init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[ 3.379522] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[ 3.379695] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[ 3.379917] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[ 3.380104] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[ 3.380278] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[ 3.380448] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[ 3.380625] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[ 3.380847] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[ 3.381038] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[ 3.381222] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[ 3.381450] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[ 3.381634] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[ 3.381816] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[ 3.382105] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[ 3.382304] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[ 3.382492] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[ 3.382675] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[ 3.382858] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[ 3.383041] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[ 3.383222] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[ 3.383405] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[ 3.383577] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[ 3.383744] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[ 3.383919] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[ 3.384099] init: ignored duplicate definition of service ‘ril-daemon’init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[ 3.384301] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[ 3.384474] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[ 3.384670] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[ 3.384858] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[ 3.385051] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[ 3.385857] init: property_set(“ro.board.platform”, “rk3399”) failed
[ 3.386094] init: property_set(“ro.rk.screenoff_time”, “2147483647”) failed
[ 3.386187] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[ 3.386261] init: (Loading properties from /system/build.prop took 0.00s.)
[ 3.386286] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 3.386307] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 3.386367] fs_mgr: Warning: unknown flag resize
[ 3.386419] init: /recovery not specified in fstab
[ 3.386474] init: Starting service ‘healthd’…
[ 3.386951] init: cannot find ‘/system/bin/displayd’ (No such file or directory), disabling ‘displayd’
[ 3.387878] init: Starting service ‘zygote’…
[ 3.388377] init: Starting service ‘zygote_secondary’…
[ 3.389001] init: Starting service ‘lmkd’…
[ 3.389736] init: Starting service ‘servicemanager’…
[ 3.389856] binder: 197:197 transaction failed 29189/-22, size 0-0 line 2951
[ 3.390622] init: Starting service ‘surfaceflinger’…
[ 3.392810] random: lmkd: uninitialized urandom read (40 bytes read, 44 bits of entropy available)
[ 3.393791] init: Starting service ‘vold’…
[ 3.394800] random: servicemanager: uninitialized urandom read (40 bytes read, 45 bits of entropy available)
[ 3.398346] random: app_process32: uninitialized urandom read (40 bytes read, 45 bits of entropy available)
[ 3.400363] random: vold: uninitialized urandom read (40 bytes read, 46 bits of entropy available)
[ 3.400879] random: surfaceflinger: uninitialized urandom read (40 bytes read, 46 bits of entropy available)
[ 3.400993] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali_kbase.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/rk30_mirroring.ko”) failed: No such file or directoryinit: finit_module for “/system/lib/modules/rk29-ipp.ko” failed: Exec format errorinit: insmod: open(“/system/lib/modules/pvrsrvkm.ko”) failed: No such file or directory
[ 3.401738] random: app_process64: uninitialized urandom read (40 bytes read, 46 bits of entropy available)
[ 3.402017] init: finit_module for “/drmboot.ko” failed: Exec format errorfs_mgr: Warning: unknown flag resize
[ 3.403364] zram0: detected capacity change from 0 to 533413888
[ 3.436216] random: mkswap: uninitialized urandom read (40 bytes read, 50 bits of entropy available)
[ 3.444960] random: mkswap: uninitialized urandom read (16 bytes read, 51 bits of entropy available)
[ 3.446164] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 3.448661] init: Starting service ‘debuggerd’…
[ 3.449435] init: Starting service ‘debuggerd64’…
[ 3.454090] init: Not bootcharting.
[ 3.723646] fs_mgr: Warning: unknown flag resize
[ 3.775034] init: Starting service ‘exec 1 (/system/bin/tzdatacheck)’…
[ 3.789795] init: Service ‘exec 1 (/system/bin/tzdatacheck)’ (pid 218) exited with status 0
[ 3.794570] audit: type=1400 audit(1358499006.443:4): avc: denied { setattr } for pid=1 comm=“init” name=“cifsmanager” dev=“mmcblk1p13” ino=86 scontext=u:r:init:s0 tcontext=u:object_r:cifsmanager_exec:s0 tclass=dir permissive=1
[ 3.795968] F2FS-fs (mmcblk1p13): acl options not supported
[ 3.795982] F2FS-fs (mmcblk1p13): Unrecognized mount option “errors=panic” or missing value
[ 3.797366] init: (Loading properties from /data/local.prop took 0.00s.)
[ 3.799726] init: Starting service ‘logd’…
[ 3.800521] init: Starting service ‘logd-reinit’…
[ 3.801469] init: write_file: Unable to open ‘/proc/sys/vm/min_free_order_shift’: No such file or directory
[ 3.802658] init: SELinux: Could not stat /sys/devices/system/cpu/cpufreq/interactive: No such file or directory.
[ 3.803561] init: write_file: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold’: No such file or directory
[ 3.805101] audit: type=1400 audit(1358499006.453:5): avc: denied { relabelto } for pid=1 comm=“init” name=“recovery” dev=“tmpfs” ino=9349 scontext=u:r:init:s0 tcontext=u:object_r:recovery_block_device:s0 tclass=lnk_file permissive=1
[ 3.805161] audit: type=1400 audit(1358499006.453:6): avc: denied { relabelto } for pid=1 comm=“init” name=“boot” dev=“tmpfs” ino=9345 scontext=u:r:init:s0 tcontext=u:object_r:boot_block_device:s0 tclass=lnk_file permissive=1
[ 3.806316] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 3.806332] init: write: cannot expand ‘${ro.serialno}’
[ 3.806929] file system registered
[ 3.814080] using random self ethernet address
[ 3.814093] using random host ethernet address
[ 3.814137] init: write_file: Unable to open ‘/config/usb_gadget/g1/functions/rndis.gs4/wceis’: Permission denied
[ 3.820001] init: Starting service ‘console’…
[ 3.820785] init: Starting service ‘adbd’…
[ 3.821353] init: cannot find ‘/system/bin/update_verifier’ (No such file or directory), disabling ‘exec 2 (/system/bin/update_verifier)’
[ 3.821384] init: cannot find ‘/system/bin/install-recovery.sh’ (No such file or directory), disabling ‘flash_recovery’
[ 3.821705] init: Starting service ‘drmservice’…
[ 3.822090] init: cannot find ‘/system/bin/bplus_helper’ (No such file or directory), disabling ‘bplus_helper’
[ 3.822313] init: Service up_eth0 does not have a SELinux domain defined.
[ 3.822330] init: cannot find ‘/system/bin/rk_store_keybox’ (No such file or directory), disabling ‘rk_store_keybox’
[ 3.822410] init: Starting service ‘akmd’…
[ 3.822968] init: Starting service ‘audioserver’…
[ 3.823874] init: Starting service ‘cameraserver’…
[ 3.824513] init: Starting service ‘drm’…
[ 3.825072] init: Starting service ‘installd’…
[ 3.825559] init: Starting service ‘keystore’…
[ 3.826077] init: Starting service ‘mediacodec’…
[ 3.827104] init: couldn’t write 240 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 3.836914] init: Starting service ‘mediadrm’…
[ 3.837558] init: Starting service ‘mediaextractor’…
[ 3.838140] init: Starting service ‘media’…
[ 3.838834] init: Starting service ‘netd’…
[ 3.839418] init: Starting service ‘gatekeeperd’…
[ 3.850451] init: Starting service ‘perfprofd’…
[ 3.851188] init: Service ‘logd-reinit’ (pid 233) exited with status 145
[ 3.871424] init: Service ‘drmservice’ (pid 237) exited with status 0
[ 3.878202] init: Service ‘akmd’ (pid 238) exited with status 254
[ 4.040013] read descriptors
[ 4.040033] read strings
[ 4.137905] init: Service ‘surfaceflinger’ (pid 202) killed by signal 6
[ 4.137927] init: Service ‘surfaceflinger’ (pid 202) killing any children in process group
[ 4.137951] init: Service ‘zygote’ is being killed…
[ 4.145459] init: Service ‘zygote’ (pid 198) killed by signal 9
[ 4.145480] init: Service ‘zygote’ (pid 198) killing any children in process group
[ 4.145574] init: write_file: Unable to open ‘/sys/android_power/request_state’: No such file or directory
[ 4.145620] init: write_file: Unable to write to ‘/sys/power/state’: Invalid argument
[ 4.145644] init: Service ‘audioserver’ is being killed…
[ 4.145707] init: Service ‘cameraserver’ is being killed…
[ 4.145740] init: Service ‘media’ is being killed…
[ 4.145782] init: Service ‘netd’ is being killed…
[ 4.147056] init: Service ‘netd’ (pid 248) killed by signal 9
[ 4.147075] init: Service ‘netd’ (pid 248) killing any children in process group
[ 4.148481] init: Service ‘audioserver’ (pid 239) killed by signal 9
[ 4.148502] init: Service ‘audioserver’ (pid 239) killing any children in process group
[ 4.148945] init: Service ‘media’ (pid 247) killed by signal 9
[ 4.148957] init: Service ‘media’ (pid 247) killing any children in process group
[ 4.149011] init: Untracked pid 269 killed by signal 9
[ 4.149255] logd.auditd: start
[ 4.149322] logd.klogd: 4026068762
[ 4.150428] init: Service ‘cameraserver’ (pid 240) killed by signal 9
[ 4.150443] init: Service ‘cameraserver’ (pid 240) killing any children in process group
[ 4.392400] healthd: BatteryCurrentNowPath not found
[ 4.392429] healthd: BatteryCycleCountPath not found
[ 4.392994] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 4.393565] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 4.394034] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 4.394492] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 8.154926] init: Starting service ‘zygote’…
[ 8.155579] init: Starting service ‘audioserver’…
[ 8.156172] init: Starting service ‘cameraserver’…
[ 8.156719] init: couldn’t write 282 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 8.156840] init: Starting service ‘media’…
[ 8.157484] init: Starting service ‘netd’…
[ 8.158265] init: Starting service ‘surfaceflinger’…
[ 8.163317] random: nonblocking pool is initialized
[ 8.360138] type=1400 audit(1358499011.003:7): avc: denied { execute } for pid=319 comm=“audioserver” name=“sh” dev=“mmcblk1p10” ino=412 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 8.360612] type=1400 audit(1358499011.003:8): avc: denied { read open } for pid=319 comm=“audioserver” path=“/system/bin/sh” dev=“mmcblk1p10” ino=412 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 8.360700] type=1400 audit(1358499011.003:9): avc: denied { execute_no_trans } for pid=319 comm=“audioserver” path=“/system/bin/sh” dev=“mmcblk1p10” ino=412 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 8.360776] type=1400 audit(1358499011.006:10): avc: denied { getattr } for pid=319 comm=“sh” path=“/system/bin/sh” dev=“mmcblk1p10” ino=412 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 8.378418] type=1400 audit(1358499011.010:11): avc: denied { getattr } for pid=319 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk1p10” ino=445 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 8.378626] type=1400 audit(1358499011.010:12): avc: denied { execute } for pid=319 comm=“sh” name=“toybox” dev=“mmcblk1p10” ino=445 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 8.378709] type=1400 audit(1358499011.010:13): avc: denied { read open } for pid=319 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk1p10” ino=445 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 8.378795] type=1400 audit(1358499011.010:14): avc: denied { execute_no_trans } for pid=319 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk1p10” ino=445 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 8.468434] init: Service ‘surfaceflinger’ (pid 285) killed by signal 6
[ 8.468471] init: Service ‘surfaceflinger’ (pid 285) killing any children in process group
[ 8.468509] init: Service ‘zygote’ is being killed…
[ 8.473399] init: Service ‘zygote’ (pid 280) killed by signal 9
[ 8.473435] init: Service ‘zygote’ (pid 280) killing any children in process group
[ 8.473543] init: write_file: Unable to open ‘/sys/android_power/request_state’: No such file or directory
[ 8.473651] init: write_file: Unable to write to ‘/sys/power/state’: Invalid argument
[ 8.473693] init: Service ‘audioserver’ is being killed…
[ 8.476514] init: Service ‘cameraserver’ is being killed…
[ 8.476639] init: Service ‘media’ is being killed…
[ 8.476681] init: Service ‘netd’ is being killed…
[ 8.477080] init: Service ‘audioserver’ (pid 281) killed by signal 9
[ 8.477108] init: Service ‘audioserver’ (pid 281) killing any children in process group
[ 8.478421] init: Service ‘netd’ (pid 284) killed by signal 9
[ 8.478459] init: Service ‘netd’ (pid 284) killing any children in process group
[ 8.478689] init: Untracked pid 336 exited with status 0
[ 8.479588] init: Service ‘cameraserver’ (pid 282) killed by signal 9
[ 8.479613] init: Service ‘cameraserver’ (pid 282) killing any children in process group
[ 8.480275] init: Service ‘media’ (pid 283) killed by signal 9
[ 8.480297] init: Service ‘media’ (pid 283) killing any children in process group
[ 10.263762] capability: warning: `main’ uses 32-bit capabilities (legacy support in use)
rk3399_box:/ $
rk3399_box:/ $
rk3399_box:/ $ [ 13.486105] init: Starting service ‘zygote’…
[ 13.486952] init: Starting service ‘audioserver’…
[ 13.487665] init: Starting service ‘cameraserver’…
[ 13.488217] init: couldn’t write 340 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 13.488342] init: Starting service ‘media’…
[ 13.489059] init: Starting service ‘netd’…
[ 13.489701] init: Starting service ‘surfaceflinger’…
[ 13.734873] init: Service ‘surfaceflinger’ (pid 343) killed by signal 6
[ 13.734924] init: Service ‘surfaceflinger’ (pid 343) killing any children in process group
[ 13.734962] init: Service ‘zygote’ is being killed…
[ 13.739481] init: Service ‘zygote’ (pid 338) killed by signal 9
[ 13.739520] init: Service ‘zygote’ (pid 338) killing any children in process group
[ 13.739635] init: write_file: Unable to open ‘/sys/android_power/request_state’: No such file or directory
[ 13.739710] init: write_file: Unable to write to ‘/sys/power/state’: Invalid argument
[ 13.739748] init: Service ‘audioserver’ is being killed…
[ 13.742422] init: Service ‘cameraserver’ is being killed…
[ 13.742486] init: Service ‘media’ is being killed…
[ 13.742523] init: Service ‘netd’ is being killed…
[ 13.742947] init: Service ‘audioserver’ (pid 339) killed by signal 9
[ 13.742969] init: Service ‘audioserver’ (pid 339) killing any children in process group
[ 13.744211] init: Service ‘netd’ (pid 342) killed by signal 9
[ 13.744232] init: Service ‘netd’ (pid 342) killing any children in process group
[ 13.744427] init: Untracked pid 396 exited with status 2
[ 13.744901] init: Service ‘cameraserver’ (pid 340) killed by signal 9
[ 13.744919] init: Service ‘cameraserver’ (pid 340) killing any children in process group
[ 13.745277] init: Service ‘media’ (pid 341) killed by signal 9
[ 13.745294] init: Service ‘media’ (pid 341) killing any children in process group
cd s[ 18.751199] init: Starting service ‘zygote’…
[ 18.751884] init: Starting service ‘audioserver’…
[ 18.752417] init: Starting service ‘cameraserver’…
[ 18.752965] init: Starting service ‘media’…
[ 18.753711] init: Starting service ‘netd’…
[ 18.754453] init: Starting service ‘surfaceflinger’…
[ 18.756960] init: couldn’t write 399 tos /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 19.034857] init: Service ‘surfaceflinger’ (pid 402) killed by signal 6
[ 19.034912] init: Service ‘surfaceflinger’ (pid 402) killing any children in process group
[ 19.034950] init: Service ‘zygote’ is being killed…
[ 19.038001] init: Service ‘zygote’ (pid 397) killed by signal 9
[ 19.038036] init: Service ‘zygote’ (pid 397) killing any children in process group
[ 19.038149] init: write_file: Unable to open ‘/sys/android_power/request_state’: No such file or directory
[ 19.038217] init: write_file: Unable to write to ‘/sys/power/state’: Invalid argument
[ 19.038259] init: Service ‘audioserver’ is being killed…
[ 19.040997] init: Service ‘cameraserver’ is being killed…
[ 19.041059] init: Service ‘media’ is being killed…
[ 19.041097] init: Service ‘netd’ is being killed…
[ 19.041533] init: Service ‘audioserver’ (pid 398) killed by signal 9
[ 19.041559] init: Service ‘audioserver’ (pid 398) killing any children in process group
[ 19.042872] init: Service ‘netd’ (pid 401) killed by signal 9
[ 19.042919] init: Service ‘netd’ (pid 401) killing any children in process group
[ 19.043493] init: Service ‘cameraserver’ (pid 399) killed by signal 9
[ 19.043516] init: Service ‘cameraserver’ (pid 399) killing any children in process group
[ 19.043879] init: Service ‘media’ (pid 400) killed by signal 9
[ 19.043896] init: Service ‘media’ (pid 400) killing any children in process group
[ 19.043949] init: Untracked pid 454 killed by signal 9
