自家主板,刷了rk3328代码,进不了。大牛进来看一下。
U-Boot 2017.02-RK3328-06 (Jan 31 2019 - 10:55:43)
CPU: rk3328
cpu version = 1
CPU’s clock information:
arm pll = 600000000HZ
general pll = 800000000HZ
ddr pll = 664000000HZ
codec pll = 594000000HZ
new pll = 594000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01000000
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 20
SdmmcInit = 2 0
storage init OK!
GetParam
remotectl v0.1
pwm freq=0x11b3dc
pwm_freq_nstime=0x35d
Load FDT from resource image.
no power key node
rk816_set_regulator_init vdd_arm init uV:1225000
pmic:rk805
can’t find dts node for pwm0
arm pll = 1200000000HZ
#Boot ver: 2019-01-31#2.43
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
can’t find dts node for deviceinfo
rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer -1x-1@-1–1
left = 65535, right = 65535, top = 65535, bottom = 65535, overscan = 65535
panel->left = 1000 , panel->right = 1000 ,panel->top = 1000, panel->bottom = 1000, panel->overscan = 1000
tve baseparamer -1x-1@-1–1
Hdmi Devices Not Exist.
can’t find dts node for rk312x-tve
can’t find dts node for rk322x-tve
SCREEN_TVOUT
rk3036_tve_init:use default config g_tve_pos = 1
no fuel gauge found
checkKey
vbus = 1
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x00e5ee48)
ramdisk @ 0x05bf0000 (0x0075fa70)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 000000000561d7f0 … OK
Add bank:0000000009400000, 0000000076c00000
[ 0.000000] [0: swapper: 0] Initializing cgroup subsys cpuset [ 0.000000] [0: swapper: 0] Initializing cgroup subsys cpu [ 0.000000] [0: swapper: 0] Initializing cgroup subsys cpuacct [ 0.000000] [0: swapper: 0] Linux version 3.10.104 (root@ubuntuandriod-virtual-machine) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Sat Jan 26 10:40:35 CST 2019 [ 0.000000] [0: swapper: 0] CPU: AArch64 Processor [410fd034] revision 4 [ 0.000000] [0: swapper: 0] Machine: rockchip,rk3328-firefly-mini [ 0.000000] [0: swapper: 0] rockchip_uboot_logo_setup: mem: 0x0000000002000000@0x000000007dc00000, offset:0x0000000001000000 [ 0.000000] [0: swapper: 0] hdmi init vic is 65536 [ 0.000000] [0: swapper: 0] cvbs init tve.format is 1 [ 0.000000] [0: swapper: 0] cvbs init tve.format is 1 [ 0.000000] [0: swapper: 0] cvbs init tve.format is 1 [ 0.000000] [0: swapper: 0] rockchip_uboot_mem_reserve: reserve 0x0000000002000000@0x000000007dc00000 for uboot logo [ 0.000000] [0: swapper: 0] rockchip_ion_reserve [ 0.000000] [0: swapper: 0] ion heap(cma): base(0) size(0) align(0) [ 0.000000] [0: swapper: 0] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] [0: swapper: 0] cma: CMA: reserved 16 MiB at 7cc00000 [ 0.000000] [0: swapper: 0] psci: probing for conduit method from DT. [ 0.000000] [0: swapper: 0] psci: PSCIv1.0 detected in firmware. [ 0.000000] [0: swapper: 0] psci: Using standard PSCI v0.2 function IDs [ 0.000000] [0: swapper: 0] PERCPU: Embedded 12 pages/cpu @ffffffc07fd33000 s18752 r8192 d22208 u49152 [ 0.000000] [0: swapper: 0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 512519 [ 0.000000] [0: swapper: 0] Kernel command line: earlyprintk=uart8250-32bit,0xff130000 console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00004000@0x00004000(trust),0x00002000@0x00008000(misc),0x00000800@0x0000A000(baseparamer),0x00007800@0x0000A800(resource),0x00010000@0x00012000(kernel),0x00010000@0x00022000(boot),0x00010000@0x00032000(recovery),0x00020000@0x00042000(backup),0x00040000@0x00062000(cache),0x00008000@0x000A2000(metadata),0x00002000@0x000AA000(kpanic),0x00300000@0x000AC000(system),-@0x003AC000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000:0x01000000 loader.timestamp=2019-01-31_10:55:43 hdmi.vic=65536 tve.format=1 SecureBootCheckOk=0 [ 0.000000] [0: swapper: 0] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] [0: swapper: 0] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] [0: swapper: 0] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.000000] [0: swapper: 0] Memory: 130MB 1900MB = 2030MB total [ 0.000000] [0: swapper: 0] Memory: 1973496k/1973496k available, 105224k reserved [ 0.000000] [0: swapper: 0] Virtual kernel memory layout: [ 0.000000] [0: swapper: 0] vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000 (245759 MB) [ 0.000000] [0: swapper: 0] vmemmap : 0xffffffbc00007000 - 0xffffffbc01c00000 ( 27 MB) [ 0.000000] [0: swapper: 0] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB) [ 0.000000] [0: swapper: 0] memory : 0xffffffc000000000 - 0xffffffc07fe00000 ( 2046 MB) [ 0.000000] [0: swapper: 0] .init : 0xffffffc000c9e000 - 0xffffffc000cff940 ( 391 kB) [ 0.000000] [0: swapper: 0] .text : 0xffffffc000080000 - 0xffffffc000c9da24 ( 12407 kB) [ 0.000000] [0: swapper: 0] .data : 0xffffffc000d00000 - 0xffffffc000edee48 ( 1916 kB) [ 0.000000] [0: swapper: 0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] [0: swapper/0: 0] Preemptible hierarchical RCU implementation. [ 0.000000] [0: swapper/0: 0] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] [0: swapper/0: 0] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] [0: swapper/0: 0] Architected cp15 timer(s) running at 24.00MHz (phys). [ 1.007421] [0: swapper/0: 0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 1.007441] [0: swapper/0: 0] pid_max: default: 32768 minimum: 301 [ 1.007542] [0: swapper/0: 0] Security Framework initialized [ 1.007566] [0: swapper/0: 0] SELinux: Initializing. [ 1.007658] [0: swapper/0: 0] Mount-cache hash table entries: 256 [ 1.008219] [0: swapper/0: 0] Initializing cgroup subsys debug [ 1.008237] [0: swapper/0: 0] Initializing cgroup subsys freezer [ 1.008669] [0: swapper/0: 1] /cpus/cpu@0: Missing clock-frequency property [ 1.008708] [0: swapper/0: 1] /cpus/cpu@1: Missing clock-frequency property [ 1.008743] [0: swapper/0: 1] /cpus/cpu@2: Missing clock-frequency property [ 1.008779] [0: swapper/0: 1] /cpus/cpu@3: Missing clock-frequency property [ 1.008796] [0: swapper/0: 1] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available [ 1.010117] [0: swapper/0: 1] last_log: 0x000000007a400000 map to 0xffffff8000006000 and copy to 0xffffff8000088000, size 0x80000 early 0x18d1 (version 3.1) [ 1.036422] [1: swapper/1: 0] CPU1: Booted secondary processor [ 1.039687] [2: swapper/2: 0] CPU2: Booted secondary processor [ 1.046253] [3: swapper/3: 0] CPU3: Booted secondary processor [ 1.046350] [0: swapper/0: 1] Brought up 4 CPUs [ 1.046379] [0: swapper/0: 1] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 1.047083] [0: swapper/0: 1] devtmpfs: initialized [ 1.051316] [0: swapper/0: 1] pinctrl core: initialized pinctrl subsystem [ 1.051608] [0: swapper/0: 1] regulator-dummy: no parameters [ 1.061078] [0: swapper/0: 1] NET: Registered protocol family 16 [ 1.061858] [0: swapper/0: 1] ion_snapshot: 0x7a6c8000 map to 0xffffff8000109000 and copy to 0xffffffc000fb2960 (version 0.1) [ 1.062280] [0: swapper/0: 1] Registered FIQ tty driver [ 1.062774] [0: swapper/0: 1] vdso: 2 pages (1 code, 1 data) at base ffffffc000d05000 [ 1.062802] [0: swapper/0: 1] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 1.064611] [0: swapper/0: 1] software IO TLB [mem 0x7a000000-0x7a400000] (4MB) mapped at [ffffffc079e00000-ffffffc07a1fffff] [ 1.065533] [0: swapper/0: 1] DMA: preallocated 256 KiB pool for atomic allocations [ 1.065556] [0: swapper/0: 1] rockchip sip version v2 [ 1.066860] [0: swapper/0: 1] rk3368_init_rockchip_pmu_ops: could not find pmu dt node [ 1.066902] [0: swapper/0: 1] rk_clk_tree_init start! [ 1.081278] [0: swapper/0: 1] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 1.081349] [0: swapper/0: 1] rkclk_init_clks: cnt_parent = 12 [ 1.081695] [0: swapper/0: 1] rkclk_init_clks: cnt_rate = 29 [ 1.082261] [0: swapper/0: 1] rkclk: gcd=0, frac div is not be supported [ 1.082287] [0: swapper/0: 1] rkclk: clk_frac_div name=uart2_frac can't get rate=0 [ 1.082316] [0: swapper/0: 1] rkclk: gcd=0, frac div is not be supported [ 1.082339] [0: swapper/0: 1] rkclk: clk_frac_div name=uart1_frac can't get rate=0 [ 1.082368] [0: swapper/0: 1] rkclk: gcd=0, frac div is not be supported [ 1.082391] [0: swapper/0: 1] rkclk: clk_frac_div name=uart0_frac can't get rate=0 [ 1.083968] [0: swapper/0: 1] rkclk: warning: clk_rate < 1*MHZ or > 2000*MHZ [ 1.084660] [0: swapper/0: 1] rkclk: warning: clk_rate < 1*MHZ or > 2000*MHZ [ 1.099549] [0: swapper/0: 1] syscon ff100000.syscon: regmap [mem 0xff100000-0xff100fff] registered [ 1.099779] [0: swapper/0: 1] syscon ff140000.syscon: regmap [mem 0xff140000-0xff140fff] registered [ 1.102048] [0: swapper/0: 1] rk_iommu ff330200.h265e_mmu: (h265e) Enter [ 1.102184] [0: swapper/0: 1] rk_iommu ff330200.h265e_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 1.102213] [0: swapper/0: 1] rk_iommu ff330200.h265e_mmu: (h265e) Initialized [ 1.102608] [0: swapper/0: 1] rk_iommu ff340800.vepu_mmu: (vepu) Enter [ 1.102706] [0: swapper/0: 1] rk_iommu ff340800.vepu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 1.102735] [0: swapper/0: 1] rk_iommu ff340800.vepu_mmu: (vepu) Initialized [ 1.103353] [0: swapper/0: 1] rk_iommu ff350800.vpu_mmu: (vpu) Enter [ 1.103503] [0: swapper/0: 1] rk_iommu ff350800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 1.103531] [0: swapper/0: 1] rk_iommu ff350800.vpu_mmu: (vpu) Initialized [ 1.103944] [0: swapper/0: 1] rk_iommu ff360480.vdec_mmu: (vdec) Enter [ 1.104039] [0: swapper/0: 1] rk_iommu ff360480.vdec_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 1.104067] [0: swapper/0: 1] rk_iommu ff360480.vdec_mmu: (vdec) Initialized [ 1.104554] [0: swapper/0: 1] rk_iommu ff373f00.vopb_mmu: (vopb) Enter [ 1.104643] [0: swapper/0: 1] rk_iommu ff373f00.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 1.104671] [0: swapper/0: 1] rk_iommu ff373f00.vopb_mmu: (vopb) Initialized [ 1.105200] [0: swapper/0: 1] rk_iommu ff3a0800.iep_mmu: (iep) Enter [ 1.105288] [0: swapper/0: 1] rk_iommu ff3a0800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 1.105315] [0: swapper/0: 1] rk_iommu ff3a0800.iep_mmu: (iep) Initialized [ 1.106049] [0: swapper/0: 1] syscon ff440000.syscon: regmap [mem 0xff440000-0xff440fff] registered [ 1.106371] [0: swapper/0: 1] syscon ff450000.syscon: regmap [mem 0xff450000-0xff450fff] registered [ 1.106665] [0: swapper/0: 1] syscon ff460000.syscon: regmap [mem 0xff460000-0xff460fff] registered [ 1.108586] [0: swapper/0: 1] syscon ff720000.syscon: regmap [mem 0xff720000-0xff722fff] registered [ 1.108804] [0: swapper/0: 1] syscon ff780000.syscon: regmap [mem 0xff780000-0xff782fff] registered [ 1.109023] [0: swapper/0: 1] syscon ff790000.syscon: regmap [mem 0xff790000-0xff7902ff] registered [ 1.122086] [0: swapper/0: 1] console [ttyFIQ0] enabled [ 1.122358] [0: swapper/0: 1] Registered fiq debugger ttyFIQ0 [ 1.122698] [0: swapper/0: 1] process version: 0 [ 1.122857] [0: swapper/0: 1] channel:0, lkg:7 [ 1.122886] [0: swapper/0: 1] target-temp:95 [ 1.122938] [0: swapper/0: 1] channel:2, lkg:7 [ 1.122984] [0: swapper/0: 1] channel:2, lkg:7 [ 1.123033] [0: swapper/0: 1] channel:2, lkg:7 [ 1.123060] [0: swapper/0: 1] target-temp:110 [ 1.148808] [0: swapper/0: 1] bio: create slab at 0 [ 1.149433] [0: swapper/0: 1] Rockchip hdmi driver version 2.0 [ 1.149632] [0: swapper/0: 1] mpp venc_srv.19: mpp_probe enter [ 1.149682] [0: swapper/0: 1] mpp venc_srv.19: init success [ 1.150604] [0: swapper/0: 1] vcc5v0_host: no parameters [ 1.151320] [0: swapper/0: 1] ppvar_sd_card_io: 1800 <--> 3300 mV at 3300 mV [ 1.152822] [0: swapper/0: 1] SCSI subsystem initialized [ 1.153045] [0: swapper/0: 1] usbcore: registered new interface driver usbfs [ 1.153175] [0: swapper/0: 1] usbcore: registered new interface driver hub [ 1.153368] [0: swapper/0: 1] usbcore: registered new device driver usb [ 1.155540] [0: swapper/0: 1] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff800026e000 [ 1.156218] [0: swapper/0: 1] media: Linux media interface: v0.10 [ 1.156290] [0: swapper/0: 1] Linux video capture interface: v2.00 [ 1.156383] [0: swapper/0: 1] pps_core: LinuxPPS API ver. 1 registered [ 1.156463] [0: swapper/0: 1] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 1.156510] [0: swapper/0: 1] PTP clock support registered [ 1.156591] [0: swapper/0: 1] i2c-core: driver [bq24296] using legacy suspend method [ 1.156619] [0: swapper/0: 1] i2c-core: driver [bq24296] using legacy resume method [ 1.156994] [0: swapper/0: 1] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203) [ 1.158113] [0: swapper/0: 1] Rockchip ion module is successfully loaded (v1.1) [ 1.158864] [0: swapper/0: 1] Advanced Linux Sound Architecture Driver Initialized. [ 1.159398] [0: swapper/0: 1] Bluetooth: Core ver 2.16 [ 1.159465] [0: swapper/0: 1] NET: Registered protocol family 31 [ 1.159492] [0: swapper/0: 1] Bluetooth: HCI device and connection manager initialized [ 1.159527] [0: swapper/0: 1] Bluetooth: HCI socket layer initialized [ 1.159559] [0: swapper/0: 1] Bluetooth: L2CAP socket layer initialized [ 1.159608] [0: swapper/0: 1] Bluetooth: SCO socket layer initialized [ 1.159992] [0: kworker/0:1: 30] cfg80211: Calling CRDA to update world regulatory domain [ 1.162521] [0: swapper/0: 1] rk816_i2c_probe,line=785 [ 1.162868] [0: swapper/0: 1] pmic is rk805, chip version is 8050 [ 1.163042] [0: swapper/0: 1] pmic on/off source: on=0x40, off=0x0 [ 1.165917] [0: swapper/0: 1] rk816_i2c_probe: rk816_pmic_sleep=0 [ 1.166680] [0: swapper/0: 1] rk816_regulator_probe: compatible rk805 [ 1.168592] [0: swapper/0: 1] vdd_logic: 712 <--> 1350 mV at 1100 mV [ 1.170004] [0: swapper/0: 1] vdd_arm: 712 <--> 1350 mV at 1225 mV [ 1.171272] [0: swapper/0: 1] vcc_ddr: 1200 mV [ 1.172964] [0: swapper/0: 1] vcc_io: 3300 mV [ 1.174642] [0: swapper/0: 1] vdd_18: 1800 mV [ 1.176271] [0: swapper/0: 1] vcc_18emmc: 1800 mV [ 1.177919] [0: swapper/0: 1] vdd_11: 1100 mV [ 1.178364] [0: swapper/0: 1] rk816_i2c_probe success [ 1.178423] [0: swapper/0: 1] i2c-core: driver [rk816] using legacy suspend method [ 1.178451] [0: swapper/0: 1] i2c-core: driver [rk816] using legacy resume method [ 1.178519] [0: swapper/0: 1] i2c-core: driver [rk818] using legacy suspend method [ 1.178546] [0: swapper/0: 1] i2c-core: driver [rk818] using legacy resume method [ 1.179382] [0: swapper/0: 1] rk816_rtc_probe,line=463 [ 1.179428] [0: swapper/0: 1] rk8xx-rtc: probe of rk8xx-rtc failed with error -22 [ 1.179885] [0: swapper/0: 1] rockchip-i2s ff000000.i2s: i2s0 has no mclk [ 1.182153] [0: swapper/0: 1] Switching to clocksource arch_sys_counter [ 1.213613] [0: swapper/0: 1] rga: Module initialized. [ 1.214261] [0: swapper/0: 1] rga2 ff390000.rga: rga ion client create success! [ 1.214484] [0: swapper/0: 1] rga: Driver loaded succesfully [ 1.214788] [0: swapper/0: 1] fb disp policy is box [ 1.214816] [0: swapper/0: 1] uboot-logo-on:1 [ 1.214874] [0: swapper/0: 1] rk-fb rockchip-fb: rk fb ion client create success! [ 1.214906] [0: swapper/0: 1] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 1.215625] [0: swapper/0: 1] can't find screen_init node [ 1.215663] [0: swapper/0: 1] rk-screen rk_screen.18: rockchip screen probe success [ 1.216909] [0: swapper/0: 1] rk322xh-lcdc ff370000.vop: vop_dev->regs=0xffffff800027c000 [ 1.216998] [0: swapper/0: 1] rk322xh-lcdc vop0: can't find power_ctr node for lcdc0 [ 1.217345] [0: swapper/0: 1] graphics fb0: rockchip framebuffer registerd:fb0 [ 1.217803] [0: swapper/0: 1] graphics fb1: rockchip framebuffer registerd:fb1 [ 1.218033] [0: swapper/0: 1] graphics fb2: rockchip framebuffer registerd:fb2 [ 1.218249] [0: swapper/0: 1] graphics fb3: rockchip framebuffer registerd:fb3 [ 1.218519] [0: swapper/0: 1] graphics fb4: rockchip framebuffer registerd:fb4 [ 1.218710] [0: swapper/0: 1] rk322xh-lcdc vop0: failed to get vop hclk_noc source [ 1.220092] [0: swapper/0: 1] rk322xh-lcdc vop0: lcdc0: dclk:594000000>>fps:112 [ 1.228725] [0: swapper/0: 1] alloc_buffer:ion_phy_addr=0x10000000 [ 1.233465] [0: swapper/0: 1] fb0:phy:10000000>>vir:ffffff8000286000>>len:0xb00000 [ 1.246720] [0: swapper/0: 1] rk_iommu ff373f00.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x7a781000 [ 1.246781] [0: swapper/0: 1] rk322xh-lcdc vop0: lcdc0 probe ok, iommu enabled [ 1.249140] [0: swapper/0: 1] NET: Registered protocol family 2 [ 1.250119] [0: swapper/0: 1] TCP established hash table entries: 16384 (order: 6, 262144 bytes) [ 1.250598] [0: swapper/0: 1] TCP bind hash table entries: 16384 (order: 6, 262144 bytes) [ 1.251095] [0: swapper/0: 1] TCP: Hash tables configured (established 16384 bind 16384) [ 1.251288] [0: swapper/0: 1] TCP: reno registered [ 1.251329] [0: swapper/0: 1] UDP hash table entries: 1024 (order: 3, 32768 bytes) [ 1.251431] [0: swapper/0: 1] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes) [ 1.251841] [0: swapper/0: 1] NET: Registered protocol family 1 [ 1.252281] [0: swapper/0: 1] RPC: Registered named UNIX socket transport module. [ 1.252312] [0: swapper/0: 1] RPC: Registered udp transport module. [ 1.252338] [0: swapper/0: 1] RPC: Registered tcp transport module. [ 1.252364] [0: swapper/0: 1] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.252570] [0: swapper/0: 1] rk816_gpio_probe: compatible rk805 [ 1.252768] [0: swapper/0: 1] rk8xx-gpio rk8xx-gpio: driver success [ 1.253819] [0: swapper/0: 1] Unpacking initramfs... [ 1.257364] [0: kworker/0:1: 30] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 1.772166] [0: swapper/0: 1] Freeing initrd memory: 7548K (ffffffc0059f0000 - ffffffc00614f000) [ 1.773502] [0: swapper/0: 1] rknandbase v1.0 2014-03-31 [ 1.774135] [0: swapper/0: 1] rknand_driver:ret = 0 [ 1.774547] [0: swapper/0: 1] vcodec_service: No noc aclk reset resource define [ 1.774575] [0: swapper/0: 1] vcodec_service: No noc hclk reset resource define [ 1.774601] [0: swapper/0: 1] vcodec_service: No core reset resource define [ 1.774625] [0: swapper/0: 1] vcodec_service: No cabac reset resource define [ 1.774760] [0: swapper/0: 1] vcodec vpu_combo.20: failed on clk_get clk_cabac [ 1.774882] [0: swapper/0: 1] vcodec vpu_combo.20: do not have pd_video [ 1.774946] [0: swapper/0: 1] vcodec_service: probe device ff350000.vpu_service [ 1.775013] [0: swapper/0: 1] vcodec_service: checking hw id 0 [ 1.776089] [0: swapper/0: 1] vcodec_service: probe device ff351000.avsd [ 1.776163] [0: swapper/0: 1] vcodec_service: checking hw id 6731 [ 1.777480] [0: swapper/0: 1] vcodec_service: init success [ 1.778688] [0: swapper/0: 1] vcodec ff360000.rkvdec: do not have pd_video [ 1.778748] [0: swapper/0: 1] vcodec_service: probe device ff360000.rkvdec [ 1.778808] [0: swapper/0: 1] DVFS ERR: dvfs_target: aclk_rkvdec is disable, set rate error [ 1.778868] [0: swapper/0: 1] vcodec_service: checking hw id 3410 [ 1.779567] [0: swapper/0: 1] DVFS ERR: dvfs_target: aclk_rkvdec is disable, set rate error [ 1.780374] [0: swapper/0: 1] vcodec_service: init success [ 1.783179] [0: swapper/0: 1] Initialise system trusted keyring [ 1.783280] [0: swapper/0: 1] audit: initializing netlink socket (disabled) [ 1.783354] [0: swapper/0: 1] type=2000 audit(0.783:1): initialized [ 1.788621] [0: swapper/0: 1] VFS: Disk quotas dquot_6.5.2 [ 1.788871] [0: swapper/0: 1] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.791135] [0: swapper/0: 1] NFS: Registering the id_resolver key type [ 1.791215] [0: swapper/0: 1] Key type id_resolver registered [ 1.791241] [0: swapper/0: 1] Key type id_legacy registered [ 1.791717] [0: swapper/0: 1] fuse init (API version 7.22) [ 1.792733] [0: swapper/0: 1] [ 1.792733] [0: swapper/0: 1] TEE Core Framework initialization (ver 1:0.1) [ 1.792807] [0: swapper/0: 1] TEE armv7 Driver initialization [ 1.793337] [0: swapper/0: 1] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0" [ 1.793371] [0: swapper/0: 1] TEE core: Alloc the misc device "opteearmtz00" (id=0) [ 1.793648] [0: swapper/0: 1] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=58) [ 1.795808] [0: swapper/0: 1] Key type asymmetric registered [ 1.795847] [0: swapper/0: 1] Asymmetric key parser 'x509' registered [ 1.796088] [0: swapper/0: 1] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 1.796122] [0: swapper/0: 1] io scheduler noop registered [ 1.796257] [0: swapper/0: 1] io scheduler cfq registered (default) [ 1.800448] [0: swapper/0: 1] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully [ 1.802555] [0: swapper/0: 1] reset hdmi [ 1.802892] [0: swapper/0: 1] rockchip-hdmiv2 ff3c0000.hdmi: rockchip hdmiv2 probe success. [ 1.803673] [0: swapper/0: 1] iep: failed to find iep power down clock source. [ 1.804229] [0: swapper/0: 1] iep ion client create success! [ 1.804261] [0: swapper/0: 1] IEP Power ON [ 1.804819] [0: swapper/0: 1] rk_iommu ff3a0800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x7a784000 [ 1.804850] [0: swapper/0: 1] IEP Power OFF [ 1.804886] [0: swapper/0: 1] IEP Driver loaded succesfully [ 1.805089] [0: swapper/0: 1] Module initialized. [ 1.805676] [0: swapper/0: 1] cvbs connect to lcdc0 [ 1.805706] [0: swapper/0: 1] switch:en=1,lcdc_id=0,screen type=5,cur type=1 [ 1.805730] [0: swapper/0: 1] data space: 0, color mode: 2 [ 1.805796] [0: swapper/0: 1] rk322xh-lcdc vop0: lcdc0: dclk:594000000>>fps:52 [ 1.805860] [0: swapper/0: 1] rk3036-tve ff373e00.tve: rockchip,rk322xh-tve tv encoder probe ok [ 1.806262] [0: swapper/0: 1] probe device ff330000.h265e [ 1.806656] [0: swapper/0: 1] mpp_dev ff330000.h265e: try to get iommu dev rockchip,h265e_mmu [ 1.807289] [0: swapper/0: 1] mpp_dev ff330000.h265e: resource ready, register device [ 1.807600] [0: swapper/0: 1] probe device ff340000.vepu [ 1.807912] [0: swapper/0: 1] mpp_dev ff340000.vepu: try to get iommu dev rockchip,vepu_mmu [ 1.808509] [0: swapper/0: 1] mpp_dev ff340000.vepu: resource ready, register device [ 1.810926] [0: swapper/0: 1] dma-pl330 ff1f0000.pdma: Loaded driver for PL330 DMAC-2364208 [ 1.810972] [0: swapper/0: 1] dma-pl330 ff1f0000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 1.811602] [0: swapper/0: 1] rk_serial.c v1.8 2014-03-04 [ 1.812108] [0: swapper/0: 1] [drm] Initialized drm 1.1.0 20060810 [ 1.815348] [0: swapper/0: 1] loop: module loaded [ 1.815829] [0: swapper/0: 1] zram: Created 1 device(s) [ 1.816052] [0: swapper/0: 1] i2c-core: driver [mpu6050B1] using legacy suspend method [ 1.816081] [0: swapper/0: 1] i2c-core: driver [mpu6050B1] using legacy resume method [ 1.816112] [0: swapper/0: 1] mpu_init: Probe name mpu6050B1 [ 1.816300] [0: swapper/0: 1] ak8963_mod_init: Probe name ak8963_mod [ 1.817536] [0: swapper/0: 1] SCSI Media Changer driver v0.25 [ 1.818018] [0: swapper/0: 1] tun: Universal TUN/TAP device driver, 1.6 [ 1.818047] [0: swapper/0: 1] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 1.819199] [0: swapper/0: 1] stmmac_probe_config_dt: Can not read property: pmu_regulator. [ 1.819239] [0: swapper/0: 1] stmmac_probe_config_dt: clock input/output? (input). [ 1.819269] [0: swapper/0: 1] stmmac_probe_config_dt: TX delay(0x26). [ 1.819295] [0: swapper/0: 1] stmmac_probe_config_dt: Can not read property: rx_delay. [ 1.819321] [0: swapper/0: 1] set rx_delay to 0x10 [ 1.819347] [0: swapper/0: 1] stmmac_probe_config_dt: Can not read property: phy-type. [ 1.819594] [0: swapper/0: 1] stmmc_pltfr_init: [ 1.819618] [0: swapper/0: 1] stmmc_pltfr_init: ERROR: Get power-gpio failed. [ 1.819654] [0: swapper/0: 1] stmmc_pltfr_init: ERROR: Get link-gpio failed. [ 1.819680] [0: swapper/0: 1] stmmc_pltfr_init: ERROR: Get led-gpio failed. [ 1.819706] [0: swapper/0: 1] stmmc_pltfr_init: init for RGMII [ 1.819731] [0: swapper/0: 1] tx delay=0x26 [ 1.819731] [0: swapper/0: 1] rx delay=0x10 [ 1.820079] [0: swapper/0: 1] gmac_clk_init: warning: cannot get mac_clkin clock [ 1.820148] [0: swapper/0: 1] gmac_clk_init: warning: cannot get clk_macphy clock [ 1.820225] [0: swapper/0: 1] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 1.820252] [0: swapper/0: 1] Normal descriptors [ 1.820275] [0: swapper/0: 1] Ring mode enabled [ 1.820300] [0: swapper/0: 1] DMA HW capability register supported [ 1.820324] [0: swapper/0: 1] RX Checksum Offload Engine supported (type 2) [ 1.820350] [0: swapper/0: 1] TX Checksum insertion supported [ 1.820373] [0: swapper/0: 1] Wake-Up On Lan supported [ 1.820446] [0: swapper/0: 1] Enable RX Mitigation via HW Watchdog Timer [ 1.821066] [0: swapper/0: 1] PPP generic driver version 2.4.2 [ 1.821341] [0: swapper/0: 1] PPP BSD Compression module registered [ 1.821370] [0: swapper/0: 1] PPP Deflate Compression module registered [ 1.821418] [0: swapper/0: 1] PPP MPPE Compression module registered [ 1.821447] [0: swapper/0: 1] NET: Registered protocol family 24 [ 1.821509] [0: swapper/0: 1] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 1.821537] [0: swapper/0: 1] CSLIP: code copyright 1989 Regents of the University of California. [ 1.821565] [0: swapper/0: 1] Rockchip WiFi SYS interface (V1.00) ... [ 1.821617] [0: swapper/0: 1] esp_mem_init enter date Jan 26 2019 10:40:18 [ 1.821644] [0: swapper/0: 1] esp_mem_init VERSION [V2.5] [ 1.821714] [0: swapper/0: 1] esp_mem_init complete [ 1.821814] [0: swapper/0: 1] usbcore: registered new interface driver catc [ 1.821910] [0: swapper/0: 1] usbcore: registered new interface driver kaweth [ 1.821940] [0: swapper/0: 1] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 1.822011] [0: swapper/0: 1] usbcore: registered new interface driver pegasus [ 1.822076] [0: swapper/0: 1] usbcore: registered new interface driver rtl8150 [ 1.822104] [0: swapper/0: 1] hso: drivers/net/usb/hso.c: Option Wireless [ 1.822207] [0: swapper/0: 1] usbcore: registered new interface driver hso [ 1.822276] [0: swapper/0: 1] usbcore: registered new interface driver asix [ 1.822340] [0: swapper/0: 1] usbcore: registered new interface driver ax88179_178a [ 1.822408] [0: swapper/0: 1] usbcore: registered new interface driver cdc_ether [ 1.822473] [0: swapper/0: 1] usbcore: registered new interface driver cdc_eem [ 1.822536] [0: swapper/0: 1] usbcore: registered new interface driver dm9601 [ 1.822599] [0: swapper/0: 1] usbcore: registered new interface driver dm9620 [ 1.822673] [0: swapper/0: 1] usbcore: registered new interface driver smsc75xx [ 1.822756] [0: swapper/0: 1] usbcore: registered new interface driver smsc95xx [ 1.822821] [0: swapper/0: 1] usbcore: registered new interface driver gl620a [ 1.822884] [0: swapper/0: 1] usbcore: registered new interface driver net1080 [ 1.822947] [0: swapper/0: 1] usbcore: registered new interface driver plusb [ 1.823015] [0: swapper/0: 1] usbcore: registered new interface driver rndis_host [ 1.823079] [0: swapper/0: 1] usbcore: registered new interface driver cdc_subset [ 1.823147] [0: swapper/0: 1] usbcore: registered new interface driver zaurus [ 1.823214] [0: swapper/0: 1] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 1.823306] [0: swapper/0: 1] usbcore: registered new interface driver int51x1 [ 1.823370] [0: swapper/0: 1] usbcore: registered new interface driver kalmia [ 1.823434] [0: swapper/0: 1] usbcore: registered new interface driver ipheth [ 1.823505] [0: swapper/0: 1] usbcore: registered new interface driver sierra_net [ 1.823571] [0: swapper/0: 1] usbcore: registered new interface driver cx82310_eth [ 1.823644] [0: swapper/0: 1] usbcore: registered new interface driver cdc_ncm [ 1.823709] [0: swapper/0: 1] usbcore: registered new interface driver qmi_wwan [ 1.823774] [0: swapper/0: 1] usbcore: registered new interface driver cdc_mbim [ 1.825886] [0: swapper/0: 1] phy phy-ff470000.usb3-phy.1: u3phy u2 power on [ 1.825956] [0: swapper/0: 1] phy phy-ff470000.usb3-phy.2: u3phy u3 power on [ 1.826737] [0: swapper/0: 1] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.826798] [0: swapper/0: 1] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 1.828045] [0: swapper/0: 1] xhci-hcd xhci-hcd.0.auto: irq 99, io mem 0xff600000 [ 1.828178] [0: swapper/0: 1] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.828213] [0: swapper/0: 1] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.828245] [0: swapper/0: 1] usb usb1: Product: xHCI Host Controller [ 1.828276] [0: swapper/0: 1] usb usb1: Manufacturer: Linux 3.10.104 xhci-hcd [ 1.828306] [0: swapper/0: 1] usb usb1: SerialNumber: xhci-hcd.0.auto [ 1.829032] [0: swapper/0: 1] hub 1-0:1.0: USB hub found [ 1.829077] [0: swapper/0: 1] hub 1-0:1.0: 1 port detected [ 1.829305] [0: swapper/0: 1] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.829350] [0: swapper/0: 1] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 1.829462] [0: swapper/0: 1] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003 [ 1.829496] [0: swapper/0: 1] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.829528] [0: swapper/0: 1] usb usb2: Product: xHCI Host Controller [ 1.829558] [0: swapper/0: 1] usb usb2: Manufacturer: Linux 3.10.104 xhci-hcd [ 1.829589] [0: swapper/0: 1] usb usb2: SerialNumber: xhci-hcd.0.auto [ 1.830131] [0: swapper/0: 1] hub 2-0:1.0: USB hub found [ 1.830172] [0: swapper/0: 1] hub 2-0:1.0: 1 port detected [ 1.830405] [0: swapper/0: 1] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.830435] [0: swapper/0: 1] ehci-platform: EHCI generic platform driver [ 1.831007] [0: swapper/0: 1] ehci-platform ff5c0000.usb: EHCI Host Controller [ 1.831058] [0: swapper/0: 1] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 3 [ 1.831646] [0: swapper/0: 1] ehci-platform ff5c0000.usb: irq 48, io mem 0xff5c0000 [ 1.841551] [0: swapper/0: 1] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00 [ 1.841673] [0: swapper/0: 1] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.841708] [0: swapper/0: 1] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.841741] [0: swapper/0: 1] usb usb3: Product: EHCI Host Controller [ 1.841771] [0: swapper/0: 1] usb usb3: Manufacturer: Linux 3.10.104 ehci_hcd [ 1.841802] [0: swapper/0: 1] usb usb3: SerialNumber: ff5c0000.usb [ 1.842376] [0: swapper/0: 1] hub 3-0:1.0: USB hub found [ 1.842420] [0: swapper/0: 1] hub 3-0:1.0: 1 port detected [ 1.843041] [0: swapper/0: 1] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.843071] [0: swapper/0: 1] ohci-platform: OHCI generic platform driver [ 1.843403] [0: swapper/0: 1] ohci-platform ff5d0000.usb: Generic Platform OHCI controller [ 1.843456] [0: swapper/0: 1] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 4 [ 1.843542] [0: swapper/0: 1] ohci-platform ff5d0000.usb: irq 49, io mem 0xff5d0000 [ 1.898062] [0: swapper/0: 1] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.898099] [0: swapper/0: 1] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.898131] [0: swapper/0: 1] usb usb4: Product: Generic Platform OHCI controller [ 1.898162] [0: swapper/0: 1] usb usb4: Manufacturer: Linux 3.10.104 ohci_hcd [ 1.898193] [0: swapper/0: 1] usb usb4: SerialNumber: ff5d0000.usb [ 1.898759] [0: swapper/0: 1] hub 4-0:1.0: USB hub found [ 1.898804] [0: swapper/0: 1] hub 4-0:1.0: 1 port detected [ 1.899232] [0: swapper/0: 1] usbcore: registered new interface driver cdc_acm [ 1.899261] [0: swapper/0: 1] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.899356] [0: swapper/0: 1] usbcore: registered new interface driver usblp [ 1.899430] [0: swapper/0: 1] usbcore: registered new interface driver cdc_wdm [ 1.899589] [0: swapper/0: 1] usbcore: registered new interface driver usb-storage [ 1.899660] [0: swapper/0: 1] usbcore: registered new interface driver ums-alauda [ 1.899728] [0: swapper/0: 1] usbcore: registered new interface driver ums-cypress [ 1.899798] [0: swapper/0: 1] usbcore: registered new interface driver ums-datafab [ 1.899865] [0: swapper/0: 1] usbcore: registered new interface driver ums_eneub6250 [ 1.899936] [0: swapper/0: 1] usbcore: registered new interface driver ums-freecom [ 1.900006] [0: swapper/0: 1] usbcore: registered new interface driver ums-isd200 [ 1.900072] [0: swapper/0: 1] usbcore: registered new interface driver ums-jumpshot [ 1.900145] [0: swapper/0: 1] usbcore: registered new interface driver ums-karma [ 1.900217] [0: swapper/0: 1] usbcore: registered new interface driver ums-onetouch [ 1.900286] [0: swapper/0: 1] usbcore: registered new interface driver ums-sddr09 [ 1.900355] [0: swapper/0: 1] usbcore: registered new interface driver ums-sddr55 [ 1.900423] [0: swapper/0: 1] usbcore: registered new interface driver ums-usbat [ 1.900618] [0: swapper/0: 1] usbcore: registered new interface driver usbserial [ 1.900692] [0: swapper/0: 1] usbcore: registered new interface driver usbserial_generic [ 1.900745] [0: swapper/0: 1] usbserial: USB Serial support registered for generic [ 1.900817] [0: swapper/0: 1] usbcore: registered new interface driver option [ 1.900894] [0: swapper/0: 1] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.901227] [0: swapper/0: 1] usbcore: registered new interface driver trancevibrator [ 1.901257] [0: swapper/0: 1] usb20_otg: version 3.10a 21-DEC-2012 [ 1.901986] [0: swapper/0: 1] ffffff8002000040 [ 1.902021] [0: swapper/0: 1] Core Release: 3.10a [ 1.902048] [0: swapper/0: 1] Setting default values for core params [ 1.902233] [0: swapper/0: 1] Using Buffer DMA mode [ 1.902261] [0: swapper/0: 1] Periodic Transfer Interrupt Enhancement - disabled [ 1.902286] [0: swapper/0: 1] Multiprocessor Interrupt Enhancement - disabled [ 1.902315] [0: swapper/0: 1] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.902340] [0: swapper/0: 1] ^^^^^^^^^^^^^^^^^Device Mode [ 1.902375] [0: swapper/0: 1] Dedicated Tx FIFOs mode [ 1.902417] [0: swapper/0: 1] pcd_init otg_dev = ffffffc077d79800 [ 1.902645] [0: swapper/0: 1] usb20_otg ff580000.usb: DWC OTG Controller [ 1.902695] [0: swapper/0: 1] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 5 [ 1.902751] [0: swapper/0: 1] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 1.902862] [0: swapper/0: 1] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.902897] [0: swapper/0: 1] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.902929] [0: swapper/0: 1] usb usb5: Product: DWC OTG Controller [ 1.902959] [0: swapper/0: 1] usb usb5: Manufacturer: Linux 3.10.104 dwc_otg_hcd [ 1.902991] [0: swapper/0: 1] usb usb5: SerialNumber: ff580000.usb [ 1.903542] [0: swapper/0: 1] hub 5-0:1.0: USB hub found [ 1.903591] [0: swapper/0: 1] hub 5-0:1.0: 1 port detected [ 1.907289] [2: swapper/0: 1] usb20_host: version 3.10a 21-DEC-2012 [ 1.908276] [2: swapper/0: 1] usbcore: registered new interface driver xpad [ 1.908371] [2: swapper/0: 1] usbcore: registered new interface driver usb_acecad [ 1.908451] [2: swapper/0: 1] usbcore: registered new interface driver aiptek [ 1.908526] [2: swapper/0: 1] usbcore: registered new interface driver gtco [ 1.908601] [2: swapper/0: 1] usbcore: registered new interface driver hanwang [ 1.908674] [2: swapper/0: 1] usbcore: registered new interface driver kbtab [ 1.908780] [2: swapper/0: 1] usbcore: registered new interface driver wacom [ 1.910363] [2: swapper/0: 1] input: rk816_pwrkey as /devices/ff160000.i2c/i2c-1/1-0018/rk8xx-pwrkey/input/input0 [ 1.910664] [2: swapper/0: 1] rk805 register rk8xx_pwrkey driver [ 1.910735] [2: swapper/0: 1] sensor_register_slave:mma8452,id=17 [ 1.910763] [2: swapper/0: 1] sensor_register_slave:gs_mc3230,id=23 [ 1.910788] [2: swapper/0: 1] [Gsensor] gsensor_init [ 1.910815] [2: swapper/0: 1] sensor_register_slave:mpu6880_acc,id=24 [ 1.910841] [2: swapper/0: 1] sensor_register_slave:mpu6500_acc,id=25 [ 1.910868] [2: swapper/0: 1] sensor_register_slave:bma2xx_acc,id=26 [ 1.910894] [2: swapper/0: 1] sensor_register_slave:cm3217,id=49 [ 1.910921] [2: swapper/0: 1] sensor_register_slave:cm3218,id=50 [ 1.910947] [2: swapper/0: 1] sensor_register_slave:ls_stk3410,id=58 [ 1.911287] [2: swapper/0: 1] sensor_register_slave:ps_stk3410,id=63 [ 1.911740] [2: swapper/0: 1] .. rk pwm remotectl v1.1 init [ 1.912229] [2: swapper/0: 1] input: ff1b0030.pwm as /devices/ff1b0030.pwm/input/input1 [ 1.912912] [2: swapper/0: 1] i2c /dev entries driver [ 1.913312] [2: swapper/0: 1] IR NEC protocol handler initialized [ 1.913340] [2: swapper/0: 1] IR RC5(x) protocol handler initialized [ 1.913365] [2: swapper/0: 1] IR RC6 protocol handler initialized [ 1.913390] [2: swapper/0: 1] IR JVC protocol handler initialized [ 1.913415] [2: swapper/0: 1] IR Sony protocol handler initialized [ 1.913440] [2: swapper/0: 1] IR RC5 (streamzap) protocol handler initialized [ 1.913465] [2: swapper/0: 1] IR SANYO protocol handler initialized [ 1.913491] [2: swapper/0: 1] IR MCE Keyboard/mouse protocol handler initialized [ 1.913822] [2: swapper/0: 1] usbcore: registered new interface driver uvcvideo [ 1.913852] [2: swapper/0: 1] USB Video Class driver (1.1.1) [ 1.913881] [2: swapper/0: 1] CamSys driver version: v0.34.0, CamSys head file version: v0.13.0 [ 1.913910] [2: swapper/0: 1] E:camsys_soc_init(30): camsys_soc_init exit! [ 1.915533] [2: swapper/0: 1] not find test_power_init dev node [ 1.915608] [2: swapper/0: 1] i2c-core: driver [bq27320] using legacy suspend method [ 1.915636] [2: swapper/0: 1] i2c-core: driver [bq27320] using legacy resume method [ 1.919270] [2: swapper/0: 1] thermal thermal_zone0: failed to read out thermal zone 0 [ 1.919894] [2: swapper/0: 1] device-mapper: uevent: version 1.0.3 [ 1.920316] [2: swapper/0: 1] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email] [ 1.920680] [2: swapper/0: 1] Bluetooth: HCI UART driver ver 2.2 [ 1.920712] [2: swapper/0: 1] Bluetooth: HCI H4 protocol initialized [ 1.920738] [2: swapper/0: 1] Bluetooth: HCILL protocol initialized [ 1.922579] [2: swapper/0: 1] cpufreq version 1.0, suspend freq 1008 MHz [ 1.923431] [2: swapper/0: 1] cpuidle: using governor ladder [ 1.923462] [2: swapper/0: 1] cpuidle: using governor menu [ 1.923923] [2: swapper/0: 1] Synopsys Designware Multimedia Card Interface Driver [ 1.923952] [2: swapper/0: 1] MHSC version = Ver 2.00 2015-06-10 [ 1.925011] [2: swapper/0: 1] dwmmc_rockchip ff520000.rksdmmc: Version ID is 270a [ 1.925100] [2: swapper/0: 1] dwmmc_rockchip ff520000.rksdmmc: failed to get hpclk_mmc [ 2.002337] [0: kworker/0:1: 30] Using Buffer DMA mode [ 2.002366] [0: kworker/0:1: 30] Periodic Transfer Interrupt Enhancement - disabled [ 2.002379] [0: kworker/0:1: 30] Multiprocessor Interrupt Enhancement - disabled [ 2.002394] [0: kworker/0:1: 30] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 2.002408] [0: kworker/0:1: 30] ^^^^^^^^^^^^^^^^^^Host Mode [ 2.003100] [2: swapper/0: 1] dwmmc_rockchip ff520000.rksdmmc: Using internal DMA controller. [ 2.003323] [2: swapper/0: 1] dwmmc_rockchip ff520000.rksdmmc: dw_mci_init_slot: fmin=400000, fmax=150000000 [mmc0] [ 2.015386] [2: swapper/0: 1] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 2.028555] [2: swapper/0: 1] dwmmc_rockchip ff520000.rksdmmc: DW MMC controller at irq 46, 32 bit host data width, 256 deep fifo [ 2.028573] [2: swapper/0: 1] dwmmc_rockchip ff520000.rksdmmc: 1 slots initialized [ 2.029169] [2: swapper/0: 1] dwmmc_rockchip ff500000.rksdmmc: Version ID is 270a [ 2.029225] [2: swapper/0: 1] dwmmc_rockchip ff500000.rksdmmc: failed to get hpclk_mmc [ 2.030559] [0: swapper/0: 1] dwmmc_rockchip ff500000.rksdmmc: Using internal DMA controller. [ 2.030909] [0: swapper/0: 1] dwmmc_rockchip ff500000.rksdmmc: dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc1] [ 2.031332] [0: swapper/0: 1] dwmmc_rockchip ff500000.rksdmmc: mmc1: No udbg pinctrl found! [ 2.031449] [0: swapper/0: 1] enter gpio_regulator_set_voltage 72 [ 2.031465] [0: swapper/0: 1] enter gpio_regulator_set_voltage line 93 ,gpio=25 state=0 [ 2.048226] [0: swapper/0: 1] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc1] [ 2.051771] [0: kworker/u8:1: 41] Init: Power Port (0) [ 2.051791] [0: kworker/u8:1: 41] rk_battery_charger_detect_cb , battery_charger_detect 5 [ 2.051854] [0: kworker/0:1: 30] ff580000.usb resume, HPRT0:0x1000 [ 2.051988] [2: kworker/2:1: 33] ff580000.usb suspend, HPRT0:0x1000 [ 2.061398] [0: swapper/0: 1] dwmmc_rockchip ff500000.rksdmmc: DW MMC controller at irq 44, 32 bit host data width, 256 deep fifo [ 2.061417] [0: swapper/0: 1] dwmmc_rockchip ff500000.rksdmmc: 1 slots initialized [ 2.061790] [0: swapper/0: 1] leds-gpio leds.32: pins are not configured from the driver [ 2.062140] [0: swapper/0: 1] leds-gpio leds.32: firefly:blue:power can_sleep:1 mode:23 [ 2.062653] [0: swapper/0: 1] leds-gpio leds.32: firefly:yellow:user can_sleep:1 mode:05 [ 2.062731] [0: swapper/0: 1] leds-gpio leds.32: Skipping unavailable LED gpio -2 (ir) [ 2.063117] [0: swapper/0: 1] hidraw: raw HID events driver (C) Jiri Kosina [ 2.064879] [0: swapper/0: 1] usbcore: registered new interface driver usbhid [ 2.064905] [0: swapper/0: 1] usbhid: USB HID core driver [ 2.065160] [0: swapper/0: 1] ashmem: initialized [ 2.065331] [0: swapper/0: 1] logger: created 256K log 'log_main' [ 2.065447] [0: swapper/0: 1] logger: created 256K log 'log_events' [ 2.065543] [0: swapper/0: 1] logger: created 256K log 'log_radio' [ 2.065660] [0: swapper/0: 1] logger: created 256K log 'log_system' [ 2.066330] [0: swapper/0: 1] Rockchip DDR Initialize, verision: V1.01 20170517 [ 2.066354] [0: swapper/0: 1] current ATF version 0x101! [ 2.066377] [0: swapper/0: 1] rockchip_ddr ddr.25: share memory addr=0x102000 [ 2.067971] [0: swapper/0: 1] rockchip_ddr_probe: success [ 2.069029] [0: swapper/0: 1] input: rk29-keypad as /devices/ff280000.adc/rockchip-key.33/input/input2 [ 2.070451] [0: swapper/0: 1] --es8316_init--start-- [ 2.166246] I[2: kworker/u8:0: 6] dwmmc_rockchip ff520000.rksdmmc: descriptor is still owned by IDMAC. [ 2.166285] I[2: kworker/u8:0: 6] dwmmc_rockchip ff520000.rksdmmc: dw_mci_submit_data_dma: fall back to PIO mode for current transfer [ 2.167127] [0: swapper/0: 1] rk322x-audio rockchip_audio.28: rk322x-hifi <-> ff010000.i2s mapping ok [ 2.169907] [0: swapper/0: 1] rockchip-hdmi-i2s rockchip_hdmi_i2s.29: rk-hdmi-i2s-hifi <-> ff000000.i2s mapping ok [ 2.170584] [0: swapper/0: 1] u32 classifier [ 2.170603] [0: swapper/0: 1] Actions configured [ 2.170620] [0: swapper/0: 1] Netfilter messages via NETLINK v0.30. [ 2.170691] [0: swapper/0: 1] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 2.171038] [0: swapper/0: 1] ctnetlink v0.93: registering with nfnetlink. [ 2.171150] [0: swapper/0: 1] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 2.171163] [0: swapper/0: 1] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 2.171456] [0: swapper/0: 1] xt_time: kernel timezone is -0000 [ 2.171669] [0: swapper/0: 1] ip_tables: (C) 2000-2006 Netfilter Core Team [ 2.171869] [0: swapper/0: 1] arp_tables: (C) 2002 David S. Miller [ 2.171912] [0: swapper/0: 1] TCP: cubic registered [ 2.171924] [0: swapper/0: 1] Initializing XFRM netlink socket [ 2.172167] [0: swapper/0: 1] NET: Registered protocol family 10 [ 2.172888] [0: swapper/0: 1] mip6: Mobile IPv6 [ 2.172944] [0: swapper/0: 1] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 2.173120] [0: swapper/0: 1] sit: IPv6 over IPv4 tunneling driver [ 2.173541] [0: swapper/0: 1] NET: Registered protocol family 17 [ 2.173586] [0: swapper/0: 1] NET: Registered protocol family 15 [ 2.173665] [0: swapper/0: 1] Bridge firewalling registered [ 2.173687] [0: swapper/0: 1] Ebtables v2.0 registered [ 2.174042] [0: swapper/0: 1] Bluetooth: RFCOMM TTY layer initialized [ 2.174087] [0: swapper/0: 1] Bluetooth: RFCOMM socket layer initialized [ 2.174102] [0: swapper/0: 1] Bluetooth: RFCOMM ver 1.11 [ 2.174115] [0: swapper/0: 1] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.174128] [0: swapper/0: 1] Bluetooth: BNEP filters: protocol multicast [ 2.174148] [0: swapper/0: 1] Bluetooth: BNEP socket layer initialized [ 2.174161] [0: swapper/0: 1] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.174180] [0: swapper/0: 1] Bluetooth: HIDP socket layer initialized [ 2.174272] [0: swapper/0: 1] l2tp_core: L2TP core driver, V2.0 [ 2.174294] [0: swapper/0: 1] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 2.174307] [0: swapper/0: 1] 8021q: 802.1Q VLAN Support v1.8 [ 2.174342] [0: swapper/0: 1] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 2.174626] [0: swapper/0: 1] [BT_RFKILL]: Enter rfkill_rk_init [ 2.174837] [0: swapper/0: 1] Key type dns_resolver registered [ 2.175919] [0: swapper/0: 1] Registering SWP/SWPB emulation handler [ 2.175948] [0: swapper/0: 1] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x0000000002000000@0x000000007dc00000 [ 2.180419] [0: swapper/0: 1] ddrfreq: verion 1.2 20140526 [ 2.180447] [0: swapper/0: 1] ddrfreq: normal 1056MHz performance 1056MHz low_power 0MHz video_1080p 1056MHz video_4k 1056MHz dualview 1056MHz idle 0MHz suspend 1056MHz reboot 1056MHz video_4k_10b 0MHz [ 2.180487] [0: swapper/0: 1] ddrfreq: auto-freq=0 [ 2.180500] [0: swapper/0: 1] ddrfreq: auto-freq-table[0] 1056MHz [ 2.180512] [0: swapper/0: 1] ddrfreq: auto-freq-table[1] 1056MHz [ 2.180679] [3: kworker/u8:0: 6] mmc0: BKOPS_EN bit is not set [ 2.191497] I[0: ddrfreqd: 115] rk_iommu ff373f00.vopb_mmu: 1.rawstat = 0xd65f03c0,status = 0xb4000060,reg_status = 0x910003fd [ 2.191520] I[0: ddrfreqd: 115] rk_iommu ff373f00.vopb_mmu: unexpected int_status: 0xd65f03c0 [ 2.191520] I[0: ddrfreqd: 115] [ 2.191544] I[0: ddrfreqd: 115] rk_iommu ff373f00.vopb_mmu: 2.rawstat = 0xd65f03c0,status = 0xb4000060,reg_status = 0x910003fd [ 2.192106] [3: swapper/0: 1] Loading compiled-in X.509 certificates [ 2.192138] [3: swapper/0: 1] registered taskstats version 1 [ 2.192221] [3: swapper/0: 1] regulator-dummy: disabling [ 2.192456] [3: swapper/0: 1] unable to find transceiver of type USB2 PHY [ 2.192499] [3: swapper/0: 1] otg_wakelock_init: No USB transceiver found [ 2.192578] [3: swapper/0: 1] pcd_pullup, is_on 0 [ 2.192624] [3: swapper/0: 1] swapper/0[1]: undefined instruction: pc=ffffffc0003f1d74 [ 2.192639] I[0: swapper/0: 0] WARN::dwc_otg_handle_mode_mismatch_intr:69: Mode Mismatch Interrupt: currently in Host mode [ 2.192639] I[0: swapper/0: 0] [ 2.192664] [3: swapper/0: 1] Code: a8c17bfd d65f03c0 a9bf7bfd 910003fd (00000004) [ 2.192679] [3: swapper/0: 1] Internal error: Oops - undefined instruction: 0 [#1] PREEMPT SMP [ 2.193366] [0: kworker/u8:0: 6] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0] [ 2.196668] [0: kworker/u8:0: 6] mmc_host mmc0: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0) [ 2.196687] [0: kworker/u8:0: 6] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0] [ 2.196713] [0: kworker/u8:0: 6] [mmc0] tuning regsbase addr 0x390. [ 2.196713] [0: kworker/u8:0: 6] cmd/data error is normal in tuning, Please Ignore!!! [ 2.196884] I[0: swapper/0: 0] rk_sdmmc: ERROR data error, status 0x00000088 [mmc0] [ 2.196951] I[0: swapper/0: 0] rk_sdmmc: ERROR data error, status 0x00002000 [mmc0] [ 2.297437] I[0: kworker/u8:0: 6] dwmmc_rockchip ff520000.rksdmmc: descriptor is still owned by IDMAC. [ 2.297451] I[0: kworker/u8:0: 6] dwmmc_rockchip ff520000.rksdmmc: dw_mci_submit_data_dma: fall back to PIO mode for current transfer [ 2.298441] [0: kworker/u8:0: 6] dwmmc_rockchip ff520000.rksdmmc: Good phase range 0-12 (2 len) [ 2.298451] [0: kworker/u8:0: 6] dwmmc_rockchip ff520000.rksdmmc: Good phase range 57-259 (19 len) [ 2.298461] [0: kworker/u8:0: 6] dwmmc_rockchip ff520000.rksdmmc: Best phase range 57-259 (19 len) [ 2.298469] [0: kworker/u8:0: 6] dwmmc_rockchip ff520000.rksdmmc: Successfully tuned phase to 158 [ 2.298506] [0: kworker/u8:0: 6] mmc0: new HS200 MMC card at address 0001 [ 2.298777] [0: kworker/u8:0: 6] mmcblk0: mmc0:0001 SLD32G 28.9 GiB [ 2.298892] [0: kworker/u8:0: 6] mmcblk0rpmb: mmc0:0001 SLD32G partition 3 4.00 MiB [ 2.299044] [0: kworker/u8:0: 6] kworker/u8:0[6]: undefined instruction: pc=ffffffc0003f1d74 [ 2.299054] [0: kworker/u8:0: 6] Code: a8c17bfd d65f03c0 a9bf7bfd 910003fd (00000004) [ 5.800068] [0: kworker/u8:0: 6] Modules linked in: [ 5.807293] [3: swapper/0: 1] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 3.10.104 #1 [ 5.813628] [3: swapper/0: 1] task: ffffffc000060000 ti: ffffffc000068000 task.ti: ffffffc000068000 [ 5.823269] [3: swapper/0: 1] PC is at klist_children_get+0x8/0x18 [ 5.830088] [3: swapper/0: 1] LR is at klist_node_init+0x50/0x5c [ 5.836738] [3: swapper/0: 1] pc : [] lr : [] pstate: 60000105 [ 5.846288] [3: swapper/0: 1] sp : ffffffc00006baf0 [ 5.851831] [3: swapper/0: 1] x29: ffffffc00006baf0 x28: 0000000000000038 [ 5.861506] 00038 swapper/0: 1] x27: 0000000000000000 x26: 0000000000000000 [ 5.869010] 00000 swapper/0: 1] x25: ffffffc005c84800 x24: ffffffc07a3a7200 [ 5.876515] a7200 swapper/0: 1] x23: 0000000000000000 x22: ffffffc000dd8000 [ 5.884020] d8000 swapper/0: 1] x21: ffffffc005c85010 x20: ffffffc079aa6300 [ 5.891524] a6300 swapper/0: 1] x19: ffffffc079aa63e8 x18: 0000000000000000 [ 5.899029] 00000 swapper/0: 1] x17: 0000000000000000 x16: 0000000000000000 [ 5.906533] 00000 swapper/0: 1] x15: 0000000000000000 x14: 0ffffffffffffffe [ 5.914038] ffffe swapper/0: 1] x13: 0000000000000018 x12: 0101010101010101 [ 5.921543] 10101 swapper/0: 1] x11: 7f7f7f7f7f7f7f7f x10: 71636d5fff617274 [ 5.929048] 17274 swapper/0: 1] x9 : 7f7f7f7f7f7f7f7f x8 : 0000000080000000 [ 5.936552] 00000 swapper/0: 1] x7 : ffffffc005c89000 x6 : ffffffc005c89000 [ 5.944057] 89000 swapper/0: 1] x5 : 0000000000000100 x4 : 0000000000000001 [ 5.951561] 00001 swapper/0: 1] x3 : 000000007f05c000 x2 : 000000007f05c000 [ 5.959066] 5c000 swapper/0: 1] x1 : ffffffc0003f1d6c x0 : ffffffc079aa63e8 [ 5.966571] [3: swapper/0: 1] [ 5.966571] [3: swapper/0: 1] PC: 0xffffffc0003f1cf4: [ 5.973866] [3: swapper/0: 1] 1cf4 d63f0060 35fffc20 b0003d56 d2800015 91293ed6 b9410280 6b15001f 54fffb6d [ 5.987692] [3: swapper/0: 1] 1d14 f8757a82 8b1302e0 aa1603e1 910006b5 97fca34f 8b20c273 17fffff7 a94153f3 [ 5.998094] [3: swapper/0: 1] 1d34 a9425bf5 f9401bf7 a8c47bfd d65f03c0 a9bf7bfd d2800001 910003fd b4000080 [ 6.008496] [3: swapper/0: 1] 1d54 91004000 97fc8064 d1004001 aa0103e0 a8c17bfd d65f03c0 a9bf7bfd 910003fd [ 6.018899] [3: swapper/0: 1] 1d74 00000004 97fffff3 a8c17bfd d65f03c0 d65f03c0 910003fd b4000060 91004000 [ 6.029302] [3: swapper/0: 1] 1d94 97fc80ad a8c17bfd d65f03c0 a9bf7bfd 910003fd f9403c00 97fffff6 a8c17bfd [ 6.039704] [3: swapper/0: 1] 1db4 d65f03c0 a9be7bfd 910003fd a90153f3 f9412c01 b4000341 aa0003f4 aa0003f3 [ 6.050107] [3: swapper/0: 1] 1dd4 f8410680 b4000140 f9402e61 d0004aa0 91304000 eb00003f 540000a0 b0003f81 [ 6.060510] [3: swapper/0: 1] [ 6.060510] [3: swapper/0: 1] LR: 0xffffffc0008bdc34: [ 6.066559] [3: swapper/0: 1] dc34 910003fd f9000bf3 f9400401 b40000c1 aa0003f3 aa0103e0 52800001 97ffff9d [ 6.080383] [3: swapper/0: 1] dc54 f900067f f9400bf3 a8c27bfd d65f03c0 a9be7bfd 910003fd a90153f3 aa0003f4 [ 6.090786] [3: swapper/0: 1] dc74 91002020 f9000420 aa0103f3 f9000400 52800020 f9000034 b9001820 360000b4 [ 6.101188] [3: swapper/0: 1] dc94 b0001c60 528007e1 911a6000 97dfa96b f9400e81 b4000061 aa1303e0 d63f0020 [ 6.111591] [3: swapper/0: 1] dcb4 a94153f3 a8c27bfd d65f03c0 a9be7bfd 910003fd a90153f3 aa0003f4 aa0103f3 [ 6.121993] [3: swapper/0: 1] dcd4 aa0103e0 aa1403e1 97ffffe2 aa1303e0 94003147 f9400661 91002280 91002262 [ 6.132396] [3: swapper/0: 1] dcf4 f9000420 f9000681 f9000a82 f9000660 aa1303e0 940031ce a94153f3 a8c27bfd [ 6.142799] [3: swapper/0: 1] dd14 d65f03c0 a9be7bfd 910003fd a90153f3 aa0003f4 aa0103f3 aa0103e0 aa1403e1 [ 6.153202] [3: swapper/0: 1] [ 6.153202] [3: swapper/0: 1] SP: 0xffffffc00006ba70: [ 6.159250] [3: swapper/0: 1] ba70 79aa6300 ffffffc0 05c85010 ffffffc0 00dd8000 ffffffc0 00000000 00000000 [ 6.173075] [3: swapper/0: 1] ba90 7a3a7200 ffffffc0 05c84800 ffffffc0 00000000 00000000 00000000 00000000 [ 6.183478] [3: swapper/0: 1] bab0 00000038 00000000 0006baf0 ffffffc0 008bdcb4 ffffffc0 0006baf0 ffffffc0 [ 6.193880] [3: swapper/0: 1] bad0 003f1d74 ffffffc0 60000105 00000000 05c85010 ffffffc0 05c85000 ffffffc0 [ 6.204283] [3: swapper/0: 1] baf0 0006bb00 ffffffc0 008bdcb4 ffffffc0 0006bb20 ffffffc0 008bdd38 ffffffc0 [ 6.214685] [3: swapper/0: 1] bb10 79aa6300 ffffffc0 79aa63e8 ffffffc0 0006bb40 ffffffc0 003f3224 ffffffc0 [ 6.225088] [3: swapper/0: 1] bb30 05c85000 ffffffc0 00000000 00000000 0006bbb0 ffffffc0 003f3388 ffffffc0 [ 6.235491] [3: swapper/0: 1] bb50 05c85000 ffffffc0 00000000 00000000 0006bc50 ffffffc0 79aa7880 ffffffc0 [ 6.245894] [3: swapper/0: 1] [ 6.245894] [3: swapper/0: 1] X0: 0xffffffc079aa6368: [ 6.251943] [3: swapper/0: 1] 6368 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.265768] [3: swapper/0: 1] 6388 79aa6388 ffffffc0 79aa6388 ffffffc0 05c56600 ffffffc0 05c84800 ffffffc0 [ 6.276171] [3: swapper/0: 1] 63a8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.286573] [3: swapper/0: 1] 63c8 79aa63c8 ffffffc0 79aa63c8 ffffffc0 003f1d6c ffffffc0 003f1da0 ffffffc0 [ 6.296976] [3: swapper/0: 1] 63e8 79aa6300 ffffffc0 79aa63f0 ffffffc0 79aa63f0 ffffffc0 00000001 00000000 [ 6.307378] [3: swapper/0: 1] 6408 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.317781] [3: swapper/0: 1] 6428 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.328183] [3: swapper/0: 1] 6448 79aa6448 ffffffc0 79aa6448 ffffffc0 00e1cad0 ffffffc0 05c85000 ffffffc0 [ 6.338587] [3: swapper/0: 1] [ 6.338587] [3: swapper/0: 1] X1: 0xffffffc0003f1cec: [ 6.344636] [3: swapper/0: 1] 1cec aa1303e0 d2800013 d63f0060 35fffc20 b0003d56 d2800015 91293ed6 b9410280 [ 6.358461] [3: swapper/0: 1] 1d0c 6b15001f 54fffb6d f8757a82 8b1302e0 aa1603e1 910006b5 97fca34f 8b20c273 [ 6.368863] [3: swapper/0: 1] 1d2c 17fffff7 a94153f3 a9425bf5 f9401bf7 a8c47bfd d65f03c0 a9bf7bfd d2800001 [ 6.379266] [3: swapper/0: 1] 1d4c 910003fd b4000080 91004000 97fc8064 d1004001 aa0103e0 a8c17bfd d65f03c0 [ 6.389668] [3: swapper/0: 1] 1d6c a9bf7bfd 910003fd 00000004 97fffff3 a8c17bfd d65f03c0 d65f03c0 910003fd [ 6.400071] [3: swapper/0: 1] 1d8c b4000060 91004000 97fc80ad a8c17bfd d65f03c0 a9bf7bfd 910003fd f9403c00 [ 6.410474] [3: swapper/0: 1] 1dac 97fffff6 a8c17bfd d65f03c0 a9be7bfd 910003fd a90153f3 f9412c01 b4000341 [ 6.420876] [3: swapper/0: 1] 1dcc aa0003f4 aa0003f3 f8410680 b4000140 f9402e61 d0004aa0 91304000 eb00003f [ 6.431281] [3: swapper/0: 1] [ 6.431281] [3: swapper/0: 1] X6: 0xffffffc005c88f80: [ 6.437329] [3: swapper/0: 1] 8f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.451154] [3: swapper/0: 1] 8fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.461557] [3: swapper/0: 1] 8fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.471959] [3: swapper/0: 1] 8fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.482362] [3: swapper/0: 1] 9000 05c8a000 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.492764] [3: swapper/0: 1] 9020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.503167] [3: swapper/0: 1] 9040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.513569] [3: swapper/0: 1] 9060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.523973] [3: swapper/0: 1] [ 6.523973] [3: swapper/0: 1] X7: 0xffffffc005c88f80: [ 6.530022] [3: swapper/0: 1] 8f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.543846] [3: swapper/0: 1] 8fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.554249] [3: swapper/0: 1] 8fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.564652] [3: swapper/0: 1] 8fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.575054] [3: swapper/0: 1] 9000 05c8a000 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.585457] [3: swapper/0: 1] 9020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.595859] [3: swapper/0: 1] 9040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.606262] [3: swapper/0: 1] 9060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.616669] [3: swapper/0: 1] [ 6.616669] [3: swapper/0: 1] X19: 0xffffffc079aa6368: [ 6.622803] [3: swapper/0: 1] 6368 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.636628] [3: swapper/0: 1] 6388 79aa6388 ffffffc0 79aa6388 ffffffc0 05c56600 ffffffc0 05c84800 ffffffc0 [ 6.647030] [3: swapper/0: 1] 63a8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.657433] [3: swapper/0: 1] 63c8 79aa63c8 ffffffc0 79aa63c8 ffffffc0 003f1d6c ffffffc0 003f1da0 ffffffc0 [ 6.667836] [3: swapper/0: 1] 63e8 79aa6300 ffffffc0 79aa63f0 ffffffc0 79aa63f0 ffffffc0 00000001 00000000 [ 6.678238] [3: swapper/0: 1] 6408 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.688641] [3: swapper/0: 1] 6428 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.699043] [3: swapper/0: 1] 6448 79aa6448 ffffffc0 79aa6448 ffffffc0 00e1cad0 ffffffc0 05c85000 ffffffc0 [ 6.709447] [3: swapper/0: 1] [ 6.709447] [3: swapper/0: 1] X20: 0xffffffc079aa6280: [ 6.715581] [3: swapper/0: 1] 6280 00000000 00000000 79aa6288 ffffffc0 79aa6288 ffffffc0 00000000 00000000 [ 6.729406] [3: swapper/0: 1] 62a0 00000000 00000000 7a4c4ad0 ffffffc0 7a4c4ad8 ffffffc0 05b54430 ffffffc0 [ 6.739808] [3: swapper/0: 1] 62c0 00000001 00000000 00000000 00000000 00d4f410 ffffffc0 00000000 00000000 [ 6.750211] [3: swapper/0: 1] 62e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.760613] [3: swapper/0: 1] 6300 00000000 00000000 79aa6308 ffffffc0 79aa6308 ffffffc0 003f1d6c ffffffc0 [ 6.771016] [3: swapper/0: 1] 6320 003f1da0 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.781418] [3: swapper/0: 1] 6340 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.791821] [3: swapper/0: 1] 6360 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.802225] [3: swapper/0: 1] [ 6.802225] [3: swapper/0: 1] X21: 0xffffffc005c84f90: [ 6.808359] [3: swapper/0: 1] 4f90 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.822183] [3: swapper/0: 1] 4fb0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.832586] [3: swapper/0: 1] 4fd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.842989] [3: swapper/0: 1] 4ff0 00000000 00000000 00000000 00000000 05c84800 ffffffc0 79aa63c0 ffffffc0 [ 6.853391] [3: swapper/0: 1] 5010 79aa78c0 ffffffc0 77d5e020 ffffffc0 05c84818 ffffffc0 05c84810 ffffffc0 [ 6.863794] [3: swapper/0: 1] 5030 7a2eca00 ffffffc0 00dd8488 ffffffc0 05c65d90 ffffffc0 00000002 00000007 [ 6.874196] [3: swapper/0: 1] 5050 00000000 00000000 00000000 00000000 00000001 00000000 05c85068 ffffffc0 [ 6.884599] [3: swapper/0: 1] 5070 05c85068 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.895002] [3: swapper/0: 1] [ 6.895002] [3: swapper/0: 1] X22: 0xffffffc000dd7f80: [ 6.901136] [3: swapper/0: 1] 7f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.914961] [3: swapper/0: 1] 7fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.925364] [3: swapper/0: 1] 7fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.935766] [3: swapper/0: 1] 7fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.946169] [3: swapper/0: 1] 8000 2c6d7261 696c616d 00303034 00000000 00000000 00000000 00000000 00000000 [ 6.956571] [3: swapper/0: 1] 8020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.966974] [3: swapper/0: 1] 8040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.977376] [3: swapper/0: 1] 8060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 6.987780] [3: swapper/0: 1] [ 6.987780] [3: swapper/0: 1] X24: 0xffffffc07a3a7180: [ 6.993914] [3: swapper/0: 1] 7180 7a3a7180 ffffffc0 7a3a7180 ffffffc0 00000000 00000000 00000000 00000000 [ 7.007739] [3: swapper/0: 1] 71a0 00000000 00000000 00000000 00000000 7a3a71b0 ffffffc0 7a3a71b0 ffffffc0 [ 7.018142] [3: swapper/0: 1] 71c0 77dfe680 ffffffc0 00000000 00000000 00000000 00000000 00000008 00000000 [ 7.028544] [3: swapper/0: 1] 71e0 00000000 00000000 00000000 00000000 00000000 00000000 05c56200 ffffffc0 [ 7.038947] [3: swapper/0: 1] 7200 00bf2a70 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.049350] [3: swapper/0: 1] 7220 00000000 00000000 7a2f45c0 ffffffc0 00000000 00000000 00000000 00000000 [ 7.059752] [3: swapper/0: 1] 7240 003f61ac ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.070155] [3: swapper/0: 1] 7260 00000000 00000000 00000000 00000000 00000000 00000000 05c56400 ffffffc0 [ 7.080558] [3: swapper/0: 1] [ 7.080558] [3: swapper/0: 1] X25: 0xffffffc005c84780: [ 7.086692] [3: swapper/0: 1] 4780 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.100517] [3: swapper/0: 1] 47a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.110919] [3: swapper/0: 1] 47c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.121322] [3: swapper/0: 1] 47e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.131725] [3: swapper/0: 1] 4800 00000000 00000000 79aa6300 ffffffc0 79aa76c0 ffffffc0 05c85018 ffffffc0 [ 7.142127] [3: swapper/0: 1] 4820 05c84418 ffffffc0 7a3a7280 ffffffc0 7a2eca00 ffffffc0 00dd8488 ffffffc0 [ 7.152530] [3: swapper/0: 1] 4840 05c65380 ffffffc0 00000005 00000007 00000000 00000000 00000000 00000000 [ 7.162932] [3: swapper/0: 1] 4860 00000001 00000000 05c84868 ffffffc0 05c84868 ffffffc0 00000000 00000000 [ 7.173337] [3: swapper/0: 1] [ 7.173337] [3: swapper/0: 1] X29: 0xffffffc00006ba70: [ 7.179472] [3: swapper/0: 1] ba70 79aa6300 ffffffc0 05c85010 ffffffc0 00dd8000 ffffffc0 00000000 00000000 [ 7.193296] [3: swapper/0: 1] ba90 7a3a7200 ffffffc0 05c84800 ffffffc0 00000000 00000000 00000000 00000000 [ 7.203699] [3: swapper/0: 1] bab0 00000038 00000000 0006baf0 ffffffc0 008bdcb4 ffffffc0 0006baf0 ffffffc0 [ 7.214101] [3: swapper/0: 1] bad0 003f1d74 ffffffc0 60000105 00000000 05c85010 ffffffc0 05c85000 ffffffc0 [ 7.224504] [3: swapper/0: 1] baf0 0006bb00 ffffffc0 008bdcb4 ffffffc0 0006bb20 ffffffc0 008bdd38 ffffffc0 [ 7.234907] [3: swapper/0: 1] bb10 79aa6300 ffffffc0 79aa63e8 ffffffc0 0006bb40 ffffffc0 003f3224 ffffffc0 [ 7.245309] [3: swapper/0: 1] bb30 05c85000 ffffffc0 00000000 00000000 0006bbb0 ffffffc0 003f3388 ffffffc0 [ 7.255712] [3: swapper/0: 1] bb50 05c85000 ffffffc0 00000000 00000000 0006bc50 ffffffc0 79aa7880 ffffffc0 [ 7.266114] [3: swapper/0: 1] [ 7.268243] [3: swapper/0: 1] Process swapper/0 (pid: 1, stack limit = 0xffffffc000068058) [ 7.275312] [3: swapper/0: 1] Stack: (0xffffffc00006baf0 to 0xffffffc00006c000) [ 7.283244] [3: swapper/0: 1] bae0: 0006bb00 ffffffc0 008bdcb4 ffffffc0 [ 7.293564] [3: swapper/0: 1] bb00: 0006bb20 ffffffc0 008bdd38 ffffffc0 79aa6300 ffffffc0 79aa63e8 ffffffc0 [ 7.303883] [3: swapper/0: 1] bb20: 0006bb40 ffffffc0 003f3224 ffffffc0 05c85000 ffffffc0 00000000 00000000 [ 7.314202] [3: swapper/0: 1] bb40: 0006bbb0 ffffffc0 003f3388 ffffffc0 05c85000 ffffffc0 00000000 00000000 [ 7.324521] [3: swapper/0: 1] bb60: 0006bc50 ffffffc0 79aa7880 ffffffc0 05c84800 ffffffc0 00000000 00000000 [ 7.334839] [3: swapper/0: 1] bb80: 00000000 00000000 00bf29ff ffffffc0 00e1c560 ffffffc0 05c56600 ffffffc0 [ 7.345158] [3: swapper/0: 1] bba0: 05c85000 ffffffc0 00000000 00000000 0006bbd0 ffffffc0 003f3508 ffffffc0 [ 7.355477] [3: swapper/0: 1] bbc0: 05c85000 ffffffc0 ffffffe8 00000000 0006bc40 ffffffc0 003f3594 ffffffc0 [ 7.365796] [3: swapper/0: 1] bbe0: 00e1cad0 ffffffc0 004e5e68 ffffffc0 00fac000 ffffffc0 7a3a7300 ffffffc0 [ 7.376115] [3: swapper/0: 1] bc00: 77c74008 ffffffc0 05c56600 ffffffc0 0006bcb0 ffffffc0 00e1cad0 ffffffc0 [ 7.386434] [3: swapper/0: 1] bc20: 0006bcb0 ffffffc0 0006bcb0 ffffffc0 0006bc90 ffffffc0 ffffffe8 00000000 [ 7.396753] [3: swapper/0: 1] bc40: 0006bcb0 ffffffc0 00505d3c ffffffc0 0006bcb0 ffffffc0 0006bcb0 ffffffc0 [ 7.407072] [3: swapper/0: 1] bc60: 0006bc90 ffffffc0 ffffffe8 00000000 0006bcb0 ffffffc0 0006bcb0 ffffffc0 [ 7.417390] [3: swapper/0: 1] bc80: 0006bc90 ffffffc0 ffffffe8 00000000 00000000 00000000 6f7264ff 755f6469 [ 7.427709] [3: swapper/0: 1] bca0: ffffffd8 00000000 80800000 00000000 0006bd20 ffffffc0 004fd8d8 ffffffc0 [ 7.438028] [3: swapper/0: 1] bcc0: 7a3a7300 ffffffc0 00000000 00000000 00e1c668 ffffffc0 77c74008 ffffffc0 [ 7.448347] [3: swapper/0: 1] bce0: 00facde0 ffffffc0 00fad128 ffffffc0 00c9e1a0 ffffffc0 00cee4b0 ffffffc0 [ 7.458666] [3: swapper/0: 1] bd00: 00ee1000 ffffffc0 00cf9fd0 ffffffc0 00e1c668 ffffffc0 77c74008 ffffffc0 [ 7.468985] [3: swapper/0: 1] bd20: 0006bd50 ffffffc0 004faf34 ffffffc0 77d9b800 ffffffc0 00e1c668 ffffffc0 [ 7.479304] [3: swapper/0: 1] bd40: 00e1c668 ffffffc0 00fac000 ffffffc0 0006bd80 ffffffc0 004fb03c ffffffc0 [ 7.489623] [3: swapper/0: 1] bd60: 00e1b638 ffffffc0 00e1c668 ffffffc0 00e1c620 ffffffc0 00000000 00000000 [ 7.499942] [3: swapper/0: 1] bd80: 0006bdb0 ffffffc0 004fc4d8 ffffffc0 00e1c620 ffffffc0 00e1c668 ffffffc0 [ 7.510260] [3: swapper/0: 1] bda0: 0006bdb0 ffffffc0 00e1c668 ffffffc0 0006bdd0 ffffffc0 00cc7f3c ffffffc0 [ 7.520579] [3: swapper/0: 1] bdc0: 05c56600 ffffffc0 00000000 00000000 0006be10 ffffffc0 00081550 ffffffc0 [ 7.530898] [3: swapper/0: 1] bde0: 00ee1000 ffffffc0 00c924e0 ffffffc0 00000000 00000000 00cc7de0 ffffffc0 [ 7.541217] [3: swapper/0: 1] be00: 00cee4e8 ffffffc0 00cee540 ffffffc0 0006be50 ffffffc0 00c9e95c ffffffc0 [ 7.551536] [3: swapper/0: 1] be20: 000001dd 00000000 00c924e0 ffffffc0 00ee1000 ffffffc0 00000007 00000000 [ 7.561855] [3: swapper/0: 1] be40: 00cee4e8 ffffffc0 00c96080 ffffffc0 0006beb0 ffffffc0 008bdffc ffffffc0 [ 7.572173] [3: swapper/0: 1] be60: 00ee1000 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.582492] [3: swapper/0: 1] be80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.592811] [3: swapper/0: 1] bea0: 00000000 00000000 00000000 00000000 00000000 00000000 000843a0 ffffffc0 [ 7.603130] [3: swapper/0: 1] bec0: 008bdfe8 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.613449] [3: swapper/0: 1] bee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.623768] [3: swapper/0: 1] bf00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.634087] [3: swapper/0: 1] bf20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.644406] [3: swapper/0: 1] bf40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.654724] [3: swapper/0: 1] bf60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.665043] [3: swapper/0: 1] bf80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.675362] [3: swapper/0: 1] bfa0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.685681] [3: swapper/0: 1] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000005 00000000 [ 7.696000] [3: swapper/0: 1] bfe0: 00000000 00000000 00000000 00000000 ffffffff ffffffff ffffffff ffffffff [ 7.706315] [3: swapper/0: 1] Call trace: [ 7.711010] [3: swapper/0: 1] [] klist_children_get+0x8/0x18 [ 7.718854] [3: swapper/0: 1] [] klist_node_init+0x50/0x5c [ 7.726529] [3: swapper/0: 1] [] klist_add_tail+0x20/0x58 [ 7.734119] [3: swapper/0: 1] [] device_add+0x408/0x550 [ 7.741538] [3: swapper/0: 1] [] device_register+0x1c/0x28 [ 7.749213] [3: swapper/0: 1] [] device_create_vargs+0xa8/0xe8 [ 7.757229] [3: swapper/0: 1] [] device_create+0x4c/0x54 [ 7.764736] [3: swapper/0: 1] [] android_bind+0x9c/0x25c [ 7.772240] [3: swapper/0: 1] [] composite_bind+0x94/0x168 [ 7.779914] [3: swapper/0: 1] [] udc_bind_to_driver+0x38/0xc0 [ 7.787845] [3: swapper/0: 1] [] usb_gadget_probe_driver+0x80/0x9c [ 7.796203] [3: swapper/0: 1] [] usb_composite_probe+0xb4/0xc0 [ 7.804220] [3: swapper/0: 1] [] init+0x15c/0x1e4 [ 7.811127] [3: swapper/0: 1] [] do_one_initcall+0x84/0x120 [ 7.818888] [3: swapper/0: 1] [] kernel_init_freeable+0x1b0/0x24c [ 7.827159] [3: swapper/0: 1] [] kernel_init+0x14/0xcc [ 7.834494] [3: swapper/0: 1] Code: a8c17bfd d65f03c0 a9bf7bfd 910003fd (00000004) [ 7.842765] [0: kworker/u8:0: 6] Internal error: Oops - undefined instruction: 0 [#2] PREEMPT SMP [ 7.842889] [3: swapper/0: 1] ---[ end trace 837bdbef19fd3e2e ]--- [ 7.842915] [3: swapper/0: 1] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b [ 7.842915] [3: swapper/0: 1] [ 7.842959] I[1: swapper/1: 0] CPU1: stopping [ 7.842970] I[1: swapper/1: 0] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 3.10.104 #1 [ 7.842976] I[1: swapper/1: 0] Call trace: [ 7.842986] I[1: swapper/1: 0] [] dump_backtrace+0x0/0x10c [ 7.842995] I[1: swapper/1: 0] [] show_stack+0x14/0x1c [ 7.843004] I[1: swapper/1: 0] [] dump_stack+0x20/0x28 [ 7.843013] I[1: swapper/1: 0] [] handle_IPI+0xc4/0x120 [ 7.843021] I[1: swapper/1: 0] [] gic_handle_irq+0x6c/0x80 [ 7.843028] I[1: swapper/1: 0] Exception stack(0xffffffc07a32bda0 to 0xffffffc07a32bec0) [ 7.843038] I[1: swapper/1: 0] bda0: 7fd41ea0 ffffffc0 00000001 00000000 7a32bee0 ffffffc0 005ec8e0 ffffffc0 [ 7.843048] I[1: swapper/1: 0] bdc0: 9dcc1b49 00000001 65a0bc00 00000001 25c17d03 00000002 29aacadf 00000000 [ 7.843058] I[1: swapper/1: 0] bde0: 00000018 00000000 fd5238b5 00380744 0b6602f2 00000000 00000314 00000000 [ 7.843068] I[1: swapper/1: 0] be00: b5193519 00000032 00083000 ffffffc0 00000000 00000000 00000000 00000000 [ 7.843078] I[1: swapper/1: 0] be20: 34d5d83d 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.843087] I[1: swapper/1: 0] be40: 00000000 00000000 00000000 00000000 00000000 00000000 7fd41ea0 ffffffc0 [ 7.843097] I[1: swapper/1: 0] be60: 00000001 00000000 4dfab6b4 00000000 00000001 00000000 00fb1000 ffffffc0 [ 7.843107] I[1: swapper/1: 0] be80: 00e900f0 ffffffc0 00000001 00000000 00ed9830 ffffffc0 00080220 ffffffc0 [ 7.843117] I[1: swapper/1: 0] bea0: 00200000 00000040 7a32bee0 ffffffc0 005ec8dc ffffffc0 7a32bee0 ffffffc0 [ 7.843125] I[1: swapper/1: 0] [] el1_irq+0x80/0xe4 [ 7.843134] I[1: swapper/1: 0] [] cpuidle_idle_call+0x16c/0x284 [ 7.843143] I[1: swapper/1: 0] [] arch_cpu_idle+0xc/0x20 [ 7.843153] I[1: swapper/1: 0] [] cpu_startup_entry+0x190/0x22c [ 7.843162] I[1: swapper/1: 0] [] secondary_start_kernel+0x128/0x134 [ 7.843169] I[2: swapper/2: 0] CPU2: stopping [ 7.843178] I[2: swapper/2: 0] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 3.10.104 #1 [ 7.843184] I[2: swapper/2: 0] Call trace: [ 7.843194] I[2: swapper/2: 0] [] dump_backtrace+0x0/0x10c [ 7.843202] I[2: swapper/2: 0] [] show_stack+0x14/0x1c [ 7.843211] I[2: swapper/2: 0] [] dump_stack+0x20/0x28 [ 7.843219] I[2: swapper/2: 0] [] handle_IPI+0xc4/0x120 [ 7.843227] I[2: swapper/2: 0] [] gic_handle_irq+0x6c/0x80 [ 7.843234] I[2: swapper/2: 0] Exception stack(0xffffffc07a32fda0 to 0xffffffc07a32fec0) [ 7.843244] I[2: swapper/2: 0] fda0: 7fd4dea0 ffffffc0 00000001 00000000 7a32fee0 ffffffc0 005ec8e0 ffffffc0 [ 7.843254] I[2: swapper/2: 0] fdc0: 9dcc3b2f 00000001 65a0bc00 00000001 25c17d03 00000002 29aacadf 00000000 [ 7.843264] I[2: swapper/2: 0] fde0: 00000018 00000000 fd5238b5 00380744 0b6602f2 00000000 00000314 00000000 [ 7.843273] I[2: swapper/2: 0] fe00: b5193519 00000032 00083000 ffffffc0 00000000 00000000 00000000 00000000 [ 7.843283] I[2: swapper/2: 0] fe20: 34d5d83d 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.843293] I[2: swapper/2: 0] fe40: 00000000 00000000 00000000 00000000 00000000 00000000 7fd4dea0 ffffffc0 [ 7.843302] I[2: swapper/2: 0] fe60: 00000001 00000000 4df78264 00000000 00000001 00000000 00fb1000 ffffffc0 [ 7.843312] I[2: swapper/2: 0] fe80: 00e900f0 ffffffc0 00000001 00000000 00ed9830 ffffffc0 00080220 ffffffc0 [ 7.843322] I[2: swapper/2: 0] fea0: 00200000 00000040 7a32fee0 ffffffc0 005ec8dc ffffffc0 7a32fee0 ffffffc0 [ 7.843330] I[2: swapper/2: 0] [] el1_irq+0x80/0xe4 [ 7.843339] I[2: swapper/2: 0] [] cpuidle_idle_call+0x16c/0x284 [ 7.843347] I[2: swapper/2: 0] [] arch_cpu_idle+0xc/0x20 [ 7.843356] I[2: swapper/2: 0] [] cpu_startup_entry+0x190/0x22c [ 7.843364] I[2: swapper/2: 0] [] secondary_start_kernel+0x128/0x134 [ 8.264814] [2: swapper/2: 0] Modules linked in: [ 8.272039] [0: kworker/u8:0: 6] CPU: 0 PID: 6 Comm: kworker/u8:0 Tainted: G D 3.10.104 #1 [ 8.279572] [0: kworker/u8:0: 6] Workqueue: kmmcd mmc_rescan [ 8.287559] [0: kworker/u8:0: 6] task: ffffffc000063340 ti: ffffffc07a30c000 task.ti: ffffffc07a30c000 [ 8.295262] [0: kworker/u8:0: 6] PC is at klist_children_get+0x8/0x18 [ 8.302083] [0: kworker/u8:0: 6] LR is at klist_node_init+0x50/0x5c [ 8.308734] [0: kworker/u8:0: 6] pc : [] lr : [] pstate: 20000105 [ 8.318285] [0: kworker/u8:0: 6] sp : ffffffc07a30f970 [ 8.323828] [0: kworker/u8:0: 6] x29: ffffffc07a30f970 x28: 0000000000000038 [ 8.333502] 00038 kworker/u8:0: 6] x27: 0000000000000000 x26: ffffffc000d479a8 [ 8.341007] 479a8 kworker/u8:0: 6] x25: ffffffc077d5e008 x24: ffffffc000d47928 [ 8.348511] 47928 kworker/u8:0: 6] x23: 0000000000000000 x22: ffffffc000dd8000 [ 8.356016] d8000 kworker/u8:0: 6] x21: ffffffc005c1e480 x20: ffffffc005b54900 [ 8.363521] 54900 kworker/u8:0: 6] x19: ffffffc005b54c28 x18: 0000000000000000 [ 8.371025] 00000 kworker/u8:0: 6] x17: 0000000000000000 x16: 0000000000000000 [ 8.378530] 00000 kworker/u8:0: 6] x15: 0000000000000000 x14: 0ffffffffffffffe [ 8.386035] ffffe kworker/u8:0: 6] x13: 0000000000000010 x12: 0000000000000030 [ 8.393539] 00030 kworker/u8:0: 6] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f [ 8.401044] f7f7f kworker/u8:0: 6] x9 : 725e646c68736d74 x8 : 7f7f7f7f7f7f7f7f [ 8.408548] f7f7f kworker/u8:0: 6] x7 : 70ff726c5e78606b x6 : 0000000000008000 [ 8.416053] 08000 kworker/u8:0: 6] x5 : 0000000000000000 x4 : ffffffc005c39478 [ 8.423558] 39478 kworker/u8:0: 6] x3 : 0000000000000000 x2 : 0000000000000000 [ 8.431062] 00000 kworker/u8:0: 6] x1 : ffffffc0003f1d6c x0 : ffffffc005b54c28 [ 8.438568] [0: kworker/u8:0: 6] [ 8.438568] [0: kworker/u8:0: 6] PC: 0xffffffc0003f1cf4: [ 8.445863] [0: kworker/u8:0: 6] 1cf4 d63f0060 35fffc20 b0003d56 d2800015 91293ed6 b9410280 6b15001f 54fffb6d [ 8.459688] [0: kworker/u8:0: 6] 1d14 f8757a82 8b1302e0 aa1603e1 910006b5 97fca34f 8b20c273 17fffff7 a94153f3 [ 8.470090] [0: kworker/u8:0: 6] 1d34 a9425bf5 f9401bf7 a8c47bfd d65f03c0 a9bf7bfd d2800001 910003fd b4000080 [ 8.480493] [0: kworker/u8:0: 6] 1d54 91004000 97fc8064 d1004001 aa0103e0 a8c17bfd d65f03c0 a9bf7bfd 910003fd [ 8.490895] [0: kworker/u8:0: 6] 1d74 00000004 97fffff3 a8c17bfd d65f03c0 d65f03c0 910003fd b4000060 91004000 [ 8.501298] [0: kworker/u8:0: 6] 1d94 97fc80ad a8c17bfd d65f03c0 a9bf7bfd 910003fd f9403c00 97fffff6 a8c17bfd [ 8.511701] [0: kworker/u8:0: 6] 1db4 d65f03c0 a9be7bfd 910003fd a90153f3 f9412c01 b4000341 aa0003f4 aa0003f3 [ 8.522103] [0: kworker/u8:0: 6] 1dd4 f8410680 b4000140 f9402e61 d0004aa0 91304000 eb00003f 540000a0 b0003f81 [ 8.532506] [0: kworker/u8:0: 6] [ 8.532506] [0: kworker/u8:0: 6] LR: 0xffffffc0008bdc34: [ 8.538555] [0: kworker/u8:0: 6] dc34 910003fd f9000bf3 f9400401 b40000c1 aa0003f3 aa0103e0 52800001 97ffff9d [ 8.552380] [0: kworker/u8:0: 6] dc54 f900067f f9400bf3 a8c27bfd d65f03c0 a9be7bfd 910003fd a90153f3 aa0003f4 [ 8.562783] [0: kworker/u8:0: 6] dc74 91002020 f9000420 aa0103f3 f9000400 52800020 f9000034 b9001820 360000b4 [ 8.573185] [0: kworker/u8:0: 6] dc94 b0001c60 528007e1 911a6000 97dfa96b f9400e81 b4000061 aa1303e0 d63f0020 [ 8.583588] [0: kworker/u8:0: 6] dcb4 a94153f3 a8c27bfd d65f03c0 a9be7bfd 910003fd a90153f3 aa0003f4 aa0103f3 [ 8.593990] [0: kworker/u8:0: 6] dcd4 aa0103e0 aa1403e1 97ffffe2 aa1303e0 94003147 f9400661 91002280 91002262 [ 8.604393] [0: kworker/u8:0: 6] dcf4 f9000420 f9000681 f9000a82 f9000660 aa1303e0 940031ce a94153f3 a8c27bfd [ 8.614796] [0: kworker/u8:0: 6] dd14 d65f03c0 a9be7bfd 910003fd a90153f3 aa0003f4 aa0103f3 aa0103e0 aa1403e1 [ 8.625199] [0: kworker/u8:0: 6] [ 8.625199] [0: kworker/u8:0: 6] SP: 0xffffffc07a30f8f0: [ 8.631248] [0: kworker/u8:0: 6] f8f0 05b54900 ffffffc0 05c1e480 ffffffc0 00dd8000 ffffffc0 00000000 00000000 [ 8.645073] [0: kworker/u8:0: 6] f910 00d47928 ffffffc0 77d5e008 ffffffc0 00d479a8 ffffffc0 00000000 00000000 [ 8.655475] [0: kworker/u8:0: 6] f930 00000038 00000000 7a30f970 ffffffc0 008bdcb4 ffffffc0 7a30f970 ffffffc0 [ 8.665878] [0: kworker/u8:0: 6] f950 003f1d74 ffffffc0 20000105 00000000 05c1e480 ffffffc0 05c1e470 ffffffc0 [ 8.676280] [0: kworker/u8:0: 6] f970 7a30f980 ffffffc0 008bdcb4 ffffffc0 7a30f9a0 ffffffc0 008bdd38 ffffffc0 [ 8.686683] [0: kworker/u8:0: 6] f990 05b54900 ffffffc0 05b54c28 ffffffc0 7a30f9c0 ffffffc0 003f3224 ffffffc0 [ 8.697085] [0: kworker/u8:0: 6] f9b0 05c1e470 ffffffc0 00000000 00000000 7a30fa30 ffffffc0 00303900 ffffffc0 [ 8.707488] [0: kworker/u8:0: 6] f9d0 05c1e400 ffffffc0 05c1e470 ffffffc0 05c1e480 ffffffc0 77ce4360 ffffffc0 [ 8.717892] [0: kworker/u8:0: 6] [ 8.717892] [0: kworker/u8:0: 6] X0: 0xffffffc005b54ba8: [ 8.723940] [0: kworker/u8:0: 6] 4ba8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 8.737765] [0: kworker/u8:0: 6] 4bc8 05b54bc8 ffffffc0 05b54bc8 ffffffc0 77ce4360 ffffffc0 05c94800 ffffffc0 [ 8.748168] [0: kworker/u8:0: 6] 4be8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 8.758570] [0: kworker/u8:0: 6] 4c08 05b54c08 ffffffc0 05b54c08 ffffffc0 003f1d6c ffffffc0 003f1da0 ffffffc0 [ 8.768973] [0: kworker/u8:0: 6] 4c28 05b54900 ffffffc0 05b54c30 ffffffc0 05b54c30 ffffffc0 00000001 00000000 [ 8.779375] [0: kworker/u8:0: 6] 4c48 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 8.789778] [0: kworker/u8:0: 6] 4c68 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 8.800180] [0: kworker/u8:0: 6] 4c88 05b54c88 ffffffc0 05b54c88 ffffffc0 00000000 00000000 05c1e470 ffffffc0 [ 8.810584] [0: kworker/u8:0: 6] [ 8.810584] [0: kworker/u8:0: 6] X1: 0xffffffc0003f1cec: [ 8.816633] [0: kworker/u8:0: 6] 1cec aa1303e0 d2800013 d63f0060 35fffc20 b0003d56 d2800015 91293ed6 b9410280 [ 8.830458] [0: kworker/u8:0: 6] 1d0c 6b15001f 54fffb6d f8757a82 8b1302e0 aa1603e1 910006b5 97fca34f 8b20c273 [ 8.840860] [0: kworker/u8:0: 6] 1d2c 17fffff7 a94153f3 a9425bf5 f9401bf7 a8c47bfd d65f03c0 a9bf7bfd d2800001 [ 8.851263] [0: kworker/u8:0: 6] 1d4c 910003fd b4000080 91004000 97fc8064 d1004001 aa0103e0 a8c17bfd d65f03c0 [ 8.861665] [0: kworker/u8:0: 6] 1d6c a9bf7bfd 910003fd 00000004 97fffff3 a8c17bfd d65f03c0 d65f03c0 910003fd [ 8.872068] [0: kworker/u8:0: 6] 1d8c b4000060 91004000 97fc80ad a8c17bfd d65f03c0 a9bf7bfd 910003fd f9403c00 [ 8.882471] [0: kworker/u8:0: 6] 1dac 97fffff6 a8c17bfd d65f03c0 a9be7bfd 910003fd a90153f3 f9412c01 b4000341 [ 8.892873] [0: kworker/u8:0: 6] 1dcc aa0003f4 aa0003f3 f8410680 b4000140 f9402e61 d0004aa0 91304000 eb00003f [ 8.903277] [0: kworker/u8:0: 6] [ 8.903277] [0: kworker/u8:0: 6] X4: 0xffffffc005c393f8: [ 8.909326] [0: kworker/u8:0: 6] 93f8 05c392a0 ffffffc0 00bc9e26 ffffffc0 05c39329 ffffffc0 00000000 00000000 [ 8.923151] [0: kworker/u8:0: 6] 9418 00000000 00000000 00000000 00000000 00000000 00000000 6e8620da 00000000 [ 8.933554] [0: kworker/u8:0: 6] 9438 00dd9118 ffffffc0 00000000 00000000 00000000 00000000 81240002 000038d7 [ 8.943956] [0: kworker/u8:0: 6] 9458 00000000 00000000 00000001 00000000 05c392a0 ffffffc0 00bc9e3d ffffffc0 [ 8.954359] [0: kworker/u8:0: 6] 9478 05c39329 ffffffc0 05c394e8 ffffffc0 05c39398 ffffffc0 00000000 00000000 [ 8.964761] [0: kworker/u8:0: 6] 9498 00000000 00000000 515701fa 00000000 00dd9138 ffffffc0 00000000 00000000 [ 8.975164] [0: kworker/u8:0: 6] 94b8 00000000 00000000 81240002 000038d8 00000000 00000000 00000001 00000000 [ 8.985566] [0: kworker/u8:0: 6] 94d8 05c392a0 ffffffc0[ 8.990927] [3: swapper/0: 1] SMP: failed to stop secondary CPUs [ 8.990933] [3: per/094 1[3:00 swapper/0: 1] 000000 0: 8.901061 0 [3:44 00000p01r00: 0 00] 0000002 0000001058 000010 1 000000 00000000 00000000 0000000 00.900005]0 [3:00 swapper/0: 1] 00000[6 0.9011e8 0 00: 58 08wappe 00: 00 000000060: 000001 0000000450000000eb8 00000000 00000000 00000000 00.99100 00 [000 swapper/0: 1] 000000 : 0099101f 000458 bwa22er00:00 1 0000000 : 000000 0 000000 8 000000 d 00000000 00000000 000000 00990008]00[00 swapper/0: 1] 000000e0 0.091001] 000000 s0appe /0: 001]0000000e000000000000000000000000000 0 00000000 00000000 00000[ 4 8.90105 00 [3:09 swapper/0: 1] 000001 : 80901000 933d 00swa02f 00: 014 00000012 0 00000400000927f 9 0100002 00010014 0000002f 0001000 8.0910f ] [001 swapper/0: 1] 000001 0: 8.901017 0 [3020 0swa3per/000 711] 0004116000000017 00000202 0 000005 00000711 00004107 00000[ 3 80091979]00000 swapper/0: 1] 000001 8.909126 0bb3: 60 00wa11f 00: 0b] 000001a 000000951000008e0 0 000031 0000000b 00000042 00000[ 0 8.00010 ] 003: 0 swapper/0: 1] 000001e 00001100] 000 0 000wa00er/0: 001] 000001e : 000000 0 000000 000000000 00000000 00000000 000000 0000016600 0000 swapper/0: 1] 0000022 00091100 00[3:000 sw00pe 00: 0101 00000220: 000000 00000000000000000 00000101 00000000 00000[ 8.00100 ] 000: swapper/0: 1] 000002 0: 80091200 03: 0 00swa00er/000 0 00000000 : 000000 0000000000 0000000 00000000 00000000 000000 00.900009000[3:00 swapper/0: 1] 000002a 00900232 0 [000 000wa000r00000 0 000002a0:0000000 0 00000000000000000 00000000 00000000 000000 00.00020 ] 03000 swapper/0: 1] 000002e 80990058] 00: 0 0w0000r/0:0 1 00000000 : 000000 0000000000 000000 0 00000000 00000000 00000[ 0 0.99007 00 03000 swapper/0: 1] 00000[20: 80001005]0 [3:000 000wa00er/0: 0000] 00000300: 000000 0 00000000 00000000 00000000 00000000 000000 0009902080 0[3:00 swapper/0: 1] 00000360 00990300 0 [300 00swap00r/000 000 00000060: 000000 00000000 0 000000 0 00000000 00000000 00000[ 08.00032 00 [000 swapper/0: 1] 000003a : 00090037]00[3:0 0 sw000er/000 000] 000000a000000000 0 000000 0 0000000 00000000 00000000 00000000 8.09100 0 [000 swapper/0: 1] 00000[ 00991300 [0: 00 000appe 00: 001] 0000000 0 000000 0 00000000 0000000 00000000 00000000 00000[ 8.001376]00[000 swapper/0: 1] 000004ip th.991l f]2503: .ts sw cpe /0:nn l1] mockchuret23 mal f2000000ts0000 c0 channal temperature(23 C) 8.991394] [3: sw[ppe /.9 7] 0[000 : 0wapper/0: 1] 00000000: 00 b.9014100 [0: 0000 000per/0 0 0 1000 00000000000000b000000000000 000000 00000000 00000000[ 00 8.001400]00[3 00 00 sw per/0: 1] 00000040: 00 08.9900000 4 3: 000 swa00er32 00 1]0000000600 000000000 0000004 000000fa 00000032 00000000[ 00 0.99140000 00 00 0wapper/0: 1] 00000080: 0 00b000 20000000 ffffffc0 05c39478 ffffffc0 00000000 00000000 [ 9.253741] [0: kworker/u8:0: 6] [ 9.253741] [0: kworker/u8:0: 6] X19: 0xffffffc005b54ba8: [ 9.259875] [0: kworker/u8:0: 6] 4ba8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.273700] [0: kworker/u8:0: 6] 4bc8 05b54bc8 ffffffc0 05b54bc8 ffffffc0 77ce4360 ffffffc0 05c94800 ffffffc0 [ 9.284102] [0: kworker/u8:0: 6] 4be8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.294505] [0: kworker/u8:0: 6] 4c08 05b54c08 ffffffc0 05b54c08 ffffffc0 003f1d6c ffffffc0 003f1da0 ffffffc0 [ 9.304908] [0: kworker/u8:0: 6] 4c28 05b54900 ffffffc0 05b54c30 ffffffc0 05b54c30 ffffffc0 00000001 00000000 [ 9.315310] [0: kworker/u8:0: 6] 4c48 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.325712] [0: kworker/u8:0: 6] 4c68 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.336115] [0: kworker/u8:0: 6] 4c88 05b54c88 ffffffc0 05b54c88 ffffffc0 00000000 00000000 05c1e470 ffffffc0 [ 9.346519] [0: kworker/u8:0: 6] [ 9.346519] [0: kworker/u8:0: 6] X20: 0xffffffc005b54880: [ 9.352653] [0: kworker/u8:0: 6] 4880 ffffffff 0000001f 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.366478] [0: kworker/u8:0: 6] 48a0 00000000 00000000 00000000 00000000 00000000 00000000 05b52e40 ffffffc0 [ 9.376881] [0: kworker/u8:0: 6] 48c0 00d247e0 ffffffc0 00d24848 ffffffc0 00d26150 ffffffc0 00000000 00000000 [ 9.387283] [0: kworker/u8:0: 6] 48e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.397686] [0: kworker/u8:0: 6] 4900 00000000 00000000 05b54908 ffffffc0 05b54908 ffffffc0 003f1d6c ffffffc0 [ 9.408088] [0: kworker/u8:0: 6] 4920 003f1da0 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.418491] [0: kworker/u8:0: 6] 4940 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.428893] [0: kworker/u8:0: 6] 4960 00000000 00000000 79ad66a8 ffffffc0 79ad66b0 ffffffc0 79ad66b0 ffffffc0 [ 9.439297] [0: kworker/u8:0: 6] [ 9.439297] [0: kworker/u8:0: 6] X21: 0xffffffc005c1e400: [ 9.445432] [0: kworker/u8:0: 6] e400 000000b3 00000000 00000020 62636d6d 00306b6c 00000000 00000000 00000000 [ 9.459256] [0: kworker/u8:0: 6] e420 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.469659] [0: kworker/u8:0: 6] e440 05c38080 ffffffc0 00000000 00000000 039d0000 00000000 00000000 00000000 [ 9.480061] [0: kworker/u8:0: 6] e460 00000000 00000000 00000000 00000000 77d5e008 ffffffc0 05b54c00 ffffffc0 [ 9.490464] [0: kworker/u8:0: 6] e480 05c38400 ffffffc0 7a2eca00 ffffffc0 05c94818 ffffffc0 05b6fd00 ffffffc0 [ 9.500867] [0: kworker/u8:0: 6] e4a0 7a2eca00 ffffffc0 00dd8488 ffffffc0 05bdbaf0 ffffffc0 00000002 00000013 [ 9.511269] [0: kworker/u8:0: 6] e4c0 00000000 00000000 00d479a8 ffffffc0 00000001 00000000 05c1e4d8 ffffffc0 [ 9.521671] [0: kworker/u8:0: 6] e4e0 05c1e4d8 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.532075] [0: kworker/u8:0: 6] [ 9.532075] [0: kworker/u8:0: 6] X22: 0xffffffc000dd7f80: [ 9.538209] [0: kworker/u8:0: 6] 7f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.552034] [0: kworker/u8:0: 6] 7fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.562437] [0: kworker/u8:0: 6] 7fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.572839] [0: kworker/u8:0: 6] 7fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.583242] [0: kworker/u8:0: 6] 8000 2c6d7261 696c616d 00303034 00000000 00000000 00000000 00000000 00000000 [ 9.593644] [0: kworker/u8:0: 6] 8020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.604047] [0: kworker/u8:0: 6] 8040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.614449] [0: kworker/u8:0: 6] 8060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.624853] [0: kworker/u8:0: 6] [ 9.624853] [0: kworker/u8:0: 6] X24: 0xffffffc000d478a8: [ 9.630987] [0: kworker/u8:0: 6] 78a8 002fd320 ffffffc0 002fcec4 ffffffc0 00b990bd ffffffc0 000001a4 00000000 [ 9.644812] [0: kworker/u8:0: 6] 78c8 002fd358 ffffffc0 002fce90 ffffffc0 00bb23a4 ffffffc0 000001a4 00000000 [ 9.655215] [0: kworker/u8:0: 6] 78e8 002fd374 ffffffc0 002fd3e4 ffffffc0 00000001 00000000 00000001 00000000 [ 9.665617] [0: kworker/u8:0: 6] 7908 00d47908 ffffffc0 00d47908 ffffffc0 00000000 00000000 00000000 00000000 [ 9.676020] [0: kworker/u8:0: 6] 7928 00ba3a7d ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.686422] [0: kworker/u8:0: 6] 7948 00000000 00000000 7a2f4500 ffffffc0 00000000 00000000 00000000 00000000 [ 9.696825] [0: kworker/u8:0: 6] 7968 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.707228] [0: kworker/u8:0: 6] 7988 00000000 00000000 00000000 00000000 00000000 00000000 79a2d000 ffffffc0 [ 9.717631] [0: kworker/u8:0: 6] [ 9.717631] [0: kworker/u8:0: 6] X25: 0xffffffc077d5df88: [ 9.723766] [0: kworker/u8:0: 6] df88 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.737590] [0: kworker/u8:0: 6] dfa8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.747993] [0: kworker/u8:0: 6] dfc8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.758396] [0: kworker/u8:0: 6] dfe8 00000000 00000000 00000000 00000000 00000000 00000000 77dd1800 ffffffc0 [ 9.768798] [0: kworker/u8:0: 6] e008 77dd1808 ffffffc0 05b54900 ffffffc0 05b52e80 ffffffc0 05c94818 ffffffc0 [ 9.779201] [0: kworker/u8:0: 6] e028 05c85018 ffffffc0 77dd1818 ffffffc0 7a2eca00 ffffffc0 00dd8488 ffffffc0 [ 9.789603] [0: kworker/u8:0: 6] e048 05bda690 ffffffc0 00000005 00000007 00000000 00000000 00e905f8 ffffffc0 [ 9.800006] [0: kworker/u8:0: 6] e068 00000000 00000000 77d5e070 ffffffc0 77d5e070 ffffffc0 00063340 ffffffc0 [ 9.810410] [0: kworker/u8:0: 6] [ 9.810410] [0: kworker/u8:0: 6] X26: 0xffffffc000d47928: [ 9.816543] [0: kworker/u8:0: 6] 7928 00ba3a7d ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.830368] [0: kworker/u8:0: 6] 7948 00000000 00000000 7a2f4500 ffffffc0 00000000 00000000 00000000 00000000 [ 9.840771] [0: kworker/u8:0: 6] 7968 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 9.851173] [0: kworker/u8:0: 6] 7988 00000000 00000000 00000000 00000000 00000000 00000000 79a2d000 ffffffc0 [ 9.861576] [0: kworker/u8:0: 6] 79a8 00beadd4 ffffffc0 00d47a30 ffffffc0 00302bbc ffffffc0 00302134 ffffffc0 [ 9.871979] [0: kworker/u8:0: 6] 79c8 00303b80 ffffffc0 00000000 00000000 00912138 ffffffc0 00912118 ffffffc0 [ 9.882381] [0: kworker/u8:0: 6] 79e8 009120f8 ffffffc0 00000000 00000000 00000001 00000000 00d47a00 ffffffc0 [ 9.892783] [0: kworker/u8:0: 6] 7a08 00d47a00 ffffffc0 00000000 00000000 00000000 00000000 00d47a20 ffffffc0 [ 9.903188] [0: kworker/u8:0: 6] [ 9.903188] [0: kworker/u8:0: 6] X29: 0xffffffc07a30f8f0: [ 9.909322] [0: kworker/u8:0: 6] f8f0 05b54900 ffffffc0 05c1e480 ffffffc0 00dd8000 ffffffc0 00000000 00000000 [ 9.923147] [0: kworker/u8:0: 6] f910 00d47928 ffffffc0 77d5e008 ffffffc0 00d479a8 ffffffc0 00000000 00000000 [ 9.933549] [0: kworker/u8:0: 6] f930 00000038 00000000 7a30f970 ffffffc0 008bdcb4 ffffffc0 7a30f970 ffffffc0 [ 9.943952] [0: kworker/u8:0: 6] f950 003f1d74 ffffffc0 20000105 00000000 05c1e480 ffffffc0 05c1e470 ffffffc0 [ 9.954355] [0: kworker/u8:0: 6] f970 7a30f980 ffffffc0 008bdcb4 ffffffc0 7a30f9a0 ffffffc0 008bdd38 ffffffc0 [ 9.964757] [0: kworker/u8:0: 6] f990 05b54900 ffffffc0 05b54c28 ffffffc0 7a30f9c0 ffffffc0 003f3224 ffffffc0 [ 9.975160] [0: kworker/u8:0: 6] f9b0 05c1e470 ffffffc0 00000000 00000000 7a30fa30 ffffffc0 00303900 ffffffc0 [ 9.985562] [0: kworker/u8:0: 6] f9d0 05c1e400 ffffffc0 05c1e470 ffffffc0 05c1e480 ffffffc0 77ce4360 ffffffc0 [ 9.995965] [0: kworker/u8:0: 6] [ 9.998093] [0: kworker/u8:0: 6] Process kworker/u8:0 (pid: 6, stack limit = 0xffffffc07a30c058) [ 10.005418] [0: kworker/u8:0: 6] Stack: (0xffffffc07a30f970 to 0xffffffc07a310000) [ 10.013351] [0: kworker/u8:0: 6] f960: 7a30f980 ffffffc0 008bdcb4 ffffffc0 [ 10.023671] [0: kworker/u8:0: 6] f980: 7a30f9a0 ffffffc0 008bdd38 ffffffc0 05b54900 ffffffc0 05b54c28 ffffffc0 [ 10.033990] [0: kworker/u8:0: 6] f9a0: 7a30f9c0 ffffffc0 003f3224 ffffffc0 05c1e470 ffffffc0 00000000 00000000 [ 10.044309] [0: kworker/u8:0: 6] f9c0: 7a30fa30 ffffffc0 00303900 ffffffc0 05c1e400 ffffffc0 05c1e470 ffffffc0 [ 10.054628] [0: kworker/u8:0: 6] f9e0: 05c1e480 ffffffc0 77ce4360 ffffffc0 05c1e40c ffffffc0 77d5e2d0 ffffffc0 [ 10.064946] [0: kworker/u8:0: 6] fa00: 00000001 00000000 05c0e3d8 ffffffc0 00c15c89 ffffffc0 00000003 00000000 [ 10.075265] [0: kworker/u8:0: 6] fa20: 3a393731 ffff0030 003031f8 ffffffc0 7a30faa0 ffffffc0 005fdeb4 ffffffc0 [ 10.085584] [0: kworker/u8:0: 6] fa40: 05c0e000 ffffffc0 05c0e000 ffffffc0 05c0e408 ffffffc0 77d5e000 ffffffc0 [ 10.095903] [0: kworker/u8:0: 6] fa60: 77d5e484 ffffffc0 77d5e2d0 ffffffc0 00000001 00000000 7a30fad0 ffffffc0 [ 10.106222] [0: kworker/u8:0: 6] fa80: 7a30fa90 0b300000 ffffffc8 00000000 7a30fad0 ffffffc0 005fe368 ffffffc0 [ 10.116541] [0: kworker/u8:0: 6] faa0: 7a30fad0 ffffffc0 005fe398 ffffffc0 77d5e000 ffffffc0 05c0e000 ffffffc0 [ 10.126860] [0: kworker/u8:0: 6] fac0: 77d5e008 ffffffc0 05c0e800 ffffffc0 7a30fb50 ffffffc0 005f1d34 ffffffc0 [ 10.137179] [0: kworker/u8:0: 6] fae0: 77d5e008 ffffffc0 00000000 00000000 00e90c68 ffffffc0 00fa6000 ffffffc0 [ 10.147498] [0: kworker/u8:0: 6] fb00: 00dd8000 ffffffc0 00000001 00000000 77dd1808 ffffffc0 00e905f8 ffffffc0 [ 10.157816] [0: kworker/u8:0: 6] fb20: 00000089 00000000 00000000 00000000 392e3832 42694720 003f5700 ffffffc0 [ 10.168135] [0: kworker/u8:0: 6] fb40: 30302e34 42694d20 00000000 00000000 7a30fb60 ffffffc0 003f5748 ffffffc0 [ 10.178454] [0: kworker/u8:0: 6] fb60: 7a30fbb0 ffffffc0 003f58dc ffffffc0 00e90c68 ffffffc0 77d5e008 ffffffc0 [ 10.188773] [0: kworker/u8:0: 6] fb80: 003f58b0 ffffffc0 00dd8000 ffffffc0 00fa6000 ffffffc0 00000000 00000000 [ 10.199092] [0: kworker/u8:0: 6] fba0: 77dd1808 ffffffc0 77d5e008 ffffffc0 7a30fbd0 ffffffc0 003f3c48 ffffffc0 [ 10.209411] [0: kworker/u8:0: 6] fbc0: 00000000 00000000 77d5e008 ffffffc0 7a30fc10 ffffffc0 003f5628 ffffffc0 [ 10.219730] [0: kworker/u8:0: 6] fbe0: 77d5e008 ffffffc0 00e904b8 ffffffc0 77d5e068 ffffffc0 003f55d8 ffffffc0 [ 10.230049] [0: kworker/u8:0: 6] fc00: 79ad66d0 ffffffc0 77b9fba8 ffffffc0 7a30fc40 ffffffc0 003f4ba0 ffffffc0 [ 10.240368] [0: kworker/u8:0: 6] fc20: 77d5e008 ffffffc0 00e904b8 ffffffc0 77d5e008 ffffffc0 00c47d50 ffffffc0 [ 10.250686] [0: kworker/u8:0: 6] fc40: 7a30fc70 ffffffc0 003f3210 ffffffc0 77d5e008 ffffffc0 00000000 00000000 [ 10.261005] [0: kworker/u8:0: 6] fc60: 77d5e018 ffffffc0 003f3208 ffffffc0 7a30fce0 ffffffc0 005f2320 ffffffc0 [ 10.271324] [0: kworker/u8:0: 6] fc80: 77d5e000 ffffffc0 77d5e008 ffffffc0 00000000 00000000 00000000 00000000 [ 10.281643] [0: kworker/u8:0: 6] fca0: 00996f48 ffffffc0 00061a80 00000000 00000000 00000000 00013018 ffffffc0 [ 10.291962] [0: kworker/u8:0: 6] fcc0: 00000089 00000000 00000000 00000000 7a30fce0 ffffffc0 005f2318 ffffffc0 [ 10.302280] [0: kworker/u8:0: 6] fce0: 7a30fd00 ffffffc0 005f4dc4 ffffffc0 77dd1800 ffffffc0 00000000 00000000 [ 10.312600] [0: kworker/u8:0: 6] fd00: 7a30fd30 ffffffc0 005f18c4 ffffffc0 77dd1800 ffffffc0 77dd1b60 ffffffc0 [ 10.322919] [0: kworker/u8:0: 6] fd20: 00000000 00000000 7a30fc70 40ff8080 7a30fd80 ffffffc0 000c3540 ffffffc0 [ 10.333237] [0: kworker/u8:0: 6] fd40: 00026700 ffffffc0 77dd1b60 ffffffc0 00013000 ffffffc0 00000000 00000000 [ 10.343556] [0: kworker/u8:0: 6] fd60: 79a31500 ffffffc0 00ed9038 ffffffc0 7a30fd80 ffffffc0 000c34bc ffffffc0 [ 10.353875] [0: kworker/u8:0: 6] fd80: 7a30fdd0 ffffffc0 000c46a4 ffffffc0 00026700 ffffffc0 00ed8912 ffffffc0 [ 10.364194] [0: kworker/u8:0: 6] fda0: 00013000 ffffffc0 00b8fef9 ffffffc0 00026730 ffffffc0 7a30c000 ffffffc0 [ 10.374513] [0: kworker/u8:0: 6] fdc0: 00013000 ffffffc0 00013018 ffffffc0 7a30fe30 ffffffc0 000c9c18 ffffffc0 [ 10.384832] [0: kworker/u8:0: 6] fde0: 0006bb10 ffffffc0 00f69d10 ffffffc0 00b8e654 ffffffc0 00026700 ffffffc0 [ 10.395151] [0: kworker/u8:0: 6] fe00: 000c449c ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 10.405469] [0: kworker/u8:0: 6] fe20: 00000000 00000000 00026700 ffffffc0 00000000 00000000 000843a0 ffffffc0 [ 10.415788] [0: kworker/u8:0: 6] fe40: 000c9b68 ffffffc0 0006bb10 ffffffc0 00000000 00000000 00000000 00000000 [ 10.426107] [0: kworker/u8:0: 6] fe60: 00000000 00000000 000d7554 ffffffc0 7fd36d40 ffffffc0 00000000 00000000 [ 10.436426] [0: kworker/u8:0: 6] fe80: 00000000 00000000 00026700 ffffffc0 00000000 ffffffff 00000000 ffffffff [ 10.446745] [0: kworker/u8:0: 6] fea0: 7a30fea0 ffffffc0 7a30fea0 ffffffc0 00000000 ffffffc0 00000000 ffffffff [ 10.457064] [0: kworker/u8:0: 6] fec0: 7a30fec0 ffffffc0 7a30fec0 ffffffc0 00000000 00000000 00000000 00000000 [ 10.467382] [0: kworker/u8:0: 6] fee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 10.477701] [0: kworker/u8:0: 6] ff00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 10.488020] [0: kworker/u8:0: 6] ff20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 10.498339] [0: kworker/u8:0: 6] ff40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 10.508658] [0: kworker/u8:0: 6] ff60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 10.518977] [0: kworker/u8:0: 6] ff80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 10.529296] [0: kworker/u8:0: 6] ffa0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 10.539615] [0: kworker/u8:0: 6] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000005 00000000 [ 10.549934] [0: kworker/u8:0: 6] ffe0: 00000000 00000000 00000000 00000000 ffffffff ffffffff ffffffff ffffffff [ 10.560248] [0: kworker/u8:0: 6] Call trace: [ 10.564943] [0: kworker/u8:0: 6] [] klist_children_get+0x8/0x18 [ 10.572787] [0: kworker/u8:0: 6] [] klist_node_init+0x50/0x5c [ 10.580462] [0: kworker/u8:0: 6] [] klist_add_tail+0x20/0x58 [ 10.588052] [0: kworker/u8:0: 6] [] device_add+0x408/0x550 [ 10.595473] [0: kworker/u8:0: 6] [] add_disk+0x1c0/0x3e4 [ 10.602722] [0: kworker/u8:0: 6] [] mmc_add_disk+0x24/0x100 [ 10.610226] [0: kworker/u8:0: 6] [] mmc_blk_probe+0x220/0x2a4 [ 10.617901] [0: kworker/u8:0: 6] [] mmc_bus_probe+0x18/0x20 [ 10.625405] [0: kworker/u8:0: 6] [] driver_probe_device+0xd8/0x240 [ 10.633506] [0: kworker/u8:0: 6] [] __device_attach+0x2c/0x4c [ 10.641182] [0: kworker/u8:0: 6] [] bus_for_each_drv+0x70/0x8c [ 10.648942] [0: kworker/u8:0: 6] [] device_attach+0x70/0x9c [ 10.656447] [0: kworker/u8:0: 6] [] bus_probe_device+0x2c/0xa0 [ 10.664207] [0: kworker/u8:0: 6] [] device_add+0x3f4/0x550 [ 10.671627] [0: kworker/u8:0: 6] [] mmc_add_card+0x1e4/0x200 [ 10.679217] [0: kworker/u8:0: 6] [] mmc_attach_mmc+0x124/0x198 [ 10.686978] [0: kworker/u8:0: 6] [] mmc_rescan+0x274/0x304 [ 10.694398] [0: kworker/u8:0: 6] [] process_one_work+0x288/0x448 [ 10.702328] [0: kworker/u8:0: 6] [] worker_thread+0x208/0x358 [ 10.710003] [0: kworker/u8:0: 6] [] kthread+0xb0/0xb8 [ 10.716996] [0: kworker/u8:0: 6] Code: a8c17bfd d65f03c0 a9bf7bfd 910003fd (00000004) [ 10.725267] I[0: kworker/u8:0: 6] CPU0: stopping [ 10.730214] I[0: kworker/u8:0: 6] CPU: 0 PID: 6 Comm: kworker/u8:0 Tainted: G D 3.10.104 #1 [ 10.739681] [0: kworker/u8:0: 6] Workqueue: kmmcd mmc_rescan [ 10.747668] I[0: kworker/u8:0: 6] Call trace: [ 10.750426] I[0: kworker/u8:0: 6] [] dump_backtrace+0x0/0x10c [ 10.758016] I[0: kworker/u8:0: 6] [] show_stack+0x14/0x1c [ 10.765265] I[0: kworker/u8:0: 6] [] dump_stack+0x20/0x28 [ 10.772513] I[0: kworker/u8:0: 6] [] handle_IPI+0xc4/0x120 [ 10.779847] I[0: kworker/u8:0: 6] [] gic_handle_irq+0x6c/0x80 [ 10.787436] I[0: kworker/u8:0: 6] Exception stack(0xffffffc07a30f600 to 0xffffffc07a30f720) [ 10.796052] I[0: kworker/u8:0: 6] f600: 7a30f850 ffffffc0 00ee1000 ffffffc0 7a30f740 ffffffc0 008ca4d4 ffffffc0 [ 10.806371] I[0: kworker/u8:0: 6] f620: 00ee1170 ffffffc0 00000002 00000000 00000080 00000000 00000080 00000000 [ 10.816690] I[0: kworker/u8:0: 6] f640: 00000000 00000000 7a5d0848 ffffffc0 00ee4cbe ffffffc0 64666237 30313920 [ 10.827009] I[0: kworker/u8:0: 6] f660: 66333030 30282064 7f7f7f7f 7f7f7f7f fefefeff fefeff04 7f7f7f7f 7f7f7f7f [ 10.837327] I[0: kworker/u8:0: 6] f680: 01010101 01010101 00000000 00000000 fffffffe 0fffffff 00000000 00000000 [ 10.847646] I[0: kworker/u8:0: 6] f6a0: 00000000 00000000 00000000 00000000 00000000 00000000 7a30f850 ffffffc0 [ 10.857965] I[0: kworker/u8:0: 6] f6c0: 00ee1000 ffffffc0 00b87f4f ffffffc0 00063340 ffffffc0 00000001 00000000 [ 10.868284] I[0: kworker/u8:0: 6] f6e0: 00b87fb2 ffffffc0 77d5e008 ffffffc0 00d479a8 ffffffc0 00000000 00000000 [ 10.878603] I[0: kworker/u8:0: 6] f700: 00000038 00000000 7a30f740 ffffffc0 00088728 ffffffc0 7a30f740 ffffffc0 [ 10.888920] I[0: kworker/u8:0: 6] [] el1_irq+0x80/0xe4 [ 10.895913] I[0: kworker/u8:0: 6] [] die+0x148/0x1ac [ 10.902736] I[0: kworker/u8:0: 6] [] arm64_notify_die+0x38/0x40 [ 10.910495] I[0: kworker/u8:0: 6] [] do_undefinstr+0x1cc/0x1dc [ 10.918170] I[0: kworker/u8:0: 6] Exception stack(0xffffffc07a30f7b0 to 0xffffffc07a30f8d0) [ 10.926784] I[0: kworker/u8:0: 6] f7a0: 05b54c28 ffffffc0 05b54900 ffffffc0 [ 10.937105] I[0: kworker/u8:0: 6] f7c0: 7a30f970 ffffffc0 001dc7e8 ffffffc0 00000004 00000000 00030001 ffffffc0 [ 10.947424] I[0: kworker/u8:0: 6] f7e0: 003f1d74 ffffffc0 00f97cb0 ffffffc0 00f97000 ffffffc0 00000002 00000000 [ 10.957743] I[0: kworker/u8:0: 6] f800: 00bc9e02 ffffffc0 000081a4 00000000 00000000 00000000 00000038 00000000 [ 10.968062] I[0: kworker/u8:0: 6] f820: 000001a4 00000000 05b6f808 ffffffc0 05c392a0 ffffffc0 0004b180 ffffffc0 [ 10.978381] I[0: kworker/u8:0: 6] f840: 7a30f870 ffffffc0 001dc920 ffffffc0 05b54c28 ffffffc0 003f1d6c ffffffc0 [ 10.988699] I[0: kworker/u8:0: 6] f860: 00000000 00000000 00000000 00000000 05c39478 ffffffc0 00000000 00000000 [ 10.999018] I[0: kworker/u8:0: 6] f880: 00008000 00000000 5e78606b 70ff726c 7f7f7f7f 7f7f7f7f 68736d74 725e646c [ 11.009337] I[0: kworker/u8:0: 6] f8a0: 7f7f7f7f 7f7f7f7f 01010101 01010101 00000030 00000000 00000010 00000000 [ 11.019654] I[0: kworker/u8:0: 6] f8c0: fffffffe 0fffffff 00000000 00000000 [ 11.026903] I[0: kworker/u8:0: 6] [] klist_node_init+0x50/0x5c [ 11.034578] I[0: kworker/u8:0: 6] [] klist_node_init+0x50/0x5c [ 11.042253] I[0: kworker/u8:0: 6] [] klist_add_tail+0x20/0x58 [ 11.049843] I[0: kworker/u8:0: 6] [] device_add+0x408/0x550 [ 11.057263] I[0: kworker/u8:0: 6] [] add_disk+0x1c0/0x3e4 [ 11.064512] I[0: kworker/u8:0: 6] [] mmc_add_disk+0x24/0x100 [ 11.072017] I[0: kworker/u8:0: 6] [] mmc_blk_probe+0x220/0x2a4 [ 11.079692] I[0: kworker/u8:0: 6] [] mmc_bus_probe+0x18/0x20 [ 11.087196] I[0: kworker/u8:0: 6] [] driver_probe_device+0xd8/0x240 [ 11.095297] I[0: kworker/u8:0: 6] [] __device_attach+0x2c/0x4c [ 11.102973] I[0: kworker/u8:0: 6] [] bus_for_each_drv+0x70/0x8c [ 11.110733] I[0: kworker/u8:0: 6] [] device_attach+0x70/0x9c [ 11.118238] I[0: kworker/u8:0: 6] [] bus_probe_device+0x2c/0xa0 [ 11.125998] I[0: kworker/u8:0: 6] [] device_add+0x3f4/0x550 [ 11.133419] I[0: kworker/u8:0: 6] [] mmc_add_card+0x1e4/0x200 [ 11.141008] I[0: kworker/u8:0: 6] [] mmc_attach_mmc+0x124/0x198 [ 11.148769] I[0: kworker/u8:0: 6] [] mmc_rescan+0x274/0x304 [ 11.156188] I[0: kworker/u8:0: 6] [] process_one_work+0x288/0x448 [ 11.164119] I[0: kworker/u8:0: 6] [] worker_thread+0x208/0x358 [ 11.171794] I[0: kworker/u8:0: 6] [] kthread+0xb0/0xb8 [ 24.667027] I[3: swapper/0: 1] ------------[ cut here ]------------ [ 24.670432] I[3: swapper/0: 1] WARNING: at kernel/watchdog.c:259 watchdog_timer_fn+0xf8/0x258() [ 24.679637] [3: swapper/0: 1] Watchdog detected hard LOCKUP on cpu 0 [ 24.686464] I[3: swapper/0: 1] Modules linked in: [ 24.693857] I[3: swapper/0: 1] CPU: 3 PID: 1 Comm: swapper/0 Tainted: G D 3.10.104 #1 [ 24.701127] I[3: swapper/0: 1] Call trace: [ 24.705821] I[3: swapper/0: 1] [] dump_backtrace+0x0/0x10c [ 24.713410] I[3: swapper/0: 1] [] show_stack+0x14/0x1c [ 24.720659] I[3: swapper/0: 1] [] dump_stack+0x20/0x28 [ 24.727908] I[3: swapper/0: 1] [] warn_slowpath_common+0x78/0x9c [ 24.736009] I[3: swapper/0: 1] [] warn_slowpath_fmt+0x50/0x58 [ 24.743856] I[3: swapper/0: 1] [] watchdog_timer_fn+0xf8/0x258 [ 24.751787] I[3: swapper/0: 1] [] __run_hrtimer+0x144/0x2b0 [ 24.759461] I[3: swapper/0: 1] [] hrtimer_interrupt+0x128/0x23c [ 24.767479] I[3: swapper/0: 1] [] arch_timer_handler_phys+0x2c/0x38 [ 24.775836] I[3: swapper/0: 1] [] handle_percpu_devid_irq+0xe8/0x1c8 [ 24.784279] I[3: swapper/0: 1] [] generic_handle_irq+0x2c/0x3c [ 24.792209] I[3: swapper/0: 1] [] handle_IRQ+0x80/0xa0 [ 24.799457] I[3: swapper/0: 1] [] gic_handle_irq+0x50/0x80 [ 24.807046] I[3: swapper/0: 1] Exception stack(0xffffffc00006b630 to 0xffffffc00006b750) [ 24.815661] I[3: swapper/0: 1] b620: 00ee4000 ffffffc0 00003cf0 00000000 [ 24.825981] I[3: swapper/0: 1] b640: 0006b770 ffffffc0 0030ec40 ffffffc0 00005dc0 00000000 23dc3786 00000000 [ 24.836300] I[3: swapper/0: 1] b660: 23dc092d 00000000 00000000 00000000 00000000 00000000 7a5d0848 ffffffc0 [ 24.846619] I[3: swapper/0: 1] b680: 00ee4ca4 ffffffc0 30383030 3030203a 30303030 30203030 ffffffff 7f7f7f7f [ 24.856938] I[3: swapper/0: 1] b6a0: 2e71646f fefeff2f 7f7f7f7f 7f7f7f7f 01010101 01010101 00000028 00000000 [ 24.867256] I[3: swapper/0: 1] b6c0: ffffffff 0fffffff 00000000 00000000 00000000 00000000 00000000 00000000 [ 24.877575] I[3: swapper/0: 1] b6e0: 00000000 00000000 00ee4000 ffffffc0 00003cf0 00000000 00000001 00000000 [ 24.887894] I[3: swapper/0: 1] b700: 00003db8 00000000 0000001f 00000000 00b87fb2 ffffffc0 0006b8c0 ffffffc0 [ 24.898213] I[3: swapper/0: 1] b720: 00000000 00000000 00060000 ffffffc0 00000038 00000000 0006b770 ffffffc0 [ 24.908530] I[3: swapper/0: 1] b740: 0030ec78 ffffffc0 0006b770 ffffffc0 [ 24.915779] I[3: swapper/0: 1] [] el1_irq+0x80/0xe4 [ 24.922773] I[3: swapper/0: 1] [] panic+0x204/0x210 [ 24.929766] I[3: swapper/0: 1] [] do_exit+0x4b4/0x900 [ 24.936929] I[3: swapper/0: 1] [] die+0x198/0x1ac [ 24.943752] I[3: swapper/0: 1] [] arm64_notify_die+0x38/0x40 [ 24.951511] I[3: swapper/0: 1] [] do_undefinstr+0x1cc/0x1dc [ 24.959186] I[3: swapper/0: 1] Exception stack(0xffffffc00006b930 to 0xffffffc00006ba50) [ 24.967800] I[3: swapper/0: 1] b920: 79aa63e8 ffffffc0 79aa6300 ffffffc0 [ 24.978121] I[3: swapper/0: 1] b940: 0006baf0 ffffffc0 0031a440 ffffffc0 00000004 00000000 00030001 ffffffc0 [ 24.988440] I[3: swapper/0: 1] b960: 003f1d74 ffffffc0 00bb34af ffffffc0 0006b9f0 ffffffc0 00312d80 ffffffc0 [ 24.998759] I[3: swapper/0: 1] b980: 05c88000 ffffffc0 00000800 00000000 00f9f000 ffffffc0 00d481f0 ffffffc0 [ 25.009077] I[3: swapper/0: 1] b9a0: 79aa7a40 ffffffc0 00bf2a70 ffffffc0 00000000 00000000 00000000 00000000 [ 25.019396] I[3: swapper/0: 1] b9c0: 00000000 00000000 00000000 00000000 79aa63e8 ffffffc0 003f1d6c ffffffc0 [ 25.029715] I[3: swapper/0: 1] b9e0: 7f05c000 00000000 7f05c000 00000000 00000001 00000000 00000100 00000000 [ 25.040034] I[3: swapper/0: 1] ba00: 05c89000 ffffffc0 05c89000 ffffffc0 80000000 00000000 7f7f7f7f 7f7f7f7f [ 25.050353] I[3: swapper/0: 1] ba20: ff617274 71636d5f 7f7f7f7f 7f7f7f7f 01010101 01010101 00000018 00000000 [ 25.060670] I[3: swapper/0: 1] ba40: fffffffe 0fffffff 00000000 00000000 [ 25.067919] I[3: swapper/0: 1] [] klist_node_init+0x50/0x5c [ 25.075594] I[3: swapper/0: 1] [] klist_node_init+0x50/0x5c [ 25.083269] I[3: swapper/0: 1] [] klist_add_tail+0x20/0x58 [ 25.090859] I[3: swapper/0: 1] [] device_add+0x408/0x550 [ 25.098278] I[3: swapper/0: 1] [] device_register+0x1c/0x28 [ 25.105953] I[3: swapper/0: 1] [] device_create_vargs+0xa8/0xe8 [ 25.113970] I[3: swapper/0: 1] [] device_create+0x4c/0x54 [ 25.121476] I[3: swapper/0: 1] [] android_bind+0x9c/0x25c [ 25.128980] I[3: swapper/0: 1] [] composite_bind+0x94/0x168 [ 25.136655] I[3: swapper/0: 1] [] udc_bind_ sw 25e1/0:69 I[ [ ff fc0ppc9/05c> ker[] b0/0x2_in t_3.eea104 #11 0/0x24c [ 25.191320] [3: swapper/0: 1] Workqueuc0 08.1ff08] I[3:l swapper/0: 1] [] kernel_[ f5.7a30c000I[0: kworker/u8:0: [ --[20nd t] I[ : efwapder20:]- 30--00ena trtie 8f7fdbc01930ce20 --- [ 25.211957] I[0: kworker/u8:0: 6] PC is at psci_fiq_debugger_uart_irq_tf_cb+0x0/0x50 [ 25.220398] I[0: kworker/u8:0: 6] LR is at 0x0 [ 25.225174] I[0: kworker/u8:0: 6] pc : [] lr : [<0000000000000000>] pstate: 200003c5 [ 25.234724] I[0: kworker/u8:0: 6] sp 0000000000000000 x20: 0000000000000000 [ 25.279960] 00000 kworker/u8:0: 6] x19: 0000000000000000 x18: 0000000000000000 [ 25.287465] 00000 kworker/u8:0: 6] x17: 0000000000000000 x16: 0000000000000000 [ 25.294970] 00000 kworker/u8:0: 6] x15: 0000000000000000 x14: 0000000000000000 [ 25.302474] 00000 kworker/u8:0: 6] x13: 0000000000000000 x12: 0000000000000000 [ 25.309979] 00000 kworker/u8:0: 6] x11: 0000000000000000 x10: 0000000000000000 [ 25.317484] 00000 kworker/u8:0: 6] x9 : 0000000000000000 x8 : 0000000000000000 [ 25.324988] 00000 kworker/u 0000000000000000 x4 : 0000000000000000 [ 25.339997] 00000 kworker/u8:0: 6] x3 : 0000000000000000 x2 : 0000000000000000 [ 25.347502] 00000 kworker/u8:0: 6] x1 : 0000000000000000 x0 : ffffffc07a30f5c0 [ 25.355007] I[0: kworker/u8:0: 6] [ 25.355007] I[0: kworker/u8:0: 6] PC: 0xffffffc000095728: [ 25.362303] [0: kworker/u8:0: 6] 5728 9420b3f7 17fffff3 b00057a0 910dc800 9420b3f3 52800001 d10083bf 2a0103e0 [ 25.376128] [0: kworker/u8:0: 6] 5748 a94353f3 a9445bf5 a94563f7 a9427bfd 9101c3ff d65f03c0 d4000003 b4000124 [ 25.386531] [0: kworker/u8:0: 6] 5768 2a0003e0 2a0103e1 2a0203e2 2a0303e3 f9000080 f9000481 00000000 00000000 [ [ 25.448947] I[0: kworker/u8:0: 6] [ 25.448947] I[0: kworker/u8:0: 6] SP: 0xffffffc07a30f540: [ 25.454996] [0: kworker/u8:0: 6] f540 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 25.468821] [0: kworker/u8:0: 6] f560 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 25.479224] [0: kworker/u8:0: 6] f580 00000000 00000000 00000000 00000000 00000000 00000000 7a30f5c0 ffffffc0 [ 25.489626] [0: kworker/u8:0: 6] f5a0 000957a8 ffffffc0 200003c5 00000000 00ee1210 ffffffc0 00000000 00000000 [ 25.500029] [0: kworker/u8:0: 6] f5c0 7a30f5f0 ffffffc0 000813cc ffffffc0 00fa0a40 ffffffc0 00002010 ffffff80 [ 25.510431] [0: kw ffc0 [ 25.531237] [0: kworker/u8:0: 6] f620 00ee1170 ffffffc0 00000002 00000000 00000080 00000000 00000080 00000000 [ 25.541640] I[0: kworker/u8:0: 6] [ 25.541640] I[0: kworker/u8:0: 6] X0: 0xffffffc07a30f540: [ 25.547689] [0: kworker/u8:0: 6] f540 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 25.561514] [0: kworker/u8:0: 6] f560 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 25.571917] [0: kworker/u8:0: 6] f580 00000000 00000000 00000000 00000000 000 6] f600 7a30f850 ffffffc0 00ee1000 ffffffc0 7a30f740 ffffffc0 008ca4d4 ffffffc0 [ 25.623930] [0: kworker/u8:0: 6] f620 00ee1170 ffffffc0 00000002 00000000 00000080 00000000 00000080 00000000 [ 25.634341] I[0: kworker/u8:0: 6] [ 25.636470] I[0: kworker/u8:0: 6] Process kworker/u8:0 (pid: 6, stack limit = 0xffffffc07a30c058) [ 25.643795] I[0: kworker/u8:0: 6] Stack: (0xffffffc07a30f5c0 to 0xffffffc07a310000) [ 25.651729] I[0: kworker/u8:0: 6] f5c0: 7a30f5f0 ffffffc0 000813cc ffffffc0 00fa0a40 ffffffc0 00002010 ffffff80 [ 25.662048] I[0: kworker/u8:0: 6] f5e0: 7a30f620 ffffffc0 ffffffff ffffffff 7a30f740 ffffffc0 00083dc0 ffffffc0 [ 25.672367] I[0: kworker/u8:0: 6] f600: 7a30f850 ffffffc0 00ee1000 ffffffc0 7a30f740 ffffffc0 008ca4d4 ffffffc0 [ 25.682685] I[0: kworker/u8:0: 6] f620: 00e 000 00000000 00000000 7a30f850 ffffffc0 [ 25.734280] I[0: kworker/u8:0: 6] f6c0: 00ee1000 ffffffc0 00b87f4f ffffffc0 00063340 ffffffc0 00000001 00000000 [ 25.744599] I[0: kworker/u8:0: 6] f6e0: 00b87fb2 ffffffc0 77d5e008 ffffffc0 00d479a8 ffffffc0 00000000 00000000 [ 25.754918] I[0: kworker/u8:0: 6] f700: 00000038 00000000 7a30f740 ffffffc0 00088728 ffffffc0 7a30f740 ffffffc0 [ 25.765237] I[0: kworker/u8:0: 6] f720: 008ca4d4 ffffffc0 60000345 00000000 7a30f750 ffffffc0 00088720 ffffffc0 [ 25.775555] I[0: kworker/u8:0: 6] f740: 7a30f750 ffffffc0 00088728 ffffffc0 7a30f790 ffffffc0 000887c4 ffffffc0 7a30f7a0 ffffffc0 000811cc ffffffc0 [ 25.806512] I[0: kworker/u8:0: 6] f7a0: 7a30f970 ffffffc0 008bdcb4 ffffffc0 05b54c28 ffffffc0 05b54900 ffffffc0 [ 25.816831] I[0: kworker/u8:0: 6] f7c0: 7a30f970 ffffffc0 001dc7e8 ffffffc0 00000004 00000000 00030001 ffffffc0 [ 25.827150] I[0: kworker/u8:0: 6] f7e0: 003f1d74 ffffffc0 00f97cb0 ffffffc0 00f97000 ffffffc0 00000002 00000000 [ 25.837469] I[0: kworker/u8:0: 6] f800: 00bc9e02 ffffffc0 000081a4 00000000 00000000 00000000 00000038 00000000 [ 25.847788] I[0: kworker/u8:0: 6] f820: 000001a4 00000000 05b6f808 ffffffc0 05c392a0 ffffffc0 0004b180 ffffffc0 [ 25.858106] I[0: kworker/u8:0: 6] f840: 7a30f870 ffffffc0 001dc920 ffffffc0 05b54c28 ffffffc0 003f1d6c ffffffc0 [ 25.868425] 1010101 00000030 00000000 00000010 00000000 [ 25.899382] I[0: kworker/u8:0: 6] f8c0: fffffffe 0fffffff 00000000 00000000 00000000 00000000 00000000 00000000 [ 25.909701] I[0: kworker/u8:0: 6] f8e0: 00000000 00000000 05b54c28 ffffffc0 05b54900 ffffffc0 05c1e480 ffffffc0 [ 25.920020] I[0: kworker/u8:0: 6] f900: 00dd8000 ffffffc0 00000000 00000000 00d47928 ffffffc0 77d5e008 ffffffc0 [ 25.930339] I[0: kworker/u8:0: 6] f920: 00d479a8 ffffffc0 00000000 00000000 00000038 00000000 7a30f970 ffffffc0 [ 25.940657] I[0: kworker/u8:0: 6] f940: 008bd c0 [ 25.971614] I[0: kworker/u8:0: 6] f9a0: 7a30f9c0 ffffffc0 003f3224 ffffffc0 05c1e470 ffffffc0 00000000 00000000 [ 25.981933] I[0: kworker/u8:0: 6] f9c0: 7a30fa30 ffffffc0 00303900 ffffffc0 05c1e400 ffffffc0 05c1e470 ffffffc0 [ 25.992252] I[0: kworker/u8:0: 6] f9e0: 05c1e480 ffffffc0 77ce4360 ffffffc0 05c1e40c ffffffc0 77d5e2d0 ffffffc0 [ 26.002571] I[0: kworker/u8:0: 6] fa00: 00000001 00000000 05c0e3d8 ffffffc0 00c15c89 ffffffc0 00000003 00000000 [ 26.012890] I[0: kworker/u8:0: 6] fa20: 3a393731 ffff0030 003031f8 ffffffc0 7a30faa0 ffffffc0 005fdeb4 ffffffc0 [ 26.023209] I[0: kworker/u8:0: 6] fa40: 05c0e000 ffffffc0 05c0e000 ffffffc0 05c0e408 ffffffc0 77d5e000 ffffffc0 [ 26.033527] I[0: kworker/u8:0: 6] fa6 26.074803] I[0: kworker/u8:0: 6] fae0: 77d5e008 ffffffc0 00000000 00000000 00e90c68 ffffffc0 00fa6000 ffffffc0 [ 26.085122] I[0: kworker/u8:0: 6] fb00: 00dd8000 ffffffc0 00000001 00000000 77dd1808 ffffffc0 00e905f8 ffffffc0 [ 26.095441] I[0: kworker/u8:0: 6] fb20: 00000089 00000000 00000000 00000000 392e3832 42694720 003f5700 ffffffc0 [ 26.105760] I[0: kworker/u8:0: 6] fb40: 30302e34 42694d20 00000000 00000000 7a30fb60 ffffffc0 003f5748 ffffffc0 [ 26.116078] I[0: kworker/u8:0: 6] fb60: 7a30fbb0 ffffffc0 003f58dc ffffffc0 00e90c68 ffffffc0 77d5e008 ffffffc0 [ 26.126397] I[0: kworker/u8:0: 6] fb80: 003f58b0 ffffffc0 00dd8000 fffff fffffc0 [ 26.167673] I[0: kworker/u8:0: 6] fc00: 79ad66d0 ffffffc0 77b9fba8 ffffffc0 7a30fc40 ffffffc0 003f4ba0 ffffffc0 [ 26.177992] I[0: kworker/u8:0: 6] fc20: 77d5e008 ffffffc0 00e904b8 ffffffc0 77d5e008 ffffffc0 00c47d50 ffffffc0 [ 26.188311] I[0: kworker/u8:0: 6] fc40: 7a30fc70 ffffffc0 003f3210 ffffffc0 77d5e008 ffffffc0 00000000 00000000 [ 26.198629] I[0: kworker/u8:0: 6] fc60: 77d5e018 ffffffc0 003f3208 ffffffc0 7a30fce0 ffffffc0 005f2320 ffffffc0 [ 26.208948] I[0: kworker/u8:0: 6] fc80: 77d5e000 ffffffc0 77d5e008 ffffffc0 00000000 00000000 00000000 00000000 [ 26.219267] I[0: kworker 0: 6] fd20: 00000000 00000000 7a30fc70 40ff8080 7a30fd80 ffffffc0 000c3540 ffffffc0 [ 26.270862] I[0: kworker/u8:0: 6] fd40: 00026700 ffffffc0 77dd1b60 ffffffc0 00013000 ffffffc0 00000000 00000000 [ 26.281181] I[0: kworker/u8:0: 6] fd60: 79a31500 ffffffc0 00ed9038 ffffffc0 7a30fd80 ffffffc0 000c34bc ffffffc0 [ 26.291499] I[0: kworker/u8:0: 6] fd80: 7a30fdd0 ffffffc0 000c46a4 ffffffc0 00026700 ffffffc0 00ed8912 ffffffc0 [ 26.301818] I[0: kworker/u8:0: 6] fda0: 00013000 ffffffc0 00b8fef9 ffffffc0 00026730 ffffffc0 7a30c000 ffffffc0 [ 26.312137] I[0: kworker/u8:0: 6] fdc0: 00013000 ffffffc0 00013018 ffffffc0 7a30fe30 ffffffc0 000c9c18 ffffffc0 [ 26.322456] I[0: kworker/u8:0: 6] fde0: 0006bb10 ffffffc0 00f69d10 ffffffc0 00b8e654 ffffffc0 00026700 700 ffffffc0 00000000 ffffffff 00000000 ffffffff [ 26.384369] I[0: kworker/u8:0: 6] fea0: 7a30fea0 ffffffc0 7a30fea0 ffffffc0 00000000 ffffffc0 00000000 ffffffff [ 26.394688] I[0: kworker/u8:0: 6] fec0: 7a30fec0 ffffffc0 7a30fec0 ffffffc0 00000000 00000000 00000000 00000000 [ 26.405007] I[0: kworker/u8:0: 6] fee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 26.415326] I[0: kworker/u8:0: 6] ff00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 26.425644] I[0: kworker/u8:0: 6] ff20: 00000000 00000000 00000000 00000000 00000000 00000000 000 /u8:0: 6] ffa0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 26.477239] I[0: kworker/u8:0: 6] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000005 00000000 [ 26.487558] I[0: kworker/u8:0: 6] ffe0: 00000000 00000000 00000000 00000000 ffffffff ffffffff ffffffff ffffffff [ 26.497872] I[0: kworker/u8:0: 6] Call trace: [ 26.502566] I[0: kworker/u8:0: 6] Code: 00000000 00000000 00000000 00000000 (00000000) [ 26.510837] I[0: kworker/u8:0: 6] ---[ end trace 837bdbef19fd3e30 ]---
