1、我使用pad版 内核,什么都没改。使用AndroidTool_Release_v2.3烧写Loader、Parameter、Misc、Resource、Kernel、Boot、Recovery、System。
DDR Version 1.00 20141007
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-02 (Feb 26 2015 - 14:42:13)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2015-02-26#2.17
sn:100612000000033C
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
got recovery cmd from misc.
failed to load fdt from recovery!
kernel @ 0x02000000 (0x0065a630)
ramdisk @ 0x04bf0000 (0x003d4b94)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 04809000, end 04826a49 … OK
之后就不动了,将Parmeter更改为
CMDLINE:console=ttyS2 earlyprintk androidboot.hardware=rk30board androidboot.console=ttyS2 board.ap_has_alsa=0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user)
能正常进入recovery 然后重新启动系统。
2、使用更改的Parameter,修改kernel中firefly-rk3288.dts文件,将i2c5 status=“disabled”改为status=“okay”,重新编译内核。按照1中烧写,启动信息如下
SRX
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
sn:100612000000033C
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
Loading Device Tree to 04809000, end 04826a45 … OK
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (smdt@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Mar 30 17:19:27 CST 2015 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] hdmi init vic is -1 [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(cma): base(40000000) size(28000000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 640 MiB at 40000000 [ 0.000000] ion_reserve: cma reserved base 40000000 size 671088640 [ 0.000000] cma: CMA: reserved 16 MiB at 2e800000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1dea000 s14016 r8192 d14656 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768 [ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user) storagemedia=emmc loader.timestamp=2015-02-26_14:42:13 hdmi.vic=-1 androidboot.serialno=100612000000033C [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1385668k/1385668k available, 711484k reserved, 663552K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0af0514 (11170 kB) [ 0.000000] .init : 0xc0af1000 - 0xc0b856c0 ( 594 kB) [ 0.000000] .data : 0xc0b86000 - 0xc0c8e9f8 (1059 kB) [ 0.000000] .bss : 0xc0c8e9f8 - 0xc0daca44 (1145 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000 [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 31 [ 0.000000] rk3288 set GPLL BW 20 for HDMI! [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 1 [ 0.000000] channel:0, lkg:29 [ 0.000000] target-temp:80 [ 0.000000] channel:2, lkg:0 [ 0.000000] target-temp:80 [ 0.000000] channel:0, lkg:29 [ 0.000000] target-temp:80 [ 0.000000] channel:1, lkg:24 [ 0.000000] target-temp:80 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.306941] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.306956] pid_max: default: 32768 minimum: 301 [ 0.307059] Security Framework initialized [ 0.307076] SELinux: Initializing. [ 0.307147] Mount-cache hash table entries: 512 [ 0.307786] Initializing cgroup subsys debug [ 0.307801] Initializing cgroup subsys memory [ 0.307827] Initializing cgroup subsys freezer [ 0.307856] CPU: Testing write buffer coherency: ok [ 0.308163] /cpus/cpu@0 missing clock-frequency property [ 0.308175] /cpus/cpu@1 missing clock-frequency property [ 0.308184] /cpus/cpu@2 missing clock-frequency property [ 0.308193] /cpus/cpu@3 missing clock-frequency property [ 0.308252] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.308303] Setting up static identity map for 0xc07df888 - 0xc07df8e0 [ 0.310707] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x173f (version 3.0) [ 0.385057] CPU1: Booted secondary processor [ 0.385089] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.404740] CPU2: Booted secondary processor [ 0.404764] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.424455] CPU3: Booted secondary processor [ 0.424479] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.424579] Brought up 4 CPUs [ 0.424609] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.424618] CPU: All CPU(s) started in SVC mode. [ 0.425349] devtmpfs: initialized [ 0.430422] pinctrl core: initialized pinctrl subsystem [ 0.430667] regulator-dummy: no parameters [ 0.442054] NET: Registered protocol family 16 [ 0.443938] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.444228] ion_snapshot: 0x2e1b0000 map to 0xf0107000 and copy to 0xc0d88044 (version 0.1) [ 0.444575] Registered FIQ tty driver [ 0.445913] console [ttyFIQ0] enabled [ 0.446133] Registered fiq debugger ttyFIQ0 [ 0.446752] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 0.446776] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f [ 0.446797] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f [ 0.446817] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b [ 0.446910] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff [ 0.446976] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff [ 0.447042] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff [ 0.447106] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff [ 0.447171] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff [ 0.447235] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff [ 0.447306] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff [ 0.447374] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff [ 0.447446] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff [ 0.447515] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 0.447531] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 0.447546] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 0.447561] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 0.448066] rockchip_interrupts_register:bank_num=7 [ 0.449985] rockchip_pinctrl_probe:init ok [ 0.455946] rk_iommu ff900800.iep_mmu: (iep) Enter [ 0.456039] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.456055] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 0.456226] rk_iommu ff950800.vip_mmu: (vip) Enter [ 0.456297] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.456312] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 0.456469] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 0.456538] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.456553] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 0.456723] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 0.456795] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.456810] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 0.456976] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 0.457050] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.457065] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 0.457231] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 0.457304] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.457319] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 0.457505] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 0.457579] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.457594] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 0.459195] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.459212] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.459420] DDR DEBUG: version 1.00 20140603 [ 0.459452] DDR DEBUG: Channel a: [ 0.459462] DDR DEBUG: DDR3 Device [ 0.459478] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.459491] DDR DEBUG: Channel b: [ 0.459499] DDR DEBUG: DDR3 Device [ 0.459513] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.459525] DDR DEBUG: addr=0xc96000 [ 0.459536] DDR DEBUG: stride=9, size=256, halfcap=40000000 [ 0.459547] DDR DEBUG: socAddr[0]=0xc96000, socAddr[1]=0xc96100 [ 0.459559] DDR DEBUG: chAddr[0]=0xc96000, chAddr[1]=0xc96000 [ 0.459572] DDR DEBUG: dtar[0]=0x60192000, dtar[1]=0x60192000 [ 0.459817] DDR DEBUG: init success!!! freq=300MHz [ 0.459828] DDR DEBUG: Channel a: [ 0.459842] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.459858] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.459875] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.459891] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.459906] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.459918] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.459930] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.459939] DDR DEBUG: Channel b: [ 0.459952] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.459968] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.459985] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.460001] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.460015] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.460028] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.460038] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.482160] bio: create slab at 0 [ 0.483015] SCSI subsystem initialized [ 0.483162] usbcore: registered new interface driver usbfs [ 0.483207] usbcore: registered new interface driver hub [ 0.483311] usbcore: registered new device driver usb [ 0.484679] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 0.486854] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 0.488354] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 0.489317] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter [ 0.489563] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter [ 0.490049] media: Linux media interface: v0.10 [ 0.490091] Linux video capture interface: v2.00 [ 0.490137] pps_core: LinuxPPS API ver. 1 registered [ 0.490148] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.490172] PTP clock support registered [ 0.490648] Rockchip ion module is successfully loaded (v1.0) [ 0.490805] Advanced Linux Sound Architecture Driver Initialized. [ 0.491176] Bluetooth: Core ver 2.16 [ 0.491213] NET: Registered protocol family 31 [ 0.491225] Bluetooth: HCI device and connection manager initialized [ 0.491243] Bluetooth: HCI socket layer initialized [ 0.491258] Bluetooth: L2CAP socket layer initialized [ 0.491285] Bluetooth: SCO socket layer initialized [ 0.491517] cfg80211: Calling CRDA to update world regulatory domain [ 0.492150] act8846_i2c_probe,line=898 [ 0.493122] act8846_parse_dt,line=746 [ 0.493815] act8846_i2c_probe: act8846_pmic_hold=1 [ 0.493837] act8846_i2c_probe: act8846_pmic_sleep=1 [ 0.493854] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1 [ 0.493871] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1 [ 0.495698] act_dcdc1: 1200 mV [ 0.498415] vccio: 3300 mV [ 0.500279] vdd_logic: 700 <--> 1500 mV at 1100 mV [ 0.502980] act_dcdc4: 2000 mV [ 0.504227] vccio_sd: 1800 <--> 3300 mV at 3300 mV [ 0.506295] act_ldo2: 1000 mV [ 0.508367] act_ldo3: 3300 mV [ 0.510439] act_ldo4: 3300 mV [ 0.512516] act_ldo5: 3300 mV [ 0.514600] act_ldo6: 1000 mV [ 0.516678] vcc_18: 1800 mV [ 0.518749] act_ldo8: 1800 mV [ 0.523522] vdd_arm: 712 <--> 1500 mV at 1000 mV [ 0.528215] vdd_gpu: 712 <--> 1500 mV at 1000 mV [ 0.529061] Switching to clocksource arch_sys_counter [ 0.549354] rk-fb rockchip-fb: rk fb ion client create success! [ 0.549372] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.549755] rk-screen rk_screen.9: rockchip screen probe success [ 0.550012] rk32-lvds rk32-lvds: rk32 lvds driver probe success [ 0.550335] rk32-edp ff970000.edp: screen is not edp! [ 0.550356] rk32-edp: probe of ff970000.edp failed with error -22 [ 0.551063] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.551411] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.551577] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.551729] graphics fb3: rockchip framebuffer registerd:fb3 [ 0.562277] rk3288-lcdc lcdc0: lcdc0: dclk:50000000>>fps:59 [ 0.562301] rk3288-lcdc lcdc0: wakeup from standby! [ 0.575868] alloc_buffer:ion_phy_addr=0x40000000 [ 0.580965] fb0:phy:40000000>>vir:f0171000>>len:0xa00000 [ 0.584513] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled [ 0.584671] rk3288-lcdc lcdc1: can't find power_ctr node for lcdc1 [ 0.584687] rk_fb_trsm_ops_get:un supported transmitter:0! [ 0.584887] graphics fb4: rockchip framebuffer registerd:fb4 [ 0.585187] graphics fb5: rockchip framebuffer registerd:fb5 [ 0.585344] graphics fb6: rockchip framebuffer registerd:fb6 [ 0.585497] graphics fb7: rockchip framebuffer registerd:fb7 [ 0.585514] fb0:phy:40000000>>vir:f0171000>>len:0xa00000 [ 0.585528] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled [ 0.586110] rockchip_set_mux:warning ignore bank num 15 [ 0.586233] rockchip_set_mux:warning ignore bank num 15 [ 0.586341] rockchip_set_mux:warning ignore bank num 15 [ 0.586455] rockchip_set_mux:warning ignore bank num 15 [ 0.586564] rockchip_set_mux:warning ignore bank num 15 [ 0.586672] rockchip_set_mux:warning ignore bank num 15 [ 0.587239] rockchip_set_mux:warning ignore bank num 15 [ 0.587386] rockchip_set_mux:warning ignore bank num 15 [ 0.587934] rockchip_set_mux:warning ignore bank num 15 [ 0.588070] rockchip_set_mux:warning ignore bank num 15 [ 0.588625] rockchip_set_mux:warning ignore bank num 15 [ 0.588787] rockchip_set_mux:warning ignore bank num 15 [ 0.589339] rockchip_set_mux:warning ignore bank num 15 [ 0.589481] rockchip_set_mux:warning ignore bank num 15 [ 0.590520] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 0.590745] NET: Registered protocol family 2 [ 0.591198] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 0.591337] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.591474] TCP: Hash tables configured (established 8192 bind 8192) [ 0.591523] TCP: reno registered [ 0.591538] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.591575] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.591769] NET: Registered protocol family 1 [ 0.591942] Unpacking initramfs... [ 0.755235] Freeing initrd memory: 3920K (c4bf0000 - c4fc4000) [ 0.755931] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available [ 0.756402] probe device ff9a0000.vpu_service [ 0.756578] vpu_service: power on [ 0.757637] checking hw id 4831 [ 0.758027] vpu_service set to auto frequency mode [ 0.758064] vpu_service: power off... [ 0.758102] done [ 0.758111] init success [ 0.758164] probe device ff9c0000.hevc_service [ 0.758359] hevc_service: power on [ 0.759396] checking hw id 6867 [ 0.759618] hevc_service: power off... [ 0.759657] done [ 0.759666] init success [ 0.759774] rknandbase v1.0 2014-03-31 [ 0.759877] rknand ff400000.nandc0: no irq resource? [ 0.760000] rknand_driver:ret = 0 [ 0.760751] audit: initializing netlink socket (disabled) [ 0.760791] type=2000 audit(0.450:1): initialized [ 0.761532] bounce pool size: 64 pages [ 0.765946] fuse init (API version 7.22) [ 0.766290] msgmni has been set to 1450 [ 0.767999] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 0.768018] io scheduler noop registered [ 0.768029] io scheduler deadline registered [ 0.768115] io scheduler cfq registered (default) [ 0.771610] rga2 ff920000.rga: rga ion client create success! [ 0.771753] rga: Driver loaded succesfully [ 0.772359] IEP Driver loaded succesfully [ 0.772449] Module initialized. [ 0.773300] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208 [ 0.773320] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 0.774585] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208 [ 0.774605] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 0.774873] pwm-voltage-regulator pwm_regulator.25: unable to request PWM, trying legacy API [ 0.774892] pwm-voltage-regulator pwm_regulator.25: unable to request legacy PWM [ 0.774904] pwm_regulator_probe:error [ 0.774926] platform pwm_regulator.25: Driver pwm-voltage-regulator requests probe deferral [ 0.775283] rk_serial.c v1.8 2014-03-04 [ 0.775499] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0 [ 0.775698] serial ff180000.serial: membase f0b94000 [ 0.778366] loop: module loaded [ 0.778918] SCSI Media Changer driver v0.25 [ 0.779215] tun: Universal TUN/TAP device driver, 1.6 [ 0.779229] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 0.779345] vmac_init. [ 0.779851] stmmac_probe_config_dt: Can not read property: pmu_regulator. [ 0.779867] stmmac_probe_config_dt: Can not read property: pmu_enable_level. [ 0.779881] stmmac_probe_config_dt: clock input or output? (input). [ 0.779894] stmmac_probe_config_dt: TX delay(0x30). [ 0.779905] stmmac_probe_config_dt: RX delay(0x10). [ 0.779952] stmmac_probe_config_dt: is rockchip,rk3288-gmac [ 0.779963] stmmc_pltfr_init: [ 0.779982] stmmc_pltfr_init: init for RGMII [ 0.779995] tx delay=0x30 [ 0.779995] rx delay=0x10 [ 0.780440] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 0.780452] Normal descriptors [ 0.780461] Ring mode enabled [ 0.780470] DMA HW capability register supported [ 0.780482] RX Checksum Offload Engine supported (type 2) [ 0.780493] TX Checksum insertion supported [ 0.780502] Wake-Up On Lan supported [ 0.780538] Enable RX Mitigation via HW Watchdog Timer [ 0.780943] PPP generic driver version 2.4.2 [ 0.781098] PPP BSD Compression module registered [ 0.781112] PPP Deflate Compression module registered [ 0.781134] PPP MPPE Compression module registered [ 0.781146] NET: Registered protocol family 24 [ 0.781179] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 0.781193] CSLIP: code copyright 1989 Regents of the University of California. [ 0.781206] Rockchip WiFi SYS interface (V1.00) ... [ 0.781237] esp_mem_init enter date Mar 30 2015 17:18:35 [ 0.781279] esp_mem_init complete [ 0.781349] usbcore: registered new interface driver catc [ 0.781388] usbcore: registered new interface driver kaweth [ 0.781401] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 0.781439] usbcore: registered new interface driver pegasus [ 0.781476] usbcore: registered new interface driver rtl8150 [ 0.781513] usbcore: registered new interface driver r8152 [ 0.781525] hso: drivers/net/usb/hso.c: Option Wireless [ 0.781592] usbcore: registered new interface driver hso [ 0.781648] usbcore: registered new interface driver asix [ 0.781689] usbcore: registered new interface driver ax88179_178a [ 0.781726] usbcore: registered new interface driver cdc_ether [ 0.781764] usbcore: registered new interface driver cdc_eem [ 0.781801] usbcore: registered new interface driver dm9601 [ 0.781837] usbcore: registered new interface driver dm9620 [ 0.781883] usbcore: registered new interface driver smsc75xx [ 0.781934] usbcore: registered new interface driver smsc95xx [ 0.781973] usbcore: registered new interface driver gl620a [ 0.782010] usbcore: registered new interface driver net1080 [ 0.782047] usbcore: registered new interface driver plusb [ 0.782085] usbcore: registered new interface driver rndis_host [ 0.782123] usbcore: registered new interface driver cdc_subset [ 0.782159] usbcore: registered new interface driver zaurus [ 0.782203] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 0.782259] usbcore: registered new interface driver int51x1 [ 0.782298] usbcore: registered new interface driver kalmia [ 0.782336] usbcore: registered new interface driver ipheth [ 0.782378] usbcore: registered new interface driver sierra_net [ 0.782418] usbcore: registered new interface driver cx82310_eth [ 0.782469] usbcore: registered new interface driver cdc_ncm [ 0.782510] usbcore: registered new interface driver qmi_wwan [ 0.782550] usbcore: registered new interface driver cdc_mbim [ 0.782562] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.784937] ehci_rk_probe f0c00000 f0c00010 [ 0.784989] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller [ 0.785022] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1 [ 0.785360] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000 [ 0.804656] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00 [ 0.804731] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.804749] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.804764] usb usb1: Product: Rockchip On-Chip EHCI Host Controller [ 0.804778] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 0.804791] usb usb1: SerialNumber: ff500000.usb [ 0.805205] hub 1-0:1.0: USB hub found [ 0.805229] hub 1-0:1.0: 1 port detected [ 0.834169] ehci_rk_probe ok [ 0.834313] usbcore: registered new interface driver cdc_acm [ 0.834327] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 0.834380] usbcore: registered new interface driver usblp [ 0.834422] usbcore: registered new interface driver cdc_wdm [ 0.834487] usbcore: registered new interface driver usb-storage [ 0.834527] usbcore: registered new interface driver ums-alauda [ 0.834565] usbcore: registered new interface driver ums-cypress [ 0.834603] usbcore: registered new interface driver ums-datafab [ 0.834639] usbcore: registered new interface driver ums_eneub6250 [ 0.834676] usbcore: registered new interface driver ums-freecom [ 0.834713] usbcore: registered new interface driver ums-isd200 [ 0.834751] usbcore: registered new interface driver ums-jumpshot [ 0.834788] usbcore: registered new interface driver ums-karma [ 0.834825] usbcore: registered new interface driver ums-onetouch [ 0.834863] usbcore: registered new interface driver ums-sddr09 [ 0.834919] usbcore: registered new interface driver ums-sddr55 [ 0.834959] usbcore: registered new interface driver ums-usbat [ 0.835046] usbcore: registered new interface driver usbserial [ 0.835085] usbcore: registered new interface driver usbserial_generic [ 0.835116] usbserial: USB Serial support registered for generic [ 0.835153] usbcore: registered new interface driver option [ 0.835181] usbserial: USB Serial support registered for GSM modem (1-port) [ 0.835252] usbcore: registered new interface driver trancevibrator [ 0.835266] usb20_otg: version 3.10a 21-DEC-2012 [ 0.835648] f0c80040 [ 0.835661] Core Release: 3.10a [ 0.835672] Setting default values for core params [ 0.835781] Using Buffer DMA mode [ 0.835793] Periodic Transfer Interrupt Enhancement - disabled [ 0.835804] Multiprocessor Interrupt Enhancement - disabled [ 0.835816] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 0.835826] ^^^^^^^^^^^^^^^^^Device Mode [ 0.835839] Dedicated Tx FIFOs mode [ 0.835862] pcd_init otg_dev = ed67f280 [ 0.835990] usb20_otg ff580000.usb: DWC OTG Controller [ 0.836016] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2 [ 0.836046] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 0.836100] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.836117] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.836132] usb usb2: Product: DWC OTG Controller [ 0.836145] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 0.836158] usb usb2: SerialNumber: ff580000.usb [ 0.836517] hub 2-0:1.0: USB hub found [ 0.836541] hub 2-0:1.0: 1 port detected [ 0.836825] usb20_host: version 3.10a 21-DEC-2012 [ 0.839277] f0d00040 [ 0.839289] Core Release: 3.10a [ 0.839300] Setting default values for core params [ 0.839400] Using Buffer DMA mode [ 0.839412] Periodic Transfer Interrupt Enhancement - disabled [ 0.839423] Multiprocessor Interrupt Enhancement - disabled [ 0.839434] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 0.839445] ^^^^^^^^^^^^^^^^^^Host Mode [ 0.839467] usb20_host ff540000.usb: DWC OTG Controller [ 0.839492] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3 [ 0.839520] usb20_host ff540000.usb: irq 57, io mem 0x00000000 [ 0.839612] Init: Power Port (0) [ 0.839663] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.839680] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.839694] usb usb3: Product: DWC OTG Controller [ 0.839707] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 0.839720] usb usb3: SerialNumber: ff540000.usb [ 0.840070] hub 3-0:1.0: USB hub found [ 0.840091] hub 3-0:1.0: 1 port detected [ 0.840596] .. rk pwm remotectl v1.0 init [ 0.840678] remotectl probe j=0x0 [ 0.840821] input: ff680000.pwm as /devices/ff680000.pwm/input/input0 [ 0.840990] pwm enable val=0x646205 [ 0.841242] usbcore: registered new interface driver xpad [ 0.841295] usbcore: registered new interface driver usb_acecad [ 0.841340] usbcore: registered new interface driver aiptek [ 0.841383] usbcore: registered new interface driver gtco [ 0.841426] usbcore: registered new interface driver hanwang [ 0.841468] usbcore: registered new interface driver kbtab [ 0.841517] usbcore: registered new interface driver wacom [ 0.841528] ==gsl_ts_init== [ 0.841618] GSLX680 Enter gsl_ts_probe [ 0.932610] dwc_otg_hcd_suspend, usb device mode [ 1.158882] gsl_ts_probe--1269, i2c_master_recv fail [ 1.158904] gslX680: probe of 1-0041 failed with error -11 [ 1.158969] ret=0 [ 1.163927] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0 [ 1.163987] i2c /dev entries driver [ 1.164657] IR NEC protocol handler initialized [ 1.164671] IR RC5(x) protocol handler initialized [ 1.164681] IR RC6 protocol handler initialized [ 1.164691] IR JVC protocol handler initialized [ 1.164701] IR Sony protocol handler initialized [ 1.164711] IR RC5 (streamzap) protocol handler initialized [ 1.164721] IR SANYO protocol handler initialized [ 1.164731] IR MCE Keyboard/mouse protocol handler initialized [ 1.164869] usbcore: registered new interface driver uvcvideo [ 1.164881] USB Video Class driver (1.1.1) [ 1.164894] CamSys driver version: v0.23.0, CamSys head file version: v0.9.0 [ 1.166285] D1:camsys_platform_probe(1067): 1-gpios-cifpowerï¼?gpio=-2 [ 1.166365] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0) [ 1.166506] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf0ba8000 size: 0x4000) [ 1.167141] D1:camsys_platform_probe(1183): ff910000.isp memory: [ 1.167160] D1:camsys_platform_probe(1193): Register memory (phy: 0xff910000 vir: 0xf0be0000 size: 0x10000) [ 1.167176] D1:camsys_platform_probe(1188): I2c memory (phy: 0x2d9b2000 vir: 0xed9b2000 size: 0x1000) [ 1.167192] D1:camsys_platform_probe(1208): Probe ff910000.isp device success [ 1.168483] device-mapper: uevent: version 1.0.3 [ 1.168723] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email] [ 1.169039] Bluetooth: HCI UART driver ver 2.2 [ 1.169054] Bluetooth: HCI H4 protocol initialized [ 1.169066] Bluetooth: HCILL protocol initialized [ 1.172130] cpufreq version 1.0, suspend freq 1200 MHz [ 1.172320] cpuidle: using governor ladder [ 1.172333] cpuidle: using governor menu [ 1.172368] Synopsys Designware Multimedia Card Interface Driver [ 1.172602] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a [ 1.172876] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller. [ 1.173030] 3379..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0] [ 1.173045] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05 [ 1.173158] 1390..dw_mci_set_ios: no card. [mmc0] [ 1.188422] 1390..dw_mci_set_ios: no card. [mmc0] [ 1.208117] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 1.208141] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo [ 1.208161] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized [ 1.208428] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a [ 1.209257] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller. [ 1.209498] 3379..dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1] [ 1.209512] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05 [ 1.209571] mmc1: no vmmc regulator found [ 1.209669] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found! [ 1.209750] 1390..dw_mci_set_ios: no card. [mmc1] [ 1.227767] 1390..dw_mci_set_ios: no card. [mmc1] [ 1.240228] mmc0: BKOPS_EN bit is not set [ 1.242116] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1) [ 1.242138] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0] [ 1.242188] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0] [ 1.242289] mmc0: new high speed MMC card at address 0001 [ 1.242531] mmcblk0: mmc0:0001 AWMB3R 14.5 GiB [ 1.242806] parameter: 0x000000000 -- 0x000400000 (4 MB) [ 1.242818] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 1.242827] misc: 0x000800000 -- 0x000c00000 (4 MB) [ 1.242836] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 1.242846] kernel: 0x001c00000 -- 0x002c00000 (16 MB) [ 1.242854] boot: 0x002c00000 -- 0x004c00000 (32 MB) [ 1.242863] recovery: 0x004c00000 -- 0x006c00000 (32 MB) [ 1.242871] backup: 0x006c00000 -- 0x00a000000 (52 MB) [ 1.242879] cache: 0x00a000000 -- 0x012000000 (128 MB) [ 1.242888] kpanic: 0x012000000 -- 0x012400000 (4 MB) [ 1.242897] system: 0x012400000 -- 0x042400000 (768 MB) [ 1.242905] metadata: 0x042400000 -- 0x042800000 (4 MB) [ 1.242914] userdata: 0x042800000 -- 0x082800000 (1024 MB) [ 1.242922] radical_update: 0x082800000 -- 0x086800000 (64 MB) [ 1.242932] user: 0x086800000 -- 0x3a3a00000 (12754 MB) [ 1.242956] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p151390..dw_mci_set_ios: no card. [mmc1] [ 1.247476] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo [ 1.247489] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized [ 1.247752] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a [ 1.247945] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller. [ 1.248057] 3379..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2] [ 1.248067] mmc2 : Rockchip specific MHSC: Ver 1.13 2014-09-05 [ 1.248319] 1390..dw_mci_set_ios: no card. [mmc2] [ 1.267119] 1390..dw_mci_set_ios: no card. [mmc2] [ 1.286830] 1390..dw_mci_set_ios: no card. [mmc2] [ 1.286839] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo [ 1.286846] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized [ 1.287072] hidraw: raw HID events driver (C) Jiri Kosina [ 1.288403] usbcore: registered new interface driver usbhid [ 1.288413] usbhid: USB HID core driver [ 1.288686] zram: Created 1 device(s) ... [ 1.288949] ashmem: initialized [ 1.289061] logger: created 256K log 'log_main' [ 1.289153] logger: created 256K log 'log_events' [ 1.289243] logger: created 256K log 'log_radio' [ 1.289338] logger: created 256K log 'log_system' [ 1.290359] input: rk29-keypad as /devices/ff100000.adc/key.37/input/input1 [ 1.291130] es8323 probe i2c recv ok [ 1.291203] i2c-core: driver [ES8323] using legacy suspend method [ 1.291212] i2c-core: driver [ES8323] using legacy resume method [ 1.291965] rockchip-hdmi-spdif rockchip-hdmi-spdif.29: ASoC: CPU DAI (null) not registered [ 1.291994] rockchip_hdmi_spdif_audio_probe() register card failed:-517 [ 1.292012] platform rockchip-hdmi-spdif.29: Driver rockchip-hdmi-spdif requests probe deferral [ 1.292248] es8323_probe [ 1.926772] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> NULL --> Left Line Mux [ 1.926783] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> NULL -> Left Line Mux [ 1.926793] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> NULL --> Left Line Mux [ 1.926802] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> NULL -> Left Line Mux [ 1.926811] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> NULL --> Left Line Mux [ 1.926819] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> NULL -> Left Line Mux [ 1.926828] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> NULL --> Right Line Mux [ 1.926836] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> NULL -> Right Line Mux [ 1.926846] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> NULL --> Right Line Mux [ 1.926854] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> NULL -> Right Line Mux [ 1.926863] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> NULL --> Right Line Mux [ 1.926870] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> NULL -> Right Line Mux [ 1.926880] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left PGA Mux [ 1.926887] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left PGA Mux [ 1.926896] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left PGA Mux [ 1.926903] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left PGA Mux [ 1.926912] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> LAMP --> Left PGA Mux [ 1.926920] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> LAMP -> Left PGA Mux [ 1.926929] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right PGA Mux [ 1.926936] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right PGA Mux [ 1.926945] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right PGA Mux [ 1.926953] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right PGA Mux [ 1.926962] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> RAMP --> Right PGA Mux [ 1.926969] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> RAMP -> Right PGA Mux [ 1.926979] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Differential Mux [ 1.926987] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Differential Mux [ 1.926996] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Differential Mux [ 1.927004] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Differential Mux [ 1.927012] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Differential Mux [ 1.927020] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Differential Mux [ 1.927029] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Differential Mux [ 1.927036] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Differential Mux [ 1.927055] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left Line Mux [ 1.927062] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left Line Mux [ 1.927071] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left Line Mux [ 1.927079] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left Line Mux [ 1.927087] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> LAMP --> Left Line Mux [ 1.927095] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> LAMP -> Left Line Mux [ 1.927104] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right Line Mux [ 1.927112] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right Line Mux [ 1.927120] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right Line Mux [ 1.927128] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right Line Mux [ 1.927136] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> RAMP --> Right Line Mux [ 1.927144] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> RAMP -> Right Line Mux [ 1.927258] ES8323 2-0010: ASoC: mux Right Line Mux has no paths [ 1.927269] ES8323 2-0010: ASoC: mux Left Line Mux has no paths [ 1.927279] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths [ 1.927288] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths [ 1.927306] ES8323 2-0010: ASoC: mux Differential Mux has no paths [ 1.930563] rockchip-es8323 rockchip-es8323.31: ES8323 HiFi <-> rockchip-i2s.0 mapping ok [ 1.930887] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.31/sound/card0/input2 [ 1.931538] rockchip-hdmi-i2s rockchip-hdmi-i2s.28: rk-hdmi-i2s-hifi <-> rockchip-i2s.0 mapping ok [ 1.931826] u32 classifier [ 1.931832] Actions configured [ 1.931841] Netfilter messages via NETLINK v0.30. [ 1.931883] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 1.932126] ctnetlink v0.93: registering with nfnetlink. [ 1.932177] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 1.932184] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 1.932381] xt_time: kernel timezone is -0000 [ 1.932533] ip_tables: (C) 2000-2006 Netfilter Core Team [ 1.932635] arp_tables: (C) 2002 David S. Miller [ 1.932666] TCP: cubic registered [ 1.932672] Initializing XFRM netlink socket [ 1.932837] NET: Registered protocol family 10 [ 1.933240] mip6: Mobile IPv6 [ 1.933261] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 1.933352] sit: IPv6 over IPv4 tunneling driver [ 1.933602] NET: Registered protocol family 17 [ 1.933621] NET: Registered protocol family 15 [ 1.933662] Bridge firewalling registered [ 1.933672] Ebtables v2.0 registered [ 1.933792] Bluetooth: RFCOMM TTY layer initialized [ 1.933812] Bluetooth: RFCOMM socket layer initialized [ 1.933819] Bluetooth: RFCOMM ver 1.11 [ 1.933826] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 1.933831] Bluetooth: BNEP filters: protocol multicast [ 1.933841] Bluetooth: BNEP socket layer initialized [ 1.933847] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 1.933856] Bluetooth: HIDP socket layer initialized [ 1.933875] l2tp_core: L2TP core driver, V2.0 [ 1.933885] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 1.933891] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 1.934027] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 1.934037] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi [ 1.934044] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 1.934052] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 1.934059] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 1.934076] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0. [ 1.934094] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0. [ 1.934101] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 1.934120] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V [ 1.934155] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 1.934192] [BT_RFKILL]: Enter rfkill_rk_init [ 1.934295] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147. [ 1.934310] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155. [ 1.934322] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157. [ 1.934334] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154. [ 1.934346] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159. [ 1.934383] [BT_RFKILL]: Request irq for bt wakeup host [ 1.934459] [BT_RFKILL]: ** disable irq [ 1.934520] [BT_RFKILL]: ap6335 device registered. [ 1.935332] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess. [ 1.936017] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0 [ 1.936032] rk3288_init_suspend [ 1.936038] rk3288_suspend_init enter [ 1.936140] rk3288_suspend_init: pm_ctrbits =200007 [ 1.936165] gpio_get_dts_info suspend:4 [ 1.936171] gpio_get_dts_info resume:4 [ 1.936176] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 1.936201] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 1.936344] clks_gating_suspend_init:clkgt info ok [ 1.936423] Registering SWP/SWPB emulation handler [ 1.936701] ddrfreq: verion 1.2 20140526 [ 1.936710] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz [ 1.936718] ddrfreq: auto-freq=0 [ 1.936723] ddrfreq: auto-freq-table[0] 240MHz [ 1.936728] ddrfreq: auto-freq-table[1] 324MHz [ 1.936734] ddrfreq: auto-freq-table[2] 396MHz [ 1.936739] ddrfreq: auto-freq-table[3] 528MHz [ 1.947332] regulator-dummy: disabling [ 1.947653] rockchip-hdmi-spdif rockchip-hdmi-spdif.29: ASoC: CPU DAI (null) not registered [ 1.947677] rockchip_hdmi_spdif_audio_probe() register card failed:-517 [ 1.947690] platform rockchip-hdmi-spdif.29: Driver rockchip-hdmi-spdif requests probe deferral [ 1.947783] pcd_pullup, is_on 0 [ 1.947819] file system registered [ 1.948340] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 1.948349] android_usb gadget: Number of LUNs=2 [ 1.948356] lun0: LUN: removable file: (no medium) [ 1.948362] lun1: LUN: removable file: (no medium) [ 1.948474] android_usb gadget: android_usb ready [ 1.949006] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:03:21 UTC (1293883401) [ 1.953456] rk_spdif:rk_spdif_init [ 1.953622] rk_spdif:Entered spdif_probe [ 1.953800] rk_spdif:spdif:spdif probe ok! [ 1.954281] usbcore: registered new interface driver snd-usb-audio [ 1.954290] ALSA device list: [ 1.954295] #0: RK_ES8323 [ 1.954300] #1: RK-HDMI-I2S [ 1.954468] rockchip-hdmi-spdif rockchip-hdmi-spdif.29: rk-hdmi-spdif-hifi <-> rockchip-spdif mapping ok [ 1.954652] Freeing unused kernel memory: 592K (c0af1000 - c0b85000) [ 1.959089] SELinux: Permission attach_queue in class tun_socket not defined in policy. [ 1.959103] SELinux: the above unknown classes and permissions will be denied [ 2.303326] type=1403 audit(1293883401.850:2): policy loaded auid=4294967295 ses=4294967295 [ 2.303429] SELinux: Loaded policy from /sepolicy [ 2.304877] type=1404 audit(1293883401.850:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295 [ 2.812003] dwc_otg_hcd_enable, enable host controller [ 2.935360] Using Buffer DMA mode [ 2.935371] Periodic Transfer Interrupt Enhancement - disabled [ 2.935377] Multiprocessor Interrupt Enhancement - disabled [ 2.935384] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 2.935389] ^^^^^^^^^^^^^^^^^^Host Mode [ 2.979364] Init: Power Port (0) [ 2.979406] ff540000.usb resume, HPRT0:0x21401 [ 3.117096] Indeed it is in host mode hprt0 = 00021501 [ 3.294199] usb 3-1: new high-speed USB device number 2 using usb20_host [ 3.294280] Indeed it is in host mode hprt0 = 00001101 [ 3.387077] init: /dev/hw_random not found [ 3.388239] type=1400 audit(1293883402.950:4): avc: denied { mount } for pid=1 comm="init" name="/" dev="functionfs" ino=2237 scontext=u:r:kernel:s0 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=1 [ 3.388327] android_usb: already disabled [ 3.388449] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}' [ 3.388459] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial' [ 3.388550] drmboot: module license 'unspecified' taints kernel. [ 3.388558] Disabling lock debugging due to kernel taint [ 3.389317] %s: ok, 20130810 [ 3.491187] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101 [ 3.491199] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 3.491208] usb 3-1: Product: USB 2.0 Hub [MTT] [ 3.491531] hub 3-1:1.0: USB hub found [ 3.491581] hub 3-1:1.0: 4 ports detected [ 3.609059] ff540000.usb suspend, HPRT0:0x1485 [ 8.186578] init: /sbin/e2fsck terminated by exit(8) ount /let/blocfoundtform/emic_by-natzdcachecouormat find aext4 dat/block/platf co/emmct f-nd a/caczde' [ 8.1king ] initT /devbio_randpennot fou: c :27 8.1901dli andonsd_usb: FIQeady roidbled [ t f8nd 6] inzda Unabee tookpen forsistentuleop [ dwa8.19030bo rd t: usidb deprecaole syntIQ0foraspecp_hang pro=ertyit=o.pro mt.manufark2rer', d:0 000ame} @0xtead [ par.1903r), x00t: u00@g dep020at(ubsynta0x0or speci0xing 400perisc'ro.p000uct.m0del006use $esome} instea008[ 80190e00] initel),in0 depr00@ted s160ax boo spex00ying p@0x0rty 000.secovlno',0x0e ${000e0x0nste000 [ 8.19x006] in0@0 00sys 8.0x0428] 0nitx00annot0(mpand '$r,0xerialn00@0h002 writ(us to '/sysx00ass/a0@0o0d414b/andadic0/iuprial',-@ 834010(u] reastoescriptor=em[ ade9.ti1] ramp stri-02 6_1 8.113 79] pcd_p-1 up, oidooot erialno=100612000000033C androidboot.mode=emmccmdline=console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user) storagemedia=emmc loader.timestamp=2015-02-26_14:42:13 hdmi.vic=-1 androidboot.serialno=100612000000033C androidboot.mode=emmc
bootmode = emmc
recovery filesystem table
0 /mnt/internal_sd vfat /dev/block/platform/ff0f0000.rksdmmc/by-name/user 0
1 /mnt/external_sd vfat /dev/block/mmcblk1p1 0
2 /system ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/system 0
3 /cache ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/cache 0
4 /metadata ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata 0
5 /data ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata 0
6 /cust ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/cust 0
7 /custom ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/custom 0
8 /radical_update ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/radical_update 0
9 /misc emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/misc 0
10 /uboot emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/uboot 0
11 /charge emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/charge 0
12 /resource emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/resource 0
13 /parameter emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/parameter 0
14 /boot emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/boot 0
15 /recovery emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/recovery 0
16 /backup emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/backup 0
17 /tmp ramdisk ramdisk 0
I/ [File] : bootable/recovery/recovery.cpp; [Line] : 1577; [Func] : void SetSdcardRootPath(); InternalSD_ROOT: /mnt/internal_sd
I/ [File] : bootable/recovery/recovery.cpp; [Line] : 1579; [Func] : void SetSdcardRootPath(); ExternalSD_ROOT: /mnt/external_sd
failed to create /cache dir,err=File exists!
[ 8.489495] EXT4-fs (mmcblk0p9): recovery complete
failed to read font: res=-1
can’t open /dev/tty0: No such file or directory
framebuffer: fd 7 (1024 x 768)
sh: applet not found
请问是怎么回事?为什么修改dts后,不能进recovery????
3、将2中,dts中&hdmi status=“okay”改为status = “disabled”,按照1中进行烧写,系统能正常进入recovery和重新系统,正常进入系统。
我需要hdmi输出,请问怎么解决这个问题。
