Starting build with ninja
ninja: Entering directory `.’
[ 0% 44/48254] Lex: aidl <= system/tools/aidl/aidl_language_l.ll
FAILED: /bin/bash -c “prebuilts/misc/linux-x86/flex/flex-2.5.39 -oout/host/linux-x86/obj/STATIC_LIBRARIES/libaidl-common_intermediates/aidl_language_l.cpp system/tools/aidl/aidl_language_l.ll”
flex-2.5.39: fatal internal error, exec of /usr/bin/m4 failed
[ 0% 44/48254] Yacc: aidl <= system/tools/aidl/aidl_language_y.yy
FAILED: /bin/bash -c “prebuilts/misc/linux-x86/bison/bison -d --defines=out/host/linux-x86/obj/STATIC_LIBRARIES/libaidl-common_intermediates/aidl_language_y.h -o out/host/linux-x86/obj/STATIC_LIBRARIES/libaidl-common_intermediates/aidl_language_y.cpp system/tools/aidl/aidl_language_y.yy”
[ 0% 44/48254] build out/target/common/obj/all-event-log-tags.txt
system/bt/hci/../EventLogTags.logtags:36: warning: tag “bt_hci_timeout” (1010000) duplicated in system/bt/btif/../EventLogTags.logtags:36
system/bt/hci/../EventLogTags.logtags:37: warning: tag “bt_config_source” (1010001) duplicated in system/bt/btif/../EventLogTags.logtags:37
system/bt/hci/../EventLogTags.logtags:38: warning: tag “bt_hci_unknown_type” (1010002) duplicated in system/bt/btif/../EventLogTags.logtags:38
[ 0% 44/48254] target Java: conscrypt (out/target/common/obj/JAVA_LIBRARIES/conscrypt_intermediates/classes)
Note: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
Note: Some input files use unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
[ 0% 44/48254] host Java: doclava (out/host/common/obj/JAVA_LIBRARIES/doclava_intermediates/classes)
ninja: build stopped: subcommand failed.
make: *** [ninja_wrapper] Error 1
单独编译7.1 上层报的错误使用官方提供的命令
cd ~/proj/firefly-rk3399/
./FFTools/make.sh -a -j8
求大神指点
ubuntu14.04 irefly-rk3399
export LC_ALL=C
