aio-3399j开发板下载官方固件,启动失败。
aio_3399j下载官方固件,(rkdevtool v2.54),固件名:AIO-3399J-UBUNTU16.04-LVDS-GPT-20181204-0952.img,启动日志为:DDR Version 1.14 20180803
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
pmugrf_os_reg[2] = 0x3AA17AA1, stride = 0xD
CPUId = 0x0
ChipType = 0x10, 214
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67792
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
GPT part: 2, name: boot, start:0xa000, size:0x10000
GPT part: 3, name: backup, start:0x2a000, size:0x10000
GPT part: 4, name: rootfs, start:0x5a000, size:0x1cc4fdf
find partition:uboot OK. first_lba:0x4000.
find partition:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xad058
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):56eea3d
NOTICE: BL31: Built : 15:27:37, Aug 8 2018
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1151): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-170-gc4654a6 #16 Wed May 30 08:54:30 UTC 2018 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09-gd80ac02 (Nov 28 2018 - 10:57:02 +0800)
Model: Firefly-RK3399 Board
DRAM: 3.8 GiB
Relocation Offset is: f7d12000
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 1075000 uV
pwm-regulator(vdd-log): init 950000 uV
vdd_log 950000 uV
regulator(vdd-log) init 950000 uV
MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
In: serial@ff1a0000
Out: serial@ff1a0000
Err: serial@ff1a0000
mmc_init: -95, time 10
switch to partitions #0, OK
get part misc fail -1
Net: eth0: ethernet@fe300000
android_bootloader_boot_flow Could not find misc partition
** Invalid Android Image header **
android_bootloader_boot_flow boot part load fail
=Booting Rockchip format image=
boot_rockchip_image kernel or boot part info error
Failed to mount ext2 filesystem…
** Unrecognized filesystem type **
starting USB…
USB0: USB EHCI 1.00
USB1: USB OHCI 1.0
USB2: USB EHCI 1.00
USB3: USB OHCI 1.0
scanning bus 0 for devices… 1 USB Device(s) found
scanning bus 1 for devices… 1 USB Device(s) found
scanning bus 2 for devices… 4 USB Device(s) found
scanning bus 3 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
Device 0: unknown device
DMA reset timeout
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-aa-38-12-22-38-cc
DMA reset timeout
Retrieving file: pxelinux.cfg/00000000
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
Retrieving file: pxelinux.cfg/default-arm-rockchip
DMA reset timeout
DMA reset timeout
请参照烧写文档
http://wiki.t-firefly.com/zh_CN/AIO-3399J/upgrade_table.html
另外,建议使用最新的固件。
已经有20190304发布的固件了
