rk3399跑Android系统出现的错误
DDR Version 1.12 20180518
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
pmugrf_os_reg[2] = 0x3AA17AA1, stride = 0xD
Boot1: 2018-04-08, version: 1.12
CPUId = 0x0
ChipType = 0x10, 215
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7264MB
FwPartOffset=2000 , 100000
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
SdmmcInit=0 1
StorageInit ok = 70096
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xa912c
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):65aa5ce
NOTICE: BL31: Built : 10:47:37, Jun 19 2018
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1151): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-170-gc4654a6 #16 Wed May 30 08:54:30 UTC 2018 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (May 23 2019 - 05:14:58)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from boot image.
power key: bank-0 pin-5
can’t find dts node for fixed
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=50
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
invalide header tag
ca head not found
#Boot ver: 2019-01-25#1.12
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
Rockchip UBOOT DRM driver version: develop-v1.0.0
failed to find phy node
failed to find panel driver
no fuel gauge found
rockchip_panel_deinit: failed to find panel deinit funcs
got recovery cmd from misc.
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel @ 0x00280000 (0x0127d808)
ramdisk @ 0x04bf0000 (0x00865b40)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 00000000046156f2 … OK
Add bank:000000000a200000, 00000000ede00000
[ 0.000000] Linux version 4.4.126 (root@ubuntu) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #2 SMP PREEMPT Mon May 20 07:32:33 PDT 2019
[ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6ef1000 s45528 r8192 d32296 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 991752
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.veritymode=/dev/block/platform/ff0f0000.dwmmc/by-name/metadata androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x00010000@0x00010000(kernel),0x00010000@0x00020000(boot),0x00020000@0x00030000(recovery),0x00038000@0x00050000(backup),0x00002000@0x00088000(security),0x00100000@0x0008a000(cache),0x00500000@0x0018a000(system),0x00008000@0x0068a000(metadata),0x00100000@0x00692000(vendor),0x00100000@0x00794000(oem),0x00000400@0x00894000(frp),-@0x00894400(userdata) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2019-05-23_05:14:58 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0xf6ea9000-0xf6ee9000] (0MB) mapped at [ffffffc0f6ea9000-ffffffc0f6ee8fff]
[ 0.000000] Memory: 3911388K/4030464K available (11006K kernel code, 1654K rwdata, 5376K rodata, 832K init, 1133K bss, 102692K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009090000 - 0xffffff8009160000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b40000 ( 11008 KB)
[ 0.000000] .rodata : 0xffffff8008b40000 - 0xffffff8009090000 ( 5440 KB)
[ 0.000000] .data : 0xffffff8009160000 - 0xffffff80092fd808 ( 1655 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.001844] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002808] pid_max: default: 32768 minimum: 301
[ 0.003298] Security Framework initialized
[ 0.003685] SELinux: Initializing.
[ 0.004115] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004745] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006234] Initializing cgroup subsys memory
[ 0.006666] Initializing cgroup subsys freezer
[ 0.007976] sched-energy: Sched-energy-costs installed from DT
[ 0.008524] CPU0: update cpu_capacity 401
[ 0.008974] ASID allocator initialised with 32768 entries
[ 0.025802] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027028] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039208] Detected VIPT I-cache on CPU1
[ 0.039239] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039279] CPU1: using LPI pending table @0x00000000f1c00000
[ 0.039321] CPU1: update cpu_capacity 401
[ 0.039325] CPU1: Booted secondary processor [410fd034]
[ 0.049193] Detected VIPT I-cache on CPU2
[ 0.049213] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049245] CPU2: using LPI pending table @0x00000000f1c30000
[ 0.049273] CPU2: update cpu_capacity 401
[ 0.049277] CPU2: Booted secondary processor [410fd034]
[ 0.059224] Detected VIPT I-cache on CPU3
[ 0.059243] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059275] CPU3: using LPI pending table @0x00000000f1c70000
[ 0.059301] CPU3: update cpu_capacity 401
[ 0.059305] CPU3: Booted secondary processor [410fd034]
[ 0.069273] Detected PIPT I-cache on CPU4
[ 0.069299] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069339] CPU4: using LPI pending table @0x00000000f1cc0000
[ 0.069378] CPU4: update cpu_capacity 1024
[ 0.069381] CPU4: Booted secondary processor [410fd082]
[ 0.079298] Detected PIPT I-cache on CPU5
[ 0.079316] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079352] CPU5: using LPI pending table @0x00000000f1cf0000
[ 0.079379] CPU5: update cpu_capacity 1024
[ 0.079382] CPU5: Booted secondary processor [410fd082]
[ 0.079466] Brought up 6 CPUs
[ 0.091571] SMP: Total of 6 processors activated.
[ 0.092013] CPU features: detected feature: GIC system register CPU interface
[ 0.092685] CPU: All CPU(s) started at EL2
[ 0.093107] alternatives: patching kernel code
[ 0.095402] devtmpfs: initialized
[ 0.114988] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.115947] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.117280] pinctrl core: initialized pinctrl subsystem
[ 0.119221] Failed to find legacy iommu devices
[ 0.120039] NET: Registered protocol family 16
[ 0.120865] schedtune: init normalization constants…
[ 0.121368] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.122001] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.122634] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.123278] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.123910] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.124544] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.125176] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.125808] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.126440] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.127100] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.127840] schedtune: verify normalization constants…
[ 0.128355] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.128896] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.129435] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.129975] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.130522] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.131062] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.131601] schedtune: configured to support 5 boost groups
[ 0.140557] cpuidle: using governor ladder
[ 0.150561] cpuidle: using governor menu
[ 0.150957] Registered FIQ tty driver
[ 0.151666] vdso: 2 pages (1 code @ ffffff8008b46000, 1 data @ ffffff8009164000)
[ 0.152401] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.154424] DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.174940] console [pstore-1] enabled
[ 0.175537] pstore: Registered ramoops as persistent store backend
[ 0.176139] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.178662] fiq debugger fiq mode enabled
[ [ 0.179313] console [ttyFIQ0] enabled
[ 0.180003] bootconsole [uart0] disabled
[ 0.180556] Registered fiq debugger ttyFIQ0
[ 0.215054] iommu: Adding device ff650000.vpu_service to group 0
[ 0.215135] iommu: Adding device ff660000.rkvdec to group 1
[ 0.215204] iommu: Adding device ff670000.iep to group 2
[ 0.215292] iommu: Adding device ff8f0000.vop to group 3
[ 0.215360] iommu: Adding device ff900000.vop to group 4
[ 0.215462] iommu: Adding device ff910000.isp to group 5
[ 0.215532] iommu: Adding device ff920000.isp to group 6
[ 0.216202] rk_iommu ff670800.iommu: can’t get aclk
[ 0.216217] rk_iommu ff670800.iommu: can’t get hclk
[ 0.217080] SCSI subsystem initialized
[ 0.217440] usbcore: registered new interface driver usbfs
[ 0.217487] usbcore: registered new interface driver hub
[ 0.217572] usbcore: registered new device driver usb
[ 0.217914] media: Linux media interface: v0.10
[ 0.217948] Linux video capture interface: v2.00
[ 0.218118] pps_core: LinuxPPS API ver. 1 registered
[ 0.218127] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.218152] PTP clock support registered
[ 0.219661] Advanced Linux Sound Architecture Driver Initialized.
[ 0.220167] Bluetooth: Core ver 2.21
[ 0.220196] NET: Registered protocol family 31
[ 0.220204] Bluetooth: HCI device and connection manager initialized
[ 0.220221] Bluetooth: HCI socket layer initialized
[ 0.220232] Bluetooth: L2CAP socket layer initialized
[ 0.220265] Bluetooth: SCO socket layer initialized
[ 0.220963] rockchip-cpuinfo cpuinfo: Serial : e138aa6ad871cdc6
[ 0.221442] clocksource: Switched to clocksource arch_sys_counter
[ 0.262950] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.263183] NET: Registered protocol family 2
[ 0.263593] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.263817] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.264043] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.264123] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.264170] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.264340] NET: Registered protocol family 1
[ 0.265198] Trying to unpack rootfs image as initramfs…
[ 0.638925] Freeing initrd memory: 8596K
[ 0.639471] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.639567] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.642369] audit: initializing netlink subsys (disabled)
[ 0.642433] audit: type=2000 audit(0.640:1): initialized
[ 0.647597] VFS: Disk quotas dquot_6.6.0
[ 0.647721] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.648755] Registering sdcardfs 0.1
[ 0.649320] fuse init (API version 7.23)
[ 0.650390]
[ 0.650390] TEE Core Framework initialization (ver 1:0.1)
[ 0.650416] TEE armv7 Driver initialization
[ 0.650767] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.650783] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.650960] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.654862] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.654884] io scheduler noop registered
[ 0.655042] io scheduler cfq registered (default)
[ 0.659845] iep: failed to find iep power down clock source.
[ 0.660213] IEP Power ON
[ 0.660376] IEP Power OFF
[ 0.660452] IEP Driver loaded succesfully
[ 0.660555] Module initialized.
[ 0.660810] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.661070] rk-vcodec ff650000.vpu_service: probe device
[ 0.661110] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f1e6dc10
[ 0.661252] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.661302] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.661776] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.661791] rk-vcodec ff650000.vpu_service: init success
[ 0.661967] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.662326] rk-vcodec ff660000.rkvdec: probe device
[ 0.662366] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f1e6e410
[ 0.662496] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.662548] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.662866] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.662880] rk-vcodec ff660000.rkvdec: init success
[ 0.664540] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.664558] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans矁Num_Peri-12 Num_Events-12
[ 0.665928] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.665947] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.667635] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.669404] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[ 0.669711] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
[ 0.669728] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[ 0.669740] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer on device rockchip-pinctrl
[ 0.669749] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
[ 0.670024] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A
[ 0.670447] [drm] Initialized drm 1.1.0 20060810
[ 0.673752] [drm] Rockchip DRM driver version: v1.0.1
[ 0.675811] Unable to detect cache hierarchy for CPU 0
[ 0.700131] brd: module loaded
[ 0.704994] loop: module loaded
[ 0.705552] zram: Added device: zram0
[ 0.706393] SCSI Media Changer driver v0.25
[ 0.707634] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 0.707653] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 0.708153] m25p80 spi0.0: unrecognized JEDEC id bytes: ff, ff, ff
[ 0.708174] m25p80: probe of spi0.0 failed with error -2
[ 0.708508] register spi return v = :0
[ 0.708546] register firefly_spi_init spi return v = :0
[ 0.708597] tun: Universal TUN/TAP device driver, 1.6
[ 0.708604] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.709571] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 0.709592] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 0.709603] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 0.709626] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 0.709790] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 0.709802] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 0.714818] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 0.714936] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.714946] Ring mode enabled
[ 0.714953] DMA HW capability register supported
[ 0.714960] Normal descriptors
[ 0.714969] RX Checksum Offload Engine supported (type 2)
[ 0.714976] TX Checksum insertion supported
[ 0.714982] Wake-Up On Lan supported
[ 0.715021] Enable RX Mitigation via HW Watchdog Timer
[ 0.784251] libphy: stmmac: probed
[ 0.784268] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 0.784277] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 0.785150] PPP generic driver version 2.4.2
[ 0.785388] PPP BSD Compression module registered
[ 0.785437] PPP Deflate Compression module registered
[ 0.785476] PPP MPPE Compression module registered
[ 0.785521] NET: Registered protocol family 24
[ 0.785599] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.785608] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.785628] Rockchip WiFi SYS interface (V1.00) …
[ 0.785774] usbcore: registered new interface driver catc
[ 0.785859] usbcore: registered new interface driver kaweth
[ 0.785877] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.785931] usbcore: registered new interface driver pegasus
[ 0.786009] usbcore: registered new interface driver rtl8150
[ 0.786063] usbcore: registered new interface driver r8152
[ 0.786079] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.786165] usbcore: registered new interface driver hso
[ 0.786254] usbcore: registered new interface driver asix
[ 0.786310] usbcore: registered new interface driver ax88179_178a
[ 0.786371] usbcore: registered new interface driver cdc_ether
[ 0.786448] usbcore: registered new interface driver cdc_eem
[ 0.786503] usbcore: registered new interface driver dm9601
[ 0.786578] usbcore: registered new interface driver smsc75xx
[ 0.786669] usbcore: registered new interface driver smsc95xx
[ 0.786725] usbcore: registered new interface driver gl620a
[ 0.786780] usbcore: registered new interface driver net1080
[ 0.786837] usbcore: registered new interface driver plusb
[ 0.786919] usbcore: registered new interface driver rndis_host
[ 0.786975] usbcore: registered new interface driver cdc_subset
[ 0.787035] usbcore: registered new interface driver zaurus
[ 0.787117] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.787196] usbcore: registered new interface driver int51x1
[ 0.787257] usbcore: registered new interface driver kalmia
[ 0.787340] usbcore: registered new interface driver ipheth
[ 0.787398] usbcore: registered new interface driver sierra_net
[ 0.787454] usbcore: registered new interface driver cx82310_eth
[ 0.787524] usbcore: registered new interface driver cdc_ncm
[ 0.787603] usbcore: registered new interface driver qmi_wwan
[ 0.787664] usbcore: registered new interface driver cdc_mbim
[ 0.789598] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 0.790880] rockchip-dwc3 usb@fe900000: failed to get drvdata dwc3
[ 0.792290] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.792319] ehci-pci: EHCI PCI platform driver
[ 0.792418] ehci-platform: EHCI generic platform driver
[ 0.793211] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.793252] ohci-platform: OHCI generic platform driver
[ 0.794405] usbcore: registered new interface driver cdc_acm
[ 0.794423] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.794499] usbcore: registered new interface driver usblp
[ 0.794562] usbcore: registered new interface driver cdc_wdm
[ 0.794632] usbcore: registered new interface driver uas
[ 0.794708] usbcore: registered new interface driver usb-storage
[ 0.794761] usbcore: registered new interface driver ums-alauda
[ 0.794845] usbcore: registered new interface driver ums-cypress
[ 0.794906] usbcore: registered new interface driver ums-datafab
[ 0.794959] usbcore: registered new interface driver ums_eneub6250
[ 0.795013] usbcore: registered new interface driver ums-freecom
[ 0.795067] usbcore: registered new interface driver ums-isd200
[ 0.795126] usbcore: registered new interface driver ums-jumpshot
[ 0.795178] usbcore: registered new interface driver ums-karma
[ 0.795234] usbcore: registered new interface driver ums-onetouch
[ 0.795292] usbcore: registered new interface driver ums-sddr09
[ 0.795351] usbcore: registered new interface driver ums-sddr55
[ 0.795404] usbcore: registered new interface driver ums-usbat
[ 0.795518] usbcore: registered new interface driver usbserial
[ 0.795572] usbcore: registered new interface driver usbserial_generic
[ 0.795611] usbserial: USB Serial support registered for generic
[ 0.795670] usbcore: registered new interface driver option
[ 0.795712] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.795781] usbcore: registered new interface driver trancevibrator
[ 0.795800] usb20_otg: version 3.10a 21-DEC-2012
[ 0.796039] usb20_host: version 3.10a 21-DEC-2012
[ 0.796739] usbcore: registered new interface driver xpad
[ 0.796810] usbcore: registered new interface driver usb_acecad
[ 0.796873] usbcore: registered new interface driver aiptek
[ 0.796935] usbcore: registered new interface driver gtco
[ 0.797005] usbcore: registered new interface driver hanwang
[ 0.797065] usbcore: registered new interface driver kbtab
[ 0.797082] ==gsl_ts_init==
[ 0.797125] ret=0
[ 0.797756] .. rk pwm remotectl v1.1 init
[ 0.798129] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 0.798699] sensor_register_slave:kxtj9,id=11
[ 0.798727] sensor_register_slave:mma8452,id=17
[ 0.798748] sensor_register_slave:lis3dh,id=7
[ 0.798766] sensor_register_slave:mma7660,id=18
[ 0.798790] sensor_register_slave:lsm303d,id=22
[ 0.798807] sensor_register_slave:gs_mc3230,id=23
[ 0.798815] [Gsensor] gsensor_init
[ 0.798833] sensor_register_slave:mpu6880_acc,id=24
[ 0.798852] sensor_register_slave:mpu6500_acc,id=25
[ 0.798869] sensor_register_slave:lsm330_acc,id=26
[ 0.798883] sensor_register_slave:bma2xx_acc,id=27
[ 0.798897] sensor_register_slave:akm8975,id=30
[ 0.798911] sensor_register_slave:akm8963,id=31
[ 0.798924] sensor_register_slave:l3g4200d,id=45
[ 0.798937] sensor_register_slave:l3g20d,id=46
[ 0.798950] sensor_register_slave:ewtsa,id=47
[ 0.798964] sensor_register_slave:lsm330_gyro,id=51
[ 0.798979] sensor_register_slave:cm3217,id=53
[ 0.799005] sensor_register_slave:cm3218,id=54
[ 0.799019] sensor_register_slave:ls_stk3410,id=62
[ 0.799033] sensor_register_slave:ps_stk3410,id=67
[ 0.799985] i2c /dev entries driver
[ 0.801774] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 0.810052] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 0.810090] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80097fa000
[ 0.811095] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 0.811164] fan53555-reg: supplied by vcc5v0_sys
[ 0.813362] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 0.813483] fan53555-reg: supplied by vcc5v0_sys
[ 0.815678] rk808 0-001b: Pmic Chip id: 0x0
[ 0.819051] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.819152] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.819282] DCDC_REG1: supplied by vcc3v3_sys
[ 0.820159] DCDC_REG2: supplied by vcc3v3_sys
[ 0.820830] DCDC_REG3: supplied by vcc3v3_sys
[ 0.821181] DCDC_REG4: supplied by vcc3v3_sys
[ 0.821808] LDO_REG1: supplied by vcc3v3_sys
[ 0.823017] LDO_REG2: supplied by vcc3v3_sys
[ 0.823213] vcca1v8_hdmi: Bringing 2800000uV into 1800000-1800000uV
[ 0.824199] LDO_REG3: supplied by vcc3v3_sys
[ 0.825278] LDO_REG4: supplied by vcc3v3_sys
[ 0.826363] LDO_REG5: supplied by vcc3v3_sys
[ 0.827390] LDO_REG6: supplied by vcc3v3_sys
[ 0.828477] LDO_REG7: supplied by vcc3v3_sys
[ 0.828676] vcc0v9i_hdmi: Bringing 1800000uV into 900000-900000uV
[ 0.829706] LDO_REG8: supplied by vcc3v3_sys
[ 0.830768] SWITCH_REG1: supplied by vcc3v3_sys
[ 0.831170] SWITCH_REG2: supplied by vcc3v3_sys
[ 0.834854] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 0.835385] rk808 0-001b: Can not read property pmic,stby-gpio
[ 0.835449] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80097fc000
[ 0.836138] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80097fe000
[ 0.836844] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80098ca000
[ 0.838326] fusb302 7-0022: Can’t get property of role, set role to default DRP
[ 1.063806] fusb302 7-0022: fusb302 send extcon to disable vbus 5v
[ 1.396788] rk3x-i2c ff160000.i2c: unexpected irq in STOP: 0x90
[ 3.157055] rk3x-i2c ff160000.i2c: unexpected irq in STOP: 0x90
[ 3.805953] rk3x-i2c ff160000.i2c: unexpected irq in STOP: 0x90
[ 4.133109] rk3x-i2c ff160000.i2c: unexpected irq in STOP: 0x90
[ 4.670635] rk3x-i2c ff160000.i2c: unexpected irq in STOP: 0x90
[ 5.203523] rk3x-i2c ff160000.i2c: unexpected irq in STOP: 0x90
[ 5.523321] rk3x-i2c ff160000.i2c: unexpected irq in STOP: 0x90
[ 5.841443] rk3x-i2c ff160000.i2c: unexpected irq in STOP: 0x90
[ 5.852793] fusb302 7-0022: port 1 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 6.060709] mp8859 7-0066: failed to set slew_rate
[ 6.060755] mp8859 7-0066: register ext0 dev0
[ 6.060932] mp8859 7-0066: mp8859 probe successful
[ 6.060973] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff80098cc000
[ 6.062300] IR NEC protocol handler initialized
[ 6.062340] IR RC5(x/sz) protocol handler initialized
[ 6.062357] IR RC6 protocol handler initialized
[ 6.062374] IR JVC protocol handler initialized
[ 6.062388] IR Sony protocol handler initialized
[ 6.062403] IR SANYO protocol handler initialized
[ 6.062417] IR Sharp protocol handler initialized
[ 6.062432] IR MCE Keyboard/mouse protocol handler initialized
[ 6.062448] IR XMP protocol handler initialized
[ 6.062727] usbcore: registered new interface driver uvcvideo
[ 6.062757] USB Video Class driver (1.1.1)
[ 6.062777] CamSys driver version: v0.41.0, CamSys head file version: v1.0.0
[ 6.068526] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 6.068730] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 6.069076] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 6.069207] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 6.069685] cw_bat_probe cw_init error
[ 6.072974] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 6.073970] device-mapper: uevent: version 1.0.3
[ 6.074394] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 6.074662] Bluetooth: HCI UART driver ver 2.3
[ 6.074684] Bluetooth: HCI UART protocol H4 registered
[ 6.074693] Bluetooth: HCI UART protocol LL registered
[ 6.074710] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 6.074718] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 6.074726] rtk_btusb: Register usb char device interface for BT driver
[ 6.075088] usbcore: registered new interface driver rtk_btusb
[ 6.075739] cpu cpu0: cpu_leakage=20
[ 6.075837] cpu cpu0: cpu_leakage=20
[ 6.088668] cpu cpu0: temp=32777, pvtm=148067 (149102 + -1035)
[ 6.089468] cpu cpu4: cpu_leakage=35
[ 6.089571] cpu cpu4: cpu_leakage=35
[ 6.101892] cpu cpu4: temp=32777, pvtm=155515 (156154 + -639)
[ 6.107759] sdhci: Secure Digital Host Controller Interface driver
[ 6.107803] sdhci: Copyright(c) Pierre Ossman
[ 6.107819] Synopsys Designware Multimedia Card Interface Driver
[ 6.109142] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 6.109338] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 6.109382] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 6.109457] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 6.109505] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 6.110083] vccio_sd: unsupportable voltage range: 3300000-3000000uV
[ 6.110135] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 6.110151] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 6.121535] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 6.135969] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 6.136446] sdhci-pltfm: SDHCI platform and OF driver helper
[ 6.138479] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 6.138515] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 6.164900] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 6.168741] hidraw: raw HID events driver (C) Jiri Kosina
[ 6.171340] usbcore: registered new interface driver usbhid
[ 6.171357] usbhid: USB HID core driver
[ 6.171538] inv_mpu_iio: inv_mpu_init:746
[ 6.172205] ashmem: initialized
[ 6.173978] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 6.176441] ff100000.saradc supply vref not found, using dummy regulator
[ 6.178969] rknandbase v1.2 2018-05-08
[ 6.179958] usbcore: registered new interface driver snd-usb-audio
[ 6.186605] u32 classifier
[ 6.186670] Actions configured
[ 6.186725] Netfilter messages via NETLINK v0.30.
[ 6.186818] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 6.187345] ctnetlink v0.93: registering with nfnetlink.
[ 6.188410] xt_time: kernel timezone is -0000
[ 6.189488] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.189830] arp_tables: (C) 2002 David S. Miller
[ 6.190254] Initializing XFRM netlink socket
[ 6.190876] NET: Registered protocol family 10
[ 6.192169] mip6: Mobile IPv6
[ 6.192219] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 6.193595] sit: IPv6 over IPv4 tunneling driver
[ 6.194240] NET: Registered protocol family 17
[ 6.194307] NET: Registered protocol family 15
[ 6.194359] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 6.194993] Bridge firewalling registered
[ 6.195032] Ebtables v2.0 registered
[ 6.195334] Bluetooth: RFCOMM TTY layer initialized
[ 6.195362] Bluetooth: RFCOMM socket layer initialized
[ 6.195403] Bluetooth: RFCOMM ver 1.11
[ 6.195460] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.195491] Bluetooth: BNEP filters: protocol multicast
[ 6.195507] Bluetooth: BNEP socket layer initialized
[ 6.195522] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.195547] Bluetooth: HIDP socket layer initialized
[ 6.195605] l2tp_core: L2TP core driver, V2.0
[ 6.195629] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 6.195645] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 6.196124] [BT_RFKILL]: Enter rfkill_rk_init
[ 6.196618] sensor_register_slave:mpu6500_gyro,id=49
[ 6.196642] sensor_register_slave:mpu6880_gyro,id=50
[ 6.198594] Registered cp15_barrier emulation handler
[ 6.198712] Registered setend emulation handler
[ 6.199930] registered taskstats version 1
[ 6.200949] rockchip ion idev is NULL
[ 6.200988] rga2 ff680000.rga: rga ion client create success!
[ 6.201270] rga: Driver loaded successfully ver:3.02
[ 6.202993] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 6.203024] phy phy-ff770000.syscon:usb2-phy@e450.2: Failed to get VBUS supply regulator
[ 6.204625] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 6.204662] phy phy-ff770000.syscon:usb2-phy@e460.4: Failed to get VBUS supply regulator
[ 6.206288] mmc1: MAN_BKOPS_EN bit is not set
[ 6.206904] rockchip-drm display-subsystem: defer getting devfreq
[ 6.207200] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 6.207439] rockchip-vop ff900000.vop: unable to request PWM
[ 6.207468] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 6.207510] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 6.207680] rockchip-vop ff8f0000.vop: unable to request PWM
[ 6.207696] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 6.208210] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 6.208252] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 6.208371] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 6.213515] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 6.213992] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 6.214511] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 6.214563] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 6.214578] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 6.214586] [drm] No driver support for vblank timestamp query.
[ 6.214969] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 6.215002] rockchip-drm display-subsystem: can’t not find any loader display
[ 6.215039] rockchip-drm display-subsystem: failed to show loader logo
[ 6.215200] Freeing drm_logo memory: 820K
[ 6.215217] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 6.215229] [drm] Cannot find any crtc or sizes - going 1024x768
[ 6.219867] rockchip-drm display-subsystem: fb0: frame buffer device
[ 6.224965] mmc1: new HS400 MMC card at address 0001
[ 6.226059] mmcblk1: mmc1:0001 Q2J55L 7.09 GiB
[ 6.226695] mmcblk1boot0: mmc1:0001 Q2J55L partition 1 16.0 MiB
[ 6.227452] mmcblk1boot1: mmc1:0001 Q2J55L partition 2 16.0 MiB
[ 6.228009] mmcblk1rpmb: mmc1:0001 Q2J55L partition 3 4.00 MiB
[ 6.228579] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 6.228599] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 6.228608] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 6.228618] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 6.228627] resource: 0x001000000 – 0x002000000 (16 MB)
[ 6.228636] kernel: 0x002000000 – 0x004000000 (32 MB)
[ 6.228645] boot: 0x004000000 – 0x006000000 (32 MB)
[ 6.228653] recovery: 0x006000000 – 0x00a000000 (64 MB)
[ 6.228662] backup: 0x00a000000 – 0x011000000 (112 MB)
[ 6.228671] security: 0x011000000 – 0x011400000 (4 MB)
[ 6.228679] cache: 0x011400000 – 0x031400000 (512 MB)
[ 6.228709] system: 0x031400000 – 0x0d1400000 (2560 MB)
[ 6.228718] metadata: 0x0d1400000 – 0x0d2400000 (16 MB)
[ 6.228727] vendor: 0x0d2400000 – 0x0f2400000 (512 MB)
[ 6.228736] oem: 0x0f2800000 – 0x112800000 (512 MB)
[ 6.228745] frp: 0x112800000 – 0x112880000 (0 MB)
[ 6.228754] userdata: 0x112880000 – 0x1c5c00000 (2867 MB)
[ 6.228856] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 6.242873] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 6.243272] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 1
[ 6.243746] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 6.243841] xhci-hcd xhci-hcd.11.auto: irq 228, io mem 0xfe800000
[ 6.244094] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.244129] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.244148] usb usb1: Product: xHCI Host Controller
[ 6.244184] usb usb1: Manufacturer: Linux 4.4.126 xhci-hcd
[ 6.244201] usb usb1: SerialNumber: xhci-hcd.11.auto
[ 6.245095] hub 1-0:1.0: USB hub found
[ 6.245169] hub 1-0:1.0: 1 port detected
[ 6.245689] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 6.245959] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 2
[ 6.246090] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 6.246273] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 6.246305] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.246324] usb usb2: Product: xHCI Host Controller
[ 6.246342] usb usb2: Manufacturer: Linux 4.4.126 xhci-hcd
[ 6.246360] usb usb2: SerialNumber: xhci-hcd.11.auto
[ 6.247192] hub 2-0:1.0: USB hub found
[ 6.247264] hub 2-0:1.0: 1 port detected
[ 6.249863] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 6.249921] usb usb2: USB disconnect, device number 1
[ 6.278749] xhci-hcd xhci-hcd.11.auto: Host not halted after 16000 microseconds.
[ 6.278823] xhci-hcd xhci-hcd.11.auto: Host controller not halted, aborting reset.
[ 6.278904] xhci-hcd xhci-hcd.11.auto: USB bus 2 deregistered
[ 6.279108] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 6.279156] usb usb1: USB disconnect, device number 1
[ 6.279590] xhci-hcd xhci-hcd.11.auto: USB bus 1 deregistered
[ 6.284695] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 6.285124] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 1
[ 6.285495] xhci-hcd xhci-hcd.12.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 6.285593] xhci-hcd xhci-hcd.12.auto: irq 229, io mem 0xfe900000
[ 6.285748] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.285795] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.285806] usb usb1: Product: xHCI Host Controller
[ 6.285816] usb usb1: Manufacturer: Linux 4.4.126 xhci-hcd
[ 6.285825] usb usb1: SerialNumber: xhci-hcd.12.auto
[ 6.286408] hub 1-0:1.0: USB hub found
[ 6.286480] hub 1-0:1.0: 1 port detected
[ 6.286765] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 6.287069] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 2
[ 6.287140] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 6.287274] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 6.287286] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.287296] usb usb2: Product: xHCI Host Controller
[ 6.287306] usb usb2: Manufacturer: Linux 4.4.126 xhci-hcd
[ 6.287315] usb usb2: SerialNumber: xhci-hcd.12.auto
[ 6.288235] hub 2-0:1.0: USB hub found
[ 6.288333] hub 2-0:1.0: 1 port detected
[ 6.288845] xhci-hcd xhci-hcd.12.auto: remove, state 1
[ 6.288905] usb usb2: USB disconnect, device number 1
[ 6.289717] xhci-hcd xhci-hcd.12.auto: USB bus 2 deregistered
[ 6.290116] xhci-hcd xhci-hcd.12.auto: remove, state 1
[ 6.290179] usb usb1: USB disconnect, device number 1
[ 6.290711] xhci-hcd xhci-hcd.12.auto: USB bus 1 deregistered
[ 6.294925] ehci-platform fe380000.usb: EHCI Host Controller
[ 6.295300] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 6.295540] ehci-platform fe380000.usb: irq 27, io mem 0xfe380000
[ 6.305075] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 6.305302] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.305351] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.305361] usb usb1: Product: EHCI Host Controller
[ 6.305371] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[ 6.305380] usb usb1: SerialNumber: fe380000.usb
[ 6.306256] hub 1-0:1.0: USB hub found
[ 6.306354] hub 1-0:1.0: 1 port detected
[ 6.310647] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 6.311193] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 6.311539] ehci-platform fe3c0000.usb: irq 29, io mem 0xfe3c0000
[ 6.321694] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 6.321944] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.321981] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.322006] usb usb2: Product: EHCI Host Controller
[ 6.322044] usb usb2: Manufacturer: Linux 4.4.126 ehci_hcd
[ 6.322067] usb usb2: SerialNumber: fe3c0000.usb
[ 6.323505] hub 2-0:1.0: USB hub found
[ 6.323637] hub 2-0:1.0: 1 port detected
[ 6.325477] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 6.326275] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 6.326643] ohci-platform fe3a0000.usb: irq 28, io mem 0xfe3a0000
[ 6.382591] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 6.382666] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.382692] usb usb3: Product: Generic Platform OHCI controller
[ 6.382715] usb usb3: Manufacturer: Linux 4.4.126 ohci_hcd
[ 6.382737] usb usb3: SerialNumber: fe3a0000.usb
[ 6.384170] hub 3-0:1.0: USB hub found
[ 6.384296] hub 3-0:1.0: 1 port detected
[ 6.386098] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 6.386935] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 6.387306] ohci-platform fe3e0000.usb: irq 30, io mem 0xfe3e0000
[ 6.442811] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 6.442907] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.442933] usb usb4: Product: Generic Platform OHCI controller
[ 6.442957] usb usb4: Manufacturer: Linux 4.4.126 ohci_hcd
[ 6.442979] usb usb4: SerialNumber: fe3e0000.usb
[ 6.444528] hub 4-0:1.0: USB hub found
[ 6.444619] hub 4-0:1.0: 1 port detected
[ 6.447277] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 6.447625] rockchip-dmc dmc: could not find power_model node
[ 6.449010] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[ 6.449086] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to add ELD: -16
[ 6.450153] rk-hdmi-dp-sound hdmi-dp-sound: multicodec ↔ ff8a0000.i2s mapping ok
[ 6.450347] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to create Playback debugfs file
[ 6.455893] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:08 UTC (1358499008)
[ 6.458446] It doesn’t contain Rogue gpu
[ 6.493643] vcc_sd: disabling
[ 6.606305] u?
[ 6.704262] vendor storage:20160801 ret = 0
请问有谁遇到过这样的问题,打印到这里就死机了,进不去系统,谢谢
已经准备进安卓系统桌面了,把不用的,你板上没有的设备删掉
否则系统报错太多就蹦了
我QQ254327173,欢迎加聊
