] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[    0.608969] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.611041] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[    0.611078] sdhci-arasa[    0.638905] mmc1: SDHCI controller on fe330000.sdhA
[    0.642322] hidraw: raw HID events driver (C) Jiri Kosina
[    0.645014] usbcore: registered new interface driver usbhid
[    0.645091] usbhid: USB HID c[    0.647589] rockchip-dmc dmc:[    0.650170] r
[    0.651643] rkna05-08
[    0.652261] usbcore: registered new interface driver s[    0.656915] u32 clar
[    0.656935]     Actions configured
[    0.656970] Netfilter ms via NETLINK v0.30.
[    0.657026] nf_conntrack version 0.5.0 ] arp_tables: (C) 2002 David S. ] Inik
[    0.660153] NET: Registered.662718] sit: IPv6 over IPv4 tuner
[    0.663392] NET: Registertic filtering via arp/ip/ip6tables has been depreca1
[    0.665528] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    0.6p_ppp: PPPoL2TP kernel driver, V2.0
[    0.665651] [WLAN_RFKILL: Enter rfkill_wlan_init
[    0ts version 1
[    0.669932] rocchip ion idev is NULL
[    0.66] rga2 ff680000.rga: rga ion cli[    0.676227] rockchip-drm display-suq
[    0.676625] rockchip-vo   0.677323] rockchip-vop ff8f00vop: unable to requesM
system: bound ff940000.hdmi (opsr support for vblank timestamp query.
[    0.684842] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_w[    0.762678] mp8859 y
[    0.762707] mp8859 7-0066: mp8859 get ufp 1 dp 0
[    0.763810] mp8859 7-0066: set mp8859 out 12v ok
[    0.774558] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000e
[    0.774848] rockchip-iodomain ff770000.[    0.799377] mmc_host mmc0: Bus spe)
[    0.889514] fusb302 7-0022: PD connected as UFP, fetching 5V
[    0.890616] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] N[    0.926387] ry
[    0.926605] rockchip-drm display-subsystem: failed to show loader logo
[  [    0.988863] mp8859 7-0066: mp8859 get notify
[    0.988905] mp8859 7-0066: mp8859 get ufp 1 dp 1
[    0.990060] mp8859 7-0066: set mp8859 out 12v ok
[    1.075558] dwmmc_rockchip fe320000.dwmmc: Successfully tuned phase to 175
[    1.075649] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[    t: 0x000400000 -- 0x000800000 (4 MB)
[    1.078829]      trust:nel: 0x002000000 -- 0x004000000    1.079648]       bo)
[    1.080335]   security: 0x011000000 -- 0x011400000 (4 MB (512 MB)
[    1.081733]       p: 0x112800000 -- 0x112880000 (0
[    1.211403] rockchip-drm display-subsystem: fb0:  frame buffer device
[    1.224845] vendor storage:20160801 ret = 0
[    1.231720] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[    1.232445] xhci-hcd xhci-hcd.11.auto: new USB bus registered 0x110 quirks 00
 1.234773] usb usb1: SerialNumbegistered, assigned bus number 2
[    1.238643] usb usb2: We don] usb usb2: New USB device found1.241482] hub 2-1
[    1.270738] xhci-hcd xhci-hcd.11.auto: Host not halted after 16000 microseco.
[    1.270786] xhci-hcd xhci-hcd.11.auto: Host controller not halted, abort-hcd1
        d
[    1.280241] xhci-hcd xhc649] xhci-hcd xhci-hcd.12.auto: new USB bus register2
[   sb usb1: Manufacturer: Linux 4.4.126 xhci-hcd
[    1.281626] us2: We don't know the algorithms for LPM for this host, disablid
[    1.285699] usb usb2: SelNumber: xhci-hcd.12.auto
[    87070] hub 2-0:1.0: 1 port detecxhci-hcd xhci-hcd.12.auto: USB bregistered
[    1.294057] ehci-[    1.305645] ehci-platform fe380000.usb: USB 2.0 started,0
 USB bus registered, assigned bu[    1.322346] ehci-platform fe3c0000.usb: USB 0
[    1.322652] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.322690] usb usb2: New USB device str USB hub found
[    1.324181] hub 2-0:1.0: 1 port detected
[   bus number 3
[    1.326781] ohci-platform fe3a0000.usb: irq 28[    1.383524] usb usb3: New U1
[    1.383733] usbUSB device strings: Mfr=3, Produ, SerialNumber=1
[    1.383954][    1.388391] ohci-platform fe3e0000.usb: Generic Platform OHCI r
[    1.389667] ohci-platform fe3e0000.usb: new USB 0
[    1.446807] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    1.449782] hub 4-0:1.0: 1 port detectedings: Mfr=3, Product=2, SerialNumber1
[    1.452655] rockchip-dmc dmc:ailed to get vop bandwidth to dm[    1.454696] D
[    1.456539] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC[    1.464517] rk)
[    1.465933] It doesn't contain Rogue gpu
[    1.497184] ret 1024
[    1.498373] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linuk
[    1.503165] usb-ext-charge usb-charge: interrupt haprge: probe success
[    1.50513ice list:
[    1.505205]   #0: rk-hdmi-dp-sound
[    1.506167][    1.513598] init: init first stage started!
[    1.514298] init: Using Android DT directory /proc/device-tree/firmware/andr8
[    1.61stem,target=/system,type=ext4)=0[    1.625219] EXT4-fs (mmcblk0p13): m8
[    1.625326] init: [libfs_mgr]__mount([    1.628782] usb 2-1: new highm
[    1.745132] audit: type=1403 audit(1358499004.776:2): policy loaded auid=4295
[    1.745614] selinux: SELinux: Loaded policy from /vendoy
[    1.745614]
[    1.753012] selinux: SELinux: Loaded file_contexts
[    1.753012]
[    1.754359] random: init: uninitialized urandom read (40 bytes read, 62 bits)
[    1.755702] inumber=0
[    1.756162] usb 2-1: Product: USB 2.0 Hub [MTT]
[  [    1.763051] init: Using Android DT directory /proc/device-tree/firmware/a/
[    1.763640] init: Set boot.mode to sd
[[    1.766509] selinux: SELinux: Loaded file_contexts
[    1.766509]
[    1.767212] selinux: [    1.773085] init: waitid failed: No child processes
[    1.776205] init: Couldn't load property file: Unable to open '/odm/default.t
[    1.77882' to import list
[    1.779482]: Added 'init.rk30board.bootmode.sd.rc' to import list
[    1.7import list
[    1.783882] initdded 'init.car.rc' to import list
[    1.784104] init: Added 'iist
[    1.785623] init: Added tory
[    1.786365] init: /initrc: 3: Could not import file '/id not import file 'inb
[    1.786.rc': No such file or directory
[    1.786970] init: /init.rc: : /init.rc: 8: Could not import ile 'init.optee.y
[    1.791261] i   1.793059] init: Parsing file /system/etc/init/android.hidl.a.
[    ootanim.rc...
[    1.796907] in.
35] init: Parsing file /system/enit/logcatd.rc...nager.rc...
[    1.803243] init: Parsing file /system/etcit/mediaextractor.rc...
[    1.em/etc/init/perfprofd.rc...
[    1.808510] init: Parsing file /tem/etc/init/thermalservice.rc..   1.811086]d
[    1.81775init: Parsing file /vendor/etc/iardware.graphics.allocator@2.0-serv.
[    1.819866] ini.hardware.graphics.composer@2.1-service.rc...
[    1.820392] init: Parsing file /vendor/etc/init/android.hardware.keymaster@3.
[    1.822445] inisors@1.0-service.rc...
[    1.823478] init: Parsing file /vendo Parsing file /odm/etc/init...
  1.825605] init: Unable to openport. Nested cgroups may change r in the future.
[    1.830181]1 on the root
[    1.831123] in
[    1.836882] ueventd: Unable to open '/vendor/ueventd.rc': Nntd.rk30board.rc:'
[    1.838517] ueventd:  1.838631] ueventd: /ueventd.rk30board.rc: 60: invalid s
[    1.962764]
[    2.022146] usb 2-1.2: new full-speed USB device number 3 using ehci-platform
[    2.037243] ueventd: Coldboot took 0.189 seconds
[    2.039306] init: Command 'wait_for_coldboot_done' action=wait_for_coldboot_.
[    2.039_random not found
[    2.039551] init: processing action (set_mmap_rnd_bits) from (<Builtin Actio)
[    2.040297] init: processing action (set_kptr_restrict) fut dev ff420030.pwmt
o open '/proc/cpu/alignment': No or directory
[    2.062234] Registered swp emulation handler
[    2.062508] init: Unable to open '/sys/class/leds/vibrator/trigger': No suchd
        d
[    2.06667084] init: processing action (fs) from (init.rk30board.bootmodesupen
[    2.091450] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode.t
[    2.091734] init: [libfs_mgr]check_fs(): mount(/dev/block/platform/[    2.109
[    2.109338] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumbed
[    2.117631] input: Logitech USB Gaming Mouse as /devices/platform/fe3c0000.u2
[    2.123358] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/platfo)
[    2.169212] hid-generic 0003:046D:C049.0001: input,hidraw0: USB HID v1.11 Mo1
[    2.245664] random: e2fsck: uninitialized urandom read (40 bytes read, 75 bi)
[    2.279474] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[    2.279474]
[    2.279628] e2fsck: oem: clean, 15/32768 files, 4209/131072 blocks
[    2.279628]
[    2.285000] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode.c
[    2.285316] init: [libfs_mgr]__mount(source=/dev/block[    2.287157] init: [)
[    2.379771] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[    2.379771]
[    2.379950] e2fsck: /dev/block/platform/fe320000.dwmmc/by-name/cache: recovey
[    2.380153]
[    2.3e2fsck: Pass 4: Checking referens 5: Checking group summary info[    2.s
[    2.[    2.392662] EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_[    2.4e
[    2.405306] EXT4-fs (mmcblk0p12): mounted filesystem with ordered datplatford
[    2.424485] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/platfo)
[    2.444404] audit: type=1400 audit(1358499005.476:3): avc:  denied  { read }1
[    2.445040] audit: tyontext=u:object_r:metadata_block:s0 tclass=blk_file per)
[    2.512278]
[    2.512508] e2fsck: Pass 1: Checking inodes, blocks, and2.513160] e2fsck: Pas
[    2.513160]
[    2.513658]
[    2.522399] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode.d
[    2.523434] init: [libfs_mgr]__mount(source=/dev/block/platform/fe320000.dwm)
[    2.535774] phy phy-ff770000.syscon:usb2-phy@e450.2: charger = USB_FLOATING_R
[    2.549049] random: fsck.f2fs: uninitialized urandom read (40 bytes read, 88)
[    2.557747] fsck.f2fs: Info: Fix the reported corruption.
[    2.557747]
[    2.557885] fsck.f2fs: Info: Segments per section = 1
[    2.557885]
[    2lid F2FS superblock at 0x0
[       2.558144] fsck.f2fs:    Can't 2FS-fs (mmcblk0p16): Magic Misman 2th supk
[    2.561198] F2FS-fs (mmcblk0p16): Magic Mismatch, valid(0xf2f52010) - read(1a
[    2.582067] fsck.f2fs: Info: Fix the reported corruption.
[    2.582067]
[    2.582367] fsck.f2fs: Info: Segments per sect583020]
[    2.583244] fsck.f2 valid(0xf2f52010) - read(0xab0e   2.587170] F2FS-fs (mmcs
[    2.5925..
[    2.592691] init: Unable to open '/odm/etc/init': No such882] init: Command )
[    2.596784] init: Couldn't load proper[    2.599866] init: property_set("ro.t
[tory
[    2.602671] init: /recovery not specified in fstab
[    2.606277] init: starting service 'logd'...
[    2.609384] init: Created socket '/dev/socket/logd', mode 666, user 1036, gr6
[    2.609909] init: Created socket '/dev/socket/logdr', mode 666, userit: Open.
[    2.620342] init: starting service 'vndservicemanager'...
[    2.625292] selinux: SELinux: Skipping restorecon_recursive(/cache)
[    2.625292]
[    2.635290] init: processing action (post-fs) from (/init.rk30board.rc:10)
[    2.635610] selinux: SELinux: Skipping restorecon_recursive(/metadata)
[    2[    2.644872] init: insmod: open("/system/lib/modules/ump.ko") failed: Ny
[    2.645179] init: insmod: [    2.715590] logd.auditd: start
[    2.715696] logd.klogd: 2713607623
[    2.861990] binder: 212:212 ioctl 620a 0 returned -22
[    3.039790] mali ff9a0000.gpu: gpu_leakage=23
[    3.052740] mali ff9a0000.gpu: temp=50555, pvtm=121051 (120943 + 108)
[    3.055974] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[    3.056217] mali ff9a0000.gpu: Protected mode not available
[    3.057635] mali ffu/arm/midgard/backend/gpu/mali_k[    3.061846] init: Comm2
[    3.108175] mkswap: Swapspace size: 1969104k, UUID=541b2a81-7fc5-4c23-809a-92
[    3.110245] Adding 1969104k swap 61] init: processing action (possing action)
[    3.117426] init: processing action (late-fs) from (/init.rc:363)
[    3.121030] init: starting service 'keymaster-3-0'...
[    3.122310] init: processing action) from (/init.rc:371)
[    3.12[    3.125379] init: Created socket '/dev/socket/vold', mode 660, user9
[    3.12627445] init: Unable to open '/daa/misc/recovery/ro.build.fingerpinit:.
[    3.148497] init: SVC_EXEC pid 228 (uid 0 gid 0+0 context default) started; .
[    3.299306] init: Service 'exec 1 (/system/bin/vdc --wait cryptfs init_user0.
[    3.325621] init: SVC_EXEC pid 232 (uid 1000 gid 1000+0 context default) sta.
[    3.330802] init: Service 'exec 2 (/system/bin/tzdatacheck /system/usr/share)
[    3.338637] tmpfs: Bad mount option background_gc
[    3.339350] init: pstem/etc/init/logtagd.rc:4)
[    3.340708] init: processing action (post-fs-data) from (/vendore 'logd-rein.
[    3.34211it: processing action (load_persist_props_action) from (/system/[  )
[    3.372416] init: Unable to open '/proc/sys/vm/min_free_order_shift': No sucy
[    3.376836] init: starting service 'hidl_memory'...
[    3.378016] init: starting service 'audio-hal-2-0'...
[    3.379210] logd.daemon: reinit
[    3.379636] init: starting service 'bluetooth-1-0'...
[    3.381059] i[    3.382687] init: couldn't write 237 to /dev/cpuset/camera-d.
t: starting service 'drm-hal-1-0[    3.391778] init: starting service 'gralloc-.
[    3.396360] init: starting service 'hwcomposer-2-1'...
[    3.400602] init: starting service 'light-hal-2-0'...
[    3.403502] init: starting service 'neuralnetworks_hal_service_armnn'...
[    3.405351] init: starting service 'power-hal-1-0'...
[    3.407291] init: starting service 'sensors-hal-1-0'..[    3.409125] init: s.
[    3.410683] init: Service 'logd-reinit' (pid 233) exited with sta93] init: cy
[    3.41351urfaceflinger'...
[    3.416567ctory
[    3.416972] init: Fail to bind socket 'pdx/system/vr/dfrom (/init.rk30board.)
[    3.420750] init: Unable to ope[    3.501665] selinux: SELinux:  Could not s.
[    3.501665]
[    3.501948] init: Command 'restorecon_recursive [    3.505541] init: processo
[    3.508244] type=1400 audit(1358499006.540:7): avc: denied 3 scontext=u:r:inf
[   0 audit(1358499006.540:7): avc: denied { getattr } for pid=1 com path="/vend
[    3.541313] type=1400 audit(1358499006.543:9): avc: denied { read open } fors
[    3.549879] using random host ethernet address
[    3.550045] init: Unable to open '/config/usb_gadget/g1[    3.554049] init: )
[    3.562816] init: processing action (boot) from (init.rk3399.rc:13)
[    3.570150] init: processing action (boot) from (/system/etc/init/bootstat.r)
[    3.570352] init: processing action (bog action (ro.debuggable=1) from (/ini)
[    3.573429] i[    3.575241] init: processing action (ro.boot.noril=true) fro)
[    3.575551] initfs=1) from (init.rk30board.usb.rc:43)
[    3.577192] init: setp77447] init: starting service 'a8975] type=1400 audit(0
[    3.579094] init:d { read } for pid=1 comm="init" name="ttyFIQ0" dev="tmpfs"0
[    3.579789] init: starting service 'exec633 scontext=u:r:init:s0 tcontext=u:0
[    3.583052] type=1400 audit(13v="tmpfs" ino=10633 scontext=u:r:init:s0 tconts
[    3.612452] init: Service 'exec 3 (/system/bin/vdc --wait cryptfs mountdefaus
[    3.613623] healthd: BatteryCurrentNowPath not f BatteryCycleCountPath not fd
ROC_RK3399_PC:/ $ [    3.866362] read descriptors
[    3.866386] read strings
[    4.795941] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[    4.796186] E:camsys_i2c_write(84): i2c wri[    4.810778] rockchip-pinctrl pp
[    4.8-11) from group cif-clkout  on d[    4.822692] E:camsys_i2c_write(84): 6
[    4.822997] E:camsys_i2c_write(84): i2c wri[    4.833413] rockchip-pinctrl pp
[    4.8ff910000.isp: Error applying setting, reverse things back
[    [    4.845509] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,er6
[    4.845917] E:camsys_i2c_write(84): i2c wri[    4.853787] init: starting ser.
[    4.856093] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 6
[    4.878630] E:camsys_i2c_write(84): i2c wri[    4.889456] rockchip-pinctrl pp
[    4.810000.isp: Error applying settin[    4.900204] E:camsys_i2c_write(84): 6
[    4.900375] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = [p
[    4.9etting, reverse things back
[   4.911165] E:camsys_mrv_iomux_cb[    4.921949] E:camsys_i2c_write(84): i2c w6
[    4.922130] E:camsys_i2c_write(84): i2c wri[    5.110753] init: Unable to wry
[    [    5.144853] fsck.f2fs: Info: Fix the reported corruption.
[    5.144853]
[    5.144893] fsck.f2fs: Info: Segments per sect12
[    5.144920]
[    5.1449    5.144946]
[    5.144954] fsck.f2fs: Info: FSCK version
[ on 6.3.1 20170404 (Linaro GCC 6.05) ) #22 SMP PREEMPT Tue Oct 1615:42:32 CST "
[    5.14500 salt = 000000000000000000000000[    5.310094] init: processing act)
[    5.310166] init: processing [    5.365095] init: starting service 'exec 4 (.
[    5.366133] init: SVC_EXEC pid[    5.384756] init: Service 'exec 4 (/system/s
[    5.384930] selinux: SEted; waiting...
[    5.394315] init: Service 'exec 5 (/system/bin/tzdatacheck /system/usr/share)
[    5.401509] init: Unable to find GID for 'system': getpwnam failed: No su[  )
[    5.408617] init: processing action (post-fs-data) from (init.rk3399.rc:37)
[    5.408827] i[    5.419569] init: processing action (init.svc.bootanim=runni)
[    5.419973 pid 339 (uid 1000 gid 1007+0 cotext default) started; waiting..[ )
[    5.435449] init: processing action (vold.decrypt=trigger_load_persist_propst
[    5.501539] init: Command 'load_persist_props' actieinit'...
[    5.503211] init: property_set("ro.boottime.logd-ry': No such file or directy
[504354] init: cannot find '/system/bin/bplus_helper', disabling 3] init: canno.
[    5.507[    5.512385] init: Created soc5.513861] init: couldn't write 3[    .
[    5.524371] init: starting service 'keystore'...
[    5.527915] init: starting service 'mediadrm'...
[    5.530087] init: starting service 'mediaextractor'...
[    5.532334] init: starting service 'mediametrics'...
[    5.534581] init: starting se[    5.536855] init: starting service 'netd'...
[    5.538983] init: Created socket '/dev/socket/netd', mode 660, user 0, group0
[    5.540819] init: Failed to open file [    5.545756] init: starting service .
[    5.547844] init: Service 'logd-reinit[    5.549063] init: starting service .
[    5.572217] init: cannot find '/system/xbin/perfprofd', disabling 'perfprofdy
[    5.572614] init 1000, group 1000
[    5.574725] init: processing action (persi00, group 1000
[    5.575691] ieated socket '/dev/socket/tombst00
[    5.576988] init: process[    5.588903] init: processing action (sys.usb.con)
[    5.589369] init: processing action (sys.uys.usb.ffs.ready=1) from (/init.us)
[    5.5918(/init.usb.configfs.rc:18)
[    5.592057] init: processing action (sys.usb.config=adb && sys.usb.configfs=)
[    5.642294] init: Sending signal 9 to service 'adbd' (pid 257) processffc0ed8
[    5.643471] android_work: did not send uevent ([    5.647754] init: Successf9
[    5.653510] init: Service 'drmservice' (pid 356) exited with [    6.001713] f
[: avc: denied { execute_no_trans[    6.033443] audit: audit_lost=1 audit_rate_d
[    6.088323] init: Untracked pid 423 exited with status 0
[    6.139085] init: Untracked pid 431 exited with status 0
[    8.578124] init: starting service 'adbd'...
[    8.579291] init: property_set("ro.boottime.adbd", "8576456379") failed: prot
[    8.581272] init: Created socket '/dev/soc[    8.597614] read descriptors
[    8.597727] read strings
[    8.598484] init: processing action (sys.usb.config=adb && sys.usb.configfs=1
[    8.872557] init: Untracked pid 434 killed by signal 1
[    9.830675] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[    9.965614] capability: warning: `main' uses 32-bit capabilities (legacy sup)
[   13.305035] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[   13.880845] init: processing action (sys.sysctl.extra_free_kbytes=*) from (/)
[   14.614156] acc_open
[   14.614186] acc_release
[   14.875099] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: mac address: 04
[   14.875120] eth0: device MAC address 0e:45:29:c2:c2:b4
[   15.055761] type=1400 audit(1358499009.053:28): avc: denied { execute_no_tra0
[   15.079465] sdcardfs: dev_name -> /data/media
[   15.079473] sdcardfs: options -> fsuid 15.080620] sdcardfs : options -g:1
[   15.080627] sdcardfs : options - gid:9997
[   15.080634[   15.125786] init: starting service 'webview_zygote32'...
[   15.128120] init: Created socket '/dev/socket/webview_zygote', m[   17.427330
[   17.562538] init: processing action (sys.usb.config=none && sys.usb.configfs)
[   17.564645] init: processing action (sys.us-gadget gadget: unbind function Fs
[   17.573487] init: Service 'adbd' (pid 462) killed by signal 9
[   17.576654] init: processing action (sys.boot_completed=1) fr.576816] init: y
[   17.585320] init: startingrom (init.rk3399.rc:1)
[   17.587704] init: processing action (tcomplete=1) from (/system/etc/ittr } fs
[   17.591752] type=1400 audit(1358499020.620:83): avc: deniedm="usb_mode_switce
        f
[   17scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tc[   17.61.
[   17.620425] type=1400 audit(1358499020.630:85): avc: denied { read } for pidf
[   17.620520] typ00 audit(1358499020.650:86): avccomm="usb_mode_switch" name="f
[   17.620984] type=1400 audit(13584990955 comm="usb_mode_switch" path=h.sh" def
[   17.623569dit(1358499020.653:88): avc: denied { getattr } for pid=959 comm=f
[   17.623608] type=1400 aud scontext=u:r:mode_switch:s0 tcotext=u:object_r:toof
[   17.623901] type=1400 audit(1358499020ath="/system/bin/toybox" dev="mmcblk0p.
[   17.640907] init[   17.654459] init: Service 'exec 9 (/system/bin/bootstat -s
[  [   17.670045] init: Service 'exec 10 (/system/bin/bootstat -l)' (pid 961) es
[sing action (sys.boot_completed=1 && sys.wifitracing.started=0) [   17.754453])
[   17.754641] init: processing .757913] init: processing action (sys.usb.confi)
[   17.759282] init: starting service 'adbd'...
[   17.762986] init: property_set("ro.boottime.adbd", "17757938635") failed: prt
[   17.767875] init: Created ket/adbd', mode 660, user 1000, group 1000
[   17.772643] read ors
[   17.772664] read strings
[   17.773813] init: processing action (sys.usb.config=adb && ady=1) from (/ini)
[   20.316272] type=1400 audit(1358499020.656:91): avc: denied { execute_no_traf
[   20.316822] type=1400 audit(135849tem_app:s0 tcontext=u:object_r:se=1400 audu
[  123.614359] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[  183.614390] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[  243.614335] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[  303.614343] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[  363.614377] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[  423.614338] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
显示器支持电视规格的分辨率吗,目前8.1并不支持1366x768等显示器分辨率
好的 改了hdmi2.0可以显示了,测试了hdmi1.4也可以显示;就是1.0无法用,谢谢!
