我按网站上一步一步配置的系统,文件系统为UBUNTU18.04.1
配置烧录之后,却启动不起来,不能点亮显示屏,求高手分析原因。
下面是我的启动日志,请求帮助。
WAR嶥DR Version 1.19 20190305
soft reset
SRX
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 292
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 68606
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 2, name: boot, start:0xa000, size:0x10000
GPT part: 3, name: backup, start:0x2a000, size:0x10000
GPT part: 4, name: rootfs, start:0x5a000, size:0x1cc4fdf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xd6fa4
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):370ab80
NOTICE: BL31: Built : 09:23:41, Mar 4 2019
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: BL31: Initializing BL32
INFO: SPSR = 0x3c9
U-Boot 2017.09-g0b1f585 (May 12 2019 - 15:44:00 +0800)
Model: Firefly-RK3399 Board
PreSerial: 2
DRAM: 2 GiB
Relocation Offset is: 7dbee000
Sysmem: init
Bootdev(atags): mmc 0
PartType: EFI
get part misc fail -1
boot mode: normal
init_resource_list: failed to get resource part, ret=-1
DTB: rk-kernel.dtb
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
“Synchronous Abort” handler, esr 0x96000010
Relocate offset = 000000007dbee000
ELR(PC) = 000000000028407c
LR = 0000000000203a8c
SP = 0000000071de2020
ESR_EL2 = 0000000096000010
EC[31:26] == 100101, Exception from a Data abort, from current exception level
IL[25] == 1, 32-bit instruction trapped -
DAIF = 00000000000003c0
D[9] == 1, DBG masked
A[8] == 1, ABORT masked
I[7] == 1, IRQ masked
F[6] == 1, FIQ masked -
SPSR_EL2 = 0000000020000349
I[7] == 0, IRQ not masked
M[4] == 0, Exception taken from AArch64
M[3:0] == 1001, EL2h -
SCTLR_EL2 = 0000000030c51835
I[12] == 1, Icaches enabled
C[2] == 1, Dcache enabled
M[0] == 1, MMU enabled -
HCR_EL2 = 000000000800003a
VBAR_EL2 = 000000007ddee800
TTBR0_EL2 = 000000007fff0000
x0 : 000000000841ee00 x1 : 000000007de8fb86
x2 : 0000000000000004 x3 : 00000000ff1a0000
x4 : 0000000000000000 x5 : 0000000000000004
x6 : 000000000841ee00 x7 : 000000007dea7f38
x8 : 0000000071de20c0 x9 : 0000000000000008
x10: 00000000ffffffd8 x11: 0000000000000006
x12: 000000000001869f x13: 0000000000000200
x14: 0000000071de2418 x15: 00000000fffffffe
x16: 0000000000000000 x17: 0000000000000000
x18: 0000000071de5d98 x19: 000000007dea5000
x20: 0000000008300000 x21: 000000000841ee00
x22: 0000000000000000 x23: 000000000001fe00
x24: 0000000008300000 x25: 000000007dec2000
x26: 0000000000000000 x27: 0000000000000000
x28: 0000000000000000 x29: 0000000071de2200
SP:
71de2020: 00000000 00000000 00000000 00000000
71de2030: 00000000 00000000 7de9be91 00000000
71de2040: 00000000 00000000 00000000 00000000
71de2050: 7de9bed8 00000000 7de9befe 00000000
71de2060: 7de9bf4b 00000000 7de9bf98 00000000
71de2070: 7de9bfd8 00000000 7de9c018 00000000
71de2080: 7de9c055 00000000 00000000 00000000
71de2090: 00000000 00000000 7de9c092 00000000
71de20a0: 71de2200 00000000 7ddeea0c 00000000
71de20b0: 7dea5000 00000000 08300000 00000000
71de20c0: 7fff0000 00000000 0800003a 00000000
71de20d0: 30c51835 00000000 71de2020 00000000
71de20e0: 20000349 00000000 7ddee800 00000000
71de20f0: 000003c0 00000000 96000010 00000000
71de2100: 7de7207c 00000000 0841ee00 00000000
71de2110: 7de8fb86 00000000 00000004 00000000
Resetting CPU …
