请能看懂的麻烦帮忙看一下,一直启动不了,刷机成功后也启动不了,
启动就显示 E:failed to mount /mnt/external_sd (No such device)
用U盘刷也不认U盘,各种方法都试过了,只能上来求救了。
下面这个是SecureCRT 得到的数据,请老师帮忙看看,
[ 2.132731] usbcore: registered new interface driver cdc_acm
[ 2.132777] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.132959] usbcore: registered new interface driver usblp
[ 2.133102] usbcore: registered new interface driver cdc_wdm
[ 2.133341] usbcore: registered new interface driver usb-storage
[ 2.133474] usbcore: registered new interface driver ums-alauda
[ 2.133604] usbcore: registered new interface driver ums-cypress
[ 2.133730] usbcore: registered new interface driver ums-datafab
[ 2.133856] usbcore: registered new interface driver ums_eneub6250
[ 2.133981] usbcore: registered new interface driver ums-freecom
[ 2.134107] usbcore: registered new interface driver ums-isd200
[ 2.134232] usbcore: registered new interface driver ums-jumpshot
[ 2.134355] usbcore: registered new interface driver ums-karma
[ 2.134480] usbcore: registered new interface driver ums-onetouch
[ 2.134622] usbcore: registered new interface driver ums-sddr09
[ 2.134755] usbcore: registered new interface driver ums-sddr55
[ 2.134883] usbcore: registered new interface driver ums-usbat
[ 2.135157] usbcore: registered new interface driver usbserial
[ 2.135291] usbcore: registered new interface driver usbserial_generic
[ 2.135402] usbserial: USB Serial support registered for generic
[ 2.135535] usbcore: registered new interface driver option
[ 2.135651] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.135991] usbcore: registered new interface driver trancevibrator
[ 2.136036] usb20_otg: version 3.10a 21-DEC-2012
[ 2.137027] f1a80040
[ 2.137076] Core Release: 3.10a
[ 2.137116] Setting default values for core params
[ 2.137557] Using Buffer DMA mode
[ 2.137600] Periodic Transfer Interrupt Enhancement - disabled
[ 2.137639] Multiprocessor Interrupt Enhancement - disabled
[ 2.137680] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.137716] ^^^^^^^^^^^^^^^^^Device Mode
[ 2.137762] Dedicated Tx FIFOs mode
[ 2.137818] pcd_init otg_dev = ed96f340
[ 2.138278] usb20_otg ff580000.usb: DWC OTG Controller
[ 2.138371] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 2.138474] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 2.138659] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.138719] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.138771] usb usb2: Product: DWC OTG Controller
[ 2.138818] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 2.138865] usb usb2: SerialNumber: ff580000.usb
[ 2.140160] hub 2-0:1.0: USB hub found
[ 2.140239] hub 2-0:1.0: 1 port detected
[ 2.141143] usb20_host: version 3.10a 21-DEC-2012
[ 2.144621] f1b00040
[ 2.144670] Core Release: 3.10a
[ 2.144723] Setting default values for core params
[ 2.145115] Using Buffer DMA mode
[ 2.145156] Periodic Transfer Interrupt Enhancement - disabled
[ 2.145195] Multiprocessor Interrupt Enhancement - disabled
[ 2.145236] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.145271] ^^^^^^^^^^^^^^^^^^Host Mode
[ 2.145355] usb20_host ff540000.usb: DWC OTG Controller
[ 2.145445] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 2.145548] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 2.145714] Init: Power Port (0)
[ 2.145904] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.145964] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.146016] usb usb3: Product: DWC OTG Controller
[ 2.146062] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 2.146108] usb usb3: SerialNumber: ff540000.usb
[ 2.147479] hub 3-0:1.0: USB hub found
[ 2.147558] hub 3-0:1.0: 1 port detected
[ 2.148742] rk_pwm_init
[ 2.149166] .. rk pwm remotectl v1.0 init
[ 2.149403] remotectl probe j=0x0
[ 2.149447] remotectl probe j=0x1
[ 2.149483] remotectl probe j=0x2
[ 2.149531] remotectl probe j=0x3
[ 2.149563] remotectl probe j=0x4
[ 2.150132] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 2.150739] pwm enable val=0x646205
[ 2.151602] usbcore: registered new interface driver xpad
[ 2.151776] usbcore: registered new interface driver usb_acecad
[ 2.152025] usbcore: registered new interface driver aiptek
[ 2.152195] usbcore: registered new interface driver gtco
[ 2.152356] usbcore: registered new interface driver hanwang
[ 2.152510] usbcore: registered new interface driver kbtab
[ 2.152683] usbcore: registered new interface driver wacom
[ 2.153755] sensor_register_slave:mma8452,id=17
[ 2.153807] sensor_register_slave:cm3217,id=44
[ 2.153847] sensor_register_slave:cm3218,id=45
[ 2.190105] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 2.190273] i2c /dev entries driver
[ 2.192542] IR NEC protocol handler initialized
[ 2.192591] IR RC5(x) protocol handler initialized
[ 2.192629] IR RC6 protocol handler initialized
[ 2.192664] IR JVC protocol handler initialized
[ 2.192699] IR Sony protocol handler initialized
[ 2.192735] IR RC5 (streamzap) protocol handler initialized
[ 2.192772] IR SANYO protocol handler initialized
[ 2.192808] IR MCE Keyboard/mouse protocol handler initialized
[ 2.193073] usbcore: registered new interface driver uvcvideo
[ 2.193115] USB Video Class driver (1.1.1)
[ 2.195678] device-mapper: uevent: version 1.0.3
[ 2.196402] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 2.197317] Bluetooth: HCI UART driver ver 2.2
[ 2.197371] Bluetooth: HCI H4 protocol initialized
[ 2.197412] Bluetooth: HCILL protocol initialized
[ 2.205400] cpufreq version 1.0, suspend freq 1200 MHz
[ 2.205960] cpuidle: using governor ladder
[ 2.205969] cpuidle: using governor menu
[ 2.205995] Synopsys Designware Multimedia Card Interface Driver
[ 2.206173] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 2.206377] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 2.206493] 3291..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 2.206503] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 2.206589] 1381..dw_mci_set_ios: no card. [mmc0]
[ 2.220806] 1381..dw_mci_set_ios: no card. [mmc0]
[ 2.240501] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 2.240525] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 2.240538] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 2.240784] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 2.241604] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 2.241703] 3291..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc1]
[ 2.241713] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 2.241787] 1381..dw_mci_set_ios: no card. [mmc1]
[ 2.260158] 1381..dw_mci_set_ios: no card. [mmc1]
[ 2.280035] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 2.280048] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 2.280238] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.281490] usbcore: registered new interface driver usbhid
[ 2.281500] usbhid: USB HID core driver
[ 2.281749] ashmem: initialized
[ 2.281855] logger: created 256K log ‘log_main’
[ 2.281947] logger: created 256K log ‘log_events’
[ 2.282035] logger: created 256K log ‘log_radio’
[ 2.282123] logger: created 256K log ‘log_system’
[ 2.282345] enter at24c16_probe
[ 2.289096] eeprom is already initialized
[ 2.292469] exit at24c16_probe!
[ 2.292507] model init
[ 2.292527] prodate init
[ 2.292537] versionhw init
[ 2.302302] mmc0: BKOPS_EN bit is not set
[ 2.304210] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 2.304234] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 2.304286] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0]
[ 2.304585] mmc0: new high speed DDR MMC card at address 0001
[ 2.304837] mmcblk0: mmc0:0001 SEM32G 29.0 GiB
[ 2.305127] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 2.305139] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 2.305148] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 2.305157] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 2.305166] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 2.305175] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 2.305184] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 2.305192] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 2.305201] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 2.305209] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 2.305218] system: 0x012400000 – 0x042400000 (768 MB)
[ 2.305226] metadata: 0x042400000 – 0x042800000 (4 MB)
[ 2.305235] userdata: 0x042800000 – 0x142800000 (4096 MB)
[ 2.305244] radical_update: 0x142800000 – 0x146800000 (64 MB)
[ 2.305252] user: 0x146800000 – 0x743800000 (24528 MB)
[ 2.305276] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p151381..dw_mci_set_ios: no card. [mmc1]
[ 2.319500] sn init
[ 2.346440] devkey init
[ 2.346451] activate init
[ 2.373390] reset_rom
[ 2.373400] gdsn init
[ 2.373408] ethmac init
[ 2.373459] usid init
[ 3.407939] u32 classifier
[ 3.407947] Actions configured
[ 3.407959] Netfilter messages via NETLINK v0.30.
[ 3.408011] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.408313] ctnetlink v0.93: registering with nfnetlink.
[ 3.408373] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 3.408382] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 3.408651] xt_time: kernel timezone is -0000
[ 3.408849] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.408970] arp_tables: (C) 2002 David S. Miller
[ 3.409010] TCP: cubic registered
[ 3.409018] Initializing XFRM netlink socket
[ 3.409237] NET: Registered protocol family 10
[ 3.409743] mip6: Mobile IPv6
[ 3.409769] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.409885] sit: IPv6 over IPv4 tunneling driver
[ 3.410190] NET: Registered protocol family 17
[ 3.410216] NET: Registered protocol family 15
[ 3.410262] Bridge firewalling registered
[ 3.410273] Ebtables v2.0 registered
[ 3.410422] Bluetooth: RFCOMM TTY layer initialized
[ 3.410448] Bluetooth: RFCOMM socket layer initialized
[ 3.410456] Bluetooth: RFCOMM ver 1.11
[ 3.410464] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.410471] Bluetooth: BNEP filters: protocol multicast
[ 3.410483] Bluetooth: BNEP socket layer initialized
[ 3.410492] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.410503] Bluetooth: HIDP socket layer initialized
[ 3.410529] l2tp_core: L2TP core driver, V2.0
[ 3.410544] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 3.410552] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 3.410691] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 3.410702] wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 3.410711] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 3.410720] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 3.410730] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 3.410751] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 3.410773] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 3.410783] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 3.410805] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 3.410845] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 3.410883] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.410995] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 3.411013] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 3.411030] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 3.411045] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 3.411060] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 3.411104] [BT_RFKILL]: Request irq for bt wakeup host
[ 3.411191] [BT_RFKILL]: ** disable irq
[ 3.411275] [BT_RFKILL]: ap6335 device registered.
[ 4.041218] ******** Show Sink Info ********
[ 4.041232] Max tmds clk is 0
[ 4.041239] Support video mode:
[ 4.041245] 1920x1080p@60Hz
[ 4.041251] 1920x1080p@50Hz
[ 4.041257] 1280x720p@60Hz
[ 4.041262] 1280x720p@50Hz
[ 4.041268] 720x576p@50Hz
[ 4.041274] 720x480p@60Hz
[ 4.041279] Support video color mode:
[ 4.041285] RGB
[ 4.041290] YCbCr422
[ 4.041295] YCbCr444
[ 4.041300] Support video color depth:
[ 4.041306] 24bit
[ 4.041312] Support audio type:
[ 4.041317] LPCM
[ 4.041323] Support max audio channel is 2
[ 4.041329] Support audio sample rate:
[ 4.041335] 32000
[ 4.041340] 44100
[ 4.041344] 48000
[ 4.041350] Support audio word lenght:
[ 4.041356] 16bit
[ 4.041360] 20bit
[ 4.041365] 24bit
[ 4.041370]
[ 4.041375] ******** Show Sink Info ********
[ 4.041393]
[ 4.041393] rk_fb_switch_screen lcdc_id 0 type 6 enable 1
[ 4.041407] fb0 win id 1 state 1
[ 4.041427] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 4.041448] fb1 win id 0 state 0
[ 4.041455] fb2 win id 2 state 0
[ 4.041462] fb3 win id 3 state 0
[ 4.041469] fb4 win id 4 state 0
[ 4.041476]
[ 4.041476] rk_fb_switch_screen lcdc_id 0 type 6 enable 1 done
[ 4.041476]
[ 4.044881] pixel clk is 148500000 tmds clk is 148500000
[ 4.044917] rk3288-hdmi ff980000.hdmi: [hdmi_dev_config_video] sucess output HDMI.
[ 4.054195] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
[ 4.055853] wm8805_codec 1-003a: revision E
[ 4.058106] wm8741 is not present
[ 4.058114] assume we are using wm8740
[ 4.058122] wm8741 i2c np=c1bd7c8c
[ 5.753360] iep dpi mode inactivity
[ 6.156801] enter wm8740_reset **************************************
[ 6.156814] nothing to do for mini
[ 6.175896] rk1000_codec 4-0060: i2c_transfer() returned -11
[ 6.177798] rk1000_codec 4-0060: i2c_transfer() returned -11
[ 6.180324] rk1000_codec 4-0060: ASoC: no sink widget found for Mic Bias1
[ 6.180336] rk1000_codec 4-0060: ASoC: Failed to add route Mic Jack → direct → Mic Bias1
[ 6.180348] rk1000_codec 4-0060: ASoC: no source widget found for Mic Bias1
[ 6.180358] rk1000_codec 4-0060: ASoC: Failed to add route Mic Bias1 → direct → MIC1
[ 6.180369] rk1000_codec 4-0060: ASoC: no source widget found for HPOL
[ 6.180379] rk1000_codec 4-0060: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 6.180389] rk1000_codec 4-0060: ASoC: no source widget found for HPOR
[ 6.180398] rk1000_codec 4-0060: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 6.180408] rk1000_codec 4-0060: ASoC: no source widget found for SPOL
[ 6.180418] rk1000_codec 4-0060: ASoC: Failed to add route SPOL → direct → Ext Spk
[ 6.180427] rk1000_codec 4-0060: ASoC: no source widget found for SPOR
[ 6.180437] rk1000_codec 4-0060: ASoC: Failed to add route SPOR → direct → Ext Spk
[ 6.180568] dgl rk1000 standby
[ 6.183950] df-codec df-codec.28: wm8805-spdif ↔ rockchip-i2s.0 mapping ok
[ 6.185555] df-codec df-codec.28: wm8741_dac ↔ rockchip-i2s.0 mapping ok
[ 6.187352] df-codec df-codec.28: rk1000_codec ↔ rockchip-i2s.0 mapping ok
[ 6.188274] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 6.188295] rk3288_init_suspend
[ 6.188303] rk3288_suspend_init enter
[ 6.188441] rk3288_suspend_init: pm_ctrbits =40017
[ 6.188482] gpio_get_dts_info suspend:8
[ 6.188490] gpio_get_dts_info resume:8
[ 6.188497] rockchip,pmic-suspend_gpios:1007c30 1007c40 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 6.188530] rockchip,pmic-resume_gpios:2007c32 2007c42 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 6.188678] clks_gating_suspend_init:clkgt info ok
[ 6.188771] Registering SWP/SWPB emulation handler
[ 6.189119] ddrfreq: verion 1.2 20140526
[ 6.189132] ddrfreq: normal 528MHz video_1080p 0MHz video_4k 0MHz dualview 0MHz idle 0MHz suspend 0MHz reboot 528MHz
[ 6.189141] ddrfreq: auto-freq=0
[ 6.189148] ddrfreq: auto-freq-table[0] 240MHz
[ 6.189155] ddrfreq: auto-freq-table[1] 324MHz
[ 6.189162] ddrfreq: auto-freq-table[2] 456MHz
[ 6.189169] ddrfreq: auto-freq-table[3] 528MHz
[ 6.190845] video src is lcdc0, prop is 0
[ 6.190854]
[ 6.190854] rk_fb_switch_screen lcdc_id 0 type 1 enable 2
[ 6.191794] rk1000 control i2c write err,ret =-11
[ 6.191808] rk1000_tve 4-0042: rk1000 tvencoder probe error -1
[ 6.191822] rk1000_tve: probe of 4-0042 failed with error -22
[ 6.191853] regulator-dummy: disabling
[ 6.192103] pcd_pullup, is_on 0
[ 6.192152] file system registered
[ 6.192789] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 6.192801] android_usb gadget: Number of LUNs=2
[ 6.192811] lun0: LUN: removable file: (no medium)
[ 6.192819] lun1: LUN: removable file: (no medium)
[ 6.192966] android_usb gadget: android_usb ready
[ 6.193063] sensor_init: Probe name sensors
[ 6.193081] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 6.195582] rtc_hym8563 0-0051: setting system clock to 2011-01-01 10:00:00 UTC (1293876000)
[ 6.201755] usbcore: registered new interface driver snd-usb-audio
[ 6.201767] ALSA device list:
[ 6.201775] #0: DF-CODEC
[ 6.202059] Freeing unused kernel memory: 340K (c09be000 - c0a13000)
[ 6.207680] SELinux: Permission attach_queue in class tun_socket not defined in policy.
[ 6.207696] SELinux: the above unknown classes and permissions will be denied
[ 6.426119] type=1403 audit(1293876000.730:2): policy loaded auid=4294967295 ses=4294967295
[ 6.426223] SELinux: Loaded policy from /sepolicy
[ 6.428031] type=1404 audit(1293876000.730:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 7.576405] init: /dev/hw_random not found
[ 7.577238] android_usb: already disabled
[ 7.577334] android_usb: Cannot enable ‘adb’ (-22)init: prope__bionic_openlnodataesnoulexit fwnd e e tzndia w’${ro.okiialfno As
a/Sh 7.hai421sh: it:ionnnoopexpazd ta:ro.uldial find hil tzrita w to '/oki/clfor/anTr
c_ust andrss 0/iSerib ’
tro 12urned73]finiion/sbopee2fzdkta:rmiulded find a(8)tzd wh33 099kinnitor peratrulal
mmc/bytmome/= ehe’ n Se ‘Janv/b 10k/p:06for11
12ove718filinisteFaiabl to ===nt ===v/b======lat===m/emm /my-nint/caal_, fvfaat devto ext4plaw
rm/ 12f3380.r] immc: /-namew_rer om 1 font/
[ern12.33 vf0] /det: lnab/mmto k1pn pers 2 entsteopext4 /ire/blry /plta/pro/ffty 000no:sdm
a b’ /me2)patapullup,dev_onock c/b 12ame046stem 0roid_ /c: ae eady /deableock[ atf.rm0570f00ndrrks_usb:by-nnoe/cnabe 0
[ a 1orm4060f0 in.rksdmingby-prec/med syta x for5 /ecia ext propv/by 'k/pproform/fanu000turksd, u/e $namme}serstea 0
        12cus069xt4initv/bsink/peprform/f sy000x fksdspecif-nag pcusert
'ro /coduom mod4 /deuselocnamlatinrteaf0f[ 0.r.34074/byinime/usitom 0
ateradyntl_ufoatspext4yinev/bropk/py ‘forserf0fn000 ussdm{naby- ineteadic[ upd.340059 9nitaseropamey ero. /dialblo doesntfoexiff0whi00.rksandc/b ‘$amesbriapar’
r 0 12.10 773sc nit: /denotlocpanlat$romser0f0no’.rkile wriy-ng t/mi/sy0
ss//ubroi emsb /ddv/id0ck/eritform/ff0f0000.rksdmmc/by-name/uboot 0
12 /charge emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/charge 0
13 /resource emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/resource 0
14 /parameter emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/parameter 0
15 /boot emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/boot 0
16 /recovery emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/recovery 0
17 /backup emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/backup 0
18 /tmp ramdisk ramdisk 0
I:InternalSD_ROOT: /mnt/internal_sd
I:ExternalSD_ROOT: /mnt/external_sd
[ 12.514636] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts:
locale is [(null)]
stage is
failed to read font: res=-1
can’t open /dev/tty0: No such file or directory
framebuffer: fd 3 (1920 x 1080)
installing_text: (1 x 1 @ 1896)
erasing_text: (1 x 1 @ 1599)
no_command_text: (1 x 1 @ 1599)
error_text: (1 x 1 @ 1599)
Recovery system v4.4.0
[ 12.644777] EXT4-fs (mmcblk0p12): warning: mounting unchecked fs, running e2fsyinis ounommdev/d
ck/ 12blk5p18] nt4-f
(mmcbryip12)ounounted bloesymmcb w1tho n jo
delay 2sec
W:trying mount /dev/block/mmcblk1p1 to ntfs
W:trying mount /dev/block/mmcblk1 to ntfs
delay 2sec
read cmdline
Not enter sdboot!
bootmode = emmc
Command: “/sbin/recovery”
ro.rk.cpu=rk3288
ro.rk.soc=rk3288
ro.rk.bt_enable=true
ro.rk.systembar.tabletUI=false
ro.rk.systembar.voiceicon=true
ro.rk.MassStorage=false
ro.rk.cpu_min_freq=1200000
ro.rk.homepage_base=http://www.google.com/webhp?client={CID}&source=android-home
ro.rk.def_brightness=200
ro.rk.screenoff_time=-1
ro.rk.screenshot_enable=true
ro.rk.LowBatteryBrightness=true
ro.rk.install_non_market_apps=true
ro.sf.hwrotation=0
ro.sf.lcd_density=160
ro.sf.fakerotation=false
ro.adb.secure=0
ro.com.android.dateformat=MM-dd-yyyy
ro.com.android.dataroaming=true
ro.ril.ecclist=112,911
ro.sms.capable=false
ro.boot.mode=emmc
ro.boot.console=ttyFIQ0
ro.boot.hardware=rk30board
ro.hwui.path_cache_size=16
ro.hwui.layer_cache_size=48
ro.hwui.shape_cache_size=4
ro.hwui.texture_cache_size=72
ro.hwui.disable_scissor_opt=true
ro.hwui.gradient_cache_size=1
ro.hwui.drop_shadow_cache_size=6
ro.hwui.text_large_cache_width=2048
ro.hwui.text_small_cache_width=1024
ro.hwui.text_large_cache_height=1024
ro.hwui.text_small_cache_height=1024
ro.wifi.channels=
ro.allow.mock.location=1
ro.audio.monitorOrientation=true
ro.board.platform=rk3288
ro.build.id=KOT49H
ro.build.date=Tue Jun 30 09:48:53 CST 2015
ro.build.date.utc=1435628933
ro.build.host=laixiaolong-dFim
ro.build.tags=test-keys
ro.build.type=eng
ro.build.user=long
ro.build.display.id=rk3288-eng v4.4.2_150630_1_02 KOT49H eng.long.20150630.094144 test-keys
ro.build.product=rk3288
ro.build.version.sdk=19
ro.build.version.release=v4.4.2_150630_1_02
ro.build.version.codename=REL
ro.build.version.incremental=eng.long.20150630.094144
ro.build.description=rk3288-eng v4.4.2_150630_1_02 KOT49H eng.long.20150630.094144 test-keys
ro.build.fingerprint=rockchip/rk3288/rk3288:v4.4.2_150630_1_02/KOT49H/eng.long.20150630.094144:eng/test-keys
ro.build.characteristics=tablet
ro.rksdk.version=RK30_ANDROID$(PLATFORM_VERSION)-SDK-v1.00.00
ro.voice.capable=false
ro.ap_mdm=-1
ro.config.ringtone=Ring_Synth_04.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
ro.config.notification_sound=pixiedust.ogg
ro.kernel.android.checkjni=0
ro.secure=0
ro.secure.hdcp2xkey.inside=false
ro.tether.denied=false
ro.vendor.sw.version=RK3288_R-BOX_ANDROID4.4.2-SDK_V1.0.0_140613
ro.carrier=unknown
ro.default.size=100
ro.factory.tool=0
ro.factory.hasGPS=false
ro.factory.hasUMS=true
ro.factory.without_battery=false
ro.factory.storage_suppntfs=true
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.ota.host:2300=www.rockchip.com
ro.product.name=rk3288
ro.product.board=rk30sdk
ro.product.brand=rockchip
ro.product.model=rk3288
ro.product.device=rk3288
ro.product.locale.region=CN
ro.product.locale.language=zh
ro.product.version=1.0.0
ro.product.usbfactory=rockchip_usb
ro.product.manufacturer=rockchip
ro.baseband=unknown
ro.bootmode=emmc
ro.hardware=rk30board
ro.opengles.version=131072
ro.revision=0
ro.bootloader=unknown
ro.debuggable=1
ro.ap_has_alsa=-1
ro.factorytest=0
ro.ap_data_only=-1
ro.ap_has_earphone=-1
sf.power.control=2073600
net.bt.name=Android
net.change=net.bt.name
ril.function.dataonly=1
sys.hwc.compose_policy=6
sys.rkadb.root=0
sys.wallpaper.rgb565=0
sys.resolution.changed=false
init.svc.adbd=running
init.svc.console=running
init.svc.ueventd=running
init.svc.recovery=running
rild.libargs=-d /dev/ttyACM0
rild.libpath=/system/lib/libril-rk29-dataonly.so
rild.libpath1=/system/lib/libreference-ril-mt6229.so
rild.libpath2=/system/lib/libreference-ril-mu509.so
rild.libpath4=/system/lib/libreference-ril-mw100.so
rild.libpath6=/system/lib/libreference-ril-sc6610.so
rild.libpath7=/system/lib/libreference-ril-m51.so
rild.libpath8=/system/lib/libreference-ril-mt6250.so
rild.libpath9=/system/lib/libreference-ril-c66a.so
rild.libpath10=/system/lib/libreference-ril-sew290.so
rild.libpath11=/system/lib/libreference-ril-u5501.so
rild.libpath12=/system/lib/libreference-ril-u7501.so
rild.libpath13=/system/lib/libreference-ril-aw706.so
rild.libpath14=/system/lib/libreference-ril-a85xx.so
rild.libpath15=/system/lib/libreference-ril-e1230s.so
wifi.interface=wlan0
wifi.supplicant_scan_interval=15
debug.nfc.se=false
debug.nfc.fw_download=false
media.rmvb.support=1
rild1.libpath=/system/lib/libreference-ril-sc6610-1.so
rild3.libpath=/system/lib/libril-rk29-dataonly.so
video.use.overlay=2
video.bluray.render=gpu
video.bluray.navigationMenu=hide
video.support.bluray=yes
dalvik.vm.jniopts=warnonly
dalvik.vm.heapsize=512m
dalvik.vm.lockprof.threshold=500
dalvik.vm.heapmaxfree=8m
dalvik.vm.heapminfree=512k
dalvik.vm.dexopt-flags=m=y
dalvik.vm.heapstartsize=16m
dalvik.vm.heapgrowthlimit=192m
dalvik.vm.stack-trace-file=/data/anr/traces.txt
dalvik.vm.heaptargetutilization=0.75
persist.sys.ui.hw=true
persist.sys.usb.config=mass_storage,adb
persist.sys.dalvik.vm.lib=libdvm.so
persist.sys.country=CN
persist.sys.display.policy=auto
persist.sys.language=zh
persist.sys.timezone=Asia/Shanghai
persist.sys.strictmode.visual=false
persist.tegra.nvmmlite=1
testing.mediascanner.skiplist=/mnt/internal_sd/Android/
keyguard.no_require_sim=true
ExternalSD_ROOT=/mnt/external_sd
InternalSD_ROOT=/mnt/internal_sd
UserVolumeLabel=RockChips
[ 17.915609] vbus detect**
[ 18.094845] Using Buffer DMA mode
[ 18.094862] Periodic Transfer Interrupt Enhancement - disabled
[ 18.094871] Multiprocessor Interrupt Enhancement - disabled
[ 18.094880] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 18.094887] ^^^^^^^^^^^^^^^^^Device Mode
[ 18.094929] soft connect!!!
[ 21.861442] soft reconnect**
[ 22.040642] Using Buffer DMA mode
[ 22.040658] Periodic Transfer Interrupt Enhancement - disabled
[ 22.040666] Multiprocessor Interrupt Enhancement - disabled
[ 22.040674] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 22.040681] ^^^^^^^^^^^^^^^^^Device Mode
[ 22.040720] ******soft connect!!!
[ 2.319500] sn init
[ 4.041285] RGB
[ 4.041306] 24bit
[ 4.041317] LPCM
[ 4.041335] 32000
[ 4.041340] 44100
[ 4.041344] 48000
[ 4.041356] 16bit
[ 4.041360] 20bit
[ 4.041365] 24bit
[ 4.041370]
[ 4.041393]
[ 4.041476]
[ 4.041476]
[ 6.190854]
locale is [(null)]
stage is
delay 2sec
delay 2sec
read cmdline
Not enter sdboot!
bootmode = emmc
ro.rk.cpu=rk3288
ro.rk.soc=rk3288
ro.sf.hwrotation=0
ro.adb.secure=0
ro.boot.mode=emmc
ro.wifi.channels=
ro.build.id=KOT49H
ro.build.type=eng
ro.build.user=long
ro.ap_mdm=-1
ro.secure=0
ro.carrier=unknown
ro.default.size=100
ro.factory.tool=0
ro.baseband=unknown
ro.bootmode=emmc
ro.revision=0
ro.debuggable=1
ro.ap_has_alsa=-1
ro.factorytest=0
ro.ap_data_only=-1
net.bt.name=Android
sys.rkadb.root=0
debug.nfc.se=false
video.use.overlay=2
[ 22.040720] soft connect!!!
[ 49.492171] Can’t find bootanimation or timeout…
自己顶一贴,还是启动不了,换了固件也不行
请烧录官方公版固件试试
jpchen 发表于 2019-3-4 17:44
请烧录官方公版固件试试
朋友你好,很高兴你能回复,现在我也找不到官方固件了,因为错误刷了别的盒子的固件,现在我手里只有网友修改版本的,但是这个版本也不行,解压固件好几个官方固件文件都没有,比如uboot和其他几个文件。如果朋友你手头有这个官方固件,非常感谢你能给我一份!!我将不胜感激!!!!
qzbing 发表于 2019-3-5 00:54
朋友你好,很高兴你能回复,现在我也找不到官方固件了,因为错误刷了别的盒子的固件,现在我手里只有网友 …
官网固件统一下载的路径如下
http://www.t-firefly.com/doc/download/page/id/31.html
firefly-rk3288的固件下载路径如下
https://pan.baidu.com/s/1l5Zx6wZhFyBK2sMYqQ1Knw#list/path=%2F
我的3288现象跟楼主一样,刷官方固件也不行,升级完成后一直处在loader模式,机子起来就是E:failed to mount /mnt/external_sd (No such device)。楼主有没有解决啊
zhyh1436 发表于 2019-11-18 13:27
我的3288现象跟楼主一样,刷官方固件也不行,升级完成后一直处在loader模式,机子起来就是E:failed to moun …
是烧录ubuntu的固件,还是Android固件,烧入前请先擦除flash,再进行升级
都试过擦除flash后再烧,正常烧写,但是启动马上直接就进loader模式。应该是硬件“recovery“按键有问题。
