直接用./build.sh编译不过去,要怎么设置呢
Which would you like? [1] firefly_rk3308_release
#TARGET_BOARD=rk3308
#BUILD_TYPE=64
#OUTPUT_DIR=output/firefly_rk3308_release
#CONFIG=firefly_rk3308_release_defconfig
make: *** O=/output/firefly_rk3308_release: No such file or directory. Stop.
Makefile:2: /output/firefly_rk3308_release/Makefile: No such file or directory
make: Warning: File Makefile' has modification time 1.7e+04 s in the future make: *** No rule to make target /output/firefly_rk3308_release/Makefile’. Stop.
you take 0:00.09 to build builroot
====Build buildroot failed!====
