板子不开机,大佬帮我看看那部分有问题。万分感谢!
DDR Version 1.08 20170320
Channel 0: LPDDR3, 800MHz
CS = 0
MR0=0xD8
MR1=0x0
MR2=0x0
MR3=0x0
MR4=0x3
MR5=0xFF
MR6=0x81
MR7=0x0
MR8=0x1B
MR9=0x0
MR10=0x0
MR11=0x0
MR12=0x0
MR13=0x0
MR14=0x0
MR15=0x0
MR16CS = 1
MR0=0xD8
MR1=0x0
MR2=0MR8=0x1B
MR9=0x0
MR10=0x0
MR11=0x0
MR12=0x0
MR13=0x0
MR14=0x0
MR15=0x0
MR16=0x0
Bus Width=32 Col=10 Bank=8 Row=14/14 CS=2 Die Bus-Widt Size=1024MB
Channel 1: LPDDR3,R4=0x2
MR5=0xFF
MR6=0x81
MR7=0x0
MR8=0x1B
MR9=0x0
MR10=0x0
MR11=0x0
MR12=0x0
MR13=0x0
MR14=0x0
MR15=0x0
M0
MR4=0x2
MR5=0xFF
MR6=0x81
12=0x0
MR13=0x0
MR14=0x0
MR15=0x0
MR16=0x0
Bus Width=32 Col=10 Bank=8 Row=14/14 CS=2 Die Bus-ch 0 ddrconfig = 0x101, ddrsize = 0x1010
ch 1 ddrconfig = 0x101, ddrsize = 0x1010
pmugrf_os_reg[2] =
Boot1: 2017-06-09, version: 1.09
CPUId = 0x0
ChipType = 0x10, 1827
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 66754
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xa6f54
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):4f4079b
NOTICE: BL31: Built : 17:40:23, Oct 11 2018
INFO: INFO: plat_rockchip_pmu_init(FO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-170-gc4654a6 #16 Wed May 30 08:54:30 UTC 2018 aarch64)
INFO: BL31: Preparing for EL3 e 0x3c9
U-Boot 2014.10-RK3399-06-03325-g27130a4-dirty (Nov 06 2018 - 11:32:05)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_pe= 66666666HZ, pclk_periph_h = 33333333HZ
aclk_periph_l0 = 266666666HZ, hclk_per4444444HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Found dram banks: 1atform Board
Reserve memory for trust os.
128 MiB
帮顶!!
