有知道的大拿,指点一下方向,问题出在何处?????不胜感激!!!!!!!!!!
从官网下载的Firefly-RK3399_Android7.1.2_MP_180126 镜像文件包
从官网下载Firefly-RK3399_Android7.1.2_git_20180126.7z 源码包
按照文档说明,将 u-boot/include/configs/rk33plat.h 中的 delay时间从’0’ 修改为 ‘20’
/* mod it to enable console commands. */
#define CONFIG_BOOTDELAY 20
然后将单独编译的uboot的三个文件替换镜像文件包中的同名文件,
uboot.img
trust.img
rk3399_loader_v1.08.109.bin → 重命名为 MiniLoaderAll.bin
用 mkupdate.bat 脚本再windows下将镜像文件打包成 update.img
最后通过 SD_Firmware_Tool._v1.46 烧录到SD 卡中。
结果还是不如预期,uboot 没有出现等待键盘输入的意思,直接引导kernel 起来,log如下,
DDR Version 1.08 20170320
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1: 2017-06-09, version: 1.09
CPUId = 0x0
ChipType = 0x10, 1834
mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
mmc: ERROR: Card did not respond to voltage select!
emmc reinit
emmc reinit
SdmmcInit=2 1
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30528MB
FwPartOffset=2000 , 0
run on sd0
StorageInit ok = 56589
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x77d6c
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):9f93abc
NOTICE: BL31: Built : 10:18:20, Jul 27 2017
INFO: plat_rockchip_pmu_init(1089): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-96-g3fbe315-dev #4 Fri Jun 30 00:35:17 UTC 2017 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.1
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Mar 14 2019 - 17:38:23)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01000000
128 MiB
SdmmcInit = 0 0
SDCard Boot.
storage init OK!
Writing env to storage…
done
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 0000-00-00#0.00
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
failed to find phy node
failed to find panel driver
no fuel gauge found
can’t find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer -69194865x169464486@-1804401840–1009472337
rockchip_panel_deinit: failed to find panel deinit funcs
failed to display kernel logo
checkKey
vbus = 0
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x01325008)
ramdisk @ 0x05bf0000 (0x007b1abc)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 0000000005615f13 … OK
Add bank:0000000009400000, 0000000076c00000
