[ 2.671177] VFS: Cannot open root device “(null)” or unknown-block(0,0): error -6
[ 2.671212] Please append a correct “root=” boot option; here are the available partitions:
是找不到根文件系统吗,还有root=这个是在那里指定?
完整log
DDR Version 1.15 20181010
soft reset
SRX
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
CPUId = 0x0
ChipType = 0x10, 271
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7457MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 70414
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: resource, start:0xa000, size:0x8000
GPT part: 4, name: kernel, start:0x12000, size:0x10000
GPT part: 5, name: dtb, start:0x22000, size:0x2000
GPT part: 6, name: dtbo, start:0x24000, size:0x2000
GPT part: 7, name: vbmeta, start:0x26000, size:0x800
GPT part: 8, name: boot, start:0x26800, size:0x10000
GPT part: 9, name: recovery, start:0x36800, size:0x20000
GPT part: 10, name: backup, start:0x56800, size:0x38000
GPT part: 11, name: security, start:0x8e800, size:0x2000
GPT part: 12, name: cache, start:0x90800, size:0x100000
GPT part: 13, name: system, start:0x190800, size:0x500000
GPT part: 14, name: metadata, start:0x690800, size:0x8000
GPT part: 15, name: vendor, start:0x698800, size:0x100000
GPT part: 16, name: oem, start:0x798800, size:0x100000
GPT part: 17, name: frp, start:0x898800, size:0x400
GPT part: 18, name: userdata, start:0x898c00, size:0x5f7bdf
find partition:uboot OK. first_lba:0x4000.
find partition:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xe7d4c
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):1b26c3f
NOTICE: BL31: Built : 20:53:30, Dec 26 2018
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: BL31: Initializing BL32
INFO: SPSR = 0x3c9
U-Boot 2017.09-g237ebb4-dirty (Apr 02 2019 - 18:02:55 +0800)
Model: Rockchip RK3399 Evaluation Board
DRAM: 2 GiB
Relocation Offset is: 00000000
mmc_init: -95, time 9
switch to partitions #0, OK
Bootdev: mmc 0
PartType: EFI
Load FDT from recovery part
DTB: rk-kernel.dtb
I2c speed: 400000Hz
PMIC: RK8180 (on=0x00, off=0x00)
vdd_cpu_l 900000 uV
vdd_center 900000 uV
vdd_log 1000000 uV
Warn: can’t find phy driver
Model: roc-rk3399-pc (Android)
enter Recovery mode!
rk818-bat: initialized… estv=4147, ch=3
rk818-bat: dl=24 rl=-2800 cap=0 m=0 v=4147 ov=3007 c=-66 pl=24 ch=3 fcc=4000, Ver=2.0
rk818-bat: DC_CHARGER
Enable charge animation display
Net: eth0: ethernet@fe300000
ca head not found
get share memory, arg0=0x0 arg1=0x9e08000 arg2=0x3f8000 arg3=0x1
read_is_device_unlocked() ops returned that device is UNLOCKED
avb_vbmeta_image.c:59: ERROR: Magic is incorrect.
avb_slot_verify.c:648: ERROR: vbmeta: Error verifying vbmeta image: invalid vbmeta header
ca head not found
do_boot_rockchip boot from Recovery partition!
=Booting Rockchip format image=
recovery: invalid image tag(0x52444e41)
boot_rockchip_image ramdisk part recovery read error
kernel @ 0x02080000 (0x011c4008)
ramdisk @ 0x0a200000 (0x00000000)
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
‘reserved-memory’ secure-memory@20000000: addr=20000000 size=10000000
Loading Ramdisk to 80000000, end 80000000 … OK
Loading Device Tree to 0000000071db5000, end 0000000071dd04a8 … OK
[ 0.000000] Linux version 4.4.167 (zy@zy) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #50 SMP PREEMPT Wed Apr 3 09:20:49 CST 2019
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eeed000 s45528 r8192 d32296 u86016
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.mode=emmc androidboot.verifiedbootstate=orange earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 consolet
[ 0.000000] software IO TLB [mem 0x7eea4000-0x7eee4000] (0MB) mapped at [ffffffc07eea4000-ffffffc07eee3fff]
[ 0.000000] Memory: 1989152K/2064384K available (10750K kernel code, 1616K rwdata, 4996K rodata, 768K init, 2403K bss, 58848K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8008ff0000 - 0xffffff80090b0000 ( 768 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b00000 ( 10752 KB)
[ 0.000000] .rodata : 0xffffff8008b00000 - 0xffffff8008ff0000 ( 5056 KB)
[ 0.000000] .data : 0xffffff80090b0000 - 0xffffff8009244008 ( 1617 KB)
[ 0.000000] ITS: allocated 65536 Devices @a280000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000000a300000
[ 0.000000] CPU0: using LPI pending table @0x000000000a310000
[ 0.001944] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002923] pid_max: default: 32768 minimum: 301
[ 0.003422] Security Framework initialized
[ 0.003816] SELinux: Initializing.
[ 0.004248] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004887] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006297] Initializing cgroup subsys memory
[ 0.006735] Initializing cgroup subsys freezer
[ 0.008048] sched-energy: Sched-energy-costs installed from DT
[ 0.008606] CPU0: update cpu_capacity 401
[ 0.009064] ASID allocator initialised with 32768 entries
[ 0.025894] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027183] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039293] Detected VIPT I-cache on CPU1
[ 0.039323] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039351] CPU1: using LPI pending table @0x0000000000270000
[ 0.039390] CPU1: update cpu_capacity 401
[ 0.039393] CPU1: Booted secondary processor [410fd034]
[ 0.049280] Detected VIPT I-cache on CPU2
[ 0.049298] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049325] CPU2: using LPI pending table @0x00000000002a0000
[ 0.049350] CPU2: update cpu_capacity 401
[ 0.049353] CPU2: Booted secondary processor [410fd034]
[ 0.059312] Detected VIPT I-cache on CPU3
[ 0.059331] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059357] CPU3: using LPI pending table @0x00000000002e0000
[ 0.059380] CPU3: update cpu_capacity 401
[ 0.059384] CPU3: Booted secondary processor [410fd034]
[ 0.069362] Detected PIPT I-cache on CPU4
[ 0.069387] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069425] CPU4: using LPI pending table @0x0000000000330000
[ 0.069462] CPU4: update cpu_capacity 1024
[ 0.069465] CPU4: Booted secondary processor [410fd082]
[ 0.079388] Detected PIPT I-cache on CPU5
[ 0.079405] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079440] CPU5: using LPI pending table @0x0000000000360000
[ 0.079465] CPU5: update cpu_capacity 1024
[ 0.079468] CPU5: Booted secondary processor [410fd082]
[ 0.079550] Brought up 6 CPUs
[ 0.091852] SMP: Total of 6 processors activated.
[ 0.092302] CPU features: detected feature: GIC system register CPU interface
[ 0.092980] CPU features: detected feature: 32-bit EL0 Support
[ 0.093547] CPU: All CPU(s) started at EL2
[ 0.093974] alternatives: patching kernel code
[ 0.096256] devtmpfs: initialized
[ 0.117998] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.118946] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.120715] pinctrl core: initialized pinctrl subsystem
[ 0.123990] Failed to find legacy iommu devices
[ 0.124916] NET: Registered protocol family 16
[ 0.125927] schedtune: init normalization constants…
[ 0.126422] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.127043] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.127678] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.128300] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.128921] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.129589] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.130204] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.130816] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.131426] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.132035] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.132751] schedtune: verify normalization constants…
[ 0.133259] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.133783] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.134303] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.134826] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.135346] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.135866] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.136388] schedtune: configured to support 5 boost groups
[ 0.146941] cpuidle: using governor ladder
[ 0.160312] cpuidle: using governor menu
[ 0.160729] Registered FIQ tty driver
[ 0.161622] vdso: 2 pages (1 code @ ffffff8008b06000, 1 data @ ffffff80090b4000)
[ 0.162350] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.163757] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.191319] console [pstore-1] enabled
[ 0.191901] pstore: Registered ramoops as persistent store backend
[ 0.192486] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.195116] fiq debugger fiq mode enabled
[[ 0.195805] console [ttyFIQ0] enabled
[ 0.196477] bootconsole [uart0] disabled
[ 0.197026] Registered fiq debugger ttyFIQ0
[ 0.231181] iommu: Adding device ff650000.vpu_service to group 0
[ 0.231274] iommu: Adding device ff660000.rkvdec to group 1
[ 0.231357] iommu: Adding device ff670000.iep to group 2
[ 0.231461] iommu: Adding device ff8f0000.vop to group 3
[ 0.231545] iommu: Adding device ff900000.vop to group 4
[ 0.231668] iommu: Adding device ff910000.isp to group 5
[ 0.231752] iommu: Adding device ff920000.isp to group 6
[ 0.232165] rk_iommu ff650800.iommu: can’t get sclk
[ 0.232401] rk_iommu ff660480.iommu: can’t get sclk
[ 0.232496] rk_iommu ff670800.iommu: can’t get aclk
[ 0.232508] rk_iommu ff670800.iommu: can’t get hclk
[ 0.232518] rk_iommu ff670800.iommu: can’t get sclk
[ 0.232678] rk_iommu ff8f3f00.iommu: can’t get sclk
[ 0.232826] rk_iommu ff903f00.iommu: can’t get sclk
[ 0.232971] rk_iommu ff914000.iommu: can’t get sclk
[ 0.233122] rk_iommu ff924000.iommu: can’t get sclk
[ 0.233420] SCSI subsystem initialized
[ 0.233790] usbcore: registered new interface driver usbfs
[ 0.233834] usbcore: registered new interface driver hub
[ 0.233900] usbcore: registered new device driver usb
[ 0.234286] media: Linux media interface: v0.10
[ 0.234327] Linux video capture interface: v2.00
[ 0.234511] pps_core: LinuxPPS API ver. 1 registered
[ 0.234520] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.234539] PTP clock support registered
[ 0.236754] Bluetooth: Core ver 2.21
[ 0.236799] NET: Registered protocol family 31
[ 0.236808] Bluetooth: HCI device and connection manager initialized
[ 0.236823] Bluetooth: HCI socket layer initialized
[ 0.236835] Bluetooth: L2CAP socket layer initialized
[ 0.236861] Bluetooth: SCO socket layer initialized
[ 0.237590] rockchip-cpuinfo cpuinfo: Serial : 0d42248dbbe127d5
[ 0.237996] clocksource: Switched to clocksource arch_sys_counter
[ 0.282202] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.282436] NET: Registered protocol family 2
[ 0.282869] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.283014] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.283289] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.283367] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.283426] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.283608] NET: Registered protocol family 1
[ 0.284964] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.285051] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.287925] audit: initializing netlink subsys (disabled)
[ 0.288006] audit: type=2000 audit(0.283:1): initialized
[ 0.293180] VFS: Disk quotas dquot_6.6.0
[ 0.293315] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.294319] Registering sdcardfs 0.1
[ 0.294879] fuse init (API version 7.23)
[ 0.296054]
[ 0.296054] TEE Core Framework initialization (ver 1:0.1)
[ 0.296085] TEE armv7 Driver initialization
[ 0.296467] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.296488] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.296661] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.300746] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.300772] io scheduler noop registered
[ 0.300934] io scheduler cfq registered (default)
[ 0.304848] iep: failed to find iep power down clock source.
[ 0.305232] IEP Power ON
[ 0.305408] IEP Power OFF
[ 0.305497] IEP Driver loaded succesfully
[ 0.305623] Module initialized.
[ 0.305894] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.306113] rk-vcodec ff650000.vpu_service: probe device
[ 0.306288] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 0.306792] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.306810] rk-vcodec ff650000.vpu_service: init success
[ 0.306994] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.307373] rk-vcodec ff660000.rkvdec: probe device
[ 0.307549] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 0.307931] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.307947] rk-vcodec ff660000.rkvdec: init success
[ 0.309380] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.309402] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.310736] dma-pl330 ff6e0000.dma-controller: Loaded drivec+#kr PL330 DMAC-241330
[ 0.310758] dma-pl330 ff6e0000.dma-controller: �Ks;FK128x[ 0.314371] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.314707] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
[ 0.314728] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[ 0.314741] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer on device rockchip-pinctrl
[ 0.314751] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
[ 0.315037] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 38, base_baud = 1500000) is a 16550A
[ 0.315501] [drm] Initialized drm 1.1.0 20060810
[ 0.319083] [drm] Rockchip DRM driver version: v1.0.1
[ 0.321775] Unable to detect cache hierarchy for CPU 0
[ 0.329805] brd: module loaded
[ 0.334699] loop: module loaded
[ 0.335212] zram: Added device: zram0
[ 0.336137] SCSI Media Changer driver v0.25
[ 0.337473] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 0.337496] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 0.337506] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 0.338044] rockchip-spi ff1e0000.spi: Failed to request TX DMA channel
[ 0.338064] rockchip-spi ff1e0000.spi: Failed to request RX DMA channel
[ 0.338073] rockchip-spi ff1e0000.spi: no high_speed pinctrl state
[ 0.338724] tun: Universal TUN/TAP device driver, 1.6
[ 0.338733] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.339752] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 0.339776] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 0.339787] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 0.339812] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 0.339968] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 0.339982] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 0.344997] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 0.345114] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.345121] Ring mode enabled
[ 0.345129] DMA HW capability register supported
[ 0.345136] Normal descriptors
[ 0.345145] RX Checksum Offload Engine supported (type 2)
[ 0.345152] TX Checksum insertion supported
[ 0.345158] Wake-Up On Lan supported
[ 0.345201] Enable RX Mitigation via HW Watchdog Timer
[ 0.414019] libphy: stmmac: probed
[ 0.414049] eth%d: No PHY found
[ 0.414771] PPP generic driver version 2.4.2
[ 0.415027] PPP BSD Compression module registered
[ 0.415068] PPP Deflate Compression module registered
[ 0.415114] PPP MPPE Compression module registered
[ 0.415142] NET: Registered protocol family 24
[ 0.415212] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.415222] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.415243] Rockchip WiFi SYS interface (V1.00) …
[ 0.415400] usbcore: registered new interface driver catc
[ 0.415469] usbcore: registered new interface driver kaweth
[ 0.415489] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.415541] usbcore: registered new interface driver pegasus
[ 0.415608] usbcore: registered new interface driver rtl8150
[ 0.415664] usbcore: registered new interface driver r8152
[ 0.415682] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.415762] usbcore: registered new interface driver hso
[ 0.415836] usbcore: registered new interface driver asix
[ 0.415893] usbcore: registered new interface driver ax88179_178a
[ 0.415949] usbcore: registered new interface driver cdc_ether
[ 0.416009] usbcore: registered new interface driver cdc_eem
[ 0.416081] usbcore: registered new interface driver dm9601
[ 0.416149] usbcore: registered new interface driver smsc75xx
[ 0.416221] usbcore: registered new interface driver smsc95xx
[ 0.416287] usbcore: registered new interface driver gl620a
[ 0.416349] usbcore: registered new interface driver net1080
[ 0.416410] usbcore: registered new interface driver plusb
[ 0.416482] usbcore: registered new interface driver rndis_host
[ 0.416539] usbcore: registered new interface driver cdc_subset
[ 0.416595] usbcore: registered new interface driver zaurus
[ 0.416657] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.416752] usbcore: registered new interface driver int51x1
[ 0.416810] usbcore: registered new interface driver kalmia
[ 0.416872] usbcore: registered new interface driver ipheth
[ 0.416941] usbcore: registered new interface driver sierra_net
[ 0.416999] usbcore: registered new interface driver cx82310_eth
[ 0.417074] usbcore: registered new interface driver cdc_ncm
[ 0.417142] usbcore: registered new interface driver qmi_wwan
[ 0.417201] usbcore: registered new interface driver cdc_mbim
[ 0.419047] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 0.420291] rockchip-dwc3 usb1: failed to get drvdata dwc3
[ 0.421569] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.421593] ehci-pci: EHCI PCI platform driver
[ 0.421683] ehci-platform: EHCI generic platform driver
[ 0.422421] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.422457] ohci-platform: OHCI generic platform driver
[ 0.423545] usbcore: registered new interface driver cdc_acm
[ 0.423564] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.423635] usbcore: registered new interface driver usblp
[ 0.423691] usbcore: registered new interface driver cdc_wdm
[ 0.423755] usbcore: registered new interface driver uas
[ 0.423831] usbcore: registered new interface driver usb-storage
[ 0.423881] usbcore: registered new interface driver ums-alauda
[ 0.423932] usbcore: registered new interface driver ums-cypress
[ 0.423985] usbcore: registered new interface driver ums-datafab
[ 0.424041] usbcore: registered new interface driver ums_eneub6250
[ 0.424093] usbcore: registered new interface driver ums-freecom
[ 0.424147] usbcore: registered new interface driver ums-isd200
[ 0.424202] usbcore: registered new interface driver ums-jumpshot
[ 0.424258] usbcore: registered new interface driver ums-karma
[ 0.424307] usbcore: registered new interface driver ums-onetouch
[ 0.424358] usbcore: registered new interface driver ums-sddr09
[ 0.424412] usbcore: registered new interface driver ums-sddr55
[ 0.424468] usbcore: registered new interface driver ums-usbat
[ 0.424570] usbcore: registered new interface driver usbserial
[ 0.424619] usbcore: registered new interface driver usbserial_generic
[ 0.424699] usbserial: USB Serial support registered for generic
[ 0.424752] usbcore: registered new interface driver option
[ 0.424789] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.424848] usbcore: registered new interface driver trancevibrator
[ 0.424879] usb20_otg: version 3.10a 21-DEC-2012
[ 0.425108] usb20_host: version 3.10a 21-DEC-2012
[ 0.425753] usbcore: registered new interface driver xpad
[ 0.425821] usbcore: registered new interface driver usb_acecad
[ 0.425885] usbcore: registered new interface driver aiptek
[ 0.425945] usbcore: registered new interface driver gtco
[ 0.426005] usbcore: registered new interface driver hanwang
[ 0.426067] usbcore: registered new interface driver kbtab
[ 0.426630] .. rk pwm remotectl v1.1 init
[ 0.426950] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 0.427457] sensor_register_slave:kxtj9,id=11
[ 0.427484] sensor_register_slave:mma8452,id=17
[ 0.427501] sensor_register_slave:lis3dh,id=7
[ 0.427516] sensor_register_slave:mma7660,id=18
[ 0.427532] sensor_register_slave:lsm303d,id=22
[ 0.427547] sensor_register_slave:gs_mc3230,id=23
[ 0.427555] [Gsensor] gsensor_init
[ 0.427563] &&&&&&&&&&&TEST&&&&&&&&&&&
[ 0.427579] sensor_register_slave:mpu6880_acc,id=24
[ 0.427595] sensor_register_slave:mpu6500_acc,id=25
[ 0.427612] sensor_register_slave:lsm330_acc,id=26
[ 0.427639] sensor_register_slave:bma2xx_acc,id=27
[ 0.427654] sensor_register_slave:akm8975,id=30
[ 0.427670] sensor_register_slave:akm8963,id=31
[ 0.427686] sensor_register_slave:l3g4200d,id=45
[ 0.427701] sensor_register_slave:l3g20d,id=46
[ 0.427716] sensor_register_slave:ewtsa,id=47
[ 0.427732] sensor_register_slave:lsm330_gyro,id=51
[ 0.427747] sensor_register_slave:cm3217,id=53
[ 0.427763] sensor_register_slave:cm3218,id=54
[ 0.427779] sensor_register_slave:ls_stk3410,id=62
[ 0.427795] sensor_register_slave:ps_stk3410,id=67
[ 0.428754] i2c /dev entries driver
[ 0.430243] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 0.430305] fan53555-reg: supplied by vcc3v3_sys
[ 0.432391] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 0.432466] fan53555-reg: supplied by vcc3v3_sys
[ 0.434190] DBUG*******************************
[ 0.434220] ******DBUG rk818 match
[ 0.434522] rk808 0-001c: Pmic Chip id: 0x8180
[ 0.434884] rk808 0-001c: source: on=0x40, off=0x00
[ 0.437061] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.437141] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.437236] DCDC_REG1: supplied by vcc3v3_sys
[ 0.438121] DCDC_REG2: supplied by vcc3v3_sys
[ 0.439011] DCDC_REG3: supplied by vcc3v3_sys
[ 0.439714] DCDC_REG4: supplied by vcc3v3_sys
[ 0.441136] LDO_REG1: supplied by vcc3v3_sys
[ 0.442536] LDO_REG2: supplied by vcc3v3_sys
[ 0.443956] LDO_REG3: supplied by vcc3v3_sys
[ 0.445379] LDO_REG4: supplied by vcc3v3_sys
[ 0.446775] LDO_REG5: supplied by vcc3v3_sys
[ 0.448197] LDO_REG6: supplied by vcc3v3_sys
[ 0.449595] LDO_REG7: supplied by vcc3v3_sys
[ 0.450996] LDO_REG8: supplied by vcc3v3_sys
[ 0.452721] LDO_REG9: supplied by vcc3v3_sys
[ 0.454010] SWITCH_REG: supplied by vcc3v3_sys
[ 0.457084] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 0.463781] rk818-bat: initialized yet..
[ 0.465336] rk818-bat: dsoc=24 cap=0 v=4167 ov=3007 rv=0 min=0 psoc=24 pcap=0
[ 0.471789] rk818-bat: driver version 7.1
[ 0.475265] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 0.476071] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff800978a000
[ 0.476614] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff800978c000
[ 0.477148] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff800978e000
[ 0.478304] fusb302 7-0022: Can’t get property of role, set role to default DRP
[ 0.478419] fusb302 7-0022: fusb302 send extcon to disable vbus 5v
[ 0.479839] fusb302 7-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 0.480078] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff8009790000
[ 0.481779] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 0.484917] fusb302 4-0022: port 1 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 0.484950] i2c i2c-4: of_i2c: invalid reg on /i2c@ff3d0000/spidev@00
[ 0.484970] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009792000
[ 0.485976] IR NEC protocol handler initialized
[ 0.485992] IR RC5(x/sz) protocol handler initialized
[ 0.486007] IR RC6 protocol handler initialized
[ 0.486022] IR JVC protocol handler initialized
[ 0.486037] IR Sony protocol handler initialized
[ 0.486047] IR SANYO protocol handler initialized
[ 0.486058] IR Sharp protocol handler initialized
[ 0.486069] IR MCE Keyboard/mouse protocol handler initialized
[ 0.486079] IR XMP protocol handler initialized
[ 0.486279] usbcore: registered new interface driver uvcvideo
[ 0.486287] USB Video Class driver (1.1.1)
[ 0.486301] CamSys driver version: v0.48.0, CamSys head file version: v1.0.0
[ 0.490403] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 0.490539] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 0.490802] thermal thermal_zone3: power_allocator: sustainable_power will be estimated
[ 0.490895] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 0.491100] cw201x 2-0062: design_capacity missing!
[ 0.628912] random: nonblocking pool is initialized
[ 2.281970] cw_bat_probe cw_init error
[ 2.282198] rk818-charger rk818-charger: otg5v_suspend_enable missing!
[ 2.282391] rk818-charger: not support dc
[ 2.282663] rk818-charger supply otg_switch not found, using dummy regulator
[ 2.282998] rk818-charger: receive type-c notifier event: OTG OFF…
[ 2.283012] rk818-charger: otg5v is off yet, ignore..
[ 2.283056] rk818-charger: register typec extcon evt notifier
[ 2.283307] rk818-charger: ac=0 usb=0 dc=0 otg=0 5v=0, v=4200 chrg=2000 input=2000 virt=1
[ 2.284934] rk818-charger: warning: virtual power mode…
[ 2.285370] rk818-charger: ac=0, usb=0, dc=0, otg=0, 5v=0
[ 2.286832] rk818-charger: driver version: 2.0
[ 2.292024] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 2.292293] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 2.293376] device-mapper: uevent: version 1.0.3
[ 2.293877] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.294086] Bluetooth: HCI UART driver ver 2.3
[ 2.294123] Bluetooth: HCI UART protocol H4 registered
[ 2.294133] Bluetooth: HCI UART protocol LL registered
[ 2.294158] rtk_btusb: RTKBT_RELEASE_NAME: 20180702_BT_ANDROID_8.1
[ 2.294172] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.5
[ 2.294180] rtk_btusb: Register usb char device interface for BT driver
[ 2.294528] usbcore: registered new interface driver rtk_btusb
[ 2.295371] cpu cpu0: bin=1
[ 2.295483] cpu cpu0: leakage=27
[ 2.308388] cpu cpu0: temp=42777, pvtm=148172 (148106 + 66)
[ 2.309251] cpu cpu0: pvtm-volt-sel=1
[ 2.309402] cpu cpu0: bin-scale=34
[ 2.309968] cpu cpu4: bin=1
[ 2.310065] cpu cpu4: leakage=47
[ 2.323137] cpu cpu4: temp=42777, pvtm=163164 (163129 + 35)
[ 2.324395] cpu cpu4: pvtm-volt-sel=3
[ 2.324547] cpu cpu4: bin-scale=17
[ 2.326996] cpu cpu0: avs=0, target-scale=34
[ 2.327149] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.329770] cpu cpu4: avs=0, target-scale=17
[ 2.329935] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.332363] sdhci: Secure Digital Host Controller Interface driver
[ 2.332404] sdhci: Copyright(c) Pierre Ossman
[ 2.332423] Synopsys Designware Multimedia Card Interface Driver
[ 2.334203] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.334468] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.334508] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.334566] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.334600] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.334945] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 2.348094] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.362467] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.363156] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.365626] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.365663] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.394752] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.398896] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.407132] usbcore: registered new interface driver usbhid
[ 2.407191] usbhid: USB HID core driver
[ 2.408516] inv_mpu_iio: inv_mpu_init:746
[ 2.409965] ashmem: initialized
[ 2.413590] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 2.418318] ff100000.saradc supply vref not found, using dummy regulator
[ 2.421050] rknandbase v1.2 2018-05-08
[ 2.422066] u32 classifier
[ 2.422127] Actions configured
[ 2.422217] Netfilter messages via NETLINK v0.30.
[ 2.422408] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.423043] ctnetlink v0.93: registering with nfnetlink.
[ 2.424179] xt_time: kernel timezone is -0000
[ 2.425376] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.425714] arp_tables: (C) 2002 David S. Miller
[ 2.426021] Initializing XFRM netlink socket
[ 2.426732] NET: Registered protocol family 10
[ 2.427924] mip6: Mobile IPv6
[ 2.427980] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.429553] sit: IPv6 over IPv4 tunneling driver
[ 2.430313] NET: Registered protocol family 17
[ 2.430406] NET: Registered protocol family 15
[ 2.430473] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.431545] Bridge firewalling registered
[ 2.431608] Ebtables v2.0 registered
[ 2.431890] Bluetooth: RFCOMM TTY layer initialized
[ 2.431937] Bluetooth: RFCOMM socket layer initialized
[ 2.431979] Bluetooth: RFCOMM ver 1.11
[ 2.432013] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.432026] Bluetooth: BNEP filters: protocol multicast
[ 2.432052] Bluetooth: BNEP socket layer initialized
[ 2.432072] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.432119] Bluetooth: HIDP socket layer initialized
[ 2.432174] l2tp_core: L2TP core driver, V2.0
[ 2.432199] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.432226] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.432794] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.433269] sensor_register_slave:mpu6500_gyro,id=49
[ 2.433299] sensor_register_slave:mpu6880_gyro,id=50
[ 2.435253] Registered cp15_barrier emulation handler
[ 2.435348] Registered setend emulation handler
[ 2.435921] mmc1: MAN_BKOPS_EN bit is not set
[ 2.436402] registered taskstats version 1
[ 2.437499] rockchip ion idev is NULL
[ 2.437517] rga2 ff680000.rga: rga ion client create success!
[ 2.437871] rga: Driver loaded successfully ver:3.02
[ 2.438168] rga2: Module initialized.
[ 2.439991] phy phy-ff770000.syscon:usb2-phy@e450.3: Failed to get VBUS supply regulator
[ 2.442517] phy phy-ff770000.syscon:usb2-phy@e460.5: Failed to get VBUS supply regulator
[ 2.445716] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 2.447841] rockchip-dwc3 usb1: failed to get drvdata dwc3
[ 2.449344] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 2.450524] mmcblk1: mmc1:0001 DG4008 7.28 GiB
[ 2.451029] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.451229] mmcblk1boot0: mmc1:0001 DG4008 partition 1 4.00 MiB
[ 2.451536] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 2.451944] ehci-platform fe380000.usb: irq 27, io mem 0xfe380000
[ 2.452057] mmcblk1boot1: mmc1:0001 DG4008 partition 2 4.00 MiB
[ 2.452786] mmcblk1rpmb: mmc1:0001 DG4008 partition 3 4.00 MiB
[ 2.454777] Alternate GPT is invalid, using primary GPT.
[ 2.454905] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19
[ 2.461540] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.461849] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.461908] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.461931] usb usb1: Product: EHCI Host Controller
[ 2.461951] usb usb1: Manufacturer: Linux 4.4.167 ehci_hcd
[ 2.462004] usb usb1: SerialNumber: fe380000.usb
[ 2.462877] hub 1-0:1.0: USB hub found
[ 2.462966] hub 1-0:1.0: 1 port detected
[ 2.466313] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 2.466628] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 2.467178] ehci-platform fe3c0000.usb: irq 29, io mem 0xfe3c0000
[ 2.474780] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.475014] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.475072] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.475290] usb usb2: Product: EHCI Host Controller
[ 2.475511] usb usb2: Manufacturer: Linux 4.4.167 ehci_hcd
[ 2.475729] usb usb2: SerialNumber: fe3c0000.usb
[ 2.476576] hub 2-0:1.0: USB hub found
[ 2.476686] hub 2-0:1.0: 1 port detected
[ 2.477964] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.478391] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 2.478756] ohci-platform fe3a0000.usb: irq 28, io mem 0xfe3a0000
[ 2.535640] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.535732] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.535949] usb usb3: Product: Generic Platform OHCI controller
[ 2.536167] usb usb3: Manufacturer: Linux 4.4.167 ohci_hcd
[ 2.536386] usb usb3: SerialNumber: fe3a0000.usb
[ 2.537381] hub 3-0:1.0: USB hub found
[ 2.537582] hub 3-0:1.0: 1 port detected
[ 2.539118] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 2.539579] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 2.540020] ohci-platform fe3e0000.usb: irq 30, io mem 0xfe3e0000
[ 2.595860] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.595996] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.596215] usb usb4: Product: Generic Platform OHCI controller
[ 2.596438] usb usb4: Manufacturer: Linux 4.4.167 ohci_hcd
[ 2.596662] usb usb4: SerialNumber: fe3e0000.usb
[ 2.598545] hub 4-0:1.0: USB hub found
[ 2.598769] hub 4-0:1.0: 1 port detected
[ 2.601522] rockchip-dmc dmc: Failed to get leakage
[ 2.601939] rockchip-dmc dmc: Failed to get pvtm
[ 2.602859] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 2.603377] rockchip-dmc dmc: could not find power_model node
[ 2.607586] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 2.610549] rockchip-dwc3 usb1: failed to get drvdata dwc3
[ 2.612968] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 09:26:02 UTC (1358501162)
[ 2.615703] It doesn’t contain Rogue gpu
[ 2.666216] vcc_sd: disabling
[ 2.666852] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko.
[ 2.667612] Mali: Mali device driver loaded
[ 2.668811] input: rk29-keypad as /devices/platform/rockchip-key/input/input1
[ 2.671239] 0100 8192 ram0 (driver?)
[ 2.671254] 0101 8192 ram1 (driver?)
[ 2.671275] 0102 8192 ram2 (driver?)
[ 2.671290] 0103 8192 ram3 (driver?)
[ 2.671301] 0104 8192 ram4 (driver?)
[ 2.671374] 0105 8192 ram5 (driver?)
[ 2.671386] 0106 8192 ram6 (driver?)
[ 2.671406] 0107 8192 ram7 (driver?)
[ 2.671421] 0108 8192 ram8 (driver?)
[ 2.671432] 0109 8192 ram9 (driver?)
[ 2.671451] 010a 8192 ram10 (driver?)
[ 2.671468] 010b 8192 ram11 (driver?)
[ 2.671480] 010c 8192 ram12 (driver?)
[ 2.671505] 010d 8192 ram13 (driver?)
[ 2.671520] 010e 8192 ram14 (driver?)
[ 2.671531] 010f 8192 ram15 (driver?)
[ 2.671556] b300 7636800 mmcblk1 driver: mmcblk
[ 2.671573] b301 4096 mmcblk1p1 6115f139-4f47-4baf-8d23-b6957eaee4b3
[ 2.671584] b302 4096 mmcblk1p2 a83fba16-d354-45c5-8b44-3ec50832d363
[ 2.671604] b303 4096 mmcblk1p3 500e2214-b72d-4cc3-d7c1-8419260130f5
[ 2.671619] b304 16384 mmcblk1p4 e099da71-5450-44ea-aa9f-1b771c582805
[ 2.671629] b305 32768 mmcblk1p5 af12d156-5d5b-4ee3-b415-8d492ca12ea9
[ 2.671649] b306 4096 mmcblk1p6 8eb9ee49-e963-4bb6-fd75-f30618df9dcd
[ 2.671664] b307 4096 mmcblk1p7 6c36c03f-066e-4448-bf41-0bb95dccabc3
[ 2.671675] b308 1024 mmcblk1p8 f2df5432-4913-45f8-aee6-d9b4369d6efa
[ 2.671697] b309 32768 mmcblk1p9 94414b7e-b134-4095-a5ad-d8ee067c8de5
[ 2.671714] b30a 65536 mmcblk1p10 d4b4790f-534c-48d3-bdbc-9a754f50728a
[ 2.671725] b30b 114688 mmcblk1p11 ecac0550-6419-41b8-e417-25f1288d46bb
[ 2.671736] b30c 4096 mmcblk1p12 1607c452-434f-4fb2-ae03-8d341335c04f
[ 2.671747] b30d 524288 mmcblk1p13 d823d771-7b6a-4dd7-b260-e6a55e5bd61f
[ 2.671758] b30e 2621440 mmcblk1p14 99ecbf63-5e3c-4aa1-ef0b-3a614ca36b5e
[ 2.671769] b30f 16384 mmcblk1p15 d404101f-0e49-4454-bd61-3ea352733cff
[ 2.671779] b310 524288 mmcblk1p16 819fcf71-1a63-46e1-e154-eccf47f8273a
[ 2.671794] b311 524288 mmcblk1p17 8caa0e48-3b01-4d8d-f175-fb6a3eca0d3c
[ 2.671805] b312 512 mmcblk1p18 17defb15-2010-48d3-945b-d4d175e8fbbe
[ 2.671825] b313 3128815 mmcblk1p19 2da0b519-c771-49b1-e2d3-6d1f730e380c
[ 2.671849] b360 4096 mmcblk1rpmb (driver?)
[ 2.671868] b340 4096 mmcblk1boot1 (driver?)
[ 2.671884] b320 4096 mmcblk1boot0 (driver?)
[ 2.671894] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 2.673218] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 2.674427] rockchip-dwc3 usb1: failed to get drvdata dwc3
[ 2.694834] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.167 #50
[ 2.695376] Hardware name: roc-rk3399-pc (Android) (DT)
[ 2.695839] Call trace:
[ 2.696073] [] dump_backtrace+0x0/0x1ec
[ 2.696552] [] show_stack+0x14/0x1c
[ 2.697008] [] dump_stack+0x94/0xbc
[ 2.697463] [] panic+0xec/0x240
[ 2.697886] [] mount_block_root+0x23c/0x2c4
[ 2.698396] [] mount_root+0x70/0x80
[ 2.698848] [] prepare_namespace+0x1a4/0x1b4
[ 2.699369] [] kernel_init_freeable+0x1e8/0x224
[ 2.699916] [] kernel_init+0x10/0xf8
[ 2.700370] [] ret_from_fork+0x10/0x30
[ 2.700848] CPU1: stopping
[ 2.701104] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.4.167 #50
[ 2.701646] Hardware name: roc-rk3399-pc (Android) (DT)
[ 2.702107] Call trace:
[ 2.702333] [] dump_backtrace+0x0/0x1ec
[ 2.702810] [] show_stack+0x14/0x1c
[ 2.703262] [] dump_stack+0x94/0xbc
[ 2.703717] [] handle_IPI+0x10c/0x2b0
[ 2.704181] [] gic_handle_irq+0xe4/0x144
[ 2.704667] Exception stack(0xffffffc00022fdd0 to 0xffffffc00022ff00)
[ 2.705235] fdc0: 0000004075e82000 00000000ffffffff
[ 2.705928] fde0: ffffffc07ef0bec0 ffffffc07ef0bec0 00ffffffffffffff 0000000005fa3ff5
[ 2.706620] fe00: 0000000000000642 00000000000000c0 ffffffc00021a520 ffffffc00022fee0
[ 2.707313] fe20: 00000000000009c0 000000000004537a 0000000000000002 0000000000000001
[ 2.708005] fe40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 2.708698] fe60: ffffffc07c14591c 00000000a0e78ad0 0000000000000000 ffffffc07c1df400
[ 2.709390] fe80: 0000000000000000 00000000a0be8488 ffffff80091db578 0000000000000018
[ 2.710083] fea0: 00000000034a0000 0000000002af3234 0000000000000000 ffffffc00022ff00
[ 2.710775] fec0: ffffff800877df08 ffffffc00022ff00 ffffff800877df3c 0000000060400045
[ 2.711468] fee0: ffffff80091db590 0000000000000000 ffffffffffffffff 0000000000000000
[ 2.712159] [] el1_irq+0xec/0x190
[ 2.712593] [] cpuidle_enter_state+0x15c/0x2c0
[ 2.713125] [] cpuidle_enter+0x18/0x20
[ 2.713603] [] call_cpuidle+0x48/0x50
[ 2.714067] [] cpu_startup_entry+0x274/0x35c
[ 2.714588] [] secondary_start_kernel+0x1ac/0x1d8
[ 2.715144] [<0000000002af3178>] 0x2af3178
[ 2.715505] CPU2: stopping
[ 2.715754] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.4.167 #50
[ 2.716295] Hardware name: roc-rk3399-pc (Android) (DT)
[ 2.716757] Call trace:
[ 2.716983] [] dump_backtrace+0x0/0x1ec
[ 2.717460] [] show_stack+0x14/0x1c
[ 2.717912] [] dump_stack+0x94/0xbc
[ 2.718365] [] handle_IPI+0x10c/0x2b0
[ 2.718829] [] gic_handle_irq+0xe4/0x144
[ 2.719315] Exception stack(0xffffffc000233dd0 to 0xffffffc000233f00)
[ 2.719881] 3dc0: 0000000000000000 ffffffc00021a880
[ 2.720574] 3de0: ffffff80087a0750 0000000000000020 00ffffffffffffff 0000000005fa3ff5
[ 2.721266] 3e00: 0000000000000642 0000000000000002 00000032b5593519 ffffff8008081800
[ 2.721959] 3e20: 0000000000001000 0000000000000000 0000000034d5d91d 0000004075e97000
[ 2.722651] 3e40: ffffffc00021a880 0000000000000000 0000000000000000 0000000000000000
[ 2.723344] 3e60: 0000000030d00800 00000000a0e8411b 0000000000000002 ffffffc07c1df600
[ 2.724036] 3e80: 0000000000000001 00000000a0bcc832 ffffff80091db578 0000000000000018
[ 2.724729] 3ea0: 00000000034a0000 0000000002af3234 0000000000000000 ffffffc000233f00
[ 2.725421] 3ec0: ffffff800877df38 ffffffc000233f00 ffffff800877df3c 0000000040400045
[ 2.726114] 3ee0: 0000000000000018 00000000034a0000 ffffffffffffffff ffffff800877df38
[ 2.726806] [] el1_irq+0xec/0x190
[ 2.727236] [] cpuidle_enter_state+0x15c/0x2c0
[ 2.727769] [] cpuidle_enter+0x18/0x20
[ 2.728244] [] call_cpuidle+0x48/0x50
[ 2.728708] [] cpu_startup_entry+0x274/0x35c
[ 2.729229] [] secondary_start_kernel+0x1ac/0x1d8
[ 2.729784] [<0000000002af3178>] 0x2af3178
[ 2.730145] CPU3: stopping
[ 2.730394] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4.167 #50
[ 2.730936] Hardware name: roc-rk3399-pc (Android) (DT)
[ 2.731397] Call trace:
[ 2.731623] [] dump_backtrace+0x0/0x1ec
[ 2.732100] [] show_stack+0x14/0x1c
[ 2.732552] [] dump_stack+0x94/0xbc
[ 2.733005] [] handle_IPI+0x10c/0x2b0
[ 2.733469] [] gic_handle_irq+0xe4/0x144
[ 2.733955] Exception stack(0xffffffc000237dd0 to 0xffffffc000237f00)
[ 2.734522] 7dc0: 0000000000000000 ffffffc00021b600
[ 2.735214] 7de0: ffffff80087a0750 0000000000000020 00ffffffffffffff 0000000005fa3ff5
[ 2.735907] 7e00: 0000000000000642 0000000000000003 00000032b5593519 ffffff8008081800
[ 2.736599] 7e20: 0000000000001000 0000000000000000 0000000034d5d91d 0000004075eac000
[ 2.737292] 7e40: ffffffc00021b600 0000000000000000 0000000000000000 0000000000000000
[ 2.737984] 7e60: 0000000030d00800 00000000a0e89323 0000000000000002 ffffffc07c1df800
[ 2.738677] 7e80: 0000000000000001 000000009ba9e778 ffffff80091db578 0000000000000018
[ 2.739369] 7ea0: 00000000034a0000 0000000002af3234 0000000000000000 ffffffc000237f00
[ 2.740062] 7ec0: ffffff800877df38 ffffffc000237f00 ffffff800877df3c 0000000040400045
[ 2.740754] 7ee0: 0000000000000018 00000000034a0000 ffffffffffffffff ffffff800877df38
[ 2.741446] [] el1_irq+0xec/0x190
[ 2.741877] [] cpuidle_enter_state+0x15c/0x2c0
[ 2.742410] [] cpuidle_enter+0x18/0x20
[ 2.742885] [] call_cpuidle+0x48/0x50
[ 2.743349] [] cpu_startup_entry+0x274/0x35c
[ 2.743871] [] secondary_start_kernel+0x1ac/0x1d8
[ 2.744425] [<0000000002af3178>] 0x2af3178
[ 2.744795] CPU4: stopping
[ 2.745068] CPU: 4 PID: 0 Comm: swapper/4 Not tainted 4.4.167 #50
[ 2.745611] Hardware name: roc-rk3399-pc (Android) (DT)
[ 2.746081] Call trace:
[ 2.746329] [] dump_backtrace+0x0/0x1ec
[ 2.746818] [] show_stack+0x14/0x1c
[ 2.747281] [] dump_stack+0x94/0xbc
[ 2.747742] [] handle_IPI+0x10c/0x2b0
[ 2.748215] [] gic_handle_irq+0xe4/0x144
[ 2.748710] Exception stack(0xffffffc00023bdd0 to 0xffffffc00023bf00)
[ 2.749293] bdc0: 0000000000000000 ffffffc00021c380
[ 2.750000] bde0: ffffff80087a0750 0000000000000020 00ffffffffffffff 0000000005fa3ff5
[ 2.750707] be00: 0000000000000642 0000000000000004 00000034b5593519 ffffff8008081800
[ 2.751413] be20: 0000000000001000 0000000000000000 0000000034d5d91d 0000004075ec1000
[ 2.752118] be40: ffffffc00021c380 0000000000000000 0000000000000000 0000000000000000
[ 2.752823] be60: 0000000030d00800 00000000a0e96fd7 0000000000000002 ffffffc07c1dfa00
[ 2.753528] be80: 0000000000000001 00000000a0bf7595 ffffff80091db578 0000000000000018
[ 2.754232] bea0: 00000000034a0000 0000000002af3234 0000000000000000 ffffffc00023bf00
[ 2.754938] bec0: ffffff800877df38 ffffffc00023bf00 ffffff800877df3c 0000000040400045
[ 2.755643] bee0: 0000000000000018 00000000034a0000 ffffffffffffffff ffffff800877df38
[ 2.756343] [] el1_irq+0xec/0x190
[ 2.756794] [] cpuidle_enter_state+0x15c/0x2c0
[ 2.757338] [] cpuidle_enter+0x18/0x20
[ 2.757824] [] call_cpuidle+0x48/0x50
[ 2.758297] [] cpu_startup_entry+0x274/0x35c
[ 2.758819] [] secondary_start_kernel+0x1ac/0x1d8
[ 2.759385] [<0000000002af3178>] 0x2af3178
[ 2.759763] CPU5: stopping
[ 2.760031] CPU: 5 PID: 0 Comm: swapper/5 Not tainted 4.4.167 #50
[ 2.760575] Hardware name: roc-rk3399-pc (Android) (DT)
[ 2.761044] Call trace:
[ 2.761285] [] dump_backtrace+0x0/0x1ec
[ 2.761774] [] show_stack+0x14/0x1c
[ 2.762236] [] dump_stack+0x94/0xbc
[ 2.762697] [] handle_IPI+0x10c/0x2b0
[ 2.763169] [] gic_handle_irq+0xe4/0x144
[ 2.763663] Exception stack(0xffffffc00023fdd0 to 0xffffffc00023ff00)
[ 2.764246] fdc0: 0000000000000000 ffffffc00021d100
[ 2.764954] fde0: ffffff80087a0750 0000000000000020 00ffffffffffffff 0000000005fa3ff5
[ 2.765660] fe00: 0000000000000642 0000000000000005 00000034b5593519 ffffff8008081800
[ 2.766366] fe20: 0000000000001000 0000000000000000 0000000034d5d91d 0000004075ed6000
[ 2.767071] fe40: ffffffc00021d100 0000000000000000 0000000000000000 0000000000000000
[ 2.767775] fe60: 0000000030d00800 00000000a0e9c1df 0000000000000002 ffffffc07c1dfc00
[ 2.768480] fe80: 0000000000000001 00000000a08e1354 ffffff80091db578 0000000000000018
[ 2.769185] fea0: 00000000034a0000 0000000002af3234 0000000000000000 ffffffc00023ff00
[ 2.769890] fec0: ffffff800877df38 ffffffc00023ff00 ffffff800877df3c 0000000040400045
[ 2.770596] fee0: 0000000000000018 00000000034a0000 ffffffffffffffff ffffff800877df38
[ 2.771296] [] el1_irq+0xec/0x190
[ 2.771746] [] cpuidle_enter_state+0x15c/0x2c0
[ 2.772290] [] cpuidle_enter+0x18/0x20
[ 2.772776] [] call_cpuidle+0x48/0x50
[ 2.773248] [] cpu_startup_entry+0x274/0x35c
[ 2.773770] [] secondary_start_kernel+0x1ac/0x1d8
[ 2.774336] [<0000000002af3178>] 0x2af3178
[ 2.774711] CRU:
[ 2.774888] 00000000: 00000032 00001101 80000000 00000108 00000007 00007f00 00000000 00000000
[ 2.775642] 00000020: 00000044 00002201 80000000 00000108 00000007 00007f00 00000000 00000000
[ 2.776396] 00000040: 00000064 00001301 8000031f 00000108 00000007 00007f00 00000000 00000000
[ 2.777150] 00000060: 000000c0 00001302 8000031f 00000008 00000007 00007f00 00000000 00000000
[ 2.777904] 00000080: 00000064 00001301 8000031f 00000108 00000007 00007f00 00000000 00000000
[ 2.778658] 000000a0: 0000004b 00001301 80000000 00000108 00000007 00007f00 00000000 00000000
[ 2.779411] 000000c0: 000000c6 00001202 8000031f 00000008 00000007 00007f00 00000000 00000000
[ 2.780165] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.780919] 00000100: 00000100 00000505 00000140 00006202 00000083 00008581 00008320 00000141
[ 2.781672] 00000120: 00000181 00008181 00000141 00000141 00004141 00008343 00003185 00000500
[ 2.782426] 00000140: 0000041d 00000300 00004a87 0000033f 00009381 00008387 00001103 00005282
[ 2.783180] 00000160: 00008247 00000187 00001743 0000001f 00000300 00000300 00000300 00000000
[ 2.783933] 00000180: 0000e300 00009200 00000200 00000200 00000200 00000200 00003f3f 00000081
[ 2.784687] 000001a0: 00000000 00000000 00004141 00000421 00008700 000002dc 00000005 00000381
[ 2.785441] 000001c0: 00000381 00000001 00000003 00000087 00000087 00000141 00000141 00008181
[ 2.786195] 000001e0: 00008323 00000007 00008f1f 00008f8f 00008f8f 00008787 00008787 00008787
[ 2.786948] 00000200: 000000c5 000000c5 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.787702] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.788455] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.789208] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.789962] 00000280: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60
[ 2.790716] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 00000000 00000000
[ 2.791469] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.792223] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.792977] 00000300: 00000080 00000080 00000202 0000006b 00000c30 000003e0 0000001d 000001c0
[ 2.793730] 00000320: 0000fff8 0000f0ff 0000f0df 0000c130 0000005e 0000e2f3 00000000 00000000
[ 2.794484] 00000340: 00000505 00000505 00001000 00000000 00000e04 0000000f 0000cfcb 00003f00
[ 2.795238] 00000360: 0000ef60 00000020 00000ffe 000001f0 000000cc 00000f86 00000d1e 000001b8
[ 2.795991] 00000380: 00002015 00000000 0000003f 00000000 00000000 00000000 00000000 00000000
[ 2.796745] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.797498] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.798252] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.799005] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.799758] 00000420: 000000bc 00007070 00000000 00000014 00000000 00000000 00000000 00000000
[ 2.800512] 00000440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.801266] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.802019] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.802772] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.803526] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.804279] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.805033] 00000500: 00000000 00000000 00640064 00000000 00000003 00000001 00000000 00000000
[ 2.805786] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.806539] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.807293] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.808044] 00000580: 00000004 00000000 00000004 00000000 00000004
[ 2.808585] PMU CRU:
[ 2.808793] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 00000000 00000000
[ 2.809548] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.810303] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.811058] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.811813] 00000080: 0000060d 00001986 00000303 00000003 000002dc 00000200 0bb8ea60 00010014
[ 2.812568] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.813324] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.814079] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.814834] 00000100: 00000ffc 0000fb80 0000000f 00000000 00000024 00000000 00000000 00000000
[ 2.815587] 00000120: 00000000 00000000 00000000 00000000 00000003
[ 2.816129] PMU:
[ 2.816303] 00000000: 00000000 00000000 00000000 00000000 00000000 9acf8300 9acf8300 00000000
[ 2.817058] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.817814] 00000040: 00000000 00000000 00000000 00000000 00000000 9acf833f 00000000 00000000
[ 2.818569] 00000060: 20c01679 20c01679 20c01679 00000010 00000000 00007e00 00000000 28800000
[ 2.819325] 00000080: 000003c0 00011940 00005dc0 000003c0 00005dc0 00000060 0000000f 00000018
[ 2.820080] 000000a0: 00000018 00000018 00000018 00000006 00000006 00005dc0 00005dc0 00005dc0
[ 2.820835] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 3fffffff 00000000
[ 2.821590] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.822338] Kernel Offset: disabled
[ 2.822651] Memory Limit: none
[ 2.822937] rockchip-thermal ff260000.tsadc: channal 0: temperature(42 C)
[ 2.823535] THERMAL REGS:
[ 2.823776] 00000000: 00001200 00030133 00000031 00000002 00000000 00000000 00000000 00000000
[ 2.824531] 00000020: 0000021f 0000021e 00000000 00000000 0000024e 00000000 00000000 00000000
[ 2.825285] 00000040: 000002a5 000002a5 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.826040] 00000060: 00000004 00000004 00000753 00000753 00000000 00000000 00000000 00000000
[ 2.826788] 00000080: 00000000 00000000
[ 2.838477] Rebooting in 5 seconds..
自己已经解决了 在dts中 bootargs = 后面加上
root=/dev/mmcblk1p14 rootfstype=ext4
mmcblk1p14 是文件系统所在分区
