rk3399 长时间无法启动
启动log如下所示:
#Boot ver: 2019-02-17#1.09
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
failed to find phy node
failed to find panel driver
no fuel gauge found
can't find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
[EDID-EXTEND] It is a  CEA 861 Series Extension.
no baseparametr,find best edid mode,vic=16
hdmi_dev->video.vic is 4
rk lcdc - 0 dclk set: dclk = 74250000HZ, pll select = 0, div = 1
rockchip_panel_prepare: failed to find panel prepare funcs
hdmi_dev_config_video vic 4 color_output 3 color_output_depth 8
pixel clk is 74250000 tmds clk is 74250000
hsync_pol 1 vsync_pol 1
[HDMI] sucess output HDMI.
PHY PLL not locked: PCLK_ON=1,TMDSCLK_ON=0
rockchip_panel_enable: failed to find panel prepare funcs
failed to display kernel logo
checkKey
vbus = 0
Hit any key to stop autoboot:  0
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel   @ 0x00280000 (0x01248008)
ramdisk  @ 0x04bf0000 (0x001ad5d8)
bootrk: do_bootm_linux...
   Loading Device Tree to 0000000004600000, end 00000000046164f0 ... OK
Add bank:000000000a200000, 00000000ede00000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Initializing cgroup subsys schedtune
[    0.000000] Linux version 4.4.103 (zhang@zhang-Inspiron-5577) (gcc version 4.9 20150123 (prerelease) (GCC) ) #10 SMP PREEMPT Wed Mar 6 15:07:30 CST 2019
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] hdmi init vic is -1
[    0.000000] Reserved memory: failed to reserve memory for node 'stb-devinfo@00000000': base 0x0000000000000000, size 0 MiB
[    0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6eed000 s45504 r8192 d32320 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 991752
[    0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30boar0
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0xf6ea4000-0xf6ee4000] (0MB) mapped at [ffffffc0f6ea4000-ffffffc0f6ee3fff]
[    0.000000] Memory: 3918852K/4030464K available (10942K kernel code, 1632K rwdata, 5264K rodata, 832K init, 1073K bss, 95228K reserved, 16384K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000]       .init : 0xffffff8009060000 - 0xffffff8009130000   (   832 KB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008b30000   ( 10944 KB)
[    0.000000]     .rodata : 0xffffff8008b30000 - 0xffffff8009060000   (  5312 KB)
[    0.000000]       .data : 0xffffff8009130000 - 0xffffff80092c8008   (  1633 KB)
[    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
[    0.000000]               0xffffffbdc0008000 - 0xffffffbdc3e00000   (    61 MB actual)
[    0.000000]     fixed   : 0xffffffbffe7fd000 - 0xffffffbffec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc0f8000000   (  3966 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[    0.000000] ITS: allocated 65536 Devices @a200000 (psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x000000000a280000
[    0.000000] ITS: Allocated 1792 chunks for LPIs
[    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] CPU0: using LPI pending table @0x000000000a290000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[    0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001930] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.002894] pid_max: default: 32768 minimum: 301
[    0.003410] Security Framework initialized
[    0.003800] SELinux:  Initializing.
[    0.004213] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.004843] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.006339] Initializing cgroup subsys freezer
[    0.006768] Initializing cgroup subsys debug
[    0.008060] sched-energy: Sched-energy-costs installed from DT
[    0.008610] CPU0: update cpu_capacity 401
[    0.009064] ASID allocator initialised with 65536 entries
[    0.025884] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.027138] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.039285] Detected VIPT I-cache on CPU1
[    0.039317] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.039357] CPU1: using LPI pending table @0x00000000f1c00000
[    0.039399] CPU1: update cpu_capacity 401
[    0.039402] CPU1: Booted secondary processor [410fd034]
[    0.049280] Detected VIPT I-cache on CPU2
[    0.049299] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.049331] CPU2: using LPI pending table @0x00000000f1c30000
[    0.049359] CPU2: update cpu_capacity 401
[    0.049362] CPU2: Booted secondary processor [410fd034]
[    0.059318] Detected VIPT I-cache on CPU3
[    0.059336] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.059368] CPU3: using LPI pending table @0x00000000f1c70000
[    0.059395] CPU3: update cpu_capacity 401
[    0.059398] CPU3: Booted secondary processor [410fd034]
[    0.069366] Detected PIPT I-cache on CPU4
[    0.069395] CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.069435] CPU4: using LPI pending table @0x00000000f1cb0000
[    0.069475] CPU4: update cpu_capacity 1024
[    0.069479] CPU4: Booted secondary processor [410fd082]
[    0.079386] Detected PIPT I-cache on CPU5
[    0.079404] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.079440] CPU5: using LPI pending table @0x00000000f1cf0000
[    0.079468] CPU5: update cpu_capacity 1024
[    0.079471] CPU5: Booted secondary processor [410fd082]
[    0.079555] Brought up 6 CPUs
[    0.091660] SMP: Total of 6 processors activated.
[    0.092104] CPU features: detected feature: GIC system register CPU interface
[    0.092775] CPU: All CPU(s) started at EL2
[    0.093195] alternatives: patching kernel code
[    0.095279] devtmpfs: initialized
[    0.115593] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.116568] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.117893] pinctrl core: initialized pinctrl subsystem
[    0.119960] Failed to find legacy iommu devices
[    0.120774] NET: Registered protocol family 16
[    0.121551] schedtune: init normalization constants...
[    0.122055] schedtune: CLUSTER[0-3]      min_pwr:    56 max_pwr:   222
[    0.122689] schedtune: CPU[0]            min_pwr:     0 max_pwr:   222
[    0.123335] schedtune: CPU[1]            min_pwr:     0 max_pwr:   222
[    0.123968] schedtune: CPU[2]            min_pwr:     0 max_pwr:   222
[    0.124601] schedtune: CPU[3]            min_pwr:     0 max_pwr:   222
[    0.125234] schedtune: CLUSTER[4-5]      min_pwr:    65 max_pwr:  1108
[    0.125866] schedtune: CPU[4]            min_pwr:     0 max_pwr:  1108
[    0.126499] schedtune: CPU[5]            min_pwr:     0 max_pwr:  1108
[    0.127158] schedtune: SYSTEM            min_pwr:   121 max_pwr:  4434
[    0.127791] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[    0.128530] schedtune: verify normalization constants...
[    0.129046] schedtune: max_pwr/2^0: 4313 => norm_pwr:  1024
[    0.129586] schedtune: max_pwr/2^1: 2156 => norm_pwr:   511
[    0.130125] schedtune: max_pwr/2^2: 1078 => norm_pwr:   255
[    0.130672] schedtune: max_pwr/2^3:  539 => norm_pwr:   127
[    0.131212] schedtune: max_pwr/2^4:  269 => norm_pwr:    63
[    0.131751] schedtune: max_pwr/2^5:  134 => norm_pwr:    31
[    0.132291] schedtune: configured to support 5 boost groups
[    0.140707] cpuidle: using governor ladder
[    0.150712] cpuidle: using governor menu
[    0.151105] Registered FIQ tty driver
[    0.151781] vdso: 2 pages (1 code @ ffffff8008b36000, 1 data @ ffffff8009134000)
[    0.152519] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.153899] DMA: preallocated 256 KiB pool for atomic allocations
[    0.175572] console [pstore0] enabled
[    0.176162] pstore: Registered ramoops as persistent store backend
[    0.176765] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[    0.179537] fiq debugger fiq mode enabled
[[    0.180201] console [ttyFIQ0] enabled
[[     0.180893] bootconsole [uart0] disabled
[    0.181820] Registered fiq debugger ttyFIQ0
[    0.212699] Rockchip hdmi driver version 2.0
[    0.214955] iommu: Adding device ff650000.vpu_service to group 0
[    0.215059] iommu: Adding device ff660000.rkvdec to group 1
[    0.215130] iommu: Adding device ff670000.iep to group 2
[    0.215224] iommu: Adding device ff8f0000.vop to group 3
[    0.215301] iommu: Adding device ff900000.vop to group 4
[    0.215407] iommu: Adding device ff910000.isp to group 5
[    0.215483] iommu: Adding device ff920000.isp to group 6
[    0.216171] rk_iommu ff670800.iommu: can't get aclk
[    0.216191] rk_iommu ff670800.iommu: can't get hclk
[    0.217062] SCSI subsystem initialized
[    0.217391] usbcore: registered new interface driver usbfs
[    0.217437] usbcore: registered new interface driver hub
[    0.217512] usbcore: registered new device driver usb
[    0.217874] media: Linux media interface: v0.10
[    0.217914] Linux video capture interface: v2.00
[    0.218045] pps_core: LinuxPPS API ver. 1 registered
[    0.218056] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.218082] PTP clock support registered
[    0.219621] Advanced Linux Sound Architecture Driver Initialized.
[    0.220091] Bluetooth: Core ver 2.21
[    0.220145] NET: Registered protocol family 31
[    0.220157] Bluetooth: HCI device and connection manager initialized
[    0.220173] Bluetooth: HCI socket layer initialized
[    0.220187] Bluetooth: L2CAP socket layer initialized
[    0.220216] Bluetooth: SCO socket layer initialized
[    0.221288] rockchip-cpuinfo cpuinfo: Serial         : 88ff02704c5b8ce7
[    0.221773] clocksource: Switched to clocksource arch_sys_counter
[    0.265005] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.265267] NET: Registered protocol family 2
[    0.265685] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.265868] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.266097] TCP: Hash tables configured (established 32768 bind 32768)
[    0.266176] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.266222] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.266397] NET: Registered protocol family 1
[    0.266902] Trying to unpack rootfs image as initramfs...
[    0.355373] Freeing initrd memory: 1716K
[    0.355879] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.355969] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.358623] audit: initializing netlink subsys (disabled)
[    0.358707] audit: type=2000 audit(0.356:1): initialized
[    0.363934] VFS: Disk quotas dquot_6.6.0
[    0.364072] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.365633] fuse init (API version 7.23)
[    0.366832]
[    0.366832] TEE Core Framework initialization (ver 1:0.1)
[    0.366867] TEE armv7 Driver initialization
[    0.367220] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[    0.367237] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[    0.367420] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[    0.371332] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.371362] io scheduler noop registered
[    0.371531] io scheduler cfq registered (default)
[    0.372874] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[    0.377865] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    0.377897] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    0.377916] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    0.898539] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    0.898716] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    0.900087] iep: failed to find iep power down clock source.
[    0.900699] IEP Power ON
[    0.900912] IEP Power OFF
[    0.900997] IEP Driver loaded succesfully
[    0.901231] Module initialized.
[    0.901842] rk-vcodec ff650000.vpu_service: probe device
[    0.901889] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f1f0a410
[    0.902062] rk-vcodec ff650000.vpu_service: allocator is drm
[    0.902126] rk-vcodec ff650000.vpu_service: checking hw id 0
[    0.902719] rk-vcodec ff650000.vpu_service: init success
[    0.905857] rk-vcodec ff660000.rkvdec: probe device
[    0.906348] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f1f0ac10
[    0.907046] rk-vcodec ff660000.rkvdec: allocator is drm
[    0.907574] rk-vcodec ff660000.rkvdec: checking hw id 6876
[    0.908379] rk-vcodec ff660000.rkvdec: init success
[    0.910259] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.910953] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    0.913086] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.913786] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    0.916204] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    0.918352] console [ttyS0] disabled
[    0.918722] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[    0.920056] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[    0.921417] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 40, base_baud = 1500000) is a 16550A
[    0.922582] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[    0.928008] mali ff9a0000.gpu: Failed to get regulator
[    0.928489] mali ff9a0000.gpu: Power control initialization failed
[    0.929329] Unable to detect cache hierarchy from DT for CPU 0
[    0.939386] brd: module loaded
[    0.945542] loop: module loaded
[    0.946209] zram: Added device: zram0
[    0.947132] SCSI Media Changer driver v0.25
[    0.948693] rockchip-pinctrl pinctrl: pin gpio1-8 already requested by ff370000.serial; cannot claim for ff1d0000.spi
[    0.948721] rockchip-pinctrl pinctrl: pin-40 (ff1d0000.spi) status -22
[    0.948742] rockchip-pinctrl pinctrl: could not request pin 40 (gpio1-8) from group spi1-tx  on device rockchip-pinctrl
[    0.948766] rockchip-spi ff1d0000.spi: Error applying setting, reverse things back
[    0.948900] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[    0.948914] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[    0.949591] register spi return v = :0
[    0.949643] tun: Universal TUN/TAP device driver, 1.6
[    0.949654] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.950573] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[    0.950661] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    0.950679] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    0.950693] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[    0.950718] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    0.950891] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    0.955909] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    0.956040] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    0.956050]  Ring mode enabled
[    0.956059]  DMA HW capability register supported
[    0.956068]  Normal descriptors
[    0.956078]  RX Checksum Offload Engine supported (type 2)
[    0.956088]  Wake-Up On Lan supported
[    0.956130]  Enable RX Mitigation via HW Watchdog Timer
[    1.024739] libphy: stmmac: probed
[    1.024796] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[    1.024811] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[    1.026227] PPP generic driver version 2.4.2
[    1.026533] PPP BSD Compression module registered
[    1.026550] PPP Deflate Compression module registered
[    1.026585] PPP MPPE Compression module registered
[    1.026606] NET: Registered protocol family 24
[    1.026657] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[    1.026702] CSLIP: code copyright 1989 Regents of the University of California.
[    1.026731] Rockchip WiFi SYS interface (V1.00) ...
[    1.026855] usbcore: registered new interface driver catc
[    1.026912] usbcore: registered new interface driver kaweth
[    1.026930] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    1.026985] usbcore: registered new interface driver pegasus
[    1.027042] usbcore: registered new interface driver rtl8150
[    1.027098] usbcore: registered new interface driver r8152
[    1.027113] hso: drivers/net/usb/hso.c: Option Wireless
[    1.027188] usbcore: registered new interface driver hso
[    1.027255] usbcore: registered new interface driver asix
[    1.027312] usbcore: registered new interface driver ax88179_178a
[    1.027368] usbcore: registered new interface driver cdc_ether
[    1.027424] usbcore: registered new interface driver cdc_eem
[    1.027478] usbcore: registered new interface driver dm9601
[    1.027553] usbcore: registered new interface driver smsc75xx
[    1.027620] usbcore: registered new interface driver smsc95xx
[    1.027676] usbcore: registered new interface driver gl620a
[    1.027731] usbcore: registered new interface driver net1080
[    1.027786] usbcore: registered new interface driver plusb
[    1.027842] usbcore: registered new interface driver rndis_host
[    1.027902] usbcore: registered new interface driver cdc_subset
[    1.027957] usbcore: registered new interface driver zaurus
[    1.028015] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.028096] usbcore: registered new interface driver int51x1
[    1.028153] usbcore: registered new interface driver kalmia
[    1.028214] usbcore: registered new interface driver ipheth
[    1.028273] usbcore: registered new interface driver sierra_net
[    1.028330] usbcore: registered new interface driver cx82310_eth
[    1.028399] usbcore: registered new interface driver cdc_ncm
[    1.028477] usbcore: registered new interface driver qmi_wwan
[    1.028541] usbcore: registered new interface driver cdc_mbim
[    1.030291] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[    1.035131] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[    1.036040] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.036061] ehci-pci: EHCI PCI platform driver
[    1.036151] ehci-platform: EHCI generic platform driver
[    1.040169] ehci-platform fe3c0000.usb: EHCI Host Controller
[    1.040206] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[    1.040441] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[    1.048463] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    1.048655] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.048672] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.048686] usb usb1: Product: EHCI Host Controller
[    1.048698] usb usb1: Manufacturer: Linux 4.4.103 ehci_hcd
[    1.048711] usb usb1: SerialNumber: fe3c0000.usb
[    1.049366] hub 1-0:1.0: USB hub found
[    1.049408] hub 1-0:1.0: 1 port detected
[    1.050211] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.050258] ohci-platform: OHCI generic platform driver
[    1.050887] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    1.050920] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[    1.051106] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[    1.105980] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.106036] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.106053] usb usb2: Product: Generic Platform OHCI controller
[    1.106067] usb usb2: Manufacturer: Linux 4.4.103 ohci_hcd
[    1.106081] usb usb2: SerialNumber: fe3e0000.usb
[    1.106692] hub 2-0:1.0: USB hub found
[    1.106734] hub 2-0:1.0: 1 port detected
[    1.108052] usbcore: registered new interface driver cdc_acm
[    1.108064] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.108148] usbcore: registered new interface driver usblp
[    1.108211] usbcore: registered new interface driver cdc_wdm
[    1.108274] usbcore: registered new interface driver uas
[    1.108382] usbcore: registered new interface driver usb-storage
[    1.108521] usbcore: registered new interface driver ums-alauda
[    1.108581] usbcore: registered new interface driver ums-cypress
[    1.108645] usbcore: registered new interface driver ums-datafab
[    1.108701] usbcore: registered new interface driver ums_eneub6250
[    1.108757] usbcore: registered new interface driver ums-freecom
[    1.108812] usbcore: registered new interface driver ums-isd200
[    1.108868] usbcore: registered new interface driver ums-jumpshot
[    1.108923] usbcore: registered new interface driver ums-karma
[    1.108980] usbcore: registered new interface driver ums-onetouch
[    1.109036] usbcore: registered new interface driver ums-sddr09
[    1.109091] usbcore: registered new interface driver ums-sddr55
[    1.109150] usbcore: registered new interface driver ums-usbat
[    1.109260] usbcore: registered new interface driver usbserial
[    1.109309] usbcore: registered new interface driver usbserial_generic
[    1.109348] usbserial: USB Serial support registered for generic
[    1.109406] usbcore: registered new interface driver ch341
[    1.109444] usbserial: USB Serial support registered for ch341-uart
[    1.109506] usbcore: registered new interface driver cp210x
[    1.109544] usbserial: USB Serial support registered for cp210x
[    1.109621] usbcore: registered new interface driver ftdi_sio
[    1.109658] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.109816] usbcore: registered new interface driver option
[    1.109853] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.110020] usbcore: registered new interface driver pl2303
[    1.110057] usbserial: USB Serial support registered for pl2303
[    1.110129] usbcore: registered new interface driver trancevibrator
[    1.110149] usb20_otg: version 3.10a 21-DEC-2012
[    1.110431] usb20_host: version 3.10a 21-DEC-2012
[    1.111094] usbcore: registered new interface driver xpad
[    1.111167] usbcore: registered new interface driver usb_acecad
[    1.111231] usbcore: registered new interface driver aiptek
[    1.111293] usbcore: registered new interface driver gtco
[    1.111355] usbcore: registered new interface driver hanwang
[    1.111417] usbcore: registered new interface driver kbtab
[    1.111434] ==gsl_ts_init==
[    1.111473] ret=0
[    1.112075] .. rk pwm remotectl v1.1 init
[    1.112398] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[    1.113036] sensor_register_slave:mma8452,id=17
[    1.113056] sensor_register_slave:lis3dh,id=7
[    1.113074] sensor_register_slave:mma7660,id=18
[    1.113091] sensor_register_slave:lsm303d,id=22
[    1.113108] sensor_register_slave:gs_mc3230,id=23
[    1.113117] [Gsensor]   gsensor_init
[    1.113133] sensor_register_slave:mpu6880_acc,id=24
[    1.113151] sensor_register_slave:mpu6500_acc,id=25
[    1.113168] sensor_register_slave:lsm330_acc,id=26
[    1.113186] sensor_register_slave:akm8975,id=29
[    1.113203] sensor_register_slave:akm8963,id=30
[    1.113221] sensor_register_slave:l3g4200d,id=44
[    1.113238] sensor_register_slave:l3g20d,id=45
[    1.113255] sensor_register_slave:ewtsa,id=46
[    1.113272] sensor_register_slave:lsm330_gyro,id=50
[    1.113289] sensor_register_slave:cm3217,id=52
[    1.113306] sensor_register_slave:cm3218,id=53
[    1.114240] i2c /dev entries driver
[    1.115741] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    1.115847] fan53555-reg: supplied by vcc5v0_sys
[    1.117742] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    1.117809] fan53555-reg: supplied by vcc5v0_sys
[    1.119904] rk808 0-001b: Pmic Chip id: 0x0
[    1.123617] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    1.123694] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    1.123811] DCDC_REG1: supplied by vcc3v3_sys
[    1.124612] DCDC_REG2: supplied by vcc3v3_sys
[    1.125296] DCDC_REG3: supplied by vcc3v3_sys
[    1.125570] DCDC_REG4: supplied by vcc3v3_sys
[    1.126031] LDO_REG1: supplied by vcc3v3_sys
[    1.127241] LDO_REG2: supplied by vcc3v3_sys
[    1.128256] LDO_REG3: supplied by vcc3v3_sys
[    1.129251] LDO_REG4: supplied by vcc3v3_sys
[    1.130274] LDO_REG5: supplied by vcc3v3_sys
[    1.131261] LDO_REG6: supplied by vcc3v3_sys
[    1.132253] LDO_REG7: supplied by vcc3v3_sys
[    1.133262] LDO_REG8: supplied by vcc3v3_sys
[    1.134289] SWITCH_REG1: supplied by vcc3v3_sys
[    1.134569] SWITCH_REG2: supplied by vcc3v3_sys
[    1.138337] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[    1.138965] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80095fe000
[    1.139718] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80096dc000
[    1.139842] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[    1.139860] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[    1.139875] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer  on device rockchip-pinctrl
[    1.139891] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[    1.140326] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80096de000
[    1.141899] fusb302 4-0022: Can't get property of role, set role to default DRP
[    1.150246] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[    1.150287] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80096f2000
[    1.151467] IR NEC protocol handler initialized
[    1.151483] IR RC5(x/sz) protocol handler initialized
[    1.151498] IR RC6 protocol handler initialized
[    1.151513] IR JVC protocol handler initialized
[    1.151527] IR Sony protocol handler initialized
[    1.151541] IR SANYO protocol handler initialized
[    1.151556] IR Sharp protocol handler initialized
[    1.151571] IR MCE Keyboard/mouse protocol handler initialized
[    1.151586] IR XMP protocol handler initialized
[    1.151911] usbcore: registered new interface driver uvcvideo
[    1.151922] USB Video Class driver (1.1.1)
[    1.151941] CamSys driver version: v0.34.8, CamSys head file version: v0.13.0
[    1.157727] __power_supply_register: Expected proper parent device for 'test_ac'
[    1.157897] __power_supply_register: Expected proper parent device for 'test_battery'
[    1.158217] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[    1.158348] __power_supply_register: Expected proper parent device for 'test_usb'
[    1.161656] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[    1.162788] device-mapper: uevent: version 1.0.3
[    1.163239] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    1.163446] Bluetooth: HCI UART driver ver 2.3
[    1.163460] Bluetooth: HCI UART protocol H4 registered
[    1.163471] Bluetooth: HCI UART protocol LL registered
[    1.163487] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[    1.163497] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[    1.163507] rtk_btusb: Register usb char device interface for BT driver
[    1.163848] usbcore: registered new interface driver rtk_btusb
[    1.164435] cpu cpu0: leakage=17
[    1.181965] cpu cpu0: temp=53888, pvtm=142619 (141827 + 792)
[    1.182389] cpu cpu0: pvtm-sel=0
[    1.182816] cpu cpu4: leakage=30
[    1.195608] cpu cpu4: temp=53333, pvtm=147824 (147404 + 420)
[    1.196674] cpu cpu4: pvtm-sel=0
[    1.202467] sdhci: Secure Digital Host Controller Interface driver
[    1.202518] sdhci: Copyright(c) Pierre Ossman
[    1.202537] Synopsys Designware Multimedia Card Interface Driver
[    1.203744] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    1.203893] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    1.203914] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    1.203984] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    1.204049] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    1.204110] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    1.204123] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    1.205262] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    1.205339] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    1.205359] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    1.205411] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    1.205437] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    1.205551] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[    1.205884] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    1.206045] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    1.218598] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    1.232879] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[    1.233156] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.234834] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[    1.234851] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[    1.262150] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    1.266139] hidraw: raw HID events driver (C) Jiri Kosina
[    1.270906] usbcore: registered new interface driver usbhid
[    1.270929] usbhid: USB HID core driver
[    1.271103] inv_mpu_iio: inv_mpu_init:746
[    1.272712] ashmem: initialized
[    1.275343] ff100000.saradc supply vref not found, using dummy regulator
[    1.281743] rknandbase v1.1 2016-11-08
[    1.282731] usbcore: registered new interface driver snd-usb-audio
[    1.284084] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[    1.284159] rt5640 1-001c: Can not read property hp-con-gpio
[    1.284172] rt5640 1-001c: Can not read property: linein-mute.
[    1.300250] u32 classifier
[    1.300276]     Actions configured
[    1.300341] Netfilter messages via NETLINK v0.30.
[    1.300408] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    1.300796] ctnetlink v0.93: registering with nfnetlink.
[    1.301467] xt_time: kernel timezone is -0000
[    1.302254] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.302429] arp_tables: (C) 2002 David S. Miller
[    1.302889] mmc1: MAN_BKOPS_EN bit is not set
[    1.302911] Initializing XFRM netlink socket
[    1.303351] NET: Registered protocol family 10
[    1.307970] mip6: Mobile IPv6
[    1.308018] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    1.309523] sit: IPv6 over IPv4 tunneling driver
[    1.310001] NET: Registered protocol family 17
[    1.310032] NET: Registered protocol family 15
[    1.310072] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    1.310894] Bridge firewalling registered
[    1.310912] Ebtables v2.0 registered
[    1.311133] Bluetooth: RFCOMM TTY layer initialized
[    1.311155] Bluetooth: RFCOMM socket layer initialized
[    1.311185] Bluetooth: RFCOMM ver 1.11
[    1.311213] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.311224] Bluetooth: BNEP filters: protocol multicast
[    1.311239] Bluetooth: BNEP socket layer initialized
[    1.311257] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.311271] Bluetooth: HIDP socket layer initialized
[    1.311318] l2tp_core: L2TP core driver, V2.0
[    1.311342] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    1.311360] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    1.311642] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    1.311696] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[    1.311708] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    1.311719] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    1.311833] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[    1.311845] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    1.311858] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    1.311920] [BT_RFKILL]: Enter rfkill_rk_init
[    1.312263] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[    1.312311] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[    1.312345] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[    1.312379] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[    1.318824] [BT_RFKILL]: Request irq for bt wakeup host
[    1.318888] [BT_RFKILL]: ** disable irq
[    1.319025] [BT_RFKILL]: bt_default device registered.
[    1.319307] sensor_register_slave:mpu6880_gyro,id=49
[    1.320560] Registered cp15_barrier emulation handler
[    1.320683] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[    1.320714] Registered setend emulation handler
[    1.321492] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[    1.321547] registered taskstats version 1
[    1.321743] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[    1.322457] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[    1.322658] rockchip ion idev is NULL
[    1.322679] rga2 ff680000.rga: rga ion client create success!
[    1.322923] rga: Driver loaded successfully ver:3.02
[    1.323046] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[    1.323611]      uboot: 0x000400000 -- 0x000800000 (4 MB)
[    1.323627]      trust: 0x000800000 -- 0x000c00000 (4 MB)
[    1.323639]       misc: 0x000c00000 -- 0x001000000 (4 MB)
[    1.323651]   resource: 0x001000000 -- 0x002000000 (16 MB)
[    1.323663]     kernel: 0x002000000 -- 0x003800000 (24 MB)
[    1.323674]       boot: 0x003800000 -- 0x005800000 (32 MB)
[    1.323686]   recovery: 0x005800000 -- 0x007800000 (32 MB)
[    1.323699]     backup: 0x007800000 -- 0x00e800000 (112 MB)
[    1.323713]      cache: 0x00e800000 -- 0x016800000 (128 MB)
[    1.323727]     system: 0x016800000 -- 0x076800000 (1536 MB)
[    1.323741]   metadata: 0x076800000 -- 0x077800000 (16 MB)
[    1.323752] baseparamer: 0x077800000 -- 0x077c00000 (4 MB)
[    1.323764]   userdata: 0x077c00000 -- 0x3a3a00000 (12990 MB)
[    1.323834]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
[    1.323921] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[    1.326359] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[    1.326594] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[    1.327109] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[    1.327146] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[    1.327217] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    1.328404] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[    1.328918] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[    1.329437] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[    1.329485] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[    1.329503] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.329517] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[    1.355193] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    1.480189] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[    1.480298] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.480325] usb 1-1: Product: USB 2.0 Hub [MTT]
[    1.481548] hub 1-1:1.0: USB hub found
[    1.481752] hub 1-1:1.0: 7 ports detected
[    1.761943] usb 1-1.2: new full-speed USB device number 3 using ehci-platform
[    1.842177] rockchip-drm display-subsystem: fb0:  frame buffer device
[    1.847617] vendor storage:20160801 ret = 0
[    1.857731] mali ff9a0000.gpu: leakage=24
[    1.867608] usb 1-1.2: New USB device found, idVendor=0403, idProduct=6001
[    1.867701] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.867740] usb 1-1.2: Product: iClebo Kobuki
[    1.867764] usb 1-1.2: Manufacturer: Yujin Robot
[    1.867788] usb 1-1.2: SerialNumber: kobuki_AL03EQNE
[    1.871327] ftdi_sio 1-1.2:1.0: FTDI USB Serial Device converter detected
[    1.871588] usb 1-1.2: Detected FT232RL
[    1.872425] mali ff9a0000.gpu: temp=52222, pvtm=120534 (120402 + 132)
[    1.872482] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
[    1.875052] mali ff9a0000.gpu: pvtm-sel=0
[    1.876532] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[    1.877577] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[    1.878551] mali ff9a0000.gpu: Probed as mali0
[    1.884585] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[    1.885249] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 3
[    1.885652] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[    1.885764] xhci-hcd xhci-hcd.10.auto: irq 233, io mem 0xfe800000
[    1.886013] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    1.886045] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.886073] usb usb3: Product: xHCI Host Controller
[    1.886094] usb usb3: Manufacturer: Linux 4.4.103 xhci-hcd
[    1.886117] usb usb3: SerialNumber: xhci-hcd.10.auto
[    1.890584] hub 3-0:1.0: USB hub found
[    1.890666] hub 3-0:1.0: 1 port detected
[    1.891177] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[    1.891217] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4
[    1.893171] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.893377] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    1.893408] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.893433] usb usb4: Product: xHCI Host Controller
[    1.893455] usb usb4: Manufacturer: Linux 4.4.103 xhci-hcd
[    1.893476] usb usb4: SerialNumber: xhci-hcd.10.auto
[    1.894284] hub 4-0:1.0: USB hub found
[    1.894354] hub 4-0:1.0: 1 port detected
[    1.900839] xhci-hcd xhci-hcd.10.auto: remove, state 1
[    1.900909] usb usb4: USB disconnect, device number 1
[    1.929807] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[    1.929838] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[    1.932104] xhci-hcd xhci-hcd.10.auto: USB bus 4 deregistered
[    1.932640] xhci-hcd xhci-hcd.10.auto: remove, state 1
[    1.933120] usb usb3: USB disconnect, device number 1
[    1.933990] xhci-hcd xhci-hcd.10.auto: USB bus 3 deregistered
[    1.939658] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[    1.939815] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[    1.940300] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[    1.940403] xhci-hcd xhci-hcd.11.auto: irq 234, io mem 0xfe900000
[    1.940733] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    1.940765] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.940793] usb usb3: Product: xHCI Host Controller
[    1.940818] usb usb3: Manufacturer: Linux 4.4.103 xhci-hcd
[    1.940842] usb usb3: SerialNumber: xhci-hcd.11.auto
[    1.945558] hub 3-0:1.0: USB hub found
[    1.945726] hub 3-0:1.0: 1 port detected
[    1.946348] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[    1.946392] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[    1.946637] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.946878] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    1.946910] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.946936] usb usb4: Product: xHCI Host Controller
[    1.946961] usb usb4: Manufacturer: Linux 4.4.103 xhci-hcd
[    1.946986] usb usb4: SerialNumber: xhci-hcd.11.auto
[    1.948581] hub 4-0:1.0: USB hub found
[    1.948683] hub 4-0:1.0: 1 port detected
[    1.951858] usb 1-1.4: new full-speed USB device number 4 using ehci-platform
[    1.954202] ehci-platform fe380000.usb: EHCI Host Controller
[    1.954283] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[    1.954664] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[    2.042130] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    2.042536] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    2.042568] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.042595] usb usb5: Product: EHCI Host Controller
[    2.042620] usb usb5: Manufacturer: Linux 4.4.103 ehci_hcd
[    2.042644] usb usb5: SerialNumber: fe380000.usb
[    2.045801] hub 5-0:1.0: USB hub found
[    2.045877] hub 5-0:1.0: 1 port detected
[    2.047622] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    2.047683] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[    2.048033] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[    2.054113] usb 1-1.4: New USB device found, idVendor=222a, idProduct=0001
[    2.054219] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.054248] usb 1-1.4: Product: ILITEK-TP
[    2.054271] usb 1-1.4: Manufacturer: ILITEK
[    2.054293] usb 1-1.4: SerialNumber: V06.00.00.00
[    2.066377] input: ILITEK ILITEK-TP as /devices/platform/fe3c0000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:222A:0001.0001/input/input1
[    2.103181] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    2.103248] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.103276] usb usb6: Product: Generic Platform OHCI controller
[    2.103302] usb usb6: Manufacturer: Linux 4.4.103 ohci_hcd
[    2.103326] usb usb6: SerialNumber: fe3a0000.usb
[    2.105787] hub 6-0:1.0: USB hub found
[    2.105864] hub 6-0:1.0: 1 port detected
[    2.108651] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    2.109112] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    2.109149] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    2.109212] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    2.109280] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.109373] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    2.109397] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    2.110074] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[    2.119497] hid-multitouch 0003:222A:0001.0001: input,hidraw0: USB HID v1.10 Device [ILITEK ILITEK-TP] on usb-fe3c0000.usb-1.4/input0
[    2.121997] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.123955] input: ILITEK ILITEK-TP as /devices/platform/fe3c0000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:222A:0001.0002/input/input2
[    2.135218] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[    2.149314] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok
[    2.154921] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card0/input3
[    2.176193] hid-generic 0003:222A:0001.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [ILITEK ILITEK-TP] on usb-fe3c0000.usb-1.4/input1
[    2.180313] asoc-simple-card spdif-sound: dit-hifi <-> ff870000.spdif mapping ok
[    2.182230] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[    2.183892] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.184959] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[    2.185547] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.185690] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to add ELD: -16
[    2.188133] rk-hdmi-dp-sound hdmi-dp-sound: multicodec <-> ff8a0000.i2s mapping ok
[    2.188515] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[    2.188974] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to create Playback debugfs file
[    2.192122] otg_wakelock_init: No USB transceiver found
[    2.193768] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:57:18 UTC (1358499438)
[    2.195171] It doesn't contain Rogue gpu
[    2.221331] ret 1024
[    2.222274] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko .
[    2.223366] Mali: Mali device driver loaded
[    2.224626] input: rk29-keypad as /devices/platform/rockchip-key/input/input4
[    2.226822] ALSA device list:
[    2.226892]   #0: rockchip,rt5640-codec
[    2.226913]   #1: ROCKCHIP,SPDIF
[    2.226932]   #2: rk-hdmi-dp-sound
[    2.227902] Freeing unused kernel memory: 832K
[    2.233534] init: init first stage started!
[    2.237001] init: init second stage started!
[    2.243563] init: Setting ro.rk.soc=rk3399
[    2.243704] init: OK,EMMC DRIVERS INIT OK
[    2.243738] init: property_set("ro.boot.mode", "emmc") failed
[    2.243836] init: property_set("ro.hardware", "rk30board") failed
[    2.243897] init: Running restorecon...
[    2.244067] init: waitpid failed: No child processes
[    2.244494] init: (Loading properties from /default.prop took 0.00s.)
[    2.246668] init: /init.rc: 588: invalid keyword 'echo'
[    2.247259] init: (Parsing /init.environ.rc took 0.00s.)
[    2.247544] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
[    2.248242] init: (Parsing /init.usb.rc took 0.00s.)
[    2.250645] init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[    2.251822] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[    2.251919] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[    2.252025] init: could not import file '/init.stt_trace.rc' from '/init.debug.rc': No such file or directory
[    2.252068] init: could not import file '/init.logs.rc' from '/init.debug.rc': No such file or directory
[    2.252110] init: could not import file '/init.crashlogd.rc' from '/init.debug.rc': No such file or directory
[    2.252152] init: could not import file '/init.coredump.rc' from '/init.debug.rc': No such file or directory
[    2.252206] init: could not import file '/init.log-watch.rc' from '/init.debug.rc': No such file or directory
[    2.252287] init: (Parsing /init.kernel.rc took 0.00s.)
[    2.252425] init: (Parsing /init.debug-charging.rc took 0.00s.)
[    2.252476] init: (Parsing /init.debug.rc took 0.00s.)
[    2.252505] init: (Parsing init.rockchip.rc took 0.00s.)
[    2.253111] init: (Parsing init.connectivity.rc took 0.00s.)
[    2.253237] init: (Parsing init.box.samba.rc took 0.00s.)
[    2.253408] init: (Parsing init.rk3399.rc took 0.00s.)
[    2.253570] init: init.box.rc: 25: invalid keyword 'ioprio'
[    2.253604] init: (Parsing init.box.rc took 0.00s.)
[    2.253653] init: could not import file 'init.car.rc' from '/init.rk30board.rc': No such file or directory
[    2.253695] init: could not import file 'init.optee.rc' from '/init.rk30board.rc': No such file or directory
[    2.253720] init: (Parsing /init.rk30board.rc took 0.01s.)
[    2.254733] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[    2.254876] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[    2.254901] init: (Parsing /init.rc took 0.01s.)
[    2.255413] init: Starting service 'ueventd'...
[    2.256976] init: write_file: Unable to open '/proc/sys/kernel/panic_on_stackoverflow': No such file or directory
[    2.260623] ueventd: ueventd started!
[    2.262196] ueventd: invalid gid 'trace'
[    2.369867] init: Waiting for /dev/.coldboot_done...
[    2.421236] ueventd: Coldboot took 0.16s.
[    2.430918] init: Waiting for /dev/.coldboot_done took 0.06s.
[    2.431071] init: /dev/hw_random not found
[    2.431719] keychord: using input dev ff420030.pwm for fevent
[    2.431775] keychord: using input dev rk29-keypad for fevent
[    2.434560] init: write_file: Unable to open '/proc/cpu/alignment': No such file or directory
[    2.441470] Registered swp emulation handler
[    2.441686] init: write_file: Unable to open '/sys/module/rockchip_pm/parameters/policy': No such file or directory
[    2.442599] init: /dev/hw_random not found
[    2.442822] init: write_file: Unable to open '/sys/block/mmcblk0/bdi/read_ahead_kb': No such file or directory
[    2.443545] fs_mgr: Warning: unknown flag resize
[    2.446818] EXT4-fs (mmcblk1p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[    2.446873] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/system,target=/system,type=ext4)=0
[    2.447601] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=-1: No such file or directory
[    2.448169] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache
[    2.455307] random: e2fsck: uninitialized urandom read (40 bytes read, 52 bits of entropy available)
[    2.486348] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    2.486348]
[    2.486385] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: recovering journal
[    2.486385]
[    2.486398] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: clean, 39/8192 files, 1741/32768 blocks
[    2.486398]
[    2.490315] EXT4-fs (mmcblk1p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[    2.490363] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[    2.491309] EXT4-fs (mmcblk1p11): Ignoring removed nomblk_io_submit option
[    2.492433] EXT4-fs (mmcblk1p11): recovery complete
[    2.492444] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    2.492470] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[    2.513818] fs_mgr: check_fs(): unmount(/metadata) succeeded
[    2.513871] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata
[    2.514780] random: e2fsck: uninitialized urandom read (40 bytes read, 55 bits of entropy available)
[    2.525959] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    2.525959]
[    2.526029] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata has been mounted 10 times without being checked, check forced.
[    2.526029]
[    2.526046] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[    2.526046]
[    2.526059] e2fsck: Pass 2: Checking directory structure
[    2.526059]
[    2.526071] e2fsck: Pass 3: Checking directory connectivity
[    2.526071]
[    2.526083] e2fsck: Pass 4: Checking reference counts
[    2.526083]
[    2.526095] e2fsck: Pass 5: Checking group summary information
[    2.526095]
[    2.526109] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata: 11/1024 files (0.0% non-contiguous), 1102/4096 blocks
[    2.526109]
[    2.528203] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[    2.528252] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[    2.528304] fs_mgr: Running /system/bin/fsck.f2fs -a /dev/block/platform/fe330000.sdhci/by-name/userdata
[    2.529479] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[    2.529479]
[    2.529520] fsck.f2fs: fsck.f2fs terminated by exit(255)
[    2.529520]
[    2.545662] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 247
[    2.548008] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[    2.548042] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[   12.437465] random: nonblocking pool is initialized
等了约莫十几分钟3399还是没有起来, 镜像是自己编译烧录的, 长时间断电后就会出现这种情况,有人可以解释一下为什么会出现这种情况么。
等了差不多有半个小时左右吧,板子最终还是起来了
[  893.305888] F2FS-fs (mmcblk1p13): recover_inode: ino = 21ec3, name = .temp.lyd6oE
[  893.308758] F2FS-fs (mmcblk1p13): recover_dentry: ino = 21ec3, name = .temp.lyd6oE, dir = 2c, err = 0
[  893.308786] F2FS-fs (mmcblk1p13): recover_data: ino = 21ec3 (i_size: recover) recovered = 0, err = 0
[  893.308799] F2FS-fs (mmcblk1p13): recover_inode: ino = 21de9, name = .temp.jV6tBx
[  893.309756] F2FS-fs (mmcblk1p13): recover_dentry: ino = 21de9, name = .temp.jV6tBx, dir = 2c, err = 0
[  893.309776] F2FS-fs (mmcblk1p13): recover_data: ino = 21de9 (i_size: recover) recovered = 0, err = 0
[  893.309785] F2FS-fs (mmcblk1p13): recover_inode: ino = 21dea, name = .temp.CagbI9
[  893.310384] F2FS-fs (mmcblk1p13): recover_dentry: ino = 21dea, name = .temp.CagbI9, dir = 2c, err = 0
[  893.310401] F2FS-fs (mmcblk1p13): recover_data: ino = 21dea (i_size: recover) recovered = 0, err = 0
[  893.310411] F2FS-fs (mmcblk1p13): recover_inode: ino = 21aee, name = .temp.AiceOD
[  898.308288] f2fs_msg: 361501 callbacks suppressed
[  898.308316] F2FS-fs (mmcblk1p13): recover_dentry: ino = 1f06e, name = .temp.jsSsgX, dir = 2c, err = 0
[  898.308340] F2FS-fs (mmcblk1p13): recover_data: ino = 1f06e (i_size: recover) recovered = 0, err = 0
[  898.308352] F2FS-fs (mmcblk1p13): recover_inode: ino = 1f06f, name = .temp.Bp2R3I
[  898.308397] F2FS-fs (mmcblk1p13): recover_dentry: ino = 1f06f, name = .temp.Bp2R3I, dir = 2c, err = 0
[  898.308416] F2FS-fs (mmcblk1p13): recover_data: ino = 1f06f (i_size: recover) recovered = 0, err = 0
[  898.308425] F2FS-fs (mmcblk1p13): recover_inode: ino = 1f070, name = .temp.0WRQpb
[  898.308469] F2FS-fs (mmcblk1p13): recover_dentry: ino = 1f070, name = .temp.0WRQpb, dir = 2c, err = 0
[  898.308485] F2FS-fs (mmcblk1p13): recover_data: ino = 1f070 (i_size: recover) recovered = 0, err = 0
[  898.308493] F2FS-fs (mmcblk1p13): recover_inode: ino = 1f071, name = .temp.7px0oM
[  898.308534] F2FS-fs (mmcblk1p13): recover_dentry: ino = 1f071, name = .temp.7px0oM, dir = 2c, err = 0
[  911.412181] f2fs_msg: 102306 callbacks suppressed
[  911.412230] F2FS-fs (mmcblk1p13): checkpoint: version = 3ef7
[  911.413593] F2FS-fs (mmcblk1p13): Mounted with checkpoint version = 3ef7
[  911.414321] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=f2fs)=0
[  911.425454] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[  911.425764] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[  911.425955] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[  911.426210] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[  911.426441] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[  911.426639] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[  911.426818] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[  911.427017] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[  911.427309] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[  911.427511] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[  911.427746] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[  911.427956] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[  911.428158] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[  911.428364] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[  911.428741] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[  911.428980] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[  911.429171] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[  911.429358] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[  911.429542] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[  911.429729] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[  911.429929] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[  911.430117] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[  911.430311] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[  911.430498] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[  911.430702] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[  911.430913] init: ignored duplicate definition of service 'ril-daemon'init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[  911.431161] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[  911.431368] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[  911.431627] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[  911.431898] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[  911.432131] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[  911.433135] init: property_set("ro.board.platform", "rk3399") failed
[  911.433528] init: property_set("ro.rk.screenoff_time", "2147483647") failed
[  911.433691] init: property_set("ro.rk.screenshot_enable", "true") failed
[  911.433801] init: (Loading properties from /system/build.prop took 0.00s.)
[  911.433844] init: (Loading properties from /vendor/build.prop took 0.00s.)
[  911.433874] init: (Loading properties from /factory/factory.prop took 0.00s.)
[  911.433967] fs_mgr: Warning: unknown flag resize
[  911.434052] init: /recovery not specified in fstab
[  911.434154] init: Starting service 'healthd'...
[  911.434541] init: cannot find '/system/bin/displayd' (No such file or directory), disabling 'displayd'
[  911.434625] init: Starting service 'zygote'...
[  911.434898] init: Starting service 'zygote_secondary'...
[  911.435281] init: Starting service 'lmkd'...
[  911.435656] init: Starting service 'servicemanager'...
[  911.436285] init: Starting service 'surfaceflinger'...
[  911.436925] binder: 202:202 transaction failed 29189/-22, size 0-0 line 2951
[  911.437010] init: Starting service 'vold'...
[  911.440136] init: insmod: open("/system/lib/modules/ump.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/mali.ko") failed: No such filee
[  911.443187] zram0: detected capacity change from 0 to 533413888
[  911.469679] Adding 520908k swap on /dev/block/zram0.  Priority:-1 extents:1 across:520908k SS
[  911.471030] init: Starting service 'debuggerd'...
[  911.471605] init: Starting service 'debuggerd64'...
[  911.473586] init: Not bootcharting.
[  911.701867] fs_mgr: Warning: unknown flag resize
[  911.757561] init: Failed to reload policy
[  911.757714] init: Starting service 'exec 1 (/system/bin/tzdatacheck)'...
[  911.764183] init: Service 'exec 1 (/system/bin/tzdatacheck)' (pid 222) exited with status 0
[  911.772416] F2FS-fs (mmcblk1p13): Unrecognized mount option "seclabel" or missing value
[  911.773079] init: (Loading properties from /data/local.prop took 0.00s.)
[  911.988669] init: Starting service 'logd'...
[  911.989248] init: Starting service 'logd-reinit'...
[  911.990050] init: write_file: Unable to open '/proc/sys/vm/min_free_order_shift': No such file or directory
[  911.991681] init: write_file: Unable to open '/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold': No such file or directory
[  911.992805] init: Starting service 'fsud'...
[  911.993345] init: Starting service 'vm_daemon'...
[  911.994316] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[  911.994338] init: write: cannot expand '${ro.serialno}'
[  911.994886] file system registered
[  911.995215] using random self ethernet address
[  911.995224] using random host ethernet address
[  911.995270] init: write_file: Unable to open '/config/usb_gadget/g1/functions/rndis.gs4/wceis': Permission denied
[  912.000314] init: Starting service 'console'...
[  912.000961] init: Starting service 'adbd'...
[  912.001757] init: cannot find '/system/bin/update_verifier' (No such file or directory), disabling 'exec 2 (/system/bin/update_verifier)'
[  912.002929] init: Starting service 'ril-daemon'...
[  912.003872] init: cannot find '/system/bin/install-recovery.sh' (No such file or directory), disabling 'flash_recovery'
[  912.004894] init: Starting service 'ipset'...
[  912.006071] init: Starting service 'drmservice'...
[  912.007005] init: cannot find '/system/bin/bplus_helper' (No such file or directory), disabling 'bplus_helper'
[  912.007944] init: Starting service 'up_eth0'...
[  912.008948] init: cannot find '/system/bin/rk_store_keybox' (No such file or directory), disabling 'rk_store_keybox'
[  912.009057] init: Starting service 'akmd'...
[  912.009954] init: Starting service 'audioserver'...
[  912.010649] init: Starting service 'cameraserver'...
[  912.011505] init: couldn't write 255 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[  912.011797] logd.auditd: start
[  912.011867] logd.klogd: 912010181112
[  912.014964] logd.daemon: reinit
[  912.015009] init: Starting service 'drm'...
[  912.015525] init: Starting service 'installd'...
[  912.016030] init: Starting service 'keystore'...
[  912.016537] init: Starting service 'mediacodec'...
[  912.017142] init: Starting service 'mediadrm'...
[  912.017623] init: Starting service 'mediaextractor'...
[  912.018192] init: Starting service 'media'...
[  912.019095] init: Starting service 'netd'...
[  912.019694] init: Service 'logd-reinit' (pid 237) exited with status 0
[  912.019865] init: Starting service 'gatekeeperd'...
[  912.020790] init: Starting service 'perfprofd'...
rk3399_firefly_box:/ $ [  912.042880] init: Service 'akmd' (pid 248) exited with status 254
[  912.059652] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: mac address: fa:97:ec:8e:fa:1e
[  912.059669] eth0: device MAC address fa:97:ec:8e:fa:1e
[  912.077685] init: Service 'up_eth0' (pid 246) exited with status 0
[  912.109159] ret = ffffffffffffffff
[  912.110385] init: property 'sys.serialno' doesn't exist while expanding '${sys.serialno}'
[  912.110408] init: setprop: cannot expand '${sys.serialno}'
[  912.120011] init: Service 'drmservice' (pid 245) exited with status 0
[  912.208463] read descriptors
[  912.208491] read strings
[  912.400989] init: Untracked pid 305 exited with status 0
[  912.438057] healthd: BatteryCurrentNowPath not found
[  912.438084] healthd: BatteryCycleCountPath not found
[  912.473782] init: Untracked pid 314 exited with status 0
[  912.930251] init: Starting service 'bootanim'...
[  912.994541] E:camsys_i2c_write(83): i2c write dev(addr:0x20) failed!,err = -6
[  912.995194] E:camsys_i2c_write(83): i2c write dev(addr:0x6c) failed!,err = -6
[  913.006240] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[  913.006262] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[  913.006273] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout  on device rockchip-pinctrl
[  913.006284] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[  913.006293] E:camsys_mrv_iomux_cb(125): pinctrl_select_state failed!
[  913.017314] E:camsys_i2c_write(83): i2c write dev(addr:0x20) failed!,err = -6
[  913.017501] E:camsys_i2c_write(83): i2c write dev(addr:0x6c) failed!,err = -6
[  913.047522] E:camsys_i2c_write(83): i2c write dev(addr:0x20) failed!,err = -6
[  913.047799] E:camsys_i2c_write(83): i2c write dev(addr:0x6c) failed!,err = -6
[  913.059932] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[  913.059955] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[  913.059966] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout  on device rockchip-pinctrl
[  913.059977] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[  913.059985] E:camsys_mrv_iomux_cb(125): pinctrl_select_state failed!
[  913.072447] E:camsys_i2c_write(83): i2c write dev(addr:0x20) failed!,err = -6
[  913.072743] E:camsys_i2c_write(83): i2c write dev(addr:0x6c) failed!,err = -6
[  913.105275] E:camsys_i2c_write(83): i2c write dev(addr:0x20) failed!,err = -6
[  913.105476] E:camsys_i2c_write(83): i2c write dev(addr:0x6c) failed!,err = -6
[  913.109141] Freeing drm_logo memory: 488K
[  913.115427] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[  913.115447] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[  913.115455] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout  on device rockchip-pinctrl
[  913.115464] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[  913.115471] E:camsys_mrv_iomux_cb(125): pinctrl_select_state failed!
[  913.129902] E:camsys_i2c_write(83): i2c write dev(addr:0x20) failed!,err = -6
[  913.130100] E:camsys_i2c_write(83): i2c write dev(addr:0x6c) failed!,err = -6
[  913.407105] init: Untracked pid 308 exited with status 1
[  913.407840] init: Untracked pid 318 exited with status 1
[  913.948210] capability: warning: `main' uses 32-bit capabilities (legacy support in use)
[  916.075279] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[  916.404877] acc_open
[  916.404936] acc_release
[  917.809667] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.2 (r)
[  917.809711] ======== dhd_wlan_init_plat_data ========
[  917.809719] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[  917.809726] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[  917.809734] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[  917.809744] dhd_wlan_init_gpio: host_oob_irq: 73
[  917.809751] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[  917.809759] dhd_wifi_platform_load: Enter
[  917.809788] Power-up adapter 'DHD generic adapter'
[  917.810156] wifi_platform_set_power = 1
[  917.810175] ======== PULL WL_REG_ON(-1) HIGH! ========
[  917.810183] [WLAN_RFKILL]: rockchip_wifi_power: 1
[  917.810191] [WLAN_RFKILL]: wifi turn on power. -1
[  918.114969] wifi_platform_bus_enumerate device present 1
[  918.115003] ======== Card detection to detect SDIO card! ========
[  918.115012] mmc2:mmc host rescan start!
[  918.131224] bcmsdh_register: register client driver
[  918.131683] bcmsdh_sdmmc_probe: Enter num=1
[  918.132141] bcmsdh_sdmmc_probe: Enter num=2
[  918.132164] bus num (host idx)=2, slot num (rca)=1
[  918.132173] found adapter info 'DHD generic adapter'
[  918.132213] sdioh_attach: set sd_f2_blocksize 256
[  918.132233] sdioh_attach: sd clock rate = 0
[  918.132395] F1 signature read @0x18000000=0x17224356
[  918.137008] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[  918.141048] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[  918.141154] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
[  918.141355] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[  918.146978] wl_escan_attach: Enter
[  918.147047] wl_escan_init: Enter
[  918.147425] wl_create_event_handler(): thread:wl_escan_handler:3e0 started
[  918.147587] tsk Enter, tsk = 0xffffffc0986301a0
[  918.147620] dhd_attach(): thread:dhd_watchdog_thread:3e1 started
[  918.147687] dhd_attach(): thread:dhd_dpc:3e2 started
[  918.147739] dhd_attach(): thread:dhd_rxf:3e3 started
[  918.147753] dhd_deferred_work_init: work queue initialized
[  918.147781] dhd_bus_set_default_min_res_mask: Unhandled chip id
[  918.148774] sdioh_cis_read: func_cis_ptr[0]=0x10ac
[  918.156875] Dongle Host Driver, version 1.579.77.41.2 (r)
[  918.161351] Register interface [wlan0]  MAC: b0:f1:ec:1a:c0:88
[  918.161351]
[  918.162107] dhd_wl_ioctl: returning as busstate=0
[  918.162140] dhd_dbg_detach_pkt_monitor, 2204
[  918.162149] dhd_bus_devreset: == Power OFF ==
[  918.162337] bcmsdh_oob_intr_unregister: Enter
[  918.162347] bcmsdh_oob_intr_unregister: irq is not registered
[  918.162362] dhd_txglom_enable: enable 0
[  918.162370] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[  918.162378] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=128, dhd_txminmax=-1
[  918.162385] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=5
[  918.162392] sdioh_set_mode: set txglom_mode to copy
[  918.162398] dhd_bus_devreset:  WLAN OFF DONE
[  918.162427] wifi_platform_set_power = 0
[  918.162434] ======== PULL WL_REG_ON(-1) LOW! ========
[  918.162442] [WLAN_RFKILL]: rockchip_wifi_power: 0
[  918.162464] [WLAN_RFKILL]: wifi shut off power.
[  918.163190] dhd_module_init: Exit err=0
[  918.229236] dhd_open: Enter ffffffc0f026c000
[  918.229276]
[  918.229276] Dongle Host Driver, version 1.579.77.41.2 (r)
[  918.229287] wl_android_wifi_on in 1
[  918.229295] wl_android_wifi_on in 2: g_wifi_on=0
[  918.229302] wifi_platform_set_power = 1
[  918.229310] ======== PULL WL_REG_ON(-1) HIGH! ========
[  918.229318] [WLAN_RFKILL]: rockchip_wifi_power: 1
[  918.229325] [WLAN_RFKILL]: wifi turn on power. -1
[  918.482758] E:camsys_i2c_write(83): i2c write dev(addr:0x20) failed!,err = -6
[  918.482975] E:camsys_i2c_write(83): i2c write dev(addr:0x6c) failed!,err = -6
[  918.493256] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[  918.493297] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[  918.493306] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout  on device rockchip-pinctrl
[  918.493317] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[  918.493324] E:camsys_mrv_iomux_cb(125): pinctrl_select_state failed!
[  918.504140] E:camsys_i2c_write(83): i2c write dev(addr:0x20) failed!,err = -6
[  918.504353] E:camsys_i2c_write(83): i2c write dev(addr:0x6c) failed!,err = -6
[  918.531733] sdio_reset_comm():
[  918.532125] E:camsys_i2c_write(83): i2c write dev(addr:0x20) failed!,err = -6
[  918.532374] E:camsys_i2c_write(83): i2c write dev(addr:0x6c) failed!,err = -6
[  918.545006] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[  918.545931] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[  918.545942] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[  918.545952] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout  on device rockchip-pinctrl
[  918.545962] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[  918.545968] E:camsys_mrv_iomux_cb(125): pinctrl_select_state failed!
[  918.556994] E:camsys_i2c_write(83): i2c write dev(addr:0x20) failed!,err = -6
[  918.557180] E:camsys_i2c_write(83): i2c write dev(addr:0x6c) failed!,err = -6
[  918.561885] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[  918.587730] E:camsys_i2c_write(83): i2c write dev(addr:0x20) failed!,err = -6
[  918.587932] E:camsys_i2c_write(83): i2c write dev(addr:0x6c) failed!,err = -6
[  918.599606] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[  918.599643] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[  918.599653] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout  on device rockchip-pinctrl
[  918.599664] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[  918.599673] E:camsys_mrv_iomux_cb(125): pinctrl_select_state failed!
[  918.610898] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[  918.612621] E:camsys_i2c_write(83): i2c write dev(addr:0x20) failed!,err = -6
[  918.612863] E:camsys_i2c_write(83): i2c write dev(addr:0x6c) failed!,err = -6
[  918.614530] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[  918.617751] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[  918.623334] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[  918.748166] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
[  918.851067] init: cannot find '/system/bin/glgps' (No such file or directory), disabling 'gpsd'
[  918.851192] init: Starting service 'mode_switch'...
[  918.905158] init: Service 'mode_switch' (pid 1034) exited with status 1
[  918.905493] init: Starting service 'exec 3 (/system/bin/bootstat)'...
[  918.923118] init: Service 'exec 3 (/system/bin/bootstat)' (pid 1044) exited with status 0
[  918.923279] init: Starting service 'exec 4 (/system/bin/bootstat)'...
[  918.938209] init: Service 'exec 4 (/system/bin/bootstat)' (pid 1045) exited with status 0
[  918.938399] init: Starting service 'exec 5 (/system/bin/bootstat)'...
[  918.954684] init: Service 'exec 5 (/system/bin/bootstat)' (pid 1046) exited with status 0
[  918.954797] init: Starting service 'exec 6 (/system/bin/bootstat)'...
[  918.985379] init: Service 'exec 6 (/system/bin/bootstat)' (pid 1049) exited with status 0
[  919.045168] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 248
[  919.045234] sdioh_start: set sd_f2_blocksize 256
[  919.045425]
[  919.045425]
[  919.045425] dhd_bus_devreset: == WLAN ON ==
[  919.045492] F1 signature read @0x18000000=0x17224356
[  919.047980] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[  919.048447] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[  919.048513] dhd_bus_set_default_min_res_mask: Unhandled chip id
[  919.049424] dhd_conf_read_config: Ignore config file /system/etc/firmware/config.txt
[  919.049449] Final fw_path=/system/etc/firmware/fw_bcm4356a2_ag.bin
[  919.049455] Final nv_path=/system/etc/firmware/nvram_ap6356.txt
[  919.049462] Final clm_path=/system/etc/firmware/clm_bcmdhd.blob
[  919.049467] Final conf_path=/system/etc/firmware/config.txt
[  919.049474] dhd_set_bus_params: set use_rxchain 0
[  919.049479] dhd_set_bus_params: set txinrx_thres 128
[  919.049485] dhd_set_bus_params: set txglomsize 36
[  919.050003] dhd_os_open_image: /system/etc/firmware/fw_bcm4356a2_ag.bin (558327 bytes) open success
[  919.136179] dhd_os_open_image: /system/etc/firmware/nvram_ap6356.txt (2840 bytes) open success
[  919.136531] NVRAM version: AP6356S_NVRAM_V1.2_20170331
[  919.136907] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[  919.192440] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[  919.192698] bcmsdh_oob_intr_register HW_OOB irq=73 flags=0x4
[  919.192921] dhd_get_memdump_info: File [/data/misc/wifi/.memdump.info] doesn't exist
[  919.192934] dhd_get_memdump_info: MEMDUMP ENABLED = 2
[  919.193964] Disable tdls_auto_op failed. -1
[  919.193999] dhd_preinit_ioctls: Set tcpack_sup_mode 1
[  919.195279] dhd_apply_default_clm: Ignore clm file /system/etc/firmware/clm_bcmdhd.blob
[  919.197013] Firmware up: op_mode=0x0005, MAC=b0:f1:ec:1a:c0:88
[  919.197031] dhd_conf_set_country: set country CN, revision 38
[  919.233894] dhd_wlfc_enable: ret=0
[  919.233930] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[  919.233947] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[  919.234694] Country code: CN (CN/38)
[  919.235161] dhd_conf_set_intiovar: set roam_off 1
[  919.237569] dhd_conf_set_intiovar: set txbf 1
[  919.238154] dhd_preinit_ioctls Set scancache failed -23
[  919.238374] dhd_conf_set_intiovar: set WLC_SET_FAKEFRAG 219 1
[  919.245424]   Driver: 1.579.77.41.2 (r)
[  919.245424]   Firmware: wl0: Apr 18 2017 13:54:43 version 7.35.184.1.r5 (A2 Station/P2P) FWID 01-efd4ca0d
[  919.245424]   CLM: 7.10.16
[  919.245787] dhd_txglom_enable: enable 1
[  919.245799] dhd_conf_set_txglom_params: txglomsize=36, deferred_tx_len=36, bus_txglom=-1
[  919.245808] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=128, dhd_txminmax=-1
[  919.245816] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=5
[  919.245823] sdioh_set_mode: set txglom_mode to copy
[  919.245837] dhd_conf_get_disable_proptx: fw_proptx=1, disable_proptx=-1
[  919.248370] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
[  919.248616] dhd_conf_set_intiovar: set ampdu_hostreorder 1
[  919.249667] dhd_pno_init: Support Android Location Service
[  919.284320] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[  919.284740] rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1), status=-23
[  919.284762] dhd_rtt_init : FTM is not supported
[  919.284772] dhd_preinit_ioctls: SensorHub diabled 0
[  919.285215] dhd_preinit_ioctls failed to set ShubHub disable
[  919.285667] dhd_ndo_get_version: failed, retcode = -23
[  919.286490] dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed, ERR -23
[  919.286507] failed to get wnm_bsstrans_resp
[  919.287347] failed to set WNM capabilities
[  919.287364] wl_android_wifi_on: Success
[  919.309310] dhd_open: Exit ret=0
[  919.313091] init: Starting service 'p2p_supplicant'...
[  919.489790] P2P interface registered
[  919.489816] wl_cfgp2p_add_p2p_disc_if: wdev: ffffffc0d0268e00, wdev->net:           (null)
[  919.502289] WLC_E_IF: NO_IF set, event Ignored
[  919.503516] P2P interface started
[  920.557664] init: Service 'bootanim' is being killed...
[  920.573799] Random MAC OUI to be used - da:a1:19
[  920.606014] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.606542] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.606988] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.607455] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.607873] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.609006] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.609501] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.609935] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.610409] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.610816] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.610980] init: Service 'bootanim' (pid 361) killed by signal 9
[  920.611195] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.611645] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.612044] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.613315] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.613744] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.614198] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.615581] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.615992] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.616429] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.617434] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.617863] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.618427] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.618864] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.619269] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.619700] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.620085] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.620464] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.620854] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.621244] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.621752] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.622158] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.622549] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.623672] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.624049] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.624417] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.627207] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.627876] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.628352] dhd_dbg_set_event_log_tag set log tag iovar failed -23
[  920.628707] dhd_dbg_attach_pkt_monitor, 1606
[  920.631397] net_os_enable_packet_filter: val = 0
[  920.633007] net_os_rxfilter_add_remove: add_remove = 0, num = 2
[  920.634232] net_os_enable_packet_filter: val = 1
[  920.634781] net_os_enable_packet_filter: val = 0
[  920.635280] net_os_rxfilter_add_remove: add_remove = 0, num = 3
[  920.636471] net_os_enable_packet_filter: val = 1
[  920.652867] dhd_set_suspend: Remove extra suspend setting
[  920.652918] dhd_enable_packet_filter: enter, value = 0
[  921.293069] init: Untracked pid 1321 exited with status 0
[  921.331408] init: Untracked pid 1329 exited with status 0
[  921.836083] init: Untracked pid 1332 exited with status 0
[  921.837243] init: Untracked pid 1324 exited with status 0
[  923.152779] Connecting with 74:7d:24:73:c3:6c ssid "310", len (3) channel=4
[  923.152779]
[  923.152849] dhd_dbg_start_pkt_monitor, 1724
[  923.152859] __dhd_dbg_free_tx_pkts, 1518
[  923.152867] __dhd_dbg_free_rx_pkts, 1536
[  923.243954] wl_iw_event: Link UP with BSSID=74:7d:24:73:c3:6c
[  923.244215] wl_bss_connect_done succeeded with 74:7d:24:73:c3:6c
[  923.334240] wl_bss_connect_done succeeded with 74:7d:24:73:c3:6c vndr_oui: 00-90-4C 00-0C-43
[  923.532343] dhd_dev_apf_get_version: firmware doesn't support APF
[  923.532390] dhd_dev_apf_get_max_len: firmware doesn't support APF
[  923.561882] dhd_ndo_remove_ip_by_type: failed, retcode = -23
[  923.561969] dhd_dev_ndo_cfg: failed to update host ip addr: -23
[  923.561981] CFG80211-ERROR) wl_cfgvendor_configure_nd_offload : dhd_dev_ndo_cfg() failed: -23
[  923.562850] net_os_enable_packet_filter: val = 0
[  923.563693] net_os_rxfilter_add_remove: add_remove = 1, num = 2
[  923.565320] net_os_enable_packet_filter: val = 1
[  923.673700] dhd_set_suspend: Remove extra suspend setting
[  923.673838] dhd_enable_packet_filter: enter, value = 0
[  924.714737] net_os_enable_packet_filter: val = 0
[  924.716246] net_os_rxfilter_add_remove: add_remove = 0, num = 2
[  924.723159] net_os_enable_packet_filter: val = 1
[  927.103498] init: Service 'ipset' (pid 244) exited with status 0
[  927.173587] net_os_enable_packet_filter: val = 0
[  927.174909] net_os_rxfilter_add_remove: add_remove = 1, num = 2
[  927.176326] net_os_enable_packet_filter: val = 1
[  928.371893] dwmmc_rockchip fe310000.dwmmc: All phases bad!
[  928.371933] mmc2: tuning execution failed
[  928.371943] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[  928.373607] dwmmc_rockchip fe310000.dwmmc: All phases bad!
[  928.373619] mmc2: tuning execution failed
[  928.373629] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[  928.668495] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 248
[  934.185643] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
[  977.855423] dwmmc_rockchip fe310000.dwmmc: All phases bad!
[  977.855527] mmc2: tuning execution failed
[  977.855556] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[  977.951939] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 310
试一下官方的固件,如果没有问题,那要检查自己的编译是否有问题,烧写工具版本是否匹配
后续发现这个是强制断电情况下会偶尔出现,执行正常关机后不再出现该问题
firefly-rk3399安卓7.1开源代码编译后在自己研发的板子上跑到一半卡死,自研的板子在CPU系统部分完全拷贝firefly-rk3399.
但是编出来的镜像在开发板上没问题,在自己板上跑不起来的,可用以下共享的镜像来验证下系统的emmc,DDR3,电源设备树
链接: https://pan.baidu.com/s/155miS8z06cBIhjKGxY02PA 提取码: w74q
如果有问题,或者成功了可Q254327173
大地主因 发表于 2019-7-22 11:31
firefly-rk3399安卓7.1开源代码编译后在自己研发的板子上跑到一半卡死,自研的板子在CPU系统部分完全拷贝fi …
请教下这个固件的出处是哪里
z3j6w9 发表于 2019-7-22 13:49
请教下这个固件的出处是哪里
瑞星微官方版本
