基于Firefly RK3399 二次开发,运行进入内核后卡死
有时候运行到这里:
[ 5.867033] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/rockchip-key/power-key[0]’ - status (0)
[ 5.867372] input: rk29-keypad as /devices/platform/rockchip-key/input/input2
[ 6.075179] read channel() error: -110
还有时候运行到这里:
[ 9.368312] Exception stack(0xffffffc00a36b710 to 0xffffffc00a36b840)
[ 9.374758] b700: ffffff800935fd40 0000008000000000
[ 9.382591] b720: 00000000014aa000 ffffff8008b15540 0000000080400045 0000000000000000
[ 9.390424] b740: ffffffc00a36b9b8 ffffff800838c5bc 00000000ffffffff 0000000000000004
[ 9.398256] b760: ffffffc000030001 f
[14:32:24.328]êÕ¡û¡ôfffff8008b15540 00000000ffffffe0 ffffffc00a36b9a0
[ 9.406089] b780: ffffffc0f1020a06 ffffffc0f1020a00 ffffff8008ece3c9 ffffffc0f1020a0b
[ 9.413921] b7a0: ffffffc00a36b7e0 ffffff800854bd7c ffffffc0f1eef800 00000000fffffdf4
[ 9.421754] b7c0: ffffffc00a36b800 ffffff8008546c94 ffffffc0f1eef800 cb88537fdc8ba667
[ 9.429587] b7e0: ffffff800935fd40 0000000000000000 0000000000000000 0000000000000002
[ 9.437420] b800: 000000000000016d ffffffc00a36ba18 000000000000ffff 0000000000000000
[ 9.445253] b820: 0000000000000000 0000000000000000 716f5e723167ff2f 7f7f7f7f7f7f7f7f
[ 9.453085] [] __proc_create+0x68/0x1f4
[ 9.458485] [] __proc_create+0x68/0x1f4
[ 9.463885] [] proc_mkdir_data+0x3c/0xa4
[ 9.469372] [] proc_mkdir+0x18/0x20
[ 9.474426] [] register_irq_proc+0x8c/0x158
[ 9.480174] [] __setup_irq+0x550/0x668
[ 9.485486] [] request_threaded_irq+0xf4/0x140
[ 9.491497] [] devm_request_threaded_irq+0x7c/0xc0
[ 9.497858] [] keys_probe+0x444/0x640
[ 9.503086] [] platform_drv_probe+0x58/0xa4
[ 9.508835] [] driver_probe_device+0x118/0x2ac
[ 9.514846] [] __driver_attach+0x64/0x90
[ 9.520333] [] bus_for_each_dev+0x80/0xb0
[ 9.525907] [] driver_attach+0x20/0x28
[ 9.531219] [] bus_add_driver+0xe8/0x1e4
[ 9.536707] [] driver_register+0x94/0xe0
[ 9.542195] [] __platform_driver_register+0x48/0x50
[ 9.548645] [] rk_keys_driver_init+0x18/0x20
[ 9.554481] [] do_one_initcall+0x178/0x194
[ 9.560145] [] kernel_init_freeable+0x1a4/0x25c
[ 9.566243] [] kernel_init+0x10/0xf8
[ 9.571380] [] ret_from_fork+0x10/0x40
[ 9.576697] Code: a9425bf5 6b1f001f 1a810000 a8c37bfd (00000000)
[ 9.582793] —[ end trace fa5427ea05a7e07c ]—
--------------------------------分割线-------------------------------------
想请原厂的技术师傅们指导一下,这种情况发生的原因?
另外想了解一下,Firefly RK3399有商业保密措施吗,在二次开发的硬件平台固件不能运行是不是这个原因?
盼复。
不懂你二次开发做了哪些改动,这个跟加密措施无关。
那您方便说一下加密措施包含哪些方面吗?
或者说,如果完全参考Firefly做一块开发板,烧您这边的固件,能跟FireFly一样启动吗?
应该时你改动了dts配置吧,看似内核挂了。。。
0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.767548] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.767566] usb wifi rtw_drv_entry 1632
[ 1.767576] RTW: rtl8821cu v5.4.1_28754.20180921_COEX20180712-3232
[ 1.767586] RTW: build time: Apr 12 2019 14:14:54
[ 1.767596] RTW: rtl8821cu BT-Coex version = COEX20180712-3232
[ 1.767634] RTW: rtw_inetaddr_notifier_register
[ 1.767687] usbcore: registered new interface driver rtl8821cu
[ 1.767698] RTW: module init ret=0
[ 1.767750] usbcore: registered new interface driver catc
[ 1.767793] usbcore: registered new interface driver kaweth
[ 1.767810] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.767848] usbcore: registered new interface driver pegasus
[ 1.767894] usbcore: registered new interface driver rtl8150
[ 1.767937] usbcore: registered new interface driver r8152
[ 1.767952] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.768012] usbcore: registered new interface driver hso
[ 1.768062] usbcore: registered new interface driver asix
[ 1.768107] usbcore: registered new interface driver ax88179_178a
[ 1.768150] usbcore: registered new interface driver cdc_ether
[ 1.768191] usbcore: registered new interface driver cdc_eem
[ 1.768233] usbcore: registered new interface driver dm9601
[ 1.768286] usbcore: registered new interface driver smsc75xx
[ 1.768340] usbcore: registered new interface driver smsc95xx
[ 1.768383] usbcore: registered new interface driver gl620a
[ 1.768425] usbcore: registered new interface driver net1080
[ 1.768467] usbcore: registered new interface driver plusb
[ 1.768509] usbcore: registered new interface driver rndis_host
[ 1.768553] usbcore: registered new interface driver cdc_subset
[ 1.768597] usbcore: registered new interface driver zaurus
[ 1.768641] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.768707] usbcore: registered new interface driver int51x1
[ 1.768749] usbcore: registered new interface driver kalmia
[ 1.768792] usbcore: registered new interface driver ipheth
[ 1.768841] usbcore: registered new interface driver sierra_net
[ 1.768884] usbcore: registered new interface driver cx82310_eth
[ 1.768937] usbcore: registered new interface driver cdc_ncm
[ 1.768979] usbcore: registered new interface driver qmi_wwan
[ 1.769024] usbcore: registered new interface driver cdc_mbim
[ 1.770151] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.775206] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.775782] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.775801] ehci-pci: EHCI PCI platform driver
[ 1.775879] ehci-platform: EHCI generic platform driver
[ 1.779197] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.779226] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.779378] ehci-platform fe3c0000.usb: irq 29, io mem 0xfe3c0000
[ 1.789180] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.789313] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.789329] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.789343] usb usb1: Product: EHCI Host Controller
[ 1.789355] usb usb1: Manufacturer: Linux 4.4.83 ehci_hcd
[ 1.789366] usb usb1: SerialNumber: fe3c0000.usb
[ 1.789817] hub 1-0:1.0: USB hub found
[ 1.789850] hub 1-0:1.0: 1 port detected
[ 1.790321] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.790351] ohci-platform: OHCI generic platform driver
[ 1.790806] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.790836] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.790948] ohci-platform fe3e0000.usb: irq 30, io mem 0xfe3e0000
[ 1.846646] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.846663] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.846677] usb usb2: Product: Generic Platform OHCI controller
[ 1.846689] usb usb2: Manufacturer: Linux 4.4.83 ohci_hcd
[ 1.846701] usb usb2: SerialNumber: fe3e0000.usb
[ 1.847114] hub 2-0:1.0: USB hub found
[ 1.847148] hub 2-0:1.0: 1 port detected
[ 1.847903] usbcore: registered new interface driver cdc_acm
[ 1.847915] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.847976] usbcore: registered new interface driver usblp
[ 1.848027] usbcore: registered new interface driver cdc_wdm
[ 1.848075] usbcore: registered new interface driver uas
[ 1.848148] usbcore: registered new interface driver usb-storage
[ 1.848191] usbcore: registered new interface driver ums-alauda
[ 1.848233] usbcore: registered new interface driver ums-cypress
[ 1.848276] usbcore: registered new interface driver ums-datafab
[ 1.848320] usbcore: registered new interface driver ums_eneub6250
[ 1.848365] usbcore: registered new interface driver ums-freecom
[ 1.848409] usbcore: registered new interface driver ums-isd200
[ 1.848451] usbcore: registered new interface driver ums-jumpshot
[ 1.848494] usbcore: registered new interface driver ums-karma
[ 1.848536] usbcore: registered new interface driver ums-onetouch
[ 1.848579] usbcore: registered new interface driver ums-sddr09
[ 1.848622] usbcore: registered new interface driver ums-sddr55
[ 1.848667] usbcore: registered new interface driver ums-usbat
[ 1.848752] usbcore: registered new interface driver usbserial
[ 1.848789] usbcore: registered new interface driver usbserial_generic
[ 1.848821] usbserial: USB Serial support registered for generic
[ 1.848867] usbcore: registered new interface driver ch341
[ 1.848897] usbserial: USB Serial support registered for ch341-uart
[ 1.848942] usbcore: registered new interface driver cp210x
[ 1.848974] usbserial: USB Serial support registered for cp210x
[ 1.849027] usbcore: registered new interface driver option
[ 1.849057] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.849201] usbcore: registered new interface driver pl2303
[ 1.849235] usbserial: USB Serial support registered for pl2303
[ 1.849289] usbcore: registered new interface driver trancevibrator
[ 1.849307] usb20_otg: version 3.10a 21-DEC-2012
[ 1.849467] usb20_host: version 3.10a 21-DEC-2012
[ 1.853238] usbcore: registered new interface driver xpad
[ 1.853293] usbcore: registered new interface driver usb_acecad
[ 1.853344] usbcore: registered new interface driver aiptek
[ 1.853395] usbcore: registered new interface driver gtco
[ 1.853443] usbcore: registered new interface driver hanwang
[ 1.853490] usbcore: registered new interface driver kbtab
[ 1.853507] fts_ts_init 1838
[ 1.853533] fts_ts_initasync 1832
[ 1.853575] ==gsl_ts_init==
[ 1.853601] ret=0
[ 1.857297] .. rk pwm remotectl v1.1 init
[ 1.857523] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.857923] remotectl-pwm ff420030.pwm: set irq err, set support_psci to 0 !!
[ 1.858036] sensor_register_slave:mma8452,id=17
[ 1.858054] sensor_register_slave:lis3dh,id=7
[ 1.858070] sensor_register_slave:mma7660,id=18
[ 1.858086] sensor_register_slave:lsm303d,id=22
[ 1.858103] sensor_register_slave:mpu6880_acc,id=24
[ 1.858120] sensor_register_slave:mpu6500_acc,id=25
[ 1.858136] sensor_register_slave:lsm330_acc,id=26
[ 1.858153] sensor_register_slave:akm8975,id=28
[ 1.858169] sensor_register_slave:akm8963,id=29
[ 1.858186] sensor_register_slave:l3g4200d,id=43
[ 1.858202] sensor_register_slave:l3g20d,id=44
[ 1.858218] sensor_register_slave:ewtsa,id=45
[ 1.858234] sensor_register_slave:lsm330_gyro,id=48
[ 1.858250] sensor_register_slave:cm3217,id=50
[ 1.858266] sensor_register_slave:cm3218,id=51
[ 1.858918] i2c /dev entries driver
[ 1.860636] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.860705] fan53555-reg: supplied by vcc5v0_sys
[ 1.864842] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.864890] fan53555-reg: supplied by vcc5v0_sys
[ 1.869153] rk808 0-001b: Pmic Chip id: 0x0
[ 1.876984] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.877038] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.877124] DCDC_REG1: supplied by vcc5v0_sys
[ 1.878657] DCDC_REG2: supplied by vcc5v0_sys
[ 1.879726] DCDC_REG3: supplied by vcc5v0_sys
[ 1.879930] DCDC_REG4: supplied by vcc5v0_sys
[ 1.880623] LDO_REG1: supplied by vcc3v3_sys
[ 1.882307] LDO_REG2: supplied by vcc3v3_sys
[ 1.883525] LDO_REG3: supplied by vcc3v3_sys
[ 1.884744] LDO_REG4: supplied by vcc3v3_sys
[ 1.885984] LDO_REG5: supplied by vcc3v3_sys
[ 1.887197] LDO_REG6: supplied by vcc3v3_sys
[ 1.888407] LDO_REG7: supplied by vcc3v3_sys
[ 1.889644] LDO_REG8: supplied by vcc3v3_sys
[ 1.890867] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.891080] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.900640] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.901743] rk808 0-001b: Can not read property pmic,hold-gpio
[ 1.901764] rk808 0-001b: Can not read property pmic,stby-gpio
[ 1.901793] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80097f8000
[ 1.902372] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80097fa000
[ 1.902454] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 1.902471] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 1.902485] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 1.902518] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 1.902864] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80097fc000
[ 1.910898] fusb302 4-0022: port 0 probe success
[ 1.911034] GSLX680 Enter gsl_ts_probe
[ 2.095851] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 2.219177] gsl_ts_probe–1253, i2c_master_recv fail
[ 2.219309] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80097fe000
[ 2.220075] IR NEC protocol handler initialized
[ 2.220090] IR RC5(x/sz) protocol handler initialized
[ 2.220105] IR RC6 protocol handler initialized
[ 2.220120] IR JVC protocol handler initialized
[ 2.220134] IR Sony protocol handler initialized
[ 2.220148] IR SANYO protocol handler initialized
[ 2.220161] IR Sharp protocol handler initialized
[ 2.220176] IR MCE Keyboard/mouse protocol handler initialized
[ 2.220191] IR XMP protocol handler initialized
[ 2.220285] usbcore: registered new interface driver uvcvideo
[ 2.220296] USB Video Class driver (1.1.1)
[ 2.220314] CamSys driver version: v0.34.3, CamSys head file version: v0.13.0
[ 2.222530] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 2.222663] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 2.222901] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 2.222996] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 2.225114] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 2.225205] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[ 2.225221] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.225235] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 2.226136] device-mapper: uevent: version 1.0.3
[ 2.226460] hub 1-1:1.0: USB hub found
[ 2.226503] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.226550] hub 1-1:1.0: 4 ports detected
[ 2.230003] Bluetooth: HCI UART driver ver 2.3
[ 2.230018] Bluetooth: HCI UART protocol H4 registered
[ 2.230028] Bluetooth: HCI UART protocol LL registered
[ 2.230044] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 2.230054] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 2.230065] rtk_btusb: Register usb char device interface for BT driver
[ 2.230261] usbcore: registered new interface driver rtk_btusb
[ 2.230660] cpu cpu0: leakage=24
[ 2.247607] cpu cpu0: temp=43333, pvtm=147851 (147719 + 132)
[ 2.248063] cpu cpu0: pvtm-sel=1
[ 2.248351] cpu cpu4: leakage=43
[ 2.263225] cpu cpu4: temp=42777, pvtm=159977 (159942 + 35)
[ 2.265770] cpu cpu4: pvtm-sel=2
[ 2.272628] sdhci: Secure Digital Host Controller Interface driver
[ 2.272644] sdhci: Copyright(c) Pierre Ossman
[ 2.272659] Synopsys Designware Multimedia Card Interface Driver
[ 2.273491] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.273599] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.273620] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.273668] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.273693] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.273791] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 2.274042] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.274058] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.285955] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.300320] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.300558] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.302222] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.302236] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.329322] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.332258] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.335619] usbcore: registered new interface driver usbhid
[ 2.335635] usbhid: USB HID core driver
[ 2.336026] inv-mpu-iio 4-0068: int_config=0,level_shifter=0,client.addr=68,client.irq=66
[ 2.336042] inv-mpu-iio 4-0068: 0
[ 2.336053] inv-mpu-iio 4-0068: -1
[ 2.336065] inv-mpu-iio 4-0068: 0
[ 2.336076] inv-mpu-iio 4-0068: -1
[ 2.336086] inv-mpu-iio 4-0068: 0
[ 2.336098] inv-mpu-iio 4-0068: 0
[ 2.336108] inv-mpu-iio 4-0068: 0
[ 2.336119] inv-mpu-iio 4-0068: 0
[ 2.336130] inv-mpu-iio 4-0068: -1
[ 2.336141] inv-mpu-iio 4-0068:
[ 2.336150] inv_mpu_iio: secondary_i2c_addr=0
[ 2.336383] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.370052] mmc1: MAN_BKOPS_EN bit is not set
[ 2.381975] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 2.382852] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 2.383345] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 2.383883] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 2.384841] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 2.385459] rkpart: partition size too small (5)
[ 2.385477] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 2.385490] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 2.385502] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 2.385514] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 2.385526] resource: 0x001000000 – 0x002000000 (16 MB)
[ 2.385539] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 2.385551] boot: 0x003800000 – 0x005800000 (32 MB)
[ 2.385563] recovery: 0x005800000 – 0x007800000 (32 MB)
[ 2.385574] backup: 0x007800000 – 0x00e800000 (112 MB)
[ 2.385587] cache: 0x00e800000 – 0x016800000 (128 MB)
[ 2.385599] system: 0x016800000 – 0x076800000 (1536 MB)
[ 2.385611] metadata: 0x076800000 – 0x077800000 (16 MB)
[ 2.385623] baseparamer: 0x077800000 – 0x077c00000 (4 MB)
[ 2.385636] userdata: 0x077c00000 – 0x3a3a00000 (12990 MB)
[ 2.385707] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 2.439653] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.542979] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.646312] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.749766] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.853098] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.956427] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.059760] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.163093] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.266428] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.473150] i2c i2c-4: inv_mpu_probe failed -6
[ 3.473173] inv-mpu-iio: probe of 4-0068 failed with error -5
[ 3.473201] inv_mpu_iio: inv_mpu_init:746
[ 3.473932] ashmem: initialized
[ 3.475106] ff100000.saradc supply vref not found, using dummy regulator
[ 3.480930] rknandbase v1.1 2016-11-08
[ 3.481592] usbcore: registered new interface driver snd-usb-audio
[ 3.482229] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 3.484176] u32 classifier
[ 3.484186] Actions configured
[ 3.484206] Netfilter messages via NETLINK v0.30.
[ 3.484241] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.484449] ctnetlink v0.93: registering with nfnetlink.
[ 3.485248] xt_time: kernel timezone is -0000
[ 3.486809] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.487236] arp_tables: (C) 2002 David S. Miller
[ 3.487879] Initializing XFRM netlink socket
[ 3.488970] NET: Registered protocol family 10
[ 3.490843] mip6: Mobile IPv6
[ 3.490916] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.492906] sit: IPv6 over IPv4 tunneling driver
[ 3.493985] NET: Registered protocol family 17
[ 3.494052] NET: Registered protocol family 15
[ 3.494148] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.495229] Bridge firewalling registered
[ 3.495268] Ebtables v2.0 registered
[ 3.495563] Bluetooth: RFCOMM TTY layer initialized
[ 3.495597] Bluetooth: RFCOMM socket layer initialized
[ 3.495691] Bluetooth: RFCOMM ver 1.11
[ 3.495744] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.495765] Bluetooth: BNEP filters: protocol multicast
[ 3.495795] Bluetooth: BNEP socket layer initialized
[ 3.495876] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.495909] Bluetooth: HIDP socket layer initialized
[ 3.495989] l2tp_core: L2TP core driver, V2.0
[ 3.496041] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 3.496077] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 3.496663] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 3.496779] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 3.496802] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 3.496825] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 3.496961] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 3.496985] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 3.497008] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 3.497130] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.497930] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 3.498029] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 3.498103] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 3.498177] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 3.498809] [BT_RFKILL]: Failed to get bt_default_reset gpio.
[ 3.498863] rfkill_bt: probe of wireless-bluetooth failed with error -1
[ 3.499104] sensor_register_slave:mpu6880_gyro,id=47
[ 3.500675] Registered cp15_barrier emulation handler
[ 3.500728] vendor storage:20160801 ret = 0
[ 3.500822] Registered setend emulation handler
[ 3.502749] registered taskstats version 1
[ 3.504857] rockchip ion idev is NULL
[ 3.504891] rga2 ff680000.rga: rga ion client create success!
[ 3.505410] rga: Driver loaded successfully ver:3.02
[ 3.507630] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 3.512085] disable 56
[ 3.512448] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.512884] disable 55
[ 3.513045] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.513420] rockchip-dp ff970000.edp: failed to get vcc regulator: -19
[ 3.513449] rockchip-dp ff970000.edp: failed to get vccio regulator: -19
[ 3.513766] !!!rockchip_dp_phy_power_on 82!!!
[ 3.554283] rockchip-drm display-subsystem: bound ff970000.edp (ops rockchip_dp_component_ops)
[ 3.554986] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 3.555016] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 3.555102] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 3.556990] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 3.557018] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.557028] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 3.557475] error zero modes
[ 3.557489] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 3.557599] analogix_dp_get_modes 951 con name=eDP-1
[ 3.557615] analogix_dp_get_modes 955 con name=eDP-1 0
[ 3.559941] rockchip-dp ff970000.edp: AUX CH command reply failed!
[ 3.562698] rockchip-dp ff970000.edp: AUX CH command reply failed!
[ 3.562718] -----drm_helper_probe_single_connector_modes_merge_bits 214 0 -----
[ 3.562856] rockchip-drm display-subsystem: failed to show loader logo
[ 3.562875] analogix_dp_get_modes 951 con name=eDP-1
[ 3.562887] analogix_dp_get_modes 955 con name=eDP-1 0
[ 3.565507] rockchip-dp ff970000.edp: AUX CH command reply failed!
[ 3.566149] -----drm_helper_probe_single_connector_modes_merge_bits 214 0 -----
[ 3.566176] error zero modes
[ 3.569542] rockchip_gem_alloc_buf 426 domain=1 kmap=1(false?)
[ 3.570318] rockchip-drm display-subsystem: fb0: frame buffer device
[ 3.581015] kbase_platform_device_probe 3568
[ 3.581089] kbase_platform_device_probe 3613
[ 3.581833] mali ff9a0000.gpu: leakage=31
[ 3.597275] mali ff9a0000.gpu: temp=42222, pvtm=124576 (124564 + 12)
[ 3.600897] mali ff9a0000.gpu: pvtm-sel=1
[ 3.602878] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 3.603584] kbase_platform_device_probe 3670
[ 3.605322] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 3.606634] mali ff9a0000.gpu: Probed as mali0
[ 3.609050] stmmac_probe_config_dt 135
[ 3.609078] stmmac_probe_config_dt 144
[ 3.609322] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 3.609357] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 3.609386] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 3.609450] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 3.609901] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 3.614938] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 3.615222] ----has gmac stmmac_hw_init 2750
[ 3.615248] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 3.615265] Ring mode enabled
[ 3.615281] DMA HW capability register supported
[ 3.615297] Normal descriptors
[ 3.615316] RX Checksum Offload Engine supported (type 2)
[ 3.615334] TX Checksum insertion supported
[ 3.615349] Wake-Up On Lan supported
[ 3.615438] Enable RX Mitigation via HW Watchdog Timer
[ 3.615462] ++++++++++stmmac_dvr_probe 2967
[ 3.682624] libphy: stmmac: probed
[ 3.682654] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 3.682678] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 3.690874] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[ 3.690893] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 3
[ 3.691063] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 3.691092] xhci-hcd xhci-hcd.8.auto: irq 229, io mem 0xfe800000
[ 3.691171] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.691178] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.691185] usb usb3: Product: xHCI Host Controller
[ 3.691191] usb usb3: Manufacturer: Linux 4.4.83 xhci-hcd
[ 3.691196] usb usb3: SerialNumber: xhci-hcd.8.auto
[ 3.691761] hub 3-0:1.0: USB hub found
[ 3.691778] hub 3-0:1.0: 1 port detected
[ 3.691907] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[ 3.691917] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 4
[ 3.691947] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.691990] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.691997] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.692003] usb usb4: Product: xHCI Host Controller
[ 3.692009] usb usb4: Manufacturer: Linux 4.4.83 xhci-hcd
[ 3.692014] usb usb4: SerialNumber: xhci-hcd.8.auto
[ 3.692330] hub 4-0:1.0: USB hub found
[ 3.692345] hub 4-0:1.0: 1 port detected
[ 3.693065] xhci-hcd xhci-hcd.8.auto: remove, state 1
[ 3.693081] usb usb4: USB disconnect, device number 1
[ 3.716825] xhci-hcd xhci-hcd.8.auto: Host not halted after 16000 microseconds.
[ 3.716833] xhci-hcd xhci-hcd.8.auto: Host controller not halted, aborting reset.
[ 3.716868] xhci-hcd xhci-hcd.8.auto: USB bus 4 deregistered
[ 3.716877] xhci-hcd xhci-hcd.8.auto: remove, state 1
[ 3.716888] usb usb3: USB disconnect, device number 1
[ 3.717351] xhci-hcd xhci-hcd.8.auto: USB bus 3 deregistered
[ 3.722362] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 3.722377] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 3
[ 3.722531] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 3.722561] xhci-hcd xhci-hcd.9.auto: irq 230, io mem 0xfe900000
[ 3.722637] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.722645] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.722652] usb usb3: Product: xHCI Host Controller
[ 3.722658] usb usb3: Manufacturer: Linux 4.4.83 xhci-hcd
[ 3.722663] usb usb3: SerialNumber: xhci-hcd.9.auto
[ 3.723247] hub 3-0:1.0: USB hub found
[ 3.723264] hub 3-0:1.0: 1 port detected
[ 3.723385] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 3.723394] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 4
[ 3.723425] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.723469] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.723476] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.723482] usb usb4: Product: xHCI Host Controller
[ 3.723487] usb usb4: Manufacturer: Linux 4.4.83 xhci-hcd
[ 3.723493] usb usb4: SerialNumber: xhci-hcd.9.auto
[ 3.723869] hub 4-0:1.0: USB hub found
[ 3.723887] hub 4-0:1.0: 1 port detected
[ 3.727636] ehci-platform fe380000.usb: EHCI Host Controller
[ 3.727651] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 3.727755] ehci-platform fe380000.usb: irq 27, io mem 0xfe380000
[ 3.735902] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 3.735970] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.735978] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.735985] usb usb5: Product: EHCI Host Controller
[ 3.735991] usb usb5: Manufacturer: Linux 4.4.83 ehci_hcd
[ 3.735997] usb usb5: SerialNumber: fe380000.usb
[ 3.736482] hub 5-0:1.0: USB hub found
[ 3.736500] hub 5-0:1.0: 1 port detected
[ 3.736840] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 3.736854] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 3.736936] ohci-platform fe3a0000.usb: irq 28, io mem 0xfe3a0000
[ 3.793318] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.793327] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.793335] usb usb6: Product: Generic Platform OHCI controller
[ 3.793341] usb usb6: Manufacturer: Linux 4.4.83 ohci_hcd
[ 3.793347] usb usb6: SerialNumber: fe3a0000.usb
[ 3.793949] hub 6-0:1.0: USB hub found
[ 3.793968] hub 6-0:1.0: 1 port detected
[ 3.794277] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 3.795301] asoc-simple-card hdmi-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 3.796817] asoc-simple-card spdif-sound: dit-hifi ↔ ff870000.spdif mapping ok
[ 3.797541] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 3.798275] otg_wakelock_init: No USB transceiver found
[ 3.798582] sensor_init: Probe name sensors
[ 3.798622] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 3.800750] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:52:36 UTC (1358499156)
[ 3.802979] It doesn’t contain Rogue gpu
u 3.840644]
[ 3.942750] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 416; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-6ef1ea2’, rk_ko_ver is ‘5’, built at ‘11:46:00’, on ‘Apr 16 2019’.
[ 3.942761] lxq mali_module_init 437
[ 3.942985] Mali: +++++Mali device driver loaded+++++
[ 3.943097] rk-keypad rockchip-key: Error rockchip,type property in the DT.
[ 3.943110] rk-keypad: probe of rockchip-key failed with error -22
[ 3.943411] ALSA device list:
[ 3.943416] #0: rockchip,hdmi
[ 3.943420] #1: ROCKCHIP,SPDIF
[ 3.943824] Freeing unused kernel memory: 832K
[ 3.946218] init: init first stage started!
[ 3.978203] audit: type=1403 audit(1358499156.673:2): policy loaded auid=4294967295 ses=4294967295
[ 3.978608] init: (Initializing SELinux non-enforcing took 0.03s.)
[ 3.980615] init: init second stage started!
[ 3.983085] init: Setting ro.rk.soc=rk3399
[ 3.983138] init: OK,EMMC DRIVERS INIT OK
[ 3.983156] init: property_set(“ro.boot.mode”, “emmc”) failed
[ 3.983193] init: property_set(“ro.hardware”, “rk30board”) failed
[ 3.984312] init: Running restorecon…
[ 4.021014] init: waitpid failed: No child processes
[ 4.021377] init: property_set(“ro.board.platform”, “rk3399”) failed
[ 4.021627] init: property_set(“ro.rk.screenoff_time”, “2147483647”) failed
[ 4.021734] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[ 4.021802] init: (Loading properties from /default.prop took 0.00s.)
[ 4.022460] init: could not import file ‘/init.bootmode.emmc.rc’ from ‘/init.rc’: No such file or directory
[ 4.022516] init: could not import file ‘/init.recovery.rk30board.rc’ from ‘/init.rc’: No such file or directory
[ 4.022533] init: (Parsing /init.rc took 0.00s.)
[ 4.022620] init: Starting service ‘ueventd’…
[ 4.022983] init: Starting service ‘healthd’…
[ 4.023284] init: Waiting for /dev/.coldboot_done…
有没有人帮忙看看是什么问题,我的板子启动到这里就挂住了
已经准备进安卓系统桌面了,把不用的,你板上没有的设备删掉
否则系统报错太多就蹦了
我QQ254327173,欢迎加聊
麻烦问下知道怎么回事了吗?
