08-06 00:19:43.009 353 1073 I CameraService: CameraService::connect call (PID -1 “com.android.camera2”, camera ID 0) for HAL version default and Camera API version 1
08-06 00:19:43.009 353 666 D CameraHal: camera_get_camera_info(1454): camera_get_camera_info(1454): camera_0 facing(0), orientation(180)
08-06 00:19:43.010 353 1073 D CameraHal: camera_get_number_of_cameras(1241): camera_get_number_of_cameras(1241): Current board have 1 cameras attached.
08-06 00:19:43.010 353 1073 D CameraHal: camera_get_number_of_cameras(1244): meida_profiles_xml_control time (143)us
08-06 00:19:43.010 353 1073 I CameraService: onTorchStatusChangedLocked: Torch status changed for cameraId=0, newStatus=0
08-06 00:19:43.010 353 1073 D CameraHal: camera_get_camera_info(1454): camera_get_camera_info(1454): camera_0 facing(0), orientation(180)
08-06 00:19:43.012 614 760 E Sensors : ECS_IOCTL_APP_SET_XXX failed (Bad file descriptor)
08-06 00:19:43.058 353 1073 D CameraHal: camera_get_camera_info(1454): camera_get_camera_info(1454): camera_0 facing(0), orientation(180)
08-06 00:19:43.058 353 1073 I CameraHal: camera_device_open(567): camera_device open
08-06 00:19:43.059 353 1073 D CameraHal: gCameraHalLogLevel: 0
08-06 00:19:43.060 353 1073 D CameraHal: CameraHal(136): it is a isp camera
08-06 00:19:43.060 353 1073 D CameraHal: Calling process is: com.android.camera2
08-06 00:19:43.062 353 1073 D CameraHal: Calling process is: com.android.camera2
08-06 00:19:43.066 353 1073 E CameraHal_Marvin: CAMERIC_ISP_FLT_DRV: CamerIcIspFltSetFilterParameter: 444 (exit)
08-06 00:19:43.067 353 1073 E CameraHal: disconnectCamera(1979): getFocusLimits failed!
08-06 00:19:43.067 353 1073 E CameraHal_Marvin: OV9282: OV9282_IsiCreateSensorIss 10 (enter)
08-06 00:19:43.179 353 1073 E CameraHal_Marvin: OV9282: OV9282_IsiCheckSensorConnectionIss value = 0x00009281
08-06 00:19:43.179 353 1073 D CameraHal_Marvin:
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: CameraHal Version Check:
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: CamSys_Head.h version:
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: kernel: (0x) v1.0.0
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: libisp_siliconimage_isp.so: (0x) v1.0.0
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: LibIsp version:
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: local: (0x) v2.3.0
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: camera.rk30board.so: (0x) v2.3.0
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: Sensor ISI version:
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: libisp_isi_drv_XXX: (0x) v0.d.0
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: libisp_siliconimage_isp.so: (0x) v0.d.0
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: Tunning XML version:
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: libisp_isi_drv_XXX: (09-06-2017 OV9282)
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: Calibdb: (12-5-2015_oyyf_OV9282_CMK-CB0407-FV1_v0.2.0)
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: sensor name OV9282:
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: sensor drv version: (0x) v0.c.0
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: Request 640x480, Exp(>= 0.000000), Fps(>= 15fps)
08-06 00:19:43.179 353 1073 D CameraHal_Marvin: getPreferedSensorRes is 800x600@30fps
08-06 00:19:43.179 353 1073 D CameraHal: setupPreview(330): isp out put format is YUV420SP.
08-06 00:19:43.179 353 1073 D CameraHal: setupPreview(342): Sensor output: 800x600 --(0,0,800,600)–> User request: 640x480
08-06 00:19:43.180 353 1073 E CameraHal_Marvin: OV9282: OV9282_IsiCheckSensorConnectionIss value = 0x00009281
08-06 00:19:43.309 353 1073 D CameraHal: cam_mem_gralloc_ops_alloc(402): alloc graphic buffer sucess,mem 0xf4e7d440, vir_addr 0xf4ad5000,fd 29
08-06 00:19:43.309 353 1073 D CameraHal: cam_mem_gralloc_ops_iommu_map(443): mem 0xf4e7d440, fd 29
08-06 00:19:43.316 353 1073 D CameraHal: cam_mem_gralloc_ops_alloc(402): alloc graphic buffer sucess,mem 0xf4e7d480, vir_addr 0xf14d6000,fd 31
08-06 00:19:43.316 353 1073 D CameraHal: cam_mem_gralloc_ops_iommu_map(443): mem 0xf4e7d480, fd 31
08-06 00:19:43.320 353 1073 D CameraHal: cam_mem_gralloc_ops_alloc(402): alloc graphic buffer sucess,mem 0xf4e7d4c0, vir_addr 0xf1423000,fd 33
08-06 00:19:43.320 353 1073 D CameraHal: cam_mem_gralloc_ops_iommu_map(443): mem 0xf4e7d4c0, fd 33
08-06 00:19:43.326 353 1073 D CameraHal: cam_mem_gralloc_ops_alloc(402): alloc graphic buffer sucess,mem 0xf4e7d500, vir_addr 0xf1370000,fd 35
08-06 00:19:43.326 353 1073 D CameraHal: cam_mem_gralloc_ops_iommu_map(443): mem 0xf4e7d500, fd 35
08-06 00:19:43.331 353 1073 D CameraHal: cam_mem_gralloc_ops_alloc(402): alloc graphic buffer sucess,mem 0xf4e7d540, vir_addr 0xf12bd000,fd 37
08-06 00:19:43.331 353 1073 D CameraHal: cam_mem_gralloc_ops_iommu_map(443): mem 0xf4e7d540, fd 37
08-06 00:19:43.334 353 1073 D CameraHal: cam_mem_gralloc_ops_alloc(402): alloc graphic buffer sucess,mem 0xf4e7d580, vir_addr 0xf120a000,fd 39
08-06 00:19:43.334 353 1073 D CameraHal: cam_mem_gralloc_ops_iommu_map(443): mem 0xf4e7d580, fd 39
08-06 00:19:43.337 353 1073 D CameraHal: cam_mem_gralloc_ops_alloc(402): alloc graphic buffer sucess,mem 0xf4e7d5c0, vir_addr 0xf1157000,fd 41
08-06 00:19:43.338 353 1073 D CameraHal: cam_mem_gralloc_ops_iommu_map(443): mem 0xf4e7d5c0, fd 41
08-06 00:19:43.340 353 1073 D CameraHal: cam_mem_gralloc_ops_alloc(402): alloc graphic buffer sucess,mem 0xf4e7d600, vir_addr 0xf10a4000,fd 43
08-06 00:19:43.340 353 1073 D CameraHal: cam_mem_gralloc_ops_iommu_map(443): mem 0xf4e7d600, fd 43
08-06 00:19:43.355 353 1073 E CameraHal_Marvin: ECM: EcmExecuteDirect: (enter) 0.000000
08-06 00:19:43.358 353 1073 E CameraHal_Marvin: ADPF: AdpfCalculateStrength: (gain=1.000000 fStrength=0.387298, R:165, G:165, B:165)
08-06 00:19:43.358 353 1073 E CameraHal_Marvin: CAM_ENGINE_API: CamEngineStart (IsiGetColorIss failed → RESULT=2)
08-06 00:19:43.358 353 1073 E CameraHal_Marvin: CAMERIC_ISP_FLT_DRV: CamerIcIspFltSetFilterParameter: 444 (exit)
08-06 00:19:43.361 353 1073 E CameraHal_Marvin: OV9282: OV9282_IsiCheckSensorConnectionIss value = 0x00009281
08-06 00:19:43.362 353 1073 D CameraHal: Calling process is: com.android.camera2
08-06 00:19:43.363 353 1073 D CameraHal: initDefaultParameters(1439): Support Preview format: yuv420sp,yuv420p yuv420sp(default)
08-06 00:19:43.363 353 1073 D CameraHal: initDefaultParameters(1441): Support Preview sizes: 176x144,320x240,352x288,640x480,720x480,800x600 800x600(default) 800x600(force)
08-06 00:19:43.363 353 1073 D CameraHal: initDefaultParameters(1442): Support Preview FPS range: (3000,30000),(15000,15000),(30000,30000)
08-06 00:19:43.363 353 1073 D CameraHal: initDefaultParameters(1443): Support Preview framerate: 10,15,20,30
08-06 00:19:43.363 353 1073 D CameraHal: initDefaultParameters(1444): Support Picture sizes: 800x600,640x480,352x288,320x240,176x144 800x600(default)
08-06 00:19:43.363 353 1073 D CameraHal: initDefaultParameters(1445): Support Focus: fixed Focus zone: 0
08-06 00:19:43.363 353 1073 D CameraHal: initDefaultParameters(1447): Support Flash: off,on,auto,torch Flash: off
08-06 00:19:43.363 353 1073 D CameraHal: initDefaultParameters(1448): Support AWB: auto
08-06 00:19:43.363 353 1073 D CameraHal: initDefaultParameters(1449): Support FOV test h(60.000000) v(60.000000)
08-06 00:19:43.363 353 1073 D CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (800x600)
08-06 00:19:43.363 353 1073 D CameraHal: isNeedToRestartPreview(145): mCamPreviewW (640x480)
08-06 00:19:43.363 353 1073 D CameraHal: isNeedToRestartPreview(146): video width (800x600)
08-06 00:19:43.366 353 1073 D CameraHal: enableSensor(214): orientation = 0xf4e063c0 (MPL Accelerometer)
08-06 00:19:43.373 353 1073 D CameraHal: camera_get_camera_info(1454): camera_get_camera_info(1454): camera_0 facing(0), orientation(180)
08-06 00:19:43.375 353 666 D CameraHal: camera_get_camera_info(1454): camera_get_camera_info(1454): camera_0 facing(0), orientation(180)
08-06 00:19:43.393 353 1754 D CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (800x600)
08-06 00:19:43.393 353 1754 D CameraHal: isNeedToRestartPreview(145): mCamPreviewW (640x480)
08-06 00:19:43.393 353 1754 D CameraHal: isNeedToRestartPreview(146): video width (800x600)
08-06 00:19:43.399 353 1754 D CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (800x600)
08-06 00:19:43.399 353 1754 D CameraHal: isNeedToRestartPreview(145): mCamPreviewW (640x480)
08-06 00:19:43.399 353 1754 D CameraHal: isNeedToRestartPreview(146): video width (800x600)
08-06 00:19:43.404 353 1754 D CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (800x600)
08-06 00:19:43.404 353 1754 D CameraHal: isNeedToRestartPreview(145): mCamPreviewW (640x480)
08-06 00:19:43.405 353 1754 D CameraHal: isNeedToRestartPreview(146): video width (800x600)
08-06 00:19:43.411 353 1754 D CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (800x600)
08-06 00:19:43.411 353 1754 D CameraHal: isNeedToRestartPreview(145): mCamPreviewW (640x480)
08-06 00:19:43.411 353 1754 D CameraHal: isNeedToRestartPreview(146): video width (800x600)
08-06 00:19:43.415 353 1754 D CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (800x600)
08-06 00:19:43.415 353 1754 D CameraHal: isNeedToRestartPreview(145): mCamPreviewW (640x480)
08-06 00:19:43.416 353 1754 D CameraHal: isNeedToRestartPreview(146): video width (800x600)
08-06 00:19:43.420 353 1754 D CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (800x600)
08-06 00:19:43.420 353 1754 D CameraHal: isNeedToRestartPreview(145): mCamPreviewW (640x480)
08-06 00:19:43.420 353 1754 D CameraHal: isNeedToRestartPreview(146): video width (800x600)
08-06 00:19:43.424 353 1754 D CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (800x600)
08-06 00:19:43.424 353 1754 D CameraHal: isNeedToRestartPreview(145): mCamPreviewW (640x480)
08-06 00:19:43.424 353 1754 D CameraHal: isNeedToRestartPreview(146): video width (800x600)
08-06 00:19:43.428 353 1754 D CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (800x600)
08-06 00:19:43.429 353 1754 D CameraHal: isNeedToRestartPreview(145): mCamPreviewW (640x480)
08-06 00:19:43.429 353 1754 D CameraHal: isNeedToRestartPreview(146): video width (800x600)
08-06 00:19:43.433 353 1754 D CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (800x600)
08-06 00:19:43.433 353 1754 D CameraHal: isNeedToRestartPreview(145): mCamPreviewW (640x480)
08-06 00:19:43.433 353 1754 D CameraHal: isNeedToRestartPreview(146): video width (800x600)
08-06 00:19:43.443 353 1754 D CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (800x600)
08-06 00:19:43.443 353 1754 D CameraHal: isNeedToRestartPreview(145): mCamPreviewW (640x480)
08-06 00:19:43.443 353 1754 D CameraHal: isNeedToRestartPreview(146): video width (800x600)
08-06 00:19:43.454 353 1754 D CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (800x600)
08-06 00:19:43.454 353 1754 D CameraHal: isNeedToRestartPreview(145): mCamPreviewW (640x480)
08-06 00:19:43.454 353 1754 D CameraHal: isNeedToRestartPreview(146): video width (800x600)
08-06 00:19:43.463 353 1754 D CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (800x600)
08-06 00:19:43.463 353 1754 D CameraHal: isNeedToRestartPreview(145): mCamPreviewW (640x480)
08-06 00:19:43.463 353 1754 D CameraHal: isNeedToRestartPreview(146): video width (800x600)
08-06 00:19:43.466 353 1754 D CameraHal: commandThread(1018): commandThread(1018):receive CMD_SET_PREVIEW_WINDOW
08-06 00:19:43.467 353 1754 D CameraHal: commandThread(1034): commandThread(1034): CMD_SET_PREVIEW_WINDOW out
08-06 00:19:43.467 353 1754 D CameraHal: commandThread(911): commandThread(911):receive CMD_PREVIEW_START
08-06 00:19:43.468 353 1754 D CameraHal_Marvin: Request 800x600, Exp(>= 0.020005), Fps(>= 10fps)
08-06 00:19:43.482 353 1754 D CameraHal_Marvin: 0: 800x600@30fps MaxIntTime(0.026441), curMaxIntTime(0.020005)
08-06 00:19:43.482 353 1754 D CameraHal_Marvin: getPreferedSensorRes is 800x600@30fps
08-06 00:19:43.482 353 1754 D CameraHal: stop(2054): m_camDevice->stopPreview success!
08-06 00:19:43.482 353 1754 E CameraHal_Marvin: CAM_API_CAMENGINE: changeResolution (can’t change resolution of sensor)
08-06 00:19:43.482 353 1754 D CameraHal: setupPreview(330): isp out put format is YUV420SP.
08-06 00:19:43.482 353 1754 D CameraHal: setupPreview(342): Sensor output: 800x600 --(0,0,800,600)–> User request: 800x600
08-06 00:19:43.483 353 1735 E CameraHal_Marvin: CAM-ENGINE: CamEngineReStartEventCbCamerIcDrv: >>>>>1.000000,1.000000<<<<<<
08-06 00:19:43.484 353 1754 D CameraHal: start(2009): m_camDevice->startPreview success
08-06 00:19:43.486 353 1729 D CameraHal: displayThread(627): displayThread(627): receive CMD_DISPLAY_START
08-06 00:19:43.486 353 1729 D CameraHal: cameraDisplayBufferDestory(418): cameraDisplayBufferDestory(418): mANativeWindow is NULL, destory is ignore
08-06 00:19:43.500 353 1754 D CameraHal: commandThread(986): commandThread(986): CMD_PREVIEW_START out
08-06 00:19:43.500 353 1754 D CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (800x600)
08-06 00:19:43.501 353 1754 D CameraHal: isNeedToRestartPreview(145): mCamPreviewW (800x600)
08-06 00:19:43.501 353 1754 D CameraHal: isNeedToRestartPreview(146): video width (800x600)
08-06 00:19:43.636 353 1757 E CameraHal_Marvin: ECM: EcmExecuteDirect: (enter) 0.000000
08-06 00:19:43.637 353 1757 E CameraHal_Marvin: ADPF: AdpfCalculateStrength: (gain=6.875000 fStrength=1.015505, R:63, G:63, B:63)
08-06 00:19:43.702 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:43.702 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 3;numFramesToSkip == 0
08-06 00:19:43.768 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:43.768 353 1757 E CameraHal_Marvin: ECM: EcmExecuteDirect: (enter) 0.000000
08-06 00:19:43.768 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 4;numFramesToSkip == 0
08-06 00:19:43.769 353 1757 E CameraHal_Marvin: ADPF: AdpfCalculateStrength: (gain=8.000000 fStrength=1.095445, R:58, G:58, B:58)
08-06 00:19:43.834 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:43.834 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 5;numFramesToSkip == 0
08-06 00:19:43.838 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:43.900 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:43.901 353 1757 E CameraHal_Marvin: ECM: EcmExecuteDirect: (enter) 0.000000
08-06 00:19:43.901 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 6;numFramesToSkip == 0
08-06 00:19:43.967 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:43.967 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 7;numFramesToSkip == 0
08-06 00:19:44.033 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:44.033 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 8;numFramesToSkip == 0
08-06 00:19:44.034 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:44.099 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:44.099 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 9;numFramesToSkip == 0
08-06 00:19:44.165 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:44.166 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 10;numFramesToSkip == 0
08-06 00:19:44.232 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:44.232 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 11;numFramesToSkip == 0
08-06 00:19:44.233 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:44.298 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:44.298 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 12;numFramesToSkip == 0
08-06 00:19:44.364 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:44.365 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 13;numFramesToSkip == 0
08-06 00:19:44.430 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:44.431 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 14;numFramesToSkip == 0
08-06 00:19:44.431 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:44.497 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:44.497 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 15;numFramesToSkip == 0
08-06 00:19:44.563 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:44.563 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 16;numFramesToSkip == 0
08-06 00:19:44.629 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:44.629 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 17;numFramesToSkip == 0
08-06 00:19:44.630 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:44.695 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:44.696 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 18;numFramesToSkip == 0
08-06 00:19:44.762 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:44.762 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 19;numFramesToSkip == 0
08-06 00:19:44.828 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:44.828 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 20;numFramesToSkip == 0
08-06 00:19:44.829 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:44.894 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:44.895 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 21;numFramesToSkip == 0
08-06 00:19:44.960 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:44.961 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 22;numFramesToSkip == 0
08-06 00:19:45.027 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:45.027 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 23;numFramesToSkip == 0
08-06 00:19:45.028 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:45.093 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:45.093 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 24;numFramesToSkip == 0
08-06 00:19:45.159 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:45.159 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 25;numFramesToSkip == 0
08-06 00:19:45.225 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:45.226 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 26;numFramesToSkip == 0
08-06 00:19:45.226 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:45.292 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:45.292 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 27;numFramesToSkip == 0
08-06 00:19:45.358 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:45.358 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 28;numFramesToSkip == 0
08-06 00:19:45.424 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:45.425 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 29;numFramesToSkip == 0
08-06 00:19:45.427 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:45.490 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:45.491 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 30;numFramesToSkip == 0
08-06 00:19:45.557 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:45.557 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 31;numFramesToSkip == 0
08-06 00:19:45.623 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:45.623 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 32;numFramesToSkip == 0
08-06 00:19:45.626 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:45.689 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:45.689 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 33;numFramesToSkip == 0
08-06 00:19:45.755 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:45.755 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 34;numFramesToSkip == 0
08-06 00:19:45.822 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:45.822 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 35;numFramesToSkip == 0
08-06 00:19:45.824 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:45.888 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:45.888 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 36;numFramesToSkip == 0
08-06 00:19:45.954 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:45.954 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 37;numFramesToSkip == 0
08-06 00:19:46.020 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:46.020 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 38;numFramesToSkip == 0
08-06 00:19:46.020 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:46.086 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:46.087 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 39;numFramesToSkip == 0
08-06 00:19:46.153 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:46.153 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 40;numFramesToSkip == 0
08-06 00:19:46.219 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:46.219 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 41;numFramesToSkip == 0
08-06 00:19:46.220 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:46.285 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:46.286 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 42;numFramesToSkip == 0
08-06 00:19:46.352 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:46.352 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 43;numFramesToSkip == 0
08-06 00:19:46.418 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:46.418 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:46.418 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 44;numFramesToSkip == 0
08-06 00:19:46.484 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:46.485 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 45;numFramesToSkip == 0
08-06 00:19:46.550 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:46.551 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 46;numFramesToSkip == 0
08-06 00:19:46.616 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:46.617 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 47;numFramesToSkip == 0
08-06 00:19:46.617 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:46.683 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:46.683 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 48;numFramesToSkip == 0
08-06 00:19:46.749 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:46.749 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 49;numFramesToSkip == 0
08-06 00:19:46.815 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:46.815 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 50;numFramesToSkip == 0
08-06 00:19:46.816 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:46.882 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:46.882 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 51;numFramesToSkip == 0
08-06 00:19:46.948 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:46.948 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 52;numFramesToSkip == 0
08-06 00:19:47.014 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:47.014 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 53;numFramesToSkip == 0
08-06 00:19:47.015 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:47.080 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:47.081 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 54;numFramesToSkip == 0
08-06 00:19:47.147 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:47.147 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 55;numFramesToSkip == 0
08-06 00:19:47.213 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:47.213 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 56;numFramesToSkip == 0
08-06 00:19:47.213 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:47.279 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:47.279 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 57;numFramesToSkip == 0
08-06 00:19:47.345 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:47.345 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 58;numFramesToSkip == 0
08-06 00:19:47.412 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:47.412 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 59;numFramesToSkip == 0
08-06 00:19:47.412 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:47.478 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:47.478 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 60;numFramesToSkip == 0
08-06 00:19:47.544 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:47.544 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 61;numFramesToSkip == 0
08-06 00:19:47.610 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:47.611 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 62;numFramesToSkip == 0
08-06 00:19:47.611 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:47.677 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:47.677 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 63;numFramesToSkip == 0
08-06 00:19:47.743 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:47.743 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 64;numFramesToSkip == 0
08-06 00:19:47.809 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:47.809 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 65;numFramesToSkip == 0
08-06 00:19:47.809 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:47.875 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:47.875 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 66;numFramesToSkip == 0
08-06 00:19:47.941 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:47.942 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 67;numFramesToSkip == 0
08-06 00:19:48.008 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:48.008 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 68;numFramesToSkip == 0
08-06 00:19:48.010 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:48.074 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:48.074 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 69;numFramesToSkip == 0
08-06 00:19:48.140 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:48.140 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 70;numFramesToSkip == 0
08-06 00:19:48.206 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:48.207 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 71;numFramesToSkip == 0
08-06 00:19:48.208 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:48.273 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:48.273 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 72;numFramesToSkip == 0
08-06 00:19:48.339 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:48.339 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 73;numFramesToSkip == 0
08-06 00:19:48.405 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:48.406 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:48.406 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 74;numFramesToSkip == 0
08-06 00:19:48.472 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:48.472 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 75;numFramesToSkip == 0
08-06 00:19:48.538 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:48.538 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 76;numFramesToSkip == 0
08-06 00:19:48.604 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:48.604 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:48.604 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 77;numFramesToSkip == 0
08-06 00:19:48.670 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:48.670 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 78;numFramesToSkip == 0
08-06 00:19:48.737 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:48.737 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 79;numFramesToSkip == 0
08-06 00:19:48.803 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:48.803 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 80;numFramesToSkip == 0
08-06 00:19:48.805 353 1757 E CameraHal_Marvin: AWB: AWB (message code 04): fLikeHoodSum near zero
08-06 00:19:48.869 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:48.869 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 81;numFramesToSkip == 0
08-06 00:19:48.935 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257084(base:0xffc00000) not filled , so reused!!
08-06 00:19:48.936 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 82;numFramesToSkip == 0
08-06 00:19:49.001 353 1758 W CameraHal_Marvin: CAMERIC-MI-IRQ: pBuf: 0xf2257058(base:0xffd00000) not filled , so reused!!
08-06 00:19:49.002 353 1758 E CameraHal_Marvin: CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,miFrameNum == 83;numFramesToSkip == 0
怀疑是isp端出错,isp处理是封装成so的,看不到代码;哪位大神有遇到过类似问题?
我也碰到了这个问题,解决了吗?
