目前贴了一块的nandflash的rk3288的板子,烧写ubuntu的镜像,目前卡在了二级uboot,无法检测到nandflash,需要修改uboot哪里的配置?错误日志如下:
Channel a: DDR3 400MHz
Channel b: DDR3 400MHz
Memory OK
Memory OK
Boot1 Release Time: Feb 2 2018 15:57:15, version: 2.34
ChipType = 0x8, 229
No.1 FLASH ID:98 d7 84 93 72 57
No.2 FLASH ID:33 33 33 33 33 33
No.4 FLASH ID:33 33 33 33 33 33
No.6 FLASH ID:33 33 33 33 33 33
No.8 FLASH ID:33 33 33 33 33 33
sync para 16
ECC:40
SdmmcInit=0 400
StorageInit ok = 122083
LOADER Check OK! 0x0, 146280
TOS Check OK! 0x8400000, 173910
Enter Trust OS
INF [0x0] TEE-CORE:init_primary_helper:366: Initializing (1.1.0-269-gc135d93 #1 Thu Feb 1 02:01:13 UTC 2018 arm)
INF [0x0] TEE-CORE:init_primary_helper:367: Release version: 1.3
INF [0x0] TEE-CORE:init_primary_helper:368: Next entry point address: 0x0
U-Boot 2017.09-gd80ac02301-dirty (May 18 2019 - 14:49:20 +0800)
Model: Firefly-RK3288
DRAM: 2 GiB
Relocation Offset is: 7ddd6000
MMC: dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0
mmc_init: -95, time 11
*** Warning - No block device, using default environment
In: serial
Out: serial
Err: serial
mmc_init: -95, time 2108
mmc_init: -95, time 10
Device 0: FtlInit fffffffe
unknown device
Unknown command ‘rksfc’ - try ‘help’
rockchip_get_boot_mode: dev_desc is NULL!
Net:
Warning: ethernet@ff290000 (eth0) using random MAC address - 8a:a6:af:37:4c:8b
eth0: ethernet@ff290000
Unknown command ‘usb’ - try ‘help’
Hit any key to stop autoboot: 2 1 0
Could not get mmc 0
do_boot_rockchip: dev_desc is NULL!
