rk3308-cc 编译出错
Resizing the filesystem on /home/project/arm/4-rk3308/buildroot/output/firefly_rk3308_recovery/images/rootfs.ext2 to 17221 (4k) blocks.
The filesystem on /home/project/arm/4-rk3308/buildroot/output/firefly_rk3308_recovery/images/rootfs.ext2 is now 17221 (4k) blocks long.
fsck /home/project/arm/4-rk3308/buildroot/output/firefly_rk3308_recovery/images/rootfs.ext2
fsck from util-linux 2.27.1
e2fsck 1.42.13 (17-May-2015)
e2fsck: need terminal for interactive repairs
fs/ext2/ext2.mk:57: recipe for target ‘/home/project/arm/4-rk3308/buildroot/output/firefly_rk3308_recovery/images/rootfs.ext2’ failed
make[1]: *** [/home/project/arm/4-rk3308/buildroot/output/firefly_rk3308_recovery/images/rootfs.ext2] Error 8
make: *** [_all] Error 2
/home/project/arm/4-rk3308/buildroot/output/firefly_rk3308_recovery/Makefile:16: recipe for target ‘_all’ failed
====Build recovery failed!====
you take 0:09.63 to build recovery
如上,是错误Log, 编译是使用./FFTools/DockerCook/DKCook ./build.sh 进行编译的。
好兄弟,这个问题你是怎么解决的?
