我用3288的板子没有mipi信号输出,请帮忙,急!
下面是我的mipi设置:(.config文件)
# CONFIG_DUAL_LCDC_DUAL_DISP_IN_KERNEL is not set
# CONFIG_ONE_LCDC_DUAL_OUTPUT_INF is not set
CONFIG_NO_DUAL_DISP=y
# CONFIG_FB_ROTATE is not set
CONFIG_THREE_FB_BUFFER=y
# CONFIG_LCDC_RK3188 is not set
CONFIG_LCDC_RK3288=y
# CONFIG_LCDC_RK3036 is not set
# CONFIG_LCDC_RK312X is not set
# CONFIG_LCD_GENERAL is not set
CONFIG_LCD_MIPI=y
CONFIG_RK_TRSM=y
# CONFIG_RK32_LVDS is not set
# CONFIG_RK31XX_LVDS is not set
# CONFIG_DP_ANX6345 is not set
# CONFIG_DP501 is not set
# CONFIG_RK32_DP is not set
CONFIG_RK_VGA=y
CONFIG_MIPI_DSI=y
# CONFIG_TC358768_RGB2MIPI is not set
# CONFIG_SSD2828_RGB2MIPI is not set
CONFIG_RK32_MIPI_DSI=y
CONFIG_RK_HDMI=y
# CONFIG_HDMI_CAT66121 is not set
CONFIG_HDMI_RK3036=y
# CONFIG_HDCP_RK3036 is not set
# CONFIG_CEC_RK3036 is not set
CONFIG_HDMI_SOURCE_LCDC0=y
下面是mipi的dtsi文件设置:
/* about mipi */
disp_mipi_init: mipi_dsi_init{
compatible = “rockchip,mipi_dsi_init”;
rockchip,screen_init = <1>;
rockchip,dsi_lane = <4>;
rockchip,dsi_hs_clk = <500>;
rockchip,mipi_dsi_num = <1>;
disp_mipi_power_ctr: mipi_power_ctr {
compatible = “rockchip,mipi_power_ctr”;
mipi_lcd_rst:mipi_lcd_rst{
compatible = “rockchip,lcd_rst”;
rockchip,gpios = <&gpio7 GPIO_A4 GPIO_ACTIVE_LOW>;//default:GPIO_ACTIVE_HIGH
rockchip,delay = <10>;
mipi_lcd_en:mipi_lcd_en {
compatible = “rockchip,lcd_en”;
rockchip,gpios = <&gpio7 GPIO_A3 GPIO_ACTIVE_HIGH>;
/*lcd_cs:lcd_cs {
rockchip,power_type = <GPIO>;
gpios = <&gpio7 GPIO_A4 GPIO_ACTIVE_HIGH>;
disp_mipi_init_cmds: screen-on-cmds {
rockchip,cmd_debug = <0>;
compatible = "rockchip,screen-on-cmds";
rockchip,on-cmds1 {
compatible = "rockchip,on-cmds";//Page0
rockchip,cmd_type = <LPDT>;
rockchip,dsi_id = <0>;
rockchip,cmd = <0x15 0xE0 0x00>;
rockchip,cmd_delay = <10>;
rockchip,on-cmds2 {
rockchip,cmd = <0x15 0xE1 0x93>; //PASSWORD
rockchip,on-cmds3 {
rockchip,cmd = <0x15 0xE2 0x65>; //PASSWORD
rockchip,cmd_delay = <0>;
rockchip,on-cmds4 {
rockchip,cmd = <0x15 0xE3 0xF8>; //PASSWORD
rockchip,on-cmds5 {
rockchip,cmd = <0x15 0xE0 0x00>; //Page0
rockchip,on-cmds6 {
rockchip,cmd = <0x15 0x70 0x02>; //Sequence Ctrl,DC0,DC1
rockchip,on-cmds7 {
rockchip,cmd = <0x15 0x71 0x23 >; //Sequence Ctrl,DC2,DC3
rockchip,on-cmds8 {
rockchip,cmd = <0x15 0x72 0x06 >; // //Sequence Ctrl,DC7
rockchip,on-cmds9 {
rockchip,cmd = <0x15 0xE0 0x01 >; //Page1
rockchip,on-cmds10 {
rockchip,cmd = <0x15 0x00 0x00 >; //Set VCOM
rockchip,on-cmds11 {
rockchip,cmd = <0x15 0x01 0xA0 >; //Set VCOM
rockchip,on-cmds12 {
rockchip,cmd = <0x15 0x03 0x00>; //Set VCOM_Reverse
rockchip,on-cmds13 {
rockchip,cmd = <0x15 0x04 0xA0>; //Set VCOM_Reverse
rockchip,cmd_delay = <120>;
rockchip,on-cmds14 {
rockchip,cmd = <0x15 0x17 0x00>; //Set Gamma Power,VGMP,VGMN,VGSP,VGSN
rockchip,on-cmds15 {
rockchip,cmd = <0x15 0x18 0xB1>; //Set Gamma Power,VGMP,VGMN,VGSP,VGSN
rockchip,on-cmds16 {
rockchip,cmd = <0x15 0x19 0x00 >; //Set Gamma Power,VGMP,VGMN,VGSP,VGSN
rockchip,on-cmds17 {
rockchip,cmd = <0x15 0x1A 0x00 >; //Set Gamma Power,VGMP,VGMN,VGSP,VGSN
rockchip,on-cmds18 {
rockchip,cmd = <0x15 0x1B 0xB1 >; //Set Gamma Power,VGMP,VGMN,VGSP,VGSN
rockchip,on-cmds19 {
rockchip,cmd = <0x15 0x1C 0x00>; //Set Gamma Power,VGMP,VGMN,VGSP,VGSN
rockchip,on-cmds20 {
rockchip,cmd = <0x15 0x1F 0x48>; //Set Gate Power
rockchip,on-cmds21 {
rockchip,cmd = <0x15 0x20 0x23>; //Set Gate Power
rockchip,on-cmds22 {
rockchip,cmd = <0x15 0x21 0x23>; //Set Gate Power
rockchip,on-cmds23 {
rockchip,cmd = <0x15 0x22 0x0E>; //Set Gate Power
rockchip,on-cmds24 {
rockchip,cmd = <0x15 0x23 0x00>; //Set Gate Power
rockchip,on-cmds25 {
rockchip,cmd = <0x15 0x24 0x38>; //Set Gate Power
rockchip,on-cmds26 {
rockchip,cmd = <0x15 0x26 0xD3>; //Set Gate Power
rockchip,on-cmds27 {
rockchip,cmd = <0x15 0x37 0x59>; //SETPANEL
rockchip,on-cmds28 {
rockchip,cmd = <0x15 0x38 0x15>; //SET RGBCYC
rockchip,on-cmds29 {
rockchip,cmd = <0x15 0x15 0x08>; //SET RGBCYC
rockchip,on-cmds30 {
rockchip,cmd = <0x15 0x3A 0x12>; //SET RGBCYC
rockchip,on-cmds31 {
rockchip,cmd = <0x15 0x3C 0x78>; //SET RGBCYC
rockchip,on-cmds32 {
rockchip,cmd = <0x15 0x3E 0x80>; //SET RGBCYC
rockchip,on-cmds33 {
rockchip,cmd = <0x15 0x3F 0x80>; //SET RGBCYC
rockchip,on-cmds34 {
rockchip,cmd = <0x15 0x40 0x06>; //Set TCON
rockchip,on-cmds35 {
rockchip,cmd = <0x15 0x41 0xA0>; //Set TCON
rockchip,on-cmds36 {
rockchip,cmd = <0x15 0x4A 0x35>; //BIST
rockchip,on-cmds37 {
rockchip,cmd = <0x15 0x55 0x0F>; //power voltage
rockchip,on-cmds38 {
rockchip,cmd = <0x15 0x56 0x01>; //power voltage
rockchip,on-cmds39 {
rockchip,cmd = <0x15 0x57 0x85>; //power voltage
rockchip,on-cmds40 {
rockchip,cmd = <0x15 0x58 0x0A>; //power voltage
rockchip,on-cmds41 {
rockchip,cmd = <0x15 0x59 0x0A>; //power voltage
rockchip,on-cmds42 {
rockchip,cmd = <0x15 0x5A 0x32>; //power voltage
rockchip,on-cmds43 {
rockchip,cmd = <0x15 0x5B 0x0F>; //power voltage
rockchip,on-cmds44 {
rockchip,cmd = <0x15 0x5D 0x7C>; //Gamma
rockchip,on-cmds45 {
rockchip,cmd = <0x15 0x5E 0x62>; //Gamma
rockchip,on-cmds46 {
rockchip,cmd = <0x15 0x5F 0x50>; //Gamma
rockchip,on-cmds47 {
rockchip,cmd = <0x15 0x60 0x42>; //Gamma
rockchip,on-cmds48 {
rockchip,cmd = <0x15 0x61 0x3D>; //Gamma
rockchip,on-cmds49 {
rockchip,cmd = <0x15 0x62 0x2D>; //Gamma
rockchip,on-cmds50 {
rockchip,cmd = <0x15 0x63 0x30>; //Gamma
rockchip,on-cmds51 {
rockchip,cmd = <0x15 0x64 0x19>; //Gamma
rockchip,on-cmds52 {
rockchip,cmd = <0x15 0x65 0x30>; //Gamma
rockchip,on-cmds53 {
rockchip,cmd = <0x15 0x66 0x2E>; //Gamma
rockchip,on-cmds54 {
rockchip,cmd = <0x15 0x67 0x2D>; //Gamma
rockchip,on-cmds55 {
rockchip,cmd = <0x15 0x68 0x4A>; //Gamma
rockchip,on-cmds56 {
rockchip,cmd = <0x15 0x69 0x3A>; //Gamma
rockchip,on-cmds57 {
rockchip,cmd = <0x15 0x6A 0x43>; //Gamma
rockchip,on-cmds58 {
rockchip,cmd = <0x15 0x6B 0x37>; //Gamma
rockchip,on-cmds59 {
rockchip,cmd = <0x15 0x6C 0x37>; //Gamma
rockchip,on-cmds60 {
rockchip,cmd = <0x15 0x6D 0x2D>; //Gamma
rockchip,on-cmds61 {
rockchip,cmd = <0x15 0x6E 0x1F>; //Gamma
rockchip,on-cmds62 {
rockchip,cmd = <0x15 0x6F 0x00>; //Gamma
rockchip,on-cmds63 {
rockchip,cmd = <0x15 0x70 0x7C>; //Gamma
rockchip,on-cmds64 {
rockchip,cmd = <0x15 0x71 0x62>; //Gamma
rockchip,on-cmds65 {
rockchip,cmd = <0x15 0x72 0x50>; //Gamma
rockchip,on-cmds66 {
rockchip,cmd = <0x15 0x73 0x42>; //Gamma
rockchip,on-cmds67 {
rockchip,cmd = <0x15 0x74 0x3D>; //Gamma
rockchip,on-cmds68 {
rockchip,cmd = <0x15 0x75 0x2D>; //Gamma
rockchip,on-cmds69 {
rockchip,cmd = <0x15 0x76 0x30>; //Gamma
rockchip,on-cmds70 {
rockchip,cmd = <0x15 0x77 0x19>; //Gamma
rockchip,on-cmds71 {
rockchip,cmd = <0x15 0x78 0x30>; //Gamma
rockchip,on-cmds72 {
rockchip,cmd = <0x15 0x79 0x2E>; //Gamma
rockchip,on-cmds73 {
rockchip,cmd = <0x15 0x7A 0x2D>; //Gamma
rockchip,on-cmds74 {
rockchip,cmd = <0x15 0x7B 0x4A>; //Gamma
rockchip,on-cmds75 {
rockchip,cmd = <0x15 0x7C 0x3A>; //Gamma
rockchip,on-cmds76 {
rockchip,cmd = <0x15 0x7D 0x43>; //Gamma
rockchip,on-cmds77 {
rockchip,cmd = <0x15 0x7E 0x37>; //Gamma
rockchip,on-cmds78 {
rockchip,cmd = <0x15 0x7F 0x37>; //Gamma
rockchip,on-cmds79 {
rockchip,cmd = <0x15 0x80 0x2D>; //Gamma
rockchip,on-cmds80 {
rockchip,cmd = <0x15 0x81 0x1F>; //Gamma
rockchip,on-cmds81 {
rockchip,cmd = <0x15 0x82 0x00>; //Gamma
rockchip,on-cmds82 {
compatible = "rockchip,on-cmds"; //Page2,for GIP
rockchip,cmd = <0x15 0xE0 0x02>;
rockchip,on-cmds83 {
compatible = "rockchip,on-cmds"; //GIP_L Pin mapping
rockchip,cmd = <0x15 0x00 0x1F>;
rockchip,on-cmds84 {
rockchip,cmd = <0x15 0x01 0x1F>;
rockchip,on-cmds85 {
rockchip,cmd = <0x15 0x02 0x13>;
rockchip,on-cmds86 {
rockchip,cmd = <0x15 0x03 0x11>;
rockchip,on-cmds87 {
rockchip,cmd = <0x15 0x04 0x0B>;
rockchip,on-cmds88 {
rockchip,cmd = <0x15 0x15 0x0B>;
rockchip,on-cmds89 {
rockchip,cmd = <0x15 0x06 0x09>;
rockchip,on-cmds90 {
rockchip,cmd = <0x15 0x07 0x09>;
rockchip,on-cmds91 {
rockchip,cmd = <0x15 0x08 0x07>;
rockchip,on-cmds92 {
rockchip,cmd = <0x15 0x09 0x1F>;
rockchip,on-cmds93 {
rockchip,cmd = <0x15 0x0A 0x1F>;
rockchip,on-cmds94 {
rockchip,cmd = <0x15 0x0B 0x1F>;
rockchip,on-cmds95 {
rockchip,cmd = <0x15 0x0C 0x1F>;
rockchip,on-cmds96 {
rockchip,cmd = <0x15 0x0D 0x1F>;
rockchip,on-cmds97 {
rockchip,cmd = <0x15 0x0E 0x1F>;
rockchip,on-cmds98 {
rockchip,cmd = <0x15 0x0F 0x07>;
rockchip,on-cmds99 {
rockchip,cmd = <0x15 0x10 0x15>;
rockchip,on-cmds100 {
rockchip,cmd = <0x15 0x11 0x15>;
rockchip,on-cmds101 {
rockchip,cmd = <0x15 0x12 0x01>;
rockchip,on-cmds102 {
rockchip,cmd = <0x15 0x13 0x03>;
rockchip,on-cmds103 {
rockchip,cmd = <0x15 0x14 0x1F>;
rockchip,on-cmds104 {
rockchip,cmd = <0x15 0x15 0x1F>;
rockchip,on-cmds105 {
compatible = "rockchip,on-cmds"; //GIP_R Pin mapping
rockchip,cmd = <0x15 0x16 0x1F>;
rockchip,on-cmds106 {
rockchip,cmd = <0x15 0x17 0x1F>;
rockchip,on-cmds107 {
rockchip,cmd = <0x15 0x18 0x12>;
rockchip,on-cmds108 {
rockchip,cmd = <0x15 0x19 0x10>;
rockchip,on-cmds109 {
rockchip,cmd = <0x15 0x1A 0x0A>;
rockchip,on-cmds110 {
rockchip,cmd = <0x15 0x1B 0x0A>;
rockchip,on-cmds111 {
rockchip,cmd = <0x15 0x1C 0x08>;
rockchip,on-cmds112 {
rockchip,cmd = <0x15 0x1D 0x08>;
rockchip,on-cmds113 {
rockchip,cmd = <0x15 0x1E 0x06>;
rockchip,on-cmds114 {
rockchip,cmd = <0x15 0x1F 0x1F>;
rockchip,on-cmds115 {
rockchip,cmd = <0x15 0x20 0x1F>;
rockchip,on-cmds116 {
rockchip,cmd = <0x15 0x21 0x1F>;
rockchip,on-cmds117 {
rockchip,cmd = <0x15 0x22 0x1F>;
rockchip,on-cmds118 {
rockchip,cmd = <0x15 0x23 0x1F>;
rockchip,on-cmds119 {
rockchip,cmd = <0x15 0x24 0x1F>;
rockchip,on-cmds120 {
rockchip,cmd = <0x15 0x25 0x06>;
rockchip,on-cmds121 {
rockchip,cmd = <0x15 0x26 0x04>;
rockchip,on-cmds122 {
rockchip,cmd = <0x15 0x27 0x04>;
rockchip,on-cmds123 {
rockchip,cmd = <0x15 0x28 0x00>;
rockchip,on-cmds124 {
rockchip,cmd = <0x15 0x29 0x02>;
rockchip,on-cmds125 {
rockchip,cmd = <0x15 0x2A 0x1F>;
rockchip,on-cmds126 {
rockchip,cmd = <0x15 0x2B 0x1F>;
rockchip,on-cmds127 {
compatible = "rockchip,on-cmds"; //GIP_L_GS Pin mapping
rockchip,cmd = <0x15 0x2C 0x1F>;
rockchip,on-cmds128 {
rockchip,cmd = <0x15 0x2D 0x1F>;
rockchip,on-cmds129 {
rockchip,cmd = <0x15 0x2E 0x00>;
rockchip,on-cmds130 {
rockchip,cmd = <0x15 0x2F 0x02>;
rockchip,on-cmds131 {
rockchip,cmd = <0x15 0x30 0x08>;
rockchip,on-cmds132 {
rockchip,cmd = <0x15 0x31 0x08>;
rockchip,on-cmds133 {
rockchip,cmd = <0x15 0x32 0x0A>;
rockchip,on-cmds134 {
rockchip,cmd = <0x15 0x33 0x0A>;
rockchip,on-cmds135 {
rockchip,cmd = <0x15 0x34 0x04>;
rockchip,on-cmds136 {
rockchip,cmd = <0x15 0x35 0x1F>;
rockchip,on-cmds137 {
rockchip,cmd = <0x15 0x36 0x1F>;
rockchip,on-cmds138 {
rockchip,cmd = <0x15 0x37 0x1F>;
rockchip,on-cmds139 {
rockchip,cmd = <0x15 0x38 0x1F>;
rockchip,on-cmds140 {
rockchip,on-cmds141 {
rockchip,cmd = <0x15 0x3A 0x1F>;
rockchip,on-cmds142 {
rockchip,cmd = <0x15 0x3B 0x04>;
rockchip,on-cmds143 {
rockchip,cmd = <0x15 0x3C 0x06>;
rockchip,on-cmds144 {
rockchip,cmd = <0x15 0x3D 0x06>;
rockchip,on-cmds145 {
rockchip,cmd = <0x15 0x3E 0x12>;
rockchip,on-cmds146 {
rockchip,cmd = <0x15 0x3F 0x10>;
rockchip,on-cmds147 {
rockchip,cmd = <0x15 0x40 0x1F>;
rockchip,on-cmds148 {
rockchip,cmd = <0x15 0x41 0x1F>;
rockchip,on-cmds149 {
compatible = "rockchip,on-cmds"; //GIP_R_GS Pin mapping
rockchip,cmd = <0x15 0x42 0x1F>;
rockchip,on-cmds150 {
rockchip,cmd = <0x15 0x43 0x1F>;
rockchip,on-cmds151 {
rockchip,cmd = <0x15 0x44 0x01>;
rockchip,on-cmds152 {
rockchip,cmd = <0x15 0x45 0x03>;
rockchip,on-cmds153 {
rockchip,cmd = <0x15 0x46 0x09>;
rockchip,on-cmds154 {
rockchip,cmd = <0x15 0x47 0x09>;
rockchip,on-cmds155 {
rockchip,cmd = <0x15 0x48 0x0B>;
rockchip,on-cmds156 {
rockchip,cmd = <0x15 0x49 0x0B>;
rockchip,on-cmds157 {
rockchip,cmd = <0x15 0x4A 0x15>;
rockchip,on-cmds158 {
rockchip,cmd = <0x15 0x4B 0x1F>;
rockchip,on-cmds159 {
rockchip,cmd = <0x15 0x4C 0x1F>;
rockchip,on-cmds160 {
rockchip,cmd = <0x15 0x4D 0x1F>;
rockchip,on-cmds161 {
rockchip,cmd = <0x15 0x4E 0x1F>;
rockchip,on-cmds162 {
rockchip,cmd = <0x15 0x4F 0x1F>;
rockchip,on-cmds163 {
rockchip,cmd = <0x15 0x50 0x1F>;
rockchip,on-cmds164 {
rockchip,cmd = <0x15 0x51 0x15>;
rockchip,on-cmds165 {
rockchip,cmd = <0x15 0x52 0x07>;
rockchip,on-cmds166 {
compatible = "rockchip,on-cmds";//GIP_R_GS Pin mapping
rockchip,cmd = <0x15 0x53 0x07>;
rockchip,on-cmds167 {
rockchip,cmd = <0x15 0x54 0x13>;
rockchip,on-cmds168 {
rockchip,cmd = <0x15 0x55 0x11>;
rockchip,on-cmds169 {
rockchip,cmd = <0x15 0x56 0x1F>;
rockchip,on-cmds170 {
rockchip,cmd = <0x15 0x57 0x1F>;
rockchip,on-cmds171 {
compatible = "rockchip,on-cmds";//GIP Timing
rockchip,cmd = <0x15 0x58 0x40>;
rockchip,on-cmds172 {
rockchip,cmd = <0x15 0x59 0x00>;
rockchip,on-cmds173 {
rockchip,cmd = <0x15 0x5A 0x00>;
rockchip,on-cmds174 {
rockchip,cmd = <0x15 0x5B 0x30>;
rockchip,on-cmds175 {
rockchip,cmd = <0x15 0x5C 0x02>;
rockchip,on-cmds176 {
rockchip,cmd = <0x15 0x5D 0x30>;
rockchip,on-cmds177 {
rockchip,cmd = <0x15 0x5E 0x01>;
rockchip,on-cmds178 {
rockchip,cmd = <0x15 0x5F 0x02>;
rockchip,on-cmds179 {
rockchip,cmd = <0x15 0x60 0x30>;
rockchip,on-cmds180 {
rockchip,cmd = <0x15 0x61 0x01>;
rockchip,on-cmds181 {
rockchip,cmd = <0x15 0x62 0x02>;
rockchip,on-cmds182 {
rockchip,cmd = <0x15 0x63 0x03>;
rockchip,on-cmds183 {
rockchip,cmd = <0x15 0x64 0x6B>;
rockchip,on-cmds184 {
rockchip,cmd = <0x15 0x65 0x75>;
rockchip,on-cmds185 {
rockchip,cmd = <0x15 0x66 0x08>;
rockchip,on-cmds186 {
rockchip,cmd = <0x15 0x67 0x73>;
rockchip,on-cmds187 {
rockchip,cmd = <0x15 0x68 0x02>;
rockchip,on-cmds188 {
rockchip,cmd = <0x15 0x69 0x03>;
rockchip,on-cmds189 {
rockchip,cmd = <0x15 0x6A 0x6B>;
rockchip,on-cmds190 {
rockchip,cmd = <0x15 0x6B 0x07>;
rockchip,on-cmds191 {
rockchip,cmd = <0x15 0x6C 0x00>;
rockchip,on-cmds192 {
rockchip,cmd = <0x15 0x6D 0x04>;
rockchip,on-cmds193 {
rockchip,cmd = <0x15 0x6E 0x04>;
rockchip,on-cmds194 {
rockchip,cmd = <0x15 0x6F 0x88>;
rockchip,on-cmds195 {
rockchip,cmd = <0x15 0x70 0x00>;
rockchip,on-cmds196 {
rockchip,cmd = <0x15 0x71 0x00>;
rockchip,on-cmds197 {
rockchip,cmd = <0x15 0x72 0x06>;
rockchip,on-cmds198 {
rockchip,cmd = <0x15 0x73 0x7B>;
rockchip,on-cmds199 {
rockchip,cmd = <0x15 0x74 0x00>;
rockchip,on-cmds200 {
rockchip,cmd = <0x15 0x75 0x3C>;
rockchip,on-cmds201 {
rockchip,cmd = <0x15 0x76 0x00>;
rockchip,on-cmds202 {
rockchip,cmd = <0x15 0x77 0x0D>;
rockchip,on-cmds203 {
rockchip,cmd = <0x15 0x78 0x2C>;
rockchip,on-cmds204 {
rockchip,cmd = <0x15 0x79 0x00>;
rockchip,on-cmds205 {
rockchip,cmd = <0x15 0x7A 0x00>;
rockchip,on-cmds206 {
rockchip,cmd = <0x15 0x7B 0x00>;
rockchip,on-cmds207 {
rockchip,cmd = <0x15 0x7C 0x00>;
rockchip,on-cmds208 {
rockchip,cmd = <0x15 0x7D 0x03>;
rockchip,on-cmds209 {
rockchip,cmd = <0x15 0x7E 0x7B>;
rockchip,on-cmds210 {
compatible = "rockchip,on-cmds";//Page1
rockchip,cmd = <0x15 0xE0 0x01>;
rockchip,on-cmds211 {
rockchip,cmd = <0x15 0x0E 0x01>;
rockchip,on-cmds212 {
compatible = "rockchip,on-cmds";//Page3
rockchip,cmd = <0x15 0xE0 0x03>;
rockchip,on-cmds213 {
rockchip,cmd = <0x15 0x98 0x2F>;
rockchip,on-cmds214 {
rockchip,on-cmds215 {
compatible = "rockchip,on-cmds";//SLP OUT
rockchip,cmd = <0x05 0x11>;
rockchip,on-cmds216 {
compatible = "rockchip,on-cmds";//DISP ON
rockchip,cmd = <0x05 0x29>;
rockchip,cmd_delay = <5>;
rockchip,on-cmds217 {
compatible = "rockchip,on-cmds";//TE
rockchip,cmd = <0x15 0x35 0x00>;
native-mode = <&timing0>;
compatible = "rockchip,display-timings";
timing0: timing0 {
screen-type = <SCREEN_MIPI>;
lvds-format = <LVDS_8BIT_2>;
out-face = <OUT_P888>;
clock-frequency = <40000000>;
hactive = <800>;
vactive = <1280>;
hsync-len = <18>;//19
hback-porch = <40>;//40
hfront-porch = <12>;//123
vsync-len = <4>;
vback-porch = <44>;
vfront-porch = <12>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <0>;
pixelclk-active = <0>;
swap-rb = <0>;
swap-rg = <0>;
swap-gb = <0>;
下面是RK3288_DTSI文件设置:
dsihost0: mipi@ff960000{
compatible = “rockchip,rk32-dsi”;
rockchip,prop = <0>;
reg = <0xff960000 0x4000>;
interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_gates5 15>, <&clk_gates16 4> , <&pd_mipidsi>;
clock-names = “clk_mipi_24m”, “pclk_mipi_dsi”, “pd_mipi_dsi”;
status = “okay”;//default:disabled
dsihost1: mipi@ff964000{
compatible = "rockchip,rk32-dsi";
rockchip,prop = <1>;
reg = <0xff964000 0x4000>;
interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_gates5 15>, <&clk_gates16 5>, <&pd_mipidsi>;
clock-names = "clk_mipi_24m", "pclk_mipi_dsi", "pd_mipi_dsi";
status = "disabled";
下面是串口输出信息:
DDR Version 1.00 20140404
Channel a: DDR3 300MHz
Channel b: DDR3 300MHz
Memory OK
Memory OK
U-Boot 2014.01-00643-g77f8e4c-dirty (Apr 21 2014 - 15:36:44)
CPU: RK32xx
arm pll: 1008000000
general pll: 594000000
codec pll: 594000000
ddr pll: 300000000
new pll: 24000000
Board: RK32xx platform Board
DRAM: 128 MiB
arch_interrupt_init
storage init OK!
In: serial
Out: serial
Err: serial
In: serial
Out: serial
Err: serial
board_late_init
PowerKeyInit start
PowerKeyInit end
charger_init, charger_type = 1, dc_is_charging= 0
pmic_charger_setting charger_type = 1
i2c_set_bus_num: I2C bus = 0
rk_i2c_init: I2C bus = 0
i2c->regs_addr = ff650000,set clk(I2C_CLKDIV: 0x003f003f)
pmic_charger_setting charge ic id = 0xff
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
partition(uboot): offset=0x00002000, size=0x00002000
partition(misc): offset=0x00004000, size=0x00002000
partition(resource): offset=0x00006000, size=0x00008000
partition(kernel): offset=0x0000E000, size=0x00008000
partition(boot): offset=0x00016000, size=0x00010000
partition(recovery): offset=0x00026000, size=0x00010000
partition(backup): offset=0x00036000, size=0x0001A000
partition(cache): offset=0x00050000, size=0x00040000
partition(kpanic): offset=0x00090000, size=0x00002000
partition(system): offset=0x00092000, size=0x00180000
partition(metadata): offset=0x00212000, size=0x00002000
partition(userdata): offset=0x00214000, size=0x00200000
partition(linuxroot): offset=0x00414000, size=0x00620000
partition(user): offset=0x00A34000, size=0xFFFFFFFF
sn:100611000000002F
checkKey
vbus = 1
Loaded dtb file:rk-kernel.dtb,load_addr = 0x54df4b8 size:137442
node:87736 read logo_on switch from dts [0]
rkclk_soft_reset
fix ramdisk_addr:05bf0000
fix kernel_addr:02000000
SecureBootCheckOK:0
rk_bootm_start
booti: do_bootm_linux…
Loading Ramdisk to 052ec000, end 0540efc1 … OK
Loading Device Tree to 052c7000, end 052eb8e1 … OK
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (root@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #18 SMP PREEMPT Mon May 4 17:56:42 CST 2015 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(cma): base(40000000) size(28000000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 640 MiB at 40000000 [ 0.000000] ion_reserve: cma reserved base 40000000 size 671088640 [ 0.000000] cma: CMA: reserved 16 MiB at 1f000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1de1000 s14016 r8192 d14656 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264 [ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00620000@0x00414000(linuxroot),-@0x00a34000(user) androidboot.bootloader=fastboot androidboot.serialno=100611000000002F vmalloc=496M [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1388828k/1388828k available, 708324k reserved, 917504K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0adcfbc (11092 kB) [ 0.000000] .init : 0xc0add000 - 0xc0b716c0 ( 594 kB) [ 0.000000] .data : 0xc0b72000 - 0xc0c793b8 (1053 kB) [ 0.000000] .bss : 0xc0c793b8 - 0xc0d979c4 (1146 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000 [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 31 [ 0.000000] rk3288 set GPLL BW 20 for HDMI! [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 0 [ 0.000000] channel:0, lkg:28 [ 0.000000] target-temp:80 [ 0.000000] channel:2, lkg:0 [ 0.000000] target-temp:80 [ 0.000000] channel:0, lkg:28 [ 0.000000] target-temp:80 [ 0.000000] channel:1, lkg:22 [ 0.000000] target-temp:80 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.229518] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.229533] pid_max: default: 32768 minimum: 301 [ 0.229631] Security Framework initialized [ 0.229646] SELinux: Initializing. [ 0.229713] Mount-cache hash table entries: 512 [ 0.230316] Initializing cgroup subsys debug [ 0.230329] Initializing cgroup subsys memory [ 0.230353] Initializing cgroup subsys freezer [ 0.230381] CPU: Testing write buffer coherency: ok [ 0.230645] /cpus/cpu@0 missing clock-frequency property [ 0.230658] /cpus/cpu@1 missing clock-frequency property [ 0.230667] /cpus/cpu@2 missing clock-frequency property [ 0.230676] /cpus/cpu@3 missing clock-frequency property [ 0.230746] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.230788] Setting up static identity map for 0xc07cfcd0 - 0xc07cfd28 [ 0.232947] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x16d4 (version 3.0) [ 0.307131] CPU1: Booted secondary processor [ 0.307160] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.326819] CPU2: Booted secondary processor [ 0.326841] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.346531] CPU3: Booted secondary processor [ 0.346554] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.346654] Brought up 4 CPUs [ 0.346681] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.346690] CPU: All CPU(s) started in SVC mode. [ 0.347364] devtmpfs: initialized [ 0.352387] pinctrl core: initialized pinctrl subsystem [ 0.352616] regulator-dummy: no parameters [ 0.362623] NET: Registered protocol family 16 [ 0.364349] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.364605] ion_snapshot: 0x1e9b0000 map to 0xe0907000 and copy to 0xc0d72fc4 (version 0.1) [ 0.364837] Registered FIQ tty driver [ 0.366069] console [ttyFIQ0] enabled [ 0.366264] Registered fiq debugger ttyFIQ0 [ 0.366893] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 0.366916] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f [ 0.366936] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f [ 0.366955] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b [ 0.367042] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff [ 0.367109] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff [ 0.367172] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff [ 0.367235] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff [ 0.367299] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff [ 0.367363] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff [ 0.367431] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff [ 0.367497] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff [ 0.367567] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff [ 0.367633] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 0.367649] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 0.367663] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 0.367677] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 0.368183] rockchip_interrupts_register:bank_num=7 [ 0.370056] rockchip_pinctrl_probe:init ok [ 0.376041] rk_iommu ff900800.iep_mmu: (iep) Enter [ 0.376114] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.376130] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 0.376296] rk_iommu ff950800.vip_mmu: (vip) Enter [ 0.376359] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.376374] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 0.376531] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 0.376593] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.376608] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 0.376768] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 0.376831] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.376846] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 0.377009] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 0.377073] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.377088] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 0.377267] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 0.377329] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.377345] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 0.377510] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 0.377571] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.377586] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 0.379414] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.379430] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.379627] DDR DEBUG: version 1.00 20140603 [ 0.379656] DDR DEBUG: Channel a: [ 0.379666] DDR DEBUG: DDR3 Device [ 0.379681] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.379693] DDR DEBUG: Channel b: [ 0.379702] DDR DEBUG: DDR3 Device [ 0.379715] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.379728] DDR DEBUG: addr=0xc81000 [ 0.379739] DDR DEBUG: stride=9, size=256, halfcap=40000000 [ 0.379750] DDR DEBUG: socAddr[0]=0xc81000, socAddr[1]=0xc81100 [ 0.379761] DDR DEBUG: chAddr[0]=0xc81000, chAddr[1]=0xc81000 [ 0.379775] DDR DEBUG: dtar[0]=0x10190000, dtar[1]=0x10190000 [ 0.379829] DDR DEBUG: init success!!! freq=300MHz [ 0.379838] DDR DEBUG: Channel a: [ 0.379852] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=3,0, DGSL=1,0 extra clock, DGPS=90,270 [ 0.379869] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=3,0, DGSL=1,0 extra clock, DGPS=90,270 [ 0.379885] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=0,0 extra clock, DGPS=360,270 [ 0.379901] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=0,0 extra clock, DGPS=360,270 [ 0.379916] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.379928] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.379939] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.379949] DDR DEBUG: Channel b: [ 0.379961] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=0,0 extra clock, DGPS=360,270 [ 0.379977] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=0,0 extra clock, DGPS=360,270 [ 0.379993] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=0,0 extra clock, DGPS=360,270 [ 0.380010] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=0,0 extra clock, DGPS=360,270 [ 0.380025] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.380036] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.380047] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.402363] bio: create slab at 0 [ 0.403229] SCSI subsystem initialized [ 0.403376] usbcore: registered new interface driver usbfs [ 0.403422] usbcore: registered new interface driver hub [ 0.403503] usbcore: registered new device driver usb [ 0.404881] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 0.407125] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 0.408643] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 0.409605] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter [ 0.409853] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter [ 0.410356] media: Linux media interface: v0.10 [ 0.410399] Linux video capture interface: v2.00 [ 0.410446] pps_core: LinuxPPS API ver. 1 registered [ 0.410458] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.410481] PTP clock support registered [ 0.410961] Rockchip ion module is successfully loaded (v1.0) [ 0.411125] Advanced Linux Sound Architecture Driver Initialized. [ 0.411500] Bluetooth: Core ver 2.16 [ 0.411538] NET: Registered protocol family 31 [ 0.411550] Bluetooth: HCI device and connection manager initialized [ 0.411568] Bluetooth: HCI socket layer initialized [ 0.411583] Bluetooth: L2CAP socket layer initialized [ 0.411610] Bluetooth: SCO socket layer initialized [ 0.411842] cfg80211: Calling CRDA to update world regulatory domain [ 0.413651] act8846_i2c_probe,line=898 [ 0.414640] act8846_parse_dt,line=746 [ 0.415860] act8846_i2c_probe: act8846_pmic_hold=1 [ 0.415883] act8846_i2c_probe: act8846_pmic_sleep=1 [ 0.415900] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1 [ 0.415917] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1 [ 0.417780] act_dcdc1: 1200 mV [ 0.420503] vccio: 3300 mV [ 0.422371] vdd_logic: 700 <--> 1500 mV at 1100 mV [ 0.425091] act_dcdc4: 2000 mV [ 0.426346] vccio_sd: 1800 <--> 3300 mV at 3300 mV [ 0.428417] act_ldo2: 1000 mV [ 0.430513] act_ldo3: 3300 mV [ 0.432576] act_ldo4: 3300 mV [ 0.434636] act_ldo5: 3300 mV [ 0.436725] act_ldo6: 1000 mV [ 0.438812] vcc_18: 1800 mV [ 0.440889] act_ldo8: 1800 mV [ 0.445706] vdd_arm: 712 <--> 1500 mV at 1000 mV [ 0.450448] vdd_gpu: 712 <--> 1500 mV at 1000 mV [ 0.451326] Switching to clocksource arch_sys_counter [ 0.471105] rk-fb rockchip-fb: rk fb ion client create success! [ 0.471123] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.471570] rk-screen rk_screen.9: rockchip screen probe success [ 0.471745] rk32-dsi [ 0.471885] dsi->host.irq =51 [ 0.471904] load mipi dsi chip:rk_mipi_dsi.0 id:3133302a [ 0.471915] mipi_dsi v1.3 2014-04-17 [ 0.471939] rk32-mipi ff960000.mipi: rk mipi_dsi probe success! [ 0.471954] rk32-mipi ff960000.mipi: rockchip mipi_dsi v1.1 2014-06-17 [ 0.472325] enter function:rk_fb_register,added by scottxiang [ 0.472385] rk3288-lcdc lcdc0: request lcd_en gpio fail:-16 [ 0.472420] rk3288-lcdc lcdc0: request lcd_cs gpio fail:-16 [ 0.472675] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.473029] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.473198] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.473354] graphics fb3: rockchip framebuffer registerd:fb3 [ 0.493754] rk3288-lcdc lcdc0: lcdc0: dclk:40000000>>fps:34 [ 0.493773] dsi->phy.sys_clk =24000000 [ 0.502896] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 4.928594] rk3288-lcdc lcdc0: wakeup from standby! [ 4.941176] alloc_buffer:ion_phy_addr=0x40000000 [ 4.947312] fb0:phy:40000000>>vir:e0971000>>len:0xc00000 [ 4.950843] out of function:rk_fb_register,added by scottxiang [ 4.950864] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled [ 4.951011] enter function:rk_fb_register,added by scottxiang [ 4.951036] rk3288-lcdc lcdc1: can't find power_ctr node for lcdc1 [ 4.951049] rk_fb_trsm_ops_get:un supported transmitter:0! [ 4.951265] graphics fb4: rockchip framebuffer registerd:fb4 [ 4.951589] graphics fb5: rockchip framebuffer registerd:fb5 [ 4.951756] graphics fb6: rockchip framebuffer registerd:fb6 [ 4.951915] graphics fb7: rockchip framebuffer registerd:fb7 [ 4.951932] fb0:phy:40000000>>vir:e0971000>>len:0xc00000 [ 4.951943] out of function:rk_fb_register,added by scottxiang [ 4.951958] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled [ 4.952313] rockchip_set_mux:warning ignore bank num 15 [ 4.952435] rockchip_set_mux:warning ignore bank num 15 [ 4.952541] rockchip_set_mux:warning ignore bank num 15 [ 4.952666] rockchip_set_mux:warning ignore bank num 15 [ 4.952772] rockchip_set_mux:warning ignore bank num 15 [ 4.952883] rockchip_set_mux:warning ignore bank num 15 [ 4.953450] rockchip_set_mux:warning ignore bank num 15 [ 4.953601] rockchip_set_mux:warning ignore bank num 15 [ 4.954151] rockchip_set_mux:warning ignore bank num 15 [ 4.954288] rockchip_set_mux:warning ignore bank num 15 [ 4.954830] rockchip_set_mux:warning ignore bank num 15 [ 4.954974] rockchip_set_mux:warning ignore bank num 15 [ 4.955518] rockchip_set_mux:warning ignore bank num 15 [ 4.955659] rockchip_set_mux:warning ignore bank num 15 [ 4.957013] NET: Registered protocol family 2 [ 4.957470] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 4.957552] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 4.957628] TCP: Hash tables configured (established 4096 bind 4096) [ 4.957677] TCP: reno registered [ 4.957692] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 4.957718] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 4.957909] NET: Registered protocol family 1 [ 4.958125] Unpacking initramfs... [ 5.021008] Freeing initrd memory: 1160K (c52ec000 - c540e000) [ 5.021682] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available [ 5.022174] probe device ff9a0000.vpu_service [ 5.022356] vpu_service: power on [ 5.023416] checking hw id 4831 [ 5.023797] vpu_service set to auto frequency mode [ 5.023834] vpu_service: power off... [ 5.023872] done [ 5.023881] init success [ 5.023935] probe device ff9c0000.hevc_service [ 5.024144] hevc_service: power on [ 5.025181] checking hw id 6867 [ 5.025415] hevc_service: power off... [ 5.025453] done [ 5.025462] init success [ 5.025577] rknandbase v1.0 2014-03-31 [ 5.025674] rknand ff400000.nandc0: no irq resource? [ 5.025798] rknand_driver:ret = 0 [ 5.026575] audit: initializing netlink socket (disabled) [ 5.026622] type=2000 audit(4.860:1): initialized [ 5.027398] bounce pool size: 64 pages [ 5.031812] fuse init (API version 7.22) [ 5.032179] msgmni has been set to 954 [ 5.033953] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 5.033971] io scheduler noop registered [ 5.033982] io scheduler deadline registered [ 5.034073] io scheduler cfq registered (default) [ 5.037420] rga2 ff920000.rga: rga ion client create success! [ 5.037562] rga: Driver loaded succesfully [ 5.038189] IEP Driver loaded succesfully [ 5.038284] Module initialized. [ 5.038994] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208 [ 5.039014] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 5.040289] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208 [ 5.040310] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 5.040674] vdd_logic: 925 <--> 1400 mV at 1000 mV [ 5.040725] vdd_logic: Failed to create debugfs directory [ 5.041146] rk_serial.c v1.8 2014-03-04 [ 5.041359] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0 [ 5.041552] serial ff180000.serial: membase e1594000 [ 5.044215] loop: module loaded [ 5.044781] SCSI Media Changer driver v0.25 [ 5.045088] tun: Universal TUN/TAP device driver, 1.6 [ 5.045102] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 5.045217] vmac_init. [ 5.045726] stmmac_probe_config_dt: Can not read property: pmu_regulator. [ 5.045743] stmmac_probe_config_dt: Can not read property: pmu_enable_level. [ 5.045757] stmmac_probe_config_dt: clock input or output? (input). [ 5.045770] stmmac_probe_config_dt: TX delay(0x30). [ 5.045782] stmmac_probe_config_dt: RX delay(0x10). [ 5.045828] stmmac_probe_config_dt: is rockchip,rk3288-gmac [ 5.045839] stmmc_pltfr_init: [ 5.045860] stmmc_pltfr_init: init for RGMII [ 5.045873] tx delay=0x30 [ 5.045873] rx delay=0x10 [ 5.046306] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 5.046317] Normal descriptors [ 5.046326] Ring mode enabled [ 5.046336] DMA HW capability register supported [ 5.046348] RX Checksum Offload Engine supported (type 2) [ 5.046359] TX Checksum insertion supported [ 5.046368] Wake-Up On Lan supported [ 5.046404] Enable RX Mitigation via HW Watchdog Timer [ 5.046848] PPP generic driver version 2.4.2 [ 5.047013] PPP BSD Compression module registered [ 5.047027] PPP Deflate Compression module registered [ 5.047048] PPP MPPE Compression module registered [ 5.047061] NET: Registered protocol family 24 [ 5.047093] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 5.047107] CSLIP: code copyright 1989 Regents of the University of California. [ 5.047120] Rockchip WiFi SYS interface (V1.00) ... [ 5.047152] esp_mem_init enter date Apr 25 2015 21:24:32 [ 5.047196] esp_mem_init complete [ 5.047263] usbcore: registered new interface driver catc [ 5.047314] usbcore: registered new interface driver kaweth [ 5.047327] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 5.047367] usbcore: registered new interface driver pegasus [ 5.047404] usbcore: registered new interface driver rtl8150 [ 5.047446] usbcore: registered new interface driver r8152 [ 5.047458] hso: drivers/net/usb/hso.c: Option Wireless [ 5.047522] usbcore: registered new interface driver hso [ 5.047566] usbcore: registered new interface driver asix [ 5.047605] usbcore: registered new interface driver ax88179_178a [ 5.047642] usbcore: registered new interface driver cdc_ether [ 5.047680] usbcore: registered new interface driver cdc_eem [ 5.047723] usbcore: registered new interface driver dm9601 [ 5.047762] usbcore: registered new interface driver dm9620 [ 5.047808] usbcore: registered new interface driver smsc75xx [ 5.047854] usbcore: registered new interface driver smsc95xx [ 5.047892] usbcore: registered new interface driver gl620a [ 5.047929] usbcore: registered new interface driver net1080 [ 5.047972] usbcore: registered new interface driver plusb [ 5.048013] usbcore: registered new interface driver rndis_host [ 5.048051] usbcore: registered new interface driver cdc_subset [ 5.048088] usbcore: registered new interface driver zaurus [ 5.048128] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 5.048186] usbcore: registered new interface driver int51x1 [ 5.048226] usbcore: registered new interface driver kalmia [ 5.048264] usbcore: registered new interface driver ipheth [ 5.048311] usbcore: registered new interface driver sierra_net [ 5.048353] usbcore: registered new interface driver cx82310_eth [ 5.048400] usbcore: registered new interface driver cdc_ncm [ 5.048440] usbcore: registered new interface driver qmi_wwan [ 5.048479] usbcore: registered new interface driver cdc_mbim [ 5.048491] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 5.050879] ehci_rk_probe e1600000 e1600010 [ 5.050896] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller [ 5.050930] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1 [ 5.051240] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000 [ 5.066361] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00 [ 5.066436] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 5.066453] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.066467] usb usb1: Product: Rockchip On-Chip EHCI Host Controller [ 5.066481] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 5.066495] usb usb1: SerialNumber: ff500000.usb [ 5.066920] hub 1-0:1.0: USB hub found [ 5.066945] hub 1-0:1.0: 1 port detected [ 5.095871] ehci_rk_probe ok [ 5.096018] usbcore: registered new interface driver cdc_acm [ 5.096031] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 5.096094] usbcore: registered new interface driver usblp [ 5.096137] usbcore: registered new interface driver cdc_wdm [ 5.096199] usbcore: registered new interface driver usb-storage [ 5.096239] usbcore: registered new interface driver ums-alauda [ 5.096279] usbcore: registered new interface driver ums-cypress [ 5.096319] usbcore: registered new interface driver ums-datafab [ 5.096357] usbcore: registered new interface driver ums_eneub6250 [ 5.096395] usbcore: registered new interface driver ums-freecom [ 5.096454] usbcore: registered new interface driver ums-isd200 [ 5.096496] usbcore: registered new interface driver ums-jumpshot [ 5.096534] usbcore: registered new interface driver ums-karma [ 5.096575] usbcore: registered new interface driver ums-onetouch [ 5.096612] usbcore: registered new interface driver ums-sddr09 [ 5.096649] usbcore: registered new interface driver ums-sddr55 [ 5.096686] usbcore: registered new interface driver ums-usbat [ 5.096768] usbcore: registered new interface driver usbserial [ 5.096811] usbcore: registered new interface driver usbserial_generic [ 5.096843] usbserial: USB Serial support registered for generic [ 5.096882] usbcore: registered new interface driver option [ 5.096911] usbserial: USB Serial support registered for GSM modem (1-port) [ 5.096978] usbcore: registered new interface driver trancevibrator [ 5.096991] usb20_otg: version 3.10a 21-DEC-2012 [ 5.097386] e1680040 [ 5.097401] Core Release: 3.10a [ 5.097413] Setting default values for core params [ 5.097535] Using Buffer DMA mode [ 5.097548] Periodic Transfer Interrupt Enhancement - disabled [ 5.097559] Multiprocessor Interrupt Enhancement - disabled [ 5.097572] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 5.097582] ^^^^^^^^^^^^^^^^^Device Mode [ 5.097597] Dedicated Tx FIFOs mode [ 5.097614] pcd_init otg_dev = dde88a00 [ 5.097754] usb20_otg ff580000.usb: DWC OTG Controller [ 5.097781] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2 [ 5.097812] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 5.097869] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 5.097886] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.097901] usb usb2: Product: DWC OTG Controller [ 5.097914] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 5.097927] usb usb2: SerialNumber: ff580000.usb [ 5.098298] hub 2-0:1.0: USB hub found [ 5.098321] hub 2-0:1.0: 1 port detected [ 5.098621] usb20_host: version 3.10a 21-DEC-2012 [ 5.101091] e1700040 [ 5.101106] Core Release: 3.10a [ 5.101117] Setting default values for core params [ 5.101214] Using Buffer DMA mode [ 5.101226] Periodic Transfer Interrupt Enhancement - disabled [ 5.101237] Multiprocessor Interrupt Enhancement - disabled [ 5.101248] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 5.101258] ^^^^^^^^^^^^^^^^^^Host Mode [ 5.101282] usb20_host ff540000.usb: DWC OTG Controller [ 5.101307] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3 [ 5.101336] usb20_host ff540000.usb: irq 57, io mem 0x00000000 [ 5.101429] Init: Power Port (0) [ 5.101501] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 5.101518] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.101532] usb usb3: Product: DWC OTG Controller [ 5.101545] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 5.101558] usb usb3: SerialNumber: ff540000.usb [ 5.101942] hub 3-0:1.0: USB hub found [ 5.101966] hub 3-0:1.0: 1 port detected [ 5.102507] .. rk pwm remotectl v1.0 init [ 5.102592] remotectl probe j=0x0 [ 5.102737] input: ff680000.pwm as /devices/ff680000.pwm/input/input0 [ 5.102934] pwm enable val=0x646205 [ 5.103201] usbcore: registered new interface driver xpad [ 5.103252] usbcore: registered new interface driver usb_acecad [ 5.103298] usbcore: registered new interface driver aiptek [ 5.103342] usbcore: registered new interface driver gtco [ 5.103386] usbcore: registered new interface driver hanwang [ 5.103435] usbcore: registered new interface driver kbtab [ 5.103488] usbcore: registered new interface driver wacom [ 5.103500] ==gsl_ts_init== [ 5.103569] GSLX680 Enter gsl_ts_probe [ 5.103580] ==kzalloc success= [ 5.103590] gsl_ts_probe-1292 [ 5.103628] gslX680 1-0041: reset pin invalid [ 5.103639] [GSLX680] Enter gslX680_ts_init [ 5.103879] input: gslX680 as /devices/ff140000.i2c/i2c-1/1-0041/input/input1 [ 5.104004] gsl_ts_probe-1318 [ 5.104016] org chip_type=36 [ 5.155629] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 5.194321] dwc_otg_hcd_suspend, usb device mode [ 5.214633] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 5.214648] chip_type=88, reg=0 [ 5.272990] test_i2c-394: Enter [ 5.273675] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 5.313011] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 5.313024] test_i2c-413: Exit [ 5.313033] ------gslX680 test_i2c error------ [ 5.352377] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 5.352392] #########check mem read 0xb0 = 0 0 0 0 ######### [ 5.410747] test_i2c-394: Enter [ 5.411430] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 5.450772] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 5.450785] test_i2c-413: Exit [ 5.450794] ------gslX680 test_i2c error------ [ 5.450980] gsl_ts_probe () : queue gsl_monitor_workqueue [ 5.451063] [GSLX680] End gsl_ts_probe [ 5.451135] ret=0 [ 5.456034] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0 [ 5.456093] i2c /dev entries driver [ 5.456770] IR NEC protocol handler initialized [ 5.456784] IR RC5(x) protocol handler initialized [ 5.456795] IR RC6 protocol handler initialized [ 5.456805] IR JVC protocol handler initialized [ 5.456814] IR Sony protocol handler initialized [ 5.456825] IR RC5 (streamzap) protocol handler initialized [ 5.456835] IR SANYO protocol handler initialized [ 5.456845] IR MCE Keyboard/mouse protocol handler initialized [ 5.456987] usbcore: registered new interface driver uvcvideo [ 5.456999] USB Video Class driver (1.1.1) [ 5.457923] rockchip_temp_probe,line=362 [ 5.509152] tsadc ff280000.tsadc: initialized [ 5.509526] device-mapper: uevent: version 1.0.3 [ 5.509771] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email] [ 5.510064] Bluetooth: HCI UART driver ver 2.2 [ 5.510080] Bluetooth: HCI H4 protocol initialized [ 5.510092] Bluetooth: HCILL protocol initialized [ 5.512648] cpufreq version 1.0, suspend freq 1200 MHz [ 5.512829] cpuidle: using governor ladder [ 5.512842] cpuidle: using governor menu [ 5.512876] Synopsys Designware Multimedia Card Interface Driver [ 5.513114] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a [ 5.513386] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller. [ 5.513550] 3379..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0] [ 5.513565] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05 [ 5.513677] 1390..dw_mci_set_ios: no card. [mmc0] [ 5.528850] 1390..dw_mci_set_ios: no card. [mmc0] [ 5.548555] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 5.548590] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo [ 5.548610] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized [ 5.548870] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a [ 5.549697] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller. [ 5.549905] 3379..dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1] [ 5.549942] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05 [ 5.550008] mmc1: no vmmc regulator found [ 5.550103] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found! [ 5.550164] 1390..dw_mci_set_ios: no card. [mmc1] [ 5.568198] 1390..dw_mci_set_ios: no card. [mmc1] [ 5.580663] mmc0: BKOPS_EN bit is not set [ 5.582555] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1) [ 5.582580] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0] [ 5.582632] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0] [ 5.582732] mmc0: new high speed MMC card at address 0001 [ 5.582966] mmcblk0: mmc0:0001 AWMB3R 14.5 GiB [ 5.583233] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 5.583245] misc: 0x000800000 -- 0x000c00000 (4 MB) [ 5.583254] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 5.583263] kernel: 0x001c00000 -- 0x002c00000 (16 MB) [ 5.583271] boot: 0x002c00000 -- 0x004c00000 (32 MB) [ 5.583280] recovery: 0x004c00000 -- 0x006c00000 (32 MB) [ 5.583288] backup: 0x006c00000 -- 0x00a000000 (52 MB) [ 5.583297] cache: 0x00a000000 -- 0x012000000 (128 MB) [ 5.583305] kpanic: 0x012000000 -- 0x012400000 (4 MB) [ 5.583314] system: 0x012400000 -- 0x042400000 (768 MB) [ 5.583322] metadata: 0x042400000 -- 0x042800000 (4 MB) [ 5.583331] userdata: 0x042800000 -- 0x082800000 (1024 MB) [ 5.583340] linuxroot: 0x082800000 -- 0x146800000 (3136 MB) [ 5.583349] user: 0x146800000 -- 0x3a3a00000 (9682 MB) [ 5.583378] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141390..dw_mci_set_ios: no card. [mmc1] [ 5.587906] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo [ 5.587919] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized [ 5.588177] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a [ 5.588370] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller. [ 5.588487] 3379..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2] [ 5.588497] mmc2 : Rockchip specific MHSC: Ver 1.13 2014-09-05 [ 5.588748] 1390..dw_mci_set_ios: no card. [mmc2] [ 5.607550] 1390..dw_mci_set_ios: no card. [mmc2] [ 5.627237] 1390..dw_mci_set_ios: no card. [mmc2] [ 5.627254] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo [ 5.627267] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized [ 5.627498] leds-gpio leds.37: pins are not configured from the driver [ 5.627702] hidraw: raw HID events driver (C) Jiri Kosina [ 5.629094] usbcore: registered new interface driver usbhid [ 5.629103] usbhid: USB HID core driver [ 5.629375] zram: Created 1 device(s) ... [ 5.629661] ashmem: initialized [ 5.629777] logger: created 256K log 'log_main' [ 5.629868] logger: created 256K log 'log_events' [ 5.629959] logger: created 256K log 'log_radio' [ 5.630050] logger: created 256K log 'log_system' [ 5.631021] input: rk29-keypad as /devices/ff100000.adc/key.39/input/input2 [ 5.631787] es8323 probe i2c recv ok [ 5.631864] i2c-core: driver [ES8323] using legacy suspend method [ 5.631873] i2c-core: driver [ES8323] using legacy resume method [ 5.632649] rockchip-hdmi-spdif rockchip-hdmi-spdif.32: ASoC: CPU DAI (null) not registered [ 5.632678] rockchip_hdmi_spdif_audio_probe() register card failed:-517 [ 5.632697] platform rockchip-hdmi-spdif.32: Driver rockchip-hdmi-spdif requests probe deferral [ 5.632919] es8323_probe [ 6.267195] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> NULL --> Left Line Mux [ 6.267207] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> NULL -> Left Line Mux [ 6.267218] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> NULL --> Left Line Mux [ 6.267226] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> NULL -> Left Line Mux [ 6.267235] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> NULL --> Left Line Mux [ 6.267244] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> NULL -> Left Line Mux [ 6.267254] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> NULL --> Right Line Mux [ 6.267262] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> NULL -> Right Line Mux [ 6.267271] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> NULL --> Right Line Mux [ 6.267279] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> NULL -> Right Line Mux [ 6.267288] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> NULL --> Right Line Mux [ 6.267296] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> NULL -> Right Line Mux [ 6.267305] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left PGA Mux [ 6.267313] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left PGA Mux [ 6.267321] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left PGA Mux [ 6.267329] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left PGA Mux [ 6.267338] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> LAMP --> Left PGA Mux [ 6.267346] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> LAMP -> Left PGA Mux [ 6.267355] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right PGA Mux [ 6.267363] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right PGA Mux [ 6.267372] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right PGA Mux [ 6.267380] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right PGA Mux [ 6.267390] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> RAMP --> Right PGA Mux [ 6.267398] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> RAMP -> Right PGA Mux [ 6.267408] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Differential Mux [ 6.267415] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Differential Mux [ 6.267425] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Differential Mux [ 6.267433] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Differential Mux [ 6.267442] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Differential Mux [ 6.267450] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Differential Mux [ 6.267459] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Differential Mux [ 6.267467] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Differential Mux [ 6.267487] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left Line Mux [ 6.267495] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left Line Mux [ 6.267504] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left Line Mux [ 6.267512] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left Line Mux [ 6.267521] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> LAMP --> Left Line Mux [ 6.267529] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> LAMP -> Left Line Mux [ 6.267538] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right Line Mux [ 6.267545] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right Line Mux [ 6.267554] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right Line Mux [ 6.267562] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right Line Mux [ 6.267571] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> RAMP --> Right Line Mux [ 6.267578] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> RAMP -> Right Line Mux [ 6.267698] ES8323 2-0010: ASoC: mux Right Line Mux has no paths [ 6.267709] ES8323 2-0010: ASoC: mux Left Line Mux has no paths [ 6.267719] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths [ 6.267728] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths [ 6.267756] ES8323 2-0010: ASoC: mux Differential Mux has no paths [ 6.271017] rockchip-es8323 rockchip-es8323.34: ES8323 HiFi <-> rockchip-i2s.0 mapping ok [ 6.271311] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.34/sound/card0/input3 [ 6.271978] rockchip-hdmi-i2s rockchip-hdmi-i2s.31: rk-hdmi-i2s-hifi <-> rockchip-i2s.0 mapping ok [ 6.272289] u32 classifier [ 6.272295] Actions configured [ 6.272304] Netfilter messages via NETLINK v0.30. [ 6.272346] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 6.272591] ctnetlink v0.93: registering with nfnetlink. [ 6.272641] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 6.272648] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 6.272839] xt_time: kernel timezone is -0000 [ 6.272993] ip_tables: (C) 2000-2006 Netfilter Core Team [ 6.273092] arp_tables: (C) 2002 David S. Miller [ 6.273120] TCP: cubic registered [ 6.273126] Initializing XFRM netlink socket [ 6.273298] NET: Registered protocol family 10 [ 6.273702] mip6: Mobile IPv6 [ 6.273725] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 6.273816] sit: IPv6 over IPv4 tunneling driver [ 6.274065] NET: Registered protocol family 17 [ 6.274084] NET: Registered protocol family 15 [ 6.274125] Bridge firewalling registered [ 6.274133] Ebtables v2.0 registered [ 6.274250] Bluetooth: RFCOMM TTY layer initialized [ 6.274269] Bluetooth: RFCOMM socket layer initialized [ 6.274276] Bluetooth: RFCOMM ver 1.11 [ 6.274282] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 6.274288] Bluetooth: BNEP filters: protocol multicast [ 6.274297] Bluetooth: BNEP socket layer initialized [ 6.274304] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 6.274313] Bluetooth: HIDP socket layer initialized [ 6.274337] l2tp_core: L2TP core driver, V2.0 [ 6.274349] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 6.274355] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 6.274491] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 6.274500] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi [ 6.274507] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 6.274515] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 6.274522] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 6.274539] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0. [ 6.274557] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0. [ 6.274564] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 6.274583] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V [ 6.274618] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 6.274654] [BT_RFKILL]: Enter rfkill_rk_init [ 6.274758] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147. [ 6.274772] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155. [ 6.274784] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157. [ 6.274796] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154. [ 6.274808] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159. [ 6.274842] [BT_RFKILL]: Request irq for bt wakeup host [ 6.274914] [BT_RFKILL]: ** disable irq [ 6.274978] [BT_RFKILL]: ap6335 device registered. [ 6.275771] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess. [ 6.276480] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0 [ 6.276497] rk3288_init_suspend [ 6.276504] rk3288_suspend_init enter [ 6.276613] rk3288_suspend_init: pm_ctrbits =200007 [ 6.276638] gpio_get_dts_info suspend:4 [ 6.276688] gpio_get_dts_info resume:4 [ 6.276694] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 6.276719] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 6.276836] clks_gating_suspend_init:clkgt info ok [ 6.276916] Registering SWP/SWPB emulation handler [ 6.277195] ddrfreq: verion 1.2 20140526 [ 6.277204] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz [ 6.277212] ddrfreq: auto-freq=0 [ 6.277217] ddrfreq: auto-freq-table[0] 240MHz [ 6.277223] ddrfreq: auto-freq-table[1] 324MHz [ 6.277228] ddrfreq: auto-freq-table[2] 396MHz [ 6.277233] ddrfreq: auto-freq-table[3] 528MHz [ 6.281896] regulator-dummy: disabling [ 6.282171] rockchip-hdmi-spdif rockchip-hdmi-spdif.32: ASoC: CPU DAI (null) not registered [ 6.282195] rockchip_hdmi_spdif_audio_probe() register card failed:-517 [ 6.282209] platform rockchip-hdmi-spdif.32: Driver rockchip-hdmi-spdif requests probe deferral [ 6.282299] pcd_pullup, is_on 0 [ 6.282340] file system registered [ 6.282854] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 6.282863] android_usb gadget: Number of LUNs=2 [ 6.282870] lun0: LUN: removable file: (no medium) [ 6.282876] lun1: LUN: removable file: (no medium) [ 6.282991] android_usb gadget: android_usb ready [ 6.283529] rtc_hym8563 0-0051: setting system clock to 2011-01-01 16:58:37 UTC (1293901117) [ 6.288093] rk_spdif:rk_spdif_init [ 6.288253] rk_spdif:Entered spdif_probe [ 6.288427] rk_spdif:spdif:spdif probe ok! [ 6.288955] usbcore: registered new interface driver snd-usb-audio [ 6.288975] ALSA device list: [ 6.288980] #0: RK_ES8323 [ 6.288985] #1: RK-HDMI-I2S [ 6.289106] rockchip-hdmi-spdif rockchip-hdmi-spdif.32: rk-hdmi-spdif-hifi <-> rockchip-spdif mapping ok [ 6.289327] Freeing unused kernel memory: 592K (c0add000 - c0b71000) [ 6.293831] SELinux: Permission attach_queue in class tun_socket not defined in policy. [ 6.293844] SELinux: the above unknown classes and permissions will be denied [ 6.712655] type=1403 audit(1293901117.930:2): policy loaded auid=4294967295 ses=4294967295 [ 6.712757] SELinux: Loaded policy from /sepolicy [ 6.714209] type=1404 audit(1293901117.930:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295 [ 7.073695] dwc_otg_hcd_enable, enable host controller [ 7.177057] Using Buffer DMA mode [ 7.177068] Periodic Transfer Interrupt Enhancement - disabled [ 7.177073] Multiprocessor Interrupt Enhancement - disabled [ 7.177080] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 7.177085] ^^^^^^^^^^^^^^^^^^Host Mode [ 7.221393] Init: Power Port (0) [ 7.221438] ff540000.usb resume, HPRT0:0x21401 [ 7.359121] Indeed it is in host mode hprt0 = 00021501 [ 7.546038] usb 3-1: new high-speed USB device number 2 using usb20_host [ 7.546114] Indeed it is in host mode hprt0 = 00001101 [ 7.743089] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101 [ 7.743109] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 7.743124] usb 3-1: Product: USB 2.0 Hub [MTT] [ 7.743461] hub 3-1:1.0: USB hub found [ 7.743512] hub 3-1:1.0: 4 ports detected [ 7.768238] init: could not import file '/init.usbstorage.rc' from '/init.rc' [ 7.768297] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead. [ 7.818700] init: /dev/hw_random not found [ 7.818768] keychord: using input dev ff680000.pwm for fevent [ 7.818780] keychord: using input dev rk29-keypad for fevent [ 7.823800] fs_mgr: parse_link_device : path = NULL [ 7.823826] fs_mgr: parse_link_device : path = NULL [ 7.823845] fs_mgr: parse_link_device : path = NULL [ 7.823906] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system [ 7.824789] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 196608 blocks long. Nothing to do!resize2fs: [ 7.834245] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc [ 7.848467] EXT4-fs (mmcblk0p8): recovery complete [ 7.849002] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard [ 7.851064] EXT4-fs (mmcblk0p11): recovery complete [ 7.851075] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard [ 7.860913] ff540000.usb suspend, HPRT0:0x1485 [ 7.946102] EXT4-fs (mmcblk0p12): recovery complete [ 7.946711] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard [ 7.966939] mali pd enabled [ 7.966966] clk enabled [ 7.968140] MALI_DVFS_STEP=5,div_dvfs=7 [ 7.968152] mali_dvfs_infotbl[0].clock=99000,min_threshold=0,max_threshold=70 [ 7.968162] mali_dvfs_infotbl[1].clock=179000,min_threshold=66,max_threshold=77 [ 7.968171] mali_dvfs_infotbl[2].clock=297000,min_threshold=73,max_threshold=84 [ 7.968181] mali_dvfs_infotbl[3].clock=417000,min_threshold=82,max_threshold=91 [ 7.968189] mali_dvfs_infotbl[4].clock=480000,min_threshold=94,max_threshold=100 [ 7.968290] gpufreq_input_connect [ 7.968301] turn on mali power [ 7.968309] kbase_platform_rk_init,register_reboot_notifier [ 7.968334] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1 [ 7.968782] mali ffa30000.gpu: Probed as mali0 [ 7.970377] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ' [ 7.979902] init: /dev/hw_random not found [ 7.986449] init: cannot find '/system/vendor/bin/pvrsrvctl', disabling 'pvrsrvctl' [ 7.987594] binder: 162:162 transaction failed 29189, size 0-0 [ 7.989142] init: cannot find '/system/bin/rild3', disabling 'ril-daemon3' [ 8.004249] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery' [ 8.005803] init: cannot find '/system/bin/chrome.sh', disabling 'chrome' [ 8.006820] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}' [ 8.006839] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial' [ 8.007033] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead [ 8.277524] init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}' [ 8.277554] init: powerctl: cannot expand '${sys.powerctl}' [ 8.277572] init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}' [ 8.277585] init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes' [ 8.277602] init: property 'sys.sysctl.tcp_def_init_rwnd' d328n't exist while expanding '${sys.sysctl.tcp_def_init_rwnd}' [ 8.277614] init: cannot expand '${sys.sysctl.tcp_def_init_rwnd}' while writing to '/proc/sys/net/ipv4/tcp_default_init_rwnd' [ 8.278537] android_usb: already disabled [ 8.280452] read descriptors [ 8.280468] read strings [ 8.280500] pcd_pullup, is_on 1 [ 8.306049] fs_mgr: parse_link_device : path = NULL [ 8.306087] fs_mgr: parse_link_device : path = NULL [ 8.306114] fs_mgr: parse_link_device : path = NULL [ 9.389690] rk3288-lcdc lcdc0: blank mode:0 [ 9.389702] I'am in gsl_ts_resume() start [ 9.484524] ----------3680A--------- [ 9.544259] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 9.544267] #########check mem read 0xb0 = 0 0 0 0 ######### [ 9.602595] test_i2c-394: Enter [ 9.603296] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 9.642657] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 9.642665] test_i2c-413: Exit [ 9.642669] ------gslX680 test_i2c error------ [ 9.642682] gsl_ts_resume () : queue gsl_monitor_work [ 9.642687] ------------[ cut here ]------------ [ 9.642701] WARNING: at kernel/irq/manage.c:432 enable_irq+0x50/0x6c() [ 9.642706] Unbalanced enable for IRQ 192 [ 9.642713] Modules linked in: mali_kbase [ 9.642720] CPU: 0 PID: 168 Comm: surfaceflinger Not tainted 3.10.0 #18 [ 9.642740] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 9.642751] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68) [ 9.642760] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c) [ 9.642770] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (enable_irq+0x50/0x6c) [ 9.642783] [] (enable_irq+0x50/0x6c) from [] (rk_ts_early_resume+0xd0/0xe4) [ 9.642794] [] (rk_ts_early_resume+0xd0/0xe4) from [] (fb_notifier_callback+0x60/0x9c) [ 9.642807] [] (fb_notifier_callback+0x60/0x9c) from [] (notifier_call_chain+0x38/0x68) [ 9.642818] [] (notifier_call_chain+0x38/0x68) from [] (__blocking_notifier_call_chain+0x44/0x58) [ 9.642827] [] (__blocking_notifier_call_chain+0x44/0x58) from [] (blocking_notifier_call_chain+0x14/0x18) [ 9.642838] [] (blocking_notifier_call_chain+0x14/0x18) from [] (fb_blank+0x7c/0x88) [ 9.642849] [] (fb_blank+0x7c/0x88) from [] (do_fb_ioctl+0x518/0x5a0) [ 9.642862] [] (do_fb_ioctl+0x518/0x5a0) from [] (do_vfs_ioctl+0x210/0x240) [ 9.642874] [] (do_vfs_ioctl+0x210/0x240) from [] (SyS_ioctl+0x50/0x6c) [ 9.642887] [] (SyS_ioctl+0x50/0x6c) from [] (ret_fast_syscall+0x0/0x30) [ 9.642893] ---[ end trace c4638b7137c07fc4 ]--- [ 9.656906] init: sys_prop: permission denied uid:1003 name:sys.gmali.version [ 10.753900] rk3288-lcdc lcdc0: win0:new_addr:0x407d0000 cur_addr:0x403e8000--1 [ 10.760715] warning: `zygote' uses 32-bit capabilities (legacy support in use) [ 10.783417] rk3288-lcdc lcdc0: win0:new_addr:0x40000000 cur_addr:0x407d0000--1 [ 10.812931] rk3288-lcdc lcdc0: win0:new_addr:0x403e8000 cur_addr:0x40000000--1 [ 10.891661] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 10.980209] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 11.068771] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 11.236051] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 11.324620] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 11.383663] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 11.472216] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 11.550941] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 11.639510] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 11.728047] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 11.816607] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 11.895329] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 11.954371] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 12.042921] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 12.131492] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 12.210227] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 12.298779] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 12.387358] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 12.475892] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 12.554629] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 12.613646] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 12.702217] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 12.790772] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 12.958053] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 12.987556] ***************vbus detect***************** [ 13.046606] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 13.167153] Using Buffer DMA mode [ 13.167188] Periodic Transfer Interrupt Enhancement - disabled [ 13.167196] Multiprocessor Interrupt Enhancement - disabled [ 13.167205] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 13.167213] ^^^^^^^^^^^^^^^^^Device Mode [ 13.167255] *******************soft connect!!!******************* [ 13.213896] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 13.272935] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 13.288155] USB RESET [ 13.361495] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 13.381563] android_work: sent uevent USB_STATE=CONNECTED [ 13.384940] USB RESET [ 13.450057] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 13.617351] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 13.705895] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 13.764934] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 13.932237] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 14.020779] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 14.109327] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 14.276627] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 14.335656] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 14.506955] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 14.574580] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj: [ 14.574607] lowmemorykiller: oom_adj 0 => oom_score_adj 0 [ 14.574613] lowmemorykiller: oom_adj 1 => oom_score_adj 58 [ 14.574619] lowmemorykiller: oom_adj 2 => oom_score_adj 117 [ 14.574625] lowmemorykiller: oom_adj 3 => oom_score_adj 176 [ 14.574631] lowmemorykiller: oom_adj 9 => oom_score_adj 529 [ 14.574637] lowmemorykiller: oom_adj 15 => oom_score_adj 1000 [ 14.591491] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 14.680059] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 14.768613] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 14.820211] phy_power_on: enable = 1 [ 14.859622] Read the Ethernet MAC address from IDB:6f:93:1c:28:27:45 [ 14.859661] eth0: device MAC address da:8f:0e:1c:71:2b [ 14.863764] libphy: stmmac: probed [ 14.863777] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active [ 14.863787] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active [ 14.935916] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 14.994926] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 15.001800] wifi_driver_write: wifi driver already rmmod [ 15.012207] acc_open [ 15.012238] acc_release [ 15.083493] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 15.172055] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 15.250769] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 15.310494] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 15.311172] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 15.311185] ======int_1st: 0 0 0 0 , int_2nd: 0 0 0 0 ====== [ 15.311840] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 15.339331] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 15.368851] test_i2c-394: Enter [ 15.369550] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 15.408983] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 15.409011] test_i2c-413: Exit [ 15.409019] ------gslX680 test_i2c error------ [ 15.427935] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 15.501922] FAT-fs (mmcblk0p14): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 15.524125] avc: denied { set } for property=sys.vold.hasAsec scontext=u:r:vold:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service [ 15.524164] init: sys_prop: permission denied uid:0 name:sys.vold.hasAsec [ 15.524421] init: no such service 'fuse_internal_sd' [ 15.585835] dwc_otg_hcd_resume, usb device mode [ 15.586003] ff540000.usb resume, HPRT0:0x1485 [ 15.586244] dwc_otg_hcd_suspend, usb device mode [ 15.634598] ff540000.usb suspend, HPRT0:0x1485 [ 15.651525] ff540000.usb resume, HPRT0:0x1485 [ 15.654229] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 15.686390] ff540000.usb suspend, HPRT0:0x1005 [ 15.742774] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 15.831357] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 15.910052] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 15.998623] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 16.087182] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 16.146229] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 16.224946] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 16.392901] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 16.392925] ======read 0xb0: 0 0 0 0 ====== [ 16.393606] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 16.393620] ======int_1st: 0 0 0 0 , int_2nd: 0 0 0 0 ====== [ 16.394286] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 16.402080] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 16.431573] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 16.451265] test_i2c-394: Enter [ 16.451960] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 16.490620] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 16.491295] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 16.491307] test_i2c-413: Exit [ 16.491314] ------gslX680 test_i2c error------ [ 16.552181] init: sys_prop: permission denied uid:10029 name:sys.gmali.version [ 16.580691] init: sys_prop: permission denied uid:10007 name:sys.gmali.version [ 16.657920] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 16.716959] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 16.805498] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 16.972789] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 17.061339] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 17.149886] rk3288-lcdc lcdc0: win0:new_addr:0x41000000 cur_addr:0x40c00000--1 [ 17.317181] rk3288-lcdc lcdc0: win0:new_addr:0x40c00000 cur_addr:0x41400000--1 [ 17.464789] rk3288-lcdc lcdc0: win0:new_addr:0x41400000 cur_addr:0x41000000--1 [ 17.475323] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 17.476002] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 17.476014] ======int_1st: 0 0 0 0 , int_2nd: 0 0 0 0 ====== [ 17.476684] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 17.512007] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit [ 17.533648] test_i2c-394: Enter [ 17.534331] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 17.573025] rk3288-lcdc lcdc0: win1:new_addr:0x41f00000 cur_addr:0x41b00000--1 [ 17.573740] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 17.573751] test_i2c-413: Exit [ 17.573756] ------gslX680 test_i2c error------ [ 17.584017] e23a6234,e23a6234,e23a6234 [ 17.632079] rk3288-lcdc lcdc0: win2:new_addr:0x41a60000 cur_addr:0x41a40000--1 [ 17.976457] rk3288-lcdc lcdc0: win1:new_addr:0x40d00000 cur_addr:0x42b00000--1 [ 18.005980] rk3288-lcdc lcdc0: win1:new_addr:0x41f00000 cur_addr:0x40d00000--1 [ 18.035497] rk3288-lcdc lcdc0: win1:new_addr:0x42b00000 cur_addr:0x41f00000--1 [ 18.065001] rk3288-lcdc lcdc0: win2:new_addr:0x40c00000 cur_addr:0x41a60000--1 [ 18.124072] rk3288-lcdc lcdc0: win1:new_addr:0x40d00000 cur_addr:0x42b00000--1 [ 18.153607] rk3288-lcdc lcdc0: win1:new_addr:0x41f00000 cur_addr:0x40d00000--1 [ 18.183088] rk3288-lcdc lcdc0: win1:new_addr:0x42b00000 cur_addr:0x41f00000--1 [ 18.261805] rk3288-lcdc lcdc0: win1:new_addr:0x42b00000 cur_addr:0x41f00000--1 [ 18.291353] rk3288-lcdc lcdc0: win1:new_addr:0x40d00000 cur_addr:0x42b00000--1 [ 18.320875] rk3288-lcdc lcdc0: win1:new_addr:0x41f00000 cur_addr:0x40d00000--1 [ 18.350398] rk3288-lcdc lcdc0: win1:new_addr:0x42b00000 cur_addr:0x41f00000--1 [ 18.379896] rk3288-lcdc lcdc0: win1:new_addr:0x40d00000 cur_addr:0x42b00000--1 [ 18.409425] rk3288-lcdc lcdc0: win1:new_addr:0x41f00000 cur_addr:0x40d00000--1 [ 18.438929] rk3288-lcdc lcdc0: win1:new_addr:0x42b00000 cur_addr:0x41f00000--1 [ 18.468445] rk3288-lcdc lcdc0: win1:new_addr:0x40d00000 cur_addr:0x42b00000--1 [ 18.497964] rk3288-lcdc lcdc0: win1:new_addr:0x41f00000 cur_addr:0x40d00000--1 [ 18.527492] rk3288-lcdc lcdc0: win1:new_addr:0x42b00000 cur_addr:0x41f00000--1 [ 18.557694] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 18.557713] ======read 0xb0: 0 0 0 0 ====== [ 18.566524] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 18.566538] ======int_1st: 0 0 0 0 , int_2nd: 0 0 0 0 ====== [ 18.567201] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 18.606216] rk3288-lcdc lcdc0: win1:new_addr:0x42b00000 cur_addr:0x41f00000--1 [ 18.625886] test_i2c-394: Enter [ 18.626562] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 18.665916] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 18.665937] test_i2c-413: Exit [ 18.665943] ------gslX680 test_i2c error------ [ 19.650731] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 19.652064] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 19.652165] ======int_1st: 0 0 0 0 , int_2nd: 0 0 0 0 ====== [ 19.653372] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 19.708350] test_i2c-394: Enter [ 19.709509] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 19.748376] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 19.748407] test_i2c-413: Exit [ 19.748420] ------gslX680 test_i2c error------ [ 20.416974] rk3288-lcdc lcdc0: win2:new_addr:0x41a40000 cur_addr:0x40c00000--1 [ 20.446471] rk3288-lcdc lcdc0: win2:new_addr:0x41a60000 cur_addr:0x41a40000--1 [ 20.475944] rk3288-lcdc lcdc0: win2:new_addr:0x40c00000 cur_addr:0x41a60000--1 [ 20.505500] rk3288-lcdc lcdc0: win2:new_addr:0x41a40000 cur_addr:0x40c00000--1 [ 20.643135] rk3288-lcdc lcdc0: win2:new_addr:0x40c00000 cur_addr:0x41a60000--1 [ 20.672644] rk3288-lcdc lcdc0: win2:new_addr:0x41a40000 cur_addr:0x40c00000--1 [ 20.702199] rk3288-lcdc lcdc0: win2:new_addr:0x41a60000 cur_addr:0x41a40000--1 [ 20.731676] rk3288-lcdc lcdc0: win2:new_addr:0x40c00000 cur_addr:0x41a60000--1 [ 20.732399] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 20.732423] ======read 0xb0: 0 0 0 0 ====== [ 20.733152] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 20.733174] ======int_1st: 0 0 0 0 , int_2nd: 0 0 0 0 ====== [ 20.733875] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 20.761201] rk3288-lcdc lcdc0: win2:new_addr:0x41a40000 cur_addr:0x40c00000--1 [ 20.790719] test_i2c-394: Enter [ 20.790759] rk3288-lcdc lcdc0: win2:new_addr:0x41a60000 cur_addr:0x41a40000--1 [ 20.791714] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 20.820263] rk3288-lcdc lcdc0: win2:new_addr:0x40c00000 cur_addr:0x41a60000--1 [ 20.830800] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 20.830836] test_i2c-413: Exit [ 20.830850] ------gslX680 test_i2c error------ [ 20.849758] rk3288-lcdc lcdc0: win2:new_addr:0x41a40000 cur_addr:0x40c00000--1 [ 21.815512] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 21.816809] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 21.816911] ======int_1st: 0 0 0 0 , int_2nd: 0 0 0 0 ====== [ 21.818113] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 21.873308] test_i2c-394: Enter [ 21.874683] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 21.913174] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 21.913205] test_i2c-413: Exit [ 21.913218] ------gslX680 test_i2c error------ [ 22.897600] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 22.897709] ======read 0xb0: 0 0 0 0 ====== [ 22.898711] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 22.898777] ======int_1st: 0 0 0 0 , int_2nd: 0 0 0 0 ====== [ 22.899770] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 22.955521] test_i2c-394: Enter [ 22.956314] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 22.995971] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 22.996105] test_i2c-413: Exit [ 22.996169] ------gslX680 test_i2c error------ [ 23.979606] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 23.980353] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 23.980374] ======int_1st: 0 0 0 0 , int_2nd: 0 0 0 0 ====== [ 23.981088] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 24.038048] test_i2c-394: Enter [ 24.039406] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 24.078437] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 24.078517] test_i2c-413: Exit [ 24.078552] ------gslX680 test_i2c error------ [ 25.062704] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 25.062853] ======read 0xb0: 0 0 0 0 ====== [ 25.064053] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 25.064150] ======int_1st: 0 0 0 0 , int_2nd: 0 0 0 0 ====== [ 25.065338] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 25.120309] test_i2c-394: Enter [ 25.121064] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 25.160773] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 25.160909] test_i2c-413: Exit [ 25.160976] ------gslX680 test_i2c error------ [ 26.145099] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 26.146382] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 26.146482] ======int_1st: 0 0 0 0 , int_2nd: 0 0 0 0 ====== [ 26.147666] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 26.203000] test_i2c-394: Enter [ 26.204435] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 26.242853] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 26.242888] test_i2c-413: Exit [ 26.242901] ------gslX680 test_i2c error------ [ 27.227447] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 27.227593] ======read 0xb0: 0 0 0 0 ====== [ 27.228825] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 27.228924] ======int_1st: 0 0 0 0 , int_2nd: 0 0 0 0 ====== [ 27.230136] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 27.285090] test_i2c-394: Enter [ 27.285861] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 27.325826] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 27.325964] test_i2c-413: Exit [ 27.326023] ------gslX680 test_i2c error------ [ 28.309878] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 28.311172] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 28.311274] ======int_1st: 0 0 0 0 , int_2nd: 0 0 0 0 ====== [ 28.312464] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 28.367607] test_i2c-394: Enter [ 28.368957] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 28.407588] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 28.407618] test_i2c-413: Exit [ 28.407631] ------gslX680 test_i2c error------ [ 28.505281] rk3288-lcdc lcdc0: win0:new_addr:0x43da3000 cur_addr:0x407d0000--1 [ 28.534794] rk3288-lcdc lcdc0: win1:new_addr:0x42b00000 cur_addr:0x41f00000--1 [ 28.564306] rk3288-lcdc lcdc0: win1:new_addr:0x40d00000 cur_addr:0x42b00000--1 [ 29.392387] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 29.392538] ======read 0xb0: 0 0 0 0 ====== [ 29.393753] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 29.393852] ======int_1st: 0 0 0 0 , int_2nd: 0 0 0 0 ====== [ 29.395047] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 29.449908] test_i2c-394: Enter [ 29.450716] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 29.479419] rk3288-lcdc lcdc0: win0:new_addr:0x40000000 cur_addr:0x43da3000--1 [ 29.489975] gsl_ts_read set data address fail! ret=-11-0xfffffff5 [ 29.489997] test_i2c-413: Exit [ 29.490010] ------gslX680 test_i2c error------ [ 29.508967] rk3288-lcdc lcdc0: win0:new_addr:0x403e8000 cur_addr:0x40000000--1 [ 29.646960] rk3288-lcdc lcdc0: win0:new_addr:0x407d0000 cur_addr:0x403e8000--1 [ 29.676423] rk3288-lcdc lcdc0: win0:new_addr:0x40000000 cur_addr:0x407d0000--1 [ 29.705983] rk3288-lcdc lcdc0: win0:new_addr:0x403e8000 cur_addr:0x40000000--1 [ 29.735351] rk3288-lcdc lcdc0: win0:new_addr:0x407d0000 cur_addr:0x403e8000--1 [ 29.764929] rk3288-lcdc lcdc0: win0:new_addr:0x40000000 cur_addr:0x407d0000--1 [ 29.789983] I'am in gsl_ts_suspend() start [ 29.789995] gsl_ts_suspend () : cancel gsl_monitor_work [ 29.794328] rk3288-lcdc lcdc0: win0:new_addr:0x403e8000 cur_addr:0x40000000--1 [ 29.823838] rk3288-lcdc lcdc0: win0:new_addr:0x407d0000 cur_addr:0x403e8000--1 [ 29.823901] rk3288-hdmi ff980000.hdmi: Removed. [ 30.035405] rk3288-lcdc lcdc0: blank mode:4 [ 67.032058] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 126.071451] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 185.111444] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 244.151400] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 303.191454] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 362.231428] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 421.271373] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 480.311435] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 539.351377] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 598.391482] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 657.431343] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 716.471391] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 775.511394] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 834.551384] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 893.591373] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 952.631504] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 1011.671440] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 1070.711496] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 1129.751434] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 1188.791551] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 1247.831460] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 1306.871380] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 1365.911452] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 1424.951333] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 1483.991355] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 1543.031336] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 1602.071364] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 1661.111366] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au [ 1720.151408] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
