重新烧写uboot后无法启动
emmc换了一片,想试试完全空白的emmc能不能启动成功。
自己编译了整个系统镜像,在原来的emmc上擦除后用maskrom模式下载,可以启动成功。
换了一片emmc后,下载成功。但无法进入界面。
命令行打印如下:
DDR Version 1.17 20190115
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1: 2017-06-09, version: 1.09
CPUId = 0x0
ChipType = 0x10, 1827
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 66565
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x7a274
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):2bb878d
NOTICE:  BL31: Built : 11:57:30, Jan  4 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1181): pd status 3e
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-195-g8f090d20 #6 Fri Dec  7 06:11:20 UTC 2018 aarch64)
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Apr 22 2019 - 21:09:02)
CPU: rk3399
cpu version = 0
CPU's clock information:
    aplll = 816000000HZ
    apllb = 24000000HZ
    gpll = 800000000HZ
               aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
    cpll = 800000000HZ
    dpll = 800000000HZ
    vpll = 24000000HZ
    npll = 24000000HZ
    ppll = 676000000HZ
Board:  Rockchip platform Board
Uboot as second level loader
DRAM:  Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can't find dts node for fixed
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can't find dts node for pwm1
    aplll = 816000000HZ
    apllb = 24000000HZ
    gpll = 800000000HZ
    cpll = 800000000HZ
    dpll = 800000000HZ
    vpll = 24000000HZ
    npll = 24000000HZ
    ppll = 676000000HZ
#Boot ver: 2019-04-22#1.09
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
failed to find phy node
no fuel gauge found
Using display timing dts
Detailed mode clock 150000 kHz, flags[a]
    H: 1920 2202 2212 2222
    V: 1080 1090 1100 1125
bus_format: 100e
rk lcdc - 0 dclk set: dclk = 150000000HZ, pll select = 1, div = 1
final DSI-Link bandwidth: 1000 Mbps x 4
failed to wait for phy clk lane stop state
failed to display kernel logo
checkKey
vbus = 0
got recovery cmd from misc.
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel   @ 0x00280000 (0x0125a008)
ramdisk  @ 0x04bf0000 (0x007b1848)
bootrk: do_bootm_linux...
   Loading Device Tree to 0000000004600000, end 0000000004616f78 ... OK
Add bank:000000000a200000, 0000000075e00000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Initializing cgroup subsys schedtune
[    0.000000] Linux version 4.4.103 (xin@xin-virtual-machine) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Sun Apr 21 22:09:08 CST 2019
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] hdmi init vic is -1
[    0.000000] Reserved memory: failed to reserve memory for node 'stb-devinfo@00000000': base 0x0000000000000000, size 0 MiB
[    0.000000] cma: Reserved 16 MiB at 0x000000007f000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eef5000 s45504 r8192 d32320 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 507912
[    0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00300000@0x000B4000(system),0x00008000@0x003B4000(metadata),0x00002000@0x003BC000(baseparamer),-@0x003BE000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2019-04-22_21:09:02 hdmi.vic=-1 SecureBootCheckOk=0
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] software IO TLB [mem 0x7eead000-0x7eeed000] (0MB) mapped at [ffffffc07eead000-ffffffc07eeecfff]
[    0.000000] Memory: 1982412K/2064384K available (11006K kernel code, 1640K rwdata, 5256K rodata, 832K init, 1073K bss, 65588K reserved, 16384K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000]       .init : 0xffffff8009070000 - 0xffffff8009140000   (   832 KB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008b40000   ( 11008 KB)
[    0.000000]     .rodata : 0xffffff8008b40000 - 0xffffff8009070000   (  5312 KB)
[    0.000000]       .data : 0xffffff8009140000 - 0xffffff80092da008   (  1641 KB)
[    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
[    0.000000]               0xffffffbdc0008000 - 0xffffffbdc2000000   (    31 MB actual)
[    0.000000]     fixed   : 0xffffffbffe7fd000 - 0xffffffbffec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc080000000   (  2046 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[    0.000000] ITS: allocated 65536 Devices @a200000 (psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x000000000a280000
[    0.000000] ITS: Allocated 1792 chunks for LPIs
[    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] CPU0: using LPI pending table @0x000000000a290000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[    0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001986] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.002948] pid_max: default: 32768 minimum: 301
[    0.003464] Security Framework initialized
[    0.003853] SELinux:  Initializing.
[    0.004265] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.004894] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.006323] Initializing cgroup subsys freezer
[    0.006751] Initializing cgroup subsys debug
[    0.008070] sched-energy: Sched-energy-costs installed from DT
[    0.008620] CPU0: update cpu_capacity 401
[    0.009074] ASID allocator initialised with 65536 entries
[    0.025900] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.027200] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.039292] Detected VIPT I-cache on CPU1
[    0.039325] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.039359] CPU1: using LPI pending table @0x000000000a3f0000
[    0.039402] CPU1: update cpu_capacity 401
[    0.039405] CPU1: Booted secondary processor [410fd034]
[    0.049286] Detected VIPT I-cache on CPU2
[    0.049305] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.049338] CPU2: using LPI pending table @0x000000007c020000
[    0.049366] CPU2: update cpu_capacity 401
[    0.049369] CPU2: Booted secondary processor [410fd034]
[    0.059323] Detected VIPT I-cache on CPU3
[    0.059342] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.059374] CPU3: using LPI pending table @0x000000007c060000
[    0.059401] CPU3: update cpu_capacity 401
[    0.059404] CPU3: Booted secondary processor [410fd034]
[    0.069373] Detected PIPT I-cache on CPU4
[    0.069402] CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.069441] CPU4: using LPI pending table @0x000000007c0a0000
[    0.069483] CPU4: update cpu_capacity 1024
[    0.069486] CPU4: Booted secondary processor [410fd082]
[    0.079396] Detected PIPT I-cache on CPU5
[    0.079414] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.079449] CPU5: using LPI pending table @0x000000007c0e0000
[    0.079476] CPU5: update cpu_capacity 1024
[    0.079479] CPU5: Booted secondary processor [410fd082]
[    0.079564] Brought up 6 CPUs
[    0.091666] SMP: Total of 6 processors activated.
[    0.092108] CPU features: detected feature: GIC system register CPU interface
[    0.092777] CPU: All CPU(s) started at EL2
[    0.093200] alternatives: patching kernel code
[    0.095287] devtmpfs: initialized
[    0.116455] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.117416] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.118743] pinctrl core: initialized pinctrl subsystem
[    0.120836] Failed to find legacy iommu devices
[    0.121650] NET: Registered protocol family 16
[    0.122438] schedtune: init normalization constants...
[    0.122959] schedtune: CLUSTER[0-3]      min_pwr:    56 max_pwr:   222
[    0.123593] schedtune: CPU[0]            min_pwr:     0 max_pwr:   222
[    0.124228] schedtune: CPU[1]            min_pwr:     0 max_pwr:   222
[    0.124862] schedtune: CPU[2]            min_pwr:     0 max_pwr:   222
[    0.125495] schedtune: CPU[3]            min_pwr:     0 max_pwr:   222
[    0.126130] schedtune: CLUSTER[4-5]      min_pwr:    65 max_pwr:  1108
[    0.126768] schedtune: CPU[4]            min_pwr:     0 max_pwr:  1108
[    0.127401] schedtune: CPU[5]            min_pwr:     0 max_pwr:  1108
[    0.128034] schedtune: SYSTEM            min_pwr:   121 max_pwr:  4434
[    0.128668] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[    0.129408] schedtune: verify normalization constants...
[    0.129925] schedtune: max_pwr/2^0: 4313 => norm_pwr:  1024
[    0.130471] schedtune: max_pwr/2^1: 2156 => norm_pwr:   511
[    0.131012] schedtune: max_pwr/2^2: 1078 => norm_pwr:   255
[    0.131552] schedtune: max_pwr/2^3:  539 => norm_pwr:   127
[    0.132093] schedtune: max_pwr/2^4:  269 => norm_pwr:    63
[    0.132634] schedtune: max_pwr/2^5:  134 => norm_pwr:    31
[    0.133175] schedtune: configured to support 5 boost groups
[    0.143846] cpuidle: using governor ladder
[    0.153848] cpuidle: using governor menu
[    0.154241] Registered FIQ tty driver
[    0.154922] vdso: 2 pages (1 code @ ffffff8008b46000, 1 data @ ffffff8009144000)
[    0.155664] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.157747] DMA: preallocated 2048 KiB pool for atomic allocations
[    0.178796] console [pstore0] enabled
[    0.179388] pstore: Registered ramoops as persistent store backend
[    0.179992] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[    0.182851] fiq debugger fiq mode enabled
[ [    0.183495] console [ttyFIQ0] enabled
[[     0.184196] bootconsole [uart0] disabled
[    0.185105] Registered fiq debugger ttyFIQ0
[    0.215225] Rockchip hdmi driver version 2.0
[    0.217541] iommu: Adding device ff650000.vpu_service to group 0
[    0.217645] iommu: Adding device ff660000.rkvdec to group 1
[    0.217713] iommu: Adding device ff670000.iep to group 2
[    0.217813] iommu: Adding device ff8f0000.vop to group 3
[    0.217895] iommu: Adding device ff900000.vop to group 4
[    0.218006] iommu: Adding device ff910000.isp to group 5
[    0.218083] iommu: Adding device ff920000.isp to group 6
[    0.218763] rk_iommu ff670800.iommu: can't get aclk
[    0.218782] rk_iommu ff670800.iommu: can't get hclk
[    0.219661] SCSI subsystem initialized
[    0.219995] usbcore: registered new interface driver usbfs
[    0.220042] usbcore: registered new interface driver hub
[    0.220117] usbcore: registered new device driver usb
[    0.220506] media: Linux media interface: v0.10
[    0.220553] Linux video capture interface: v2.00
[    0.220689] pps_core: LinuxPPS API ver. 1 registered
[    0.220701] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.220725] PTP clock support registered
[    0.222242] Advanced Linux Sound Architecture Driver Initialized.
[    0.222707] Bluetooth: Core ver 2.21
[    0.222756] NET: Registered protocol family 31
[    0.222768] Bluetooth: HCI device and connection manager initialized
[    0.222786] Bluetooth: HCI socket layer initialized
[    0.222801] Bluetooth: L2CAP socket layer initialized
[    0.222830] Bluetooth: SCO socket layer initialized
[    0.223856] rockchip-cpuinfo cpuinfo: Serial         : 9003721ebe94e80f
[    0.224354] clocksource: Switched to clocksource arch_sys_counter
[    0.268407] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.268648] NET: Registered protocol family 2
[    0.269068] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.269212] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    0.269489] TCP: Hash tables configured (established 16384 bind 16384)
[    0.269566] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    0.269629] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    0.269808] NET: Registered protocol family 1
[    0.270318] Trying to unpack rootfs image as initramfs...
[    0.610759] Freeing initrd memory: 7876K
[    0.611303] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.611394] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.614022] audit: initializing netlink subsys (disabled)
[    0.614096] audit: type=2000 audit(0.610:1): initialized
[    0.619100] VFS: Disk quotas dquot_6.6.0
[    0.619223] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.620591] fuse init (API version 7.23)
[    0.621713]
[    0.621713] TEE Core Framework initialization (ver 1:0.1)
[    0.621745] TEE armv7 Driver initialization
[    0.622117] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[    0.622135] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[    0.622333] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[    0.626292] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.626322] io scheduler noop registered
[    0.626495] io scheduler cfq registered (default)
[    0.627784] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[    0.628848] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[    0.634032] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    0.634059] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    0.634083] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    1.154449] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    1.155199] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    1.156634] backlight supply power not found, using dummy regulator
[    1.157424] pwm-backlight backlight: invalid default brightness level: 200, using 105
[    1.158963] iep: failed to find iep power down clock source.
[    1.160013] IEP Power ON
[    1.160466] IEP Power OFF
[    1.160799] IEP Driver loaded succesfully
[    1.161444] Module initialized.
[    1.162074] rk-vcodec ff650000.vpu_service: probe device
[    1.162130] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07c301c10
[    1.162305] rk-vcodec ff650000.vpu_service: allocator is drm
[    1.162360] rk-vcodec ff650000.vpu_service: checking hw id 0
[    1.162849] rk-vcodec ff650000.vpu_service: init success
[    1.163442] rk-vcodec ff660000.rkvdec: probe device
[    1.163490] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07c302410
[    1.163620] rk-vcodec ff660000.rkvdec: allocator is drm
[    1.163675] rk-vcodec ff660000.rkvdec: checking hw id 6876
[    1.163987] rk-vcodec ff660000.rkvdec: init success
[    1.165713] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.165734] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    1.167051] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.167071] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.168730] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    1.170325] console [ttyS0] disabled
[    1.17038h180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[    1.170970] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[    1.171437] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[    1.175417] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[    1.175650] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[    1.175681] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[    1.175940] rockchip-drm display-subsystem: master bind failed: -517
[    1.177481] ff960000.dsi.0 supply power not found, using dummy regulator
[    1.177743] panel-simple-dsi ff960000.dsi.0: panel_simple_dsi_parse_dcs_cmds: dcs_cmd=29 len=243, cmd_cnt=27
[    1.177763] panel-simple-dsi ff960000.dsi.0: panel_simple_dsi_parse_dcs_cmds: dcs_cmd=5 len=8, cmd_cnt=2
[    1.178186] mali ff9a0000.gpu: Failed to get regulator
[    1.178201] mali ff9a0000.gpu: Power control initialization failed
[    1.178513] Unable to detect cache hierarchy from DT for CPU 0
[    1.190093] brd: module loaded
[    1.194805] loop: module loaded
[    1.195329] zram: Added device: zram0
[    1.195932] SCSI Media Changer driver v0.25
[    1.197237] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[    1.197260] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[    1.198095] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    1.368440] wk2xxx_serial_init()
[    1.368456] wk2xxx_request_port
[    1.368470] ttysWK0 at I/O 0x1 (irq = 105, base_baud = 460800) is a wk2xxx
[    1.368730] uart_add_one_port success for line i:= 0 with right 0
[    1.368743] wk2xxx_request_port
[    1.368755] ttysWK1 at I/O 0x2 (irq = 105, base_baud = 460800) is a wk2xxx
[    1.368946] uart_add_one_port success for line i:= 1 with right 0
[    1.368959] wk2xxx_request_port
[    1.368971] ttysWK2 at I/O 0x3 (irq = 105, base_baud = 460800) is a wk2xxx
[    1.369157] uart_add_one_port success for line i:= 2 with right 0
[    1.369170] wk2xxx_request_port
[    1.369181] ttysWK3 at I/O 0x4 (irq = 105, base_baud = 460800) is a wk2xxx
[    1.369364] uart_add_one_port success for line i:= 3 with right 0
[    1.369376] uart_add_one_port = 0x0
[    1.369403] register spi return v = :0
[    1.369455] tun: Universal TUN/TAP device driver, 1.6
[    1.369466] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.370376] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[    1.370469] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    1.370489] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    1.370503] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[    1.370530] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    1.370703] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    1.375723] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    1.375851] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    1.375862]  Ring mode enabled
[    1.375871]  DMA HW capability register supported
[    1.375881]  Normal descriptors
[    1.375892]  RX Checksum Offload Engine supported (type 2)
[    1.375902]  Wake-Up On Lan supported
[    1.375942]  Enable RX Mitigation via HW Watchdog Timer
[    1.448821] libphy: stmmac: probed
[    1.448864] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[    1.448883] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[    1.448901] eth%d: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02)
[    1.448918] eth%d: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03)
[    1.448933] eth%d: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04)
[    1.448946] eth%d: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05)
[    1.448958] eth%d: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06)
[    1.448971] eth%d: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07)
[    1.448982] eth%d: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08)
[    1.448994] eth%d: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09)
[    1.449006] eth%d: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a)
[    1.449018] eth%d: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b)
[    1.449030] eth%d: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c)
[    1.449041] eth%d: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d)
[    1.449053] eth%d: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e)
[    1.449064] eth%d: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f)
[    1.449076] eth%d: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10)
[    1.449087] eth%d: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11)
[    1.449099] eth%d: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12)
[    1.449111] eth%d: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13)
[    1.449122] eth%d: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14)
[    1.449134] eth%d: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15)
[    1.449146] eth%d: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16)
[    1.449158] eth%d: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17)
[    1.449169] eth%d: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18)
[    1.449181] eth%d: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19)
[    1.449193] eth%d: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a)
[    1.449205] eth%d: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b)
[    1.449217] eth%d: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c)
[    1.449228] eth%d: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d)
[    1.449241] eth%d: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e)
[    1.449253] eth%d: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f)
[    1.450125] PPP generic driver version 2.4.2
[    1.450333] PPP BSD Compression module registered
[    1.450348] PPP Deflate Compression module registered
[    1.450382] PPP MPPE Compression module registered
[    1.450400] NET: Registered protocol family 24
[    1.450439] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[    1.450453] CSLIP: code copyright 1989 Regents of the University of California.
[    1.450524] usbcore: registered new interface driver mt7601u
[    1.450547] Rockchip WiFi SYS interface (V1.00) ...
[    1.450608] usbcore: registered new interface driver catc
[    1.450650] usbcore: registered new interface driver kaweth
[    1.450666] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    1.450705] usbcore: registered new interface driver pegasus
[    1.450747] usbcore: registered new interface driver rtl8150
[    1.450792] usbcore: registered new interface driver r8152
[    1.450807] hso: drivers/net/usb/hso.c: Option Wireless
[    1.450868] usbcore: registered new interface driver hso
[    1.450915] usbcore: registered new interface driver asix
[    1.450956] usbcore: registered new interface driver ax88179_178a
[    1.450998] usbcore: registered new interface driver cdc_ether
[    1.451069] usbcore: registered new interface driver cdc_eem
[    1.451111] usbcore: registered new interface driver dm9601
[    1.451165] usbcore: registered new interface driver smsc75xx
[    1.451214] usbcore: registered new interface driver smsc95xx
[    1.451264] usbcore: registered new interface driver gl620a
[    1.451307] usbcore: registered new interface driver net1080
[    1.451348] usbcore: registered new interface driver plusb
[    1.451389] usbcore: registered new interface driver rndis_host
[    1.451432] usbcore: registered new interface driver cdc_subset
[    1.451473] usbcore: registered new interface driver zaurus
[    1.451519] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.451577] usbcore: registered new interface driver int51x1
[    1.451620] usbcore: registered new interface driver kalmia
[    1.451662] usbcore: registered new interface driver ipheth
[    1.451707] usbcore: registered new interface driver sierra_net
[    1.451753] usbcore: registered new interface driver cx82310_eth
[    1.451804] usbcore: registered new interface driver cdc_ncm
[    1.451845] usbcore: registered new interface driver qmi_wwan
[    1.451888] usbcore: registered new interface driver cdc_mbim
[    1.457556] rockchip-dwc3 usb@fe800000: fail to get drvdata hcd
[    1.465510] rockchip-typec-phy ff800000.phy: Needed 1 loops to turn on
[    1.465737] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[    1.466407] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.466425] ehci-pci: EHCI PCI platform driver
[    1.466485] ehci-platform: EHCI generic platform driver
[    1.470134] ehci-platform fe380000.usb: EHCI Host Controller
[    1.470166] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[    1.470338] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[    1.477704] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    1.477843] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.477860] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.477874] usb usb1: Product: EHCI Host Controller
[    1.477887] usb usb1: Manufacturer: Linux 4.4.103 ehci_hcd
[    1.477899] usb usb1: SerialNumber: fe380000.usb
[    1.478565] hub 1-0:1.0: USB hub found
[    1.478616] hub 1-0:1.0: 1 port detected
[    1.482694] ehci-platform fe3c0000.usb: EHCI Host Controller
[    1.482727] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[    1.482895] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[    1.491067] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    1.491249] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.491266] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.491281] usb usb2: Product: EHCI Host Controller
[    1.491293] usb usb2: Manufacturer: Linux 4.4.103 ehci_hcd
[    1.491306] usb usb2: SerialNumber: fe3c0000.usb
[    1.491888] hub 2-0:1.0: USB hub found
[    1.491928] hub 2-0:1.0: 1 port detected
[    1.492761] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.492799] ohci-platform: OHCI generic platform driver
[    1.493222] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    1.493254] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[    1.493482] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[    1.548560] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    1.548588] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.548605] usb usb3: Product: Generic Platform OHCI controller
[    1.548619] usb usb3: Manufacturer: Linux 4.4.103 ohci_hcd
[    1.548633] usb usb3: SerialNumber: fe3a0000.usb
[    1.549228] hub 3-0:1.0: USB hub found
[    1.549274] hub 3-0:1.0: 1 port detected
[    1.549959] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    1.549991] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[    1.550158] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[    1.605208] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    1.605248] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.605264] usb usb4: Product: Generic Platform OHCI controller
[    1.605279] usb usb4: Manufacturer: Linux 4.4.103 ohci_hcd
[    1.605294] usb usb4: SerialNumber: fe3e0000.usb
[    1.605894] hub 4-0:1.0: USB hub found
[    1.605934] hub 4-0:1.0: 1 port detected
[    1.607323] usbcore: registered new interface driver cdc_acm
[    1.607337] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.607421] usbcore: registered new interface driver usblp
[    1.607486] usbcore: registered new interface driver cdc_wdm
[    1.607552] usbcore: registered new interface driver uas
[    1.607713] usbcore: registered new interface driver usb-storage
[    1.607772] usbcore: registered new interface driver ums-alauda
[    1.607835] usbcore: registered new interface driver ums-cypress
[    1.607894] usbcore: registered new interface driver ums-datafab
[    1.607950] usbcore: registered new interface driver ums_eneub6250
[    1.608005] usbcore: registered new interface driver ums-freecom
[    1.608063] usbcore: registered new interface driver ums-isd200
[    1.608119] usbcore: registered new interface driver ums-jumpshot
[    1.608175] usbcore: registered new interface driver ums-karma
[    1.608234] usbcore: registered new interface driver ums-onetouch
[    1.608296] usbcore: registered new interface driver ums-sddr09
[    1.608354] usbcore: registered new interface driver ums-sddr55
[    1.608412] usbcore: registered new interface driver ums-usbat
[    1.608522] usbcore: registered new interface driver usbserial
[    1.608573] usbcore: registered new interface driver usbserial_generic
[    1.608613] usbserial: USB Serial support registered for generic
[    1.608674] usbcore: registered new interface driver ch341
[    1.608716] usbserial: USB Serial support registered for ch341-uart
[    1.608777] usbcore: registered new interface driver cp210x
[    1.608815] usbserial: USB Serial support registered for cp210x
[    1.608902] usbcore: registered new interface driver option
[    1.608940] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.609213] usbcore: registered new interface driver pl2303
[    1.609253] usbserial: USB Serial support registered for pl2303
[    1.609332] usbcore: registered new interface driver trancevibrator
[    1.609349] usb20_otg: version 3.10a 21-DEC-2012
[    1.609644] usb20_host: version 3.10a 21-DEC-2012
[    1.610320] usbcore: registered new interface driver xpad
[    1.610387] usbcore: registered new interface driver usb_acecad
[    1.610459] usbcore: registered new interface driver aiptek
[    1.610524] usbcore: registered new interface driver gtco
[    1.610589] usbcore: registered new interface driver hanwang
[    1.610651] usbcore: registered new interface driver kbtab
[    1.610668] ==gsl_ts_init==
[    1.610708] ret=0
[    1.611418] .. rk pwm remotectl v1.1 init
[    1.611737] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[    1.612361] sensor_register_slave:mma8452,id=17
[    1.612380] sensor_register_slave:lis3dh,id=7
[    1.612397] sensor_register_slave:mma7660,id=18
[    1.612414] sensor_register_slave:lsm303d,id=22
[    1.612430] sensor_register_slave:gs_mc3230,id=23
[    1.612439] [Gsensor]   gsensor_init
[    1.612455] sensor_register_slave:mpu6880_acc,id=24
[    1.612473] sensor_register_slave:mpu6500_acc,id=25
[    1.612489] sensor_register_slave:lsm330_acc,id=26
[    1.612506] sensor_register_slave:akm8975,id=29
[    1.612523] sensor_register_slave:akm8963,id=30
[    1.612539] sensor_register_slave:l3g4200d,id=44
[    1.612555] sensor_register_slave:l3g20d,id=45
[    1.612572] sensor_register_slave:ewtsa,id=46
[    1.612588] sensor_register_slave:lsm330_gyro,id=50
[    1.612604] sensor_register_slave:cm3217,id=52
[    1.612621] sensor_register_slave:cm3218,id=53
[    1.613565] i2c /dev entries driver
[    1.615111] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    1.615229] fan53555-reg: supplied by vcc5v0_sys
[    1.617291] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    1.617366] fan53555-reg: supplied by vcc5v0_sys
[    1.619620] rk808 0-001b: Pmic Chip id: 0x0
[    1.623501] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    1.623577] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    1.623705] DCDC_REG1: supplied by vcc3v3_sys
[    1.624591] DCDC_REG2: supplied by vcc3v3_sys
[    1.625215] DCDC_REG3: supplied by vcc3v3_sys
[    1.625488] DCDC_REG4: supplied by vcc3v3_sys
[    1.625994] LDO_REG1: supplied by vcc3v3_sys
[    1.627174] LDO_REG2: supplied by vcc3v3_sys
[    1.628194] LDO_REG3: supplied by vcc3v3_sys
[    1.629237] LDO_REG4: supplied by vcc3v3_sys
[    1.630244] LDO_REG5: supplied by vcc3v3_sys
[    1.631281] LDO_REG6: supplied by vcc3v3_sys
[    1.632278] LDO_REG7: supplied by vcc3v3_sys
[    1.633312] LDO_REG8: supplied by vcc3v3_sys
[    1.634295] SWITCH_REG1: supplied by vcc3v3_sys
[    1.634605] SWITCH_REG2: supplied by vcc3v3_sys
[    1.638426] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[    1.639048] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009942000
[    1.639951] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009944000
[    1.640078] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[    1.640096] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[    1.640112] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer  on device rockchip-pinctrl
[    1.640127] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[    1.640580] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff8009946000
[    1.641420] GSLX680 Enter gsl_ts_probe
[    1.797704] usb 2-1: new high-speed USB device number 2 using ehci-platform
[    1.921696] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201
[    1.921736] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.921757] usb 2-1: Product: USB 2.0 Hub [MTT]
[    1.922314] hub 2-1:1.0: USB hub found
[    1.922444] hub 2-1:1.0: 7 ports detected
[    1.951046] gsl_ts_probe--1305, i2c_master_recv fail
[    1.951123] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009948000
[    1.952362] IR NEC protocol handler initialized
[    1.952402] IR RC5(x/sz) protocol handler initialized
[    1.952420] IR RC6 protocol handler initialized
[    1.952436] IR JVC protocol handler initialized
[    1.952452] IR Sony protocol handler initialized
[    1.952465] IR SANYO protocol handler initialized
[    1.952479] IR Sharp protocol handler initialized
[    1.952493] IR MCE Keyboard/mouse protocol handler initialized
[    1.952508] IR XMP protocol handler initialized
[    1.952823] usbcore: registered new interface driver uvcvideo
[    1.952834] USB Video Class driver (1.1.1)
[    1.952854] CamSys driver version: v0.38.0, CamSys head file version: v1.0.0
[    1.958789] __power_supply_register: Expected proper parent device for 'test_ac'
[    1.959008] __power_supply_register: Expected proper parent device for 'test_battery'
[    1.959324] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[    1.959448] __power_supply_register: Expected proper parent device for 'test_usb'
[    1.962778] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[    1.964206] device-mapper: uevent: version 1.0.3
[    1.964642] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    1.964894] Bluetooth: HCI UART driver ver 2.3
[    1.964909] Bluetooth: HCI UART protocol H4 registered
[    1.964919] Bluetooth: HCI UART protocol LL registered
[    1.964935] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[    1.964945] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[    1.964955] rtk_btusb: Register usb char device interface for BT driver
[    1.965241] usbcore: registered new interface driver rtk_btusb
[    1.965817] cpu cpu0: leakage=19
[    1.983472] cpu cpu0: temp=46250, pvtm=147784 (147454 + 330)
[    1.983894] cpu cpu0: pvtm-sel=1
[    1.984313] cpu cpu4: leakage=36
[    1.996540] cpu cpu4: temp=46250, pvtm=154617 (154442 + 175)
[    1.996695] cpu cpu4: pvtm-sel=1
[    2.002280] sdhci: Secure Digital Host Controller Interface driver
[    2.002329] sdhci: Copyright(c) Pierre Ossman
[    2.002350] Synopsys Designware Multimedia Card Interface Driver
[    2.003578] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    2.003736] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    2.003758] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    2.003819] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    2.003847] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.003902] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    2.003915] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    2.005022] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    2.005149] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    2.005169] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    2.005220] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    2.005246] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.005362] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[    2.006271] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.008220] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[    2.008236] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[    2.034479] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    2.036638] hidraw: raw HID events driver (C) Jiri Kosina
[    2.041304] usbcore: registered new interface driver usbhid
[    2.041322] usbhid: USB HID core driver
[    2.041483] inv_mpu_iio: inv_mpu_init:746
[    2.042050] ashmem: initialized
[    2.044717] ff100000.saradc supply vref not found, using dummy regulator
[    2.050487] rknandbase v1.1 2016-11-08
[    2.051160] usbcore: registered new interface driver snd-usb-audio
[    2.052546] rt5640 1-001c: Can not read property hp-con-gpio
[    2.052590] rt5640 1-001c: Can not read property: linein-mute.
[    2.065202] lkd tc358749x_parse_dts: power(1)
[    2.065301] lkd tc358749x_parse_dts: int(0)
[    2.065389] lkd tc358749x_parse_dts: reset(1)
[    2.075878] mmc0: MAN_BKOPS_EN bit is not set
[    2.076457] tc358749x 1-000f: tc358749x_parse_dts success
[    2.076627] tc358749x 1-000f: tc358749x_i2c_probe success
[    2.082249] u32 classifier
[    2.082283]     Actions configured
[    2.082353] Netfilter messages via NETLINK v0.30.
[    2.082439] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    2.082931] ctnetlink v0.93: registering with nfnetlink.
[    2.083805] xt_time: kernel timezone is -0000
[    2.084676] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.084865] arp_tables: (C) 2002 David S. Miller
[    2.085284] Initializing XFRM netlink socket
[    2.085730] NET: Registered protocol family 10
[    2.086700] mip6: Mobile IPv6
[    2.086736] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    2.087883] sit: IPv6 over IPv4 tunneling driver
[    2.088351] NET: Registered protocol family 17
[    2.088382] NET: Registered protocol family 15
[    2.088422] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    2.088658] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    2.089076] Bridge firewalling registered
[    2.089096] Ebtables v2.0 registered
[    2.089219] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[    2.089389] Bluetooth: RFCOMM TTY layer initialized
[    2.089412] Bluetooth: RFCOMM socket layer initialized
[    2.089438] Bluetooth: RFCOMM ver 1.11
[    2.089464] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.089475] Bluetooth: BNEP filters: protocol multicast
[    2.089491] Bluetooth: BNEP socket layer initialized
[    2.089509] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.089524] Bluetooth: HIDP socket layer initialized
[    2.089542] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[    2.089561] l2tp_core: L2TP core driver, V2.0
[    2.089584] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    2.089613] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    2.089831] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[    2.089912] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    2.089969] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[    2.089981] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    2.089994] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    2.090071] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[    2.090085] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    2.090098] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    2.090119] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[    2.090156] [BT_RFKILL]: Enter rfkill_rk_init
[    2.090535] rkpart: partition size too small (0)
[    2.090557]  parameter: 0x000000000 -- 0x000400000 (4 MB)
[    2.090571]      uboot: 0x000400000 -- 0x000800000 (4 MB)
[    2.090584]      trust: 0x000800000 -- 0x000c00000 (4 MB)
[    2.090600] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[    2.090617]       misc: 0x000c00000 -- 0x001000000 (4 MB)
[    2.090630] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[    2.090644]   resource: 0x001000000 -- 0x002000000 (16 MB)
[    2.090652] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[    2.090673]     kernel: 0x002000000 -- 0x003800000 (24 MB)
[    2.090678]      800000 -- 0x005800000 (32 MB)
[    2.090683]   recovery: 0x005800000 -- 0x007800000 (32 MB)
[    2.090687]     backup: 0x007800000 -- 0x00e800000 (112 MB)
[    2.090691]      cache: 0x00e800000 -- 0x016800000 (128 MB)
[    2.090694]     system: 0x016800000 -- 0x076800000 (1536 MB)
[    2.090699]   metadata: 0x076800000 -- 0x077800000 (16 MB)
[    2.090702] baseparamer: 0x077800000 -- 0x077c00000 (4 MB)
[    2.090706]   userdata: 0x077c00000 -- 0x3a3a00000 (12990 MB)
[    2.090750] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[    2.091358]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[    2.091359] [BT_RFKILL]: Request irq for bt wakeup host
[    2.091413] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[    2.091440] [BT_RFKILL]: ** disable irq
[    2.091696] [BT_RFKILL]: bt_default device registered.
[    2.091985] sensor_register_slave:mpu6880_gyro,id=49
[    2.093785] Registered cp15_barrier emulation handler
[    2.093874] vendor storage:20160801 ret = 0
[    2.093881] Registered setend emulation handler
[    2.094692] registered taskstats version 1
[    2.095705] rockchip ion idev is NULL
[    2.095725] rga2 ff680000.rga: rga ion client create success!
[    2.095939] rga: Driver loaded successfully ver:3.02
[    2.097741] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[    2.098031] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[    2.098113] rockchip-drm display-subsystem: bound ff960000.dsi (ops dw_mipi_dsi_ops)
[    2.098652] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[    2.098693] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.098786] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    2.103228] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[    2.103250] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.103265] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[    2.140456] rockchip-drm display-subsystem: fb0:  frame buffer device
[    2.154031] mali ff9a0000.gpu: leakage=25
[    2.167173] mali ff9a0000.gpu: temp=46875, pvtm=122757 (122697 + 60)
[    2.168694] mali ff9a0000.gpu: pvtm-sel=1
[    2.170032] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[    2.171537] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[    2.172240] mali ff9a0000.gpu: Probed as mali0
[    2.177871] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    2.177913] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[    2.178137] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[    2.178181] xhci-hcd xhci-hcd.9.auto: irq 236, io mem 0xfe800000
[    2.178296] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    2.178312] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.178324] usb usb5: Product: xHCI Host Controller
[    2.178335] usb usb5: Manufacturer: Linux 4.4.103 xhci-hcd
[    2.178345] usb usb5: SerialNumber: xhci-hcd.9.auto
[    2.178817] hub 5-0:1.0: USB hub found
[    2.178846] hub 5-0:1.0: 1 port detected
[    2.179063] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    2.179080] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 6
[    2.179134] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.179212] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[    2.179225] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.179237] usb usb6: Product: xHCI Host Controller
[    2.179247] usb usb6: Manufacturer: Linux 4.4.103 xhci-hcd
[    2.179257] usb usb6: SerialNumber: xhci-hcd.9.auto
[    2.179618] hub 6-0:1.0: USB hub found
[    2.179644] hub 6-0:1.0: 1 port detected
[    2.180727] xhci-hcd xhci-hcd.9.auto: remove, state 1
[    2.180750] usb usb6: USB disconnect, device number 1
[    2.204530] xhci-hcd xhci-hcd.9.auto: Host not halted after 16000 microseconds.
[    2.204564] xhci-hcd xhci-hcd.9.auto: Host controller not halted, aborting reset.
[    2.204602] xhci-hcd xhci-hcd.9.auto: USB bus 6 deregistered
[    2.204616] xhci-hcd xhci-hcd.9.auto: remove, state 1
[    2.204634] usb usb5: USB disconnect, device number 1
[    2.205056] xhci-hcd xhci-hcd.9.auto: USB bus 5 deregistered
[    2.209244] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[    2.209284] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 5
[    2.209480] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[    2.209518] xhci-hcd xhci-hcd.10.auto: irq 237, io mem 0xfe900000
[    2.209625] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    2.209637] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.209647] usb usb5: Product: xHCI Host Controller
[    2.209656] usb usb5: Manufacturer: Linux 4.4.103 xhci-hcd
[    2.209665] usb usb5: SerialNumber: xhci-hcd.10.auto
[    2.210075] hub 5-0:1.0: USB hub found
[    2.210099] hub 5-0:1.0: 1 port detected
[    2.210276] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[    2.210291] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 6
[    2.210336] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.210401] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[    2.210412] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.210422] usb usb6: Product: xHCI Host Controller
[    2.210430] usb usb6: Manufacturer: Linux 4.4.103 xhci-hcd
[    2.210439] usb usb6: SerialNumber: xhci-hcd.10.auto
[    2.210734] hub 6-0:1.0: USB hub found
[    2.210757] hub 6-0:1.0: 1 port detected
[    2.211588] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    2.211671] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    2.211688] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    2.211713] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    2.211734] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.211772] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    2.211781] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    2.211997] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[    2.224404] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.237761] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[    2.238445] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    2.238521] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    2.238537] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    2.238562] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    2.238581] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.238650] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[    2.238936] dwmmc_rockchip fe320000.dwmmc: allocated mmc-pwrseq
[    2.239041] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    2.239450] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    2.251214] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.264497] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[    2.265758] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok
[    2.281228] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok
[    2.282754] asoc-simple-card rt5640-sound: rt5640-aif2 <-> ff890000.i2s mapping ok
[    2.283484] asoc-simple-card rt5640-sound: tc358749x-audio <-> ff890000.i2s mapping ok
[    2.284072] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    2.285757] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.287452] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.289891] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input1
[    2.290486] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    2.293067] asoc-simple-card spdif-sound: dit-hifi <-> ff870000.spdif mapping ok
[    2.295305] otg_wakelock_init: No USB transceiver found
[    2.296802] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:03 UTC (1358499003)
[    2.298291] It doesn't contain Rogue gpu
u   2.329230]
[    2.349981] mmc_host mmc1: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
沙发自抢,求大神解答!!!
