急....急。。。RK3399系统不能启动,
自己设计的rk3399电路,系统启动到某个地方卡死了,急需大牛们给解决一下。以下是打印的信息。
[ 0.199885] console [ttyFIQ0] enabled
[ 0.207574] bootconsole [uart0] disabled
[ 0.216006] Registered fiq debugger ttyFIQ0
[ 0.249926] iommu: Adding device ff650000.vpu_service to group 0
[ 0.256010] iommu: Adding device ff660000.rkvdec to group 1
[ 0.261682] iommu: Adding device ff8f0000.vop to group 2
[ 0.267068] iommu: Adding device ff900000.vop to group 3
[ 0.272486] iommu: Adding device ff910000.cif_isp to group 4
[ 0.279587] SCSI subsystem initialized
[ 0.283677] usbcore: registered new interface driver usbfs
[ 0.289215] usbcore: registered new interface driver hub
[ 0.294610] usbcore: registered new device driver usb
[ 0.299729] media: Linux media interface: v0.10
[ 0.304303] Linux video capture interface: v2.00
[ 0.308971] pps_core: LinuxPPS API ver. 1 registered
[ 0.313944] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.323088] PTP clock support registered
[ 0.328072] Advanced Linux Sound Architecture Driver Initialized.
[ 0.334631] Bluetooth: Core ver 2.21
[ 0.338240] NET: Registered protocol family 31
[ 0.342683] Bluetooth: HCI device and connection manager initialized
[ 0.349039] Bluetooth: HCI socket layer initialized
[ 0.353921] Bluetooth: L2CAP socket layer initialized
[ 0.358996] Bluetooth: SCO socket layer initialized
[ 0.364465] rockchip-cpuinfo cpuinfo: Serial : c05ad7cff81d96e2
[ 0.371162] clocksource: Switched to clocksource arch_sys_counter
[ 0.424652] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.432879] NET: Registered protocol family 2
[ 0.437650] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.445032] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.452509] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.459145] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.465431] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.472296] NET: Registered protocol family 1
[ 0.476956] RPC: Registered named UNIX socket transport module.
[ 0.482898] RPC: Registered udp transport module.
[ 0.487609] RPC: Registered tcp transport module.
[ 0.492320] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.500008] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.508285] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.519560] Initialise system trusted keyring
[ 0.531797] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.538411] NFS: Registering the id_resolver key type
[ 0.543488] Key type id_resolver registered
[ 0.547683] Key type id_legacy registered
[ 0.551789] fuse init (API version 7.23)
[ 0.556073] SGI XFS with security attributes, no debug enabled
[ 0.567001] NET: Registered protocol family 38
[ 0.571476] Key type asymmetric registered
[ 0.575588] Asymmetric key parser ‘x509’ registered
[ 0.580625] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.588027] io scheduler noop registered
[ 0.591956] io scheduler deadline registered
[ 0.596352] io scheduler cfq registered (default)
[ 0.602465] phy phy-ff770000.syscon:usb2-phy@e460.0: Failed to get VBUS supply regulator
[ 0.615943] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.622324] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.628696] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.176231] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.183166] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.191110] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.197754] rk-vcodec ff650000.vpu_service: probe device
[ 1.203127] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f2fdbc10
[ 1.210084] rk-vcodec ff650000.vpu_service: allocator is drm
[ 1.215825] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 1.222231] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.229210] rk-vcodec ff650000.vpu_service: init success
[ 1.234935] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.241254] rk-vcodec ff660000.rkvdec: probe device
[ 1.246190] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f2fe0410
[ 1.252625] rk-vcodec ff660000.rkvdec: allocator is drm
[ 1.257910] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 1.263749] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.270293] rk-vcodec ff660000.rkvdec: init success
[ 1.276602] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.284182] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.294838] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.302419] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.312785] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.320789] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.329969] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
[ 1.340680] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[ 1.347559] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer on device rockchip-pinctrl
[ 1.358857] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
[ 1.366942] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[ 1.376552] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 39, base_baud = 1500000) is a 16550A
[ 1.386458] [drm] Initialized drm 1.1.0 20060810
[ 1.394441] [drm] Rockchip DRM driver version: v1.0.1
[ 1.401469] mali ff9a0000.gpu: Failed to get regulator
[ 1.406618] mali ff9a0000.gpu: Power control initialization failed
[ 1.413105] Unable to detect cache hierarchy for CPU 0
[ 1.419007] brd: module loaded
[ 1.427087] loop: module loaded
[ 1.430750] zram: Added device: zram0
[ 1.434703] lkdtm: No crash points registered, enable through debugfs
[ 1.442505] register spi return v = :0
[ 1.447093] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.454002] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.461063] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.466729] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.472407] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.478740] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.485709] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.496813] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.502498] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.507558] Ring mode enabled
[ 1.510624] DMA HW capability register supported
[ 1.515161] Normal descriptors
[ 1.518503] RX Checksum Offload Engine supported (type 2)
[ 1.524000] Wake-Up On Lan supported
[ 1.527705] Enable RX Mitigation via HW Watchdog Timer
[ 1.597005] libphy: stmmac: probed
[ 1.600417] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.606856] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.613899] usbcore: registered new interface driver rndis_wlan
[ 1.620064] Rockchip WiFi SYS interface (V1.00) …
[ 1.625114] usbcore: registered new interface driver rtl8150
[ 1.630814] usbcore: registered new interface driver r8152
[ 1.636351] usbcore: registered new interface driver asix
[ 1.641785] usbcore: registered new interface driver ax88179_178a
[ 1.647918] usbcore: registered new interface driver cdc_ether
[ 1.653788] usbcore: registered new interface driver rndis_host
[ 1.659768] usbcore: registered new interface driver cdc_ncm
[ 1.665466] usbcore: registered new interface driver qmi_wwan
[ 1.671249] usbcore: registered new interface driver cdc_mbim
[ 1.678271] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.688527] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.695612] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.702174] ehci-pci: EHCI PCI platform driver
[ 1.706672] ehci-platform: EHCI generic platform driver
[ 1.715732] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.721551] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.729480] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.741181] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.747515] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.754311] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.761535] usb usb1: Product: EHCI Host Controller
[ 1.766415] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[ 1.771908] usb usb1: SerialNumber: fe3c0000.usb
[ 1.777035] hub 1-0:1.0: USB hub found
[ 1.780821] hub 1-0:1.0: 1 port detected
[ 1.785306] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.791508] ohci-platform: OHCI generic platform driver
[ 1.797230] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.804095] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.812011] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.872320] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.879114] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.886348] usb usb2: Product: Generic Platform OHCI controller
[ 1.892268] usb usb2: Manufacturer: Linux 4.4.126 ohci_hcd
[ 1.897761] usb usb2: SerialNumber: fe3e0000.usb
[ 1.902837] hub 2-0:1.0: USB hub found
[ 1.906622] hub 2-0:1.0: 1 port detected
[ 1.911471] usbcore: registered new interface driver cdc_acm
[ 1.917137] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.925191] usbcore: registered new interface driver cdc_wdm
[ 1.930898] usbcore: registered new interface driver uas
[ 1.936291] usbcore: registered new interface driver usb-storage
[ 1.942381] usbcore: registered new interface driver usbserial
[ 1.948247] usbcore: registered new interface driver usbserial_generic
[ 1.954805] usbserial: USB Serial support registered for generic
[ 1.960856] usbcore: registered new interface driver cp210x
[ 1.966460] usbserial: USB Serial support registered for cp210x
[ 1.972438] usbcore: registered new interface driver ftdi_sio
[ 1.978210] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.985596] usbcore: registered new interface driver keyspan
[ 1.991286] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.999141] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.006471] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.013813] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.021171] usbcore: registered new interface driver option
[ 2.026772] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.033837] usbcore: registered new interface driver oti6858
[ 2.039523] usbserial: USB Serial support registered for oti6858
[ 2.045578] usbcore: registered new interface driver pl2303
[ 2.051184] usbserial: USB Serial support registered for pl2303
[ 2.057147] usbcore: registered new interface driver qcserial
[ 2.062919] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.069932] usbcore: registered new interface driver sierra
[ 2.075533] usbserial: USB Serial support registered for Sierra USB modem
[ 2.083062] ==gsl_ts_init==
[ 2.085889] ret=0
[ 2.088074] usbcore: registered new interface driver usbtouchscreen
[ 2.094618] .. rk pwm remotectl v1.1 init
[ 2.098877] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 2.106387] remotectl-pwm ff420030.pwm: set irq err, set support_psci to 0 !!
[ 2.113661] sensor_register_slave:mma8452,id=17
[ 2.118212] sensor_register_slave:lis3dh,id=7
[ 2.122577] sensor_register_slave:mma7660,id=18
[ 2.127122] sensor_register_slave:lsm303d,id=22
[ 2.131667] sensor_register_slave:gs_mc3230,id=23
[ 2.136373] [Gsensor] gsensor_init
[ 2.139964] sensor_register_slave:mpu6880_acc,id=24
[ 2.144847] sensor_register_slave:mpu6500_acc,id=25
[ 2.149727] sensor_register_slave:lsm330_acc,id=26
[ 2.154522] sensor_register_slave:akm8975,id=30
[ 2.159066] sensor_register_slave:akm8963,id=31
[ 2.163616] sensor_register_slave:l3g4200d,id=45
[ 2.168245] sensor_register_slave:l3g20d,id=46
[ 2.172693] sensor_register_slave:ewtsa,id=47
[ 2.177054] sensor_register_slave:lsm330_gyro,id=51
[ 2.181936] sensor_register_slave:cm3217,id=53
[ 2.186383] sensor_register_slave:cm3218,id=54
[ 2.191144] i2c /dev entries driver
[ 2.195770] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.202711] fan53555-reg: supplied by vcc5v0_sys
[ 2.209336] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 2.216262] fan53555-reg: supplied by vcc5v0_sys
[ 2.223021] rk808 0-001b: Pmic Chip id: 0x0
[ 2.230401] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 2.236632] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 2.242906] DCDC_REG1: supplied by vcc3v3_sys
[ 2.248057] DCDC_REG2: supplied by vcc3v3_sys
[ 2.253025] DCDC_REG3: supplied by vcc3v3_sys
[ 2.257700] DCDC_REG4: supplied by vcc3v3_sys
[ 2.262554] LDO_REG1: supplied by vcc3v3_sys
[ 2.267985] LDO_REG2: supplied by vcc3v3_sys
[ 2.273272] LDO_REG3: supplied by vcc3v3_sys
[ 2.278552] LDO_REG4: supplied by vcc3v3_sys
[ 2.283837] LDO_REG5: supplied by vcc3v3_sys
[ 2.289122] LDO_REG6: supplied by vcc3v3_sys
[ 2.294420] LDO_REG7: supplied by vcc3v3_sys
[ 2.299706] LDO_REG8: supplied by vcc3v3_sys
[ 2.304983] SWITCH_REG1: supplied by vcc3v3_sys
[ 2.309839] SWITCH_REG2: supplied by vcc3v3_sys
[ 2.317899] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.325062] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80094ba000
[ 2.333251] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80094bc000
[ 2.341821] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 2.352314] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 2.361209] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80094be000
[ 2.369462] ov13850 1-0010: probing…
[ 2.373235] ov13850 1-0010: probing successful
[ 2.378289] IR NEC protocol handler initialized
[ 2.383368] rockchip-rga ff680000.rga: HW Version: 0x03.02
[ 2.389138] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[ 2.396518] usbcore: registered new interface driver uvcvideo
[ 2.402278] USB Video Class driver (1.1.1)
[ 2.408986] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 2.418469] Bluetooth: Virtual HCI driver ver 1.5
[ 2.423330] Bluetooth: HCI UART driver ver 2.3
[ 2.427782] Bluetooth: HCI UART protocol H4 registered
[ 2.432926] Bluetooth: HCI UART protocol LL registered
[ 2.438069] Bluetooth: HCI UART protocol ATH3K registered
[ 2.443530] usbcore: registered new interface driver bfusb
[ 2.449079] usbcore: registered new interface driver btusb
[ 2.454985] cpu cpu0: cpu_leakage=17
[ 2.458623] cpu cpu0: cpu_leakage=17
[ 2.463535] cpu cpu4: cpu_leakage=32
[ 2.467200] cpu cpu4: cpu_leakage=32
[ 2.476511] sdhci: Secure Digital Host Controller Interface driver
[ 2.482712] sdhci: Copyright(c) Pierre Ossman
[ 2.487077] Synopsys Designware Multimedia Card Interface Driver
[ 2.493930] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.501201] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.507995] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.513770] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.523532] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.531669] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.537847] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.544704] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.551960] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.558748] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.564518] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.574256] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.582580] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.590362] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.608187] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.628375] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.634432] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.641847] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.647857] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.680330] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.688830] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.694615] usbcore: registered new interface driver usbhid
[ 2.700212] usbhid: USB HID core driver
[ 2.704140] inv_mpu_iio: inv_mpu_init:746
[ 2.708810] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 2.716861] usbcore: registered new interface driver snd-usb-audio
[ 2.723947] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 2.730256] rt5640 1-001c: Can not read property hp_det_gpio
[ 2.735911] rt5640 1-001c: Can not read property: linein-mute.
[ 2.753474] mmc1: MAN_BKOPS_EN bit is not set
[ 2.755823] Initializing XFRM netlink socket
[ 2.756205] NET: Registered protocol family 10
[ 2.766820] NET: Registered protocol family 17
[ 2.771295] NET: Registered protocol family 15
[ 2.775920] Bluetooth: RFCOMM socket layer initialized
[ 2.781087] Bluetooth: RFCOMM ver 1.11
[ 2.784868] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.790802] Bluetooth: HIDP socket layer initialized
[ 2.795816] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.800718] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.805562] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 2.812523] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.819651] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.827083] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 2.836131] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.841354] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.846092] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.850599] Key type dns_resolver registered
[ 2.855546] sensor_register_slave:mpu6880_gyro,id=50
[ 2.861027] cif_isp10_v4l2_drv_probe: probing…
[ 2.865759] cif_isp10_pltfrm_dev_init(1224) ERR: could not get default pinstate
[ 2.873076] cif_isp10_pltfrm_dev_init WARN: could not get pins_sleep pinstate
[ 2.880207] cif_isp10_pltfrm_dev_init WARN: could not get pins_inactive pinstate
[ 2.913549] ov13850.ov_camera_module_write_config(182) ERR: no active sensor configuration
[ 2.921632] ov13850.ov_camera_module_write_config(233) ERR: failed with error -14
[ 2.929581] ov13850.pltfrm_camera_module_read_reg(1007) ERR: i2c read from offset 0x0000300a failed with error -6
[ 2.940792] ov13850.pltfrm_camera_module_read_reg(1007) ERR: i2c read from offset 0x0000300b failed with error -6
[ 2.951068] ov13850.ov13850_check_camera_id(1820) ERR: register read failed, camera module powered off?
[ 2.960463] ov13850.ov13850_check_camera_id(1838) ERR: failed with error (-6)
[ 2.967625] ov13850.ov_camera_module_attach(256) ERR: failed with error -6
[ 2.974532] cif_isp10_img_src_v4l2_i2c_subdev_to_img_src(59) ERR: failed with error -6
[ 2.982451] cif_isp10_img_src_to_img_src(70) ERR: to_img_src failed!
[ 2.988804] cif_isp10_img_src_to_img_src(78) ERR: failed with error -14
[ 2.995412] cif_isp10_img_srcs_init(1099) ERR: failed with error -14
[ 3.001764] cif_isp10_create(5772) ERR: cif_isp10_img_srcs_init failed
[ 3.008290] cif_isp10_create(5808) ERR: failed with error -14
[ 3.014066] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 3.020422] Registered cp15_barrier emulation handler
[ 3.021310] mmcblk1: mmc1:0001 AJNB4R 14.6 GiB
[ 3.022130] mmcblk1boot0: mmc1:0001 AJNB4R partition 1 4.00 MiB
[ 3.022757] mmcblk1boot1: mmc1:0001 AJNB4R partition 2 4.00 MiB
[ 3.023593] mmcblk1rpmb: mmc1:0001 AJNB4R partition 3 4.00 MiB
[ 3.023809] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 3.023811] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 3.023813] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 3.023815] kernel: 0x001c00000 – 0x003000000 (20 MB)
[ 3.023816] backup: 0x003000000 – 0x003400000 (4 MB)
[ 3.023818] boot: 0x003400000 – 0x3a3a00000 (14854 MB)
[ 3.080748] mmcblk1: p1 p2 p3 p4 p5 p6
[ 3.080748] Registered setend emulation handler
[ 3.090283] Loading compiled-in X.509 certificates
[ 3.095927] phy phy-ff770000.syscon:usb2-phy@e450.6: Failed to get VBUS supply regulator
[ 3.104999] rockchip-drm display-subsystem: defer getting devfreq
[ 3.111285] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 3.117763] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008cada00)
[ 3.125784] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 3.132228] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008cada00)
[ 3.140555] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 3.147182] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 3.154977] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 3.167055] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008ca4508)
[ 3.176053] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 3.182864] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff8008ca54a8)
[ 3.190824] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 3.199540] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.206147] [drm] No driver support for vblank timestamp query.
[ 3.212242] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 3.220086] rockchip-drm display-subsystem: can’t not find any loader display
[ 3.227221] rockchip-drm display-subsystem: failed to show loader logo
[ 3.233835] Freeing drm_logo memory: 732K
[ 3.237858] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 3.245869] [drm] Cannot find any crtc or sizes - going 1024x768
[ 3.258093] Console: switching to colour frame buffer device 128x48
[ 3.267115] rockchip-drm display-subsystem: fb0: frame buffer device
[ 3.281302] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 3.287841] mali ff9a0000.gpu: Protected mode not available
[ 3.294389] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 3.306121] mali ff9a0000.gpu: Probed as mali0
[ 3.314400] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 3.320332] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 3
[ 3.328101] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 3.336811] xhci-hcd xhci-hcd.9.auto: irq 230, io mem 0xfe800000
[ 3.342885] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.349677] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.356888] usb usb3: Product: xHCI Host Controller
[ 3.361766] usb usb3: Manufacturer: Linux 4.4.126 xhci-hcd
[ 3.361905] vendor storage:20160801 ret = 0
[ 3.371429] usb usb3: SerialNumber: xhci-hcd.9.auto
[ 3.376608] hub 3-0:1.0: USB hub found
[ 3.380368] hub 3-0:1.0: 1 port detected
[ 3.384437] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 3.389994] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 4
[ 3.397679] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.405807] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.412599] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.419813] usb usb4: Product: xHCI Host Controller
[ 3.424691] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 3.430172] usb usb4: SerialNumber: xhci-hcd.9.auto
[ 3.435337] hub 4-0:1.0: USB hub found
[ 3.439107] hub 4-0:1.0: 1 port detected
[ 3.443291] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 3.448351] usb usb4: USB disconnect, device number 1
[ 3.453697] xhci-hcd xhci-hcd.9.auto: USB bus 4 deregistered
[ 3.459451] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 3.464560] usb usb3: USB disconnect, device number 1
[ 3.469862] xhci-hcd xhci-hcd.9.auto: USB bus 3 deregistered
[ 3.578325] rockchip-typec-phy ff800000.phy: wait pma ready timeout
[ 3.684755] rockchip-typec-phy ff800000.phy: wait pma ready timeout
[ 3.692288] rockchip-typec-phy ff800000.phy: Needed 2 loops to turn on
[ 3.699409] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 3.705432] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 3
[ 3.713414] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 3.722258] xhci-hcd xhci-hcd.10.auto: irq 231, io mem 0xfe900000
[ 3.728555] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.735362] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.742599] usb usb3: Product: xHCI Host Controller
[ 3.747508] usb usb3: Manufacturer: Linux 4.4.126 xhci-hcd
[ 3.753012] usb usb3: SerialNumber: xhci-hcd.10.auto
[ 3.758844] hub 3-0:1.0: USB hub found
[ 3.762640] hub 3-0:1.0: 1 port detected
[ 3.766943] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 3.772793] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4
[ 3.780642] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.788872] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.795670] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.802910] usb usb4: Product: xHCI Host Controller
[ 3.807807] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 3.813313] usb usb4: SerialNumber: xhci-hcd.10.auto
[ 3.819224] hub 4-0:1.0: USB hub found
[ 3.823044] hub 4-0:1.0: 1 port detected
[ 3.831577] ehci-platform fe380000.usb: EHCI Host Controller
[ 3.837755] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 3.845790] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 3.857412] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 3.863834] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.870681] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.877914] usb usb5: Product: EHCI Host Controller
[ 3.882801] usb usb5: Manufacturer: Linux 4.4.126 ehci_hcd
[ 3.888290] usb usb5: SerialNumber: fe380000.usb
[ 3.893911] hub 5-0:1.0: USB hub found
[ 3.897787] hub 5-0:1.0: 1 port detected
[ 3.903153] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 3.910265] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 3.918347] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 3.979777] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.986576] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.993813] usb usb6: Product: Generic Platform OHCI controller
[ 3.999744] usb usb6: Manufacturer: Linux 4.4.126 ohci_hcd
[ 4.005239] usb usb6: SerialNumber: fe3a0000.usb
[ 4.011088] hub 6-0:1.0: USB hub found
[ 4.014984] hub 6-0:1.0: 1 port detected
[ 4.021073] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.028384] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 4.035203] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 4.041009] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 4.050813] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 4.059008] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 4.065219] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 4.071775] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 4.089363] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.109386] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 4.122050] rockchip-dmc dmc: could not find power_model node
[ 4.138960] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 4.151700] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card0/input1
[ 4.157425] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 4.173080] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0
[ 4.180163] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22
[ 4.187226] asoc-simple-card spdif-sound: ASoC: can’t create pcm ff870000.spdif-dit-hifi :-22
[ 4.195771] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22
[ 4.200508] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 4.212361] asoc-simple-card: probe of spdif-sound failed with error -22
[ 4.220058] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[ 4.226411] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 4.236943] hdmi-audio-codec hdmi-audio-codec.8.auto: ASoC: Failed to add ELD: -16
[ 4.245360] rk-hdmi-dp-sound hdmi-dp-sound: multicodec ↔ ff8a0000.i2s mapping ok
[ 4.253067] hdmi-audio-codec hdmi-audio-codec.8.auto: ASoC: Failed to create Playback debugfs file
[ 4.264288]
[ 4.265797] =======================================================
[ 4.272073] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 4.278340] =======================================================
[ 4.284608] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver v5.2.2.3_24783.20171030) init.
[ 4.293571] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 4.298282] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[ 4.307325] [WLAN_RFKILL]: wifi turn on power. -1
[ 4.312029] RTW: module init start
[ 4.315437] RTW: rtl8188eu v5.2.2.3_24783.20171030
[ 4.320229] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 4.325811] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.2 (r)
[ 4.332942] ======== dhd_wlan_init_plat_data ========
[ 4.338002] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 4.342970] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 4.348189] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 4.353757] dhd_wlan_init_gpio: host_oob_irq: 71
[ 4.358379] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 4.363685] dhd_wifi_platform_load: Enter
[ 4.367707] Power-up adapter ‘DHD generic adapter’
[ 4.372524] wifi_platform_set_power = 1
[ 4.376355] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 4.381494] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 4.386198] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[ 4.395233] [WLAN_RFKILL]: wifi turn on power. -1
[ 4.415393] usbcore: registered new interface driver rtl8188eu
[ 4.421231] RTW: module init ret=0
[ 4.425113] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[ 4.433371] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 15:03:57 UTC (1358521437)
[ 4.451791] vcc_sd: disabling
u? 4.457183]
[ 4.562488] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 415; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-ebc75b0’, rk_ko_ver is ‘5’, built at ‘15:20:47’, on ‘Dec 13 2018’.
[ 4.772375] Mali: Mali device driver loaded
[ 4.776812] input: rk29-keypad as /devices/platform/rk-key/input/input3
[ 4.783862] ALSA device list:
??4t???1???~??^:?x阋?W£??W??og^?
?z???o???y?9r?ˉ!oN’w???岼 8n?3±W§Y%V?FOg???§£bi??fF3QFFv£3W(GN£T
t?GO·??u??W
?oˉ*???£?h?G§§§?v?V F/fV"£bT?3QffF3?w_£???w_?離3i(αC¨?GGtG_?_??uUf??kWtT?Eg?GV3]y·G3E£33o???|<e#??~?<R|d7???Ta???2??)~ 1t??'?? ???p|z????|???à??B鹾???|?????Q?J|?E?xO???x??? R@ ???cXV@???壎
        ぼplT0?????????
        t????@v?????4??~?|?????辟 ??^aZ??g?跨?v????XA???|溟?N??|??8????-???????????????>Dt??c??|_I°t??訷??h?|?>J|????>?&9|?`??|B??0|>>???Е???|??£E?|??c??xo?0 |?T:F????|< |?0|(?礢?u覿.Y?踟????H$@屄??й描惟豾???缟??t[    0.199941] console [ttyFIQ0] enabled
[ 0.207631] bootconsole [uart0] disabled
[ 0.216062] Registered fiq debugger ttyFIQ0
[ 0.249986] iommu: Adding device ff650000.vpu_service to group 0
[ 0.256072] iommu: Adding device ff660000.rkvdec to group 1
[ 0.261746] iommu: Adding device ff8f0000.vop to group 2
[ 0.267132] iommu: Adding device ff900000.vop to group 3
[ 0.272549] iommu: Adding device ff910000.cif_isp to group 4
[ 0.279654] SCSI subsystem initialized
[ 0.283739] usbcore: registered new interface driver usbfs
[ 0.289277] usbcore: registered new interface driver hub
[ 0.294671] usbcore: registered new device driver usb
[ 0.299791] media: Linux media interface: v0.10
[ 0.304364] Linux video capture interface: v2.00
[ 0.309033] pps_core: LinuxPPS API ver. 1 registered
[ 0.314006] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.323150] PTP clock support registered
[ 0.328134] Advanced Linux Sound Architecture Driver Initialized.
[ 0.334686] Bluetooth: Core ver 2.21
[ 0.338294] NET: Registered protocol family 31
[ 0.342738] Bluetooth: HCI device and connection manager initialized
[ 0.349093] Bluetooth: HCI socket layer initialized
[ 0.353975] Bluetooth: L2CAP socket layer initialized
[ 0.359050] Bluetooth: SCO socket layer initialized
[ 0.364529] rockchip-cpuinfo cpuinfo: Serial : c05ad7cff81d96e2
[ 0.371225] clocksource: Switched to clocksource arch_sys_counter
[ 0.424636] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.432863] NET: Registered protocol family 2
[ 0.437632] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.445015] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.452497] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.459132] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.465359] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.472282] NET: Registered protocol family 1
[ 0.476936] RPC: Registered named UNIX socket transport module.
[ 0.482867] RPC: Registered udp transport module.
[ 0.487578] RPC: Registered tcp transport module.
[ 0.492288] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.499972] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.508263] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.519424] Initialise system trusted keyring
[ 0.531467] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.538067] NFS: Registering the id_resolver key type
[ 0.543149] Key type id_resolver registered
[ 0.547340] Key type id_legacy registered
[ 0.551436] fuse init (API version 7.23)
[ 0.555721] SGI XFS with security attributes, no debug enabled
[ 0.566187] NET: Registered protocol family 38
[ 0.570674] Key type asymmetric registered
[ 0.574790] Asymmetric key parser ‘x509’ registered
[ 0.579824] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.587235] io scheduler noop registered
[ 0.591164] io scheduler deadline registered
[ 0.595559] io scheduler cfq registered (default)
[ 0.601657] phy phy-ff770000.syscon:usb2-phy@e460.0: Failed to get VBUS supply regulator
[ 0.615397] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.621776] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.628151] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.176286] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.183213] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.191182] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.197800] rk-vcodec ff650000.vpu_service: probe device
[ 1.203174] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f2fdbc10
[ 1.210133] rk-vcodec ff650000.vpu_service: allocator is drm
[ 1.215879] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 1.222243] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.229206] rk-vcodec ff650000.vpu_service: init success
[ 1.234827] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.241077] rk-vcodec ff660000.rkvdec: probe device
[ 1.246017] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f2fe0410
[ 1.252446] rk-vcodec ff660000.rkvdec: allocator is drm
[ 1.257734] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 1.263588] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.270132] rk-vcodec ff660000.rkvdec: init success
[ 1.276438] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.284018] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.294682] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.302261] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.312634] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.320623] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.329802] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
[ 1.340513] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[ 1.347392] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer on device rockchip-pinctrl
[ 1.358691] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
[ 1.366772] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[ 1.376283] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 39, base_baud = 1500000) is a 16550A
[ 1.386305] [drm] Initialized drm 1.1.0 20060810
[ 1.394280] [drm] Rockchip DRM driver version: v1.0.1
[ 1.401291] mali ff9a0000.gpu: Failed to get regulator
[ 1.406439] mali ff9a0000.gpu: Power control initialization failed
[ 1.412924] Unable to detect cache hierarchy for CPU 0
[ 1.418818] brd: module loaded
[ 1.427134] loop: module loaded
[ 1.430857] zram: Added device: zram0
[ 1.434821] lkdtm: No crash points registered, enable through debugfs
[ 1.442626] register spi return v = :0
[ 1.447240] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.454149] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.461209] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.466881] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.472558] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.478894] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.485863] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.496966] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.502652] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.507712] Ring mode enabled
[ 1.510777] DMA HW capability register supported
[ 1.515320] Normal descriptors
[ 1.518663] RX Checksum Offload Engine supported (type 2)
[ 1.524154] Wake-Up On Lan supported
[ 1.527854] Enable RX Mitigation via HW Watchdog Timer
[ 1.598029] libphy: stmmac: probed
[ 1.601441] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.607891] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.614934] usbcore: registered new interface driver rndis_wlan
[ 1.621077] Rockchip WiFi SYS interface (V1.00) …
[ 1.626125] usbcore: registered new interface driver rtl8150
[ 1.631825] usbcore: registered new interface driver r8152
[ 1.637362] usbcore: registered new interface driver asix
[ 1.642794] usbcore: registered new interface driver ax88179_178a
[ 1.648929] usbcore: registered new interface driver cdc_ether
[ 1.654797] usbcore: registered new interface driver rndis_host
[ 1.660786] usbcore: registered new interface driver cdc_ncm
[ 1.666485] usbcore: registered new interface driver qmi_wwan
[ 1.672267] usbcore: registered new interface driver cdc_mbim
[ 1.679291] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.689741] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.696841] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.703396] ehci-pci: EHCI PCI platform driver
[ 1.707894] ehci-platform: EHCI generic platform driver
[ 1.716932] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.722755] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.730690] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.742241] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.748578] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.755373] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.762597] usb usb1: Product: EHCI Host Controller
[ 1.767477] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[ 1.772970] usb usb1: SerialNumber: fe3c0000.usb
[ 1.778046] hub 1-0:1.0: USB hub found
[ 1.781890] hub 1-0:1.0: 1 port detected
[ 1.786385] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.792588] ohci-platform: OHCI generic platform driver
[ 1.798289] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.805160] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.813074] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.873370] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.880164] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.887388] usb usb2: Product: Generic Platform OHCI controller
[ 1.893306] usb usb2: Manufacturer: Linux 4.4.126 ohci_hcd
[ 1.898799] usb usb2: SerialNumber: fe3e0000.usb
[ 1.903832] hub 2-0:1.0: USB hub found
[ 1.907639] hub 2-0:1.0: 1 port detected
[ 1.912495] usbcore: registered new interface driver cdc_acm
[ 1.918169] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.926243] usbcore: registered new interface driver cdc_wdm
[ 1.931952] usbcore: registered new interface driver uas
[ 1.937343] usbcore: registered new interface driver usb-storage
[ 1.943428] usbcore: registered new interface driver usbserial
[ 1.949291] usbcore: registered new interface driver usbserial_generic
[ 1.955848] usbserial: USB Serial support registered for generic
[ 1.961902] usbcore: registered new interface driver cp210x
[ 1.967504] usbserial: USB Serial support registered for cp210x
[ 1.973470] usbcore: registered new interface driver ftdi_sio
[ 1.979245] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.986632] usbcore: registered new interface driver keyspan
[ 1.992318] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.000174] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.007504] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.014848] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.022197] usbcore: registered new interface driver option
[ 2.027798] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.034867] usbcore: registered new interface driver oti6858
[ 2.040555] usbserial: USB Serial support registered for oti6858
[ 2.046604] usbcore: registered new interface driver pl2303
[ 2.052205] usbserial: USB Serial support registered for pl2303
[ 2.058167] usbcore: registered new interface driver qcserial
[ 2.063939] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.070953] usbcore: registered new interface driver sierra
[ 2.076554] usbserial: USB Serial support registered for Sierra USB modem
[ 2.084100] ==gsl_ts_init==
[ 2.086926] ret=0
[ 2.089079] usbcore: registered new interface driver usbtouchscreen
[ 2.095626] .. rk pwm remotectl v1.1 init
[ 2.099875] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 2.107397] remotectl-pwm ff420030.pwm: set irq err, set support_psci to 0 !!
[ 2.114679] sensor_register_slave:mma8452,id=17
[ 2.119235] sensor_register_slave:lis3dh,id=7
[ 2.123601] sensor_register_slave:mma7660,id=18
[ 2.128153] sensor_register_slave:lsm303d,id=22
[ 2.132699] sensor_register_slave:gs_mc3230,id=23
[ 2.137408] [Gsensor] gsensor_init
[ 2.141001] sensor_register_slave:mpu6880_acc,id=24
[ 2.145887] sensor_register_slave:mpu6500_acc,id=25
[ 2.150768] sensor_register_slave:lsm330_acc,id=26
[ 2.155565] sensor_register_slave:akm8975,id=30
[ 2.160107] sensor_register_slave:akm8963,id=31
[ 2.164639] sensor_register_slave:l3g4200d,id=45
[ 2.169270] sensor_register_slave:l3g20d,id=46
[ 2.173720] sensor_register_slave:ewtsa,id=47
[ 2.178082] sensor_register_slave:lsm330_gyro,id=51
[ 2.182963] sensor_register_slave:cm3217,id=53
[ 2.187410] sensor_register_slave:cm3218,id=54
[ 2.192177] i2c /dev entries driver
[ 2.196856] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.203797] fan53555-reg: supplied by vcc5v0_sys
[ 2.210414] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 2.217338] fan53555-reg: supplied by vcc5v0_sys
[ 2.224092] rk808 0-001b: Pmic Chip id: 0x0
[ 2.231555] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 2.237789] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 2.244056] DCDC_REG1: supplied by vcc3v3_sys
[ 2.249179] DCDC_REG2: supplied by vcc3v3_sys
[ 2.254144] DCDC_REG3: supplied by vcc3v3_sys
[ 2.258803] DCDC_REG4: supplied by vcc3v3_sys
[ 2.263644] LDO_REG1: supplied by vcc3v3_sys
[ 2.269084] LDO_REG2: supplied by vcc3v3_sys
[ 2.274373] LDO_REG3: supplied by vcc3v3_sys
[ 2.279652] LDO_REG4: supplied by vcc3v3_sys
[ 2.284941] LDO_REG5: supplied by vcc3v3_sys
[ 2.290245] LDO_REG6: supplied by vcc3v3_sys
[ 2.295523] LDO_REG7: supplied by vcc3v3_sys
[ 2.300808] LDO_REG8: supplied by vcc3v3_sys
[ 2.306090] SWITCH_REG1: supplied by vcc3v3_sys
[ 2.310951] SWITCH_REG2: supplied by vcc3v3_sys
[ 2.319007] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.326190] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80094ba000
[ 2.334395] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80094bc000
[ 2.343002] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 2.353507] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 2.362409] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80094be000
[ 2.370672] ov13850 1-0010: probing…
[ 2.374446] ov13850 1-0010: probing successful
[ 2.379495] IR NEC protocol handler initialized
[ 2.384574] rockchip-rga ff680000.rga: HW Version: 0x03.02
[ 2.390374] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[ 2.397742] usbcore: registered new interface driver uvcvideo
[ 2.403494] USB Video Class driver (1.1.1)
[ 2.410192] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 2.419650] Bluetooth: Virtual HCI driver ver 1.5
[ 2.424497] Bluetooth: HCI UART driver ver 2.3
[ 2.428952] Bluetooth: HCI UART protocol H4 registered
[ 2.434096] Bluetooth: HCI UART protocol LL registered
[ 2.439238] Bluetooth: HCI UART protocol ATH3K registered
[ 2.444698] usbcore: registered new interface driver bfusb
[ 2.450254] usbcore: registered new interface driver btusb
[ 2.456152] cpu cpu0: cpu_leakage=17
[ 2.459790] cpu cpu0: cpu_leakage=17
[ 2.464697] cpu cpu4: cpu_leakage=32
[ 2.468353] cpu cpu4: cpu_leakage=32
[ 2.477676] sdhci: Secure Digital Host Controller Interface driver
[ 2.483869] sdhci: Copyright(c) Pierre Ossman
[ 2.488235] Synopsys Designware Multimedia Card Interface Driver
[ 2.495091] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.502356] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.509151] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.514927] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.524692] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.532830] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.539011] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.545851] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.553102] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.559894] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.565665] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.575402] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.583726] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.591507] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.609251] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.629270] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.635282] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.642630] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.648641] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.681387] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.690581] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.696610] usbcore: registered new interface driver usbhid
[ 2.702234] usbhid: USB HID core driver
[ 2.706247] inv_mpu_iio: inv_mpu_init:746
[ 2.711622] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 2.720999] usbcore: registered new interface driver snd-usb-audio
[ 2.728726] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 2.735106] rt5640 1-001c: Can not read property hp_det_gpio
[ 2.738238] mmc1: MAN_BKOPS_EN bit is not set
[ 2.745143] rt5640 1-001c: Can not read property: linein-mute.
[ 2.752280] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 2.759337] mmcblk1: mmc1:0001 AJNB4R 14.6 GiB
[ 2.764425] mmcblk1boot0: mmc1:0001 AJNB4R partition 1 4.00 MiB
[ 2.766055] Initializing XFRM netlink socket
[ 2.766605] NET: Registered protocol family 10
[ 2.767573] NET: Registered protocol family 17
[ 2.767593] NET: Registered protocol family 15
[ 2.767875] Bluetooth: RFCOMM socket layer initialized
[ 2.767890] Bluetooth: RFCOMM ver 1.11
[ 2.767900] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.767905] Bluetooth: HIDP socket layer initialized
[ 2.767954] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.768172] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.768206] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 2.768209] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.768232] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.768276] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 2.768278] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.768282] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.768326] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.768481] Key type dns_resolver registered
[ 2.768702] sensor_register_slave:mpu6880_gyro,id=50
[ 2.769244] cif_isp10_v4l2_drv_probe: probing…
[ 2.769339] cif_isp10_pltfrm_dev_init(1224) ERR: could not get default pinstate
[ 2.769341] cif_isp10_pltfrm_dev_init WARN: could not get pins_sleep pinstate
[ 2.769343] cif_isp10_pltfrm_dev_init WARN: could not get pins_inactive pinstate
[ 2.795595] ov13850.ov_camera_module_write_config(182) ERR: no active sensor configuration
[ 2.795596] ov13850.ov_camera_module_write_config(233) ERR: failed with error -14
[ 2.796062] ov13850.pltfrm_camera_module_read_reg(1007) ERR: i2c read from offset 0x0000300a failed with error -6
[ 2.796682] ov13850.pltfrm_camera_module_read_reg(1007) ERR: i2c read from offset 0x0000300b failed with error -6
[ 2.796685] ov13850.ov13850_check_camera_id(1820) ERR: register read failed, camera module powered off?
[ 2.796688] ov13850.ov13850_check_camera_id(1838) ERR: failed with error (-6)
[ 2.796712] ov13850.ov_camera_module_attach(256) ERR: failed with error -6
[ 2.796729] cif_isp10_img_src_v4l2_i2c_subdev_to_img_src(59) ERR: failed with error -6
[ 2.796731] cif_isp10_img_src_to_img_src(70) ERR: to_img_src failed!
[ 2.796733] cif_isp10_img_src_to_img_src(78) ERR: failed with error -14
[ 2.796736] cif_isp10_img_srcs_init(1099) ERR: failed with error -14
[ 2.796738] cif_isp10_create(5772) ERR: cif_isp10_img_srcs_init failed
[ 2.796740] cif_isp10_create(5808) ERR: failed with error -14
[ 2.802812] Registered cp15_barrier emulation handler
[ 2.807770] Registered setend emulation handler
[ 2.809134] Loading compiled-in X.509 certificates
[ 2.811683] phy phy-ff770000.syscon:usb2-phy@e450.6: Failed to get VBUS supply regulator
[ 2.815742] rockchip-drm display-subsystem: defer getting devfreq
[ 2.816462] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 2.817188] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008cada00)
[ 2.817312] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 2.817787] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008cada00)
[ 2.819031] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 2.819089] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.819410] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 2.822556] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008ca4508)
[ 2.823982] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 2.824587] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff8008ca54a8)
[ 2.824748] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 2.824784] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.824789] [drm] No driver support for vblank timestamp query.
[ 2.825504] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 2.825591] rockchip-drm display-subsystem: can’t not find any loader display
[ 2.825611] rockchip-drm display-subsystem: failed to show loader logo
[ 2.825923] Freeing drm_logo memory: 732K
[ 2.826070] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 2.826085] [drm] Cannot find any crtc or sizes - going 1024x768
[ 3.161872] mmcblk1boot1: mmc1:0001 AJNB4R partition 2 4.00 MiB
[ 3.162494] mmcblk1rpmb: mmc1:0001 AJNB4R partition 3 4.00 MiB
[ 3.162778] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 3.162780] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 3.162782] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 3.162784] kernel: 0x001c00000 – 0x003000000 (20 MB)
[ 3.162785] backup: 0x003000000 – 0x003400000 (4 MB)
[ 3.162787] boot: 0x003400000 – 0x3a3a00000 (14854 MB)
[ 3.186974] mmcblk1: p1 p2 p3 p4 p5 p6
[ 3.186981] Console: switching to colour frame buffer device 128x48
[ 3.253245] rockchip-drm display-subsystem: fb0: frame buffer device
[ 3.267500] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 3.271373] vendor storage:20160801 ret = 0
[ 3.278497] mali ff9a0000.gpu: Protected mode not available
[ 3.284808] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 3.297144] mali ff9a0000.gpu: Probed as mali0
[ 3.307303] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 3.313120] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 3
[ 3.321034] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 3.329836] xhci-hcd xhci-hcd.9.auto: irq 230, io mem 0xfe800000
[ 3.335982] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.342777] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.350012] usb usb3: Product: xHCI Host Controller
[ 3.354893] usb usb3: Manufacturer: Linux 4.4.126 xhci-hcd
[ 3.360382] usb usb3: SerialNumber: xhci-hcd.9.auto
[ 3.365622] hub 3-0:1.0: USB hub found
[ 3.369410] hub 3-0:1.0: 1 port detected
[ 3.373558] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 3.379173] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 4
[ 3.386890] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.395061] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.401849] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.409065] usb usb4: Product: xHCI Host Controller
[ 3.413948] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 3.419442] usb usb4: SerialNumber: xhci-hcd.9.auto
[ 3.424585] hub 4-0:1.0: USB hub found
[ 3.428359] hub 4-0:1.0: 1 port detected
[ 3.432567] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 3.437642] usb usb4: USB disconnect, device number 1
[ 3.442996] xhci-hcd xhci-hcd.9.auto: USB bus 4 deregistered
[ 3.448726] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 3.453793] usb usb3: USB disconnect, device number 1
[ 3.459082] xhci-hcd xhci-hcd.9.auto: USB bus 3 deregistered
[ 3.468421] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 3.474107] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 3
[ 3.481954] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 3.490777] xhci-hcd xhci-hcd.10.auto: irq 231, io mem 0xfe900000
[ 3.496931] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.503720] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.510934] usb usb3: Product: xHCI Host Controller
[ 3.515814] usb usb3: Manufacturer: Linux 4.4.126 xhci-hcd
[ 3.521295] usb usb3: SerialNumber: xhci-hcd.10.auto
[ 3.526513] hub 3-0:1.0: USB hub found
[ 3.530280] hub 3-0:1.0: 1 port detected
[ 3.534362] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 3.540012] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4
[ 3.547784] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.555914] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.562712] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.569928] usb usb4: Product: xHCI Host Controller
[ 3.574809] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 3.580300] usb usb4: SerialNumber: xhci-hcd.10.auto
[ 3.585537] hub 4-0:1.0: USB hub found
[ 3.589308] hub 4-0:1.0: 1 port detected
[ 3.597082] ehci-platform fe380000.usb: EHCI Host Controller
[ 3.602917] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 3.610837] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 3.622367] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 3.628660] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.635458] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.642672] usb usb5: Product: EHCI Host Controller
[ 3.647551] usb usb5: Manufacturer: Linux 4.4.126 ehci_hcd
[ 3.653034] usb usb5: SerialNumber: fe380000.usb
[ 3.658035] hub 5-0:1.0: USB hub found
[ 3.661814] hub 5-0:1.0: 1 port detected
[ 3.666171] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 3.673032] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 3.680946] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 3.741508] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.748300] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.755516] usb usb6: Product: Generic Platform OHCI controller
[ 3.761452] usb usb6: Manufacturer: Linux 4.4.126 ohci_hcd
[ 3.766938] usb usb6: SerialNumber: fe3a0000.usb
[ 3.772281] hub 6-0:1.0: USB hub found
[ 3.776053] hub 6-0:1.0: 1 port detected
[ 3.780679] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 3.787929] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 3.794723] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 3.800483] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 3.810227] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 3.818344] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 3.824514] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 3.825658] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 3.839625] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 3.857406] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.877428] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 3.888411] rockchip-dmc dmc: could not find power_model node
[ 3.905252] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 3.914768] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card0/input1
[ 3.916335] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 3.934639] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0
[ 3.941688] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22
[ 3.948744] asoc-simple-card spdif-sound: ASoC: can’t create pcm ff870000.spdif-dit-hifi :-22
[ 3.954326] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 3.966466] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22
[ 3.973776] asoc-simple-card: probe of spdif-sound failed with error -22
[ 3.980765] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[ 3.988334] hdmi-audio-codec hdmi-audio-codec.8.auto: ASoC: Failed to add ELD: -16
[ 3.996222] rk-hdmi-dp-sound hdmi-dp-sound: multicodec ↔ ff8a0000.i2s mapping ok
[ 4.003807] hdmi-audio-codec hdmi-audio-codec.8.auto: ASoC: Failed to create Playback debugfs file
[ 4.014650]
[ 4.014739] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.2 (r)
[ 4.014744] ======== dhd_wlan_init_plat_data ========
[ 4.014746] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 4.014747] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 4.014750] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 4.014754] dhd_wlan_init_gpio: host_oob_irq: 71
[ 4.014755] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 4.014756] dhd_wifi_platform_load: Enter
[ 4.014778] Power-up adapter ‘DHD generic adapter’
[ 4.014813] wifi_platform_set_power = 1
[ 4.014814] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 4.014816] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 4.014818] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[ 4.014819] [WLAN_RFKILL]: wifi turn on power. -1
[ 4.090542] =======================================================
[ 4.096818] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 4.103086] =======================================================
[ 4.109377] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver v5.2.2.3_24783.20171030) init.
[ 4.118348] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 4.123057] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[ 4.132104] [WLAN_RFKILL]: wifi turn on power. -1
[ 4.136816] RTW: module init start
[ 4.140240] RTW: rtl8188eu v5.2.2.3_24783.20171030
[ 4.145034] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 4.150795] usbcore: registered new interface driver rtl8188eu
[ 4.156655] RTW: module init ret=0
[ 4.160810] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[ 4.169917] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 15:05:59 UTC (1358521559)
[ 4.196693] vcc_sd: disabling
u? 4.202705]
检查下你的emmc,降下速率,调整到HS100 或150,可能系统默认的HS200太高,板子PCB设计走线,等长,阻抗没搞好
然后还要看看GPU_SLEEP_H和VDD_CPU_B_SLEEP_H这2个信号有没有变高(进了省电模式)
还要看看VDD_CENTER和VDD_CPU_L、VDD_GPU、VDD_CPU_B,VDD_LOG的电压有没有过低,不要低于0.8V,VDD_GPU、VDD_CPU_B不要低于0.9V
我的QQ254327173,欢迎加聊
估计是RK3399退出BOOT,进入kernel,重新调整了EMMC速率,跑挂了
BOOT是低速的加载的,所以没问题
还有看看SYR837和SYR838有没有焊错,之前有网友反馈焊错了,也导致起不来
已经准备进安卓系统桌面了,把不用的,你板上没有的设备删掉
否则系统报错太多就蹦了
我QQ254327173,欢迎加聊
问题已经解决,结帖
楼主能分享一下解决的方法吗?请问你的板是供电出问题吗,还是软件的问题,期待你的分享!
你这边遇到了什么问题?
15910697963 发表于 2019-7-25 15:47
问题已经解决,结帖
请问怎么解决的?跟你一样的log
你好 能分享下吗
我这也是自研的板子 卡在同样位置
我也是碰到一模一样的问题,卡在同一个位置,能分享下吗。
能不能把原理图 搞个PDF出来 我串口乱码 心里慌得一逼
用示波器看看串口信号,如果是锯齿一样的波形,把TX上拉电阻换为2K试试,我的是刚开始乱码,然后正常,示波器观察,刚开始TX信号是小锯齿波。我是硬件,感觉应当是BOOT的上电预设引脚配置问题。
问题已经解决,结帖
能分享如何解决的吗?我也是在这里挂了
我也遇到同样的问题,卡在同一个地方,请教是怎么解决的?
咋解决的啊老铁
我的也是换了一个sa3635 64G emmc后出现相同的现象, 请问如何解决的?谢谢!
我在rk3399 换了个sa3635 emmc后出现同样的问题,请问是如何解决的!
问题已经解决,结帖
能不能分享一下你是如何解决的?
