bootrk: do_bootm_linux…
Loading Device Tree to 65600000, end 65614ced … OK
Add bank:0000000060000000, 0000000040000000
[14:56:21.451]收←◆
[14:56:24.431]收←◆
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 3.10.0 (booslink2@booslink-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #213 SMP PREEMPT Thu Apr 25 14:55:15 CST 2019
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] Machine: Rockchip RK3128, model: rockchip,rk3128
[ 0.000000] rockchip_uboot_logo_setup: mem: 2000000@9dc00000, offset:1000000
[ 0.000000] rockchip_uboot_mem_reserve: reserve 2000000@9dc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(800000) align(0)
[ 0.000000] cma: CMA: reserved 8 MiB at 9d400000
[ 0.000000] ion_reserve: cma reserved base 9d400000 size 8388608
[ 0.000000] cma: CMA: reserved 16 MiB at 7f000000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1672000 s14016 r8192 d14656 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 261120
[ 0.000000] Kernel command line: vmalloc=496M rockchip_jtag console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00006000@0x0000E000(kernel),0x00006000@0x00014000(boot),0x00010000@0x0001A000(recovery),0x00020000@0x0002A000(backup),0x00040000@0x0004A000(cache),0x001FE000@0x0008A000(userdata),0x00002000@0x00288000(metadata),0x00002000@0x0028A000(kpanic),0x00180000@0x0028C000(system),-@0x0040C000(user) storagemedia=nand uboot_logo=0x02000000@0x9dc00000:0x01000000 loader.timestamp=2019-04-24_16:35:39
[ 0.000000] rockchip jtag enabled
[ 0.000000] allocated 2097152 bytes of page_cgroup
[ 0.000000] Memory: 1024MB = 1024MB total
[ 0.000000] Memory: 964368k/964368k available, 84208k reserved, 483328K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bb2848 (11947 kB)
[ 0.000000] .init : 0xc0bb3000 - 0xc0c0b6c0 ( 354 kB)
[ 0.000000] .data : 0xc0c0c000 - 0xc0d271f8 (1133 kB)
[ 0.000000] .bss : 0xc0d271f8 - 0xc0e4ce7c (1176 kB)
[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_parent = 25
[ 0.000000] rkclk_init_clks: cnt_rate = 17
[ 0.000000] process version: 0
[ 0.000000] channel:0, lkg:30
[ 0.000000] target-temp:85
[ 0.285367] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.285395] pid_max: default: 32768 minimum: 301
[ 0.285597] Security Framework initialized
[ 0.285627] SELinux: Initializing.
[ 0.285760] Mount-cache hash table entries: 512
[ 0.286974] Initializing cgroup subsys debug
[ 0.287002] Initializing cgroup subsys memory
[ 0.287052] Initializing cgroup subsys freezer
[ 0.287114] CPU: Testing write buffer coherency: ok
[ 0.287634] /cpus/cpu@0 missing clock-frequency property
[ 0.287662] /cpus/cpu@1 missing clock-frequency property
[ 0.287681] /cpus/cpu@2 missing clock-frequency property
[ 0.287700] /cpus/cpu@3 missing clock-frequency property
[ 0.287764] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.287835] Setting up static identity map for 0xc0878e30 - 0xc0878e88
[ 0.289710] last_log: 0x7e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x16de (version 3.0)
[ 0.363460] CPU1: Booted secondary processor
[ 0.363517] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.383146] CPU2: Booted secondary processor
[ 0.383192] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.402898] CPU3: Booted secondary processor
[ 0.402942] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.403128] Brought up 4 CPUs
[ 0.403181] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.403197] CPU: All CPU(s) started in SVC mode.
[ 0.404610] devtmpfs: initialized
[ 0.413999] pinctrl core: initialized pinctrl subsystem
[ 0.414506] regulator-dummy: no parameters
[ 0.416011] NET: Registered protocol family 16
[ 0.419031] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.419583] ion_snapshot: 0x7ea18000 map to 0xe0907000 and copy to 0xc0e25144 (version 0.1)
[ 0.419803] Registered FIQ tty driver
[ 0.422147] console [ttyFIQ0] enabled
[ 0.422553] Registered fiq debugger ttyFIQ0
[ 0.423928] rockchip_get_bank_data:name=/pinctrl@20008000/gpio0@2007c000 start=0x2007c000,end=0x2007c0ff
[ 0.424061] rockchip_get_bank_data:name=/pinctrl@20008000/gpio1@20080000 start=0x20080000,end=0x200800ff
[ 0.424147] rockchip_get_bank_data:name=/pinctrl@20008000/gpio2@20084000 start=0x20084000,end=0x200840ff
[ 0.424225] rockchip_get_bank_data:name=/pinctrl@20008000/gpio3@20088000 start=0x20088000,end=0x200880ff
[ 0.424313] rockchip_get_bank_data:name=/pinctrl@20008000/gpio15@2008A000 start=0x20086000,end=0x200860ff
[ 0.424384] rockchip_pinctrl_probe:name=rk312x-GPIO,type=5
[ 0.424415] rockchip_pinctrl_probe:name=base start=0x20008000,end=0x200080a7
[ 0.424457] rockchip_pinctrl_probe:name=mux start=0x200080a8,end=0x200080f3
[ 0.424485] rockchip_pinctrl_probe:name=pull start=0x20008118,end=0x20008137
[ 0.424514] rockchip_pinctrl_probe:name=drv start=0x20008100,end=0x20008103
[ 0.427240] rockchip_pinctrl_probe:init ok
[ 0.435905] rk_iommu 1010e300.vop_mmu: (vop) Enter
[ 0.435959] rk_iommu 1010e300.vop_mmu: skip request vop mmu irq
[ 0.436052] rk_iommu 1010e300.vop_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.436079] rk_iommu 1010e300.vop_mmu: (vop) Initialized
[ 0.436353] rk_iommu 10104440.hevc_mmu: (hevc) Enter
[ 0.436499] rk_iommu 10104440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.436529] rk_iommu 10104440.hevc_mmu: (hevc) Initialized
[ 0.436806] rk_iommu 10106800.vpu_mmu: (vpu) Enter
[ 0.436931] rk_iommu 10106800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.436961] rk_iommu 10106800.vpu_mmu: (vpu) Initialized
[ 0.437213] rk_iommu 10108800.iep_mmu: (iep) Enter
[ 0.437338] rk_iommu 10108800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.437367] rk_iommu 10108800.iep_mmu: (iep) Initialized
[ 0.438992] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.439023] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.439306] DDR DEBUG: version 1.02 20140828
[ 0.439330] DDR DEBUG: DRAM Type:DDR3
[ 0.439354] DDR DEBUG: 1 CS, ROW=15, Bank=8, COL=10, Total Capability=1024MB
[ 0.439401] DDR DEBUG: init success!!! freq=300MHz
[ 0.490580] bio: create slab at 0
[ 0.491684] Rockchip hdmi driver version 2.0
[ 0.492427] SCSI subsystem initialized
[ 0.492788] usbcore: registered new interface driver usbfs
[ 0.492882] usbcore: registered new interface driver hub
[ 0.493094] usbcore: registered new device driver usb
[ 0.495236] rockchip_i2c 20072000.i2c: i2c-0: Rockchip I2C adapter
[ 0.495272] i2c i2c-0: of_i2c: modalias failure on /i2c@20072000/rk818@1c
[ 0.495300] i2c i2c-0: of_i2c: modalias failure on /i2c@20072000/act8931@5b
[ 0.496652] media: Linux media interface: v0.10
[ 0.496745] Linux video capture interface: v2.00
[ 0.496953] pps_core: LinuxPPS API ver. 1 registered
[ 0.496976] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.497024] PTP clock support registered
[ 0.497115] i2c-core: driver [bq24296] using legacy suspend method
[ 0.497137] i2c-core: driver [bq24296] using legacy resume method
[ 0.498145] Rockchip ion module is successfully loaded (v1.1)
[ 0.498409] Advanced Linux Sound Architecture Driver Initialized.
[ 0.499166] Bluetooth: Core ver 2.16
[ 0.499245] NET: Registered protocol family 31
[ 0.499268] Bluetooth: HCI device and connection manager initialized
[ 0.499302] Bluetooth: HCI socket layer initialized
[ 0.499332] Bluetooth: L2CAP socket layer initialized
[ 0.499388] Bluetooth: SCO socket layer initialized
[ 0.499818] cfg80211: Calling CRDA to update world regulatory domain
[ 0.501791] rk816_i2c_probe,line=773
[ 0.501823] pmic: addr=de9c2890
[ 0.502509] pmic is rk816, chip version is 8163
[ 0.503038] pmic on/off source: on=0x40, off=0x0
[ 0.510953] rk816_i2c_probe: rk816_pmic_sleep=0
[ 0.514584] rk816_regulator_probe: compatible rk816
[ 0.519148] vdd_arm: 712 ↔ 1450 mV at 1100 mV
[ 0.523498] vdd_logic: 712 ↔ 1450 mV at 1100 mV
[ 0.527352] vcc_ddr: 1200 mV
[ 0.532616] vcc_io: 3300 mV
[ 0.536907] rk816_ldo1: 1800 mV
[ 0.541150] rk816_ldo2: 1800 mV
[ 0.545384] rk816_ldo3: 1100 mV
[ 0.547260] RK816_LDO4: at 1000 mV
[ 0.549120] RK816_LDO5: at 3000 mV
[ 0.551019] RK816_LDO6: at 3000 mV
[ 0.551431] rk816_regulator_probe: END (null)
[ 0.551954] rk816_i2c_probe success
[ 0.552016] i2c-core: driver [rk816] using legacy suspend method
[ 0.552038] i2c-core: driver [rk816] using legacy resume method
[ 0.552436] rk816_rtc_probe,line=463
[ 0.562477] rk8xx-rtc rk8xx-rtc: rtc core: registered rk816 as rtc0
[ 0.563897] rk816: rtc ok
[ 0.565196] Switching to clocksource arch_sys_counter
[ 0.597683] rk_battery_charger_detect_cb , battery_charger_detect 2
[ 0.601685] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.601715] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.602144] rk-screen rk_screen.21: rockchip screen probe success
[ 0.602823] rk31xx-lvds rk31xx-lvds: rk31xx lvds driver probe success
[ 0.604775] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.605534] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.605939] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.616395] rk312x-lcdc lcdc0: set lcdc0 dclk failed
[ 0.616433] rk312x-lcdc lcdc0: lcdc0: dclk:66000000>>fps:56
[ 0.616459] rk312x-lcdc lcdc0: wakeup from standby!
[ 0.633056] alloc_buffer:ion_phy_addr=0x10000000
[ 0.639313] fb0:phy:10000000>>vir:e0939000>>len:0xa00000
[ 0.649410] rk312x-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.652695] NET: Registered protocol family 2
[ 0.653626] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.653761] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.653925] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.654038] TCP: reno registered
[ 0.654069] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.654116] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.654519] NET: Registered protocol family 1
[ 0.655152] Unpacking initramfs…
[ 0.769965] Freeing initrd memory: 1168K (c5bf0000 - c5d14000)
[ 0.771170] hw perfevents: enabled with ARMv7_Cortex_A7 PMU driver, 5 counters available
[ 0.772041] probe device vpu_combo.22
[ 0.772205] vcodec vpu_combo.22: failed on clk_get clk_cabac
[ 0.772313] vpu_combo.22: power on
[ 0.772468] probe device 10106000.vpu_service
[ 0.772532] checking hw id 4831
[ 0.773825] probe device 10104000.hevc_service
[ 0.773891] checking hw id 6867
[ 0.774831] vpu_combo.22: power off…
[ 0.774899] done
[ 0.774917] init success
[ 0.776792] rk_dts_sensor_probe:Get ov2659 rockchip,power failed!
[ 0.776855] rk_dts_sensor_probe:Get gc0329 rockchip,power failed!
[ 0.778320] audit: initializing netlink socket (disabled)
[ 0.778410] type=2000 audit(0.490:1): initialized
[ 0.779796] bounce pool size: 64 pages
[ 0.790153] fuse init (API version 7.22)
[ 0.790998] msgmni has been set to 973
[ 0.794593] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.794627] io scheduler noop registered
[ 0.794647] io scheduler deadline registered
[ 0.794851] io scheduler cfq registered (default)
[ 0.800875] rga 1010c000.rga: rga ion client create success!
[ 0.801182] rga: Driver loaded succesfully
[ 0.801312] rga: Module initialized.
[ 0.802285] ------>rockchip_hdmiv1_probe :START rockchip_hdmiv1_probe
[ 0.909989] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mode 0 → 1
[ 0.910025] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mode LOWER_PWR
[ 0.910174] rk-hdmi 20034000.hdmi: hdmi probe success.
[ 0.911153] IEP Power ON
[ 0.911233] iep ion client create success!
[ 0.911673] IEP Power OFF
[ 0.911707] IEP Driver loaded succesfully
[ 0.911858] Module initialized.
[ 0.914953] dma-pl330 20078000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.914993] dma-pl330 20078000.pdma: DBUFF-64x8bytes Num_Chans-8 Num_Peri-16 Num_Events-16
[ 0.915549] vdd_arm: 950 ↔ 1425 mV at 1250 mV
[ 0.915648] vdd_arm: Failed to create debugfs directory
[ 0.915989] pwm-voltage-regulator pwm-regulator2.29: unable to request PWM, trying legacy API
[ 0.916025] pwm-voltage-regulator pwm-regulator2.29: unable to request legacy PWM
[ 0.916047] pwm_regulator_probe:error
[ 0.916089] platform pwm-regulator2.29: Driver pwm-voltage-regulator requests probe deferral
[ 0.916757] rk_serial.c v1.8 2014-03-04
[ 0.917095] 20064000.serial: ttyS1 at MMIO 0x20064000 (irq = 53) is a rk29_serial.1
[ 0.917536] serial 20064000.serial: membase e2352000
[ 0.923807] loop: module loaded
[ 0.923931] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 0.923955] i2c-core: driver [mpu6050B1] using legacy resume method
[ 0.923981] mpu_init: Probe name mpu6050B1
[ 0.924297] ak8963_mod_init: Probe name ak8963_mod
[ 0.925327] SCSI Media Changer driver v0.25
[ 0.925986] tun: Universal TUN/TAP device driver, 1.6
[ 0.926012] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.926298] vmac_init.
[ 0.927308] rockchip-pinctrl 20008000.pinctrl: pin gpio2-8 already requested by device; cannot claim for 2008c000.eth
[ 0.927347] rockchip-pinctrl 20008000.pinctrl: pin-72 (2008c000.eth) status -22
[ 0.927375] rockchip-pinctrl 20008000.pinctrl: could not request pin 72 on device rockchip-pinctrl
[ 0.927403] stmmaceth 2008c000.eth: Error applying setting, reverse things back
[ 0.927521] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 0.927547] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[ 0.927571] stmmac_probe_config_dt: Can not read property: clock_in_out.
[ 0.927594] stmmac_probe_config_dt: Can not read property: tx_delay. set tx_delay to 0x30
[ 0.927619] stmmac_probe_config_dt: Can not read property: rx_delay. set rx_delay to 0x10
[ 0.927697] stmmac_probe_config_dt: is rockchip,rk312x-gmac
[ 0.927716] stmmc_pltfr_init:
[ 0.927734] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 0.927754] stmmc_pltfr_init: ERROR: Get reset-gpio failed.
[ 0.927774] stmmc_pltfr_init: init for RGMII
[ 0.927794] tx delay=0x30
[ 0.927794] rx delay=0x10
[ 0.928039] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.928061] Normal descriptors
[ 0.928077] Ring mode enabled
[ 0.928094] DMA HW capability register supported
[ 0.928114] RX Checksum Offload Engine supported (type 2)
[ 0.928133] TX Checksum insertion supported
[ 0.928150] Wake-Up On Lan supported
[ 0.928234] Enable RX Mitigation via HW Watchdog Timer
[ 0.929175] PPP generic driver version 2.4.2
[ 0.929582] PPP BSD Compression module registered
[ 0.929609] PPP Deflate Compression module registered
[ 0.929644] PPP MPPE Compression module registered
[ 0.929667] NET: Registered protocol family 24
[ 0.929723] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.929747] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.929770] Rockchip WiFi SYS interface (V1.00) …
[ 0.929857] esp_mem_init enter date Apr 13 2019 14:42:32
[ 0.929880] esp_mem_init VERSION [V2.3]
[ 0.929956] esp_mem_init complete
[ 0.930081] usbcore: registered new interface driver catc
[ 0.930166] usbcore: registered new interface driver kaweth
[ 0.930190] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.930274] usbcore: registered new interface driver pegasus
[ 0.930359] usbcore: registered new interface driver rtl8150
[ 0.930441] usbcore: registered new interface driver r8152
[ 0.930462] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.930600] usbcore: registered new interface driver hso
[ 0.930729] usbcore: registered new interface driver asix
[ 0.930817] usbcore: registered new interface driver ax88179_178a
[ 0.930901] usbcore: registered new interface driver cdc_ether
[ 0.930992] usbcore: registered new interface driver cdc_eem
[ 0.931078] usbcore: registered new interface driver dm9601
[ 0.931161] usbcore: registered new interface driver dm9620
[ 0.931278] usbcore: registered new interface driver smsc75xx
[ 0.931412] usbcore: registered new interface driver smsc95xx
[ 0.931501] usbcore: registered new interface driver gl620a
[ 0.931579] usbcore: registered new interface driver net1080
[ 0.931655] usbcore: registered new interface driver plusb
[ 0.931730] usbcore: registered new interface driver rndis_host
[ 0.931806] usbcore: registered new interface driver cdc_subset
[ 0.931891] usbcore: registered new interface driver zaurus
[ 0.931972] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.932093] usbcore: registered new interface driver int51x1
[ 0.932172] usbcore: registered new interface driver kalmia
[ 0.932248] usbcore: registered new interface driver ipheth
[ 0.932333] usbcore: registered new interface driver sierra_net
[ 0.932411] usbcore: registered new interface driver cx82310_eth
[ 0.932517] usbcore: registered new interface driver cdc_ncm
[ 0.932598] usbcore: registered new interface driver qmi_wwan
[ 0.932677] usbcore: registered new interface driver cdc_mbim
[ 0.932700] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.934649] EHCI: ehci_rk_probe e2380000 e2380010
[ 0.934682] rockchip_ehci_host 101c0000.usb: EHCI Host Controller
[ 0.934737] rockchip_ehci_host 101c0000.usb: new USB bus registered, assigned bus number 1
[ 0.935422] rockchip_ehci_host 101c0000.usb: irq 43, io mem 0x101c0000
[ 0.949094] rockchip_ehci_host 101c0000.usb: USB 2.0 started, EHCI 1.00
[ 0.949245] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.949278] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.949304] usb usb1: Product: EHCI Host Controller
[ 0.949329] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 0.949353] usb usb1: SerialNumber: 101c0000.usb
[ 0.950248] hub 1-0:1.0: USB hub found
[ 0.950296] hub 1-0:1.0: 1 port detected
[ 0.950658] EHCI: ehci_rk_probe ok
[ 0.950833] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.951073] ohci-rockchip 101e0000.usb: RK OHCI Host Controller
[ 0.951128] ohci-rockchip 101e0000.usb: new USB bus registered, assigned bus number 2
[ 0.951210] ohci-rockchip 101e0000.usb: irq 64, io mem 0x101e0000
[ 1.012161] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.012198] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.012225] usb usb2: Product: RK OHCI Host Controller
[ 1.012249] usb usb2: Manufacturer: Linux 3.10.0 ohci_hcd
[ 1.012273] usb usb2: SerialNumber: 101e0000.usb
[ 1.013081] hub 2-0:1.0: USB hub found
[ 1.013128] hub 2-0:1.0: 1 port detected
[ 1.013743] usbcore: registered new interface driver cdc_acm
[ 1.013769] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.013884] usbcore: registered new interface driver usblp
[ 1.013973] usbcore: registered new interface driver cdc_wdm
[ 1.014124] usbcore: registered new interface driver usb-storage
[ 1.014206] usbcore: registered new interface driver ums-alauda
[ 1.014283] usbcore: registered new interface driver ums-cypress
[ 1.014362] usbcore: registered new interface driver ums-datafab
[ 1.014437] usbcore: registered new interface driver ums_eneub6250
[ 1.014515] usbcore: registered new interface driver ums-freecom
[ 1.014591] usbcore: registered new interface driver ums-isd200
[ 1.014666] usbcore: registered new interface driver ums-jumpshot
[ 1.014740] usbcore: registered new interface driver ums-karma
[ 1.014827] usbcore: registered new interface driver ums-onetouch
[ 1.014907] usbcore: registered new interface driver ums-sddr09
[ 1.014984] usbcore: registered new interface driver ums-sddr55
[ 1.015060] usbcore: registered new interface driver ums-usbat
[ 1.015246] usbcore: registered new interface driver usbserial
[ 1.015348] usbcore: registered new interface driver usbserial_generic
[ 1.015416] usbserial: USB Serial support registered for generic
[ 1.015499] usbcore: registered new interface driver option
[ 1.015577] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.015796] usbcore: registered new interface driver trancevibrator
[ 1.015820] usb20_otg: version 3.10a 21-DEC-2012
[ 1.016495] e2400040
[ 1.016522] Core Release: 2.91a
[ 1.016543] Setting default values for core params
[ 1.016805] Using Buffer DMA mode
[ 1.016828] Periodic Transfer Interrupt Enhancement - disabled
[ 1.016848] Multiprocessor Interrupt Enhancement - disabled
[ 1.016869] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.016887] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.016913] Dedicated Tx FIFOs mode
[ 1.016948] pcd_init otg_dev = de200500
[ 1.017263] usb20_otg 10180000.usb: DWC OTG Controller
[ 1.017318] usb20_otg 10180000.usb: new USB bus registered, assigned bus number 3
[ 1.017388] usb20_otg 10180000.usb: irq 42, io mem 0x00000000
[ 1.017509] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.017540] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.017567] usb usb3: Product: DWC OTG Controller
[ 1.017591] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.017615] usb usb3: SerialNumber: 10180000.usb
[ 1.018534] hub 3-0:1.0: USB hub found
[ 1.018582] hub 3-0:1.0: 1 port detected
[ 1.019209] usb20_host: version 3.10a 21-DEC-2012
[ 1.020227] usbcore: registered new interface driver xpad
[ 1.020342] usbcore: registered new interface driver usb_acecad
[ 1.020438] usbcore: registered new interface driver aiptek
[ 1.020536] usbcore: registered new interface driver gtco
[ 1.020631] usbcore: registered new interface driver hanwang
[ 1.020721] usbcore: registered new interface driver kbtab
[ 1.020827] usbcore: registered new interface driver wacom
[ 1.021451] sensor_register_slave:mma8452,id=17
[ 1.021478] sensor_register_slave:gs_mc3230,id=23
[ 1.021495] gsensor_init
[ 1.021513] sensor_register_slave:mpu6880_acc,id=24
[ 1.021533] sensor_register_slave:cm3217,id=47
[ 1.021553] sensor_register_slave:cm3218,id=48
[ 1.021918] .. rk pwm remotectl v1.1 init
[ 1.022361] input: 20050030.pwm as /devices/20050030.pwm/input/input0
[ 1.023182] i2c /dev entries driver
[ 1.023840] IR NEC protocol handler initialized
[ 1.023865] IR RC5(x) protocol handler initialized
[ 1.023884] IR RC6 protocol handler initialized
[ 1.023902] IR JVC protocol handler initialized
[ 1.023920] IR Sony protocol handler initialized
[ 1.023938] IR RC5 (streamzap) protocol handler initialized
[ 1.023957] IR SANYO protocol handler initialized
[ 1.023976] IR MCE Keyboard/mouse protocol handler initialized
[ 1.024400] usbcore: registered new interface driver uvcvideo
[ 1.024424] USB Video Class driver (1.1.1)
[ 1.024447] CamSys driver version: v0.27.0, CamSys head file version: v0.10.0
[ 1.024474] E:camsys_soc_init(87): camsys isn’t support soc: 0x31260001!
[ 1.025116] not find test_power_init dev node
[ 1.025202] i2c-core: driver [bq27320] using legacy suspend method
[ 1.025225] i2c-core: driver [bq27320] using legacy resume method
[ 1.025554] ===========lg_mute_probe start===========
[ 1.025619] ------------[ cut here ]------------
[ 1.025657] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[ 1.025679] autorequest GPIO-13
[ 1.025695] Modules linked in:
[ 1.025723] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #213
[ 1.025775] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 1.025816] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 1.025857] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 1.025899] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
[ 1.025942] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_output+0x80/0x2b0)
[ 1.025985] [] (gpiod_direction_output+0x80/0x2b0) from [] (lg_mute_probe+0x48/0xa4)
[ 1.026027] [] (lg_mute_probe+0x48/0xa4) from [] (platform_drv_probe+0x14/0x18)
[ 1.026067] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c)
[ 1.026106] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 1.026143] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 1.026184] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 1.026224] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 1.026261] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 1.026299] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8)
[ 1.026339] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 1.026377] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 1.026420] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 1.026463] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 1.026526] —[ end trace e6aa1d79079698a3 ]—
[ 1.026613] ===========lg_mute_probe end===========
[ 1.026877]
[ 1.026877] ------>lg_gfdy_probe :START
[ 1.026908]
[ 1.026908] ------>lg_gfdy_probe :1
[ 1.026969]
[ 1.026969] ------>lg_gfdy_probe :2
[ 1.026995]
[ 1.026995] ------>lg_gfdy_probe :3
[ 1.027022] ------------[ cut here ]------------
[ 1.027055] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[ 1.027076] autorequest GPIO-8
[ 1.027092] Modules linked in:
[ 1.027118] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.10.0 #213
[ 1.027161] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 1.027200] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 1.027240] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 1.027282] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
[ 1.027324] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_output+0x80/0x2b0)
[ 1.027365] [] (gpiod_direction_output+0x80/0x2b0) from [] (lg_gfdy_probe+0x7c/0x11c)
[ 1.027406] [] (lg_gfdy_probe+0x7c/0x11c) from [] (platform_drv_probe+0x14/0x18)
[ 1.027445] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c)
[ 1.027483] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 1.027520] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 1.027560] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 1.027600] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 1.027637] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 1.027675] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8)
[ 1.027713] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 1.027751] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 1.027792] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 1.027834] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 1.027859] —[ end trace e6aa1d79079698a4 ]—
[ 1.027943]
[ 1.027943] ------>lg_gfdy_probe :4
[ 1.028012]
[ 1.028012] ------>lg_gfdy_probe :5
[ 1.028048]
[ 1.028048] ------>lg_gfdy_probe :6
[ 1.028075]
[ 1.028075] ------>lg_gfdy_probe :END
[ 1.028343] ===========lg_standby_probe start===========
[ 1.028401] ------------[ cut here ]------------
[ 1.028434] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[ 1.028456] autorequest GPIO-17
[ 1.028472] Modules linked in:
[ 1.028499] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.10.0 #213
[ 1.028543] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 1.028583] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 1.028622] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 1.028665] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
[ 1.028706] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_output+0x80/0x2b0)
[ 1.028747] [] (gpiod_direction_output+0x80/0x2b0) from [] (lg_standby_probe+0x48/0xa4)
[ 1.028788] [] (lg_standby_probe+0x48/0xa4) from [] (platform_drv_probe+0x14/0x18)
[ 1.028827] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c)
[ 1.028864] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 1.028901] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 1.028942] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 1.028981] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 1.029018] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 1.029056] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8)
[ 1.029095] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 1.029132] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 1.029174] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 1.029215] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 1.029240] —[ end trace e6aa1d79079698a5 ]—
[ 1.029311] ===========lg_standby_probe end===========
[ 1.029574] ===========lg_power_probe start===========
[ 1.029633] ------------[ cut here ]------------
[ 1.029664] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[ 1.029685] autorequest GPIO-107
[ 1.029701] Modules linked in:
[ 1.029727] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.10.0 #213
[ 1.029768] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 1.029808] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 1.029847] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 1.029890] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
[ 1.029931] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_input+0x58/0x1f0)
[ 1.029971] [] (gpiod_direction_input+0x58/0x1f0) from [] (lg_power_probe+0x3c/0x98)
[ 1.030012] [] (lg_power_probe+0x3c/0x98) from [] (platform_drv_probe+0x14/0x18)
[ 1.030051] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c)
[ 1.030088] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 1.030125] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 1.030165] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 1.030204] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 1.030241] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 1.030279] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8)
[ 1.030317] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 1.030354] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 1.030396] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 1.030437] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 1.030462] —[ end trace e6aa1d79079698a6 ]—
[ 1.030532] ===========lg_power_probe end===========
[ 1.030787] ===========lg_bat_probe start===========
[ 1.030844] ------------[ cut here ]------------
[ 1.030875] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[ 1.030896] autorequest GPIO-12
[ 1.030912] Modules linked in:
[ 1.030939] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.10.0 #213
[ 1.030980] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 1.031019] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 1.031058] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 1.031100] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
[ 1.031143] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_output+0x80/0x2b0)
[ 1.031183] [] (gpiod_direction_output+0x80/0x2b0) from [] (lg_bat_probe+0x48/0xa4)
[ 1.031224] [] (lg_bat_probe+0x48/0xa4) from [] (platform_drv_probe+0x14/0x18)
[ 1.031263] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c)
[ 1.031300] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 1.031337] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 1.031377] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 1.031416] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 1.031453] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 1.031491] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8)
[ 1.031529] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 1.031567] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 1.031607] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 1.031650] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 1.031676] —[ end trace e6aa1d79079698a7 ]—
[ 1.031743] ===========lg_bat_probe end===========
[ 1.031987] ===========lg_bthpower_probe start===========
[ 1.032042] ------------[ cut here ]------------
[ 1.032073] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[ 1.032095] autorequest GPIO-44
[ 1.032111] Modules linked in:
[ 1.032137] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.10.0 #213
[ 1.032177] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 1.032217] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 1.032256] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 1.032299] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
[ 1.032340] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_output+0x80/0x2b0)
[ 1.032380] [] (gpiod_direction_output+0x80/0x2b0) from [] (lg_bthpower_probe+0x48/0xa4)
[ 1.032422] [] (lg_bthpower_probe+0x48/0xa4) from [] (platform_drv_probe+0x14/0x18)
[ 1.032461] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c)
[ 1.032499] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 1.032536] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 1.032576] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 1.032615] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 1.032652] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 1.032690] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8)
[ 1.032728] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 1.032766] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 1.032806] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 1.032848] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 1.032873] —[ end trace e6aa1d79079698a8 ]—
[ 1.032958] ===========lg_bthpower_probe end===========
[ 1.033201] ===========lg_bthcon_probe start===========
[ 1.033255] ------------[ cut here ]------------
[ 1.033286] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[ 1.033307] autorequest GPIO-43
[ 1.033324] Modules linked in:
[ 1.033349] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.10.0 #213
[ 1.033390] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 1.033429] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 1.033469] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 1.033512] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
[ 1.033553] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_input+0x58/0x1f0)
[ 1.033593] [] (gpiod_direction_input+0x58/0x1f0) from [] (lg_bthcon_probe+0x3c/0x98)
[ 1.033635] [] (lg_bthcon_probe+0x3c/0x98) from [] (platform_drv_probe+0x14/0x18)
[ 1.033673] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c)
[ 1.033711] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 1.033748] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 1.033788] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 1.033827] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 1.033865] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 1.033902] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8)
[ 1.033940] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 1.033978] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 1.034018] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 1.034060] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 1.034085] —[ end trace e6aa1d79079698a9 ]—
[ 1.034197] ===========lg_bthcon_probe end===========
[ 1.034465] ===========lg_micdet_probe start===========
[ 1.034525] ------------[ cut here ]------------
[ 1.034556] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[ 1.034578] autorequest GPIO-14
[ 1.034594] Modules linked in:
[ 1.034620] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.10.0 #213
[ 1.034662] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 1.034702] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 1.034741] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 1.034783] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
[ 1.034825] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_input+0x58/0x1f0)
[ 1.034866] [] (gpiod_direction_input+0x58/0x1f0) from [] (lg_micdet_probe+0x3c/0x98)
[ 1.034907] [] (lg_micdet_probe+0x3c/0x98) from [] (platform_drv_probe+0x14/0x18)
[ 1.034946] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c)
[ 1.034983] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 1.035020] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 1.035061] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 1.035100] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 1.035137] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 1.035175] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8)
[ 1.035213] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 1.035251] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 1.035291] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 1.035333] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 1.035358] —[ end trace e6aa1d79079698aa ]—
[ 1.035426] ===========lg_micdet_probe end===========
[ 1.035674] ===========lg_micfir_probe start===========
[ 1.035729] ------------[ cut here ]------------
[ 1.035760] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[ 1.035781] autorequest GPIO-11
[ 1.035797] Modules linked in:
[ 1.035823] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.10.0 #213
[ 1.035864] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 1.035903] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 1.035943] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 1.035985] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
[ 1.036027] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_input+0x58/0x1f0)
[ 1.036067] [] (gpiod_direction_input+0x58/0x1f0) from [] (lg_micfir_probe+0x3c/0x98)
[ 1.036108] [] (lg_micfir_probe+0x3c/0x98) from [] (platform_drv_probe+0x14/0x18)
[ 1.036147] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c)
[ 1.036184] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 1.036221] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 1.036261] [] (_driver_attach+0x60/0x84) from [<c02fbhell@rk312xfor ach_dev+0x50/0x90)
[ 1.036301] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 1.036338] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 1.036376] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8)
[ 1.036414] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 1.036451] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 1.036493] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 1.036534] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 1.036559] —[ end trace e6aa1d79079698ab ]—
[ 1.036626] ===========lg_micfir_probe end===========
[ 1.036869] ===========lg_linein_probe start===========
[ 1.036926] ------------[ cut here ]------------
[ 1.036957] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[ 1.036979] autorequest GPIO-91
[ 1.036994] Modules linked in:
[ 1.037020] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.10.0 #213
[ 1.037061] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 1.037100] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 1.037139] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 1.037182] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
[ 1.037224] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_input+0x58/0x1f0)
[ 1.037264] [] (gpiod_direction_input+0x58/0x1f0) from [] (lg_linein_probe+0x3c/0x98)
[ 1.037305] [] (lg_linein_probe+0x3c/0x98) from [] (platform_drv_probe+0x14/0x18)
[ 1.037344] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c)
[ 1.037381] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 1.037418] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 1.037458] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 1.037498] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 1.037535] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 1.037573] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8)
[ 1.037612] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 1.037649] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 1.037691] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 1.037734] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 1.037759] —[ end trace e6aa1d79079698ac ]—
[ 1.037872] ===========lg_linein_probe end===========
[ 1.038150] ===========lg_avout_probe start===========
[ 1.038211] ------------[ cut here ]------------
[ 1.038244] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[ 1.038266] autorequest GPIO-93
[ 1.038282] Modules linked in:
[ 1.038308] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.10.0 #213
[ 1.038352] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 1.038392] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 1.038432] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 1.038475] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
[ 1.038517] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_output+0x80/0x2b0)
[ 1.038558] [] (gpiod_direction_output+0x80/0x2b0) from [] (lg_avout_probe+0x48/0xa4)
[ 1.038599] [] (lg_avout_probe+0x48/0xa4) from [] (platform_drv_probe+0x14/0x18)
[ 1.038638] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c)
[ 1.038676] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 1.038713] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 1.038753] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 1.038793] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 1.038830] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 1.038868] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8)
[ 1.038906] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 1.038943] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 1.038984] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 1.039027] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 1.039051] —[ end trace e6aa1d79079698ad ]—
[ 1.039122] ===========lg_avout_probe end===========
[ 1.039829] device-mapper: uevent: version 1.0.3
[ 1.040368] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.041032] Bluetooth: HCI UART driver ver 2.2
[ 1.041061] Bluetooth: HCI H4 protocol initialized
[ 1.041081] Bluetooth: HCILL protocol initialized
[ 1.041101] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.19
[ 1.041122] rtk_btusb: Register usb char device interface for BT driver
[ 1.041517] usbcore: registered new interface driver rtk_btusb
[ 1.045215] cpufreq version 1.0, suspend freq 816 MHz
[ 1.045592] cpuidle: using governor ladder
[ 1.045611] cpuidle: using governor menu
[ 1.045666] Synopsys Designware Multimedia Card Interface Driver
[ 1.046031] dwmmc_rockchip 1021c000.rksdmmc: Version ID is 270a
[ 1.046387] dwmmc_rockchip 1021c000.rksdmmc: Using external DMA controller.
[ 1.046729] 3445..dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc0]
[ 1.046750] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 1.046978] 1410..dw_mci_set_ios: no card. [mmc0]
[ 1.057647] 1410..dw_mci_set_ios: no card. [mmc0]
[ 1.077043] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.077059] dwmmc_rockchip 1021c000.rksdmmc: DW MMC controller at irq 48, 32 bit host data width, 256 deep fifo
[ 1.077071] dwmmc_rockchip 1021c000.rksdmmc: 1 slots initialized
[ 1.077399] dwmmc_rockchip 10218000.rksdmmc: Version ID is 270a
[ 1.078279] dwmmc_rockchip 10218000.rksdmmc: Using external DMA controller.
[ 1.080587] 3445..dw_mci_init_slot: fmin=200000, fmax=37500000 [mmc1]
[ 1.080606] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 1.080837] 1410..dw_mci_set_ios: no card. [mmc1]
[ 1.096689] 1410..dw_mci_set_ios: no card. [mmc1]
[ 1.116402] 1410..dw_mci_set_ios: no card. [mmc1]
[ 1.116430] dwc_otg_hcd_suspend, usb device mode
[ 1.116453] dwmmc_rockchip 10218000.rksdmmc: DW MMC controller at irq 47, 32 bit host data width, 256 deep fifo
[ 1.116473] dwmmc_rockchip 10218000.rksdmmc: 1 slots initialized
[ 1.116847] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.119471] usbcore: registered new interface driver usbhid
[ 1.119489] usbhid: USB HID core driver
[ 1.120106] zram: Created 1 device(s) …
[ 1.120721] `bz?initialized
[ 1.120993
[14:59:33.177]收←◆\0
