ROC-RK3328-CC烧写Debian固件到emmc失败
1.使用官方镜像和官网下载的2.39版本androidtool
ROC-RK3328-CC_Debian9-Arch64_20180525.img
rk3328_loader_ddr786_v1.06.243.bin
2.根据wiki指导,启动按recovery或短接clk、GND进入maskrom模式,烧写镜像
3.烧写完成进入uboot,但无法启动系统,uboot下命令查看
=>mmc list
rksdmmc@ff520000: 0 (eMMC)
rksdmmc@ff500000: 1
=> mmcinfo
Device: rksdmmc@ff520000
Manufacturer ID: 15
OEM: 100
Timing Interface: DDR52
Tran Speed: 52000000
Rd Block Len: 512
MMC version 5.1
High Capacity: Yes
Capacity: 14.6 GiB
Bus Width: 8-bit DDR
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 14.6 GiB WRREL
Boot Capacity: 4 MiB ENH
RPMB Capacity: 4 MiB ENH
=>part list mmc 1
mmc_init: -95, time 10
** Bad device mmc 1 **
没有断电,过几十秒,再执行
=>mmc list
rksdmmc@ff520000: 0
rksdmmc@ff500000: 1
=> mmc info
mmc_init: -110, time 72
4.重启开发板,串口就没有输出了,怀疑emmc没有烧写成功
万用表测量emmc各模块电压正常
示波器测试emmc_clk信号,无波形
是不是这个emmc是坏的
进入maskrom模式烧写的log
DDR version 1.06 20170424
DDR4
786MHz
Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
ddrconfig:14
Boot1 Release Time: 2017-05-18, version: 2.43
SdmmcInit=0 2
 SDC_BusRequest:  CMD=8  SDC_RESP_TIMEOUT 1853
  SDC_BusRequest:  CMD=5  SDC_RESP_TIMEOUT 1853
  SDC_BusRequest:  CMD=55  SDC_RESP_TIMEOUT 1853
 mmc Ext_csd, ret=0 ,
 Ext[226]=20, bootSize=2000,
                Ext[215]=1, Ext[214]=d1, Ext[213]=f0, Ext[212]=0,cap =1d1f000 REL=1f
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=14910MB
FwPartOffset=2000 , 2000
UsbHook 775631
powerOn 775703
SDC ERR: 0x40
SDMMC_CMD=0x20002759, SDMMC_RINISTS=0x90, SDMMC_STATUS=0xcd06
SDC_BusRequest 444-1  ---START_CMD timeout---  ../src/common/emmc/hw_SDController.c  1793
SDM_Write error=480 ret=1000
SDM_Write error=500 ret=1000
SDC_BusRequest:  CMD=25 START CMD ERROR 1680
SDM_Write error=580 ret=1000
SDM_Write error=600 ret=1000
SDM_Write error=680 ret=1000
SDM_Write error=700 ret=1000
是不是卖的emmc是坏的
