01-31 06:28:20.344 489 1702 E ActivityManager: getPackageFerformanceMode--ComponentInfo{com.android.settings/com.android.settings.Settings$SystemDashboardActivity}----com.android.settings
01-31 06:28:20.366 237 962 D AudioHardwareTiny: Now set mixer audio_mode is 0 for drm
01-31 06:28:20.368 237 962 W StreamHAL: Error from HAL stream in function get_presentation_position: Operation not permitted
01-31 06:28:20.417 1704 1704 D AndroidRuntime: Shutting down VM
01-31 06:28:20.417 1704 1704 E AndroidRuntime: FATAL EXCEPTION: main
01-31 06:28:20.417 1704 1704 E AndroidRuntime: Process: com.android.settings, PID: 1704
01-31 06:28:20.417 1704 1704 E AndroidRuntime: java.lang.RuntimeException: Unable to start activity ComponentInfo{com.android.settings/com.android.settings.Settings$SystemDashboardActivity}: java.lang.RuntimeException: Only one Looper may be created per thread
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2778)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2856)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.app.ActivityThread.-wrap11(Unknown Source:0)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1589)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:106)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.os.Looper.loop(Looper.java:164)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.app.ActivityThread.main(ActivityThread.java:6494)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at java.lang.reflect.Method.invoke(Native Method)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:438)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:807)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: Caused by: java.lang.RuntimeException: Only one Looper may be created per thread
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.os.Looper.prepare(Looper.java:95)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.os.Looper.prepare(Looper.java:90)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at com.android.settings.system.ConnectToPcPreferenceController.<init>(ConnectToPcPreferenceController.java:63)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at com.android.settings.system.SystemDashboardFragment.buildPreferenceControllers(SystemDashboardFragment.java:72)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at com.android.settings.system.SystemDashboardFragment.getPreferenceControllers(SystemDashboardFragment.java:67)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at com.android.settings.dashboard.DashboardFragment.onAttach(DashboardFragment.java:76)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.app.FragmentManagerImpl.moveToState(FragmentManager.java:1223)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.app.FragmentManagerImpl.addAddedFragments(FragmentManager.java:2407)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.app.FragmentManagerImpl.executeOpsTogether(FragmentManager.java:2186)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.app.FragmentManagerImpl.removeRedundantOperationsAndExecute(FragmentManager.java:2142)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.app.FragmentManagerImpl.execPendingActions(FragmentManager.java:2043)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.app.FragmentManagerImpl.executePendingTransactions(FragmentManager.java:799)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at com.android.settings.SettingsActivity.switchToFragment(SettingsActivity.java:737)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at com.android.settings.SettingsActivity.launchSettingFragment(SettingsActivity.java:424)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at com.android.settings.SettingsActivity.onCreate(SettingsActivity.java:322)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.app.Activity.performCreate(Activity.java:7036)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.app.Activity.performCreate(Activity.java:7027)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1214)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2731)
01-31 06:28:20.417 1704 1704 E AndroidRuntime: ... 9 more
01-31 06:28:20.420 489 1702 W ActivityManager: Force finishing activity com.android.settings/.Settings$SystemDashboardActivity
01-31 06:28:20.423 489 1702 W ActivityManager: Force finishing activity com.android.settings/.Settings
01-31 06:28:20.427 489 505 I ActivityManager: Showing crash dialog for package com.android.settings u0
u-boot:
make rk3399_defconfig
make ARCHV=aarch64 -j8
kernel:
make ARCH=arm64 firefly_defconfig
make -j8 ARCH=arm64 rk3399-roc-pc.img
Android:
source build/envsetup.sh
lunch ROC_RK3399_PC-userdebug
make installclean
make -j8
./mkimage.sh
package:
./FFTools/mkupdate/mkupdate.sh update
